Other Parts Discussed in Thread: AM62P
Dear expert.
local customer is doing EMC test w/ their AM62P product.
they found high power emitted on Y5 pin, cause the test failure. emit Frequency is 1.6GHz.
1. This pin belongs to EMIF I/F, external resistance must be added. So it cannot be routed from the inner layer.
2. customer use K3conf to check clocks, there are a lot of 800MHz/400MHz clocks, for example, MCU_R5F/GPU frequency. These core/HWA can not be shut down or change frequency.
may I ask your help to give suggestion to reduce the radiation intensity of this pin?
thanks a lot!
yong
