TDA4VH-Q1: How to sign the TIFS binary if we were using SBL bootflow?
Part Number: TDA4VH-Q1
            Please tell us how to sign the TIFS binary with the Custom keys?
Sriram
  • Hi Sriram,
    When you say how to sigen TIFS binary i assume you want to sign the outer certificate of the TIFS.
    The PDK code has a firmwareHeaderGen.sh script available in pdk_j784s4_10_01_00_25/packages/ti/drv/sciclient/tools folder that can be used to generate the needed TIFS binary for HS-SE.
    You can use the following commands, this does use the keys as mentioned above.
    $ cd pdk_j784s4_10_01_00_25/packages/ti/drv/sciclient/tools
    $ ./firmwareHeaderGen.sh j784s4-hs
    This will generate the TIFS HS-SE binary as pdk_j784s4_10_01_00_25/packages/ti/drv/sciclient/soc/V6/tifs-hs-enc.bin, that needs to be used as the final TIFS binary on your HS-SE device.
    Diwakar
