AM625: Run multiple serial ports simultaneously and toggle the wired NIC to introduce interference.
Part Number: AM625
SDK10.00.07.04  Kernel version 6.6.32
1.Main Test Item: Simultaneously operating 4 serial ports at 460800 baud and 1 serial port at 115200 baud
serialcheck -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d &
serialcheck -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d &
serialcheck -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d &
serialcheck -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d &
serialcheck -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d &
2.Interference Test Item: Toggling the wired network interface card (NIC)
./eth_up_down.sh &
#!/bin/sh
for (( ; ; ))
do
ifconfig eth0 down
sleep 1
ifconfig eth0 up
sleep 1
done
3.Test Result: The serialcheck serial port test program has stopped
    1. Applied the following patch.
      diff --git a/drivers/tty/serial/8250/8250_omap.c b/drivers/tty/serial/8250/8250_omap.c
      index 0b9c47172bc8..0952f08622c9 100644
      --- a/drivers/tty/serial/8250/8250_omap.c
      +++ b/drivers/tty/serial/8250/8250_omap.c
      @@ -1042,6 +1042,10 @@ static int omap_8250_tx_dma(struct uart_8250_port *p)
              unsigned int    skip_byte = 0;
              int ret;
      +       /* HACK: do not use DMA for TX */
      +       ret = -EINVAL;
      +       goto err;
              if (dma->tx_running)
                      return 0;
              if (uart_tx_stopped(&p->port) || uart_circ_empty(xmit)) {
    2. Tested the serial port using serialcheck in DMA mode.
    3. Test result: All five serialcheck instances crashed.
      Similar errors are as follows:
      timeout, RX/TX: 9856/10000
      Needed 4 reads 1 writes Oh oh, inconsistency at pos 9856 (0x2680).
      Original sample:
      00002650: 62 60 f6 f1 ec 97 70 fe  32 b7 a0 14 32 e1 19 57   b`....p.2...2..W
      00002660: 14 60 e0 c3 44 ea 7a 9c  ce 1c 6f 54 e4 1f ef 89   .`..D.z...oT....
      00002670: f5 27 54 35 1d 57 b3 15  a4 c2 ed 79 da 8d 8e c6   .'T5.W.....y....
      00002680: e8 96 98 ef 5f 7b b9 12  a2 87 fc 53 50 35 7b da   ...._{.....SP5{.
      00002690: e7 8c c9 46 59 15 42 84  a3 22 0f b8 19 a9 a7 60   ...FY.B..".....`
      000026a0: dc cf a0 47 e8 b1 38 78  94 b7 fe 61 4d 30 64 74   ...G..8x...aM0dt
      Received sample:
  • Hi Fuyi,
    Please attach other console logs you have captured. I'd like to see if the messages have any pattern.
  • Can you please remind me which SDK or kernel version do you use?
  • Hi,Bin
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [70612.303998] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [70612.314215] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    root@am62xx-evm:~# reboot
    Failed to connect to bus: Connection refused
    [  OK  ] Removed slice Slice /system/modprobe.
    [  OK  ] Stopped target Graphical Interface.
    [  OK  ] Stopped target Multi-User System.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target Printer Support.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target Sound Card.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily rotation of log files.
                                                           topping Load/Save OS Random Seed...
    [  OK  ] Stopped Job spooling tools.
    [  OK  ] Stopped Periodic Command Scheduler.
    [  OK  ] Stopped Netperf Benchmark Se[  OK  ] Stopped Save/Restore Sound Card State.
    [  OK  ] Stopped Load/Save OS Random Seed.
    [  OK  ] Removed slice Slice /system/serial-getty.
             Stopping /etc/rc.local Compatibility...
             Stopping Permit User Sessions...
    [  OK  ] Stopped /etc/rc.local Compatibility.
    [  OK  ] Stopped Permit User Sessions.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
    [  OK  ] Stopped target Remote File Systems.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
    [  OK  ] Closed Weston socket.
    [  OK  ] Stopped target System Initialization.
             Stopping Network Configuration...
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting /srv...
             Unmounting Temporary Directory /tmp...
             Unmounting /usr/cm/dbBackup...
             Unmounting /usr/cm/patdata...
    [70614.030097] EXT4-fs (mmcblk0p3): unmounting filesystem 16d316d3-16d3-16d3-16d3-16d316d316d3.
             Unmounting /usr/cm/userconfig...
    [70614.081930] EXT4-fs (mmcblk0p4): unmounting filesystem 61646164-6164-6164-6164-616461646164.
    [70614.090632] EXT4-fs (mmcblk0p2): unmounting filesystem 8ad38ad3-8ad3-8ad3-8ad3-8ad38ad38ad3.
             Unmounting /var/cache...
             Unmounting /var/lib...
             Unmounting /var/spool...
             Stopping Bind mount volatile /var/cache...
             Stopping Bind mount volatile /var/lib...
             Stopping Bind mount volatile /var/spool...
             Stopping Bind mount volatile /srv...
    [  OK  ] Stopped Network Configuration.
    [  OK  ] Unmounted /srv.
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /usr/cm/dbBackup.
    [  OK  ] Unmounted /usr/cm/patdata.
    [  OK  ] Unmounted /usr/cm/userconfig.
    [  OK  ] Unmounted /var/cache.
    [  OK  ] Unmounted /var/lib.
    [  OK  ] Unmounted /var/spool.
    [  OK  ] Stopped Bind mount volatile /var/cache.
    [  OK  ] Stopped Bind mount volatile /var/lib.
    [  OK  ] Stopped Bind mount volatile /var/spool.
    [  OK  ] Stopped Bind mount volatile /srv.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Closed Network Service Netlink Socket.
             Unmounting /var/volatile...
    [  OK  ] Stopped Generate network units from Kernel command line.
    [  OK  ] Stopped Apply Kernel Variables.
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Stopped Create Static Device Nodes in /dev gracefully.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Reboot.
    [  OK  ] Reached target System Reboot.
    [70615.104467] systemd-shutdown[1]: Syncing filesystems and block devices.
    [70615.111617] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [70615.137630] systemd-journald[103]: Received SIGTERM from PID 1 (systemd-shutdow).
    [70615.165044] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [70615.184376] systemd-shutdown[1]: Unmounting file systems.
    [70615.191100] systemd-shutdown[1]: All filesystems unmounted.
    [70615.196725] systemd-shutdown[1]: Deactivating swaps.
    [70615.201785] systemd-shutdown[1]: All swaps deactivated.
    [70615.207013] systemd-shutdown[1]: Detaching loop devices.
    [70615.217799] systemd-shutdown[1]: All loop devices detached.
    [70615.223490] systemd-shutdown[1]: Stopping MD devices.
    [70615.230627] systemd-shutdown[1]: All MD devices stopped.
    [70615.236048] systemd-shutdown[1]: Detaching DM devices.
    [70615.241565] systemd-shutdown[1]: All DM devices detached.
    [70615.246981] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [70615.259162] systemd-shutdown[1]: Syncing filesystems and block devices.
    [70615.266131] systemd-shutdown[1]: Rebooting.
    [70615.303384] reboot: Restarting system
    U-Boot SPL 2024.04-00003-g0edc8b4d (Jan 03 2025 - 14:01:21 +0800)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 13392 bytes
    Trying to boot from MMC1
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    U-Boot SPL 2024.04-00003-g0edc8b4d (Jan 03 2025 - 14:01:43 +0800)
    SPL initial stack usage: 1904 bytes
    U-Boot 2024.04-00003-g0edc8b4d (Jan 03 2025 - 14:01:43 +0800)
    SoC:   AM62X SR1.0 GP
    Model: COMEN Am625 Board
    EEPROM not available at 0x50, trying to read at 0x51
    Reading on-board EEPROM at 0x51 failed -121
    DRAM:  2 GiB
    Core:  79 devices, 31 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0
    Loading Environment from nowhere... OK
        Machine    [    K15_AM62X    ]
    ** Bad device specification mmc 1 **
    Couldn't find partition mmc 1:1
    Error: could not access storage.
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Bus usb@31000000: generic_phy_get_bulk : no phys property
    Register 1000840 NbrPorts 1
    Starting the controller
    USB XHCI 1.10
    Bus usb@31100000: generic_phy_get_bulk : no phys property
    USB XHCI 1.10
    scanning bus usb@31000000 for devices... 1 USB Device(s) found
    scanning bus usb@31100000 for devices... 2 USB Device(s) found
           scanning usb for storage devices... 0 Storage Device(s) found
    UPDATEINFO:no storage device detected.
    switch to partitions #0, OK
    mmc0(part 0) is current device
    MMC read: dev # 0, block # 71680, count 1 ... 1 blocks read: OK
    MMC read: dev # 0, block # 71681, count 29 ... 29 blocks read: OK
    Uncompressed size: 8294400 = 0x7E9000
    MMC read: dev # 0, block # 20480, count 1 ... 1 blocks read: OK
    zimage_size=19012096, dtb_size=61440, zimagedtb_size=19074048
    MMC read: dev # 0, block # 20601, count 37133 ... 37133 blocks read: OK
    MMC read: dev # 0, block # 20481, count 120 ... 120 blocks read: OK
    Working FDT set to 88000000
    Host not halted after 16000 microseconds.
    ERROR: reserving fdt memory region failed (addr=ff700000 size=7e9000 flags=4)
       Loading Device Tree to 000000008ffee000, end 000000008ffffe40 ... OK
    Working FDT set to 8ffee000
    Starting kernel ...
    SoC:   AM62X SR1.0 GP
    DRAM:  2 GiB
    MMC:   mmc@fa10000: 0
    In:    serial
    Out:   serial
    Err:   serial
    USB XHCI 1.10
    USB XHCI 1.10
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.32+ (gaofuyi@ubuntu2004-92) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #183 SMP PREEMPT Sun Apr 27 14:22:22 HKT 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM625 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000f7600000..0x00000000ff5fffff (131072 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffee8fff (8100 KiB) nomap non-reusable framebuffer@ff700000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009c7fffff]
    [    0.000000]   node   0: [mem 0x000000009c800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffee8fff]
    [    0.000000]   node   0: [mem 0x00000000ffee9000-0x00000000ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.4
    [    0.000000] percpu: Embedded 20 pages/cpu s42728 r8192 d31000 u81920
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p1 rw rootfstype=ext3 rootwait
    [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 516096
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 2.
    [    0.000000] software IO TLB: mapped [mem 0x00000000f1000000-0x00000000f5000000] (64MB)
    [    0.000000] Memory: 1774424K/2097152K available (11264K kernel code, 1158K rwdata, 3820K rodata, 2176K init, 455K bss, 191656K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080440000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008621] Console: colour dummy device 80x25
    [    0.013236] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023920] pid_max: default: 32768 minimum: 301
    [    0.028750] LSM: initializing lsm=capability,integrity
    [    0.034149] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.041741] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.051921] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.059283] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
    [    0.067277] rcu: Hierarchical SRCU implementation.
    [    0.072192] rcu:     Max phase no-delay instances is 1000.
    [    0.077854] Platform MSI: msi-controller@1820000 domain created
    [    0.084660] smp: Bringing up secondary CPUs ...
    [    0.090084] Detected VIPT I-cache on CPU1
    [    0.090188] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.090213] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
    [    0.090280] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.090437] smp: Brought up 1 node, 2 CPUs
    [    0.119844] SMP: Total of 2 processors activated.
    [    0.124656] CPU features: detected: 32-bit EL0 Support
    [    0.129933] CPU features: detected: CRC32 instructions
    [    0.135262] CPU: All CPU(s) started at EL2
    [    0.139459] alternatives: applying system-wide alternatives
    [    0.147377] devtmpfs: initialized
    [    0.160114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.170141] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
    [    0.182508] pinctrl core: initialized pinctrl subsystem
    [    0.189390] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.196566] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.203980] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.212062] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.220731] thermal_sys: Registered thermal governor 'step_wise'
    [    0.220740] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.226934] cpuidle: using governor menu
    [    0.237812] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.244824] ASID allocator initialised with 65536 entries
    [    0.263190] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/adv7511w@39
    [    0.272660] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1
    [    0.282549] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0
    [    0.292554] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.304249] platform display: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1
    [    0.313741] platform display: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0
    [    0.323516] Modules: 28000 pages in range for non-PLT usage
    [    0.323521] Modules: 519520 pages in range for PLT usage
    [    0.330278] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.342667] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.349075] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.356014] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.362424] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.369362] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.375769] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.382712] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.390607] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.400000] iommu: Default domain type: Translated
    [    0.404920] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.411578] SCSI subsystem initialized
    [    0.415645] usbcore: registered new interface driver usbfs
    [    0.421283] usbcore: registered new interface driver hub
    [    0.426751] usbcore: registered new device driver usb
    [    0.432432] pps_core: LinuxPPS API ver. 1 registered
    [    0.437514] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.446865] PTP clock support registered
    [    0.451061] EDAC MC: Ver: 3.0.0
    [    0.454830] scmi_core: SCMI protocol bus registered
    [    0.460223] FPGA manager framework
    [    0.463851] Advanced Linux Sound Architecture Driver Initialized.
    [    0.471380] clocksource: Switched to clocksource arch_sys_counter
    [    0.477934] VFS: Disk quotas dquot_6.6.0
    [    0.481989] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.496228] NET: Registered PF_INET protocol family
    [    0.501568] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.510850] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
    [    0.519681] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.527628] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.535848] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [    0.543969] TCP: Hash tables configured (established 16384 bind 16384)
    [    0.550917] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.557863] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
    [    0.565426] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.571896] RPC: Registered named UNIX socket transport module.
    [    0.577984] RPC: Registered udp transport module.
    [    0.582795] RPC: Registered tcp transport module.
    [    0.587612] RPC: Registered tcp-with-tls transport module.
    [    0.593222] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.599816] NET: Registered PF_XDP protocol family
    [    0.606468] Initialise system trusted keyrings
    [    0.611411] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.618417] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.624754] NFS: Registering the id_resolver key type
    [    0.629990] Key type id_resolver registered
    [    0.634268] Key type id_legacy registered
    [    0.638392] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.645250] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.686686] Key type asymmetric registered
    [    0.690883] Asymmetric key parser 'x509' registered
    [    0.695936] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.703504] io scheduler mq-deadline registered
    [    0.708138] io scheduler kyber registered
    [    0.712307] io scheduler bfq registered
    [    0.719769] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.726494] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.734412] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.746692] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.765112] loop: module loaded
    [    0.772285] VFIO - User Level meta-driver version: 0.3
    [    0.778561] usbcore: registered new interface driver usblp
    [    0.784249] usbcore: registered new interface driver usb-storage
    [    0.790894] i2c_dev: i2c /dev entries driver
    [    0.797186] sdhci: Secure Digital Host Controller Interface driver
    [    0.803577] sdhci: Copyright(c) Pierre Ossman
    [    0.808293] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.814597] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.821859] usbcore: registered new interface driver usbhid
    [    0.827561] usbhid: USB HID core driver
    [    0.831934] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    0.840321] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    0.849353] optee: probing for conduit method.
    [    0.853944] optee: revision 4.2 (12d7c4ee)
    [    0.854349] optee: dynamic shared memory is enabled
    [    0.864499] random: crng init done
    [    0.868114] optee: initialized driver
    [    0.874757] NET: Registered PF_PACKET protocol family
    [    0.880081] Key type dns_resolver registered
    [    0.891557] registered taskstats version 1
    [    0.896001] Loading compiled-in X.509 certificates
    [    0.916198] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    [    0.971703] ti-sci-clk 44043000.system-controller:clock-controller: recalc-rate failed for dev=81, clk=20, ret=-19
    [    1.006268] tlv320aic3x 0-0018: supply IOVDD not found, using dummy regulator
    [    1.013764] tlv320aic3x 0-0018: supply DVDD not found, using dummy regulator
    [    1.021038] tlv320aic3x 0-0018: supply AVDD not found, using dummy regulator
    [    1.028282] tlv320aic3x 0-0018: supply DRVDD not found, using dummy regulator
    [    1.035636] tlv320aic3x 0-0018: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    1.064186] rtc-isl1208 0-006f: rtc power failure detected, please set clock.
    [    1.072484] rtc-isl1208 0-006f: registered as rtc0
    [    1.078151] rtc-isl1208 0-006f: hctosys: unable to read the hardware clock
    [    1.085262] omap_i2c 20000000.i2c: bus 0 rev0.12 at 200 kHz
    [    1.092253] platform 30200000.dss: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/adv7511w@39
    [    1.101881] i2c 1-0039: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.109468] omap_i2c 20010000.i2c: bus 1 rev0.12 at 200 kHz
    [    1.116829] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.122947] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.132796] debugfs: File ':bus@f0000:bus@48000000:interrupt-controller@48000000' in directory 'domains' already present!
    [    1.144097] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.154392] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x7e9000 bytes
    [    1.163241] simple-framebuffer ff700000.framebuffer: format=x8r8g8b8, mode=1920x1080x32, linelength=7680
    [    1.172963] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.181502] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.191352] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.202962] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.216006] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.227220] 4a00000.serial: ttyS9 at MMIO 0x4a00000 (irq = 241, base_baud = 3000000) is a 8250
    [    1.237830] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 242, base_baud = 3000000) is a 8250
    [    1.246843] printk: console [ttyS2] enabled
    [    1.255423] printk: bootconsole [ns16550a0] disabled
    [    1.267308] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 243, base_baud = 3000000) is a 8250
    [    1.277564] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 244, base_baud = 3000000) is a 8250
    [    1.287846] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 245, base_baud = 3000000) is a 8250
    [    1.298027] 2850000.serial: ttyS7 at MMIO 0x2850000 (irq = 246, base_baud = 3000000) is a 8250
    [    1.308460] 2860000.serial: ttyS8 at MMIO 0x2860000 (irq = 247, base_baud = 3000000) is a 8250
    [    1.323676] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.367387] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.376928] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver SMSC LAN8710/LAN8720
    [    1.385946] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.398774] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.405902] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.412535] pps pps0: new PPS source ptp0
    [    1.416907] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.432869] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.444542] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.450140] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.457947] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.463951] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010
    [    1.473399] xhci-hcd xhci-hcd.0.auto: irq 261, io mem 0x31000000
    [    1.480457] hub 1-0:1.0: USB hub found
    [    1.484283] hub 1-0:1.0: 1 port detected
    [    1.491027] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
    [    1.496603] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
    [    1.504478] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports
    [    1.510488] xhci-hcd xhci-hcd.1.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008000000010
    [    1.519980] xhci-hcd xhci-hcd.1.auto: irq 262, io mem 0x31100000
    [    1.526933] hub 2-0:1.0: USB hub found
    [    1.530755] hub 2-0:1.0: 1 port detected
    [    1.537961] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.551582] mmc0: CQHCI version 5.10
    [    1.566941] adv7511 1-0039: supply avdd not found, using dummy regulator
    [    1.573968] adv7511 1-0039: supply dvdd not found, using dummy regulator
    [    1.580709] adv7511 1-0039: supply pvdd not found, using dummy regulator
    [    1.587497] adv7511 1-0039: supply bgvdd not found, using dummy regulator
    [    1.594329] adv7511 1-0039: supply dvdd-3v not found, using dummy regulator
    [    1.601349] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.627740] egalax version is 2021-12-3 1.0.0
    [    1.632366] read the cut_above is 0
    [    1.635854] read the cut_below is 0
    [    1.639330] read the cut_left is 0
    [    1.642733] read the cut_right is 0
    [    1.646222] read the physical_TFT_H is 0
    [    1.650245] read the physical_TFT_V is 0
    [    1.676830] mmc0: mmc_select_hs200 failed, error -74
    [    1.683798] mmc0: new DDR MMC card at address 0001
    [    1.689512] mmcblk0: mmc0:0001 Q2J55L 7.13 GiB
    [    1.696435]  mmcblk0: p1 p2 p3 p4
    [    1.700808] mmcblk0boot0: mmc0:0001 Q2J55L 2.00 MiB
    [    1.707201] mmcblk0boot1: mmc0:0001 Q2J55L 2.00 MiB
    [    1.713347] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (240:0)
    [    1.787394] usb 2-1: new high-speed USB device number 2 using xhci-hcd
    [    1.974347] hub 2-1:1.0: USB hub found
    [    1.978164] hub 2-1:1.0: 4 ports detected
    [    2.364458] input: eGalax_Touch_Screen as /devices/virtual/input/input0
    [    2.495911]  egalax_i2c_probe: i2c transfer fail
    [    2.500529]  egalax_i2c_probe: Close the Touch
    [    2.506327] gpio_conctrol_probe
    [    2.509804] gpio_control finish
    [    2.515250] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    2.531636] mmc1: CQHCI version 5.10
    [    2.533230] debugfs: Directory 'pd:186' with parent 'pm_genpd' already present!
    [    2.543056] clk: Disabling unused clocks
    [    2.550535] ti-sci-clk 44043000.system-controller:clock-controller: is_prepared failed for dev=81, clk=20, ret=-19
    [    2.566036] ALSA device list:
    [    2.569010]   #0: AM62x-SKEVM
    [    4.051486] sdhci-am654 fa00000.mmc: Power on failed
    [    4.087066] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    4.098307] EXT4-fs (mmcblk0p1): mounting ext3 file system using the ext4 subsystem
    [    4.131362] EXT4-fs (mmcblk0p1): mounted filesystem db0387d5-f801-4ae5-be68-1dd8cb6e4107 r/w with ordered data mode. Quota mode: none.
    [    4.143580] VFS: Mounted root (ext3 filesystem) on device 179:1.
    [    4.153404] devtmpfs: mounted
    [    4.158043] Freeing unused kernel memory: 2176K
    [    4.162686] Run /sbin/init as init process
    [    4.459755] systemd[1]: System time before build time, advancing clock.
    [    4.526898] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    4.558836] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2023.10!
    [    4.578785] systemd[1]: Hostname set to <am62xx-evm>.
    [    4.864479] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    4.899237] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    4.946507] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.955545] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
    [    4.991418] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    5.162303] systemd[1]: Queued start job for default target Graphical Interface.
    [    5.214540] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    5.238256] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    5.261507] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    5.284037] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    5.307812] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    5.331662] systemd[1]: Expecting device /dev/ttyS2...
    [    5.347713] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    5.363570] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    5.383518] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    5.399535] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    5.450588] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    5.471762] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    5.499201] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    5.520147] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    5.551528] systemd[1]: Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
    [    5.563595] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    5.588636] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    5.604690] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    5.629166] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    5.652297] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    5.676310] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    5.728061] systemd[1]: Mounting Huge Pages File System...
    [    5.749252] systemd[1]: Mounting POSIX Message Queue File System...
    [    5.780376] systemd[1]: Mounting Kernel Debug File System...
    [    5.796688] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    5.820399] systemd[1]: Mounting Temporary Directory /tmp...
    [    5.844710] systemd[1]: Starting Create List of Static Device Nodes...
    [    5.877130] systemd[1]: Starting Load Kernel Module configfs...
    [    5.929179] systemd[1]: Starting Load Kernel Module drm...
    [    5.957551] systemd[1]: Starting Load Kernel Module fuse...
    [    5.980011] systemd[1]: Start psplash boot splash screen was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/psplash).
    [    5.993739] systemd[1]: Start psplash-systemd progress communication helper was skipped because of an unmet condition check (ConditionFileIsExecutable=/usr/bin/psplash).
    [    6.015861] systemd[1]: Starting RPC Bind...
    [    6.036168] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    6.061157] systemd[1]: Starting Journal Service...
    [    6.085461] systemd[1]: Load Kernel Modules was skipped because no trigger condition checks were met.
    [    6.132843] systemd[1]: Starting Generate network units from Kernel command line...
    [    6.178972] systemd-journald[103]: Collecting audit messages is disabled.
    [    6.180665] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.245796] systemd[1]: Starting Apply Kernel Variables...
    [    6.292594] systemd[1]: Starting Coldplug All udev Devices...
    [    6.334452] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    6.352771] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    6.385866] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    6.418171] systemd[1]: Mounted Kernel Debug File System.
    [    6.429072] EXT4-fs (mmcblk0p1): re-mounted db0387d5-f801-4ae5-be68-1dd8cb6e4107 ro. Quota mode: none.
    [  OK  ] Mounted Kernel Debug File System.
    [    6.450837] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Finished Apply Kernel Variables.
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Create Static Device Nodes in /dev gracefully...
    [  OK  ] Mounted Kernel Configuration File System.
    [    6.832969] systemd-journald[103]: Received client request to flush runtime journal.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Mounting /var/volatile...
    [  OK  ] Mounted /var/volatile.
             Starting Bind mount volatile /var/cache...
             Starting Bind mount volatile /var/lib...
             Starting Bind mount volatile /var/spool...
             Starting Bind mount volatile /srv...
    [  OK  ] Finished Bind mount volatile /var/cache.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Finished Bind mount volatile /var/spool.
    [  OK  ] Finished Bind mount volatile /srv.
    [  OK  ] Finished Bind mount volatile /var/lib.
    [  OK  ] Reached target Local File Systems.
             Starting Load/Save OS Random Seed...
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create Volatile Files and Directories.
    [FAILED] Failed to start Network Name Resolution.
    See 'systemctl status systemd-resolved.service' for details.
    [  OK  ] Reached target Host and Network Name Lookups.
    [FAILED] Failed to start Network Time Synchronization.
    See 'systemctl status systemd-timesyncd.service' for details.
    [  OK  ] Reached target System Time Set.
             Starting Record System Boot/Shutdown in UTMP...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
             Starting Weston socket...
    [FAILED] Failed to start D-Bus System Message Bus.
    See 'systemctl status dbus-broker.service' for details.
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Listening on Weston socket.
    [FAILED] Failed to start Reboot and dump vmcore via kexec.
    See 'systemctl status kdump.service' for details.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
             Starting Telephony service...
             Starting PulseAudio Sound System...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started Seva Launcher Service.
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [FAILED] Failed to start User Login Management.
    See 'systemctl status systemd-logind.service' for details.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started ti-apps-launcher service.
    [FAILED] Failed to start Print notice about GPLv3 packages.
    See 'systemctl status gplv3-notice.service' for details.
    [FAILED] Failed to start IPv6 Packet Filtering Framework.
    See 'systemctl status ip6tables.service' for details.
    [FAILED] Failed to start IPv4 Packet Filtering Framework.
    See 'systemctl status iptables.service' for details.
    [FAILED] Failed to start Telephony service.
    See 'systemctl status ofono.service' for details.
    [FAILED] Failed to start PulseAudio Sound System.
    See 'systemctl status pulseaudio.service' for details.
    [FAILED] Failed to start Expand the rootfs …n to full size of the boot device..
    See 'systemctl status resize_rootfs.service' for details.
    [FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
    See 'systemctl status avahi-daemon.service' for details.
    [  OK  ] Reached target Preparation for Network.
             Starting Network Configuration...
    [   10.905585] pvrsrvkm: loading out-of-tree module taints kernel.
             Starting Save/Restore Sound Card State...
    [   10.977325] PVR_K:  160: Device: fd00000.gpu
    [   10.990552] PVR_K:  160: Read BVNC 33.15.11.3 from HW device registers
    [   11.000459] PVR_K:  160: RGX Device registered with BVNC 33.15.11.3
    [   11.017692] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1
             Starting User Database Manager...
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Started User Database Manager.
    [   11.732167] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   11.743835] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
             Starting Virtual Console Setup...
    [  OK  ] Started Network Configuration.
    [FAILED] Failed to start Virtual Console Setup.
    See 'systemctl status systemd-vconsole-setup.service' for details.
    [  OK  ] Reached target Network.
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
    [  OK  ] Started Netperf Benchmark Server.
             Starting /etc/rc.local Compatibility...
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
    [FAILED] Failed to start Enable and configure wl18xx bluetooth stack.
    See 'systemctl status bt-enable.service' for details.
    [FAILED] Failed to start Simple Network Management Protocol (SNMP) Daemon..
    See 'systemctl status snmpd.service' for details.
    [FAILED] Failed to start containerd container runtime.
    See 'systemctl status containerd.service' for details.
    [  OK  ] Finished Permit User Sessions.
    e2fsck 1.47.0 (5-Feb-2023)
    Superblock last write time is in the future.
            (by less than a day, probably due to the hardware clock being incorrectly set)
    /dev/mmcblk0p2: clean, 15/2560 files, 1129/2560 blocks
             Starting Weston, a Wayland compositor, as a system service...
    [   12.586720] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
    [   12.623800] EXT4-fs (mmcblk0p2): mounted filesystem 8ad38ad3-8ad3-8ad3-8ad3-8ad38ad38ad3 r/w with ordered data mode. Quota mode: none.
    mount userconfig success!
    [FAILED] Failed to start Seva Launcher Service.
    See 'systemctl status seva-launcher.service' for details.
    /dev/mmcblk0p3: clean, 12/2560 files, 1117/2560 blocks
    [   12.752047] EXT4-fs (mmcblk0p3): mounting ext3 file system using the ext4 subsystem
    [  OK  ] Finished Load Kernel Module drm[   12.776925] EXT4-fs (mmcblk0p3): mounted filesystem 16d316d3-16d3-16d3-16d3-16d316d316d3 r/w with ordered data mode. Quota mode: none.
    mount dbBackup success!
    [FAILED] Failed to start Weston, a Wayland compositor, as a system service.
    See 'systemctl status weston.service' for details.
    See 'systemctl status systemd-logind.service'[   12.840663] EXT4-fs (mmcblk0p4): mounting ext3 file system using the ext4 subsystem
     for details.
    [   12.856800] EXT4-fs (mmcblk0p4): warning: mounting fs with errors, running e2fsck is recommended
    [   12.879673] EXT4-fs (mmcblk0p4): mounted filesystem 61646164-6164-6164-6164-616461646164 r/w with ordered data mode. Quota mode: none.
    mount patdata success!
    [   12.915583] dxtest buffer_size 8192 line_size 48 cacheline 10 period_time:1000 strobe_num 2
    [  OK  ] Reached target Printer Support.
    /etc/rc.local: line 31: ./Main: No such file or directory
    [  OK  ] Started /etc/rc.local Compatibility.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62xx-evm ttyS2
    Arago 2023.10 am62xx-evm ttyS2
    am62xx-evm login: root (automatic login)
    root@am62xx-evm:~# [   12.924173] dxtest pwm period 312500 duty_cycle 156250
    [   13.819801] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [   17.320156] EXT4-fs error (device mmcblk0p4): ext4_mb_generate_buddy:1213: group 1, block bitmap and bg descriptor inconsistent: 30887 vs 30888 free clusters
    [   23.164525] platform 2b300050.target-module: deferred probe pending
    ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d &
    [1] 540
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 1 / 696729
    Needed 4 reads 1 writes loops 2 / 696729
    Needed 4 reads 1 writes loops 3 / 696729
    Needed 4 reads 1 writes loops 4 / 696729
    Needed 4 reads 1 writes loops 5 / 696729
    Needed 4 reads 1 writes loops 6 / 696729
    ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d &
    [2] 545
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 1 / 2786918
    Needed 4 reads 1 writes loops 7 / 696729
    Needed 4 reads 1 writes loops 2 / 2786918
    Needed 4 reads 1 writes loops 3 / 2786918
    Needed 4 reads 1 writes loops 4 / 2786918
    Needed 4 reads 1 writes loops 5 / 2786918
    Needed 4 reads 1 writes loops 8 / 696729
    Needed 4 reads 1 writes loops 6 / 2786918
    Needed 4 reads 1 writes loops 7 / 2786918
    Needed 4 reads 1 writes loops 8 / 2786918
    Needed 4 reads 1 writes loops 9 / 2786918
    Needed 4 reads 1 writes loops 9 / 696729
    Needed 4 reads 1 writes loops 10 / 2786918
    Needed 4 reads 1 writes loops 11 / 2786918
    Needed 4 reads 1 writes loops 12 / 2786918
    Needed 4 reads 1 writes loops 13 / 2786918
    Needed 4 reads 1 writes loops 10 / 696729
    Needed 4 reads 1 writes loops 14 / 2786918
    Needed 4 reads 1 writes loops 15 / 2786918
    Needed 4 reads 1 writes loops 16 / 2786918
    Needed 4 reads 1 writes loops 17 / 2786918
    Needed 4 reads 1 writes loops 11 / 696729
    Needed 4 reads 1 writes loops 18 / 2786918
    Needed 4 reads 1 writes loops 19 / 2786918
    Needed 4 reads 1 writes loops 20 / 2786918
    Needed 4 reads 1 writes loops 21 / 2786918
    Needed 4 reads 1 writes loops 12 / 696729
    Needed 4 reads 1 writes loops 22 / 2786918
    Needed 4 reads 1 writes loops 23 / 2786918
    ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d &
    [3] 550
    [3] 550            Needed 4 reads 1 writes loops 24 / 2786918
    Needed 4 reads 1 writes loops 25 / 2786918
    Needed 4 reads 1 writes loops 13 / 696729
    Needed 4 reads 1 writes loops 26 / 2786918
    Needed 4 reads 1 writes loops 27 / 2786918
    Needed 4 reads 1 writes loops 28 / 2786918
    Needed 4 reads 1 writes loops 29 / 2786918
    Needed 4 reads 1 writes loops 14 / 696729
    Needed 4 reads 1 writes loops 30 / 2786918
    Needed 4 reads 1 writes loops 31 / 2786918
    Needed 4 reads 1 writes loops 32 / 2786918
    Needed 4 reads 1 writes loops 33 / 2786918
    Needed 4 reads 1 writes loops 15 / 696729
    Needed 4 reads 1 writes loops 34 / 2786918
    Needed 4 reads 1 writes loops 35 / 2786918
    Needed 4 reads 1 writes loops 36 / 2786918
    Needed 4 reads 1 writes loops 37 / 2786918
    Needed 4 reads 1 writes loops 16 / 696729
    Needed 4 reads 1 writes loops 38 / 2786918
    Needed 4 reads 1 writes loops 39 / 2786918
    Needed 4 reads 1 writes loops 40 / 2786918
    Needed 4 reads 1 writes loops 41 / 2786918
    Needed 4 reads 1 writes loops 17 / 696729
    Needed 4 reads 1 writes loops 42 / 2786918
    Needed 4 reads 1 writes loops 43 / 2786918
    Needed 4 reads 1 writes loops 44 / 2786918
    Needed 4 reads 1 writes loops 45 / 2786918
    Needed 4 reads 1 writes loops 18 / 696729
    Needed 4 reads 1 writes loops 46 / 2786918
    Needed 4 reads 1 writes loops 47 / 2786918
    Needed 4 rNeeded 4 reads 1 writes loops 24 / 2786918
    Needed 4 rNeeded 4 reads 1 writes loops 24 / 2786918                    Needed 4 reads 1 writes loops 48 / 2786918
    Needed 4 reads 1 writes loops 49 / 2786918
    Needed 4 reads 1 writes loops 19 / 696729
    Needed 4 reads 1 writes loops 50 / 2786918
    eck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d &
    [4] 555
    [4] 555            Needed 4 reads 1 writes loops 27 / 2786918
    Needed 4 reads 1 writes loops 51 / 2786918
    Needed 4 reads 1 writes loops 52 / 2786918
    Needed 4 reads 1 writes loops 53 / 2786918
    Needed 4 reads 1 writes loops 20 / 696729
    Needed 4 reads 1 writes loops 54 / 2786918
    Needed 4 reads 1 writes loops 55 / 2786918
    Needed 4 reads 1 writes loops 56 / 2786918
    Needed 4 reads 1 writes loops 57 / 2786918
    Needed 4 reads 1 writes loops 21 / 696729
    Needed 4 reads 1 writes loops 58 / 2786918
    Needed 4 reads 1 writes loops 59 / 2786918
    Needed 4 reads 1 writes loops 60 / 2786918
    Needed 4 reads 1 writes loops 61 / 2786918
    Needed 4 reads 1 writes loops 22 / 696729
    Needed 4 reads 1 writes loops 62 / 2786918
    Needed 4 reads 1 writes loops 63 / 2786918
    Needed 4 reads 1 writes loops 64 / 2786918
    Needed 4 reads 1 writes loops 65 / 2786918
    Needed 4 reads 1 writes loops 23 / 696729
    Needed 4 reads 1 writes loops 66 / 2786918
    Needed 4 reads 1 writes loops 67 / 2786918
    Needed 4 reads 1 writes loops 68 / 2786918
    Needed 4 reads 1 writes loops 69 / 2786918
    Needed 4 reads 1 writes loops 24 / 696729
    Needed 4 reads 1 writes loops 24 / 696729                                         Needed 4 reads 1 writes loops 70 / 2786918
    ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d &
    [5] 560
    [5] 560            Needed 4 reads 1 writes loops 47 / 2786918
    Needed 4 reads 1 writes loops 71 / 2786918
    Needed 4 reads 1 writes loops 72 / 2786918
    Needed 4 reads 1 writes loops 73 / 2786918
    Needed 4 reads 1 writes loops 25 / 696729
    root@am62xx-evm:~#
    Needed 4 reads 1 writes loops 74 / 2786918
    Needed 4 reads 1 wrNeeded 4 reads 1 writes loops 24 / 2786918
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 75 / 2786918
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 76 / 2786918
    Needed 4 reads 1 writes loops 77 / 2786918
    Needed 4 reads 1 writes loops 26 / 696729
    Needed 4 reads 1 writes loops 78 / 2786918
    Needed 4 reads 1 writes loops 79 / 2786918
    Needed 4 reads 1 writes loops 80 / 2786918
    Needed 4 reads 1 writes loops 81 / 2786918
    Needed 4 reads 1 writes loops 27 / 696729
    Needed 4 reads 1 writes loops 82 / 2786918
    Needed 4 reads 1 writes loops 83 / 2786918
    Needed 4 reads 1 writes loops 84 / 2786918
    Needed 4 reads 1 writes loops 85 / 2786918
    Needed 4 reads 1 writes loops 28 / 696729
    Needed 4 reads 1 writes loops 86 / 2786918
    Needed 4 reads 1 writes loops 87 / 2786918
    Needed 4 reads 1 writes loops 88 / 2786918
    Needed 4 reads 1 writes loops 89 / 2786918
    Needed 4 reads 1 writes loops 29 / 696729
    Needed 4 reads 1 writes loops 90 / 2786918
    Needed 4 reads 1 writes loops 91 / 2786918
    Needed 4 reads 1 writes loops 92 / 2786918
    Needed 4 reads 1 writes loops 93 / 2786918
    Needed 4 reads 1 writes loops 30 / 696729
    Needed 4 reads 1 writes loops 94 / 2786918
    Needed 4 reads 1 writes loops 95 / 2786918
    Needed 4 reads 1 writes loops 96 / 2786918
    Needed 4 reads 1 writes loops 97 / 2786918
    Needed 4 reads 1 writes loops 31 / 696729
    Needed 4 reads 1 writes loops 98 / 2786918
    Needed 4 reads 1 writes loops 99 / 2786918
    Needed 4 reads 1 writes loops 100 / 2786918
    Needed 4 reads 1 writes loops 101 / 2786918
    Needed 4 reads 1 writes loops 32 / 696729
    Needed 4 reads 1 writes loops 102 / 2786918
    Needed 4 reads 1 writes loops 103 / 2786918
    Needed 4 reads 1 wNeeded 4 reads 1 writes loops 104 / 2786918
    ./eth_up_down.sh &
    [6] 565
    root@am62xx-evm:~# [   58.561749] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
    Needed 5 reads 1 writes loops 34 / 2786918
    Needed 4 reads 1 writes loops 105 / 2786918
    Needed 4 reads 1 writes loops 33 / 696729
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 106 / 2786918
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 107 / 2786918
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 108 / 2786918
    root@am62xx-evm:~#
    root@am62xx-evm:~# Needed 4 reads 1 writes loops 85 / 2786918
    Needed 4 reads 1 writes loops 109 / 2786918
    [   59.647935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   59.658393] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 6 reads 1 writes loops 39 / 2786918
    Needed 6 reads 1 writes loops 34 / 696729
    Needed 4 reads 1 writes loops 110 / 2786918
    Needed 4 reads 1 writes loops 111 / 2786918
    NNeeded 4 reads 1 writes loops 112 / 2786918
    NNeeded 4 reads 1 writes loops 113 / 2786918
    NNeeded 4 reads 1 writes loops 90 / 2786918
    Needed 4 reads 1 writes loops 35 / 696729
    Needed 4 reads 1 writes loops 114 / 2786918
    NNeeded 4 reads 1 writes loops 64 / 2786918
    a
    Needed 4 reads 1 writes loops 115 / 2786918
      PID TTY      STAT   TIME COMMAND
      514 ttyS2    Ss     0:00 /bin/login -f --
      518 ttyS2    S      0:00 -sh
      540 ttyS2    SL     0:00 ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d
      545 ttyS2    SL     0:00 ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d
      550 ttyS2    SL     0:00 ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d
      555 ttyS2    SL     0:00 ./serialcheck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d
      560 ttyS2    SL     0:00 ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d
      565 ttyS2    S      0:00 /bin/sh ./eth_up_down.sh
      575 ttyS2    S      0:00 sleep 1
      576 ttyS2    R+     0:00 ps a
    Needed 4 reads 1 wrNeeded 4 reads 1 writes loops 92 / 2786918
    Needed 4 reads 1 writes loops 116 / 2786918
    Needed 4 reads 1 writes loops 117 / 2786918
    Needed 4 reads 1 writes loops 36 / 696729
    Needed 4 reads 1 writes loops 118 / 2786918
    [   61.763922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   61.774150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 119 / 2786918
    Needed 4 reads 1 writes loops 120 / 2786918
    Needed 4 reads 1 writes loops 121 / 2786918
    Needed 4 reads 1 writes loops 37 / 696729
    Needed 4 reads 1 writes loops 122 / 2786918
    Needed 4 reads 1 writes loops 123 / 2786918
    Needed 4 reads 1 writes loops 124 / 2786918
    Needed 4 reads 1 writes loops 125 / 2786918
    Needed 4 reads 1 writes loops 38 / 696729
    Needed 4 reads 1 writes loops 126 / 2786918
    Needed 4 reads 1 writes loops 127 / 2786918
    Needed 4 reads 1 writes loops 128 / 2786918
    [   63.879926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   63.890153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 129 / 2786918
    Needed 4 reads 1 writes loops 39 / 696729
    Needed 4 reads 1 writes loops 130 / 2786918
    Needed 4 reads 1 writes loops 131 / 2786918
    Needed 4 reads 1 writes loops 132 / 2786918
    Needed 4 reads 1 writes loops 133 / 2786918
    Needed 4 reads 1 writes loops 40 / 696729
    Needed 4 reads 1 writes loops 134 / 2786918
    Needed 4 reads 1 writes loops 135 / 2786918
    Needed 4 reads 1 writes loops 136 / 2786918
    Needed 4 reads 1 writes loops 137 / 2786918
    Needed 4 reads 1 writes loops 41 / 696729
    Needed 4 reads 1 writes loops 138 / 2786918
    [   65.991942] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   66.002185] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 139 / 2786918
    Needed 4 reads 1 writes loops 140 / 2786918
    Needed 4 reads 1 writes loops 141 / 2786918
    Needed 4 reads 1 writes loops 142 / 2786918
    Needed 4 reads 1 writes loops 143 / 2786918
    Needed 4 reads 1 writes loops 144 / 2786918
    Needed 4 reads 1 writes loops 145 / 2786918
    Needed 4 reads 1 writes loops 146 / 2786918
    Needed 4 reads 1 writes loops 147 / 2786918
    [   68.103931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   68.114456] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 6 reads 1 writes loops 148 / 2786918
    Needed 4 reads 1 writes loops 149 / 2786918
    Needed 4 reads 1 writes loops 150 / 2786918
    Needed 4 reads 1 writes loops 151 / 2786918
    Needed 4 reads 1 writes loops 152 / 2786918
    Needed 4 reads 1 writes loops 153 / 2786918
    Needed 4 reads 1 writes loops 154 / 2786918
    Needed 4 reads 1 writes loops 155 / 2786918
    Needed 4 reads 1 writes loops 156 / 2786918
    Needed 4 reads 1 writes loops 157 / 2786918
    [   70.204157] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   70.215132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 6 reads 1 writes loops 134 / 2786918
    [   72.335952] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   72.346381] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 6 reads 1 writes loops 97 / 2786918
    Needed 4 reads 1 writes loops 148 / 2786918
    [   74.451940] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   74.462372] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 158 / 2786918
    Needed 4 reads 1 writes loops 159 / 2786918
    Needed 4 reads 1 writes loops 160 / 2786918
    Needed 4 reads 1 writes loops 161 / 2786918
    Needed 4 reads 1 writes loops 162 / 2786918
    [   76.571921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   76.582146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 163 / 2786918
    Needed 4 reads 1 writes loops 164 / 2786918
    Needed 4 reads 1 writes loops 165 / 2786918
    Needed 4 reads 1 writes loops 166 / 2786918
    Needed 4 reads 1 writes loops 167 / 2786918
    Needed 4 reads 1 writes loops 168 / 2786918
    Needed 4 reads 1 writes loops 169 / 2786918
    Needed 4 reads 1 writes loops 170 / 2786918
    Needed 4 reads 1 writes loops 171 / 2786918
    Needed 4 reads 1 writes loops 172 / 2786918
    [   78.651918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   78.662136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 173 / 2786918
    Needed 4 reads 1 writes loops 174 / 2786918
    Needed 4 reads 1 writes loops 175 / 2786918
    Needed 4 reads 1 writes loops 176 / 2786918
    Needed 4 reads 1 writes loops 177 / 2786918
    Needed 4 reads 1 writes loops 178 / 2786918
    Needed 4 reads 1 writes loops 179 / 2786918
    Needed 4 reads 1 writes loops 180 / 2786918
    Needed 4 reads 1 writes loops 181 / 2786918
    Needed 4 reads 1 writes loops 182 / 2786918
    [   80.743954] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   80.754338] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 183 / 2786918
    Needed 4 reads 1 writes loops 184 / 2786918
    Needed 4 reads 1 writes loops 185 / 2786918
    Needed 4 reads 1 writes loops 186 / 2786918
    Needed 4 reads 1 writes loops 187 / 2786918
    Needed 4 reads 1 writes loops 188 / 2786918
    Needed 4 reads 1 writes loops 189 / 2786918
    Needed 4 reads 1 writes loops 190 / 2786918
    Needed 4 reads 1 writes loops 191 / 2786918
    [   82.875926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   82.886150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 192 / 2786918
    Needed 4 reads 1 writes loops 193 / 2786918
    Needed 4 reads 1 writes loops 194 / 2786918
    Needed 4 reads 1 writes loops 195 / 2786918
    Needed 4 reads 1 writes loops 196 / 2786918
    Needed 4 reads 1 writes loops 197 / 2786918
    Needed 4 reads 1 writes loops 198 / 2786918
    Needed 4 reads 1 writes loops 199 / 2786918
    Needed 4 reads 1 writes loops 200 / 2786918
    Needed 4 reads 1 writes loops 201 / 2786918
    [   84.987938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   84.998162] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 202 / 2786918
    Needed 4 reads 1 writes loops 203 / 2786918
    Needed 4 reads 1 writes loops 204 / 2786918
    Needed 4 reads 1 writes loops 205 / 2786918
    Needed 4 reads 1 writes loops 206 / 2786918
    Needed 4 reads 1 writes loops 207 / 2786918
    Needed 4 reads 1 writes loops 208 / 2786918
    Needed 4 reads 1 writes loops 209 / 2786918
    Needed 4 reads 1 writes loops 210 / 2786918
    Needed 4 reads 1 writes loops 211 / 2786918
    [   87.107917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   87.118136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 212 / 2786918
    Needed 4 reads 1 writes loops 213 / 2786918
    Needed 4 reads 1 writes loops 214 / 2786918
    Needed 4 reads 1 writes loops 215 / 2786918
    Needed 4 reads 1 writes loops 216 / 2786918
    Needed 4 reads 1 writes loops 217 / 2786918
    Needed 4 reads 1 writes loops 218 / 2786918
    Needed 4 reads 1 writes loops 219 / 2786918
    Needed 4 reads 1 writes loops 220 / 2786918
    [   89.219921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   89.230141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 221 / 2786918
    Needed 4 reads 1 writes loops 222 / 2786918
    Needed 4 reads 1 writes loops 223 / 2786918
    Needed 4 reads 1 writes loops 224 / 2786918
    Needed 4 reads 1 writes loops 225 / 2786918
    Needed 4 reads 1 writes loops 226 / 2786918
    Needed 4 reads 1 writes loops 227 / 2786918
    Needed 4 reads 1 writes loops 228 / 2786918
    Needed 4 reads 1 writes loops 229 / 2786918
    Needed 4 reads 1 writes loops 230 / 2786918
    [   91.331955] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   91.342350] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 231 / 2786918
    Needed 4 reads 1 writes loops 232 / 2786918
    Needed 4 reads 1 writes loops 233 / 2786918
    Needed 4 reads 1 writes loops 234 / 2786918
    Needed 4 reads 1 writes loops 235 / 2786918
    Needed 4 reads 1 writes loops 236 / 2786918
    Needed 4 reads 1 writes loops 237 / 2786918
    Needed 4 reads 1 writes loops 238 / 2786918
    Needed 4 reads 1 writes loops 239 / 2786918
    Needed 4 reads 1 writes loops 240 / 2786918
    [   93.443956] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   93.454292] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 241 / 2786918
    Needed 4 reads 1 writes loops 242 / 2786918
    Needed 4 reads 1 writes loops 243 / 2786918
    Needed 4 reads 1 writes loops 244 / 2786918
    Needed 4 reads 1 writes loops 245 / 2786918
    Needed 4 reads 1 writes loops 246 / 2786918
    Needed 4 reads 1 writes loops 247 / 2786918
    Needed 4 reads 1 writes loops 248 / 2786918
    Needed 4 reads 1 writes loops 249 / 2786918
    [   95.555936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   95.566304] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 6 reads 1 writes loops 250 / 2786918
    Needed 4 reads 1 writes loops 251 / 2786918
    Needed 4 reads 1 writes loops 252 / 2786918
    Needed 4 reads 1 writes loops 253 / 2786918
    Needed 4 reads 1 writes loops 254 / 2786918
    Needed 4 reads 1 writes loops 255 / 2786918
    Needed 4 reads 1 writes loops 256 / 2786918
    Needed 4 reads 1 writes loops 257 / 2786918
    Needed 4 reads 1 writes loops 258 / 2786918
    Needed 4 reads 1 writes loops 259 / 2786918
    [   97.667938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   97.678227] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 260 / 2786918
    Needed 4 reads 1 writes loops 261 / 2786918
    Needed 4 reads 1 writes loops 262 / 2786918
    Needed 4 reads 1 writes loops 263 / 2786918
    Needed 4 reads 1 writes loops 264 / 2786918
    Needed 4 reads 1 writes loops 265 / 2786918
    Needed 4 reads 1 writes loops 266 / 2786918
    Needed 4 reads 1 writes loops 267 / 2786918
    Needed 4 reads 1 writes loops 268 / 2786918
    Needed 4 reads 1 writes loops 269 / 2786918
    [   99.779926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [   99.790135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    Needed 4 reads 1 writes loops 270 / 2786918
    Needed 4 reads 1 writes loops 271 / 2786918
    Needed 4 reads 1 writes loops 272 / 2786918
    Needed 4 reads 1 writes loops 273 / 2786918
    Needed 4 reads 1 writes loops 274 / 2786918
    Needed 4 reads 1 writes loops 275 / 2786918
    Needed 4 reads 1 writes loops 276 / 2786918
    Needed 4 reads 1 writes loops 277 / 2786918
    Needed 4 reads 1 writes loops 278 / 2786918
    [  101.891923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  101.902142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  104.003914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  104.014140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  106.115919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  106.126145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  108.227931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  108.238154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  110.339915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  110.350131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  112.451916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  112.462143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  114.563921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  114.574150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  116.675916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  116.686136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  118.787916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  118.798135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  120.899920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  120.910142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  123.011924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  123.022149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  125.123914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  125.134130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  127.235919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  127.246138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  129.347923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  129.358143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  131.459913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  131.470140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  133.571915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  133.582128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  135.683923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  135.694141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  137.795917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  137.806140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  139.907930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  139.918158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  142.019918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  142.030133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  144.111920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  144.122138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  146.223914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  146.234129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  148.327924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  148.338148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  150.439915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  150.450131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  152.551919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  152.562139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  154.663920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  154.674145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  156.775921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  156.786150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  158.887917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  158.898132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  160.999922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  161.010160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  163.111916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  163.122139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  165.195924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  165.206151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    timeout, RX/TX: 9856/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9856 (0x2680).
    Original sample:
    00002650: 62 60 f6 f1 ec 97 70 fe  32 b7 a0 14 32 e1 19 57   b`....p.2...2..W
    00002660: 14 60 e0 c3 44 ea 7a 9c  ce 1c 6f 54 e4 1f ef 89   .`..D.z...oT....
    00002670: f5 27 54 35 1d 57 b3 15  a4 c2 ed 79 da 8d 8e c6   .'T5.W.....y....
    00002680: e8 96 98 ef 5f 7b b9 12  a2 87 fc 53 50 35 7b da   ...._{.....SP5{.
    00002690: e7 8c c9 46 59 15 42 84  a3 22 0f b8 19 a9 a7 60   ...FY.B..".....`
    000026a0: dc cf a0 47 e8 b1 38 78  94 b7 fe 61 4d 30 64 74   ...G..8x...aM0dt
    Received sample:
    00002680: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    00002690: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    000026a0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 42 / 696729
    spend 137 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 419856 tx: 420000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    [  167.307917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  167.318138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  169.419915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  169.430131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    timeout, RX/TX: 9728/10000
    Needed 3 reads 1 writes Oh oh, inconsistency at pos 9729 (0x2601).
    Original sample:
    000025d0: 55 1b 07 96 0c fe 26 20  90 5a 46 9e 90 f7 ec 5b   U.....& .ZF....[
    000025e0: 21 47 56 61 3a 39 d5 ee  e7 83 37 50 e9 07 4e d0   !GVa:9....7P..N.
    000025f0: e5 71 96 10 a9 40 aa 36  1a 6e de 01 d0 ab f4 3e   .q...@.6.n.....>
    00002600: 00 c6 3c 4f 93 79 52 4c  5e 28 da b7 8e a4 e4 43   ..<O.yRL^(.....C
    00002610: 33 35 2f 0a a7 34 71 66  6e f2 17 86 15 9a cf eb   35/..4qfn.......
    00002620: c8 bb 74 90 a1 13 ab e7  e5 a7 29 4d 37 03 c8 2e   ..t.......)M7...
    Received sample:
    00002600: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    00002610: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    00002620: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 158 / 2786918
    spend 134 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 1579728 tx: 1580000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    [  171.527914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  171.538130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  173.639914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  173.650136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    timeout, RX/TX: 9984/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9984 (0x2700).
    Original sample:
    000026d0: b6 a3 43 44 f3 2f df af  09 f8 33 dc c0 2e 7f 6e   ..CD./....3....n
    000026e0: a8 d0 95 3a e0 e0 42 a5  eb d0 a7 f6 11 22 36 2f   ...:..B......"6/
    000026f0: 9a 42 79 c9 33 6d 4b 06  44 c1 39 cd 2f 2d 83 5b   .By.3mK.D.9./-.[
    00002700: 0b 57 0e 0f 8f 7c 67 e7  33 2a ac 9c b7 c1 9e 03   .W...|g.3*......
    Received sample:
    00002700: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 107 / 2786918
    spend 124 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 1069984 tx: 1070000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    [  175.751916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  175.762140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  177.863906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  177.874121] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  179.975921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  179.986163] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  182.087913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  182.098140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  184.199911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  184.210132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  186.311909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  186.322131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  188.423914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  188.434131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  190.535915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  190.546139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  192.647905] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  192.658132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  194.759912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  194.770131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    timeout, RX/TX: 9792/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9792 (0x2640).
    Original sample:
    00002630: 6a 4e 00 26 7d c1 ab 70  f2 64 64 10 f0 63 b0 9f   jN.&}..p.dd..c..
    00002640: dd 0b d7 33 29 29 17 3b  ed 00 b9 8d 33 2b 1b a6   ...3)).;....3+..
    Received sample:
    00002640: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    00002650: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    00002660: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 224 / 2786918
    spend 149 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 2239792 tx: 2240000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    [  196.871912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  196.882133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  198.983914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  198.994140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  201.095907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  201.106125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    timeout, RX/TX: 9857/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9857 (0x2681).
    Original sample:
    Received sample:
    00002680: e8 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 279 / 2786918
    spend 161 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 2789857 tx: 2790000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    [  203.207910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  203.218130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  205.319909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  205.330132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  207.431906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  207.442128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  209.543908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  209.554121] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  211.655908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  211.666123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  213.767906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  213.778120] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  215.879906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  215.890117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  217.991909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  218.002119] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  220.103912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  220.114132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  222.215910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  222.226125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  224.327905] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  224.338128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  226.439922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  226.450140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  228.551907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  228.562125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  230.663907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  230.674125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  232.775907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  232.786117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  234.887909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  234.898121] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  236.999910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  237.010125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  239.111910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  239.122127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  241.223909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  241.234116] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  243.335909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  243.346124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  245.447906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  245.458127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  247.559907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  247.570122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  249.671909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  249.682118] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  251.783907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  251.794126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  253.895908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  253.906124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  256.007910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  256.018117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  258.119913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  258.130122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  260.231912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  260.242127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  262.343906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  262.354127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  264.456080] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  264.466451] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  266.571915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  266.582143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  268.683914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  268.694133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  270.803922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  270.814148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  272.903911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  272.914122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  275.016012] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  275.026239] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  277.131921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  277.142143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  279.243917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  279.254131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  281.359922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  281.370146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  283.471915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  283.482145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  285.587924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  285.598148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  287.699913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  287.710131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  289.819915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  289.830130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  291.931917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  291.942140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  294.043920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  294.054145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  296.155915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  296.166144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  298.267917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  298.278137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  300.379957] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  300.390183] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  302.491910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  302.502135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  304.603918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  304.614135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  306.715919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  306.726138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  308.827919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  308.838145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  310.939921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  310.950151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  313.051916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  313.062133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  315.163914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  315.174138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  316.539379] EXT4-fs (mmcblk0p4): error count since last fsck: 79
    [  316.545434] EXT4-fs (mmcblk0p4): initial error at time 1709059948: ext4_mb_mark_diskspace_used:4034
    [  316.554492] EXT4-fs (mmcblk0p4): last error at time 1709054776: ext4_mb_generate_buddy:1213
    [  317.275920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  317.286144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  319.387914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  319.398131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  321.499917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  321.510137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  323.611915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  323.622140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  325.723920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  325.734147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  327.835921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  327.846148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  329.947916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  329.958136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  332.059918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  332.070141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  334.171922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  334.182142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  336.283916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  336.294131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  338.395920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  338.406141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  340.507918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  340.518142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  342.619925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  342.630149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  344.731916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  344.742131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  346.843922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  346.854142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  348.955921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  348.966147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  351.067928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  351.078152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  353.179915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  353.190130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  355.291925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  355.302142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  357.383919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  357.394138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  359.495919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  359.506145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  361.607929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  361.618158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  363.719915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  363.730132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  365.831915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  365.842136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  367.943918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  367.954140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  370.055919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  370.066134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  372.167920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  372.178138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  374.279917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  374.290139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  376.391924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  376.402147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  378.503917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  378.514135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  380.615918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  380.626144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  382.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  382.738144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  384.839909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  384.850125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  386.951917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  386.962132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  389.063919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  389.074143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  391.175909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  391.186137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  393.287924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  393.298156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  395.399918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  395.410136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  397.511915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  397.522140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  399.623919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  399.634147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  401.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  401.746135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  403.847916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  403.858134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  405.959920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  405.970142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  408.071923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  408.082143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  410.183915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  410.194133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  412.295920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  412.306140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  414.407917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  414.418141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  416.519914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  416.530141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  418.631915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  418.642133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  420.743922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  420.754139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  422.855920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  422.866144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  424.967919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  424.978147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  427.079917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  427.090137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  429.191915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  429.202136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  431.303919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  431.314144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  433.415914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  433.426127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  435.527915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  435.538135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  437.639915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  437.650137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  439.751922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  439.762142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  441.863916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  441.874133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  443.975918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  443.986135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  446.087915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  446.098140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  448.200056] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  448.210485] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  450.315918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  450.326138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  452.427924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  452.438149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  454.543915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  454.554130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  456.655923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  456.666142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  458.767945] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  458.778172] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  460.891919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  460.902138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  463.003916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  463.014132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  465.115917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  465.126137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  467.227917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  467.238137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  469.339952] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  469.350182] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  471.451917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  471.462137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  473.563919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  473.574140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  475.675919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  475.686142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  477.787915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  477.798140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  479.899916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  479.910133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  482.011923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  482.022166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  484.123922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  484.134151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  486.235927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  486.246153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  488.347919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  488.358135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  490.459915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  490.470141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  492.551916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  492.562140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  494.663918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  494.674143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  496.775935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  496.786159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  498.887915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  498.898135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  500.999928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  501.010165] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  503.111921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  503.122146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  505.223917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  505.234132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  507.335916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  507.346138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  509.447919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  509.458143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  511.559922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  511.570142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  513.671916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  513.682131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  515.783919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  515.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  517.895921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  517.906146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  520.007926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  520.018169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  522.119918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  522.130134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  524.231912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  524.242134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  526.343920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  526.354144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  528.455914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  528.466133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  530.567916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  530.578132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  532.679915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  532.690135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  534.791920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  534.802145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  536.903914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  536.914135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  539.015916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  539.026132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  541.127918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  541.138138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  543.239926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  543.250150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  545.351914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  545.362132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  547.463921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  547.474138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  549.575919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  549.586145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  551.687926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  551.698146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  553.799916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  553.810132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  555.911920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  555.922138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  558.023915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  558.034135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  560.135928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  560.146147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  562.247918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  562.258131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  564.359915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  564.370139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  566.471916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  566.482138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  568.583914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  568.594131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  570.695916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  570.706135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  572.807920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  572.818141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  574.919922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  574.930142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  577.031914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  577.042130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  579.143919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  579.154135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  581.255917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  581.266141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  583.367925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  583.378151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  585.479919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  585.490135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  587.591920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  587.602141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  589.703923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  589.714146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  591.815910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  591.826139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  593.927919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  593.938134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  596.039914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  596.050138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  598.151920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  598.162142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  600.263914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  600.274128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  602.375914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  602.386131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  604.487918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  604.498142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  606.599919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  606.610141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  608.711920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  608.722147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  610.823918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  610.834140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  612.935917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  612.946143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  615.019924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  615.030147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  617.131915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  617.142136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  619.243917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  619.254132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  621.355921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  621.366140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  623.463909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  623.474123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  625.575912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  625.586128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  627.687925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  627.698140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  629.799921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  629.810129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  631.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  631.922136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  634.023908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  634.034139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  636.111914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  636.122129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  638.195916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  638.206132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  640.307920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  640.318140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  642.419916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  642.430152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  644.535920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  644.546141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  646.647917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  646.658156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  648.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  648.746129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  650.847912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  650.858137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  652.960116] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  652.970466] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  655.067916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  655.078140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  657.179920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  657.190145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  659.295917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  659.306135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  661.407920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  661.418140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  663.520032] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  663.530322] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  665.631916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  665.642134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  667.743915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  667.754138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  669.827915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  669.838140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  671.939907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  671.950125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  674.059935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  674.070163] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  676.171918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  676.182135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  678.283919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  678.294138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  680.367919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  680.378143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  682.479911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  682.490127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  684.587928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  684.598156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  686.699923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  686.710156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  688.811921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  688.822137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  690.923916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  690.934141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  693.035920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  693.046150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  695.147933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  695.158163] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  697.259916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  697.270135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  699.371921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  699.382147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  701.483916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  701.494144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  703.595918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  703.606134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  705.707924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  705.718140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  707.819920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  707.830144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  709.931909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  709.942127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  712.039918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  712.050133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  714.151929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  714.162148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  716.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  716.274143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  718.375917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  718.386142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  720.487948] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  720.498181] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  722.599914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  722.610132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  724.711918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  724.722133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  726.823918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  726.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  728.935922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  728.946139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  731.047915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  731.058129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  733.159920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  733.170141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  735.271918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  735.282141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  737.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  737.394141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  739.495918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  739.506135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  741.607913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  741.618131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  743.719918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  743.730147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  745.831913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  745.842132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  747.943923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  747.954140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  750.055916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  750.066139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  752.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  752.154129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  754.255916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  754.266132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  756.367917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  756.378146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  758.479922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  758.490142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  760.591913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  760.602131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  762.703919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  762.714137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  764.815917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  764.826142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  766.927924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  766.938148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  769.031917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  769.042133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  771.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  771.154144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  773.255919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  773.266144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  775.367914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  775.378132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  777.479917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  777.490134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  779.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  779.602138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  781.703921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  781.714143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  783.815915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  783.826131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  785.927919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  785.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  788.039919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  788.050145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  790.151915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  790.162142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  792.263916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  792.274132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  794.375921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  794.386138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  796.487916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  796.498142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  798.599915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  798.610138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  800.711919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  800.722135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  802.823915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  802.834132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  804.935918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  804.946137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  807.047930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  807.058155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  809.159916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  809.170133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  811.247916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  811.258141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  813.359915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  813.370133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  815.463922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  815.474141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  817.575922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  817.586141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  819.687927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  819.698147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  821.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  821.810131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  823.911914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  823.922136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  826.023919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  826.034142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  828.115917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  828.126142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  830.227928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  830.238152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  832.347936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  832.358157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  834.459922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  834.470139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  836.571924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  836.582146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  838.683927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  838.694153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  840.795916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  840.806135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  842.907924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  842.918142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  845.019925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  845.030161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  847.131914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  847.142133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  849.243942] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  849.254164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  851.355915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  851.366136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  853.467925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  853.478152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  855.559921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  855.570140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  857.671916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  857.682132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  859.787921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  859.798144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  861.899915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  861.910133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  864.011916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  864.022133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  866.123915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  866.134138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  868.238518] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  868.251928] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  870.363927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  870.374151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  872.475917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  872.486132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  874.587914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  874.598131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  876.699915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  876.710135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  878.811940] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  878.822190] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  880.923917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  880.934132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  883.035934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  883.046188] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  885.147919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  885.158140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  887.259915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  887.270131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  889.371918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  889.382134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  891.483919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  891.494143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  893.595920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  893.606144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  895.707916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  895.718133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  897.819919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  897.830136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  899.931932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  899.942151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  902.043926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  902.054149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  904.155917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  904.166137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  906.267913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  906.278137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  908.379914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  908.390141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  910.491914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  910.502129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  912.603918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  912.614134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  914.715916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  914.726139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  916.827920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  916.838140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  918.939915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  918.950135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  921.051923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  921.062139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  923.163920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  923.174140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  925.275917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  925.286152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  927.387917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  927.398132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  929.499920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  929.510136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  931.611919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  931.622139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  933.723938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  933.734160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  935.835917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  935.846133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  937.947922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  937.958138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  940.059919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  940.070140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  942.171913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  942.182133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  944.283917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  944.294131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  946.395915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  946.406138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  948.507920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  948.518138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  950.619916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  950.630131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  952.731923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  952.742141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  954.843917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  954.854138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  956.955921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  956.966146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  959.067915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  959.078132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  961.179918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  961.190134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  963.291919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  963.302143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  965.403925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  965.414152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  967.515942] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  967.526164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  969.627921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  969.638138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  971.739922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  971.750143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  973.831920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  973.842149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  975.943909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  975.954123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  978.055917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  978.066134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  980.167912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  980.178138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  982.279917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  982.290142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  984.391929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  984.402150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  986.503915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  986.514132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  988.615918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  988.626137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  990.727921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  990.738146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  992.839914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  992.850131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  994.951919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  994.962135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  997.063915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  997.074136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [  999.175920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [  999.186142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1001.287914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1001.298127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1003.399920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1003.410139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1005.511918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1005.522141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1007.623925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1007.634146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1009.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1009.746132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1011.847920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1011.858141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1013.959921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1013.970141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1016.043919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1016.054146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1018.155914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1018.166127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1020.267917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1020.278134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1022.379917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1022.390137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1024.491921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1024.502150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1026.603917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1026.614132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1028.715917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1028.726138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1030.827918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1030.838138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1032.939908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1032.950136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1035.023915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1035.034141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1037.135916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1037.146130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1039.247916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1039.258142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1041.359920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1041.370148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1043.463916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1043.474133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1045.575916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1045.586135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1047.687916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1047.698143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1049.799912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1049.810138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1051.911917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1051.922134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1054.023921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1054.034137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1056.135919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1056.146139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1058.251914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1058.262137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1060.363916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1060.374139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1062.452061] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1062.463506] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1064.575923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1064.586145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1066.687916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1066.698130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1068.803921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1068.814140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1070.915913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1070.926128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1073.031949] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1073.042178] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1075.143915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1075.154131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1077.227917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1077.238134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1079.339922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1079.350137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1081.451919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1081.462143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1083.567933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1083.578159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1085.679921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1085.690143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1087.791926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1087.802155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1089.903915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1089.914131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1092.015920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1092.026145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1094.127924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1094.138149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1096.239912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1096.250129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1098.351916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1098.362132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1100.463916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1100.474140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1102.575919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1102.586139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1104.687917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1104.698136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1106.799915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1106.810134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1108.911918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1108.922143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1111.023936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1111.034189] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1113.135915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1113.146130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1115.247919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1115.258137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1117.359918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1117.370141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1119.471920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1119.482139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1121.583919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1121.594133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1123.687916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1123.698134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1125.799920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1125.810145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1127.911915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1127.922132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1130.023917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1130.034133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1132.135916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1132.146141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1134.247912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1134.258145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1136.359915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1136.370140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1138.471918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1138.482137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1140.583920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1140.594151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1142.695926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1142.706148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1144.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1144.818133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1146.919922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1146.930140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1149.031917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1149.042141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1151.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1151.154144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1153.255917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1153.266135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1155.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1155.378143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1157.451919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1157.462148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1159.563940] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1159.574156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1161.675914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1161.686132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1163.783926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1163.794146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1165.895915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1165.906132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1168.007920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1168.018137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1170.091913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1170.102137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1172.203918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1172.214145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1174.315914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1174.326142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1176.423922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1176.434146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1178.535914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1178.546133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1180.647916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1180.658139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1182.759920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1182.770143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1184.871923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1184.882152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1186.983915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1186.994137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1189.095921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1189.106137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1191.207914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1191.218141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1193.319923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1193.330147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1195.431915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1195.442129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1197.543916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1197.554136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1199.655918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1199.666143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1201.767920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1201.778148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1203.879920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1203.890139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1205.991925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1206.002157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1208.103921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1208.114146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1210.215915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1210.226146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1212.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1212.338133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1214.439916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1214.450139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1216.551924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1216.562145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1218.663916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1218.674134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1220.775919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1220.786138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1222.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1222.898150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1224.999925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1225.010147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1227.111917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1227.122132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1229.223923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1229.234145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1231.311928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1231.322155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1233.423915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1233.434131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1235.535914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1235.546144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1237.647913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1237.658138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1239.759928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1239.770154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1241.871914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1241.882133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1243.983916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1243.994141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1246.087911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1246.098136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1248.199916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1248.210129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1250.311921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1250.322140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1252.423915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1252.434141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1254.535917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1254.546142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1256.647917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1256.658137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1258.759914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1258.770142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1260.871919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1260.882144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1262.983913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1262.994130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1265.095916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1265.106137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1267.208073] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1267.219461] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1269.323918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1269.334132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1271.435916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1271.446132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1273.555922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1273.566143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1275.667914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1275.678143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1277.791944] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1277.802172] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1279.903916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1279.914145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1282.015921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1282.026186] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1284.127922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1284.138139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1286.239915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1286.250145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1288.351929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1288.362156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1290.463921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1290.474140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1292.575914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1292.586134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1294.687919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1294.698145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1296.799932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1296.810157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1298.911916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1298.922134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1301.023919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1301.034137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1303.135922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1303.146146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1305.247914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1305.258133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1307.359917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1307.370136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1309.471916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1309.482146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1311.583912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1311.594137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1313.695918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1313.706136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1315.807920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1315.818139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1317.895914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1317.906139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1320.007918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1320.018142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1322.119922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1322.130141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1324.231918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1324.242145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1326.343913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1326.354134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1328.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1328.466132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1330.567916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1330.578141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1332.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1332.690146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1334.791916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1334.802132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1336.903916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1336.914132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1339.015919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1339.026137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1341.099921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1341.110146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1343.211911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1343.222124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1345.323915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1345.334131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1347.431918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1347.442141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1349.543916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1349.554133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1351.655917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1351.666139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1353.767917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1353.778141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1355.879922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1355.890160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1357.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1358.002136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1360.103914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1360.114139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1362.215923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1362.226145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1364.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1364.338133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1366.439919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1366.450136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1368.551916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1368.562139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1370.663926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1370.674150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1372.775920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1372.786137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1374.887920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1374.898141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1376.999921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1377.010143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1379.111911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1379.122131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1381.223919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1381.234133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1383.335915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1383.346137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1385.447919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1385.458139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1387.559914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1387.570130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1389.671919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1389.682134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1391.783917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1391.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1393.895923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1393.906148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1396.007913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1396.018131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1398.119918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1398.130138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1400.231918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1400.242139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1402.343910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1402.354138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1404.455918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1404.466134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1406.567920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1406.578141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1408.679918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1408.690145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1410.791910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1410.802129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1412.903919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1412.914137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1415.015923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1415.026171] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1417.127915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1417.138144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1419.239914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1419.250133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1421.351916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1421.362133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1423.463919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1423.474148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1425.575921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1425.586147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1427.687915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1427.698132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1429.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1429.810139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1431.911920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1431.922138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1434.023925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1434.034150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1436.135916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1436.146134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1438.247919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1438.258137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1440.359915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1440.370140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1442.471920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1442.482154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1444.583917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1444.594134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1446.695913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1446.706137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1448.807918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1448.818138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1450.919917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1450.930141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1453.031915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1453.042130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1455.143917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1455.154141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1457.255921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1457.266147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1459.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1459.378141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1461.480113] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1461.490540] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1463.599914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1463.610140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1465.711919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1465.722147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1467.839909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1467.850124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1469.951918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1469.962136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1472.063925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1472.074146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1474.175923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1474.186152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1476.287927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1476.298152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1478.399915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1478.410134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1480.511914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1480.522139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1482.623919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1482.634145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1484.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1484.746140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1486.847915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1486.858131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1488.959918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1488.970138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1491.071915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1491.082140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1493.183932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1493.194156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1495.295918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1495.306134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1497.407915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1497.418142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1499.519912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1499.530138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1501.631915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1501.642146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1503.743918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1503.754139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1505.855921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1505.866142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1507.967927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1507.978151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1510.079916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1510.090134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1512.171917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1512.182133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1514.283922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1514.294138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1516.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1516.402136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1518.503916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1518.514133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1520.615919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1520.626144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1522.727915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1522.738143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1524.839917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1524.850134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1526.951918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1526.962146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1529.063921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1529.074149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1531.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1531.186131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1533.287919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1533.298139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1535.399921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1535.410143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1537.511915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1537.522144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1539.623917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1539.634135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1541.735921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1541.746146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1543.847922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1543.858143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1545.951932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1545.962157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1548.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1548.074134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1550.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1550.186136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1552.287922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1552.298142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1554.399913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1554.410130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1556.511920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1556.522136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1558.623919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1558.634140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1560.735908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1560.746123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1562.847917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1562.858140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1564.959920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1564.970140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1567.071919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1567.082140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1569.183913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1569.194138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1571.295918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1571.306139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1573.383919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1573.394141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1575.495920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1575.506149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1577.607914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1577.618130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1579.719917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1579.730142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1581.831917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1581.842141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1583.943915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1583.954132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1586.055916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1586.066138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1588.167917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1588.178138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1590.279920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1590.290148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1592.391917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1592.402136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1594.503919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1594.514141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1596.615919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1596.626145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1598.727913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1598.738138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1600.839917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1600.850133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1602.951923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1602.962142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1605.043922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1605.054139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1607.155916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1607.166153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1609.267929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1609.278154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1611.379918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1611.390135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1613.491914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1613.502138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1615.603919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1615.614146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1617.715919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1617.726147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1619.815920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1619.826145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1621.927915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1621.938131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1624.039921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1624.050145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1626.151919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1626.162142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1628.263919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1628.274154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1630.375917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1630.386136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1632.487914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1632.498137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1634.599919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1634.610144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1636.711918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1636.722144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1638.823916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1638.834137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1640.935917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1640.946140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1643.047921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1643.058141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1645.159913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1645.170131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1647.271918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1647.282134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1649.383921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1649.394146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1651.495911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1651.506127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1653.607916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1653.618131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1655.721010] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1655.732116] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1657.839918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1657.850138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1659.951913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1659.962141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1662.079928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1662.090156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1664.191915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1664.202132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1666.307920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1666.318164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1668.419910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1668.430128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1670.531908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1670.542125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1672.643918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1672.654136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1674.755919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1674.766128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1676.867908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1676.878126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1678.979919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1678.990149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1681.091924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1681.102141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1683.203920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1683.214129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1685.315922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1685.326135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1687.427912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1687.438140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1689.539916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1689.550144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1691.651913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1691.662136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1693.763917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1693.774139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1695.875919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1695.886140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1697.987947] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1697.998169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1700.099915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1700.110129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1702.211915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1702.222133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1704.323918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1704.334136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1706.435918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1706.446143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1708.547921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1708.558140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1710.659917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1710.670141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1712.771923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1712.782151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1714.883915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1714.894134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1716.995923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1717.006172] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1719.107916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1719.118138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1721.219924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1721.230149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1723.331918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1723.342137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1725.443920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1725.454137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1727.555918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1727.566145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1729.667914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1729.678141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1731.779916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1731.790138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1733.891915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1733.902139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1736.003921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1736.014176] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1738.115917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1738.126137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1740.203926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1740.214145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1742.315918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1742.326140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1744.427921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1744.438145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1746.539919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1746.550137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1748.651918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1748.662142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1750.763922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1750.774149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1752.875915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1752.886132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1754.983925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1754.994149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1757.095920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1757.106136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1759.207922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1759.218143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1761.319917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1761.330143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1763.431927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1763.442153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1765.543918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1765.554136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1767.655915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1767.666139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1769.767919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1769.778144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1771.879915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1771.890134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1773.991914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1774.002138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1776.103915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1776.114139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1778.215921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1778.226146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1780.327923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1780.338149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1782.439917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1782.450137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1784.551919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1784.562139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1786.663925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1786.674144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1788.775916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1788.786132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1790.887920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1790.898140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1792.999932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1793.010204] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1795.111928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1795.122154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1797.223915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1797.234136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1799.335913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1799.346133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1801.447919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1801.458144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1803.559929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1803.570154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1805.671917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1805.682136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1807.783917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1807.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1809.895919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1809.906141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1812.007915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1812.018132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1814.119918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1814.130134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1816.231916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1816.242140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1818.343924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1818.354147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1820.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1820.466144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1822.567921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1822.578138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1824.679914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1824.690136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1826.791915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1826.802140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1828.903918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1828.914135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1831.019917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1831.030139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1833.131914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1833.142130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1835.243923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1835.254139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1837.355918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1837.366143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1839.452088] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1839.463505] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1841.571915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1841.582138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1843.683916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1843.694139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1845.799916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1845.810134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1847.911918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1847.922138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1850.027968] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1850.038212] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1852.139916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1852.150137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1854.251924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1854.262149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1856.363915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1856.374131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1858.475919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1858.486135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1860.591920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1860.602147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1862.703920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1862.714137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1864.815920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1864.826142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1866.927926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1866.938154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1869.039915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1869.050133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1871.151922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1871.162142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1873.263919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1873.274146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1875.375927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1875.386151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1877.487918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1877.498134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1879.599916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1879.610139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1881.711918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1881.722143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1883.823915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1883.834131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1885.935916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1885.946133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1888.047917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1888.058147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1890.159922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1890.170150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1892.271916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1892.282138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1894.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1894.394136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1896.495919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1896.506144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1898.607925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1898.618144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1900.719914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1900.730132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1902.831920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1902.842139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1904.943922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1904.954142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1907.055915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1907.066138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1909.167916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1909.178134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1911.279919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1911.290146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1913.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1913.402140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1915.503917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1915.514146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1917.615916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1917.626134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1919.727916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1919.738138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1921.839921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1921.850147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1923.951934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1923.962161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1926.063917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1926.074135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1928.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1928.186138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1930.287921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1930.298144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1932.399918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1932.410133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1934.511919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1934.522140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1936.623921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1936.634140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1938.735927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1938.746153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1940.839915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1940.850133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1942.951917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1942.962143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1945.063926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1945.074154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1947.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1947.186133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1949.287920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1949.298138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1951.399920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1951.410147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1953.511924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1953.522143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1955.623917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1955.634137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1957.735920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1957.746138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1959.847918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1959.858142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1961.959909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1961.970127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1964.071919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1964.082134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1966.183918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1966.194139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1968.295918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1968.306144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1970.407915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1970.418140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1972.519915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1972.530136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1974.631916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1974.642138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1976.743921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1976.754145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1978.855914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1978.866130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1980.951926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1980.962145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1983.063919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1983.074143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1985.175930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1985.186152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1987.287918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1987.298133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1989.399917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1989.410137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1991.511922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1991.522154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1993.623917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1993.634132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1995.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1995.746136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1997.831920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1997.842146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 1999.943916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 1999.954134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2002.055915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2002.066139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2004.167918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2004.178139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2006.279909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2006.290123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2008.391916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2008.402134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2010.503919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2010.514137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2012.615917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2012.626139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2014.727913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2014.738135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2016.839916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2016.850134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2018.951921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2018.962138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2021.063917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2021.074140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2023.175919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2023.186147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2025.291922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2025.302143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2027.403916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2027.414142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2029.515918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2029.526136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2031.623922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2031.634150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2033.736055] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2033.746441] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2035.855914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2035.866135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2037.967918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2037.978139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2040.091919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2040.102135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2042.175922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2042.186141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2044.291949] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2044.302194] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2046.403923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2046.414139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2048.515924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2048.526147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2050.627916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2050.638139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2052.739919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2052.750134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2054.851921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2054.862148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2056.963919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2056.974144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2059.075930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2059.086157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2061.187915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2061.198131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2063.299918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2063.310145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2065.411922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2065.422146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2067.523914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2067.534135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2069.635918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2069.646138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2071.747916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2071.758137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2073.859924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2073.870145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2075.971916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2075.982135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2078.083922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2078.094138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2080.195920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2080.206146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2082.307929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2082.318149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2084.419916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2084.430137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2086.531920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2086.542143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2088.643918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2088.654145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2090.755917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2090.766141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2092.867915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2092.878135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2094.979917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2094.990140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2097.091927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2097.102155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2099.203916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2099.214136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2101.315916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2101.326138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2103.427920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2103.438149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2105.539923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2105.550146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2107.651918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2107.662132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2109.763920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2109.774137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2111.875914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2111.886139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2113.987910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2113.998130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2116.099915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2116.110129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2118.203921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2118.214142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2120.315921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2120.326144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2122.427914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2122.438131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2124.539918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2124.550141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2126.651917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2126.662141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2128.763912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2128.774136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2130.875917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2130.886147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2132.987948] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2132.998182] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2135.099921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2135.110144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2137.211926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2137.222150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2139.323916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2139.334135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2141.435920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2141.446144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2143.547917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2143.558145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2145.659929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2145.670150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2147.771917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2147.782135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2149.883953] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2149.894175] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2151.995930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2152.006167] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2154.107941] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2154.118166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2156.219917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2156.230137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2158.331918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2158.342138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2160.443923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2160.454148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2162.555916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2162.566133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2164.667919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2164.678139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2166.779932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2166.790152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2168.891917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2168.902147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2171.003918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2171.014134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2173.115923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2173.126142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2175.227916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2175.238146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2177.339912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2177.350128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2179.431928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2179.442149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2181.543915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2181.554133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2183.655916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2183.666143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2185.767919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2185.778143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2187.879920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2187.890148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2189.991922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2190.002170] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2192.103915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2192.114141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2194.215919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2194.226144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2196.327917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2196.338133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2198.439918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2198.450135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2200.551919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2200.562143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2202.663914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2202.674139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2204.775914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2204.786136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2206.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2206.898140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2208.999919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2209.010142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2211.111927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2211.122153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2213.223915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2213.234131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2215.335915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2215.346139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2217.448073] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2217.458466] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2219.563914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2219.574138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2221.675908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2221.686137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2223.791912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2223.802132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2225.903917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2225.914136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2228.016029] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2228.026396] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2230.127916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2230.138134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2232.211916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2232.222134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2234.331913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2234.342133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2236.423917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2236.434144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2238.539941] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2238.550169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2240.651921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2240.662141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2242.763917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2242.774142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2244.875929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2244.886154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2246.987921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2246.998157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2249.099918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2249.110143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2251.183914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2251.194137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2253.295922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2253.306146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2255.407914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2255.418133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2257.519920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2257.530138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2259.631918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2259.642140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2261.743908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2261.754125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2263.855914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2263.866132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2265.967914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2265.978139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2268.079906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2268.090135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2270.191910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2270.202140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2272.303914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2272.314131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2274.415917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2274.426145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2276.527914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2276.538144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2278.639915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2278.650131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2280.751916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2280.762135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2282.855917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2282.866139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2284.967912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2284.978135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2287.079919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2287.090136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2289.191921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2289.202139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2291.303921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2291.314144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2293.415918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2293.426142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2295.527916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2295.538130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2297.639914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2297.650136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2299.751919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2299.762143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2301.863915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2301.874133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2303.975916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2303.986132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2306.087918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2306.098142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2308.199922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2308.210145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2310.311914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2310.322132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2312.423919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2312.434136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2314.535919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2314.546144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2316.647925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2316.658153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2318.759917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2318.770149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2320.871920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2320.882139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2322.983921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2322.994145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2325.095913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2325.106139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2327.207918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2327.218139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2329.319919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2329.330140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2331.431918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2331.442146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2333.543930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2333.554155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2335.655915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2335.666131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2337.767916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2337.778139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2339.879920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2339.890144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2341.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2342.002131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2344.103918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2344.114137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2346.215916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2346.226138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2348.327924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2348.338149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2350.439917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2350.450134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2352.551919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2352.562139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2354.663918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2354.674142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2356.775913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2356.786139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2358.887917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2358.898133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2360.999923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2361.010139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2363.111917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2363.122141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2365.223917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2365.234145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2367.335915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2367.346133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2369.447916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2369.458141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2371.559922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2371.570148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2373.671915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2373.682136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2375.783916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2375.794133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2377.895919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2377.906142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2380.007918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2380.018143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2382.119915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2382.130133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2384.231919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2384.242140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2386.343919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2386.354142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2388.455925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2388.466151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2390.567915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2390.578132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2392.679924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2392.690139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2394.791916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2394.802141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2396.903916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2396.914133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2399.015917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2399.026135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2401.127916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2401.138140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2403.239919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2403.250144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2405.351919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2405.362144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2407.463919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2407.474132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2409.575917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2409.586138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2411.687924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2411.698164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2413.799913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2413.810129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2415.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2415.922136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2418.023918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2418.034142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2420.135925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2420.146154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2422.252113] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2422.262594] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2424.367917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2424.378133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2426.479918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2426.490145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2428.595915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2428.606133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2430.707921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2430.718143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2432.819926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2432.830175] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2434.931915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2434.942134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2437.043919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2437.054139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2439.155917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2439.166139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2441.275920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2441.286151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2443.387919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2443.398144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2445.499917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2445.510139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2447.611917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2447.622141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2449.723912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2449.734139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2451.835916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2451.846136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2453.947921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2453.958141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2456.059970] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2456.070192] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2458.171919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2458.182152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2460.283920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2460.294136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2462.395915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2462.406139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2464.507918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2464.518140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2466.619915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2466.630131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2468.731918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2468.742136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2470.843918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2470.854141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2472.955949] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2472.966168] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2475.067915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2475.078133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2477.179919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2477.190138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2479.291916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2479.302139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2481.403926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2481.414152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2483.515916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2483.526137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2485.627922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2485.638139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2487.739921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2487.750146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2489.851927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2489.862153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2491.963920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2491.974138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2494.075915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2494.086138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2496.187919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2496.198161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2498.299920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2498.310151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2500.411916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2500.422132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2502.523918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2502.534136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2504.635922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2504.646146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2506.747917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2506.758144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2508.859919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2508.870135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2510.971917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2510.982142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2513.083918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2513.094150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2515.195915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2515.206133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2517.307920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2517.318137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2519.399920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2519.410137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2521.511914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2521.522138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2523.623925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2523.634151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2525.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2525.746131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2527.847923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2527.858145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2529.959916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2529.970143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2532.071929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2532.082155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2534.183920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2534.194136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2536.295917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2536.306140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2538.407919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2538.418140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2540.519931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2540.530151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2542.631916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2542.642132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2544.743927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2544.754146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2546.855922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2546.866149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2548.967916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2548.978133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2551.079918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2551.090134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2553.191921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2553.202144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2555.303920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2555.314144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2557.415917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2557.426131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2559.527919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2559.538137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2561.639921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2561.650142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2563.751929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2563.762153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2565.863921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2565.874140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2567.975916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2567.986140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2570.087918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2570.098138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2572.199914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2572.210131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2574.311919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2574.322134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2576.423917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2576.434137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2578.535924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2578.546150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2580.647914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2580.658132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2582.759917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2582.770141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2584.871916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2584.882140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2586.983925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2586.994151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2589.095916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2589.106136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2591.207922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2591.218141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2593.319914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2593.330138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2595.431927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2595.442168] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2597.543920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2597.554138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2599.655915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2599.666136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2601.771919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2601.782137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2603.883916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2603.894141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2605.996143] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2606.007059] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2608.115914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2608.126145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2610.235913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2610.246132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2612.347919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2612.358139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2614.459920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2614.470149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2616.575932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2616.586146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2618.687915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2618.698141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2620.799924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2620.810150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2622.911916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2622.922133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2625.023920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2625.034139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2627.135923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2627.146145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2629.247913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2629.258139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2631.359916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2631.370133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2633.471920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2633.482139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2635.583915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2635.594141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2637.695916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2637.706141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2639.807914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2639.818134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2641.919918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2641.930139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2644.031921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2644.042147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2646.143933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2646.154158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2648.255916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2648.266133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2650.367919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2650.378142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2652.479924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2652.490149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2654.591916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2654.602132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2656.703920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2656.714141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2658.815918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2658.826141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2660.927927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2660.938148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2663.039937] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2663.050193] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2665.151920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2665.162139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2667.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2667.274140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2669.375920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2669.386155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2671.487917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2671.498134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2673.599916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2673.610144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2675.711920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2675.722146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2677.823915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2677.834138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2679.935918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2679.946160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2682.047918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2682.058143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2684.159922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2684.170148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2686.271916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2686.282134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2688.383920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2688.394136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2690.495922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2690.506148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2692.607916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2692.618146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2694.719918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2694.730138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2696.831922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2696.842144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2698.943917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2698.954142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2701.027918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2701.038144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2703.139913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2703.150134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2705.251917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2705.262135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2707.363919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2707.374139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2709.475921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2709.486146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2711.587916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2711.598134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2713.699920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2713.710139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2715.811919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2715.822138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2717.923926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2717.934150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2720.035915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2720.046133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2722.147922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2722.158139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2724.259911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2724.270142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2726.371912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2726.382131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2728.483919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2728.494137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2730.595915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2730.606145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2732.707927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2732.718151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2734.819920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2734.830153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2736.931916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2736.942132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2739.043916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2739.054135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2741.155921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2741.166146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2743.267916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2743.278131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2745.379920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2745.390134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2747.491916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2747.502142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2749.603924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2749.614145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2751.715915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2751.726131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2753.827921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2753.838139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2755.939920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2755.950142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2758.051917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2758.062152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2760.163918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2760.174145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2762.275921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2762.286141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2764.387920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2764.398141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2766.499919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2766.510150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2768.611918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2768.622136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2770.723917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2770.734138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2772.835920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2772.846149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2774.947914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2774.958130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2777.059916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2777.070135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2779.171919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2779.182144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2781.287922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2781.298137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2783.399917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2783.410133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2785.511922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2785.522137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2787.623915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2787.634143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2789.740048] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2789.750475] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2791.855917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2791.866142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2793.967922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2793.978147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2796.083918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2796.094141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2798.203918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2798.214145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2800.315933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2800.326163] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2802.427917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2802.438133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2804.539918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2804.550143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2806.631916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2806.642139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2808.743918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2808.754140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2810.855920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2810.866148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2812.967916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2812.978135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2815.079915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2815.090136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2817.191922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2817.202146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2819.303915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2819.314137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2821.415918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2821.426139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2823.527921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2823.538144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2825.639925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2825.650145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2827.751917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2827.762131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2829.863920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2829.874138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2831.975916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2831.986137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2834.087927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2834.098147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2836.199919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2836.210136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2838.311915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2838.322136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2840.423917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2840.434141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2842.535916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2842.546136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2844.647915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2844.658131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2846.759920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2846.770141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2848.871921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2848.882141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2850.983914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2850.994136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2853.095917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2853.106135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2855.207918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2855.218138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2857.319923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2857.330150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2859.431915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2859.442136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2861.543922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2861.554138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2863.655918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2863.666139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2865.767934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2865.778169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2867.879918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2867.890137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2869.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2870.002138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2872.103917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2872.114137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2874.215932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2874.226160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2876.327918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2876.338134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2878.439914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2878.450135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2880.551928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2880.562154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2882.663915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2882.674135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2884.775917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2884.786135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2886.887918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2886.898145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2888.999931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2889.010171] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2891.111916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2891.122133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2893.223921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2893.234142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2895.335923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2895.346142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2897.447926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2897.458152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2899.559918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2899.570135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2901.671913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2901.682138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2903.783914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2903.794142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2905.895912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2905.906139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2908.007920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2908.018137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2910.119916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2910.130134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2912.231920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2912.242139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2914.343915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2914.354133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2916.455917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2916.466136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2918.567917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2918.578141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2920.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2920.690145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2922.791914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2922.802144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2924.903920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2924.914139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2927.015931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2927.026195] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2929.127915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2929.138151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2931.239916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2931.250134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2933.351922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2933.362139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2935.463923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2935.474148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2937.575916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2937.586143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2939.687920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2939.698138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2941.799916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2941.810139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2943.911917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2943.922139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2946.023916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2946.034142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2948.135916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2948.146134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2950.247916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2950.258141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2952.359924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2952.370146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2954.471916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2954.482130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2956.583919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2956.594137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2958.695919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2958.706140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2960.807909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2960.818125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2962.919917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2962.930140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2965.031922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2965.042141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2967.143919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2967.154143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2969.255918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2969.266150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2971.367918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2971.378132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2973.452065] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2973.463497] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2975.579919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2975.590138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2977.691917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2977.702139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2979.811922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2979.822142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2981.923917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2981.934135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2984.040033] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2984.050250] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2986.151915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2986.162130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2988.263919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2988.274134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2990.375920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2990.386138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2992.487914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2992.498145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2994.599918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2994.610137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2996.711921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2996.722137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 2998.823920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 2998.834140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3000.935918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3000.946148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3003.047920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3003.058136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3005.159919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3005.170143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3007.271918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3007.282142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3009.383913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3009.394129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3011.495915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3011.506130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3013.607918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3013.618142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3015.719921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3015.730148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3017.831916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3017.842133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3019.943921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3019.954135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3022.055919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3022.066138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3024.167924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3024.178144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3026.279919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3026.290136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3028.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3028.402139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3030.503914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3030.514135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3032.615927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3032.626153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3034.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3034.738137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3036.839922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3036.850141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3038.951941] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3038.962157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3041.063917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3041.074141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3043.175916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3043.186132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3045.287916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3045.298138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3047.399921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3047.410146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3049.511915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3049.522131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3051.623916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3051.634134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3053.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3053.746141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3055.847923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3055.858147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3057.951920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3057.962139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3060.063914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3060.074137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3062.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3062.186139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3064.287911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3064.298126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3066.399918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3066.410140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3068.511918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3068.522139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3070.623920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3070.634141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3072.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3072.746131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3074.847916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3074.858136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3076.959918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3076.970143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3079.043921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3079.054146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3081.155909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3081.166135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3083.267919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3083.278136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3085.379922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3085.390137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3087.491917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3087.502140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3089.603928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3089.614154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3091.715914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3091.726132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3093.827916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3093.838140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3095.939918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3095.950142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3098.051915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3098.062140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3100.163915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3100.174133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3102.275918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3102.286137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3104.387938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3104.398158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3106.499914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3106.510137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3108.611918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3108.622137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3110.723916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3110.734141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3112.835915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3112.846144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3114.947919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3114.958136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3117.059923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3117.070137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3119.171920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3119.182147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3121.283918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3121.294146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3123.395915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3123.406132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3125.507915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3125.518137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3127.619918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3127.630138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3129.731918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3129.742145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3131.843919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3131.854137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3133.955918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3133.966142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3136.067921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3136.078150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3138.179934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3138.190162] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3140.291917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3140.302137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3142.403917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3142.414139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3144.515921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3144.526151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3146.627915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3146.638130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3148.739922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3148.750141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3150.851918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3150.862142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3152.963912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3152.974136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3155.075922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3155.086149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3157.187923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3157.198221] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3159.307920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3159.318149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3161.419926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3161.430154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3163.535920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3163.546145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3165.647925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3165.658152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3167.760061] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3167.770518] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3169.871921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3169.882140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3171.983917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3171.994142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3174.099920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3174.110141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3176.219917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3176.230140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3178.335918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3178.346139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3180.447921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3180.458144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3182.559924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3182.570149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3184.671915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3184.682132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3186.783921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3186.794144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3188.895920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3188.906146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3191.007930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3191.018192] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3193.119919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3193.130136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3195.203920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3195.214138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3197.315917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3197.326135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3199.427919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3199.438147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3201.539931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3201.550156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3203.651916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3203.662137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3205.763919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3205.774143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3207.875923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3207.886151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3209.987920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3209.998157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3212.099918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3212.110140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3214.211920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3214.222144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3216.323920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3216.334145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3218.435917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3218.446135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3220.547921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3220.558140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3222.659924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3222.670148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3224.771914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3224.782141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3226.883917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3226.894138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3228.995915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3229.006139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3231.107918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3231.118140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3233.219916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3233.230134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3235.331918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3235.342138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3237.443917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3237.454143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3239.555926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3239.566151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3241.667915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3241.678138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3243.779918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3243.790137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3245.891917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3245.902144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3248.003908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3248.014127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3250.115917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3250.126135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3252.227924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3252.238141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3254.339914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3254.350138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3256.451920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3256.462153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3258.563915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3258.574132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3260.675915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3260.686142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3262.787912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3262.798142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3264.899916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3264.910131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3267.011922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3267.022180] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3269.095919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3269.106136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3271.207916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3271.218138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3273.319921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3273.330144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3275.431918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3275.442135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3277.543921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3277.554140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3279.655919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3279.666144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3281.767923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3281.778146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3283.879914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3283.890134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3285.991922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3286.002169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3288.103916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3288.114143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3290.215920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3290.226148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3292.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3292.338138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3294.439916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3294.450136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3296.551917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3296.562140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3298.663915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3298.674135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3300.775916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3300.786138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3302.887917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3302.898142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3304.999931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3305.010187] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3307.111917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3307.122132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3309.215923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3309.226143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3311.327918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3311.338142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3313.439918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3313.450142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3315.551920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3315.562137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3317.663916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3317.674139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3319.775921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3319.786146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3321.887915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3321.898136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3323.999916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3324.010134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3326.111915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3326.122138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3328.223923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3328.234149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3330.335915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3330.346130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3332.447919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3332.458136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3334.559918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3334.570141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3336.671925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3336.682153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3338.783916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3338.794135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3340.895922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3340.906145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3343.007918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3343.018144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3345.119927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3345.130154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3347.231918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3347.242133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3349.343916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3349.354139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3351.456103] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3351.466495] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3353.571916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3353.582144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3355.683919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3355.694146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3357.803915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3357.814138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3359.915919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3359.926140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3362.027958] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3362.038325] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3364.139918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3364.150140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3366.247917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3366.258133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3368.359921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3368.370136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3370.471914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3370.482130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3372.583921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3372.594140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3374.695916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3374.706130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3376.807925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3376.818145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3378.919916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3378.930133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3381.031923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3381.042139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3383.143923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3383.154142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3385.255912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3385.266130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3387.367917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3387.378138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3389.479915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3389.490132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3391.591917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3391.602140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3393.703916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3393.714132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3395.815914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3395.826135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3397.927918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3397.938134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3400.039921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3400.050136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3402.151913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3402.162127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3404.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3404.274136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3406.375917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3406.386134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3408.487923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3408.498139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3410.599916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3410.610137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3412.711920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3412.722138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3414.823919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3414.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3416.935926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3416.946143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3419.047915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3419.058139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3421.159922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3421.170146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3423.271917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3423.282133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3425.383915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3425.394132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3427.495921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3427.506135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3429.607916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3429.618136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3431.719921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3431.730144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3433.831916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3433.842132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3435.943919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3435.954136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3438.055918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3438.066142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3440.167906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3440.178123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3442.279916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3442.290132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3444.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3444.402136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3446.503922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3446.514146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3448.615910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3448.626130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3450.727920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3450.738137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3452.839922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3452.850142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3454.951918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3454.962142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3457.063911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3457.074127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3459.175916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3459.186131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3461.287915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3461.298138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3463.399921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3463.410146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3465.511921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3465.522150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3467.623917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3467.634135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3469.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3469.746139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3471.847922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3471.858145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3473.959917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3473.970132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3476.071918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3476.082140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3478.183919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3478.194147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3480.295924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3480.306151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3482.407915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3482.418134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3484.519922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3484.530137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3486.631915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3486.642140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3488.743911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3488.754131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3490.855918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3490.866134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3492.967914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3492.978138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3495.079918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3495.090140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3497.191915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3497.202130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3499.303915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3499.314134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3501.415919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3501.426141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3503.527922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3503.538149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3505.639915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3505.650129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3507.751919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3507.762137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3509.867933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3509.878153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3511.979919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3511.990134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3514.091938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3514.102174] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3516.203924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3516.214147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3518.315919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3518.326134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3520.427920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3520.438137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3522.539921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3522.550143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3524.651928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3524.662154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3526.763918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3526.774136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3528.875917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3528.886137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3530.987919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3530.998145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3533.099918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3533.110145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3535.207921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3535.218145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3537.319916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3537.330131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3539.431917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3539.442141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3541.543918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3541.554138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3543.655924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3543.666150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3545.767917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3545.778145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3547.879919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3547.890139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3549.991920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3550.002141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3552.103916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3552.114145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3554.215916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3554.226134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3556.327921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3556.338140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3558.439917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3558.450144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3560.551914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3560.562136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3562.663916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3562.674130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3564.775915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3564.786137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3566.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3566.898148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3568.999914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3569.010132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3571.111916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3571.122135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3573.223919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3573.234139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3575.335908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3575.346134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3577.447919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3577.458146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3579.559920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3579.570139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3581.671914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3581.682139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3583.783913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3583.794125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3585.895916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3585.906133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3588.007921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3588.018140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3590.119916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3590.130137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3592.231913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3592.242140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3594.343919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3594.354135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3596.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3596.466146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3598.567920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3598.578144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3600.679914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3600.690144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3602.791916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3602.802133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3604.903917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3604.914138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3607.015922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3607.026142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3609.127915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3609.138134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3611.239918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3611.250140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    hwclock: ioctl(RTC_RD_NAME) to /dev/rtc0 to read the time failed: Invalid argument
    [ 3613.351916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3613.362139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3615.463924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3615.474150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3617.575918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3617.586138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3619.687923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3619.698142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3621.799915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3621.810140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3623.911927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3623.922149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3626.023916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3626.034132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3628.135914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3628.146139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3630.247919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3630.258149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3632.359917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3632.370147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3634.471921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3634.482138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3636.583917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3636.594135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3638.695921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3638.706145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3640.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3640.818134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3642.919919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3642.930140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3645.031920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3645.042143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3647.147917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3647.158134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3649.259929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3649.270147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3651.371924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3651.382151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3653.483916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3653.494135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3655.587929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3655.598149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3657.699911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3657.710138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3659.811917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3659.822142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3661.923916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3661.934133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3664.035916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3664.046144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3666.147925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3666.158149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3668.259912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3668.270132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3670.371918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3670.382136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3672.483914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3672.494143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3674.595926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3674.606150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3676.707916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3676.718136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3678.819920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3678.830138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3680.931914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3680.942141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3683.043927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3683.054153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3685.155915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3685.166133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3687.267915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3687.278138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3689.379913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3689.390139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3691.491912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3691.502127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3693.603917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3693.614132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3695.715917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3695.726141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3697.827920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3697.838145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3699.939914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3699.950137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3702.051917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3702.062137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3704.163917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3704.174141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3706.275905] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3706.286127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3708.387915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3708.398133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3710.499921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3710.510140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3712.611914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3712.622142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3714.723909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3714.734138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3716.835916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3716.846134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3718.947925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3718.958143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3721.059914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3721.070136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3723.171912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3723.182129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3725.255916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3725.266134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3727.367917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3727.378135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3729.479920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3729.490138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3731.591919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3731.602139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3733.703915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3733.714139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3735.815918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3735.826151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3737.927921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3737.938148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3740.039909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3740.050127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3742.151916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3742.162135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3744.263921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3744.274137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3746.375918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3746.386141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3748.487921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3748.498144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3750.599915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3750.610131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3752.711914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3752.722142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3754.823919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3754.834147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3756.935914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3756.946131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3759.047921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3759.058137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3761.159913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3761.170135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3763.271922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3763.282147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3765.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3765.394144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3767.495918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3767.506137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3769.607919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3769.618148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3771.719926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3771.730150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3773.831915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3773.842133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3775.943921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3775.954138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3778.055920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3778.066141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3780.167916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3780.178146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3782.279919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3782.290140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3784.391913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3784.402136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3786.503918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3786.514137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3788.615914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3788.626129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3790.727914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3790.738132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3792.839916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3792.850137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3794.951922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3794.962140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3797.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3797.074145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3799.175918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3799.186138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3801.287919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3801.298147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3803.399924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3803.410150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3805.511916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3805.522134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3807.623920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3807.634137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3809.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3809.746140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3811.847927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3811.858151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3813.959919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3813.970138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3816.071915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3816.082132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3818.183917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3818.194160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3820.295914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3820.306129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3822.407916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3822.418132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3824.519915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3824.530134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3826.631919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3826.642141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3828.744474] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3828.754855] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3830.859920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3830.870143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3832.971914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3832.982134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3835.087910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3835.098137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3837.199918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3837.210139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3839.311928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3839.322174] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3841.423916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3841.434136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3843.535923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3843.546147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3845.647918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3845.658140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3847.759918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3847.770137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3849.871922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3849.882147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3851.983927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3851.994164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3854.095916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3854.106136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3856.207919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3856.218147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3858.319918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3858.330142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3860.431916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3860.442141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3862.535917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3862.546132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3864.647915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3864.658136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3866.759912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3866.770149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3868.871915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3868.882137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3870.983918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3870.994141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3873.067921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3873.078139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3875.179921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3875.190141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3877.291914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3877.302141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3879.403917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3879.414133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3881.515916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3881.526138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3883.627918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3883.638139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3885.739913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3885.750130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3887.851916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3887.862134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3889.963913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3889.974135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3892.075922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3892.086142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3894.167918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3894.178146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3896.279914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3896.290130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3898.375918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3898.386139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3900.487918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3900.498139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3902.599930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3902.610150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3904.711914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3904.722133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3906.823917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3906.834140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3908.935921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3908.946145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3911.047914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3911.058131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3913.131915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3913.142133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3915.243919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3915.254141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3917.355920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3917.366146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3919.467927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3919.478150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3921.579918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3921.590134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3923.691923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3923.702144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3925.803921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3925.814145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3927.915916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3927.926143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3930.027915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3930.038131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3932.139916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3932.150138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3934.251921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3934.262149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3936.363932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3936.374158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3938.475916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3938.486134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3940.587914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3940.598136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3942.699923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3942.710145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3944.811918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3944.822137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3946.923919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3946.934135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3949.035917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3949.046142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3951.147925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3951.158151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3953.259920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3953.270138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3955.371923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3955.382139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3957.483920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3957.494144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3959.595916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3959.606144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3961.703920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3961.714147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3963.815916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3963.826132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3965.927922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3965.938139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3968.039918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3968.050137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3970.151923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3970.162149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3972.263916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3972.274133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3974.375919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3974.386136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3976.487915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3976.498139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3978.599921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3978.610150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3980.711920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3980.722137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3982.823920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3982.834138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3984.935916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3984.946141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3987.047911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3987.058128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3989.159918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3989.170135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3991.271914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3991.282138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3993.383919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3993.394139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3995.495913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3995.506139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3997.607915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3997.618133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 3999.719919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 3999.730143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4001.831922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4001.842148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4003.943921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4003.954146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4006.055918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4006.066137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4008.167918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4008.178145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4010.279926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4010.290152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4012.391916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4012.402132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4014.503920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4014.514138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4016.615919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4016.626144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4018.727913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4018.738130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4020.839920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4020.850139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4022.952131] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4022.962529] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4025.067917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4025.078133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4027.179914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4027.190138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4029.295914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4029.306128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4031.407917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4031.418144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4033.520029] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4033.530285] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4035.631930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4035.642154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4037.743920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4037.754140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4039.859917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4039.870144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4041.971913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4041.982130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4044.099923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4044.110145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4046.211920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4046.222146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4048.323924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4048.334149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4050.435917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4050.446132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4052.547922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4052.558139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4054.659922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4054.670143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4056.771912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4056.782128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4058.883915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4058.894132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4060.995924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4061.006152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4063.107912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4063.118139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4065.219916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4065.230143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4067.331916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4067.342130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4069.443917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4069.454141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4071.555922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4071.566151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4073.667917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4073.678133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4075.779917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4075.790135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4077.891917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4077.902146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4080.003924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4080.014150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4082.115916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4082.126148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4084.227922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4084.238137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4086.339920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4086.350140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4088.451916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4088.462151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4090.563921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4090.574138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4092.675916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4092.686139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4094.787917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4094.798142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4096.899917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4096.910148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4099.011924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4099.022174] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4101.123916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4101.134136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4103.235920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4103.246146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4105.347932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4105.358158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4107.451921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4107.462141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4109.563917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4109.574146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4111.675911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4111.686131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4113.767925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4113.778150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4115.879914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4115.890132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4117.991921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4118.002141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4120.103919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4120.114144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4122.215918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4122.226151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4124.327917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4124.338138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4126.439916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4126.450140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4128.551915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4128.562147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4130.663920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4130.674150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4132.775914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4132.786134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4134.887919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4134.898139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4136.999922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4137.010147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4139.111933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4139.122160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4141.223921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4141.234141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4143.335919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4143.346137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4145.447924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4145.458148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4147.559916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4147.570131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4149.671923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4149.682140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4151.783916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4151.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4153.895914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4153.906139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4156.007919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4156.018139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4158.119915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4158.130139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4160.203917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4160.214141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4162.315921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4162.326149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4164.427917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4164.438148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4166.539916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4166.550134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4168.651919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4168.662143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4170.759920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4170.770139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4172.871923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4172.882144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4174.983917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4174.994149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4177.095916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4177.106130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4179.207914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4179.218140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4181.319917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4181.330146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4183.431929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4183.442153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4185.543913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4185.554133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4187.655917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4187.666141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4189.767920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4189.778147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4191.879918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4191.890142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4193.991919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4194.002133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4196.103916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4196.114139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4198.215924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4198.226148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4200.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4200.338134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4202.439919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4202.450137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4204.551916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4204.562140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4206.663926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4206.674151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4208.775919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4208.786136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4210.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4210.898139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4212.999926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4213.010163] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4215.111911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4215.122129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4217.224115] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4217.234567] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4219.343922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4219.354137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4221.447920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4221.458145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4223.571921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4223.582139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4225.695916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4225.706140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4227.811924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4227.822148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4229.923914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4229.934130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4232.035916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4232.046132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4234.147916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4234.158137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4236.231918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4236.242144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4238.343927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4238.354154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4240.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4240.466132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4242.567921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4242.578139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4244.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4244.690143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4246.791928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4246.802155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4248.903921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4248.914149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4251.015915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4251.026137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4253.127920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4253.138145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4255.239918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4255.250149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4257.351917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4257.362133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4259.463918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4259.474143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4261.575921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4261.586150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4263.687915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4263.698130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4265.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4265.810137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4267.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4267.922146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4270.023925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4270.034156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4272.135917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4272.146135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4274.247922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4274.258140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4276.359920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4276.370141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4278.471915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4278.482142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4280.583915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4280.594131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4282.695914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4282.706132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4284.807920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4284.818142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4286.919928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4286.930160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4289.031917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4289.042134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4291.143917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4291.154136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4293.255921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4293.266147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4295.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4295.378133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4297.479917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4297.490135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4299.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4299.602140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4301.703925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4301.714150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4303.815917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4303.826136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4305.927920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4305.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4308.039918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4308.050140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4310.151912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4310.162138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4312.263916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4312.274135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4314.375914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4314.386138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4316.487918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4316.498143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4318.599923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4318.610147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4320.711917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4320.722134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4322.823916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4322.834139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4324.935921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4324.946144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4327.047915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4327.058131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4329.159916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4329.170134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4331.271919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4331.282137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4333.383924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4333.394148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4335.495916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4335.506134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4337.607918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4337.618141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4339.719917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4339.730139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4341.831910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4341.842134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4343.943916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4343.954138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4346.055921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4346.066139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4348.167921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4348.178142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4350.279912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4350.290129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4352.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4352.402136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4354.503917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4354.514140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4356.615919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4356.626143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4358.727915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4358.738143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4360.839915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4360.850135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4362.951917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4362.962149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4365.063922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4365.074149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4367.175918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4367.186146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4369.287919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4369.298135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4371.399919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4371.410147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4373.511926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4373.522148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4375.623914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4375.634133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4377.739927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4377.750152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4379.851916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4379.862135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4381.963921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4381.974140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4384.075917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4384.086142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4386.187927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4386.198155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4388.299919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4388.310134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4390.411914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4390.422133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4392.523918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4392.534138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4394.635917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4394.646140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4396.747914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4396.758130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4398.859918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4398.870142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4400.952076] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4400.963502] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4403.075916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4403.086133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4405.187920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4405.198140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4407.303917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4407.314140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4409.415921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4409.426137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4411.535936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4411.546155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4413.647906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4413.658134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4415.759915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4415.770134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4417.871921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4417.882136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4419.983915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4419.994141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4422.099932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4422.110171] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4424.199915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4424.210134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4426.311917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4426.322137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4428.423921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4428.434145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4430.535914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4430.546129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4432.615921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4432.626145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4434.727927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4434.738151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4436.839915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4436.850133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4438.951912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4438.962138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4441.063917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4441.074145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4443.175914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4443.186134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4445.287915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4445.298138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4447.399917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4447.410140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4449.511920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4449.522143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4451.623915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4451.634133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4453.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4453.746137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4455.847916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4455.858142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4457.959923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4457.970152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4460.071919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4460.082139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4462.183919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4462.194140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4464.295921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4464.306146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4466.407926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4466.418151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4468.519915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4468.530134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4470.631918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4470.642139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4472.743918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4472.754144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4474.855914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4474.866139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4476.967919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4476.978138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4479.079916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4479.090143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4481.191921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4481.202145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4483.303914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4483.314132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4485.415918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4485.426136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4487.527918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4487.538139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4489.639924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4489.650149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4491.751914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4491.762131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4493.863920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4493.874136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4495.975932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4495.986151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4498.087913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4498.098139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4500.199913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4500.210128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4502.311921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4502.322141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4504.423915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4504.434139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4506.535913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4506.546128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4508.647921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4508.658139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4510.759915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4510.770143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4512.871916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4512.882145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4514.983917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4514.994137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4517.067914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4517.078125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4519.179911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4519.190129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4521.291913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4521.302130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4523.403908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4523.414117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4525.515910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4525.526128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4527.623929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4527.634151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4529.735916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4529.746138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4531.847915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4531.858139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4533.959914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4533.970138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4536.071916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4536.082130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4538.183915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4538.194131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4540.295917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4540.306142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4542.407922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4542.418144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4544.519915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4544.530131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4546.631916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4546.642140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4548.743918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4548.754143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4550.855908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4550.866135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4552.967917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4552.978146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4555.079919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4555.090137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4557.191919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4557.202142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4559.303926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4559.314153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4561.415915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4561.426130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4563.527913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4563.538138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4565.639921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4565.650144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4567.751930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4567.762156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4569.863914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4569.874130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4571.975917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4571.986140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4574.087920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4574.098145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4576.199915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4576.210132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4578.311917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4578.322131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4580.423913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4580.434135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4582.535923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4582.546148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4584.647915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4584.658134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4586.759919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4586.770135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4588.871919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4588.882140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4590.983921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4590.994149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4593.095918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4593.106144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4595.208104] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4595.218461] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4597.323917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4597.334134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4599.435921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4599.446139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4601.555915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4601.566140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4603.675921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4603.686145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4605.792027] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4605.802328] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4607.903919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4607.914140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4610.015922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4610.026180] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4612.127916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4612.138139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4614.239917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4614.250145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4616.351924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4616.362151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4618.463917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4618.474135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4620.575921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4620.586140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4622.687919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4622.698148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4624.799911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4624.810127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4626.911918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4626.922135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4629.023922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4629.034138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4631.135923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4631.146143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4633.247913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4633.258142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4635.359918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4635.370138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4637.471916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4637.482140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4639.583920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4639.594144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4641.695914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4641.706140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4643.807917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4643.818132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4645.919918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4645.930141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4648.031924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4648.042151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4650.115926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4650.126149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4652.227915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4652.238130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4654.339922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4654.350136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4656.451919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4656.462145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4658.563946] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4658.574164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4660.675918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4660.686135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4662.787916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4662.798139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4664.899918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4664.910146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4667.011919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4667.022141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4669.123914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4669.134132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4671.235915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4671.246138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4673.347921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4673.358145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4675.459914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4675.470137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4677.571916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4677.582136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4679.683921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4679.694148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4681.795925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4681.806152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4683.907917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4683.918137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4686.019921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4686.030135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4688.131915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4688.142139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4690.243929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4690.254155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4692.355914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4692.366128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4694.467923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4694.478143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4696.579918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4696.590142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4698.691915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4698.702144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4700.803916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4700.814133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4702.915917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4702.926142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4705.027921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4705.038147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4707.139916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4707.150133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4709.251927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4709.262145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4711.363914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4711.374137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4713.475923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4713.486149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4715.587916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4715.598132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4717.699921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4717.710143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4719.811921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4719.822144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4721.923922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4721.934151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4724.035916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4724.046131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4726.147932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4726.158151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4728.259912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4728.270139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4730.371924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4730.382153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4732.483917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4732.494136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4734.595921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4734.606142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4736.707921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4736.718151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4738.819917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4738.830145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4740.931919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4740.942159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4743.015918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4743.026135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4745.127918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4745.138139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4747.239924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4747.250150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4749.351917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4749.362134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4751.463922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4751.474141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4753.575926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4753.586141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4755.687918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4755.698143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4757.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4757.810136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4759.911917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4759.922140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4762.023919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4762.034140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4764.135913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4764.146128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4766.247915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4766.258133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4768.359918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4768.370135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4770.471922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4770.482145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4772.583915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4772.594145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4774.695919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4774.706135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4776.807918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4776.818144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4778.919925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4778.930150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4781.031917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4781.042134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4783.143922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4783.154139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4785.255916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4785.266141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4787.367912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4787.378133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4789.452079] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4789.462400] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4791.571916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4791.582136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4793.683915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4793.694145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4795.799916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4795.810134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4797.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4797.922137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4800.028139] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4800.038360] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4802.139920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4802.150141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4804.251916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4804.262142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4806.363910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4806.374127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4808.475916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4808.486131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4810.571926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4810.582149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4812.683925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4812.694146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4814.795915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4814.806133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4816.903929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4816.914153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4819.015916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4819.026131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4821.127918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4821.138140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4823.239921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4823.250147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4825.351914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4825.362130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4827.463917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4827.474136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4829.575917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4829.586141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4831.687907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4831.698137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4833.799918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4833.810136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4835.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4835.922136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4838.023920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4838.034144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4840.135917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4840.146152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4842.247917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4842.258137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4844.359917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4844.370140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4846.471918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4846.482141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4848.583928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4848.594156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4850.695920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4850.706139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4852.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4852.818141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4854.919920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4854.930146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4857.031914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4857.042132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4859.143917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4859.154133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4861.227917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4861.238137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4863.335913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4863.346131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4865.447922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4865.458142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4867.559921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4867.570148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4869.671911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4869.682128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4871.783918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4871.794134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4873.895916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4873.906135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4876.007920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4876.018146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4878.119914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4878.130130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4880.231917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4880.242132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4882.343917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4882.354138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4884.451921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4884.462138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4886.563917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4886.574139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4888.675924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4888.686154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4890.787915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4890.798134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4892.899921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4892.910142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4895.011917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4895.022143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4897.123912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4897.134140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4899.235918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4899.246133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4901.347924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4901.358142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4903.459921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4903.470141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4905.571912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4905.582131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4907.683915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4907.694136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4909.795918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4909.806141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4911.907921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4911.918151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4914.019913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4914.030130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4916.131919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4916.142139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4918.243920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4918.254143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4920.355926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4920.366150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4922.467917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4922.478134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4924.579922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4924.590143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4926.691915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4926.702139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4928.803927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4928.814151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4930.915915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4930.926137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4933.027914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4933.038142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4935.139918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4935.150146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4937.251923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4937.262152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4939.363916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4939.374137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4941.475915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4941.486138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4943.587921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4943.598148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4945.699914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4945.710133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4947.811916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4947.822134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4949.923915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4949.934137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4952.035910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4952.046135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4954.147914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4954.158129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4956.259921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4956.270137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4958.371917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4958.382141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4960.483927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4960.494154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4962.595916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4962.606134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4964.707914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4964.718135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4966.819922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4966.830145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4968.931929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4968.942153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4971.043917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4971.054131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4973.155915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4973.166140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4975.267920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4975.278147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4977.379914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4977.390129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4979.491916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4979.502138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4981.603918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4981.614143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4983.716094] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4983.726438] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4985.823919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4985.834139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4987.935926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4987.946152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4990.051921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4990.062148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4992.147917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4992.158140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4994.260203] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4994.270759] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4996.379918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4996.390142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 4998.491921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 4998.502143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5000.603916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5000.614147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5002.715917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5002.726136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5004.831932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5004.842171] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5006.943917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5006.954135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5009.055916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5009.066142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5011.167923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5011.178149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5013.279916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5013.290132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5015.391921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5015.402137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5017.503918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5017.514139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5019.615913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5019.626142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5021.727917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5021.738136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5023.839920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5023.850144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5025.951917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5025.962142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5028.063912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5028.074132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5030.175919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5030.186139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5032.287916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5032.298134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5034.399919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5034.410142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5036.511915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5036.522143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5038.623915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5038.634133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5040.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5040.746139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5042.847921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5042.858144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5044.959913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5044.970131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5047.043917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5047.054135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5049.155919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5049.166137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5051.267916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5051.278140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5053.379911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5053.390126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5055.491918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5055.502136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5057.603914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5057.614135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5059.715919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5059.726142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5061.827918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5061.838146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5063.939914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5063.950137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5066.051916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5066.062143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5068.143917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5068.154140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5070.255921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5070.266146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5072.367916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5072.378143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5074.479916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5074.490133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5076.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5076.602138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5078.703923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5078.714148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5080.815915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5080.826132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5082.927919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5082.938135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5085.039915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5085.050144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5087.151911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5087.162136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5089.263918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5089.274133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5091.375921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5091.386140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5093.487919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5093.498142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5095.599916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5095.610132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5097.711916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5097.722137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5099.823916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5099.834137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5101.927923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5101.938147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5104.039915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5104.050134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5106.151919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5106.162136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5108.263918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5108.274144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5110.375926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5110.386150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5112.487920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5112.498135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5114.599919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5114.610142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5116.711918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5116.722143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5118.823929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5118.834153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5120.935918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5120.946137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5123.047914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5123.058132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5125.159919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5125.170144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5127.271916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5127.282142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5129.383916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5129.394134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5131.495916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5131.506140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5133.607921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5133.618147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5135.719915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5135.730133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5137.831919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5137.842134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5139.943920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5139.954142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5142.055915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5142.066144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5144.167918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5144.178136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5146.279920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5146.290140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5148.391920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5148.402142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5150.503928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5150.514152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5152.615916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5152.626134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5154.727914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5154.738133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5156.839909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5156.850141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5158.951924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5158.962149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5161.063919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5161.074142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5163.175916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5163.186137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5165.287921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5165.298145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5167.399916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5167.410142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5169.511918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5169.522133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5171.623920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5171.634144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5173.735914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5173.746143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5175.847915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5175.858133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5177.960112] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5177.970483] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5180.067918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5180.078132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5182.179914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5182.190141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5184.295914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5184.306128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5186.407915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5186.418142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5188.520028] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5188.530282] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5190.631912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5190.642129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5192.743917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5192.754134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5194.859929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5194.870157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5196.971915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5196.982132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5199.083930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5199.094151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5201.195918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5201.206146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5203.303919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5203.314142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5205.415911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5205.426136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5207.527918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5207.538134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5209.639921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5209.650138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5211.751915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5211.762141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5213.863909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5213.874135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5215.975921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5215.986156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5218.087919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5218.098140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5220.199914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5220.210140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5222.311912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5222.322127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5224.423915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5224.434130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5226.535916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5226.546137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5228.647920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5228.658143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5230.759914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5230.770144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5232.871918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5232.882137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5234.983919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5234.994141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5237.095922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5237.106146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5239.207914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5239.218134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5241.319917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5241.330137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5243.431915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5243.442139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5245.543925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5245.554151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5247.655914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5247.666133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5249.767913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5249.778141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5251.879917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5251.890143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5253.991910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5254.002128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5256.103915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5256.114130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5258.191918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5258.202142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5260.295915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5260.306131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5262.407917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5262.418135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5264.519919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5264.530141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5266.631925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5266.642149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5268.743917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5268.754136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5270.855922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5270.866139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5272.951927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5272.962150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5275.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5275.074134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5277.175919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5277.186148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5279.287922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5279.298145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5281.399909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5281.410124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5283.511916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5283.522133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5285.623922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5285.634140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5287.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5287.746147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5289.847914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5289.858132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5291.959919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5291.970137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5294.071916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5294.082141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5296.183920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5296.194143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5298.295916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5298.306132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5300.407916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5300.418133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5302.519918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5302.530140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5304.631923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5304.642147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5306.743915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5306.754132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5308.855920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5308.866138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5310.967916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5310.978153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5313.079910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5313.090134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5315.191917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5315.202136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5317.303922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5317.314137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5319.415919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5319.426140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5321.527912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5321.538128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5323.623920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5323.634134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5325.735920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5325.746141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5327.847926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5327.858147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5329.959919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5329.970134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5332.071922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5332.082140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5334.183923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5334.194146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5336.295928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5336.306154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5338.407916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5338.418132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5340.519916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5340.530178] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5342.631919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5342.642144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5344.743915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5344.754130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5346.855915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5346.866133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5348.967918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5348.978141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5351.079923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5351.090142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5353.191916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5353.202134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5355.303919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5355.314135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5357.415920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5357.426140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5359.527915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5359.538151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5361.639917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5361.650136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5363.751922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5363.762140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5365.863917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5365.874144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5367.975916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5367.986142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5370.087918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5370.098134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5372.200061] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5372.210487] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5374.311920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5374.322144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5376.423914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5376.434134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5378.539918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5378.550136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5380.651912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5380.662130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5382.768065] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5382.778432] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5384.879918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5384.890147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5386.991914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5387.002134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5389.103918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5389.114142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5391.215919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5391.226145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5393.331930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5393.342154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5395.443921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5395.454159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5397.555915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5397.566132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5399.675916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5399.686131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5401.787916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5401.798134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5403.899920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5403.910138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5406.011931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5406.022177] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5408.103913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5408.114133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5410.215915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5410.226140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5412.327919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5412.338142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5414.439922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5414.450145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5416.551914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5416.562135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5418.663920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5418.674137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5420.775919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5420.786143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5422.887923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5422.898151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5424.999916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5425.010145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5427.111922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5427.122138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5429.223920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5429.234143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5431.311920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5431.322135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5433.423923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5433.434142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5435.535917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5435.546139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5437.647916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5437.658140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5439.759918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5439.770135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5441.871917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5441.882141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5443.983920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5443.994148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5446.095916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5446.106143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5448.179915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5448.190132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5450.291918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5450.302136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5452.411926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5452.422143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5454.523921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5454.534147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5456.635915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5456.646134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5458.747918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5458.758136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5460.839916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5460.850131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5462.951919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5462.962134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5465.063922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5465.074139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5467.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5467.186132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5469.287919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5469.298135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5471.399922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5471.410142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5473.511911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5473.522125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5475.623916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5475.634136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5477.735925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5477.746142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5479.847912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5479.858132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5481.959917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5481.970144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5484.071918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5484.082135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5486.183916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5486.194133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5488.295918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5488.306134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5490.407915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5490.418138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5492.519915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5492.530144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5494.631920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5494.642148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5496.743922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5496.754154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5498.855916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5498.866132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5500.967919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5500.978134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5503.079922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5503.090143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5505.191926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5505.202145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5507.303916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5507.314134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5509.415920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5509.426137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5511.527917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5511.538140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5513.639914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5513.650144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5515.751916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5515.762132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5517.863915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5517.874140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5519.975918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5519.986143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5522.087913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5522.098130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5524.199914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5524.210138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5526.311917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5526.322137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5528.423921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5528.434146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5530.535916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5530.546144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5532.647916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5532.658136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5534.759921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5534.770140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5536.871927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5536.882154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5538.983915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5538.994133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5541.095921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5541.106136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5543.207918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5543.218141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5545.319924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5545.330150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5547.431916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5547.442130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5549.543923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5549.554142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5551.655918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5551.666143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5553.767915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5553.778130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5555.879914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5555.890132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5557.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5558.002138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5560.103921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5560.114148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5562.215916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5562.226133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5564.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5564.338135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5566.439918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5566.450151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5568.551925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5568.562148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5570.663917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5570.674146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5572.779923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5572.790148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5574.891913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5574.902130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5577.004128] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5577.014521] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5579.119914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5579.130130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5581.231919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5581.242137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5583.347916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5583.358152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5585.467915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5585.478132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5587.583932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5587.594159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5589.695915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5589.706133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5591.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5591.818139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5593.919921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5593.930147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5596.031915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5596.042131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5598.143919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5598.154141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5600.255917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5600.266140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5602.367925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5602.378149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5604.479920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5604.490136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5606.591922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5606.602137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5608.703919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5608.714146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5610.815916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5610.826143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5612.927920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5612.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5615.039925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5615.050144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5617.151918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5617.162144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5619.263916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5619.274138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5621.375919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5621.386137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5623.487914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5623.498136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5625.599915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5625.610148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5627.711915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5627.722131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5629.823917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5629.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5631.935917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5631.946139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5634.019918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5634.030145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5636.131926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5636.142149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5638.243918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5638.254134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5640.355922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5640.366140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5642.467926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5642.478153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5644.579914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5644.590127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5646.691915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5646.702132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5648.803915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5648.814138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5650.915922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5650.926149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5653.027915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5653.038142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5655.139915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5655.150138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5657.251918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5657.262141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5659.363923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5659.374147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5661.451918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5661.462139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5663.563917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5663.574138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5665.675924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5665.686151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5667.787917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5667.798140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5669.895916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5669.906141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5672.007922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5672.018166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5674.119923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5674.130146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5676.231916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5676.242146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5678.343927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5678.354149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5680.455921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5680.466140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5682.567916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5682.578138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5684.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5684.690150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5686.791917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5686.802132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5688.903917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5688.914135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5691.015920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5691.026173] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5693.099920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5693.110145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5695.211914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5695.222141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5697.323916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5697.334134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5699.431915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5699.442140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5701.543920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5701.554138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5703.655916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5703.666140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5705.767920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5705.778145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5707.879917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5707.890141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5709.991924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5710.002165] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5712.103915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5712.114141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5714.215911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5714.226145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5716.327919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5716.338139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5718.439920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5718.450138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5720.551917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5720.562138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5722.663909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5722.674125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5724.775916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5724.786134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5726.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5726.898140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5728.999926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5729.010166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5731.111911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5731.122140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5733.223919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5733.234134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5735.335916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5735.346134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5737.447925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5737.458151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5739.559916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5739.570137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5741.671915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5741.682135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5743.783916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5743.794142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5745.895922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5745.906146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5748.007921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5748.018167] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5750.119919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5750.130138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5752.231919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5752.242147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5754.343924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5754.354153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5756.455919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5756.466137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5758.567921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5758.578140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5760.679932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5760.690162] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5762.791910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5762.802143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5764.903918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5764.914134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5767.015915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5767.026135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5769.127914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5769.138145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5771.241472] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5771.251844] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5773.355918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5773.366136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5775.467930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5775.478150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5777.583918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5777.594143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5779.695915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5779.706129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5781.792016] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5781.802329] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5783.903906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5783.914114] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5786.015912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5786.026151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5788.127907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5788.138125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5790.215920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5790.226144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5792.319937] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5792.330164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5794.431919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5794.442138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5796.543919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5796.554140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5798.655925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5798.666154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5800.767917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5800.778132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5802.879923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5802.890141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5804.991923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5805.002191] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5807.103918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5807.114150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5809.215918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5809.226136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5811.327914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5811.338137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5813.439921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5813.450145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5815.551930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5815.562161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5817.663917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5817.674135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5819.775917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5819.786139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5821.887920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5821.898145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5823.999917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5824.010137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5826.111918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5826.122138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5828.223918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5828.234145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5830.335914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5830.346148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5832.447917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5832.458133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5834.559921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5834.570143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5836.671918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5836.682142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5838.783915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5838.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5840.895917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5840.906134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5843.007917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5843.018140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5845.119922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5845.130144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5847.231913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5847.242130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5849.343914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5849.354131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5851.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5851.466139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5853.567920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5853.578148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5855.679915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5855.690147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5857.791916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5857.802135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5859.903918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5859.914138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5862.015924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5862.026146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5864.127913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5864.138136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5866.239923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5866.250142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5868.351915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5868.362145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5870.463916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5870.474152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5872.575920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5872.586151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5874.687917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5874.698140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5876.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5876.810137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5878.911911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5878.922128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5881.023918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5881.034135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5883.107916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5883.118135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5885.219916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5885.230138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5887.331923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5887.342149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5889.443915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5889.454132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5891.555917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5891.566138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5893.667920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5893.678140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5895.779921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5895.790149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5897.891919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5897.902138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5900.003919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5900.014140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5902.115921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5902.126142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5904.227912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5904.238141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5906.339916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5906.350133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5908.451924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5908.462144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5910.563918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5910.574142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5912.675913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5912.686129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5914.787915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5914.798132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5916.899917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5916.910142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5919.011922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5919.022196] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5921.095923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5921.106149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5923.207917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5923.218132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5925.319922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5925.330147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5927.431921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5927.442142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5929.543914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5929.554143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5931.655916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5931.666132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5933.767923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5933.778140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5935.879917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5935.890140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5937.991931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5938.002175] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5940.103915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5940.114130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5942.215916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5942.226143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5944.327921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5944.338145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5946.439916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5946.450136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5948.551921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5948.562142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5950.663916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5950.674140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5952.775923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5952.786142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5954.887916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5954.898132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5956.999923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5957.010155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5959.111917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5959.122139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5961.223925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5961.234145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5963.335919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5963.346137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5965.448055] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5965.458455] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5967.563911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5967.574131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5969.675914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5969.686132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5971.795919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5971.806157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5973.907915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5973.918143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5976.028089] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5976.038834] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5978.139916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5978.150131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5980.251917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5980.262143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5982.363908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5982.374127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5984.475916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5984.486147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5986.587927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5986.598183] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5988.699915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5988.710141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5990.811910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5990.822137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5992.923917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5992.934137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5995.035924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5995.046166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5997.147919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5997.158145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 5999.259911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 5999.270128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6001.371921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6001.382141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6003.483916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6003.494139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6005.595943] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6005.606164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6007.707916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6007.718134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6009.819919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6009.830138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6011.931918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6011.942139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6014.043914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6014.054148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6016.155914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6016.166132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6018.267920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6018.278137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6020.379915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6020.390140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6022.491952] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6022.502183] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6024.603915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6024.614131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6026.715922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6026.726144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6028.827916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6028.838138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6030.939913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6030.950128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6033.051916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6033.062135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6035.163915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6035.174143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6037.275920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6037.286145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6039.387939] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6039.398161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6041.499916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6041.510134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6043.611916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6043.622137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6045.723923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6045.734147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6047.835916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6047.846133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6049.947920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6049.958138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6052.059916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6052.070144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6054.171914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6054.182142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6056.283937] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6056.294161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6058.395929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6058.406146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6060.507924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6060.518146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6062.599922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6062.610147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6064.711915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6064.722143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6066.823917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6066.834133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6068.935916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6068.946142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6071.047917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6071.058144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6073.159919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6073.170149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6075.271915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6075.282132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6077.383916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6077.394137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6079.495920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6079.506138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6081.607916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6081.618143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6083.724075] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6083.734386] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6085.835915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6085.846130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6087.947917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6087.958133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6090.059918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6090.070147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6092.171923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6092.182149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6094.283917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6094.294145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6096.391914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6096.402145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6098.503915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6098.514129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6100.615921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6100.626140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6102.727916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6102.738138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6104.839919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6104.850148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6106.951914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6106.962134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6109.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6109.074137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6111.175923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6111.186148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6113.259923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6113.270149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6115.371916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6115.382132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6117.483921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6117.494139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6119.595921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6119.606144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6121.707909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6121.718126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6123.819916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6123.830136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6125.931915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6125.942137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6128.043915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6128.054135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6130.155911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6130.166128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6132.267915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6132.278130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6134.379915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6134.390138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6136.491918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6136.502147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6138.603913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6138.614129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6140.715914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6140.726131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6142.823916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6142.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6144.935917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6144.946136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6147.047927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6147.058149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6149.159925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6149.170150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6151.271916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6151.282136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6153.383920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6153.394136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6155.495916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6155.506140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6157.607927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6157.618146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6159.704062] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6159.714563] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6161.827918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6161.838141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6163.939914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6163.950132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6166.055932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6166.066158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6168.167914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6168.178134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6170.287936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6170.298166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6172.399918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6172.410142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6174.511916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6174.522146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6176.623913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6176.634135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6178.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6178.746140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6180.847941] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6180.858162] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6182.959915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6182.970131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6185.071916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6185.082132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6187.183919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6187.194139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6189.295909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6189.306123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6191.407917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6191.418148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6193.511923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6193.522140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6195.623918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6195.634142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6197.735917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6197.746141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6199.847913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6199.858131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6201.959915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6201.970138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6204.071922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6204.082142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6206.183915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6206.194131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6208.295918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6208.306134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6210.407917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6210.418138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6212.519924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6212.530150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6214.631914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6214.642132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6216.743919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6216.754139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6218.855922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6218.866142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6220.967917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6220.978145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6223.079918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6223.090136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6225.191921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6225.202138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6227.303917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6227.314140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6229.415912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6229.426140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6231.527918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6231.538139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6233.639916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6233.650134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6235.751926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6235.762155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6237.863914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6237.874139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6239.975914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6239.986137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6242.087916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6242.098148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6244.199923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6244.210151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6246.311919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6246.322133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6248.423919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6248.434136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6250.535917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6250.546139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6252.647914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6252.658153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6254.759918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6254.770137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6256.871920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6256.882142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6258.983916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6258.994145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6261.095911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6261.106127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6263.207917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6263.218133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6265.319915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6265.330135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6267.431919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6267.442145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6269.543921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6269.554150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6271.655914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6271.666138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6273.767918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6273.778142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6275.879921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6275.890147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6277.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6278.002131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6280.103918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6280.114135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6282.215917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6282.226139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6284.327914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6284.338139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6286.439916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6286.450136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6288.551921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6288.562136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6290.663919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6290.674142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6292.775918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6292.786146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6294.887916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6294.898135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6296.999915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6297.010140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6299.111918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6299.122138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6301.223931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6301.234155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6303.335922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6303.346139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6305.447916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6305.458135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6307.559921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6307.570144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6309.671916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6309.682134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6311.783917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6311.794136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6313.895916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6313.906138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6316.007911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6316.018139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6318.119917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6318.130134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6320.231921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6320.242138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6322.343917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6322.354145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6324.455927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6324.466156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6326.567917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6326.578135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6328.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6328.690140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6330.791917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6330.802144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6332.903920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6332.914149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6335.015922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6335.026138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6337.127924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6337.138142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6339.239913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6339.250146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6341.351916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6341.362141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6343.469940] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6343.481048] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6345.575915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6345.586136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6347.687909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6347.698126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6349.803918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6349.814140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6351.915909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6351.926126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6354.032121] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6354.042384] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6356.143922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6356.154144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6358.255914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6358.266145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6360.375917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6360.386133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6362.487917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6362.498137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6364.607921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6364.618148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6366.719920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6366.730152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6368.831915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6368.842132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6370.943918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6370.954137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6373.055921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6373.066145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6375.167915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6375.178143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6377.279916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6377.290135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6379.391919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6379.402142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6381.503918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6381.514153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6383.615916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6383.626132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6385.727920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6385.738137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6387.839918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6387.850139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6389.951910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6389.962138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6392.063915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6392.074136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6394.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6394.186139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6396.287912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6396.298143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6398.399920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6398.410149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6400.511918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6400.522137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6402.623916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6402.634139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6404.735920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6404.746139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6406.847930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6406.858157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6408.959916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6408.970131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6411.071918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6411.082146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6413.183922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6413.194147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6415.295915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6415.306133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6417.407919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6417.418136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6419.519917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6419.530141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6421.631925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6421.642150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6423.743917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6423.754135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6425.855921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6425.866137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6427.967935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6427.978179] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6430.079919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6430.090150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6432.191917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6432.202150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6434.303915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6434.314133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6436.415918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6436.426145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6438.527914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6438.538144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6440.639915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6440.650133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6442.751918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6442.762142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6444.863923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6444.874147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6446.975915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6446.986137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6449.087918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6449.098140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6451.199920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6451.210142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6453.311912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6453.322128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6455.423919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6455.434133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6457.535922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6457.546140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6459.647911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6459.658135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6461.759912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6461.770142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6463.871941] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6463.882166] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6465.983924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6465.994164] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6468.095917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6468.106142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6470.207931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6470.218156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6472.319919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6472.330146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6474.431919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6474.442144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6476.543921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6476.554145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6478.655915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6478.666145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6480.767917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6480.778138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6482.879919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6482.890155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6484.991925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6485.002150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6487.103914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6487.114136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6489.215921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6489.226142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6491.327914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6491.338139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6493.439926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6493.450149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6495.551917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6495.562135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6497.663915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6497.674138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6499.775919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6499.786144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6501.887915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6501.898131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6503.999922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6504.010185] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6506.111926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6506.122144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6508.223920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6508.234146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6510.335914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6510.346145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6512.447918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6512.458135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6514.559915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6514.570137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6516.671922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6516.682148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6518.787918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6518.798142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6520.899923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6520.910148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6523.011934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6523.022191] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6525.123919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6525.134139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6527.240095] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6527.250642] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6529.355921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6529.366149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6531.467916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6531.478131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6533.583921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6533.594146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6535.695914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6535.706130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6537.811942] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6537.822186] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6539.923914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6539.934129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6542.035916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6542.046133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6544.147916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6544.158142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6546.259921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6546.270160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6548.371918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6548.382135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6550.483921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6550.494136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6552.583917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6552.594131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6554.695914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6554.706135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6556.807923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6556.818146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6558.895917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6558.906135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6561.007919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6561.018147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6563.119924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6563.130150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6565.231916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6565.242131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6567.343920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6567.354137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6569.455922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6569.466148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6571.567915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6571.578142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6573.679916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6573.690134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6575.791921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6575.802139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6577.903916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6577.914137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6580.015914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6580.026140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6582.119919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6582.130136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6584.231920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6584.242138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6586.343924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6586.354150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6588.455915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6588.466132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6590.567921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6590.578139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6592.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6592.690145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6594.791926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6594.802152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6596.903920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6596.914137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6599.015923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6599.026140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6601.127917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6601.138142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6603.239918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6603.250141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6605.351919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6605.362135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6607.463918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6607.474142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6609.575918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6609.586134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6611.687915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6611.698135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6613.799916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6613.810134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6615.911918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6615.922138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6618.023909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6618.034132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6620.135915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6620.146131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6622.247920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6622.258140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6624.359907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6624.370134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6626.471917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6626.482140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6628.583918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6628.594136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6630.695923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6630.706142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6632.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6632.818141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6634.919911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6634.930127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6637.031918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6637.042135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6639.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6639.154145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6641.255920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6641.266146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6643.367914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6643.378130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6645.479917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6645.490139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6647.591920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6647.602147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6649.703922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6649.714148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6651.815913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6651.826135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6653.927920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6653.938142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6656.039923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6656.050145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6658.151925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6658.162151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6660.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6660.274136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6662.375922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6662.386139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6664.487916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6664.498140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6666.599910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6666.610131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6668.711916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6668.722133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6670.823917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6670.834141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6672.935918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6672.946144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6675.047919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6675.058144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6677.159915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6677.170132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6679.271916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6679.282141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6681.383921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6681.394146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6683.495915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6683.506132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6685.607919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6685.618134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6687.719917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6687.730139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6689.831926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6689.842152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6691.943916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6691.954138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6694.055923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6694.066139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6696.167923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6696.178149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6698.279915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6698.290142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6700.391916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6700.402131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6702.503915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6702.514137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6704.615922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6704.626148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6706.727930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6706.738156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6708.839914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6708.850133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6710.952070] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6710.963497] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6713.083914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6713.094129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6715.167917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6715.178133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6717.283924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6717.294149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6719.395916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6719.406134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6721.500134] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6721.510490] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6723.619923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6723.630149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6725.731927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6725.742154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6727.851915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6727.862132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6729.963919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6729.974137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6732.075936] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6732.086193] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6734.183916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6734.194137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6736.295917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6736.306141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6738.407913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6738.418130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6740.519917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6740.530132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6742.603918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6742.614134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6744.715920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6744.726142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6746.827922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6746.838147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6748.939915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6748.950133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6751.051920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6751.062141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6753.163919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6753.174146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6755.275925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6755.286148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6757.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6757.394140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6759.495913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6759.506129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6761.607923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6761.618149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6763.719916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6763.730136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6765.831920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6765.842147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6767.943915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6767.954143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6770.055916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6770.066132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6772.167919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6772.178141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6774.279923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6774.290150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6776.391916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6776.402134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6778.503918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6778.514135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6780.615921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6780.626140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6782.727924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6782.738149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6784.839917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6784.850134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6786.951921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6786.962139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6789.063915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6789.074141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6791.175928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6791.186150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6793.287915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6793.298131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6795.399916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6795.410137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6797.511920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6797.522143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6799.623914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6799.634130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6801.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6801.746132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6803.847917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6803.858138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6805.951926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6805.962153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6808.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6808.074134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6810.175922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6810.186137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6812.287914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6812.298139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6814.399929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6814.410153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6816.511919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6816.522138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6818.623912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6818.634133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6820.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6820.746142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6822.847916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6822.858130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6824.959916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6824.970134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6827.071918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6827.082138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6829.183923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6829.194145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6831.295916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6831.306145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6833.407920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6833.418133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6835.519920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6835.530143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6837.631915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6837.642145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6839.743915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6839.754129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6841.855920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6841.866139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6843.967916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6843.978142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6846.079927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6846.090151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6848.191913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6848.202128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6850.303916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6850.314142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6852.415918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6852.426136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6854.527916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6854.538137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6856.639915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6856.650133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6858.751916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6858.762139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6860.863921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6860.874145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6862.975913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6862.986130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6865.087917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6865.098135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6867.199913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6867.210140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6869.311929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6869.322153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6871.423917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6871.434135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6873.535920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6873.546139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6875.647920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6875.658141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6877.759919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6877.770147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6879.871917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6879.882134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6881.983923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6881.994181] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6884.095926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6884.106154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6886.179920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6886.190148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6888.291915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6888.302133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6890.403918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6890.414137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6892.515919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6892.526140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6894.627922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6894.638147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6896.739915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6896.750131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6898.851918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6898.862138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6900.951918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6900.962136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6903.063916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6903.074140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6905.175918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6905.186147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6907.291913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6907.302135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6909.403921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6909.414145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6911.515914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6911.526134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6913.627916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6913.638133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6915.741833] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6915.752858] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6917.859920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6917.870143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6919.971914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6919.982145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6922.083915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6922.094131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6924.195917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6924.206138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6926.311930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6926.322154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6928.423916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6928.434136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6930.535923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6930.546149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6932.647915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6932.658134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6934.759918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6934.770137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6936.871920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6936.882145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6938.983921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6938.994147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6941.095917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6941.106134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6943.207920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6943.218141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6945.319922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6945.330145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6947.431915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6947.442143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6949.543918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6949.554137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6951.655915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6951.666138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6953.767918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6953.778136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6955.879930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6955.890155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6957.991916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6958.002134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6960.103914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6960.114136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6962.215922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6962.226147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6964.327914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6964.338133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6966.439918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6966.450138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6968.551919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6968.562145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6970.663908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6970.674125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6972.775918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6972.786136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6974.887918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6974.898142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6976.999923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6977.010158] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6979.111916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6979.122142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6981.223916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6981.234134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6983.335914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6983.346135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6985.447910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6985.458137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6987.559930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6987.570155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6989.671917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6989.682135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6991.783916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6991.794137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6993.895921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6993.906144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6996.007923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6996.018176] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 6998.119917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 6998.130133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7000.203921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7000.214139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7002.315915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7002.326137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7004.427926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7004.438156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7006.539918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7006.550138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7008.651920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7008.662140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7010.763922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7010.774148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7012.875913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7012.886140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7014.987919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7014.998157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7017.099915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7017.110139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7019.211919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7019.222147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7021.323917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7021.334144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7023.435916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7023.446131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7025.547917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7025.558145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7027.659919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7027.670148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7029.767915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7029.778139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7031.879914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7031.890142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7033.991931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7034.002182] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7036.103921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7036.114141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7038.215909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7038.226137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7040.327918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7040.338147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7042.439917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7042.450134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7044.551925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7044.562143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7046.663919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7046.674144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7048.775913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7048.786128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7050.887915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7050.898131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7052.999928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7053.010173] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7055.111921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7055.122148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7057.223915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7057.234130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7059.335918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7059.346135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7061.447918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7061.458143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7063.559913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7063.570141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7065.671915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7065.682131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7067.783920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7067.794139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7069.895922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7069.906146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7072.007926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7072.018154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7074.119919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7074.130136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7076.231915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7076.242140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7078.343911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7078.354138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7080.455916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7080.466143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7082.567914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7082.578135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7084.679918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7084.690140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7086.791921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7086.802146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7088.903917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7088.914144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7091.015920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7091.026179] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7093.127916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7093.138138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7095.239923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7095.250145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7097.351918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7097.362135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7099.452082] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7099.463505] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7101.575920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7101.586146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7103.687914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7103.698133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7105.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7105.818132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7107.919920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7107.930135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7110.036036] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7110.046327] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7112.155914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7112.166133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7114.267919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7114.278142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7116.379921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7116.390147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7118.491914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7118.502131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7120.595925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7120.606141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7122.707921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7122.718144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7124.819916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7124.830142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7126.931918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7126.942137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7129.051921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7129.062141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7131.163925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7131.174148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7133.275928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7133.286156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7135.387917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7135.398134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7137.499914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7137.510141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7139.611917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7139.622140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7141.723938] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7141.734161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7143.835916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7143.846130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7145.947916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7145.958141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7148.039915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7148.050139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7150.151910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7150.162139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7152.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7152.274138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7154.375916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7154.386138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7156.487919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7156.498140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7158.599922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7158.610147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7160.711915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7160.722131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7162.823919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7162.834139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7164.935922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7164.946145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7167.047913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7167.058138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7169.159919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7169.170141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7171.271921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7171.282138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7173.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7173.394143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7175.495928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7175.506150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7177.607917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7177.618134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7179.719916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7179.730142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7181.831919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7181.842141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7183.943933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7183.954156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7186.055918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7186.066132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7188.167917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7188.178141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7190.279922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7190.290141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7192.391914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7192.402134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7194.471921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7194.482145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7196.583928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7196.594156] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7198.695922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7198.706139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7200.807924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7200.818140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7202.919919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7202.930143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7205.031915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7205.042140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7207.143915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7207.154132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7209.255917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7209.266143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7211.367922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7211.378143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    hwclock: ioctl(RTC_RD_NAME) to /dev/rtc0 to read the time failed: Invalid argument
    [ 7213.479917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7213.490133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7215.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7215.602138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7217.703920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7217.714143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7219.815911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7219.826136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7221.927918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7221.938144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7224.039920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7224.050142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7226.151917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7226.162145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7228.263913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7228.274140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7230.375915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7230.386131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7232.487913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7232.498137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7234.599923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7234.610145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7236.711931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7236.722157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7238.823916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7238.834131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7240.935917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7240.946138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7243.047920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7243.058148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7245.159914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7245.170133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7247.243915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7247.254131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7249.355919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7249.366139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7251.463920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7251.474146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7253.575918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7253.586140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7255.687917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7255.698138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7257.799913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7257.810130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7259.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7259.922136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7262.023916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7262.034138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7264.135921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7264.146142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7266.247915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7266.258135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7268.359919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7268.370131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7270.471915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7270.482136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7272.583923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7272.594150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7274.695915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7274.706143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7276.807920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7276.818135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7278.919914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7278.930133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7281.031927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7281.042154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7283.143918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7283.154136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7285.255923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7285.266138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7287.367916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7287.378142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7289.479928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7289.490154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7291.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7291.602133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7293.704068] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7293.714440] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7295.819921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7295.830136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7297.931915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7297.942134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7300.035923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7300.046146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7302.147915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7302.158132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7304.260066] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7304.270628] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7306.371922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7306.382151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7308.483925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7308.494148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7310.595914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7310.606131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7312.707920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7312.718140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7314.819946] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7314.830184] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7316.931913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7316.942129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7319.043917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7319.054132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7321.155918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7321.166146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7323.267927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7323.278153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7325.379931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7325.390161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7327.491916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7327.502138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7329.603915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7329.614142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7331.715922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7331.726144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7333.827914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7333.838133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7335.939920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7335.950137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7338.051918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7338.062146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7340.163924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7340.174150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7342.275916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7342.286131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7344.387920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7344.398143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7346.499919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7346.510141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7348.611912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7348.622139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7350.723916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7350.734136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7352.835917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7352.846141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7354.947918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7354.958143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7357.031908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7357.042134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7359.143914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7359.154136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7361.255913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7361.266136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7363.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7363.378142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7365.479907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7365.490134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7367.591907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7367.602129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7369.703907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7369.714127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7371.815909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7371.826126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7373.927909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7373.938123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7376.039907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7376.050130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7378.151907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7378.162125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7380.263907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7380.274126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7382.375908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7382.386120] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7384.487906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7384.498122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7386.599909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7386.610131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7388.711913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7388.722132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7390.823907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7390.834121] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7392.935906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7392.946125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7395.047908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7395.058125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7397.159907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7397.170117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7399.271906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7399.282122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7401.383907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7401.394127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7403.495910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7403.506129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7405.607918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7405.618126] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7407.719908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7407.730124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7409.831907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7409.842122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7411.943908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7411.954117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7414.055911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7414.066121] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7416.167911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7416.178123] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7418.279907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7418.290122] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7420.391912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7420.402118] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7422.503918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7422.514128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7424.615908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7424.626125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7426.727909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7426.738124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7428.839908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7428.850117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7430.951908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7430.962125] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7433.035916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7433.046135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7435.147921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7435.158137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7437.259906] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7437.270139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7439.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7439.378134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7441.479920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7441.490143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7443.591916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7443.602130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7445.703915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7445.714133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7447.815917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7447.826139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7449.927921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7449.938147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7452.039913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7452.050128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7454.123919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7454.134134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7456.235918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7456.246137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7458.347920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7458.358140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7460.459927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7460.470150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7462.571923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7462.582150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7464.683915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7464.694140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7466.795918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7466.806144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7468.907931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7468.918155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7471.019919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7471.030138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7473.131917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7473.142135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7475.243920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7475.254144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7477.355923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7477.366159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7479.467915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7479.478135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7481.579917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7481.590139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7483.691919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7483.702142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7485.799915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7485.810138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7487.911927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7487.922151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7490.023916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7490.034135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7492.135921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7492.146140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7494.247917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7494.258140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7496.359912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7496.370128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7498.452052] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7498.462368] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7500.571937] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7500.582159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7502.683934] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7502.694157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7504.803919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7504.814141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7506.915924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7506.926146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7509.032093] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7509.042398] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7511.143923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7511.154149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7513.255918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7513.266133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7515.367921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7515.378135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7517.479918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7517.490145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7519.591948] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7519.602187] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7521.703918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7521.714137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7523.815922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7523.826143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7525.927917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7525.938145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7528.039929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7528.050153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7530.151919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7530.162139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7532.263915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7532.274131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7534.375920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7534.386140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7536.487913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7536.498131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7538.599917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7538.610137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7540.711927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7540.722144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7542.823923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7542.834147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7544.935913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7544.946133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7547.047919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7547.058140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7549.159917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7549.170142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7551.271926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7551.282155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7553.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7553.394136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7555.495922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7555.506139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7557.607918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7557.618139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7559.719918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7559.730148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7561.831921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7561.842137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7563.943914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7563.954134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7566.055918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7566.066145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7568.167914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7568.178131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7570.279917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7570.290135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7572.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7572.402141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7574.503921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7574.514146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7576.615916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7576.626133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7578.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7578.738134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7580.839920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7580.850147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7582.951926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7582.962152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7585.063914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7585.074134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7587.175919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7587.186138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7589.287923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7589.298146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7591.399910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7591.410131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7593.511917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7593.522134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7595.623914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7595.634132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7597.735913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7597.746143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7599.847929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7599.858160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7601.959916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7601.970134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7604.047922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7604.058144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7606.159915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7606.170130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7608.243916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7608.254134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7610.355919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7610.366159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7612.467922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7612.478145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7614.579908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7614.590124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7616.691915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7616.702133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7618.811917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7618.822134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7620.923917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7620.934137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7623.035942] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7623.046188] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7625.147918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7625.158134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7627.259926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7627.270142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7629.371918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7629.382142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7631.483945] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7631.494162] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7633.595917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7633.606137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7635.707920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7635.718139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7637.819919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7637.830145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7639.911916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7639.922141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7642.023928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7642.034148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7644.135918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7644.146140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7646.247915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7646.258136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7648.359919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7648.370138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7650.471914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7650.482130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7652.583914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7652.594132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7654.695918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7654.706145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7656.807923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7656.818147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7658.919913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7658.930128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7661.031919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7661.042136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7663.143920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7663.154138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7665.255925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7665.266150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7667.367918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7667.378136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7669.479922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7669.490138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7671.591924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7671.602147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7673.703916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7673.714140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7675.815918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7675.826137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7677.927916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7677.938140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7680.039918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7680.050144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7682.151930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7682.162153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7684.263917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7684.274132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7686.375916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7686.386136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7688.487919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7688.498144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7690.599915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7690.610131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7692.712087] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7692.722459] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7694.819917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7694.830131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7696.931921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7696.942139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7699.047919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7699.058135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7701.159921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7701.170138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7703.272075] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7703.282309] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7705.383926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7705.394151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7707.495917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7707.506131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7709.611920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7709.622151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7711.723918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7711.734133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7713.815924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7713.826140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7715.927921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7715.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7718.023923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7718.034146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7720.135914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7720.146130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7722.247920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7722.258136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7724.359930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7724.370154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7726.471924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7726.482148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7728.583918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7728.594141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7730.695918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7730.706139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7732.807919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7732.818140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7734.919929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7734.930150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7737.031914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7737.042131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7739.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7739.154138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7741.255921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7741.266145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7743.367915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7743.378131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7745.479916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7745.490135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7747.591917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7747.602141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7749.703923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7749.714151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7751.815916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7751.826133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7753.927920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7753.938135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7756.039922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7756.050150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7758.151928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7758.162150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7760.263915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7760.274132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7762.375922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7762.386142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7764.487921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7764.498141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7766.599930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7766.610149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7768.711914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7768.722127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7770.823915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7770.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7772.935920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7772.946135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7775.047914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7775.058132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7777.159916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7777.170131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7779.251913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7779.262132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7781.371925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7781.382140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7783.483915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7783.494143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7785.596199] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7785.606431] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7787.707923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7787.718144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7789.819916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7789.830140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7791.931913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7791.942144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7794.043916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7794.054132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7796.155916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7796.166141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7798.267935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7798.278153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7800.379924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7800.390151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7802.491917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7802.502145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7804.603919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7804.614139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7806.715921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7806.726144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7808.827926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7808.838146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7810.919924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7810.930149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7813.031916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7813.042132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7815.143921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7815.154141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7817.255916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7817.266141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7819.367927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7819.378146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7821.479920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7821.490137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7823.591916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7823.602138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7825.703917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7825.714137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7827.815931] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7827.826153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7829.927919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7829.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7832.039960] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7832.050182] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7834.151922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7834.162146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7836.263914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7836.274130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7838.375917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7838.386137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7840.487921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7840.498141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7842.599908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7842.610128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7844.711917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7844.722134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7846.823921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7846.834135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7848.935919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7848.946141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7851.047926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7851.058150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7853.159918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7853.170135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7855.271914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7855.282142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7857.383917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7857.394144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7859.495916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7859.506133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7861.607919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7861.618134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7863.719916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7863.730138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7865.831923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7865.842150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7867.943914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7867.954130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7870.055917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7870.066134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7872.167919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7872.178142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7874.279924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7874.290149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7876.391914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7876.402130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7878.503920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7878.514136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7880.615919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7880.626147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7882.727927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7882.738151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7884.839919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7884.850137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7886.952073] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7886.963505] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7889.083918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7889.094142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7891.195914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7891.206134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7893.315916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7893.326138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7895.427916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7895.438139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7897.547933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7897.558160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7899.655917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7899.666142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7901.767919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7901.778147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7903.879916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7903.890131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7905.991917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7906.002140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7908.103940] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7908.114155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7910.215915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7910.226130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7912.327917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7912.338132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7914.439927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7914.450144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7916.551922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7916.562142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7918.663917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7918.674135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7920.775921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7920.786141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7922.887919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7922.898140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7924.999924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7925.010189] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7927.111915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7927.122134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7929.223922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7929.234141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7931.335916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7931.346138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7933.447916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7933.458143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7935.559919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7935.570139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7937.671922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7937.682141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7939.783919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7939.794143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7941.895914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7941.906130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7944.007921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7944.018169] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7946.119916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7946.130140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7948.231923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7948.242146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7950.343917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7950.354137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7952.455919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7952.466137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7954.567919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7954.578146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7956.679913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7956.690136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7958.791916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7958.802134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7960.903922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7960.914141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7963.015923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7963.026187] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7965.127928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7965.138152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7967.239918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7967.250132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7969.351915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7969.362135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7971.451921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7971.462142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7973.563922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7973.574145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7975.675924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7975.686149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7977.787917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7977.798134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7979.899922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7979.910140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7982.011915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7982.022144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7984.123932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7984.134154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7986.235917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7986.246132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7988.347915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7988.358138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7990.459919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7990.470146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7992.571914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7992.582134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7994.683914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7994.694132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7996.775915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7996.786131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 7998.887917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 7998.898137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8000.999924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8001.010150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8003.111914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8003.122134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8005.223916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8005.234132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8007.335919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8007.346136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8009.447922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8009.458147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8011.559916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8011.570133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8013.671919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8013.682138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8015.783918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8015.794138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8017.895927] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8017.906155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8020.007915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8020.018131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8022.119921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8022.130141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8024.231912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8024.242139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8026.343915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8026.354136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8028.455917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8028.466133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8030.567917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8030.578140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8032.679920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8032.690143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8034.791914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8034.802135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8036.903917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8036.914136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8039.015918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8039.026142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8041.127919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8041.138140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8043.239918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8043.250135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8045.351919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8045.362136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8047.463921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8047.474145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8049.575926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8049.586151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8051.687918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8051.698141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8053.799923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8053.810142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8055.911924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8055.922148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8058.023913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8058.034128] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8060.135921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8060.146151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8062.219914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8062.230133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8064.331917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8064.342135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8066.443921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8066.454146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8068.555914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8068.566129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8070.663915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8070.674143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8072.775916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8072.786130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8074.887921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8074.898138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8076.999933] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8077.010177] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8079.111920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8079.122151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8081.204077] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8081.214544] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8083.327916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8083.338140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8085.439921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8085.450148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8087.555917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8087.566141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8089.667922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8089.678147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8091.784204] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8091.794440] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8093.895920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8093.906143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8096.007917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8096.018130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8098.119917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8098.130134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8100.231917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8100.242138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8102.343928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8102.354152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8104.455916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8104.466133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8106.567920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8106.578137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8108.679922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8108.690152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8110.791910] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8110.802127] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8112.903920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8112.914146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8115.015918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8115.026139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8117.127915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8117.138137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8119.239929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8119.250155] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8121.351919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8121.362136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8123.463916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8123.474141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8125.575923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8125.586151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8127.687914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8127.698132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8129.799917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8129.810133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8131.911919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8131.922146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8134.023924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8134.034151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8136.135915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8136.146133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8138.247921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8138.258136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8140.359921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8140.370141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8142.471926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8142.482154] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8144.583914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8144.594130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8146.695922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8146.706142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8148.807916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8148.818139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8150.919916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8150.930142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8153.031916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8153.042133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8155.143916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8155.154134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8157.255920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8157.266143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8159.367932] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8159.378161] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8161.479916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8161.490134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8163.591918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8163.602144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8165.703925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8165.714150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8167.815916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8167.826135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8169.927918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8169.938137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8172.039920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8172.050145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8174.151914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8174.162144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8176.263920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8176.274136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8178.375923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8178.386140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8180.487917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8180.498146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8182.599916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8182.610147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8184.711921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8184.722137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8186.823921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8186.834142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8188.935920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8188.946145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8191.047930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8191.058157] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8193.159921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8193.170138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8195.271918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8195.282142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8197.383922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8197.394146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8199.495913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8199.506130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8201.607919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8201.618135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8203.719914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8203.730136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8205.831922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8205.842149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8207.943919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8207.954137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8210.055921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8210.066141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8212.167915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8212.178140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8214.279912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8214.290141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8216.391918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8216.402134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8218.503914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8218.514137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8220.615909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8220.626135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8222.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8222.738144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8224.839914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8224.850136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8226.951918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8226.962140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8229.063922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8229.074148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8231.175917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8231.186133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8233.287918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8233.298141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8235.399920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8235.410144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8237.511928] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8237.522150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8239.623915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8239.634132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8241.735921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8241.746136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8243.847918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8243.858143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8245.959926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8245.970150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8248.071915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8248.082136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8250.155918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8250.166136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8252.267917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8252.278141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8254.379920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8254.390146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8256.491915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8256.502131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8258.603918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8258.614133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8260.715920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8260.726145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8262.827920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8262.838149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8264.939918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8264.950160] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8267.051920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8267.062134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8269.163919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8269.174146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8271.279914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8271.290135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8273.391920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8273.402148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8275.504078] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8275.514627] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8277.619918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8277.630145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8279.731914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8279.742147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8281.851915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8281.862136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8283.963919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8283.974136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8286.075924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8286.086147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8288.187914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8288.198143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8290.299935] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8290.310159] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8292.411920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8292.422135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8294.523915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8294.534140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8296.607916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8296.618144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8298.719923] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8298.730153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8300.831916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8300.842138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8302.943914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8302.954139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8305.055921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8305.066146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8307.167915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8307.178132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8309.279918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8309.290133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8311.391916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8311.402139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8313.503909] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8313.514133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8315.615915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8315.626134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8317.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8317.738137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8319.839917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8319.850138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8321.951926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8321.962151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8324.063918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8324.074134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8326.175922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8326.186139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8328.287918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8328.298144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8330.399929] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8330.410152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8332.511916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8332.522137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8334.623915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8334.634132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8336.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8336.746142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8338.847930] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8338.858153] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8340.951921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8340.962138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8343.063921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8343.074142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8345.175914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8345.186136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8347.287916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8347.298135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8349.399922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8349.410138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8351.511917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8351.522141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8353.623917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8353.634149] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8355.735915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8355.746132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8357.847916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8357.858140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8359.951925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8359.962151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8362.063914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8362.074135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8364.175919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8364.186138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8366.287918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8366.298145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8368.399925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8368.410152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8370.511920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8370.522137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8372.623922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8372.634139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8374.735918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8374.746140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8376.839916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8376.850136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8378.951916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8378.962137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8381.063919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8381.074145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8383.175922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8383.186151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8385.287914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8385.298133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8387.399919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8387.410141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8389.511918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8389.522139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8391.623926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8391.634151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8393.735919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8393.746136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [ 8395.847921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [ 8395.858138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23586.499917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23586.510139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23588.611912] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23588.622142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23590.723914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23590.734143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [1]   Done(255)               ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d
    [2]   Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d
    [3]   Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d
    [4]   Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d
    [5]-  Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [23592.835916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23592.846138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [23594.947918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23594.958142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [23597.059922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23597.070145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    ps[23599.171914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23599.182130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
     a
      PID TTY      STAT   TIME COMMAND
      514 ttyS2    Ss     0:00 /bin/login -f --
      518 ttyS2    S      0:00 -sh
      565 ttyS2    S      0:54 /bin/sh ./eth_up_down.sh
    31089 ttyS2    S      0:00 sleep 1
    31090 ttyS2    R+     0:00 ps a
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [23601.283920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23601.294135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23603.395921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23603.406148] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23605.507915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23605.518142] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23607.619916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23607.630136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23609.731921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23609.742137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23611.843925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23611.854152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23613.955918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23613.966152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23616.067918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23616.078135] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23618.179914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23618.190138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23620.291921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23620.302143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23622.403914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23622.414129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23624.515922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23624.526136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23626.627914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23626.638143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23628.739918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23628.750145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23630.851916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23630.862133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23632.963918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23632.974137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23635.075920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23635.086139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23637.187924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23637.198152] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23639.299915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23639.310132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23641.411920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23641.422140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23643.523917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23643.534139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23645.635913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23645.646140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23647.747916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23647.758134] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23649.859919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23649.870146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23651.971921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23651.982145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23654.083913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23654.094133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23656.167915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23656.178131] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23658.279917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23658.290132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23660.391917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23660.402141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23662.503913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23662.514147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23664.615916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23664.626133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23666.727918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23666.738136] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23668.839914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23668.850141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23670.951926] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23670.962150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23673.063918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23673.074138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23675.175921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23675.186143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23677.287917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23677.298143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23679.399911] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23679.410137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23681.511915] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23681.522133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23683.623924] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23683.634143] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23685.735920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23685.746144] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23687.847917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23687.858138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23689.959917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23689.970133] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23692.071916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23692.082141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23694.183922] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23694.194150] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23696.295914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23696.306130] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23698.407918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23698.418141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23700.519920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23700.530139] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23702.631925] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23702.642147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23704.743914] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23704.754132] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23706.855920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23706.866140] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23708.967917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23708.978146] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23711.079921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23711.090151] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23713.191944] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23713.202274] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23715.311920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23715.322138] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23717.423920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23717.434147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23719.539920] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23719.550141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23721.663913] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23721.674129] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23723.775974] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23723.786431] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23725.887916] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23725.898141] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23727.999921] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23728.010147] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23730.111917] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23730.122145] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23732.223919] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23732.234137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23734.315918] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23734.326137] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23736.427907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23736.438124] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
    [23738.539908] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    [23738.550117] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode
  • Hi Bin,
    Customer forgot to update the test result:
    Applied upper patches, test with DMA (applied patch to disable Tx DMA), even doesn't toggle Ethernet up/down, serial check also hang with multiple instance test at the same time.
  • Hi Tony,
    Thanks for the update.
    I will see if I can reproduce the problem on EVM and look into it.
  • Hi,Bin
    The first and second patches are already included in kernel 6.6.32, so I only need to apply the third patch for modification. I am currently testing it.
  • Hi, Bin
    After applying the patch, all serialcheck tests have stopped.
  • Hi Fuyi,
    Do you mean the test stopped prematurely because RX data do not patch with the TX data? Please attach the test log.
  • Serialcheck verification failed.
    Needed 4 reads 1 writes loops 114 / 2786918
    Needed 4 reads 1 writes loops 36 / 696729
    Needed 4 reads 1 writes loops 34 / 2786918
    Needed 4 reads 1 writes loops 86 / 2786918
    Needed 4 reads 1 writes loops 59 / 2786918
    Needed 4 reads 1 writes loops 115 / 2786918
    Needed 4 reads 1 writes loops 35 / 2786918
    Needed 4 reads 1 writes loops 87 / 2786918
    Needed 4 reads 1 writes loops 60 / 2786918
    Needed 4 reads 1 writes loops 116 / 2786918
    Needed 4 reads 1 writes loops 36 / 2786918
    Needed 4 reads 1 writes loops 88 / 2786918
    Needed 4 reads 1 writes loops 61 / 2786918
    Needed 4 reads 1 writes loops 117 / 2786918
    Needed 4 reads 1 writes loops 37 / 2786918
    Needed 4 reads 1 writes loops 89 / 2786918
    Needed 4 reads 1 writes loops 62 / 2786918
    Needed 4 reads 1 writes loops 118 / 2786918
    Needed 4 reads 1 writes loops 37 / 696729
    Needed 4 reads 1 writes loops 38 / 2786918
    Needed 4 reads 1 writes loops 90 / 2786918
    Needed 4 reads 1 writes loops 63 / 2786918
    Needed 4 reads 1 writes loops 119 / 2786918
    Needed 4 reads 1 writes loops 39 / 2786918
    Needed 4 reads 1 writes loops 91 / 2786918
    Needed 4 reads 1 writes loops 64 / 2786918
    Needed 4 reads 1 writes loops 120 / 2786918
    Needed 4 reads 1 writes loops 40 / 2786918
    Needed 4 reads 1 writes loops 92 / 2786918
    Needed 4 reads 1 writes loops 65 / 2786918
    Needed 4 reads 1 writes loops 121 / 2786918
    Needed 4 reads 1 writes loops 41 / 2786918
    Needed 4 reads 1 writes loops 93 / 2786918
    Needed 4 reads 1 writes loops 66 / 2786918
    Needed 4 reads 1 writes loops 122 / 2786918
    Needed 4 reads 1 writes loops 38 / 696729
    Needed 4 reads 1 writes loops 42 / 2786918
    Needed 4 reads 1 writes loops 94 / 2786918
    Needed 4 reads 1 writes loops 67 / 2786918
    Needed 4 reads 1 writes loops 123 / 2786918
    Needed 4 reads 1 writes loops 43 / 2786918
    Needed 4 reads 1 writes loops 95 / 2786918
    Needed 4 reads 1 writes loops 68 / 2786918
    Needed 4 reads 1 writes loops 124 / 2786918
    Needed 4 reads 1 writes loops 44 / 2786918
    Needed 4 reads 1 writes loops 96 / 2786918
    Needed 4 reads 1 writes loops 69 / 2786918
    Needed 4 reads 1 writes loops 125 / 2786918
    Needed 4 reads 1 writes loops 45 / 2786918
    Needed 4 reads 1 writes loops 97 / 2786918
    Needed 4 reads 1 writes loops 70 / 2786918
    Needed 4 reads 1 writes loops 126 / 2786918
    Needed 4 reads 1 writes loops 39 / 696729
    Needed 4 reads 1 writes loops 46 / 2786918
    Needed 4 reads 1 writes loops 98 / 2786918
    Needed 4 reads 1 writes loops 71 / 2786918
    Needed 4 reads 1 writes loops 127 / 2786918
    Needed 4 reads 1 writes loops 47 / 2786918
    Needed 4 reads 1 writes loops 99 / 2786918
    Needed 4 reads 1 writes loops 72 / 2786918
    Needed 4 reads 1 writes loops 128 / 2786918
    Needed 4 reads 1 writes loops 48 / 2786918
    Needed 4 reads 1 writes loops 100 / 2786918
    Needed 4 reads 1 writes loops 73 / 2786918
    Needed 4 reads 1 writes loops 129 / 2786918
    Needed 4 reads 1 writes loops 49 / 2786918
    Needed 4 reads 1 writes loops 101 / 2786918
    Needed 4 reads 1 writes loops 74 / 2786918
    Needed 4 reads 1 writes loops 130 / 2786918
    Needed 4 reads 1 writes loops 40 / 696729
    Needed 4 reads 1 writes loops 50 / 2786918
    Needed 4 reads 1 writes loops 102 / 2786918
    Needed 4 reads 1 writes loops 75 / 2786918
    Needed 4 reads 1 writes loops 131 / 2786918
    Needed 4 reads 1 writes loops 51 / 2786918
    Needed 4 reads 1 writes loops 103 / 2786918
    Needed 4 reads 1 writes loops 76 / 2786918
    Needed 4 reads 1 writes loops 132 / 2786918
    Needed 4 reads 1 writes loops 52 / 2786918
    Needed 4 reads 1 writes loops 104 / 2786918
    Needed 4 reads 1 writes loops 77 / 2786918
    Needed 4 reads 1 writes loops 133 / 2786918
    Needed 4 reads 1 writes loops 53 / 2786918
    Needed 4 reads 1 writes loops 105 / 2786918
    Needed 4 reads 1 writes loops 78 / 2786918
    Needed 4 reads 1 writes loops 134 / 2786918
    Needed 4 reads 1 writes loops 41 / 696729
    Needed 4 reads 1 writes loops 54 / 2786918
    Needed 4 reads 1 writes loops 106 / 2786918
    Needed 4 reads 1 writes loops 79 / 2786918
    Needed 4 reads 1 writes loops 135 / 2786918
    Needed 4 reads 1 writes loops 55 / 2786918
    Needed 4 reads 1 writes loops 107 / 2786918
    Needed 4 reads 1 writes loops 80 / 2786918
    Needed 4 reads 1 writes loops 136 / 2786918
    Needed 4 reads 1 writes loops 56 / 2786918
    Needed 4 reads 1 writes loops 108 / 2786918
    Needed 4 reads 1 writes loops 81 / 2786918
    Needed 4 reads 1 writes loops 137 / 2786918
    Needed 4 reads 1 writes loops 57 / 2786918
    Needed 4 reads 1 writes loops 109 / 2786918
    Needed 4 reads 1 writes loops 82 / 2786918
    Needed 4 reads 1 writes loops 138 / 2786918
    Needed 4 reads 1 writes loops 42 / 696729
    Needed 4 reads 1 writes loops 58 / 2786918
    Needed 4 reads 1 writes loops 110 / 2786918
    Needed 4 reads 1 writes loops 83 / 2786918
    Needed 4 reads 1 writes loops 139 / 2786918
    Needed 4 reads 1 writes loops 111 / 2786918
    Needed 4 reads 1 writes loops 84 / 2786918
    Needed 4 reads 1 writes loops 140 / 2786918
    Needed 4 reads 1 writes loops 112 / 2786918
    Needed 4 reads 1 writes loops 85 / 2786918
    Needed 4 reads 1 writes loops 141 / 2786918
    Needed 4 reads 1 writes loops 113 / 2786918
    Needed 4 reads 1 writes loops 142 / 2786918
    Needed 4 reads 1 writes loops 43 / 696729
    Needed 4 reads 1 writes loops 143 / 2786918
    Needed 4 reads 1 writes loops 144 / 2786918
    Needed 4 reads 1 writes loops 145 / 2786918
    Needed 4 reads 1 writes loops 146 / 2786918
    Needed 4 reads 1 writes loops 44 / 696729
    Needed 4 reads 1 writes loops 147 / 2786918
    Needed 4 reads 1 writes loops 148 / 2786918
    Needed 4 reads 1 writes loops 149 / 2786918
    Needed 4 reads 1 writes loops 150 / 2786918
    Needed 4 reads 1 writes loops 45 / 696729
    Needed 4 reads 1 writes loops 151 / 2786918
    Needed 4 reads 1 writes loops 152 / 2786918
    Needed 4 reads 1 writes loops 153 / 2786918
    Needed 4 reads 1 writes loops 154 / 2786918
    Needed 4 reads 1 writes loops 46 / 696729
    Needed 4 reads 1 writes loops 155 / 2786918
    Needed 4 reads 1 writes loops 156 / 2786918
    Needed 4 reads 1 writes loops 157 / 2786918
    Needed 4 reads 1 writes loops 158 / 2786918
    Needed 4 reads 1 writes loops 47 / 696729
    Needed 4 reads 1 writes loops 159 / 2786918
    Needed 4 reads 1 writes loops 160 / 2786918
    Needed 4 reads 1 writes loops 161 / 2786918
    Needed 4 reads 1 writes loops 48 / 696729
    Needed 4 reads 1 writes loops 162 / 2786918
    Needed 4 reads 1 writes loops 163 / 2786918
    Needed 5 reads 1 writes loops 164 / 2786918
    Needed 4 reads 1 writes loops 165 / 2786918
    Needed 4 reads 1 writes loops 49 / 696729
    Needed 4 reads 1 writes loops 166 / 2786918
    Needed 4 reads 1 writes loops 167 / 2786918
    Needed 4 reads 1 writes loops 168 / 2786918
    Needed 4 reads 1 writes loops 169 / 2786918
    Needed 4 reads 1 writes loops 50 / 696729
    Needed 4 reads 1 writes loops 170 / 2786918
    Needed 4 reads 1 writes loops 171 / 2786918
    Needed 4 reads 1 writes loops 172 / 2786918
    Needed 4 reads 1 writes loops 173 / 2786918
    Needed 4 reads 1 writes loops 51 / 696729
    Needed 4 reads 1 writes loops 174 / 2786918
    Needed 4 reads 1 writes loops 175 / 2786918
    Needed 4 reads 1 writes loops 176 / 2786918
    Needed 4 reads 1 writes loops 177 / 2786918
    Needed 4 reads 1 writes loops 52 / 696729
    Needed 4 reads 1 writes loops 178 / 2786918
    Needed 4 reads 1 writes loops 179 / 2786918
    Needed 4 reads 1 writes loops 180 / 2786918
    Needed 4 reads 1 writes loops 181 / 2786918
    Needed 4 reads 1 writes loops 53 / 696729
    Needed 4 reads 1 writes loops 182 / 2786918
    Needed 4 reads 1 writes loops 183 / 2786918
    Needed 4 reads 1 writes loops 184 / 2786918
    Needed 4 reads 1 writes loops 185 / 2786918
    Needed 4 reads 1 writes loops 54 / 696729
    Needed 4 reads 1 writes loops 186 / 2786918
    Needed 4 reads 1 writes loops 187 / 2786918
    Needed 4 reads 1 writes loops 188 / 2786918
    Needed 4 reads 1 writes loops 189 / 2786918
    Needed 4 reads 1 writes loops 55 / 696729
    Needed 4 reads 1 writes loops 190 / 2786918
    Needed 4 reads 1 writes loops 191 / 2786918
    Needed 4 reads 1 writes loops 192 / 2786918
    Needed 4 reads 1 writes loops 164 / 2786918
    Needed 4 reads 1 writes loops 193 / 2786918
    Needed 4 reads 1 writes loops 56 / 696729
    Needed 4 reads 1 writes loops 194 / 2786918
    Needed 4 reads 1 writes loops 195 / 2786918
    Needed 4 reads 1 writes loops 196 / 2786918
    Needed 4 reads 1 writes loops 197 / 2786918
    Needed 4 reads 1 writes loops 57 / 696729
    Needed 4 reads 1 writes loops 198 / 2786918
    Needed 4 reads 1 writes loops 199 / 2786918
    Needed 4 reads 1 writes loops 200 / 2786918
    Needed 4 reads 1 writes loops 201 / 2786918
    Needed 4 reads 1 writes loops 58 / 696729
    Needed 4 reads 1 writes loops 202 / 2786918
    Needed 4 reads 1 writes loops 203 / 2786918
    Needed 4 reads 1 writes loops 204 / 2786918
    Needed 4 reads 1 writes loops 205 / 2786918
    Needed 4 reads 1 writes loops 59 / 696729
    Needed 4 reads 1 writes loops 206 / 2786918
    Needed 4 reads 1 writes loops 207 / 2786918
    Needed 4 reads 1 writes loops 208 / 2786918
    Needed 4 reads 1 writes loops 209 / 2786918
    Needed 4 reads 1 writes loops 60 / 696729
    Needed 4 reads 1 writes loops 210 / 2786918
    Needed 4 reads 1 writes loops 211 / 2786918
    Needed 4 reads 1 writes loops 212 / 2786918
    Needed 4 reads 1 writes loops 213 / 2786918
    Needed 4 reads 1 writes loops 61 / 696729
    Needed 4 reads 1 writes loops 214 / 2786918
    Needed 4 reads 1 writes loops 215 / 2786918
    Needed 4 reads 1 writes loops 216 / 2786918
    Needed 4 reads 1 writes loops 217 / 2786918
    Needed 4 reads 1 writes loops 62 / 696729
    Needed 4 reads 1 writes loops 218 / 2786918
    Needed 4 reads 1 writes loops 219 / 2786918
    Needed 4 reads 1 writes loops 220 / 2786918
    Needed 4 reads 1 writes loops 221 / 2786918
    Needed 4 reads 1 writes loops 63 / 696729
    Needed 4 reads 1 writes loops 222 / 2786918
    Needed 4 reads 1 writes loops 223 / 2786918
    Needed 4 reads 1 writes loops 224 / 2786918
    Needed 4 reads 1 writes loops 225 / 2786918
    Needed 4 reads 1 writes loops 64 / 696729
    Needed 4 reads 1 writes loops 226 / 2786918
    Needed 4 reads 1 writes loops 227 / 2786918
    Needed 4 reads 1 writes loops 228 / 2786918
    Needed 4 reads 1 writes loops 229 / 2786918
    Needed 4 reads 1 writes loops 65 / 696729
    Needed 4 reads 1 writes loops 230 / 2786918
    Needed 4 reads 1 writes loops 231 / 2786918
    Needed 4 reads 1 writes loops 232 / 2786918
    Needed 4 reads 1 writes loops 233 / 2786918
    Needed 4 reads 1 writes loops 66 / 696729
    Needed 4 reads 1 writes loops 234 / 2786918
    Needed 4 reads 1 writes loops 235 / 2786918
    Needed 4 reads 1 writes loops 236 / 2786918
    Needed 4 reads 1 writes loops 237 / 2786918
    Needed 4 reads 1 writes loops 67 / 696729
    Needed 4 reads 1 writes loops 238 / 2786918
    Needed 4 reads 1 writes loops 239 / 2786918
    Needed 4 reads 1 writes loops 240 / 2786918
    Needed 4 reads 1 writes loops 241 / 2786918
    Needed 4 reads 1 writes loops 68 / 696729
    Needed 4 reads 1 writes loops 242 / 2786918
    Needed 4 reads 1 writes loops 243 / 2786918
    Needed 4 reads 1 writes loops 244 / 2786918
    Needed 4 reads 1 writes loops 245 / 2786918
    Needed 4 reads 1 writes loops 69 / 696729
    Needed 4 reads 1 writes loops 246 / 2786918
    Needed 4 reads 1 writes loops 247 / 2786918
    Needed 4 reads 1 writes loops 248 / 2786918
    Needed 4 reads 1 writes loops 249 / 2786918
    Needed 4 reads 1 writes loops 70 / 696729
    Needed 4 reads 1 writes loops 250 / 2786918
    Needed 4 reads 1 writes loops 251 / 2786918
    Needed 4 reads 1 writes loops 252 / 2786918
    Needed 4 reads 1 writes loops 253 / 2786918
    Needed 4 reads 1 writes loops 71 / 696729
    Needed 4 reads 1 writes loops 254 / 2786918
    Needed 4 reads 1 writes loops 255 / 2786918
    Needed 4 reads 1 writes loops 256 / 2786918
    Needed 4 reads 1 writes loops 257 / 2786918
    Needed 4 reads 1 writes loops 72 / 696729
    Needed 4 reads 1 writes loops 258 / 2786918
    Needed 4 reads 1 writes loops 259 / 2786918
    Needed 4 reads 1 writes loops 260 / 2786918
    Needed 4 reads 1 writes loops 261 / 2786918
    Needed 4 reads 1 writes loops 73 / 696729
    Needed 4 reads 1 writes loops 262 / 2786918
    Needed 4 reads 1 writes loops 263 / 2786918
    Needed 4 reads 1 writes loops 264 / 2786918
    Needed 4 reads 1 writes loops 265 / 2786918
    Needed 4 reads 1 writes loops 74 / 696729
    Needed 4 reads 1 writes loops 266 / 2786918
    Needed 4 reads 1 writes loops 267 / 2786918
    Needed 4 reads 1 writes loops 268 / 2786918
    Needed 4 reads 1 writes loops 269 / 2786918
    Needed 4 reads 1 writes loops 75 / 696729
    Needed 4 reads 1 writes loops 270 / 2786918
    Needed 4 reads 1 writes loops 271 / 2786918
    Needed 4 reads 1 writes loops 272 / 2786918
    Needed 4 reads 1 writes loops 273 / 2786918
    Needed 4 reads 1 writes loops 76 / 696729
    Needed 4 reads 1 writes loops 274 / 2786918
    Needed 4 reads 1 writes loops 275 / 2786918
    Needed 4 reads 1 writes loops 276 / 2786918
    Needed 4 reads 1 writes loops 277 / 2786918
    Needed 4 reads 1 writes loops 77 / 696729
    Needed 4 reads 1 writes loops 278 / 2786918
    Needed 4 reads 1 writes loops 279 / 2786918
    Needed 4 reads 1 writes loops 280 / 2786918
    Needed 4 reads 1 writes loops 281 / 2786918
    Needed 4 reads 1 writes loops 78 / 696729
    Needed 4 reads 1 writes loops 282 / 2786918
    Needed 4 reads 1 writes loops 283 / 2786918
    Needed 4 reads 1 writes loops 284 / 2786918
    Needed 5 reads 1 writes loops 229 / 2786918
    Needed 5 reads 1 writes loops 285 / 2786918
    Needed 4 reads 1 writes loops 79 / 696729
    Needed 4 reads 1 writes loops 286 / 2786918
    Needed 4 reads 1 writes loops 287 / 2786918
    Needed 4 reads 1 writes loops 288 / 2786918
    Needed 4 reads 1 writes loops 289 / 2786918
    Needed 4 reads 1 writes loops 80 / 696729
    Needed 4 reads 1 writes loops 290 / 2786918
    Needed 4 reads 1 writes loops 291 / 2786918
    Needed 4 reads 1 writes loops 292 / 2786918
    Needed 4 reads 1 writes loops 293 / 2786918
    Needed 4 reads 1 writes loops 81 / 696729
    Needed 4 reads 1 writes loops 294 / 2786918
    Needed 4 reads 1 writes loops 295 / 2786918
    Needed 4 reads 1 writes loops 296 / 2786918
    Needed 4 reads 1 writes loops 297 / 2786918
    Needed 4 reads 1 writes loops 82 / 696729
    Needed 4 reads 1 writes loops 298 / 2786918
    Needed 4 reads 1 writes loops 299 / 2786918
    Needed 4 reads 1 writes loops 300 / 2786918
    Needed 4 reads 1 writes loops 301 / 2786918
    Needed 4 reads 1 writes loops 83 / 696729
    Needed 4 reads 1 writes loops 302 / 2786918
    Needed 4 reads 1 writes loops 303 / 2786918
    Needed 4 reads 1 writes loops 304 / 2786918
    Needed 4 reads 1 writes loops 305 / 2786918
    Needed 4 reads 1 writes loops 84 / 696729
    Needed 4 reads 1 writes loops 306 / 2786918
    Needed 4 reads 1 writes loops 307 / 2786918
    Needed 4 reads 1 writes loops 308 / 2786918
    Needed 4 reads 1 writes loops 309 / 2786918
    Needed 4 reads 1 writes loops 85 / 696729
    Needed 4 reads 1 writes loops 310 / 2786918
    Needed 4 reads 1 writes loops 311 / 2786918
    Needed 4 reads 1 writes loops 312 / 2786918
    Needed 4 reads 1 writes loops 313 / 2786918
    Needed 4 reads 1 writes loops 86 / 696729
    Needed 4 reads 1 writes loops 285 / 2786918
    Needed 4 reads 1 writes loops 314 / 2786918
    Needed 4 reads 1 writes loops 315 / 2786918
    Needed 4 reads 1 writes loops 316 / 2786918
    Needed 4 reads 1 writes loops 317 / 2786918
    Needed 4 reads 1 writes loops 87 / 696729
    Needed 4 reads 1 writes loops 318 / 2786918
    Needed 4 reads 1 writes loops 319 / 2786918
    Needed 4 reads 1 writes loops 320 / 2786918
    Needed 4 reads 1 writes loops 321 / 2786918
    Needed 4 reads 1 writes loops 88 / 696729
    Needed 4 reads 1 writes loops 322 / 2786918
    Needed 4 reads 1 writes loops 323 / 2786918
    Needed 4 reads 1 writes loops 324 / 2786918
    Needed 4 reads 1 writes loops 325 / 2786918
    Needed 4 reads 1 writes loops 89 / 696729
    Needed 4 reads 1 writes loops 326 / 2786918
    Needed 4 reads 1 writes loops 327 / 2786918
    Needed 4 reads 1 writes loops 328 / 2786918
    Needed 4 reads 1 writes loops 329 / 2786918
    Needed 4 reads 1 writes loops 90 / 696729
    Needed 4 reads 1 writes loops 330 / 2786918
    Needed 4 reads 1 writes loops 331 / 2786918
    Needed 4 reads 1 writes loops 332 / 2786918
    Needed 4 reads 1 writes loops 333 / 2786918
    Needed 4 reads 1 writes loops 91 / 696729
    Needed 4 reads 1 writes loops 334 / 2786918
    Needed 4 reads 1 writes loops 335 / 2786918
    Needed 4 reads 1 writes loops 336 / 2786918
    Needed 4 reads 1 writes loops 337 / 2786918
    Needed 4 reads 1 writes loops 92 / 696729
    Needed 4 reads 1 writes loops 338 / 2786918
    Needed 4 reads 1 writes loops 339 / 2786918
    Needed 4 reads 1 writes loops 340 / 2786918
    Needed 4 reads 1 writes loops 341 / 2786918
    Needed 4 reads 1 writes loops 93 / 696729
    Needed 4 reads 1 writes loops 342 / 2786918
    Needed 4 reads 1 writes loops 343 / 2786918
    Needed 4 reads 1 writes loops 344 / 2786918
    Needed 4 reads 1 writes loops 345 / 2786918
    Needed 4 reads 1 writes loops 94 / 696729
    Needed 4 reads 1 writes loops 346 / 2786918
    Needed 4 reads 1 writes loops 347 / 2786918
    Needed 4 reads 1 writes loops 348 / 2786918
    Needed 4 reads 1 writes loops 349 / 2786918
    Needed 4 reads 1 writes loops 95 / 696729
    Needed 4 reads 1 writes loops 350 / 2786918
    Needed 4 reads 1 writes loops 351 / 2786918
    Needed 4 reads 1 writes loops 352 / 2786918
    Needed 4 reads 1 writes loops 353 / 2786918
    Needed 4 reads 1 writes loops 96 / 696729
    Needed 4 reads 1 writes loops 354 / 2786918
    Needed 4 reads 1 writes loops 355 / 2786918
    Needed 4 reads 1 writes loops 356 / 2786918
    Needed 4 reads 1 writes loops 357 / 2786918
    Needed 4 reads 1 writes loops 97 / 696729
    Needed 4 reads 1 writes loops 358 / 2786918
    Needed 4 reads 1 writes loops 359 / 2786918
    Needed 4 reads 1 writes loops 360 / 2786918
    Needed 4 reads 1 writes loops 361 / 2786918
    Needed 4 reads 1 writes loops 98 / 696729
    Needed 4 reads 1 writes loops 362 / 2786918
    Needed 4 reads 1 writes loops 363 / 2786918
    Needed 4 reads 1 writes loops 364 / 2786918
    Needed 4 reads 1 writes loops 365 / 2786918
    Needed 4 reads 1 writes loops 99 / 696729
    Needed 4 reads 1 writes loops 366 / 2786918
    Needed 4 reads 1 writes loops 367 / 2786918
    Needed 4 reads 1 writes loops 368 / 2786918
    Needed 4 reads 1 writes loops 369 / 2786918
    Needed 4 reads 1 writes loops 100 / 696729
    Needed 4 reads 1 writes loops 370 / 2786918
    Needed 4 reads 1 writes loops 371 / 2786918
    Needed 4 reads 1 writes loops 372 / 2786918
    Needed 4 reads 1 writes loops 373 / 2786918
    Needed 4 reads 1 writes loops 101 / 696729
    Needed 4 reads 1 writes loops 374 / 2786918
    Needed 4 reads 1 writes loops 375 / 2786918
    Needed 4 reads 1 writes loops 376 / 2786918
    Needed 4 reads 1 writes loops 377 / 2786918
    Needed 4 reads 1 writes loops 102 / 696729
    Needed 4 reads 1 writes loops 378 / 2786918
    Needed 4 reads 1 writes loops 379 / 2786918
    Needed 4 reads 1 writes loops 380 / 2786918
    Needed 4 reads 1 writes loops 381 / 2786918
    Needed 4 reads 1 writes loops 103 / 696729
    Needed 4 reads 1 writes loops 382 / 2786918
    Needed 4 reads 1 writes loops 383 / 2786918
    Needed 4 reads 1 writes loops 384 / 2786918
    Needed 4 reads 1 writes loops 385 / 2786918
    Needed 4 reads 1 writes loops 104 / 696729
    Needed 4 reads 1 writes loops 386 / 2786918
    Needed 4 reads 1 writes loops 387 / 2786918
    Needed 4 reads 1 writes loops 388 / 2786918
    Needed 4 reads 1 writes loops 389 / 2786918
    Needed 4 reads 1 writes loops 105 / 696729
    Needed 4 reads 1 writes loops 390 / 2786918
    Needed 4 reads 1 writes loops 391 / 2786918
    Needed 4 reads 1 writes loops 392 / 2786918
    Needed 4 reads 1 writes loops 393 / 2786918
    Needed 4 reads 1 writes loops 106 / 696729
    Needed 4 reads 1 writes loops 394 / 2786918
    Needed 4 reads 1 writes loops 395 / 2786918
    Needed 4 reads 1 writes loops 396 / 2786918
    Needed 4 reads 1 writes loops 397 / 2786918
    Needed 4 reads 1 writes loops 107 / 696729
    Needed 4 reads 1 writes loops 398 / 2786918
    Needed 4 reads 1 writes loops 399 / 2786918
    Needed 4 reads 1 writes loops 400 / 2786918
    Needed 4 reads 1 writes loops 401 / 2786918
    Needed 4 reads 1 writes loops 108 / 696729
    Needed 4 reads 1 writes loops 402 / 2786918
    Needed 4 reads 1 writes loops 403 / 2786918
    Needed 4 reads 1 writes loops 404 / 2786918
    Needed 4 reads 1 writes loops 405 / 2786918
    Needed 4 reads 1 writes loops 109 / 696729
    Needed 4 reads 1 writes loops 406 / 2786918
    Needed 4 reads 1 writes loops 407 / 2786918
    Needed 4 reads 1 writes loops 408 / 2786918
    Needed 4 reads 1 writes loops 409 / 2786918
    Needed 4 reads 1 writes loops 110 / 696729
    Needed 4 reads 1 writes loops 410 / 2786918
    Needed 4 reads 1 writes loops 411 / 2786918
    Needed 4 reads 1 writes loops 412 / 2786918
    Needed 4 reads 1 writes loops 413 / 2786918
    Needed 4 reads 1 writes loops 111 / 696729
    Needed 4 reads 1 writes loops 414 / 2786918
    Needed 4 reads 1 writes loops 415 / 2786918
    Needed 4 reads 1 writes loops 416 / 2786918
    Needed 4 reads 1 writes loops 417 / 2786918
    Needed 4 reads 1 writes loops 112 / 696729
    Needed 4 reads 1 writes loops 418 / 2786918
    Needed 4 reads 1 writes loops 419 / 2786918
    Needed 4 reads 1 writes loops 420 / 2786918
    Needed 4 reads 1 writes loops 421 / 2786918
    Needed 4 reads 1 writes loops 113 / 696729
    Needed 4 reads 1 writes loops 422 / 2786918
    Needed 4 reads 1 writes loops 423 / 2786918
    Needed 4 reads 1 writes loops 424 / 2786918
    Needed 4 reads 1 writes loops 425 / 2786918
    Needed 4 reads 1 writes loops 114 / 696729
    Needed 4 reads 1 writes loops 426 / 2786918
    Needed 4 reads 1 writes loops 427 / 2786918
    Needed 4 reads 1 writes loops 428 / 2786918
    Needed 4 reads 1 writes loops 429 / 2786918
    Needed 4 reads 1 writes loops 115 / 696729
    Needed 4 reads 1 writes loops 430 / 2786918
    Needed 4 reads 1 writes loops 431 / 2786918
    Needed 4 reads 1 writes loops 432 / 2786918
    Needed 4 reads 1 writes loops 433 / 2786918
    Needed 4 reads 1 writes loops 116 / 696729
    Needed 4 reads 1 writes loops 434 / 2786918
    Needed 4 reads 1 writes loops 435 / 2786918
    Needed 4 reads 1 writes loops 436 / 2786918
    Needed 4 reads 1 writes loops 437 / 2786918
    Needed 4 reads 1 writes loops 117 / 696729
    Needed 4 reads 1 writes loops 438 / 2786918
    Needed 4 reads 1 writes loops 439 / 2786918
    Needed 4 reads 1 writes loops 440 / 2786918
    Needed 4 reads 1 writes loops 441 / 2786918
    Needed 4 reads 1 writes loops 118 / 696729
    Needed 4 reads 1 writes loops 442 / 2786918
    Needed 4 reads 1 writes loops 443 / 2786918
    Needed 4 reads 1 writes loops 444 / 2786918
    Needed 4 reads 1 writes loops 445 / 2786918
    Needed 4 reads 1 writes loops 119 / 696729
    Needed 4 reads 1 writes loops 446 / 2786918
    Needed 4 reads 1 writes loops 447 / 2786918
    Needed 4 reads 1 writes loops 448 / 2786918
    Needed 4 reads 1 writes loops 449 / 2786918
    Needed 4 reads 1 writes loops 120 / 696729
    Needed 4 reads 1 writes loops 450 / 2786918
    Needed 4 reads 1 writes loops 451 / 2786918
    Needed 4 reads 1 writes loops 452 / 2786918
    Needed 4 reads 1 writes loops 453 / 2786918
    Needed 4 reads 1 writes loops 121 / 696729
    Needed 5 reads 1 writes loops 398 / 2786918
    Needed 4 reads 1 writes loops 454 / 2786918
    Needed 4 reads 1 writes loops 455 / 2786918
    Needed 4 reads 1 writes loops 456 / 2786918
    Needed 4 reads 1 writes loops 457 / 2786918
    Needed 4 reads 1 writes loops 122 / 696729
    Needed 4 reads 1 writes loops 458 / 2786918
    Needed 4 reads 1 writes loops 459 / 2786918
    Needed 4 reads 1 writes loops 460 / 2786918
    Needed 4 reads 1 writes loops 461 / 2786918
    Needed 4 reads 1 writes loops 123 / 696729
    Needed 4 reads 1 writes loops 462 / 2786918
    Needed 4 reads 1 writes loops 463 / 2786918
    Needed 4 reads 1 writes loops 464 / 2786918
    Needed 4 reads 1 writes loops 465 / 2786918
    Needed 4 reads 1 writes loops 124 / 696729
    Needed 4 reads 1 writes loops 466 / 2786918
    Needed 4 reads 1 writes loops 467 / 2786918
    Needed 4 reads 1 writes loops 468 / 2786918
    Needed 4 reads 1 writes loops 469 / 2786918
    Needed 4 reads 1 writes loops 125 / 696729
    Needed 4 reads 1 writes loops 470 / 2786918
    Needed 4 reads 1 writes loops 471 / 2786918
    Needed 4 reads 1 writes loops 472 / 2786918
    Needed 4 reads 1 writes loops 473 / 2786918
    Needed 4 reads 1 writes loops 126 / 696729
    Needed 4 reads 1 writes loops 474 / 2786918
    Needed 4 reads 1 writes loops 475 / 2786918
    Needed 4 reads 1 writes loops 476 / 2786918
    Needed 4 reads 1 writes loops 477 / 2786918
    Needed 4 reads 1 writes loops 127 / 696729
    Needed 4 reads 1 writes loops 478 / 2786918
    Needed 4 reads 1 writes loops 479 / 2786918
    Needed 4 reads 1 writes loops 480 / 2786918
    Needed 4 reads 1 writes loops 481 / 2786918
    Needed 4 reads 1 writes loops 128 / 696729
    Needed 4 reads 1 writes loops 482 / 2786918
    Needed 4 reads 1 writes loops 483 / 2786918
    Needed 4 reads 1 writes loops 484 / 2786918
    Needed 4 reads 1 writes loops 485 / 2786918
    Needed 4 reads 1 writes loops 129 / 696729
    Needed 4 reads 1 writes loops 486 / 2786918
    Needed 4 reads 1 writes loops 487 / 2786918
    Needed 4 reads 1 writes loops 488 / 2786918
    Needed 4 reads 1 writes loops 489 / 2786918
    Needed 4 reads 1 writes loops 130 / 696729
    Needed 4 reads 1 writes loops 490 / 2786918
    Needed 4 reads 1 writes loops 491 / 2786918
    Needed 4 reads 1 writes loops 492 / 2786918
    Needed 4 reads 1 writes loops 493 / 2786918
    Needed 4 reads 1 writes loops 131 / 696729
    Needed 4 reads 1 writes loops 494 / 2786918
    Needed 4 reads 1 writes loops 495 / 2786918
    Needed 4 reads 1 writes loops 496 / 2786918
    Needed 4 reads 1 writes loops 497 / 2786918
    Needed 4 reads 1 writes loops 132 / 696729
    Needed 4 reads 1 writes loops 498 / 2786918
    Needed 4 reads 1 writes loops 499 / 2786918
    Needed 4 reads 1 writes loops 500 / 2786918
    Needed 4 reads 1 writes loops 501 / 2786918
    Needed 4 reads 1 writes loops 133 / 696729
    Needed 4 reads 1 writes loops 502 / 2786918
    Needed 4 reads 1 writes loops 503 / 2786918
    Needed 4 reads 1 writes loops 504 / 2786918
    Needed 4 reads 1 writes loops 505 / 2786918
    Needed 4 reads 1 writes loops 134 / 696729
    Needed 4 reads 1 writes loops 506 / 2786918
    Needed 4 reads 1 writes loops 507 / 2786918
    Needed 4 reads 1 writes loops 508 / 2786918
    Needed 4 reads 1 writes loops 509 / 2786918
    Needed 4 reads 1 writes loops 135 / 696729
    Needed 4 reads 1 writes loops 510 / 2786918
    Needed 4 reads 1 writes loops 511 / 2786918
    Needed 4 reads 1 writes loops 512 / 2786918
    Needed 4 reads 1 writes loops 513 / 2786918
    Needed 4 reads 1 writes loops 136 / 696729
    Needed 4 reads 1 writes loops 514 / 2786918
    Needed 4 reads 1 writes loops 515 / 2786918
    Needed 4 reads 1 writes loops 516 / 2786918
    Needed 4 reads 1 writes loops 517 / 2786918
    Needed 4 reads 1 writes loops 137 / 696729
    Needed 4 reads 1 writes loops 518 / 2786918
    Needed 4 reads 1 writes loops 519 / 2786918
    Needed 4 reads 1 writes loops 520 / 2786918
    Needed 4 reads 1 writes loops 521 / 2786918
    Needed 4 reads 1 writes loops 138 / 696729
    Needed 4 reads 1 writes loops 522 / 2786918
    Needed 4 reads 1 writes loops 523 / 2786918
    Needed 4 reads 1 writes loops 524 / 2786918
    Needed 4 reads 1 writes loops 525 / 2786918
    Needed 4 reads 1 writes loops 139 / 696729
    Needed 4 reads 1 writes loops 526 / 2786918
    Needed 4 reads 1 writes loops 527 / 2786918
    Needed 4 reads 1 writes loops 528 / 2786918
    Needed 4 reads 1 writes loops 529 / 2786918
    Needed 4 reads 1 writes loops 140 / 696729
    Needed 4 reads 1 writes loops 530 / 2786918
    Needed 4 reads 1 writes loops 531 / 2786918
    Needed 4 reads 1 writes loops 532 / 2786918
    Needed 4 reads 1 writes loops 533 / 2786918
    Needed 4 reads 1 writes loops 141 / 696729
    Needed 4 reads 1 writes loops 534 / 2786918
    Needed 4 reads 1 writes loops 535 / 2786918
    Needed 4 reads 1 writes loops 536 / 2786918
    Needed 4 reads 1 writes loops 537 / 2786918
    Needed 4 reads 1 writes loops 142 / 696729
    Needed 4 reads 1 writes loops 538 / 2786918
    Needed 4 reads 1 writes loops 539 / 2786918
    Needed 4 reads 1 writes loops 540 / 2786918
    Needed 4 reads 1 writes loops 541 / 2786918
    Needed 4 reads 1 writes loops 143 / 696729
    Needed 4 reads 1 writes loops 542 / 2786918
    Needed 4 reads 1 writes loops 543 / 2786918
    Needed 4 reads 1 writes loops 544 / 2786918
    Needed 4 reads 1 writes loops 545 / 2786918
    Needed 4 reads 1 writes loops 144 / 696729
    Needed 4 reads 1 writes loops 546 / 2786918
    Needed 4 reads 1 writes loops 547 / 2786918
    Needed 4 reads 1 writes loops 548 / 2786918
    Needed 4 reads 1 writes loops 549 / 2786918
    Needed 4 reads 1 writes loops 145 / 696729
    Needed 4 reads 1 writes loops 550 / 2786918
    Needed 4 reads 1 writes loops 551 / 2786918
    Needed 4 reads 1 writes loops 552 / 2786918
    Needed 4 reads 1 writes loops 553 / 2786918
    Needed 4 reads 1 writes loops 146 / 696729
    Needed 4 reads 1 writes loops 554 / 2786918
    Needed 5 reads 1 writes loops 499 / 2786918
    Needed 4 reads 1 writes loops 555 / 2786918
    Needed 4 reads 1 writes loops 556 / 2786918
    Needed 4 reads 1 writes loops 557 / 2786918
    Needed 4 reads 1 writes loops 147 / 696729
    Needed 4 reads 1 writes loops 558 / 2786918
    Needed 4 reads 1 writes loops 559 / 2786918
    Needed 4 reads 1 writes loops 560 / 2786918
    Needed 4 reads 1 writes loops 561 / 2786918
    Needed 4 reads 1 writes loops 148 / 696729
    Needed 4 reads 1 writes loops 562 / 2786918
    Needed 4 reads 1 writes loops 563 / 2786918
    Needed 4 reads 1 writes loops 564 / 2786918
    Needed 4 reads 1 writes loops 565 / 2786918
    Needed 4 reads 1 writes loops 149 / 696729
    Needed 4 reads 1 writes loops 566 / 2786918
    Needed 4 reads 1 writes loops 567 / 2786918
    Needed 4 reads 1 writes loops 568 / 2786918
    Needed 4 reads 1 writes loops 569 / 2786918
    Needed 4 reads 1 writes loops 150 / 696729
    Needed 4 reads 1 writes loops 570 / 2786918
    Needed 4 reads 1 writes loops 571 / 2786918
    Needed 4 reads 1 writes loops 572 / 2786918
    Needed 4 reads 1 writes loops 573 / 2786918
    Needed 4 reads 1 writes loops 151 / 696729
    Needed 4 reads 1 writes loops 574 / 2786918
    Needed 4 reads 1 writes loops 575 / 2786918
    Needed 4 reads 1 writes loops 576 / 2786918
    Needed 4 reads 1 writes loops 577 / 2786918
    Needed 4 reads 1 writes loops 152 / 696729
    Needed 4 reads 1 writes loops 578 / 2786918
    Needed 4 reads 1 writes loops 579 / 2786918
    Needed 4 reads 1 writes loops 580 / 2786918
    Needed 4 reads 1 writes loops 581 / 2786918
    Needed 4 reads 1 writes loops 153 / 696729
    Needed 4 reads 1 writes loops 582 / 2786918
    Needed 4 reads 1 writes loops 583 / 2786918
    Needed 4 reads 1 writes loops 584 / 2786918
    Needed 4 reads 1 writes loops 585 / 2786918
    Needed 4 reads 1 writes loops 154 / 696729
    Needed 4 reads 1 writes loops 586 / 2786918
    Needed 4 reads 1 writes loops 587 / 2786918
    Needed 4 reads 1 writes loops 588 / 2786918
    Needed 4 reads 1 writes loops 589 / 2786918
    Needed 4 reads 1 writes loops 155 / 696729
    Needed 4 reads 1 writes loops 590 / 2786918
    Needed 4 reads 1 writes loops 591 / 2786918
    Needed 4 reads 1 writes loops 592 / 2786918
    Needed 4 reads 1 writes loops 593 / 2786918
    Needed 4 reads 1 writes loops 156 / 696729
    Needed 4 reads 1 writes loops 594 / 2786918
    Needed 4 reads 1 writes loops 595 / 2786918
    Needed 4 reads 1 writes loops 596 / 2786918
    Needed 4 reads 1 writes loops 597 / 2786918
    Needed 4 reads 1 writes loops 157 / 696729
    Needed 4 reads 1 writes loops 598 / 2786918
    Needed 4 reads 1 writes loops 599 / 2786918
    Needed 4 reads 1 writes loops 600 / 2786918
    Needed 4 reads 1 writes loops 601 / 2786918
    Needed 4 reads 1 writes loops 158 / 696729
    Needed 4 reads 1 writes loops 602 / 2786918
    Needed 4 reads 1 writes loops 603 / 2786918
    Needed 4 reads 1 writes loops 604 / 2786918
    Needed 4 reads 1 writes loops 605 / 2786918
    Needed 4 reads 1 writes loops 159 / 696729
    Needed 4 reads 1 writes loops 606 / 2786918
    Needed 4 reads 1 writes loops 607 / 2786918
    Needed 4 reads 1 writes loops 608 / 2786918
    Needed 4 reads 1 writes loops 609 / 2786918
    Needed 4 reads 1 writes loops 160 / 696729
    Needed 4 reads 1 writes loops 610 / 2786918
    Needed 4 reads 1 writes loops 611 / 2786918
    Needed 4 reads 1 writes loops 612 / 2786918
    Needed 4 reads 1 writes loops 613 / 2786918
    Needed 4 reads 1 writes loops 161 / 696729
    Needed 4 reads 1 writes loops 614 / 2786918
    Needed 4 reads 1 writes loops 615 / 2786918
    Needed 4 reads 1 writes loops 616 / 2786918
    Needed 4 reads 1 writes loops 617 / 2786918
    Needed 4 reads 1 writes loops 162 / 696729
    Needed 4 reads 1 writes loops 618 / 2786918
    Needed 4 reads 1 writes loops 619 / 2786918
    Needed 4 reads 1 writes loops 620 / 2786918
    Needed 4 reads 1 writes loops 621 / 2786918
    Needed 4 reads 1 writes loops 163 / 696729
    Needed 4 reads 1 writes loops 622 / 2786918
    Needed 5 reads 1 writes loops 567 / 2786918
    Needed 4 reads 1 writes loops 623 / 2786918
    Needed 4 reads 1 writes loops 624 / 2786918
    Needed 4 reads 1 writes loops 625 / 2786918
    Needed 4 reads 1 writes loops 164 / 696729
    Needed 4 reads 1 writes loops 626 / 2786918
    Needed 4 reads 1 writes loops 627 / 2786918
    Needed 4 reads 1 writes loops 628 / 2786918
    Needed 4 reads 1 writes loops 629 / 2786918
    Needed 4 reads 1 writes loops 165 / 696729
    Needed 4 reads 1 writes loops 630 / 2786918
    Needed 4 reads 1 writes loops 631 / 2786918
    Needed 4 reads 1 writes loops 632 / 2786918
    Needed 4 reads 1 writes loops 633 / 2786918
    Needed 4 reads 1 writes loops 166 / 696729
    Needed 4 reads 1 writes loops 634 / 2786918
    Needed 4 reads 1 writes loops 635 / 2786918
    Needed 4 reads 1 writes loops 636 / 2786918
    Needed 4 reads 1 writes loops 637 / 2786918
    Needed 4 reads 1 writes loops 167 / 696729
    Needed 4 reads 1 writes loops 638 / 2786918
    Needed 4 reads 1 writes loops 639 / 2786918
    Needed 4 reads 1 writes loops 640 / 2786918
    Needed 4 reads 1 writes loops 641 / 2786918
    Needed 4 reads 1 writes loops 168 / 696729
    Needed 4 reads 1 writes loops 642 / 2786918
    Needed 4 reads 1 writes loops 643 / 2786918
    Needed 4 reads 1 writes loops 644 / 2786918
    Needed 4 reads 1 writes loops 645 / 2786918
    Needed 4 reads 1 writes loops 169 / 696729
    Needed 4 reads 1 writes loops 646 / 2786918
    Needed 4 reads 1 writes loops 647 / 2786918
    Needed 4 reads 1 writes loops 648 / 2786918
    Needed 4 reads 1 writes loops 649 / 2786918
    Needed 4 reads 1 writes loops 170 / 696729
    Needed 4 reads 1 writes loops 650 / 2786918
    Needed 4 reads 1 writes loops 651 / 2786918
    Needed 4 reads 1 writes loops 652 / 2786918
    Needed 4 reads 1 writes loops 653 / 2786918
    Needed 4 reads 1 writes loops 171 / 696729
    Needed 4 reads 1 writes loops 654 / 2786918
    Needed 4 reads 1 writes loops 655 / 2786918
    Needed 4 reads 1 writes loops 656 / 2786918
    Needed 4 reads 1 writes loops 657 / 2786918
    Needed 4 reads 1 writes loops 172 / 696729
    Needed 4 reads 1 writes loops 658 / 2786918
    Needed 4 reads 1 writes loops 659 / 2786918
    Needed 4 reads 1 writes loops 660 / 2786918
    Needed 4 reads 1 writes loops 661 / 2786918
    Needed 4 reads 1 writes loops 173 / 696729
    Needed 4 reads 1 writes loops 662 / 2786918
    Needed 4 reads 1 writes loops 663 / 2786918
    Needed 4 reads 1 writes loops 664 / 2786918
    Needed 4 reads 1 writes loops 665 / 2786918
    Needed 4 reads 1 writes loops 174 / 696729
    Needed 4 reads 1 writes loops 666 / 2786918
    Needed 4 reads 1 writes loops 667 / 2786918
    Needed 4 reads 1 writes loops 668 / 2786918
    Needed 4 reads 1 writes loops 669 / 2786918
    Needed 4 reads 1 writes loops 175 / 696729
    Needed 4 reads 1 writes loops 670 / 2786918
    Needed 4 reads 1 writes loops 671 / 2786918
    Needed 4 reads 1 writes loops 672 / 2786918
    Needed 4 reads 1 writes loops 673 / 2786918
    Needed 4 reads 1 writes loops 176 / 696729
    Needed 4 reads 1 writes loops 674 / 2786918
    Needed 4 reads 1 writes loops 675 / 2786918
    Needed 4 reads 1 writes loops 676 / 2786918
    Needed 4 reads 1 writes loops 677 / 2786918
    Needed 4 reads 1 writes loops 177 / 696729
    Needed 4 reads 1 writes loops 678 / 2786918
    Needed 4 reads 1 writes loops 679 / 2786918
    Needed 4 reads 1 writes loops 680 / 2786918
    Needed 4 reads 1 writes loops 681 / 2786918
    Needed 4 reads 1 writes loops 178 / 696729
    Needed 4 reads 1 writes loops 682 / 2786918
    Needed 4 reads 1 writes loops 683 / 2786918
    Needed 4 reads 1 writes loops 684 / 2786918
    Needed 4 reads 1 writes loops 685 / 2786918
    Needed 4 reads 1 writes loops 179 / 696729
    Needed 4 reads 1 writes loops 686 / 2786918
    Needed 4 reads 1 writes loops 687 / 2786918
    Needed 4 reads 1 writes loops 688 / 2786918
    Needed 4 reads 1 writes loops 689 / 2786918
    Needed 4 reads 1 writes loops 180 / 696729
    Needed 4 reads 1 writes loops 690 / 2786918
    Needed 4 reads 1 writes loops 691 / 2786918
    Needed 4 reads 1 writes loops 692 / 2786918
    Needed 4 reads 1 writes loops 693 / 2786918
    Needed 4 reads 1 writes loops 181 / 696729
    Needed 4 reads 1 writes loops 694 / 2786918
    Needed 4 reads 1 writes loops 695 / 2786918
    Needed 4 reads 1 writes loops 696 / 2786918
    Needed 4 reads 1 writes loops 697 / 2786918
    Needed 4 reads 1 writes loops 182 / 696729
    Needed 4 reads 1 writes loops 698 / 2786918
    Needed 4 reads 1 writes loops 699 / 2786918
    Needed 4 reads 1 writes loops 700 / 2786918
    Needed 4 reads 1 writes loops 701 / 2786918
    Needed 4 reads 1 writes loops 183 / 696729
    Needed 4 reads 1 writes loops 702 / 2786918
    Needed 4 reads 1 writes loops 703 / 2786918
    Needed 4 reads 1 writes loops 704 / 2786918
    Needed 4 reads 1 writes loops 705 / 2786918
    Needed 4 reads 1 writes loops 184 / 696729
    Needed 4 reads 1 writes loops 706 / 2786918
    Needed 4 reads 1 writes loops 707 / 2786918
    Needed 4 reads 1 writes loops 708 / 2786918
    Needed 4 reads 1 writes loops 709 / 2786918
    Needed 4 reads 1 writes loops 185 / 696729
    Needed 4 reads 1 writes loops 710 / 2786918
    Needed 4 reads 1 writes loops 711 / 2786918
    Needed 4 reads 1 writes loops 712 / 2786918
    Needed 4 reads 1 writes loops 713 / 2786918
    Needed 4 reads 1 writes loops 186 / 696729
    Needed 4 reads 1 writes loops 714 / 2786918
    Needed 4 reads 1 writes loops 715 / 2786918
    Needed 4 reads 1 writes loops 716 / 2786918
    Needed 4 reads 1 writes loops 717 / 2786918
    Needed 4 reads 1 writes loops 187 / 696729
    Needed 4 reads 1 writes loops 718 / 2786918
    Needed 4 reads 1 writes loops 719 / 2786918
    Needed 4 reads 1 writes loops 720 / 2786918
    Needed 4 reads 1 writes loops 721 / 2786918
    Needed 4 reads 1 writes loops 188 / 696729
    Needed 4 reads 1 writes loops 722 / 2786918
    Needed 4 reads 1 writes loops 723 / 2786918
    Needed 4 reads 1 writes loops 724 / 2786918
    Needed 4 reads 1 writes loops 725 / 2786918
    Needed 4 reads 1 writes loops 189 / 696729
    Needed 4 reads 1 writes loops 726 / 2786918
    Needed 4 reads 1 writes loops 727 / 2786918
    Needed 4 reads 1 writes loops 728 / 2786918
    Needed 4 reads 1 writes loops 729 / 2786918
    Needed 4 reads 1 writes loops 190 / 696729
    Needed 4 reads 1 writes loops 730 / 2786918
    Needed 4 reads 1 writes loops 731 / 2786918
    Needed 4 reads 1 writes loops 732 / 2786918
    Needed 4 reads 1 writes loops 733 / 2786918
    Needed 4 reads 1 writes loops 191 / 696729
    Needed 4 reads 1 writes loops 734 / 2786918
    Needed 4 reads 1 writes loops 735 / 2786918
    Needed 4 reads 1 writes loops 736 / 2786918
    Needed 4 reads 1 writes loops 737 / 2786918
    Needed 4 reads 1 writes loops 192 / 696729
    Needed 4 reads 1 writes loops 738 / 2786918
    Needed 4 reads 1 writes loops 739 / 2786918
    Needed 4 reads 1 writes loops 740 / 2786918
    Needed 4 reads 1 writes loops 193 / 696729
    Needed 4 reads 1 writes loops 741 / 2786918
    Needed 4 reads 1 writes loops 742 / 2786918
    Needed 4 reads 1 writes loops 743 / 2786918
    Needed 4 reads 1 writes loops 744 / 2786918
    Needed 4 reads 1 writes loops 194 / 696729
    Needed 4 reads 1 writes loops 745 / 2786918
    Needed 4 reads 1 writes loops 746 / 2786918
    Needed 4 reads 1 writes loops 747 / 2786918
    Needed 4 reads 1 writes loops 748 / 2786918
    Needed 4 reads 1 writes loops 195 / 696729
    Needed 4 reads 1 writes loops 749 / 2786918
    Needed 4 reads 1 writes loops 750 / 2786918
    Needed 4 reads 1 writes loops 751 / 2786918
    Needed 4 reads 1 writes loops 752 / 2786918
    Needed 4 reads 1 writes loops 196 / 696729
    Needed 4 reads 1 writes loops 753 / 2786918
    Needed 4 reads 1 writes loops 754 / 2786918
    Needed 4 reads 1 writes loops 755 / 2786918
    Needed 4 reads 1 writes loops 756 / 2786918
    Needed 4 reads 1 writes loops 197 / 696729
    Needed 4 reads 1 writes loops 757 / 2786918
    Needed 4 reads 1 writes loops 758 / 2786918
    Needed 4 reads 1 writes loops 759 / 2786918
    Needed 4 reads 1 writes loops 760 / 2786918
    Needed 4 reads 1 writes loops 198 / 696729
    Needed 4 reads 1 writes loops 761 / 2786918
    Needed 4 reads 1 writes loops 762 / 2786918
    Needed 4 reads 1 writes loops 763 / 2786918
    Needed 4 reads 1 writes loops 764 / 2786918
    Needed 4 reads 1 writes loops 199 / 696729
    Needed 4 reads 1 writes loops 765 / 2786918
    Needed 4 reads 1 writes loops 766 / 2786918
    Needed 4 reads 1 writes loops 767 / 2786918
    Needed 4 reads 1 writes loops 768 / 2786918
    Needed 4 reads 1 writes loops 200 / 696729
    Needed 4 reads 1 writes loops 769 / 2786918
    Needed 4 reads 1 writes loops 770 / 2786918
    Needed 4 reads 1 writes loops 771 / 2786918
    Needed 4 reads 1 writes loops 772 / 2786918
    Needed 4 reads 1 writes loops 201 / 696729
    Needed 4 reads 1 writes loops 773 / 2786918
    Needed 4 reads 1 writes loops 774 / 2786918
    Needed 4 reads 1 writes loops 775 / 2786918
    Needed 4 reads 1 writes loops 776 / 2786918
    Needed 4 reads 1 writes loops 202 / 696729
    Needed 4 reads 1 writes loops 777 / 2786918
    Needed 4 reads 1 writes loops 778 / 2786918
    Needed 4 reads 1 writes loops 779 / 2786918
    Needed 4 reads 1 writes loops 780 / 2786918
    Needed 4 reads 1 writes loops 203 / 696729
    Needed 4 reads 1 writes loops 781 / 2786918
    Needed 4 reads 1 writes loops 782 / 2786918
    Needed 4 reads 1 writes loops 783 / 2786918
    Needed 4 reads 1 writes loops 784 / 2786918
    Needed 4 reads 1 writes loops 204 / 696729
    Needed 4 reads 1 writes loops 785 / 2786918
    Needed 4 reads 1 writes loops 786 / 2786918
    Needed 4 reads 1 writes loops 787 / 2786918
    Needed 4 reads 1 writes loops 788 / 2786918
    Needed 4 reads 1 writes loops 205 / 696729
    Needed 4 reads 1 writes loops 789 / 2786918
    Needed 4 reads 1 writes loops 790 / 2786918
    Needed 4 reads 1 writes loops 791 / 2786918
    Needed 4 reads 1 writes loops 792 / 2786918
    Needed 4 reads 1 writes loops 206 / 696729
    Needed 4 reads 1 writes loops 793 / 2786918
    Needed 4 reads 1 writes loops 794 / 2786918
    Needed 4 reads 1 writes loops 795 / 2786918
    Needed 4 reads 1 writes loops 796 / 2786918
    Needed 4 reads 1 writes loops 207 / 696729
    Needed 4 reads 1 writes loops 797 / 2786918
    Needed 4 reads 1 writes loops 798 / 2786918
    Needed 4 reads 1 writes loops 799 / 2786918
    Needed 4 reads 1 writes loops 800 / 2786918
    Needed 4 reads 1 writes loops 208 / 696729
    Needed 4 reads 1 writes loops 801 / 2786918
    Needed 4 reads 1 writes loops 802 / 2786918
    Needed 4 reads 1 writes loops 803 / 2786918
    Needed 4 reads 1 writes loops 804 / 2786918
    Needed 4 reads 1 writes loops 209 / 696729
    Needed 4 reads 1 writes loops 805 / 2786918
    Needed 4 reads 1 writes loops 806 / 2786918
    Needed 4 reads 1 writes loops 807 / 2786918
    Needed 4 reads 1 writes loops 808 / 2786918
    Needed 4 reads 1 writes loops 210 / 696729
    Needed 4 reads 1 writes loops 809 / 2786918
    Needed 4 reads 1 writes loops 810 / 2786918
    Needed 4 reads 1 writes loops 811 / 2786918
    Needed 4 reads 1 writes loops 812 / 2786918
    Needed 4 reads 1 writes loops 211 / 696729
    Needed 4 reads 1 writes loops 813 / 2786918
    Needed 4 reads 1 writes loops 814 / 2786918
    Needed 4 reads 1 writes loops 815 / 2786918
    Needed 4 reads 1 writes loops 816 / 2786918
    Needed 4 reads 1 writes loops 212 / 696729
    Needed 4 reads 1 writes loops 817 / 2786918
    Needed 4 reads 1 writes loops 818 / 2786918
    Needed 4 reads 1 writes loops 819 / 2786918
    Needed 4 reads 1 writes loops 820 / 2786918
    Needed 4 reads 1 writes loops 213 / 696729
    Needed 4 reads 1 writes loops 821 / 2786918
    Needed 4 reads 1 writes loops 822 / 2786918
    Needed 4 reads 1 writes loops 823 / 2786918
    Needed 4 reads 1 writes loops 824 / 2786918
    Needed 4 reads 1 writes loops 214 / 696729
    Needed 4 reads 1 writes loops 825 / 2786918
    Needed 4 reads 1 writes loops 826 / 2786918
    Needed 4 reads 1 writes loops 827 / 2786918
    Needed 4 reads 1 writes loops 828 / 2786918
    Needed 4 reads 1 writes loops 215 / 696729
    Needed 4 reads 1 writes loops 829 / 2786918
    Needed 4 reads 1 writes loops 830 / 2786918
    Needed 4 reads 1 writes loops 831 / 2786918
    Needed 4 reads 1 writes loops 832 / 2786918
    Needed 4 reads 1 writes loops 216 / 696729
    Needed 4 reads 1 writes loops 833 / 2786918
    Needed 4 reads 1 writes loops 834 / 2786918
    Needed 4 reads 1 writes loops 835 / 2786918
    Needed 4 reads 1 writes loops 836 / 2786918
    Needed 4 reads 1 writes loops 217 / 696729
    Needed 4 reads 1 writes loops 837 / 2786918
    Needed 4 reads 1 writes loops 838 / 2786918
    Needed 4 reads 1 writes loops 839 / 2786918
    Needed 4 reads 1 writes loops 840 / 2786918
    Needed 4 reads 1 writes loops 218 / 696729
    Needed 4 reads 1 writes loops 841 / 2786918
    Needed 4 reads 1 writes loops 842 / 2786918
    Needed 4 reads 1 writes loops 843 / 2786918
    Needed 4 reads 1 writes loops 844 / 2786918
    Needed 4 reads 1 writes loops 219 / 696729
    Needed 4 reads 1 writes loops 845 / 2786918
    Needed 4 reads 1 writes loops 846 / 2786918
    Needed 4 reads 1 writes loops 847 / 2786918
    Needed 4 reads 1 writes loops 848 / 2786918
    Needed 4 reads 1 writes loops 220 / 696729
    Needed 4 reads 1 writes loops 849 / 2786918
    Needed 4 reads 1 writes loops 850 / 2786918
    Needed 4 reads 1 writes loops 851 / 2786918
    Needed 4 reads 1 writes loops 852 / 2786918
    Needed 4 reads 1 writes loops 221 / 696729
    Needed 4 reads 1 writes loops 853 / 2786918
    Needed 4 reads 1 writes loops 854 / 2786918
    Needed 4 reads 1 writes loops 855 / 2786918
    Needed 4 reads 1 writes loops 856 / 2786918
    Needed 4 reads 1 writes loops 222 / 696729
    Needed 4 reads 1 writes loops 857 / 2786918
    Needed 4 reads 1 writes loops 858 / 2786918
    Needed 4 reads 1 writes loops 859 / 2786918
    Needed 4 reads 1 writes loops 860 / 2786918
    Needed 4 reads 1 writes loops 223 / 696729
    Needed 4 reads 1 writes loops 861 / 2786918
    Needed 4 reads 1 writes loops 862 / 2786918
    Needed 4 reads 1 writes loops 863 / 2786918
    Needed 4 reads 1 writes loops 864 / 2786918
    Needed 4 reads 1 writes loops 224 / 696729
    Needed 4 reads 1 writes loops 865 / 2786918
    Needed 4 reads 1 writes loops 866 / 2786918
    Needed 4 reads 1 writes loops 867 / 2786918
    Needed 4 reads 1 writes loops 868 / 2786918
    Needed 4 reads 1 writes loops 225 / 696729
    Needed 4 reads 1 writes loops 869 / 2786918
    Needed 4 reads 1 writes loops 870 / 2786918
    Needed 4 reads 1 writes loops 871 / 2786918
    Needed 4 reads 1 writes loops 872 / 2786918
    Needed 4 reads 1 writes loops 226 / 696729
    Needed 4 reads 1 writes loops 873 / 2786918
    Needed 4 reads 1 writes loops 874 / 2786918
    Needed 4 reads 1 writes loops 875 / 2786918
    Needed 4 reads 1 writes loops 876 / 2786918
    Needed 4 reads 1 writes loops 227 / 696729
    Needed 4 reads 1 writes loops 877 / 2786918
    Needed 4 reads 1 writes loops 878 / 2786918
    Needed 4 reads 1 writes loops 879 / 2786918
    Needed 4 reads 1 writes loops 880 / 2786918
    Needed 4 reads 1 writes loops 228 / 696729
    Needed 4 reads 1 writes loops 881 / 2786918
    Needed 4 reads 1 writes loops 882 / 2786918
    Needed 4 reads 1 writes loops 883 / 2786918
    Needed 4 reads 1 writes loops 884 / 2786918
    Needed 4 reads 1 writes loops 229 / 696729
    Needed 4 reads 1 writes loops 885 / 2786918
    Needed 4 reads 1 writes loops 886 / 2786918
    Needed 4 reads 1 writes loops 887 / 2786918
    Needed 4 reads 1 writes loops 888 / 2786918
    Needed 4 reads 1 writes loops 230 / 696729
    Needed 4 reads 1 writes loops 889 / 2786918
    Needed 4 reads 1 writes loops 890 / 2786918
    Needed 4 reads 1 writes loops 891 / 2786918
    Needed 4 reads 1 writes loops 892 / 2786918
    Needed 4 reads 1 writes loops 231 / 696729
    Needed 4 reads 1 writes loops 893 / 2786918
    Needed 4 reads 1 writes loops 894 / 2786918
    Needed 4 reads 1 writes loops 895 / 2786918
    Needed 4 reads 1 writes loops 896 / 2786918
    Needed 4 reads 1 writes loops 232 / 696729
    Needed 4 reads 1 writes loops 897 / 2786918
    Needed 4 reads 1 writes loops 898 / 2786918
    Needed 4 reads 1 writes loops 899 / 2786918
    Needed 4 reads 1 writes loops 900 / 2786918
    Needed 4 reads 1 writes loops 233 / 696729
    Needed 4 reads 1 writes loops 901 / 2786918
    Needed 4 reads 1 writes loops 902 / 2786918
    Needed 4 reads 1 writes loops 903 / 2786918
    Needed 4 reads 1 writes loops 904 / 2786918
    Needed 4 reads 1 writes loops 234 / 696729
    Needed 4 reads 1 writes loops 905 / 2786918
    Needed 4 reads 1 writes loops 906 / 2786918
    Needed 4 reads 1 writes loops 907 / 2786918
    Needed 4 reads 1 writes loops 908 / 2786918
    Needed 4 reads 1 writes loops 235 / 696729
    Needed 4 reads 1 writes loops 909 / 2786918
    Needed 4 reads 1 writes loops 910 / 2786918
    Needed 4 reads 1 writes loops 911 / 2786918
    Needed 4 reads 1 writes loops 912 / 2786918
    Needed 4 reads 1 writes loops 236 / 696729
    Needed 4 reads 1 writes loops 913 / 2786918
    Needed 4 reads 1 writes loops 914 / 2786918
    Needed 4 reads 1 writes loops 915 / 2786918
    Needed 4 reads 1 writes loops 916 / 2786918
    Needed 4 reads 1 writes loops 237 / 696729
    Needed 4 reads 1 writes loops 917 / 2786918
    Needed 4 reads 1 writes loops 918 / 2786918
    Needed 4 reads 1 writes loops 919 / 2786918
    Needed 4 reads 1 writes loops 920 / 2786918
    Needed 4 reads 1 writes loops 238 / 696729
    Needed 4 reads 1 writes loops 921 / 2786918
    Needed 4 reads 1 writes loops 922 / 2786918
    Needed 4 reads 1 writes loops 923 / 2786918
    Needed 4 reads 1 writes loops 924 / 2786918
    Needed 4 reads 1 writes loops 239 / 696729
    Needed 4 reads 1 writes loops 925 / 2786918
    Needed 4 reads 1 writes loops 926 / 2786918
    Needed 4 reads 1 writes loops 927 / 2786918
    Needed 4 reads 1 writes loops 928 / 2786918
    Needed 4 reads 1 writes loops 240 / 696729
    Needed 4 reads 1 writes loops 929 / 2786918
    Needed 4 reads 1 writes loops 930 / 2786918
    Needed 4 reads 1 writes loops 931 / 2786918
    Needed 4 reads 1 writes loops 932 / 2786918
    Needed 4 reads 1 writes loops 241 / 696729
    Needed 4 reads 1 writes loops 933 / 2786918
    Needed 4 reads 1 writes loops 934 / 2786918
    Needed 4 reads 1 writes loops 935 / 2786918
    Needed 4 reads 1 writes loops 936 / 2786918
    Needed 4 reads 1 writes loops 242 / 696729
    Needed 4 reads 1 writes loops 937 / 2786918
    Needed 4 reads 1 writes loops 938 / 2786918
    Needed 4 reads 1 writes loops 939 / 2786918
    Needed 4 reads 1 writes loops 940 / 2786918
    Needed 4 reads 1 writes loops 243 / 696729
    Needed 4 reads 1 writes loops 941 / 2786918
    Needed 4 reads 1 writes loops 942 / 2786918
    Needed 4 reads 1 writes loops 943 / 2786918
    Needed 4 reads 1 writes loops 944 / 2786918
    Needed 4 reads 1 writes loops 244 / 696729
    Needed 4 reads 1 writes loops 945 / 2786918
    Needed 4 reads 1 writes loops 946 / 2786918
    Needed 4 reads 1 writes loops 947 / 2786918
    Needed 4 reads 1 writes loops 948 / 2786918
    Needed 4 reads 1 writes loops 245 / 696729
    Needed 4 reads 1 writes loops 949 / 2786918
    Needed 4 reads 1 writes loops 950 / 2786918
    Needed 4 reads 1 writes loops 951 / 2786918
    Needed 4 reads 1 writes loops 952 / 2786918
    Needed 4 reads 1 writes loops 246 / 696729
    Needed 4 reads 1 writes loops 953 / 2786918
    Needed 4 reads 1 writes loops 954 / 2786918
    Needed 4 reads 1 writes loops 955 / 2786918
    Needed 4 reads 1 writes loops 956 / 2786918
    Needed 4 reads 1 writes loops 247 / 696729
    Needed 4 reads 1 writes loops 957 / 2786918
    Needed 4 reads 1 writes loops 958 / 2786918
    Needed 4 reads 1 writes loops 959 / 2786918
    Needed 4 reads 1 writes loops 960 / 2786918
    Needed 4 reads 1 writes loops 248 / 696729
    Needed 5 reads 1 writes loops 961 / 2786918
    Needed 4 reads 1 writes loops 962 / 2786918
    Needed 4 reads 1 writes loops 963 / 2786918
    Needed 4 reads 1 writes loops 964 / 2786918
    Needed 4 reads 1 writes loops 249 / 696729
    Needed 4 reads 1 writes loops 965 / 2786918
    Needed 4 reads 1 writes loops 966 / 2786918
    Needed 4 reads 1 writes loops 967 / 2786918
    Needed 4 reads 1 writes loops 968 / 2786918
    Needed 4 reads 1 writes loops 250 / 696729
    Needed 4 reads 1 writes loops 969 / 2786918
    Needed 4 reads 1 writes loops 970 / 2786918
    Needed 4 reads 1 writes loops 971 / 2786918
    Needed 4 reads 1 writes loops 972 / 2786918
    Needed 4 reads 1 writes loops 251 / 696729
    Needed 4 reads 1 writes loops 973 / 2786918
    Needed 4 reads 1 writes loops 974 / 2786918
    Needed 4 reads 1 writes loops 975 / 2786918
    Needed 4 reads 1 writes loops 976 / 2786918
    Needed 4 reads 1 writes loops 252 / 696729
    Needed 4 reads 1 writes loops 977 / 2786918
    Needed 4 reads 1 writes loops 978 / 2786918
    Needed 4 reads 1 writes loops 979 / 2786918
    Needed 4 reads 1 writes loops 980 / 2786918
    Needed 4 reads 1 writes loops 253 / 696729
    Needed 4 reads 1 writes loops 981 / 2786918
    Needed 4 reads 1 writes loops 982 / 2786918
    Needed 4 reads 1 writes loops 983 / 2786918
    Needed 4 reads 1 writes loops 984 / 2786918
    Needed 4 reads 1 writes loops 254 / 696729
    Needed 4 reads 1 writes loops 985 / 2786918
    Needed 4 reads 1 writes loops 986 / 2786918
    Needed 4 reads 1 writes loops 987 / 2786918
    Needed 4 reads 1 writes loops 988 / 2786918
    Needed 4 reads 1 writes loops 255 / 696729
    Needed 4 reads 1 writes loops 989 / 2786918
    Needed 4 reads 1 writes loops 961 / 2786918
    Needed 4 reads 1 writes loops 990 / 2786918
    Needed 4 reads 1 writes loops 991 / 2786918
    Needed 4 reads 1 writes loops 992 / 2786918
    Needed 4 reads 1 writes loops 256 / 696729
    Needed 4 reads 1 writes loops 993 / 2786918
    Needed 4 reads 1 writes loops 994 / 2786918
    Needed 4 reads 1 writes loops 995 / 2786918
    Needed 4 reads 1 writes loops 996 / 2786918
    Needed 4 reads 1 writes loops 257 / 696729
    Needed 4 reads 1 writes loops 997 / 2786918
    Needed 4 reads 1 writes loops 998 / 2786918
    Needed 4 reads 1 writes loops 999 / 2786918
    Needed 4 reads 1 writes loops 1000 / 2786918
    Needed 4 reads 1 writes loops 258 / 696729
    Needed 4 reads 1 writes loops 1001 / 2786918
    Needed 4 reads 1 writes loops 1002 / 2786918
    Needed 4 reads 1 writes loops 1003 / 2786918
    Needed 4 reads 1 writes loops 1004 / 2786918
    Needed 4 reads 1 writes loops 259 / 696729
    Needed 4 reads 1 writes loops 1005 / 2786918
    Needed 4 reads 1 writes loops 1006 / 2786918
    Needed 4 reads 1 writes loops 1007 / 2786918
    Needed 4 reads 1 writes loops 1008 / 2786918
    Needed 4 reads 1 writes loops 260 / 696729
    Needed 5 reads 1 writes loops 1009 / 2786918
    Needed 4 reads 1 writes loops 1010 / 2786918
    Needed 4 reads 1 writes loops 1011 / 2786918
    Needed 4 reads 1 writes loops 1012 / 2786918
    Needed 4 reads 1 writes loops 261 / 696729
    Needed 4 reads 1 writes loops 1013 / 2786918
    Needed 4 reads 1 writes loops 1014 / 2786918
    Needed 4 reads 1 writes loops 1015 / 2786918
    Needed 4 reads 1 writes loops 1016 / 2786918
    Needed 4 reads 1 writes loops 262 / 696729
    Needed 4 reads 1 writes loops 1017 / 2786918
    Needed 4 reads 1 writes loops 1018 / 2786918
    Needed 4 reads 1 writes loops 1019 / 2786918
    Needed 4 reads 1 writes loops 1020 / 2786918
    Needed 4 reads 1 writes loops 263 / 696729
    Needed 4 reads 1 writes loops 1021 / 2786918
    Needed 4 reads 1 writes loops 1022 / 2786918
    Needed 4 reads 1 writes loops 1023 / 2786918
    Needed 4 reads 1 writes loops 1024 / 2786918
    Needed 4 reads 1 writes loops 264 / 696729
    Needed 4 reads 1 writes loops 1025 / 2786918
    Needed 4 reads 1 writes loops 1026 / 2786918
    Needed 4 reads 1 writes loops 1027 / 2786918
    Needed 4 reads 1 writes loops 1028 / 2786918
    Needed 4 reads 1 writes loops 265 / 696729
    Needed 4 reads 1 writes loops 1029 / 2786918
    Needed 4 reads 1 writes loops 1030 / 2786918
    Needed 4 reads 1 writes loops 1031 / 2786918
    Needed 4 reads 1 writes loops 1032 / 2786918
    Needed 4 reads 1 writes loops 266 / 696729
    Needed 4 reads 1 writes loops 1033 / 2786918
    Needed 4 reads 1 writes loops 1034 / 2786918
    Needed 4 reads 1 writes loops 1035 / 2786918
    Needed 4 reads 1 writes loops 1036 / 2786918
    Needed 4 reads 1 writes loops 267 / 696729
    Needed 4 reads 1 writes loops 1037 / 2786918
    Needed 4 reads 1 writes loops 1009 / 2786918
    Needed 4 reads 1 writes loops 1038 / 2786918
    Needed 4 reads 1 writes loops 1039 / 2786918
    Needed 4 reads 1 writes loops 1040 / 2786918
    Needed 4 reads 1 writes loops 268 / 696729
    Needed 4 reads 1 writes loops 1041 / 2786918
    Needed 4 reads 1 writes loops 1042 / 2786918
    Needed 4 reads 1 writes loops 1043 / 2786918
    Needed 4 reads 1 writes loops 1044 / 2786918
    Needed 4 reads 1 writes loops 269 / 696729
    Needed 4 reads 1 writes loops 1045 / 2786918
    Needed 4 reads 1 writes loops 1046 / 2786918
    Needed 4 reads 1 writes loops 1047 / 2786918
    Needed 4 reads 1 writes loops 1048 / 2786918
    Needed 4 reads 1 writes loops 270 / 696729
    Needed 4 reads 1 writes loops 1049 / 2786918
    Needed 4 reads 1 writes loops 1050 / 2786918
    Needed 4 reads 1 writes loops 1051 / 2786918
    Needed 4 reads 1 writes loops 1052 / 2786918
    Needed 4 reads 1 writes loops 271 / 696729
    Needed 4 reads 1 writes loops 1053 / 2786918
    Needed 4 reads 1 writes loops 1054 / 2786918
    Needed 4 reads 1 writes loops 1055 / 2786918
    Needed 4 reads 1 writes loops 1056 / 2786918
    Needed 4 reads 1 writes loops 272 / 696729
    Needed 4 reads 1 writes loops 1057 / 2786918
    Needed 4 reads 1 writes loops 1058 / 2786918
    Needed 4 reads 1 writes loops 1059 / 2786918
    Needed 4 reads 1 writes loops 1060 / 2786918
    Needed 4 reads 1 writes loops 273 / 696729
    Needed 4 reads 1 writes loops 1061 / 2786918
    Needed 4 reads 1 writes loops 1062 / 2786918
    Needed 4 reads 1 writes loops 1063 / 2786918
    Needed 4 reads 1 writes loops 1064 / 2786918
    Needed 4 reads 1 writes loops 274 / 696729
    Needed 4 reads 1 writes loops 1065 / 2786918
    Needed 4 reads 1 writes loops 1066 / 2786918
    Needed 4 reads 1 writes loops 1067 / 2786918
    Needed 4 reads 1 writes loops 1068 / 2786918
    Needed 4 reads 1 writes loops 275 / 696729
    Needed 4 reads 1 writes loops 1069 / 2786918
    Needed 4 reads 1 writes loops 1070 / 2786918
    Needed 4 reads 1 writes loops 1071 / 2786918
    Needed 4 reads 1 writes loops 1072 / 2786918
    Needed 4 reads 1 writes loops 276 / 696729
    Needed 4 reads 1 writes loops 1073 / 2786918
    Needed 4 reads 1 writes loops 1074 / 2786918
    Needed 4 reads 1 writes loops 1075 / 2786918
    Needed 4 reads 1 writes loops 1076 / 2786918
    Needed 4 reads 1 writes loops 277 / 696729
    Needed 4 reads 1 writes loops 1077 / 2786918
    Needed 4 reads 1 writes loops 1078 / 2786918
    Needed 4 reads 1 writes loops 1079 / 2786918
    Needed 4 reads 1 writes loops 1080 / 2786918
    Needed 4 reads 1 writes loops 278 / 696729
    Needed 4 reads 1 writes loops 1081 / 2786918
    Needed 4 reads 1 writes loops 1082 / 2786918
    Needed 4 reads 1 writes loops 1083 / 2786918
    Needed 4 reads 1 writes loops 1084 / 2786918
    Needed 4 reads 1 writes loops 279 / 696729
    Needed 4 reads 1 writes loops 1085 / 2786918
    Needed 4 reads 1 writes loops 1086 / 2786918
    Needed 4 reads 1 writes loops 1087 / 2786918
    Needed 4 reads 1 writes loops 1088 / 2786918
    Needed 4 reads 1 writes loops 280 / 696729
    Needed 4 reads 1 writes loops 1089 / 2786918
    Needed 4 reads 1 writes loops 1090 / 2786918
    Needed 4 reads 1 writes loops 1091 / 2786918
    Needed 4 reads 1 writes loops 1092 / 2786918
    Needed 4 reads 1 writes loops 281 / 696729
    Needed 4 reads 1 writes loops 1093 / 2786918
    Needed 4 reads 1 writes loops 1094 / 2786918
    Needed 4 reads 1 writes loops 1095 / 2786918
    Needed 4 reads 1 writes loops 1096 / 2786918
    Needed 4 reads 1 writes loops 282 / 696729
    Needed 4 reads 1 writes loops 1097 / 2786918
    Needed 4 reads 1 writes loops 1098 / 2786918
    Needed 4 reads 1 writes loops 1099 / 2786918
    Needed 4 reads 1 writes loops 1100 / 2786918
    Needed 4 reads 1 writes loops 283 / 696729
    Needed 4 reads 1 writes loops 1101 / 2786918
    Needed 4 reads 1 writes loops 1102 / 2786918
    Needed 4 reads 1 writes loops 1103 / 2786918
    Needed 4 reads 1 writes loops 1104 / 2786918
    Needed 4 reads 1 writes loops 284 / 696729
    Needed 4 reads 1 writes loops 1105 / 2786918
    Needed 4 reads 1 writes loops 1106 / 2786918
    Needed 4 reads 1 writes loops 1107 / 2786918
    Needed 4 reads 1 writes loops 1108 / 2786918
    Needed 4 reads 1 writes loops 285 / 696729
    Needed 4 reads 1 writes loops 1109 / 2786918
    Needed 4 reads 1 writes loops 1110 / 2786918
    Needed 4 reads 1 writes loops 1111 / 2786918
    Needed 4 reads 1 writes loops 1112 / 2786918
    Needed 4 reads 1 writes loops 286 / 696729
    Needed 4 reads 1 writes loops 1113 / 2786918
    Needed 4 reads 1 writes loops 1114 / 2786918
    Needed 4 reads 1 writes loops 1115 / 2786918
    Needed 4 reads 1 writes loops 1116 / 2786918
    Needed 4 reads 1 writes loops 287 / 696729
    Needed 4 reads 1 writes loops 1117 / 2786918
    Needed 4 reads 1 writes loops 1118 / 2786918
    Needed 4 reads 1 writes loops 1119 / 2786918
    Needed 4 reads 1 writes loops 1120 / 2786918
    Needed 4 reads 1 writes loops 288 / 696729
    Needed 4 reads 1 writes loops 1121 / 2786918
    Needed 4 reads 1 writes loops 1122 / 2786918
    Needed 4 reads 1 writes loops 1123 / 2786918
    Needed 4 reads 1 writes loops 1124 / 2786918
    Needed 4 reads 1 writes loops 289 / 696729
    Needed 4 reads 1 writes loops 1125 / 2786918
    Needed 4 reads 1 writes loops 1126 / 2786918
    Needed 4 reads 1 writes loops 1127 / 2786918
    Needed 4 reads 1 writes loops 1128 / 2786918
    Needed 4 reads 1 writes loops 290 / 696729
    Needed 4 reads 1 writes loops 1129 / 2786918
    Needed 4 reads 1 writes loops 1130 / 2786918
    Needed 4 reads 1 writes loops 1131 / 2786918
    Needed 4 reads 1 writes loops 1132 / 2786918
    Needed 4 reads 1 writes loops 291 / 696729
    Needed 4 reads 1 writes loops 1133 / 2786918
    Needed 4 reads 1 writes loops 1134 / 2786918
    Needed 4 reads 1 writes loops 1135 / 2786918
    Needed 4 reads 1 writes loops 1136 / 2786918
    Needed 4 reads 1 writes loops 292 / 696729
    Needed 4 reads 1 writes loops 1137 / 2786918
    Needed 4 reads 1 writes loops 1138 / 2786918
    Needed 4 reads 1 writes loops 1139 / 2786918
    Needed 4 reads 1 writes loops 1140 / 2786918
    Needed 4 reads 1 writes loops 293 / 696729
    Needed 4 reads 1 writes loops 1141 / 2786918
    Needed 4 reads 1 writes loops 1142 / 2786918
    Needed 4 reads 1 writes loops 1143 / 2786918
    Needed 4 reads 1 writes loops 1144 / 2786918
    Needed 4 reads 1 writes loops 294 / 696729
    Needed 4 reads 1 writes loops 1145 / 2786918
    Needed 4 reads 1 writes loops 1146 / 2786918
    Needed 4 reads 1 writes loops 1147 / 2786918
    Needed 4 reads 1 writes loops 1148 / 2786918
    Needed 4 reads 1 writes loops 295 / 696729
    Needed 4 reads 1 writes loops 1149 / 2786918
    Needed 4 reads 1 writes loops 1150 / 2786918
    Needed 4 reads 1 writes loops 1151 / 2786918
    Needed 4 reads 1 writes loops 1152 / 2786918
    Needed 4 reads 1 writes loops 296 / 696729
    Needed 4 reads 1 writes loops 1153 / 2786918
    Needed 4 reads 1 writes loops 1154 / 2786918
    Needed 4 reads 1 writes loops 1155 / 2786918
    Needed 4 reads 1 writes loops 1156 / 2786918
    Needed 4 reads 1 writes loops 297 / 696729
    Needed 4 reads 1 writes loops 1157 / 2786918
    Needed 4 reads 1 writes loops 1158 / 2786918
    Needed 4 reads 1 writes loops 1159 / 2786918
    Needed 4 reads 1 writes loops 1160 / 2786918
    Needed 4 reads 1 writes loops 298 / 696729
    Needed 4 reads 1 writes loops 1161 / 2786918
    Needed 4 reads 1 writes loops 1162 / 2786918
    Needed 4 reads 1 writes loops 1163 / 2786918
    Needed 4 reads 1 writes loops 1164 / 2786918
    Needed 4 reads 1 writes loops 299 / 696729
    Needed 4 reads 1 writes loops 1165 / 2786918
    Needed 4 reads 1 writes loops 1166 / 2786918
    Needed 4 reads 1 writes loops 1167 / 2786918
    Needed 4 reads 1 writes loops 1168 / 2786918
    Needed 4 reads 1 writes loops 300 / 696729
    Needed 4 reads 1 writes loops 1169 / 2786918
    Needed 4 reads 1 writes loops 1170 / 2786918
    Needed 4 reads 1 writes loops 1171 / 2786918
    Needed 4 reads 1 writes loops 1172 / 2786918
    Needed 4 reads 1 writes loops 301 / 696729
    Needed 4 reads 1 writes loops 1173 / 2786918
    Needed 4 reads 1 writes loops 1174 / 2786918
    Needed 4 reads 1 writes loops 1175 / 2786918
    Needed 4 reads 1 writes loops 1176 / 2786918
    Needed 4 reads 1 writes loops 302 / 696729
    Needed 4 reads 1 writes loops 1177 / 2786918
    Needed 4 reads 1 writes loops 1178 / 2786918
    Needed 4 reads 1 writes loops 1179 / 2786918
    Needed 4 reads 1 writes loops 1180 / 2786918
    Needed 4 reads 1 writes loops 303 / 696729
    Needed 4 reads 1 writes loops 1181 / 2786918
    Needed 4 reads 1 writes loops 1182 / 2786918
    Needed 4 reads 1 writes loops 1183 / 2786918
    Needed 4 reads 1 writes loops 1184 / 2786918
    Needed 4 reads 1 writes loops 304 / 696729
    Needed 4 reads 1 writes loops 1185 / 2786918
    Needed 4 reads 1 writes loops 1186 / 2786918
    Needed 4 reads 1 writes loops 1187 / 2786918
    Needed 4 reads 1 writes loops 1188 / 2786918
    Needed 4 reads 1 writes loops 305 / 696729
    Needed 4 reads 1 writes loops 1189 / 2786918
    Needed 4 reads 1 writes loops 1190 / 2786918
    Needed 4 reads 1 writes loops 1191 / 2786918
    Needed 4 reads 1 writes loops 1192 / 2786918
    Needed 4 reads 1 writes loops 306 / 696729
    Needed 4 reads 1 writes loops 1193 / 2786918
    Needed 4 reads 1 writes loops 1194 / 2786918
    Needed 4 reads 1 writes loops 1195 / 2786918
    Needed 4 reads 1 writes loops 1196 / 2786918
    Needed 4 reads 1 writes loops 307 / 696729
    Needed 4 reads 1 writes loops 1197 / 2786918
    Needed 4 reads 1 writes loops 1198 / 2786918
    Needed 4 reads 1 writes loops 1199 / 2786918
    Needed 4 reads 1 writes loops 1200 / 2786918
    Needed 4 reads 1 writes loops 308 / 696729
    Needed 4 reads 1 writes loops 1201 / 2786918
    Needed 4 reads 1 writes loops 1202 / 2786918
    Needed 4 reads 1 writes loops 1203 / 2786918
    Needed 4 reads 1 writes loops 1204 / 2786918
    Needed 4 reads 1 writes loops 309 / 696729
    Needed 4 reads 1 writes loops 1205 / 2786918
    Needed 4 reads 1 writes loops 1206 / 2786918
    Needed 4 reads 1 writes loops 1207 / 2786918
    Needed 4 reads 1 writes loops 1208 / 2786918
    Needed 4 reads 1 writes loops 310 / 696729
    Needed 4 reads 1 writes loops 1209 / 2786918
    Needed 4 reads 1 writes loops 1210 / 2786918
    Needed 4 reads 1 writes loops 1211 / 2786918
    Needed 4 reads 1 writes loops 1212 / 2786918
    Needed 4 reads 1 writes loops 311 / 696729
    Needed 4 reads 1 writes loops 1213 / 2786918
    Needed 4 reads 1 writes loops 1214 / 2786918
    Needed 4 reads 1 writes loops 1215 / 2786918
    Needed 4 reads 1 writes loops 1216 / 2786918
    Needed 4 reads 1 writes loops 312 / 696729
    Needed 4 reads 1 writes loops 1217 / 2786918
    Needed 4 reads 1 writes loops 1218 / 2786918
    Needed 4 reads 1 writes loops 1219 / 2786918
    Needed 4 reads 1 writes loops 1220 / 2786918
    Needed 4 reads 1 writes loops 313 / 696729
    Needed 4 reads 1 writes loops 1221 / 2786918
    Needed 4 reads 1 writes loops 1222 / 2786918
    Needed 4 reads 1 writes loops 1223 / 2786918
    Needed 4 reads 1 writes loops 1224 / 2786918
    Needed 4 reads 1 writes loops 314 / 696729
    Needed 4 reads 1 writes loops 1225 / 2786918
    Needed 4 reads 1 writes loops 1226 / 2786918
    Needed 4 reads 1 writes loops 1227 / 2786918
    Needed 4 reads 1 writes loops 1228 / 2786918
    Needed 4 reads 1 writes loops 315 / 696729
    Needed 4 reads 1 writes loops 1229 / 2786918
    Needed 4 reads 1 writes loops 1230 / 2786918
    Needed 4 reads 1 writes loops 1231 / 2786918
    Needed 4 reads 1 writes loops 1232 / 2786918
    Needed 4 reads 1 writes loops 316 / 696729
    Needed 4 reads 1 writes loops 1233 / 2786918
    Needed 4 reads 1 writes loops 1234 / 2786918
    Needed 4 reads 1 writes loops 1235 / 2786918
    timeout, RX/TX: 9920/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9920 (0x26c0).
    Original sample:
    00002690: e7 8c c9 46 59 15 42 84  a3 22 0f b8 19 a9 a7 60   ...FY.B..".....`
    000026a0: dc cf a0 47 e8 b1 38 78  94 b7 fe 61 4d 30 64 74   ...G..8x...aM0dt
    000026b0: 97 d4 cb 67 13 1f 83 a2  88 1f 2b b3 b8 67 90 04   ...g......+..g..
    000026c0: 5d 34 09 1b c5 fd 10 00  fc 46 51 54 3b 92 70 1b   ]4.......FQT;.p.
    000026d0: b6 a3 43 44 f3 2f df af  09 f8 33 dc c0 2e 7f 6e   ..CD./....3....n
    000026e0: a8 d0 95 3a e0 e0 42 a5  eb d0 a7 f6 11 22 36 2f   ...:..B......"6/
    Received sample:
    000026c0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    000026d0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    000026e0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 695 / 2786918
    spend 251 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 6949920 tx: 6950000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    Needed 4 reads 1 writes loops 1236 / 2786918
    Needed 4 reads 1 writes loops 317 / 696729
    Needed 4 reads 1 writes loops 1237 / 2786918
    Needed 4 reads 1 writes loops 1238 / 2786918
    Needed 4 reads 1 writes loops 1239 / 2786918
    Needed 4 reads 1 writes loops 1240 / 2786918
    Needed 4 reads 1 writes loops 318 / 696729
    Needed 4 reads 1 writes loops 1241 / 2786918
    Needed 4 reads 1 writes loops 1242 / 2786918
    Needed 4 reads 1 writes loops 1243 / 2786918
    Needed 4 reads 1 writes loops 1244 / 2786918
    Needed 4 reads 1 writes loops 319 / 696729
    Needed 4 reads 1 writes loops 1245 / 2786918
    Needed 4 reads 1 writes loops 1246 / 2786918
    Needed 4 reads 1 writes loops 1247 / 2786918
    Needed 4 reads 1 writes loops 1248 / 2786918
    Needed 4 reads 1 writes loops 320 / 696729
    Needed 4 reads 1 writes loops 1249 / 2786918
    Needed 4 reads 1 writes loops 1250 / 2786918
    Needed 4 reads 1 writes loops 1251 / 2786918
    Needed 4 reads 1 writes loops 1252 / 2786918
    Needed 4 reads 1 writes loops 321 / 696729
    Needed 4 reads 1 writes loops 1253 / 2786918
    Needed 4 reads 1 writes loops 1254 / 2786918
    Needed 4 reads 1 writes loops 1255 / 2786918
    Needed 4 reads 1 writes loops 1256 / 2786918
    Needed 4 reads 1 writes loops 322 / 696729
    Needed 4 reads 1 writes loops 1257 / 2786918
    Needed 4 reads 1 writes loops 1258 / 2786918
    Needed 4 reads 1 writes loops 1259 / 2786918
    Needed 4 reads 1 writes loops 1260 / 2786918
    Needed 4 reads 1 writes loops 323 / 696729
    Needed 4 reads 1 writes loops 1261 / 2786918
    Needed 4 reads 1 writes loops 1262 / 2786918
    Needed 4 reads 1 writes loops 1263 / 2786918
    Needed 4 reads 1 writes loops 1264 / 2786918
    Needed 4 reads 1 writes loops 324 / 696729
    Needed 4 reads 1 writes loops 1265 / 2786918
    Needed 4 reads 1 writes loops 1266 / 2786918
    Needed 4 reads 1 writes loops 1267 / 2786918
    Needed 4 reads 1 writes loops 325 / 696729
    Needed 4 reads 1 writes loops 1268 / 2786918
    Needed 4 reads 1 writes loops 1269 / 2786918
    Needed 4 reads 1 writes loops 1270 / 2786918
    Needed 4 reads 1 writes loops 1271 / 2786918
    Needed 4 reads 1 writes loops 326 / 696729
    Needed 4 reads 1 writes loops 1272 / 2786918
    Needed 4 reads 1 writes loops 1273 / 2786918
    Needed 4 reads 1 writes loops 1274 / 2786918
    Needed 4 reads 1 writes loops 1275 / 2786918
    Needed 4 reads 1 writes loops 327 / 696729
    Needed 4 reads 1 writes loops 1276 / 2786918
    Needed 4 reads 1 writes loops 1277 / 2786918
    Needed 4 reads 1 writes loops 1278 / 2786918
    Needed 4 reads 1 writes loops 1279 / 2786918
    Needed 4 reads 1 writes loops 328 / 696729
    Needed 4 reads 1 writes loops 1280 / 2786918
    Needed 4 reads 1 writes loops 1281 / 2786918
    Needed 4 reads 1 writes loops 1282 / 2786918
    Needed 4 reads 1 writes loops 1283 / 2786918
    Needed 4 reads 1 writes loops 329 / 696729
    Needed 4 reads 1 writes loops 1284 / 2786918
    Needed 4 reads 1 writes loops 1285 / 2786918
    Needed 4 reads 1 writes loops 1286 / 2786918
    Needed 4 reads 1 writes loops 1287 / 2786918
    Needed 4 reads 1 writes loops 330 / 696729
    Needed 4 reads 1 writes loops 1288 / 2786918
    Needed 4 reads 1 writes loops 1289 / 2786918
    Needed 4 reads 1 writes loops 1290 / 2786918
    Needed 4 reads 1 writes loops 1291 / 2786918
    Needed 4 reads 1 writes loops 331 / 696729
    Needed 4 reads 1 writes loops 1292 / 2786918
    Needed 4 reads 1 writes loops 1293 / 2786918
    Needed 4 reads 1 writes loops 1294 / 2786918
    Needed 4 reads 1 writes loops 1295 / 2786918
    Needed 4 reads 1 writes loops 332 / 696729
    Needed 4 reads 1 writes loops 1296 / 2786918
    Needed 4 reads 1 writes loops 1297 / 2786918
    Needed 4 reads 1 writes loops 1298 / 2786918
    Needed 4 reads 1 writes loops 1299 / 2786918
    Needed 4 reads 1 writes loops 333 / 696729
    Needed 4 reads 1 writes loops 1300 / 2786918
    [  316.539827] EXT4-fs (mmcblk0p4): error count since last fsck: 81
    [  316.546031] EXT4-fs (mmcblk0p4): initial error at time 1709059948: ext4_mb_mark_diskspace_used:4034
    [  316.555170] EXT4-fs (mmcblk0p4): last error at time 1709054776: ext4_mb_generate_buddy:1213
    Needed 4 reads 1 writes loops 1301 / 2786918
    Needed 4 reads 1 writes loops 1302 / 2786918
    Needed 4 reads 1 writes loops 1303 / 2786918
    Needed 4 reads 1 writes loops 1304 / 2786918
    Needed 4 reads 1 writes loops 1305 / 2786918
    Needed 4 reads 1 writes loops 1306 / 2786918
    Needed 4 reads 1 writes loops 1307 / 2786918
    Needed 4 reads 1 writes loops 1308 / 2786918
    Needed 4 reads 1 writes loops 1309 / 2786918
    Needed 4 reads 1 writes loops 1310 / 2786918
    Needed 4 reads 1 writes loops 1311 / 2786918
    Needed 4 reads 1 writes loops 1312 / 2786918
    Needed 4 reads 1 writes loops 1313 / 2786918
    Needed 4 reads 1 writes loops 1314 / 2786918
    Needed 4 reads 1 writes loops 1315 / 2786918
    Needed 4 reads 1 writes loops 1316 / 2786918
    Needed 4 reads 1 writes loops 1317 / 2786918
    Needed 4 reads 1 writes loops 1318 / 2786918
    Needed 4 reads 1 writes loops 1319 / 2786918
    Needed 4 reads 1 writes loops 1320 / 2786918
    Needed 4 reads 1 writes loops 1321 / 2786918
    Needed 4 reads 1 writes loops 1322 / 2786918
    Needed 4 reads 1 writes loops 1323 / 2786918
    Needed 4 reads 1 writes loops 1324 / 2786918
    Needed 4 reads 1 writes loops 1325 / 2786918
    Needed 4 reads 1 writes loops 1326 / 2786918
    Needed 4 reads 1 writes loops 1327 / 2786918
    Needed 4 reads 1 writes loops 1328 / 2786918
    Needed 4 reads 1 writes loops 1329 / 2786918
    Needed 4 reads 1 writes loops 1330 / 2786918
    Needed 4 reads 1 writes loops 1331 / 2786918
    Needed 4 reads 1 writes loops 1332 / 2786918
    Needed 4 reads 1 writes loops 1333 / 2786918
    Needed 4 reads 1 writes loops 1334 / 2786918
    Needed 4 reads 1 writes loops 1335 / 2786918
    Needed 4 reads 1 writes loops 1336 / 2786918
    Needed 4 reads 1 writes loops 1337 / 2786918
    Needed 4 reads 1 writes loops 1338 / 2786918
    Needed 4 reads 1 writes loops 1339 / 2786918
    Needed 4 reads 1 writes loops 1340 / 2786918
    Needed 4 reads 1 writes loops 1341 / 2786918
    Needed 4 reads 1 writes loops 1342 / 2786918
    Needed 4 reads 1 writes loops 1343 / 2786918
    Needed 4 reads 1 writes loops 1344 / 2786918
    Needed 4 reads 1 writes loops 1345 / 2786918
    Needed 4 reads 1 writes loops 1346 / 2786918
    Needed 4 reads 1 writes loops 1347 / 2786918
    Needed 4 reads 1 writes loops 1348 / 2786918
    Needed 4 reads 1 writes loops 1349 / 2786918
    Needed 4 reads 1 writes loops 1350 / 2786918
    Needed 4 reads 1 writes loops 1351 / 2786918
    Needed 4 reads 1 writes loops 1352 / 2786918
    Needed 4 reads 1 writes loops 1353 / 2786918
    Needed 4 reads 1 writes loops 1354 / 2786918
    Needed 4 reads 1 writes loops 1355 / 2786918
    Needed 4 reads 1 writes loops 1356 / 2786918
    Needed 4 reads 1 writes loops 1357 / 2786918
    Needed 4 reads 1 writes loops 1358 / 2786918
    Needed 4 reads 1 writes loops 1359 / 2786918
    Needed 4 reads 1 writes loops 1360 / 2786918
    Needed 4 reads 1 writes loops 1361 / 2786918
    Needed 4 reads 1 writes loops 1362 / 2786918
    Needed 4 reads 1 writes loops 1363 / 2786918
    Needed 4 reads 1 writes loops 1364 / 2786918
    Needed 4 reads 1 writes loops 1365 / 2786918
    Needed 4 reads 1 writes loops 1366 / 2786918
    Needed 4 reads 1 writes loops 1367 / 2786918
    Needed 4 reads 1 writes loops 1368 / 2786918
    Needed 4 reads 1 writes loops 1369 / 2786918
    Needed 4 reads 1 writes loops 1370 / 2786918
    Needed 4 reads 1 writes loops 1371 / 2786918
    Needed 4 reads 1 writes loops 1372 / 2786918
    Needed 4 reads 1 writes loops 1373 / 2786918
    Needed 4 reads 1 writes loops 1374 / 2786918
    Needed 4 reads 1 writes loops 1375 / 2786918
    Needed 4 reads 1 writes loops 1376 / 2786918
    Needed 4 reads 1 writes loops 1377 / 2786918
    Needed 4 reads 1 writes loops 1378 / 2786918
    Needed 4 reads 1 writes loops 1379 / 2786918
    Needed 4 reads 1 writes loops 1380 / 2786918
    Needed 4 reads 1 writes loops 1381 / 2786918
    Needed 4 reads 1 writes loops 1382 / 2786918
    Needed 4 reads 1 writes loops 1383 / 2786918
    Needed 4 reads 1 writes loops 1384 / 2786918
    Needed 4 reads 1 writes loops 1385 / 2786918
    Needed 4 reads 1 writes loops 1386 / 2786918
    Needed 4 reads 1 writes loops 1387 / 2786918
    Needed 4 reads 1 writes loops 1388 / 2786918
    Needed 4 reads 1 writes loops 1389 / 2786918
    Needed 4 reads 1 writes loops 1390 / 2786918
    Needed 4 reads 1 writes loops 1391 / 2786918
    Needed 4 reads 1 writes loops 1392 / 2786918
    Needed 4 reads 1 writes loops 1393 / 2786918
    Needed 4 reads 1 writes loops 1394 / 2786918
    Needed 4 reads 1 writes loops 1395 / 2786918
    Needed 4 reads 1 writes loops 1396 / 2786918
    Needed 4 reads 1 writes loops 1397 / 2786918
    Needed 4 reads 1 writes loops 1398 / 2786918
    Needed 4 reads 1 writes loops 1399 / 2786918
    Needed 4 reads 1 writes loops 1400 / 2786918
    Needed 4 reads 1 writes loops 1401 / 2786918
    Needed 4 reads 1 writes loops 1402 / 2786918
    Needed 4 reads 1 writes loops 1403 / 2786918
    Needed 4 reads 1 writes loops 1404 / 2786918
    Needed 4 reads 1 writes loops 1405 / 2786918
    Needed 4 reads 1 writes loops 1406 / 2786918
    Needed 4 reads 1 writes loops 1407 / 2786918
    Needed 4 reads 1 writes loops 1408 / 2786918
    Needed 4 reads 1 writes loops 1409 / 2786918
    Needed 4 reads 1 writes loops 1410 / 2786918
    Needed 4 reads 1 writes loops 1411 / 2786918
    Needed 4 reads 1 writes loops 1412 / 2786918
    Needed 4 reads 1 writes loops 1413 / 2786918
    Needed 4 reads 1 writes loops 1414 / 2786918
    Needed 4 reads 1 writes loops 1415 / 2786918
    Needed 4 reads 1 writes loops 1416 / 2786918
    Needed 4 reads 1 writes loops 1417 / 2786918
    Needed 4 reads 1 writes loops 1418 / 2786918
    Needed 4 reads 1 writes loops 1419 / 2786918
    Needed 4 reads 1 writes loops 1420 / 2786918
    Needed 4 reads 1 writes loops 1421 / 2786918
    Needed 4 reads 1 writes loops 1422 / 2786918
    Needed 4 reads 1 writes loops 1423 / 2786918
    Needed 4 reads 1 writes loops 1424 / 2786918
    Needed 4 reads 1 writes loops 1425 / 2786918
    Needed 4 reads 1 writes loops 1426 / 2786918
    Needed 4 reads 1 writes loops 1427 / 2786918
    Needed 4 reads 1 writes loops 1428 / 2786918
    Needed 4 reads 1 writes loops 1429 / 2786918
    Needed 4 reads 1 writes loops 1430 / 2786918
    Needed 4 reads 1 writes loops 1431 / 2786918
    Needed 4 reads 1 writes loops 1432 / 2786918
    Needed 4 reads 1 writes loops 1433 / 2786918
    Needed 4 reads 1 writes loops 1434 / 2786918
    Needed 4 reads 1 writes loops 1435 / 2786918
    Needed 4 reads 1 writes loops 1436 / 2786918
    Needed 4 reads 1 writes loops 1437 / 2786918
    Needed 4 reads 1 writes loops 1438 / 2786918
    Needed 4 reads 1 writes loops 1439 / 2786918
    Needed 4 reads 1 writes loops 1440 / 2786918
    Needed 4 reads 1 writes loops 1441 / 2786918
    Needed 4 reads 1 writes loops 1442 / 2786918
    Needed 4 reads 1 writes loops 1443 / 2786918
    Needed 4 reads 1 writes loops 1444 / 2786918
    Needed 4 reads 1 writes loops 1445 / 2786918
    Needed 4 reads 1 writes loops 1446 / 2786918
    Needed 4 reads 1 writes loops 1447 / 2786918
    Needed 4 reads 1 writes loops 1448 / 2786918
    Needed 4 reads 1 writes loops 1449 / 2786918
    Needed 4 reads 1 writes loops 1450 / 2786918
    Needed 4 reads 1 writes loops 1451 / 2786918
    Needed 4 reads 1 writes loops 1452 / 2786918
    Needed 4 reads 1 writes loops 1453 / 2786918
    Needed 4 reads 1 writes loops 1454 / 2786918
    Needed 4 reads 1 writes loops 1455 / 2786918
    Needed 4 reads 1 writes loops 1456 / 2786918
    Needed 4 reads 1 writes loops 1457 / 2786918
    Needed 4 reads 1 writes loops 1458 / 2786918
    Needed 4 reads 1 writes loops 1459 / 2786918
    Needed 4 reads 1 writes loops 1460 / 2786918
    Needed 4 reads 1 writes loops 1461 / 2786918
    Needed 4 reads 1 writes loops 1462 / 2786918
    Needed 4 reads 1 writes loops 1463 / 2786918
    Needed 4 reads 1 writes loops 1464 / 2786918
    Needed 4 reads 1 writes loops 1465 / 2786918
    Needed 4 reads 1 writes loops 1466 / 2786918
    Needed 4 reads 1 writes loops 1467 / 2786918
    Needed 4 reads 1 writes loops 1468 / 2786918
    Needed 4 reads 1 writes loops 1469 / 2786918
    Needed 4 reads 1 writes loops 1470 / 2786918
    Needed 4 reads 1 writes loops 1471 / 2786918
    Needed 4 reads 1 writes loops 1472 / 2786918
    Needed 4 reads 1 writes loops 1473 / 2786918
    Needed 4 reads 1 writes loops 1474 / 2786918
    Needed 4 reads 1 writes loops 1475 / 2786918
    Needed 4 reads 1 writes loops 1476 / 2786918
    Needed 4 reads 1 writes loops 1477 / 2786918
    Needed 4 reads 1 writes loops 1478 / 2786918
    Needed 4 reads 1 writes loops 1479 / 2786918
    Needed 4 reads 1 writes loops 1480 / 2786918
    Needed 4 reads 1 writes loops 1481 / 2786918
    Needed 4 reads 1 writes loops 1482 / 2786918
    Needed 4 reads 1 writes loops 1483 / 2786918
    Needed 4 reads 1 writes loops 1484 / 2786918
    Needed 4 reads 1 writes loops 1485 / 2786918
    Needed 4 reads 1 writes loops 1486 / 2786918
    Needed 4 reads 1 writes loops 1487 / 2786918
    Needed 4 reads 1 writes loops 1488 / 2786918
    Needed 4 reads 1 writes loops 1489 / 2786918
    Needed 4 reads 1 writes loops 1490 / 2786918
    Needed 4 reads 1 writes loops 1491 / 2786918
    Needed 4 reads 1 writes loops 1492 / 2786918
    Needed 4 reads 1 writes loops 1493 / 2786918
    Needed 4 reads 1 writes loops 1494 / 2786918
    Needed 4 reads 1 writes loops 1495 / 2786918
    Needed 4 reads 1 writes loops 1496 / 2786918
    Needed 4 reads 1 writes loops 1497 / 2786918
    Needed 4 reads 1 writes loops 1498 / 2786918
    Needed 4 reads 1 writes loops 1499 / 2786918
    Needed 4 reads 1 writes loops 1500 / 2786918
    Needed 4 reads 1 writes loops 1501 / 2786918
    Needed 4 reads 1 writes loops 1502 / 2786918
    Needed 4 reads 1 writes loops 1503 / 2786918
    Needed 4 reads 1 writes loops 1504 / 2786918
    Needed 4 reads 1 writes loops 1505 / 2786918
    Needed 4 reads 1 writes loops 1506 / 2786918
    Needed 4 reads 1 writes loops 1507 / 2786918
    Needed 4 reads 1 writes loops 1508 / 2786918
    Needed 4 reads 1 writes loops 1509 / 2786918
    Needed 4 reads 1 writes loops 1510 / 2786918
    Needed 4 reads 1 writes loops 1511 / 2786918
    Needed 4 reads 1 writes loops 1512 / 2786918
    Needed 4 reads 1 writes loops 1513 / 2786918
    Needed 4 reads 1 writes loops 1514 / 2786918
    Needed 4 reads 1 writes loops 1515 / 2786918
    Needed 4 reads 1 writes loops 1516 / 2786918
    Needed 4 reads 1 writes loops 1517 / 2786918
    Needed 4 reads 1 writes loops 1518 / 2786918
    Needed 4 reads 1 writes loops 1519 / 2786918
    Needed 4 reads 1 writes loops 1520 / 2786918
    Needed 4 reads 1 writes loops 1521 / 2786918
    Needed 4 reads 1 writes loops 1522 / 2786918
    Needed 4 reads 1 writes loops 1523 / 2786918
    Needed 4 reads 1 writes loops 1524 / 2786918
    Needed 4 reads 1 writes loops 1525 / 2786918
    Needed 4 reads 1 writes loops 1526 / 2786918
    Needed 4 reads 1 writes loops 1527 / 2786918
    Needed 4 reads 1 writes loops 1528 / 2786918
    Needed 4 reads 1 writes loops 1529 / 2786918
    Needed 4 reads 1 writes loops 1530 / 2786918
    Needed 4 reads 1 writes loops 1531 / 2786918
    Needed 4 reads 1 writes loops 1532 / 2786918
    Needed 4 reads 1 writes loops 1533 / 2786918
    Needed 4 reads 1 writes loops 1534 / 2786918
    Needed 4 reads 1 writes loops 1535 / 2786918
    Needed 4 reads 1 writes loops 1536 / 2786918
    Needed 4 reads 1 writes loops 1537 / 2786918
    Needed 4 reads 1 writes loops 1538 / 2786918
    Needed 4 reads 1 writes loops 1539 / 2786918
    Needed 4 reads 1 writes loops 1540 / 2786918
    Needed 4 reads 1 writes loops 1541 / 2786918
    Needed 4 reads 1 writes loops 1542 / 2786918
    Needed 4 reads 1 writes loops 1543 / 2786918
    Needed 4 reads 1 writes loops 1544 / 2786918
    Needed 4 reads 1 writes loops 1545 / 2786918
    Needed 4 reads 1 writes loops 1546 / 2786918
    Needed 4 reads 1 writes loops 1547 / 2786918
    Needed 4 reads 1 writes loops 1548 / 2786918
    Needed 4 reads 1 writes loops 1549 / 2786918
    Needed 4 reads 1 writes loops 1550 / 2786918
    Needed 4 reads 1 writes loops 1551 / 2786918
    Needed 4 reads 1 writes loops 1552 / 2786918
    Needed 4 reads 1 writes loops 1553 / 2786918
    Needed 4 reads 1 writes loops 1554 / 2786918
    Needed 4 reads 1 writes loops 1555 / 2786918
    Needed 4 reads 1 writes loops 1556 / 2786918
    Needed 4 reads 1 writes loops 1557 / 2786918
    Needed 4 reads 1 writes loops 1558 / 2786918
    Needed 4 reads 1 writes loops 1559 / 2786918
    Needed 4 reads 1 writes loops 1560 / 2786918
    Needed 4 reads 1 writes loops 1561 / 2786918
    Needed 4 reads 1 writes loops 1562 / 2786918
    Needed 4 reads 1 writes loops 1563 / 2786918
    Needed 4 reads 1 writes loops 1564 / 2786918
    Needed 4 reads 1 writes loops 1565 / 2786918
    timeout, RX/TX: 9926/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9926 (0x26c6).
    Original sample:
    Received sample:
    000026c0: 5d 34 09 1b c5 fd 00 00  00 00 00 00 00 00 00 00   ]4..............
    spend 334 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 10769926 tx: 10770000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    timeout, RX/TX: 9923/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9923 (0x26c3).
    Original sample:
    Received sample:
    000026c0: 5d 34 09 00 00 00 00 00  00 00 00 00 00 00 00 00   ]4..............
    spend 329 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 10499923 tx: 10500000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    Needed 4 reads 1 writes loops 1566 / 2786918
    Needed 4 reads 1 writes loops 1567 / 2786918
    Needed 4 reads 1 writes loops 1568 / 2786918
    Needed 4 reads 1 writes loops 1569 / 2786918
    Needed 4 reads 1 writes loops 1570 / 2786918
    Needed 4 reads 1 writes loops 1571 / 2786918
    Needed 4 reads 1 writes loops 1572 / 2786918
    Needed 4 reads 1 writes loops 1573 / 2786918
    Needed 4 reads 1 writes loops 1574 / 2786918
    Needed 4 reads 1 writes loops 1575 / 2786918
    Needed 4 reads 1 writes loops 1576 / 2786918
    Needed 4 reads 1 writes loops 1577 / 2786918
    Needed 4 reads 1 writes loops 1578 / 2786918
    Needed 4 reads 1 writes loops 1579 / 2786918
    Needed 4 reads 1 writes loops 1580 / 2786918
    Needed 4 reads 1 writes loops 1581 / 2786918
    Needed 4 reads 1 writes loops 1582 / 2786918
    Needed 4 reads 1 writes loops 1583 / 2786918
    Needed 4 reads 1 writes loops 1584 / 2786918
    Needed 4 reads 1 writes loops 1585 / 2786918
    Needed 4 reads 1 writes loops 1586 / 2786918
    Needed 4 reads 1 writes loops 1587 / 2786918
    Needed 4 reads 1 writes loops 1588 / 2786918
    Needed 4 reads 1 writes loops 1589 / 2786918
    Needed 4 reads 1 writes loops 1590 / 2786918
    Needed 4 reads 1 writes loops 1591 / 2786918
    Needed 4 reads 1 writes loops 1592 / 2786918
    Needed 4 reads 1 writes loops 1593 / 2786918
    Needed 4 reads 1 writes loops 1594 / 2786918
    Needed 4 reads 1 writes loops 1595 / 2786918
    Needed 4 reads 1 writes loops 1596 / 2786918
    Needed 4 reads 1 writes loops 1597 / 2786918
    Needed 4 reads 1 writes loops 1598 / 2786918
    Needed 4 reads 1 writes loops 1599 / 2786918
    Needed 4 reads 1 writes loops 1600 / 2786918
    Needed 4 reads 1 writes loops 1601 / 2786918
    Needed 4 reads 1 writes loops 1602 / 2786918
    Needed 4 reads 1 writes loops 1603 / 2786918
    Needed 4 reads 1 writes loops 1604 / 2786918
    Needed 4 reads 1 writes loops 1605 / 2786918
    Needed 4 reads 1 writes loops 1606 / 2786918
    Needed 4 reads 1 writes loops 1607 / 2786918
    Needed 4 reads 1 writes loops 1608 / 2786918
    Needed 4 reads 1 writes loops 1609 / 2786918
    Needed 4 reads 1 writes loops 1610 / 2786918
    Needed 4 reads 1 writes loops 1611 / 2786918
    Needed 4 reads 1 writes loops 1612 / 2786918
    Needed 4 reads 1 writes loops 1613 / 2786918
    Needed 4 reads 1 writes loops 1614 / 2786918
    Needed 4 reads 1 writes loops 1615 / 2786918
    Needed 4 reads 1 writes loops 1616 / 2786918
    Needed 4 reads 1 writes loops 1617 / 2786918
    Needed 4 reads 1 writes loops 1618 / 2786918
    Needed 4 reads 1 writes loops 1619 / 2786918
    Needed 4 reads 1 writes loops 1620 / 2786918
    Needed 4 reads 1 writes loops 1621 / 2786918
    Needed 4 reads 1 writes loops 1622 / 2786918
    Needed 4 reads 1 writes loops 1623 / 2786918
    Needed 4 reads 1 writes loops 1624 / 2786918
    Needed 4 reads 1 writes loops 1625 / 2786918
    Needed 4 reads 1 writes loops 1626 / 2786918
    Needed 4 reads 1 writes loops 1627 / 2786918
    Needed 4 reads 1 writes loops 1628 / 2786918
    Needed 4 reads 1 writes loops 1629 / 2786918
    Needed 4 reads 1 writes loops 1630 / 2786918
    Needed 4 reads 1 writes loops 1631 / 2786918
    Needed 4 reads 1 writes loops 1632 / 2786918
    Needed 4 reads 1 writes loops 1633 / 2786918
    Needed 4 reads 1 writes loops 1634 / 2786918
    Needed 4 reads 1 writes loops 1635 / 2786918
    Needed 4 reads 1 writes loops 1636 / 2786918
    Needed 4 reads 1 writes loops 1637 / 2786918
    Needed 4 reads 1 writes loops 1638 / 2786918
    Needed 4 reads 1 writes loops 1639 / 2786918
    Needed 4 reads 1 writes loops 1640 / 2786918
    Needed 4 reads 1 writes loops 1641 / 2786918
    Needed 4 reads 1 writes loops 1642 / 2786918
    Needed 4 reads 1 writes loops 1643 / 2786918
    Needed 4 reads 1 writes loops 1644 / 2786918
    Needed 4 reads 1 writes loops 1645 / 2786918
    Needed 4 reads 1 writes loops 1646 / 2786918
    Needed 4 reads 1 writes loops 1647 / 2786918
    Needed 4 reads 1 writes loops 1648 / 2786918
    Needed 4 reads 1 writes loops 1649 / 2786918
    Needed 4 reads 1 writes loops 1650 / 2786918
    Needed 4 reads 1 writes loops 1651 / 2786918
    Needed 4 reads 1 writes loops 1652 / 2786918
    Needed 4 reads 1 writes loops 1653 / 2786918
    Needed 4 reads 1 writes loops 1654 / 2786918
    Needed 4 reads 1 writes loops 1655 / 2786918
    Needed 4 reads 1 writes loops 1656 / 2786918
    Needed 4 reads 1 writes loops 1657 / 2786918
    Needed 4 reads 1 writes loops 1658 / 2786918
    Needed 4 reads 1 writes loops 1659 / 2786918
    Needed 4 reads 1 writes loops 1660 / 2786918
    Needed 4 reads 1 writes loops 1661 / 2786918
    Needed 4 reads 1 writes loops 1662 / 2786918
    Needed 4 reads 1 writes loops 1663 / 2786918
    Needed 4 reads 1 writes loops 1664 / 2786918
    Needed 4 reads 1 writes loops 1665 / 2786918
    Needed 4 reads 1 writes loops 1666 / 2786918
    Needed 4 reads 1 writes loops 1667 / 2786918
    Needed 4 reads 1 writes loops 1668 / 2786918
    Needed 4 reads 1 writes loops 1669 / 2786918
    Needed 4 reads 1 writes loops 1670 / 2786918
    Needed 4 reads 1 writes loops 1671 / 2786918
    Needed 4 reads 1 writes loops 1672 / 2786918
    Needed 4 reads 1 writes loops 1673 / 2786918
    Needed 4 reads 1 writes loops 1674 / 2786918
    Needed 4 reads 1 writes loops 1675 / 2786918
    Needed 4 reads 1 writes loops 1676 / 2786918
    Needed 4 reads 1 writes loops 1677 / 2786918
    Needed 4 reads 1 writes loops 1678 / 2786918
    Needed 4 reads 1 writes loops 1679 / 2786918
    Needed 4 reads 1 writes loops 1680 / 2786918
    Needed 4 reads 1 writes loops 1681 / 2786918
    Needed 4 reads 1 writes loops 1682 / 2786918
    Needed 4 reads 1 writes loops 1683 / 2786918
    Needed 4 reads 1 writes loops 1684 / 2786918
    Needed 4 reads 1 writes loops 1685 / 2786918
    Needed 4 reads 1 writes loops 1686 / 2786918
    Needed 4 reads 1 writes loops 1687 / 2786918
    Needed 4 reads 1 writes loops 1688 / 2786918
    Needed 4 reads 1 writes loops 1689 / 2786918
    Needed 4 reads 1 writes loops 1690 / 2786918
    Needed 4 reads 1 writes loops 1691 / 2786918
    Needed 4 reads 1 writes loops 1692 / 2786918
    Needed 4 reads 1 writes loops 1693 / 2786918
    Needed 4 reads 1 writes loops 1694 / 2786918
    Needed 4 reads 1 writes loops 1695 / 2786918
    Needed 4 reads 1 writes loops 1696 / 2786918
    Needed 4 reads 1 writes loops 1697 / 2786918
    Needed 4 reads 1 writes loops 1698 / 2786918
    Needed 4 reads 1 writes loops 1699 / 2786918
    Needed 4 reads 1 writes loops 1700 / 2786918
    Needed 4 reads 1 writes loops 1701 / 2786918
    Needed 4 reads 1 writes loops 1702 / 2786918
    Needed 4 reads 1 writes loops 1703 / 2786918
    Needed 4 reads 1 writes loops 1704 / 2786918
    Needed 4 reads 1 writes loops 1705 / 2786918
    Needed 4 reads 1 writes loops 1706 / 2786918
    Needed 4 reads 1 writes loops 1707 / 2786918
    Needed 4 reads 1 writes loops 1708 / 2786918
    Needed 4 reads 1 writes loops 1709 / 2786918
    Needed 4 reads 1 writes loops 1710 / 2786918
    Needed 4 reads 1 writes loops 1711 / 2786918
    Needed 4 reads 1 writes loops 1712 / 2786918
    Needed 4 reads 1 writes loops 1713 / 2786918
    Needed 4 reads 1 writes loops 1714 / 2786918
    Needed 4 reads 1 writes loops 1715 / 2786918
    Needed 4 reads 1 writes loops 1716 / 2786918
    Needed 4 reads 1 writes loops 1717 / 2786918
    Needed 4 reads 1 writes loops 1718 / 2786918
    Needed 4 reads 1 writes loops 1719 / 2786918
    Needed 4 reads 1 writes loops 1720 / 2786918
    Needed 4 reads 1 writes loops 1721 / 2786918
    Needed 4 reads 1 writes loops 1722 / 2786918
    Needed 4 reads 1 writes loops 1723 / 2786918
    Needed 4 reads 1 writes loops 1724 / 2786918
    Needed 4 reads 1 writes loops 1725 / 2786918
    Needed 4 reads 1 writes loops 1726 / 2786918
    Needed 4 reads 1 writes loops 1727 / 2786918
    Needed 4 reads 1 writes loops 1728 / 2786918
    Needed 4 reads 1 writes loops 1729 / 2786918
    Needed 4 reads 1 writes loops 1730 / 2786918
    Needed 4 reads 1 writes loops 1731 / 2786918
    Needed 4 reads 1 writes loops 1732 / 2786918
    Needed 4 reads 1 writes loops 1733 / 2786918
    Needed 4 reads 1 writes loops 1734 / 2786918
    Needed 4 reads 1 writes loops 1735 / 2786918
    Needed 4 reads 1 writes loops 1736 / 2786918
    Needed 4 reads 1 writes loops 1737 / 2786918
    Needed 4 reads 1 writes loops 1738 / 2786918
    Needed 4 reads 1 writes loops 1739 / 2786918
    Needed 4 reads 1 writes loops 1740 / 2786918
    Needed 4 reads 1 writes loops 1741 / 2786918
    Needed 4 reads 1 writes loops 1742 / 2786918
    Needed 4 reads 1 writes loops 1743 / 2786918
    Needed 4 reads 1 writes loops 1744 / 2786918
    Needed 4 reads 1 writes loops 1745 / 2786918
    Needed 4 reads 1 writes loops 1746 / 2786918
    Needed 4 reads 1 writes loops 1747 / 2786918
    Needed 4 reads 1 writes loops 1748 / 2786918
    Needed 4 reads 1 writes loops 1749 / 2786918
    Needed 4 reads 1 writes loops 1750 / 2786918
    Needed 4 reads 1 writes loops 1751 / 2786918
    Needed 4 reads 1 writes loops 1752 / 2786918
    Needed 4 reads 1 writes loops 1753 / 2786918
    Needed 4 reads 1 writes loops 1754 / 2786918
    Needed 4 reads 1 writes loops 1755 / 2786918
    Needed 4 reads 1 writes loops 1756 / 2786918
    Needed 4 reads 1 writes loops 1757 / 2786918
    Needed 4 reads 1 writes loops 1758 / 2786918
    Needed 4 reads 1 writes loops 1759 / 2786918
    Needed 4 reads 1 writes loops 1760 / 2786918
    Needed 4 reads 1 writes loops 1761 / 2786918
    Needed 4 reads 1 writes loops 1762 / 2786918
    Needed 4 reads 1 writes loops 1763 / 2786918
    Needed 4 reads 1 writes loops 1764 / 2786918
    timeout, RX/TX: 9984/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9984 (0x2700).
    Original sample:
    000026f0: 9a 42 79 c9 33 6d 4b 06  44 c1 39 cd 2f 2d 83 5b   .By.3mK.D.9./-.[
    00002700: 0b 57 0e 0f 8f 7c 67 e7  33 2a ac 9c b7 c1 9e 03   .W...|g.3*......
    Received sample:
    00002700: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
    loops 334 / 696729
    spend 390 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 3339984 tx: 3340000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    Needed 4 reads 1 writes loops 1765 / 2786918
    Needed 4 reads 1 writes loops 1766 / 2786918
    Needed 4 reads 1 writes loops 1767 / 2786918
    Needed 4 reads 1 writes loops 1768 / 2786918
    Needed 4 reads 1 writes loops 1769 / 2786918
    Needed 4 reads 1 writes loops 1770 / 2786918
    Needed 4 reads 1 writes loops 1771 / 2786918
    Needed 4 reads 1 writes loops 1772 / 2786918
    Needed 4 reads 1 writes loops 1773 / 2786918
    Needed 4 reads 1 writes loops 1774 / 2786918
    Needed 4 reads 1 writes loops 1775 / 2786918
    Needed 4 reads 1 writes loops 1776 / 2786918
    Needed 4 reads 1 writes loops 1777 / 2786918
    Needed 4 reads 1 writes loops 1778 / 2786918
    Needed 4 reads 1 writes loops 1779 / 2786918
    Needed 4 reads 1 writes loops 1780 / 2786918
    Needed 4 reads 1 writes loops 1781 / 2786918
    Needed 4 reads 1 writes loops 1782 / 2786918
    Needed 4 reads 1 writes loops 1783 / 2786918
    Needed 4 reads 1 writes loops 1784 / 2786918
    Needed 4 reads 1 writes loops 1785 / 2786918
    Needed 4 reads 1 writes loops 1786 / 2786918
    Needed 4 reads 1 writes loops 1787 / 2786918
    Needed 4 reads 1 writes loops 1788 / 2786918
    Needed 4 reads 1 writes loops 1789 / 2786918
    Needed 4 reads 1 writes loops 1790 / 2786918
    Needed 4 reads 1 writes loops 1791 / 2786918
    Needed 4 reads 1 writes loops 1792 / 2786918
    Needed 4 reads 1 writes loops 1793 / 2786918
    Needed 4 reads 1 writes loops 1794 / 2786918
    Needed 4 reads 1 writes loops 1795 / 2786918
    Needed 4 reads 1 writes loops 1796 / 2786918
    Needed 4 reads 1 writes loops 1797 / 2786918
    Needed 4 reads 1 writes loops 1798 / 2786918
    Needed 4 reads 1 writes loops 1799 / 2786918
    Needed 4 reads 1 writes loops 1800 / 2786918
    Needed 4 reads 1 writes loops 1801 / 2786918
    Needed 4 reads 1 writes loops 1802 / 2786918
    Needed 4 reads 1 writes loops 1803 / 2786918
    Needed 4 reads 1 writes loops 1804 / 2786918
    Needed 4 reads 1 writes loops 1805 / 2786918
    Needed 4 reads 1 writes loops 1806 / 2786918
    Needed 4 reads 1 writes loops 1807 / 2786918
    Needed 4 reads 1 writes loops 1808 / 2786918
    Needed 4 reads 1 writes loops 1809 / 2786918
    Needed 4 reads 1 writes loops 1810 / 2786918
    Needed 4 reads 1 writes loops 1811 / 2786918
    Needed 4 reads 1 writes loops 1812 / 2786918
    Needed 4 reads 1 writes loops 1813 / 2786918
    Needed 4 reads 1 writes loops 1814 / 2786918
    Needed 4 reads 1 writes loops 1815 / 2786918
    Needed 4 reads 1 writes loops 1816 / 2786918
    Needed 4 reads 1 writes loops 1817 / 2786918
    Needed 4 reads 1 writes loops 1818 / 2786918
    Needed 4 reads 1 writes loops 1819 / 2786918
    Needed 4 reads 1 writes loops 1820 / 2786918
    Needed 4 reads 1 writes loops 1821 / 2786918
    Needed 4 reads 1 writes loops 1822 / 2786918
    Needed 4 reads 1 writes loops 1823 / 2786918
    Needed 4 reads 1 writes loops 1824 / 2786918
    Needed 4 reads 1 writes loops 1825 / 2786918
    Needed 4 reads 1 writes loops 1826 / 2786918
    Needed 4 reads 1 writes loops 1827 / 2786918
    Needed 4 reads 1 writes loops 1828 / 2786918
    Needed 4 reads 1 writes loops 1829 / 2786918
    timeout, RX/TX: 9921/10000
    Needed 4 reads 1 writes Oh oh, inconsistency at pos 9921 (0x26c1).
    Original sample:
    Received sample:
    000026c0: 5d 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ]...............
    loops 1830 / 2786918
    spend 498 s
    cts: 0 dsr: 0 rng: 0 dcd: 0 rx: 18299921 tx: 18300000 frame 0 ovr 0 par: 0 brk: 0 buf_ovrr: 0
    hwclock: ioctl(RTC_RD_NAME) to /dev/rtc0 to read the time failed: Invalid argument
    [1]   Done(255)               ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d
    [2]   Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d
    [3]   Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d
    [4]-  Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d
    [5]+  Done(255)               ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# ps a
      PID TTY      STAT   TIME COMMAND
      515 ttyS2    Ss     0:00 /bin/login -f --
      519 ttyS2    S      0:00 -sh
    16338 ttyS2    R+     0:00 ps a
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~#
    root@am62xx-evm:~# [20295.558791] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down
    [20298.620203] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    [92574.843826] EXT4-fs (mmcblk0p4): error count since last fsck: 81
    [92574.849877] EXT4-fs (mmcblk0p4): initial error at time 1709059948: ext4_mb_mark_diskspace_used:4034
    [92574.858914] EXT4-fs (mmcblk0p4): last error at time 1709054776: ext4_mb_generate_buddy:1213
    [184849.531834] EXT4-fs (mmcblk0p4): error count since last fsck: 81
    [184849.537987] EXT4-fs (mmcblk0p4): initial error at time 1709059948: ext4_mb_mark_diskspace_used:4034
    [184849.547115] EXT4-fs (mmcblk0p4): last error at time 1709054776: ext4_mb_generate_buddy:1213
  • Ok, this looks to be the same error as before applied the third patch.
    Which AM625 device variant do you use? I'd to know how many A53 cores does it have.
  • It is dual core AM6252.
  • Thanks for all the details. I will try to reproduce it on the EVM and look into it.
  • I will be out of office for the next weeks. My test on the EVM so far has 3 UART running at the same time without DMA along with ethernet link up/down, and I see one UART has RX overun problem. Once I am back in office, I will enable UART DMA and continue the test.
  • Hi Fuyi,
    I am still debugging the issue on my EVM (without DMA), at this moment I see inconsistent UART behaviors, so trying to understand what exact the failure is.
    But I see the way you use serialcheck program with parameter '-m d' is likely not correct. The following SDK doc says duplex mode is not supported. I guess the reason is that serialcheck is not a multi-thread program, while doing TX, RX is blocked, which could cause TTY RX buffer overflow therefore data loss.
    https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/11_00_09_04/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/UART.html#basic-external-loopback-testing
    So please run serialcheck twice on each UART, one with '-m r', the other with '-m t'. This is the way I am testing.
  • serialcheck -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m d &
    serialcheck -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m d &
    serialcheck -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m d &
    serialcheck -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m d &
    serialcheck -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m d &
    and what is the file size binary_1w_ttySx in the test?
  • 10,000 bytes
  • Okay, I believe 10K bytes should be okay. I tested with a 350KB file on 3 UART simultaneously and didn't see any data loss problem (with NIC up/down). But if the data file is too big, it might cause data loss, since RX is blocked when the entire file is received and comparing for data mismatching. If RX was blocked for too long, the RX buffer would overflow then data loss would happen.
    Have you tested using '-m r' and '-m t' instead '-m d' in serialcheck parameters to see if data loss still happens on your board?
  • Hi,bin
    I will take over this issue. We use '-m r' and '-m t' instead of '-m d' in the serialcheck parameters, but the  packet loss still occurs.
    ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m r &
    ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m r &
    ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m r &
    ./serialcheck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m r &
    ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m r &
    ./serialcheck_comen -b 115200 -d /dev/ttyS3 -f ./binary_1w_ttyS3 -l 696729 -m t &
    ./serialcheck_comen -b 460800 -d /dev/ttyS4 -f ./binary_1w_ttyS4 -l 2786918 -m t &
    ./serialcheck_comen -b 460800 -d /dev/ttyS6 -f ./binary_1w_ttyS6 -l 2786918 -m t &
    ./serialcheck_comen -b 460800 -d /dev/ttyS7 -f ./binary_1w_ttyS7 -l 2786918 -m t &
    ./serialcheck_comen -b 460800 -d /dev/ttyS8 -f ./binary_1w_ttyS8 -l 2786918 -m t &
  • Hi Jie,
    Can you please share the test log showing the data loss?
    Did you test with or without DMA on UART? I tested 3 uart ports simultaneously without DMA.
  • I am simultaneously testing five ports without DMA.
    Needed 153 reads 0 writes Oh oh, inconsistency at pos 9918 (0x26be).
    Original sample:
    00002680: e8 96 98 ef 5f 7b b9 12  a2 87 fc 53 50 35 7b da   ...._{.....SP5{.
    Received sample:
    000026b0: 97 d4 cb 67 13 1f 83 a2  88 1f 2b b3 b8 67 04 5d   ...g......+..g.]
    000026c0: 34 09 1b c5 fd 10 00 fc  46 51 54 3b 92 70 1b b6   4.......FQT;.p..
    000026d0: a3 43 44 f3 2f df af 09  f8 33 dc c0 2e 7f 6e a8   .CD./....3....n.
    loops 3991 / 2786918
    spend 913 s
    Needed 157 reads 0 writes loops 3994 / 2786918
    [  987.251592] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
    Needed 155 reads 0 writes loops 4004 / 2786918
    [  989.367907] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [SMSC LAN8710/LAN8720] (irq=POLL)
  • Hi Jie,
    It seems the code block somehow got messed up, but I can see the RX lost one byte in the 4th line of the log.
    This was the exact the same problem I saw in my test, and the reason is a design flaw in serialcheck.c. It uses a single thread does RX and TX (but we workaround it by run it twice in parallel in rx-only and tx-only mode respectively), but still the RX routine receives the entire data file (binary_1w_ttySx in your test) and compares with the original file for data mismatch. During the comparison time RX is blocked and data loss could happen.
    In real scenarios this condition shouldn't happen. The UART user space application should be designed to consume RX data fast enough so that the RX buffer in kernel TTY layer won't overflow.
    To avoid data loss in this serialcheck test, you either
    - reduce the data file size, so that the RX data comparison takes little time;
    - or pause the TX for a little time to give RX time for data comparison. I tested with the following patch and it also resolves the data loss problem. You probably have to adjust the pause time for you test though.
    diff --git a/serialcheck.c b/serialcheck.c
    index f3161cc26a3d..32f596d0965b 100644
    --- a/serialcheck.c
    +++ b/serialcheck.c
    @@ -389,6 +389,10 @@ static int stress_test_uart_once(struct g_opt *opts, int fd, unsigned char *data
                    print_hex_dump(cmp_data + min_pos, max_pos - min_pos, min_pos);
                    return -1;
    +       /* pause TX for 100ms waiting for RX to finish memcmp() */
    +       if (opts->mode & MODE_TX_ONLY)
    +               usleep(100000);
            return 0;
  • hi,bin
    Is it necessary to pause 100ms after each tx is sent? The current test baud rate for the serial port is already quite low at 460800.
    The actual baud rate for our serial communication in practical usage scenarios is determined by the baud rate itself, and no additional delay will be added after transmission. I will reduce the size of the data file for testing purposes.
  • Hi Jie,
    As I explained above, adding pause after the whole data file is transmitted is one of the methods to workaround the design flaw in the serialcheck program on the RX path. In your real scenarios, since all the UART do not have hw flow control, the RX routine has to ensure to read data from TTY buffer fast enough to avoid it overflow.
    Yes, this should the better way to test it, since in real scenarios, the TX likely won't stop transmitting.
  • Hi Bin,
    I reduced the data file to 100 bytes, yet packet loss still occurs. Additionally, I added logging in the ttybuffer.c file when exceeding the kernel buffer size, but this log does not appear during packet loss. It is possible that a buffer overflow is occurring in the hardware FIFO segment.
    	if (atomic_read(&port->buf.mem_used) > port->buf.mem_limit) {
    		WARN_ONCE(1, "Memory limit exceeded: used=%d, limit=%d\n",
                  atomic_read(&port->buf.mem_used), port->buf.mem_limit);
    		return NULL;
  • Hi Jie,
    Can you please apply the following kernel patch to reduce the RX FIFO watermark to see if it resolve the data loss problem?
    diff --git a/drivers/tty/serial/8250/8250_omap.c b/drivers/tty/serial/8250/8250_omap.c
    index 0dd68bdbfbcf..a9306c5fedf7 100644
    --- a/drivers/tty/serial/8250/8250_omap.c
    +++ b/drivers/tty/serial/8250/8250_omap.c
    @@ -87,7 +87,7 @@
     #define OMAP_UART_TX_WAKEUP_EN (1 << 7)
     #define TX_TRIGGER     1
    -#define RX_TRIGGER     48
    +#define RX_TRIGGER     32
     #define OMAP_UART_TCR_RESTORE(x)       ((x / 4) << 4)
    I will see if I can enable more UART ports on the SK to test as well. I have 3 UARTs enabled right now.
  • Modifying the RX FIFO threshold can also result in packet loss
  • Hi Jie,
    Thanks for the update.
    I will debug the issue on my EVM to understand how the one byte gets lost. I will keep you posted.
  • Hi Jie,
    Do you still use RT Linux in your test? The previous e2e thread has mentioned that RT Linux doesn't help on the issue, but the previous test used '-m d' in serialcheck program. Now since the test has been updated with two separate seriallcheck program (each for TX and RX respectively), I want to check if you still test with RT Linux.
    When using serialcheck or any other program for UART external loopback test, the same amount of data are transmitted and received on the same UART port. But typically the UART has big amount data only in one of the directions in real use case, either RX or TX. Does the UART in your project transmits and receives the similar amount data, or just in one direction? I want to know what exact UART problem do you see in your project, not the serialcheck loopback test.
  • HI Jie,
    Can you please provide response to Bin's query ?
    Ashwani
  • Hi Jie,
    I unlocked this thread, so you can respond to my questions.
  • Hi Bin,
    I experience packet loss when executing the serialcheck program on the RT kernel without using the -m d option. The result is even worse than test with Linux, loss data in shorter time and result in serialcheck crash.
    Certainly, this type of loopback pressure testing represents an extreme case of serial communication. We can only ensure that normal conditions are adequately covered when such tests can guarantee stable communication.
    We apply the same testing standards on other platforms such as IMX6, 7, and 8, which also use the Linux operating system. Additionally, I have attempted to run the serial port stress test programs from other platforms on the AM62, and packet loss also occurs.
  • Hi Joe,
    Can you please share the log showing the data loss?
    What do you mean by other platforms on the AM62? Different AM62 boards?
  • Can you please share the log showing the data loss?
    timeout, RX/TX: 9999/10000
    Needed 39 reads 1 writes Oh oh, inconsistency at pos 5759 (0x167f).
    Original sample:
    00001640: db f3 47 95 05 ff fc 57  0f 1f fd b6 93 a0 7f 19   ..G....W........
    00001650: 6c 9e 6a 44 cc 80 66 d7  24 5c 4e f0 05 d1 3e a1   l.jD..f.$\N...>.
    00001660: a5 f2 f8 c3 ed d4 6f 8d  64 c2 54 94 cb ca 8d c7   ......o.d.T.....
    00001670: 78 81 b3 ee ed 87 c5 78  36 3e dd 57 1f 6b 85 3f   x......x6>.W.k.?
    00001680: 12 be c9 33 de 09 dc 77  dd b8 ee 84 3e e5 93 32   ...3...w....>..2
    00001690: 9d 29 bb 1f 8e 68 aa f5  27 60 cb d4 80 b0 7a 01   .)...h..'`....z.
    Received sample:
    00001670: 78 81 b3 ee ed 87 c5 78  36 3e dd 57 1f 6b 85 12   x......x6>.W.k..
    00001680: be c9 33 de 09 dc 77 dd  b8 ee 84 3e e5 93 32 9d   ..3...w....>..2.
    00001690: 29 bb 1f 8e 68 aa f5 27  60 cb d4 80 b0 7a 01 3f   )...h..'`....z.?
    loops 9832 / 2786918
    spend 2265 s
     We did UART test on other vendor's platform with our own developed UART test tool/method, the same test can pass on other vendor's platform, but loss data on AM62x.
  • Hi Jie,
    Thanks for the log. The data loss pattern is the same as before.
    I will look into it.
  • Hi Jie,
    While I am waiting for the shipment, can you please run a test on your board with the following two changes?
    1. Change the TX load size to 48 bytes using the kernel patch below. This is to aligned with the 48-bytes RX FIFO watermark in the UART driver to better utilize the RX FIFO.
    index 6d21e99a363f..ddee1f0e7741 100644
    @@ -1477,7 +1477,7 @@ static int omap8250_probe(struct platform_device *pdev)
            up.port.regshift = OMAP_UART_REGSHIFT;
            up.port.fifosize = 64;
    -       up.tx_loadsz = 64;
    +       up.tx_loadsz = 48;
            up.capabilities = UART_CAP_FIFO;
    2. Use irq affinity to move UART irq handling out of CPU0. Following is the script I use before starting the UART loopback testing.
    # set uart irq affinity
    _cpu=1
    for _u in 2b300000 4a00000 2810000 2850000 2860000; do
            _irq=$(grep "${_u}.serial" /proc/interrupts | cut -d: -f1 | cut -d' ' -f2)
            echo $_cpu > /proc/irq/${_irq}/smp_affinity_list
            _cpu=$(((_cpu % 3) + 1))
    done
    You can adjust the entries in the first line "for" loop for the UART instances enabled on your board.
  • Hi Jie,
    I identified a kernel patch in TTY layer which causes UART data loss in my test.
    The patch attached below is to revert the code change by this offending patch. I have tested 5 UARTs at 921600bps baud for 60K loops which does not show any data loss issue. (I used the "up.tx_loadsz = 48" change shown in my previous post, but didn't use UART irq affinity, I am using SDK10.1 kernel, non-RT).
    Can you please test again with this patch to see if it resolves the test failure in your setup?
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/0001_2D00_tty_2D00_manual_2D00_revert_2D00_tty_2D00_Prevent_2D00_writing_2D00_chars_2D00_during_2D00_t.patch
    Following is my test script.
    prog='/usr/bin/serialcheck'
    cnt=300000
    baud=921600
    dat=/dev/shm/dat
    cp ~/seq_data_10k $dat
    $prog -b $baud -d /dev/ttyS0 -f $dat -l $((cnt+0)) -m r -k &
    $prog -b $baud -d /dev/ttyS1 -f $dat -l $((cnt+1)) -m r &
    $prog -b $baud -d /dev/ttyS3 -f $dat -l $((cnt+3)) -m r &
    $prog -b $baud -d /dev/ttyS7 -f $dat -l $((cnt+7)) -m r &
    $prog -b $baud -d /dev/ttyS8 -f $dat -l $((cnt+8)) -m r &
    sleep 0.1
    $prog -b $baud -d /dev/ttyS0 -f $dat -l $((cnt+0)) -m t -n -k &
    $prog -b $baud -d /dev/ttyS1 -f $dat -l $((cnt+1)) -m t -n &
    $prog -b $baud -d /dev/ttyS3 -f $dat -l $((cnt+3)) -m t -n &
    $prog -b $baud -d /dev/ttyS7 -f $dat -l $((cnt+7)) -m t -n &
    $prog -b $baud -d /dev/ttyS8 -f $dat -l $((cnt+8)) -m t -n &
    while true; do ifconfig eth1 up && sleep 1 && ifconfig eth1 down && sleep 1; done
    A few notes of the script:
    - ttyS0 is the wkup_uart0 on the EVM, which directly routes to the FTDI and cannot use external loopback. So I used internal loopback (-k parameter);
    - I added 'sleep 0.1' before starting the RX threads and the TX threads to avoid any potential race condition in kerel TTY framework (set_termios and ioctl);
    - I used slight different loop number for each UART to distinguish the messages in the console log.
    I just noticed you use SDK10.0 but I test with SDK10.1 kernel. I am currently repeating the same test but with 2Mbps baud. Once this test is done, I will switch my test to SDK10.0 kernel.
  • It appears this thread is corrupted since the last several posts, and the new posts cannot be modified or "reply"...
     > I have tested 5 UARTs at 921600bps baud for 60K loops which does not show any data loss issue.
    I forgot to mention that this test was done with the attached kernel patch applied.
  • Hi Jie,
    I tested multiple combinations today, the real fix of the data loss issue is both of
    - the tty driver patch (0001-tty-manual-revert-tty-Prevent-writing-chars-during-t.patch) posted above;
    - and 8250_omap.c driver change (up.tx_loadsz = 48) posted above too.
    Please test with both changes and let me know.
