AM623: Method to distinguish between HS-FS and HS-SE devices w/o UART boot
Part Number: AM623
Dear Support Team,
Is there a possibility to distinguish between HS-FS and HS-SE devices without using the console date in UART boot mode?
The only interface we would like to use is USB and UART over USB in our use-case without any real UART or JTAG.
The boot mode is limited to USB-DFU, too.
So, we thought about something, like reading out the key revision (TSCI_MSG_READ_KEYCNT_KEYREV) by a dedicated sbl bootloader (firmeware). Form the documentation we’ve found this looks like it is limited to the HS-SE devices.
Is there maybe a different API call we could use for both SE and FS devices, or would you recommend a different approach?
Best Regards
