Hello
do you know if there is a posibility of decoding H.264 using the ARM in this device? if so, does TI provide the codec? is it via a third party?
Anjli Behl.
Hello
Anjli Behl.
Anjili,
Ti provides example application for H.264 decode using opensource libav codecs using GStreame multimedia stack. If you are interested in better performance, 3P like Ittiam provide NEON optimized H.264 codecs. SDK for AM335x EVM with multimedia example applications will be available on December 15th on ti.com.
Regards, Punya
Thanks for the reply.
What about audio codecs? Will TI supply or do customers need to go to Ittiam or other 3rd P??
Also, how many Mhz will be needed for 720p H.264 decode @ 10FPS? Will there be any Mhz left for audio?
i would need to support audio capture: 22050 samplerate mono and audio encode: AAC raw, 22050 samplerate mono, 32 kbps bitrate
