sgxComposite error
Hi ,
We're seen an error log : "sgxComposite error" on our board when running an application:
What does this mean?   Log files pasted below. (you can search for the 5 items listed below to take you to the beginning of the log in the content pasted below,
  1.  Kernel Startup Log
  2.  Script to start X
  3.  X Startup Log
  4.  Xorg Log
  5.  application log
Sojan
->>>>>--Kernel Startup Log-------------------------------------------------------
IPL: 9905 (B0 sample, CPU PG2.1), 720/570/400 MHz (ARM/DSP/DDR); RAM: 1024 MB
[ver.11364A, built 2011-09-08 17:12:57 2252815+]
IOC boot mode: ....
Entering CLI, type '?' for help
=> go 8020000
*** unknown/unsupported image type #0 at 0x8020000
U-Boot 2010.06 (Sep 09 2011 - 17:45:11)
I2C:   ready
DRAM:  2 GiB
Flash: 64 MiB
                          .:;rrr;;.
                    ,5#@@@@#####@@@@@@#2,
                 ,A@@@hi;;;r5;;;;r;rrSG@@@A,
               r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
             :@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
            B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
           @@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
          @@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
         @@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
        G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
        @9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
       X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
       @#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
       @A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
       @&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
       @#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
       M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
       :@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
        @@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
         @A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
         ;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
          r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
           ,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
             B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
              .@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
                .A@@#5r;;;r;;;rrr;r:r#AsM@@H.
                   ;&@@@@MhXS5i5SX9B@@@@G;
                       :ihM#@@@@@##hs,
Hit any key to stop autoboot:  0
mmc1 is available
reading uImage
2308900 bytes read
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-2.6.37
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2308836 Bytes = 2.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpuset
Linux version 2.6.37 (phoenix@ubuntu) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #2 Wed Nov 30 09:06:23 PST 2011
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148-Phoenix
vram size = 52428800 at 0
reserved size = 52428800 at 0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is TI8148 2.0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 52224
Kernel command line: console=ttyO0,115200n8 rootwait root=/dev/mmcblk0p2 rw mem=256M earlyprink vram=50M ip=off noinitrd notifyk.vpssm3_sva=0x8DB00000  noinitrd init=/bin/systemd systemd.unit=phoenix.target
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 206MB = 206MB total
Memory: 203712k/203712k available, 58432k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0033000   ( 172 kB)
      .text : 0xc0033000 - 0xc0468000   (4308 kB)
      .data : 0xc0468000 - 0xc04a1a00   ( 231 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 719.25 BogoMIPS (lpj=3596288)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys ns
ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
Initializing cgroup subsys cpuacct
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
MMC2: gpio0_5 <-- OMAP_PIN_OUTPUTMMC3: gpio0_14_mux1 <-- OMAP_PIN_OUTPUT
registered ti814x_vpss device
pm_dbg_init: only OMAP3 supported
Registered ti81xx_fb device
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
omap_i2c omap_i2c.2: bus 2 rev4.0 at 100 kHz
i2c i2c-2: Invalid 7-bit I2C address 0x00
i2c i2c-2: Can't create device at 0x00
omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
omap_i2c omap_i2c.4: bus 4 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at d080c000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.15)
Btrfs loaded
msgmni has been set to 397
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
mtdoops: mtd device (mtddev=name/number) must be supplied
physmap platform flash device: 08000000 at 08000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x002301
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
RedBoot partition parsing not available
Using physmap partition information
Creating 4 MTD partitions on "physmap-flash.0":
0x000000080000-0x000000480000 : "Kernel-em"
ftl_cs: FTL header not found.
0x000000480000-0x000000880000 : "Filesystem-em"
0x000000880000-0x000000c80000 : "Kernel"
0x000000c80000-0x000003e80000 : "Filesystem"
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
notify_init : notify drivercreated  for  remote proc id 2 at physical Address 0x8db00000
usbcore: registered new interface driver snd-usb-audio
phoenix_dummy-codec  ALSA SoC Codec Driver init
phoenix_dummy_probe
codec register phoenix_dummy-codec
snd_soc_register_codec ret =0
Registered ti81xx_snd_soc_card
platform_set_drvdata
asoc: phoenix_dummy-hifi <-> davinci-mcasp.0 mapping ok
 platform_device_add
ALSA device list:
  #0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Waiting for root device /dev/mmcblk0p2...
mmc1: new SD card at address aaaa
mmcblk0: mmc1:aaaa SD02G 1.84 GiB
 mmcblk0: p1 p2
EXT3-fs: barriers not enabled
mmc2: new high speed SDIO card at address 0001
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 172K
<30>systemd[1]: systemd 26 running in system mode. (-PAM +LIBWRAP -AUDIT -SELINUX +SYSVINIT -LIBCRYPTSETUP; debian)
Welcome to Linux!
NET: Registered protocol family 10
<28>systemd[1]: /sbin/modprobe failed with error code 1.
<30>systemd[1]: Set hostname to <omap3evm>.
<27>systemd[1]: Failed to fully start up daemon: No such file or directory
Starting Getty on TTY0...
Started Getty on TTY0.
Starting DLT Daemon for logging and tracing...
Starting udev Kernel Device Manager...
                                      Starting Syslog daemon...
                                                               Starting Syslog Kernel Log Buffer Bridge...
        Started Syslog Kernel Log Buffer Bridge.
        Starting D-Bus Session Message Bus...
        Starting Stdio Syslog Bridge...
        Started Stdio Syslog Bridge.
     Starting Hostname Service...
                                 Starting D-Bus System Message Bus...
        Started Syslog daemon.
        Starting Klog daemon...
        Started Klog daemon.
        Started DLT Daemon for logging and tracing.
        <29>DLT[49]: DLT| NOTICE:    Starting DLT Daemon; DLT Package Version: 2.4.0 , Package Revision: , build on Nov  3 2011 12:03:03
Started D-Bus System Message Bus.
                                 Started udev Kernel Device Manager.
        Started D-Bus Session Message Bus.
        Starting tuner_service...
        Started tuner_service.
        Starting udev Coldplug all Devices...
omap3evm login: root
root@omap3evm:~#
root@omap3evm:~#
root@omap3evm:~#
->>>>>--End Kernel Startup Log-------------------------------------------------------
->>>>>--Script to start X-------------------------------------------------------
echo "Loading kernel modules "
modprobe syslink.ko
/bin/slaveloader startup VPSS-M3 /bin/ti814x_hdvpss_512M.xem3
modprobe vpss
modprobe ti81xxfb
echo 0 > /sys/devices/platform/vpss/graphics0/enabled
echo 1:dvo2 > /sys/devices/platform/vpss/graphics0/nodes
echo 1 > /sys/devices/platform/vpss/graphics0/enabled
echo 0 > /sys/devices/platform/vpss/display1/enabled
echo 33500,800/88/100/44,480/4/36/5,1 > /sys/devices/platform/vpss/display1/timings
echo triplediscrete,rgb888 > /sys/devices/platform/vpss/display1/output
echo 1 > /sys/devices/platform/vpss/display1/enabled
fbset -xres 800 -yres 480 -rgba 8,8,8,0 -vxres 800 -vyres 480 -depth 32
RM_SGX_RSTCTRL=0x48180F04
CM_SGX_CLKSTCTRL=0x48180900
CM_SGX_SGX_CLKCTRL=0x48180920
/etc/init.d/devmem2 $RM_SGX_RSTCTRL w 0x0     # Bring SGX out of reset
/etc/init.d/devmem2 $CM_SGX_CLKSTCTRL w 0x2   # Enable the SGX clocks
/etc/init.d/devmem2 $CM_SGX_SGX_CLKCTRL w 0x2 # Bring SGX out of idle
# while((RD_MEM_32(CM_SGX_SGX_CLKCTRL)) != 0x00040002);           //Wait for SGX to come out of idle
#sleep 2
modprobe pvrsrvkm
#!/bin/sh
echo "Starting X "
echo "************"
# Start the X Server.
# The X Server will load the PVR Services module.
/usr/bin/X -verbose -config /etc/X11/xorg.conf &
if ! /usr/local/bin/pvrsrvinit; then return; fi
echo "Loaded PowerVR consumer services."
return 0;
->>>>>--End Script to start X-------------------------------------------------------
->>>>>--X Startup Log -------------------------------------------------------
root@omap3evm:~# ./StartX.sh
Attached to slave procId 2.
Loaded file /bin/ti814x_hdvpss_512M.xem3 on slave procId 2.
Started slave procId 2.
/dev/mem opened.
Memory mapped at address 0x4011a000.
Value at address 0x48180F04 (0x4011af04): 0x1
Written 0x0; readback 0x0
/dev/mem opened.
Memory mapped at address 0x403ec000.
Value at address 0x48180900 (0x403ec900): 0x2
Written 0x2; readback 0x2
/dev/mem opened.
Memory mapped at address 0x40095000.
Value at address 0x48180920 (0x40095920): 0x70000
Starting X
X.Org X Server 1.7.5
Release Date: 2010-02-16
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32-33-generic i686
Current Operating System: Linux omap3evm 2.6.37 #2 Wed Nov 30 09:06:23 PST 2011 armv7l
Build Date: 26 October 2011  02:25:05AM
Current version of pixman: 0.21.6
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan  1 00:08:13 1970
(++) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "X.org Configured"
(**) |-->Screen "Screen" (0)
(**) |   |-->Monitor "<default monitor>"
(**) |   |-->Device "Video Device"
(==) No monitor specified for screen "Screen".
        Using a default monitor configuration.
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Not automatically adding devices
(==) Not automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/Type1/" does not exist.
        Entry deleted from font path.
(WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
(WW) The directory "/usr/share/fonts/X11/misc/" does not exist.
(WW) The directory "/usr/share/fonts/X11/util/" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/truetype/".
        (Run 'mkfontdir' on "/usr/share/fonts/truetype/").
(WW) The directory "/usr/share/fonts/X11/misc" does not exist.
(**) FontPath set to:
(**) ModulePath set to "/usr/lib/xorg/modules"
(--) using VT number 2
(II) "extmod" will be loaded. This was enabled by default and also specified in the config file.
(II) "glx" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri" will be loaded. This was enabled by default and also specified in the config file.
(II) "dri2" will be loaded by default.
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 1.0.0
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
dlopen: /usr/lib/xorg/modules/extensions/libdbe.so: undefined symbol: noDbeExtension
(EE) Failed to load /usr/lib/xorg/modules/extensions/libdbe.so
(EE) Failed to load module "dbe" (loader failed, 7)
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
        compiled for 1.9.4, module version = 1.13.0
(EE) module ABI major version (4) doesn't match the server's version (2)
(II) Unloading /usr/lib/xorg/modules/extensions/librecord.so
(EE) Failed to load module "record" (module requirement mismatch, 0)
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 1.1.0
(II) Loading /usr/lib/xorg/modules/drivers/pvr_drv.so
(II) Module PVR: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 1.6.4117
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 1.7.0
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 1.6.0
(II) pvr: Driver for PowerVR chipsets: PowerVR SGX
(WW) Falling back to old probe method for pvr
root@omap3evm:~# (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
(II) pvr(0): Creating default Display subsection in Screen section
        "Screen" for depth/fbbpp 24/32
(==) pvr(0): Depth 24, (==) framebuffer bpp 32
(==) pvr(0): RGB weight 888
(==) pvr(0): Default visual is TrueColor
(==) pvr(0): Using gamma correction (1.0, 1.0, 1.0)
(--) pvr(0): Virtual size is 800x480 (pitch 800)
(**) pvr(0):  Built-in mode "800x480"
(==) pvr(0): DPI set to (96, 96)
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
(II) pvr(0): [pvr] Software copy threshold : 0B
(II) pvr(0): [pvr] Software solid threshold : 0B
(II) pvr(0): [pvr] Software composite threshold : 1024B
(II) pvr(0): [pvr] Pixmap pool size: 1B
(II) Loading /usr/lib/xorg/modules/libexa.so
(II) Module exa: vendor="X.Org Foundation"
        compiled for 1.7.5, module version = 2.5.0
PVRPreInit: done
(--) Depth 24 pixmap format is 32 bpp
PVRScreenInit
(II) pvr(0): [DRI2] Setup complete
(II) EXA(0): Driver allocated offscreen pixmaps
(II) EXA(0): Driver registered support for the following operations:
(II)         Solid
(II)         Copy
(II)         Composite (RENDER acceleration)
(==) pvr(0): Backing store disabled
(==) pvr(0): Silken mouse enabled
(==) pvr(0): Direct rendering enabled
(EE) pvr(0): PVRDisplayCommandNoArgs: drmCommandWrite failed (-22)
(EE) pvr(0): PVRDisplayScreenInitFinalize: PVRDisplayCommandNoArgs failed (-22)
PVRScreenInit: done
(==) RandR enabled
(II) AIGLX: Loaded and initialized /usr/lib/dri/swrast_dri.so
(II) GLX: Initialized DRISWRAST GL provider for screen 0
(WW) Mouse0: No Device specified, looking for one...
(II) Mouse0: Setting Device option to "/dev/input/mice"
(--) Mouse0: Device: "/dev/input/mice"
(==) Mouse0: Protocol: "Auto"
(**) Mouse0: always reports core events
(==) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Mouse0: ZAxisMapping: buttons 4, 5, 6 and 7
(**) Mouse0: Buttons: 11
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(**) Mouse0: (accel) keeping acceleration scheme 1
(**) Mouse0: (accel) acceleration profile 0
(II) Mouse0: Setting mouse protocol to "ExplorerPS/2"
(II) Mouse0: ps2EnableDataReporting: succeeded
(**) Keyboard0: always reports core events
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
->>>>>--End X Startup Log-------------------------------------------------------
->>>>>--Xorg Log-------------------------------------------------------
root@omap3evm:~# cat /var/log/Xorg.0.log
(**) Option "DontZap" "off"
(**) Option "AutoAddDevices" "off"
(II) Loader magic: 0x19d7cc
(II) Module ABI versions:
        X.Org ANSI C Emulation: 0.4
        X.Org Video Driver: 6.0
        X.Org XInput driver : 7.0
        X.Org Server Extension : 2.0
(II) LoadModule: "extmod"
        Module class: X.Org Server Extension
        ABI class: X.Org Server Extension, version 2.0
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) UnloadModule: "dbe"
(II) LoadModule: "glx"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
        ABI class: X.Org Server Extension, version 4.0
(II) UnloadModule: "record"
(II) LoadModule: "dri"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading extension DRI2
(II) LoadModule: "pvr"
        Module class: X.Org Video Driver
        ABI class: X.Org Video Driver, version 6.0
(II) LoadModule: "mouse"
        Module class: X.Org XInput Driver
        ABI class: X.Org XInput driver, version 7.0
(II) LoadModule: "kbd"
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 6, (OK)
drmGetBusid returned ''
drmOpenDevice: open result is 7, (OK)
drmGetBusid returned 'pci:0000:00:00.0'
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
drmOpenDevice: node name is /dev/dri/card15
drmOpenByBusid: Searching for BusID pci:0000:00:00.0
drmOpenByBusid: drmOpenMinor returns 7
drmOpenByBusid: Interface 1.4 failed, trying 1.1
drmOpenByBusid: drmGetBusid reports pci:0000:00:00.0
(**) pvr(0): Option "NoAccel" "false"
(**) pvr(0): Option "FlipChain" "true"
(II) Loading sub module "fb"
(II) LoadModule: "fb"
        ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "dri2"
(II) Reloading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Loading sub module "exa"
(II) LoadModule: "exa"
PVRPreInit: done
PVRScreenInit
(II)         Solid
(II)         Copy
PVRScreenInit: done
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(**) Option "CorePointer"
(**) Option "Device" "/dev/input/mice"
(**) Option "ZAxisMapping" "4 5 6 7"
(**) Option "CoreKeyboard"
(**) Option "Protocol" "standard"
(**) Option "XkbRules" "base"
(**) Option "XkbModel" "pc105"
(**) Option "XkbLayout" "us"
(**) Option "XkbOptions" "terminate:ctrl_alt_bksp"
sgxComposite: failed to do composition
(II) UnloadModule: "mouse"
(II) UnloadModule: "kbd"
PVRScreenInit
(II)         Solid
(II)         Copy
PVRScreenInit: done
(==) RandR enabled
->>>>>--End Xorg Log-------------------------------------------------------
->>>>>--application log -------------------------------------------------------
root@omap3evm:~# PVRScreenInit
(II)         Solid
(II)         Copy
PVRScreenInit: done
(==) RandR enabled
root@omap3evm:~# (WW) Mouse0: No Device specified, looking for one...
->>>>>--application log-------------------------------------------------------
  • root@omap3evm:~# ./gfx_check.sh
    WSEGL settings
    [default]
    WindowSystem=libpvrPVR2D_DRIWSEGL.so
    #WindowSystem=libpvrPVR2D_FLIPWSEGL.so
    ARM CPU information
    Processor       : ARMv7 Processor rev 2 (v7l)
    BogoMIPS        : 719.25
    Features        : swp half thumb fastmult vfp edsp neon vfpv3
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant     : 0x3
    CPU part        : 0xc08
    CPU revision    : 2
    Hardware        : ti8148-Phoenix
    Revision        : 0000
    Serial          : 0000000000000000
    SGX driver information
    Version 1.6.16.4117 (release) /home/phoenix/Perforce/ti_ezsdk_phoenix_kernel_dev/Graphics_SDK_4_04_00_03/GFX_Linux_KM
    System Version String: SGX revision = 1.2.5
    Framebuffer settings
    mode "800x480-62"
        # D: 33.501 MHz, H: 32.462 kHz, V: 61.832 Hz
        geometry 800 480 800 480 32
        timings 29850 100 88 36 4 44 5
        rgba 8/16,8/8,8/0,8/24
    endmode
    Frame buffer device information:
        Address     : 0x8ce00000
        Type        : PACKED PIXELS
        Visual      : TRUECOLOR
        XPanStep    : 1
        YPanStep    : 1
        YWrapStep   : 0
        LineLength  : 3200
        Accelerator : No
    Rotation settings
    0
    Kernel Module information
    Module                  Size  Used by    Not tainted
    pvrsrvkm              162972  2
    drm                   129840  3 pvrsrvkm
    ti81xxfb               20647  1
    vpss                   60930  2 pvrsrvkm,ti81xxfb
    syslink              1111820  0
    asix                   11418  0
    usbnet                 12182  1 asix
    mii                     3288  2 asix,usbnet
    ipv6                  212009  8
    Boot settings
    Linux Kernel version
    Linux omap3evm 2.6.37 #2 Wed Nov 30 09:06:23 PST 2011 armv7l GNU/Linux
    root@omap3evm:~#
