DRA821U: shutdown command not working on our custom board
Part Number: DRA821U
Hi there,
We created a base image using TI's Yocto project with our customization. When we try to reboot our custom board using command "shutdown -r now", the Linux system doesn't do the reboot at all. However, reboot works on J7200 EVM with TI's built-in image. What could prevent our board from rebooting? How does the shutdown command perform rebooting? How to trouble-shooting the issue? I attached both logs below.
Charles
Reboot log from our custom board:
U-Boot SPL 2024.04-ti-g7968a65d0e4f (Apr 02 2025 - 14:32:05 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -121
i2c_write: error waiting for data ACK (status=0x116)
read error from device: 41c866a0 register: x!
write error to device: 41c86550 register: x!
esm_pmic esm: clearing ESM irqs failed: -5
ESM PMIC init failed: -5
Trying to boot from MMC1
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
init_env from device 17 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
I/TC:
I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2024.04-ti-g7968a65d0e4f (Apr 02 2025 - 14:32:05 +0000)
SoC:   J7200 SR2.0 GP
Model: EDR A-Sample
DRAM:  2 GiB (effective 8 GiB)
Core:  81 devices, 30 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
Can't set block device
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
75416 bytes read in 22 ms (3.3 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 75416 bytes: Success!
Load Remote Processor 3 with data@addr=0x82000000 75416 bytes: Success!
20283904 bytes read in 74 ms (261.4 MiB/s)
76726 bytes read in 18 ms (4.1 MiB/s)
Working FDT set to 88000000
   Loading Device Tree to 000000008feea000, end 000000008fffffff ... OK
Working FDT set to 8feea000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.6.32-ti-01310-g3cc477f2c742 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Wed Mar 19 18:07:09 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: EDR A-Sample
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a47fffff (8192 KiB) nomap non-reusable ipc-memories@a4000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
[    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=8e43eb4b-a91e-9644-957e-ba69096861e9 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2064384
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
[    0.000000] Memory: 8010708K/8388608K available (11968K kernel code, 1248K rwdata, 4020K rodata, 2432K init, 504K bss, 345132K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008488] Console: colour dummy device 80x25
[    0.013093] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023792] pid_max: default: 32768 minimum: 301
[    0.028598] LSM: initializing lsm=capability,integrity
[    0.033965] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.041782] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.051377] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.058710] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.066664] rcu: Hierarchical SRCU implementation.
[    0.071600] rcu:     Max phase no-delay instances is 1000.
[    0.077220] Platform MSI: msi-controller@1820000 domain created
[    0.083470] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.092958] EFI services will not be available.
[    0.097784] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.111117] Detected PIPT I-cache on CPU1
[    0.111187] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.111207] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.111247] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.111332] smp: Brought up 1 node, 2 CPUs
[    0.140820] SMP: Total of 2 processors activated.
[    0.145640] CPU features: detected: 32-bit EL0 Support
[    0.150932] CPU features: detected: CRC32 instructions
[    0.156246] CPU: All CPU(s) started at EL2
[    0.160452] alternatives: applying system-wide alternatives
[    0.167405] devtmpfs: initialized
[    0.180325] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.190358] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.198110] pinctrl core: initialized pinctrl subsystem
[    0.203845] DMI not present or invalid.
[    0.208308] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.215250] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.222857] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.231289] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.239574] audit: initializing netlink subsys (disabled)
[    0.245269] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1
[    0.245621] thermal_sys: Registered thermal governor 'step_wise'
[    0.253242] thermal_sys: Registered thermal governor 'power_allocator'
[    0.259445] cpuidle: using governor menu
[    0.270299] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.277296] ASID allocator initialised with 65536 entries
[    0.298513] Modules: 27680 pages in range for non-PLT usage
[    0.298524] Modules: 519200 pages in range for PLT usage
[    0.304928] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.317345] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.323785] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.330736] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.337173] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.344123] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.350562] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.357512] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.365234] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
[    0.374491] iommu: Default domain type: Translated
[    0.379423] iommu: DMA domain TLB invalidation policy: strict mode
[    0.385970] SCSI subsystem initialized
[    0.390098] usbcore: registered new interface driver usbfs
[    0.395771] usbcore: registered new interface driver hub
[    0.401235] usbcore: registered new device driver usb
[    0.406827] pps_core: LinuxPPS API ver. 1 registered
[    0.411915] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.421313] PTP clock support registered
[    0.425488] EDAC MC: Ver: 3.0.0
[    0.429114] scmi_core: SCMI protocol bus registered
[    0.434396] FPGA manager framework
[    0.437972] Advanced Linux Sound Architecture Driver Initialized.
[    0.444911] vgaarb: loaded
[    0.447929] clocksource: Switched to clocksource arch_sys_counter
[    0.454392] VFS: Disk quotas dquot_6.6.0
[    0.458450] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.471570] NET: Registered PF_INET protocol family
[    0.477172] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.490052] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.498930] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.506894] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.515462] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.526086] TCP: Hash tables configured (established 65536 bind 65536)
[    0.533032] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.540171] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.547886] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.554169] RPC: Registered named UNIX socket transport module.
[    0.560274] RPC: Registered udp transport module.
[    0.565097] RPC: Registered tcp transport module.
[    0.569934] RPC: Registered tcp-with-tls transport module.
[    0.575553] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.582176] NET: Registered PF_XDP protocol family
[    0.587096] PCI: CLS 0 bytes, default 64
[    0.592177] Initialise system trusted keyrings
[    0.596905] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.603820] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.610046] NFS: Registering the id_resolver key type
[    0.615269] Key type id_resolver registered
[    0.619556] Key type id_legacy registered
[    0.623691] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.630559] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.665165] Key type asymmetric registered
[    0.669371] Asymmetric key parser 'x509' registered
[    0.674427] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.682010] io scheduler mq-deadline registered
[    0.686665] io scheduler kyber registered
[    0.690803] io scheduler bfq registered
[    0.697643] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.703794] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
[    0.709680] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
[    0.716004] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
[    0.722052] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.727880] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.733680] pinctrl-single 11c000.pinctrl: 67 pins, size 268
[    0.739965] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
[    0.745740] pinctrl-single 11c164.pinctrl: 2 pins, size 8
[    0.757125] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.772152] loop: module loaded
[    0.776273] megasas: 07.725.01.00-rc1
[    0.783071] tun: Universal TUN/TAP device driver, 1.6
[    0.789137] VFIO - User Level meta-driver version: 0.3
[    0.795449] usbcore: registered new interface driver usb-storage
[    0.802128] i2c_dev: i2c /dev entries driver
[    0.807616] sdhci: Secure Digital Host Controller Interface driver
[    0.813980] sdhci: Copyright(c) Pierre Ossman
[    0.818640] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.824985] ledtrig-cpu: registered to indicate activity on CPUs
[    0.831412] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.838812] usbcore: registered new interface driver usbhid
[    0.844534] usbhid: USB HID core driver
[    0.849763] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.858601] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.863178] optee: revision 4.2 (12d7c4ee)
[    0.879714] optee: dynamic shared memory is enabled
[    0.889671] random: crng init done
[    0.893282] optee: initialized driver
[    0.898882] NET: Registered PF_PACKET protocol family
[    0.904158] Key type dns_resolver registered
[    0.914910] registered taskstats version 1
[    0.919221] Loading compiled-in X.509 certificates
[    0.935380] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    1.029828] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 400 kHz
[    1.036755] omap_i2c 42120000.i2c: bus 1 rev0.12 at 400 kHz
[    1.042788] pinctrl-single 11c000.pinctrl: Invalid number of rows: 0
[    1.049316] pinctrl-single 11c000.pinctrl: no pins entries for main-i2c0-default-pins
[    1.058020] omap_i2c 2020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.063853] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    1.072478] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    1.081911] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    1.090600] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
[    1.103018] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[    1.112971] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.119755] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.132419] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
[    1.142599] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.149406] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.157912] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 268, base_baud = 6000000) is a 8250
[    1.168039] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 269, base_baud = 3000000) is a 8250
[    1.176973] printk: console [ttyS2] enabled
[    1.185598] printk: bootconsole [ns16550a0] disabled
[    1.208988] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 270, base_baud = 3000000) is a 8250
[    1.217963] pinctrl-single 11c000.pinctrl: Invalid number of rows: 0
[    1.224323] pinctrl-single 11c000.pinctrl: no pins entries for main-uart3-default-pins
[    1.233807] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    1.279938] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.297668] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver BCM89885M Custom
[    1.306277] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver BCM89885M Custom
[    1.314912] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 5 quirks:00000000
[    1.329509] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    1.338490] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
[    1.345126] mmc0: CQHCI version 5.10
[    1.345549] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
[    1.383990] tps6594 1-0048: error -EREMOTEIO: Failed to set PMIC state
[    1.389813] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.390568] tps6594: probe of 1-0048 failed with error -121
[    1.403854] tps6594 1-004c: error -EREMOTEIO: Failed to set PMIC state
[    1.410480] tps6594: probe of 1-004c failed with error -121
[    1.417688] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.425290] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.433456] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.441617] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.503968] mmc0: Command Queue Engine enabled
[    1.508421] mmc0: new HS400 MMC card at address 0001
[    1.513843] mmcblk0: mmc0:0001 AAM20E 29.6 GiB
[    1.521887]  mmcblk0: p1
[    1.524840] mmcblk0boot0: mmc0:0001 AAM20E 31.5 MiB
[    1.530742] mmcblk0boot1: mmc0:0001 AAM20E 31.5 MiB
[    1.536548] mmcblk0rpmb: mmc0:0001 AAM20E 4.00 MiB, chardev (239:0)
[    2.452020] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    2.458295] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.463779] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    2.473247] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    2.480140] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
[    2.486269] pci 0000:00:00.0: supports D1
[    2.490278] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.496042] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    2.502911] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    2.514835] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.522987] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.529616] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[    2.536923] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.541988] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    2.548848] pcieport 0000:00:00.0: PME: Signaling with IRQ 442
[    2.554941] pcieport 0000:00:00.0: AER: enabled with IRQ 442
[    2.561948] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    2.573271] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
[    2.587249] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    2.592315] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
[    2.599364] Creating 7 MTD partitions on "47040000.spi.0":
[    2.604845] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[    2.611276] 0x000000100000-0x000000300000 : "ospi.tispl"
[    2.617419] 0x000000300000-0x000000700000 : "ospi.u-boot"
[    2.623595] 0x000000700000-0x000000740000 : "ospi.env"
[    2.629542] 0x000000740000-0x000000780000 : "ospi.env.backup"
[    2.636111] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    2.642328] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    2.649699] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[    2.695938] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.713676] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver BCM89885M Custom
[    2.722290] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver BCM89885M Custom
[    2.730925] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 5 quirks:00000000
[    2.743835] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    2.750215] am65-cpsw-nuss c000000.ethernet: Use random MAC address
[    2.756496] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.4
[    2.763624] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
[    2.770054] am65-cpsw-nuss c000000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    2.788779] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 60
[    2.800707] debugfs: Directory 'pd:49' with parent 'pm_genpd' already present!
[    2.810126] debugfs: Directory 'pd:35' with parent 'pm_genpd' already present!
[    2.817991] clk: Disabling unused clocks
[    2.835935] ALSA device list:
[    2.838900]   No soundcards found.
[    2.872740] EXT4-fs (mmcblk0p1): mounted filesystem aaa19cde-b65c-48b2-bb1c-448d172f6eab r/w with ordered data mode. Quota mode: none.
[    2.884879] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    2.893215] devtmpfs: mounted
[    2.898078] Freeing unused kernel memory: 2432K
[    2.902760] Run /sbin/init as init process
[    2.990893] systemd[1]: System time before build time, advancing clock.
[    3.016981] NET: Registered PF_INET6 protocol family
[    3.022876] Segment Routing with IPv6
[    3.026578] In-situ OAM (IOAM) with IPv6
[    3.049516] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.081479] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    3.105570] systemd[1]: Hostname set to <edr>.
[    3.402789] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.466676] systemd[1]: Queued start job for default target Multi-User System.
[    3.508808] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    3.533802] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.557727] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.581407] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.604292] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    3.628215] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.652063] systemd[1]: Expecting device /dev/ttyS2...
[    3.672100] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    3.692048] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.712029] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    3.732042] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    3.786405] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.812180] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.837846] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.860338] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.884904] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.908543] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.932599] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.952624] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.977504] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.000479] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.020438] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    4.072215] systemd[1]: Mounting Huge Pages File System...
[    4.095386] systemd[1]: Mounting POSIX Message Queue File System...
[    4.128330] systemd[1]: Mounting Kernel Debug File System...
[    4.156413] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.173342] systemd[1]: Mounting Temporary Directory /tmp...
[    4.212677] systemd[1]: Starting Create List of Static Device Nodes...
[    4.244719] systemd[1]: Starting Load Kernel Module configfs...
[    4.268743] systemd[1]: Starting Load Kernel Module drm...
[    4.308778] systemd[1]: Starting Load Kernel Module fuse...
[    4.344776] systemd[1]: Starting RPC Bind...
[    4.359632] fuse: init (API version 7.39)
[    4.364331] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    4.383669] systemd[1]: Starting Journal Service...
[    4.440558] systemd[1]: Starting Load Kernel Modules...
[    4.472299] systemd[1]: Starting Generate network units from Kernel command line...
[    4.480487] cryptodev: loading out-of-tree module taints kernel.
         Starting Generate network units from Kernel co[    4.488751] cryptodev: driver 1.13 loaded.
mmand line...
[    4.506044] systemd-journald[112]: Collecting audit messages is enabled.
[    4.532588] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.580756] systemd[1]: Starting Coldplug All udev Devices...
[    4.601874] EXT4-fs (mmcblk0p1): re-mounted aaa19cde-b65c-48b2-bb1c-448d172f6eab r/w. Quota mode: none.
[    4.617789] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.638029] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev gracefully...
[    5.040369] systemd-journald[112]: Received client request to flush runtime journal.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    5.282342] audit: type=1334 audit(1709054766.288:2): prog-id=6 op=LOAD
[    5.295992] audit: type=1334 audit(1709054766.296:3): prog-id=7 op=LOAD
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
[    5.518465] audit: type=1334 audit(1709054766.524:4): prog-id=8 op=LOAD
         Starting Network Name Resolution...
[    5.556077] audit: type=1334 audit(1709054766.560:5): prog-id=9 op=LOAD
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    5.677412] audit: type=1334 audit(1709054766.684:6): prog-id=10 op=LOAD
[    5.688187] audit: type=1334 audit(1709054766.696:7): prog-id=11 op=LOAD
[    5.698216] audit: type=1334 audit(1709054766.704:8): prog-id=12 op=LOAD
         Starting User Database Manager...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started User Database Manager.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[    6.467654] audit: type=1334 audit(1709133230.280:9): prog-id=13 op=LOAD
         Starting D-Bus System Message Bus...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Started D-Bus System Message Bus.
[    6.619914] dbus-broker-lau[285]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Expand the rootfs partiti…to full size of the boot device....
[    6.832964] audit: type=1334 audit(1709133230.648:10): prog-id=14 op=LOAD
[    6.848028] audit: type=1334 audit(1709133230.656:11): prog-id=15 op=LOAD
[    6.860206] audit: type=1334 audit(1709133230.656:12): prog-id=16 op=LOAD
         Starting Telnet Server...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Reached target Prepara[    7.017706] audit: type=1334 audit(1709133230.832:13): prog-id=17 op=LOAD
tion for Network.
         Starting Network Configuration...
[  OK  ] Started User Login Management.
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[    7.427244] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.461543] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.472937] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    7.486305] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    7.501083] cfg80211: failed to load regulatory.db
[  OK  ] Started Network Configuration.
[  OK  ] Reached target Network.
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
         Starting Permit User Sessions...
[    7.668949] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:01] driver [BCM89885M Custom] (irq=POLL)
[    7.704858] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/sgmii link mode
[    7.781619] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:00] driver [BCM89885M Custom] (irq=POLL)
[    7.806270] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/sgmii link mode
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[    8.179751] at24 1-0050: supply vcc not found, using dummy regulator
[    8.209912] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    8.359423] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
NOTICE: This file system contains the following GPL-3.0 packages:
        bash
        cifs-utils
        dosfstools
        grub-common
        grub-editenv
        grub-efi
        kbd-keymaps-pine
        less
        libatomic1
        libdw1
        libelf1
        libgcc1
        libreadline8
        libstdc++6
        nano
        parted
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE[    8.476357] platform 41000000.r5f: configured R5F for IPC-only mode
: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Finished Print notice about GPLv3 packages.
[    8.539293] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[    8.568077] remoteproc remoteproc0: 41000000.r5f is available
[    8.574453] remoteproc remoteproc0: attaching to 41000000.r5f
[    8.593888] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    8.601393] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node r5f-dma-memory@a0000000
[    8.621727] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.632294] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    8.640040] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    8.664591] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    8.679306] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
[    8.713256] platform 5c00000.r5f: configured R5F for IPC-only mode
[    8.720897] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[    8.732323] remoteproc remoteproc1: 5c00000.r5f is available
[    8.738601] remoteproc remoteproc1: attaching to 5c00000.r5f
[    8.749319] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    8.758429] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@a2000000
[    8.771049] virtio_rpmsg_bus virtio1: rpmsg host is online
[    8.776684] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[    8.777956] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    8.785609] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
[    8.791105] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    8.808490] platform 5d00000.r5f: configured R5F for IPC-only mode
[    8.815646] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[    8.880053] remoteproc remoteproc2: 5d00000.r5f is available
[    8.897270] remoteproc remoteproc2: attaching to 5d00000.r5f
[  OK  ] Started containerd container runtime.
[  OK  ] Reached target Multi-User System.
[    8.965373] platform 5d00000.r5f: R5F core initialized in IPC-only mode
         Starting Record Runlevel Change in UTMP...
[    9.003259] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@a3000000
[  OK  ] Listening on Load/Save RF Kill Swit[    9.031117] virtio_rpmsg_bus virtio2: rpmsg host is online
ch Status /dev/rfkill Watch.
[    9.042002] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7)
[    9.042060] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[    9.059412] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Finished Record Runlevel Change in [    9.082414] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
UTMP.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project edr ttyS2
Arago 2023.10 edr ttyS2
edr login: root
[   27.202706] audit: type=1006 audit(1709133251.016:14): pid=515 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[   27.215190] audit: type=1300 audit(1709133251.016:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffffd17e138 a2=1 a3=1 items=0 ppid=1 pid=515 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   27.241704] audit: type=1327 audit(1709133251.016:14): proctitle="(systemd)"
[   27.248796] audit: type=1334 audit(1709133251.028:15): prog-id=18 op=LOAD
[   27.255631] audit: type=1300 audit(1709133251.028:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffee885d68 a2=90 a3=0 items=0 ppid=1 pid=515 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   27.283150] audit: type=1327 audit(1709133251.028:15): proctitle="(systemd)"
[   27.290263] audit: type=1334 audit(1709133251.056:16): prog-id=18 op=UNLOAD
[   27.297263] audit: type=1300 audit(1709133251.056:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffaa94cc60 items=0 ppid=1 pid=515 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   27.322810] audit: type=1327 audit(1709133251.056:16): proctitle="(systemd)"
[   27.330221] audit: type=1334 audit(1709133251.056:17): prog-id=19 op=LOAD
root@edr:~# shutdown -r now
root@edr:~#          S[  OK  ] Removed slice Slice /system/modprobe.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
[  OK  ] Stopped target Host and Network Name Lookups.
[  OK  ] Stopped target RPC Port Mapper.
[  OK  ] Stopped target System Time Set.
[  OK  ] Stopped target Timer Units.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Stopping Avahi mDNS/DNS-SD Stack...
         Stopping containerd container runtime...
         Stopping Getty on tty1...
         Stopping Netperf Benchmark Server...
[  OK  ] Stopped Expand the rootfs partition to full size of the boot device..
         Stopping Serial Getty on ttyS2...
         Stopping Load/Save OS Random Seed...
         Stopping Telnet Server...
[  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
[  OK  ] Stopped Netperf Benchmark Server.
[  OK  ] Stopped containerd container runtime.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped Serial Getty on ttyS2.
[  OK  ] Stopped Load/Save OS Random Seed.
[  OK  ] Stopped Telnet Server.
[  OK  ] Stopped Session c1 of User root.
[  OK  ] Removed slice Slice /system/getty.
[  OK  ] Removed slice Slice /system/serial-getty.
         Stopping User Login Management...
         Stopping Permit User Sessions...
         Stopping User Manager for UID 0...
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped target Network.
[  OK  ] Stopped target Remote File Systems.
         Stopping Network Configuration...
         Stopping User Runtime Directory /run/user/0...
[  OK  ] Unmounted /run/user/0.
[  OK  ] Stopped User Login Management.
[  OK  ] Stopped Network Configuration.
[  OK  ] Stopped User Runtime Directory /run/user/0.
[   36.061530] kauditd_printk_skb: 5 callbacks suppressed
[   36.061540] audit: type=1334 audit(1709133259.876:19): prog-id=14 op=UNLOAD
[  OK  ] Removed slice User Slice of UID 0   36.074062] audit: type=1334 audit(1709133259.876:20): prog-id=17 op=UNLOAD
0m.
[  OK  ] Stopped target Preparation for Network.
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Path Units.
[  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
[  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
[  OK  ] Stopped target Slice Units.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Socket Units.
[  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Closed Docker Socket for the API.
[  OK  ] Closed dropbear.socket.
[  OK  ] Closed Network Service Netlink Socket.
         Stopping D-Bus System Message Bus...
[  OK  ] Stopped Generate network units from Kernel command line.
[  OK  ] Stopped D-Bus System Message Bus.
[   36.378847] audit: type=1334 audit(1709133260.192:21): prog-id=13 op=UNLOAD
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
         Stopping Network Name Resolution...
         Stopping Network Time Synchronization...
[  OK  ] Stopped Network Name Resolution.
[  OK  ] Stopped Network Time Synchronization.
[   36.496164] audit: type=1334 audit(1709133260.308:22): prog-id=8 op=UNLOAD
[   36.503111] audit: type=1334 audit(1709133260.312:23): prog-id=9 op=UNLOAD
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Closed Process Core Dump Socket.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting Temporary Directory /tmp...
         Unmounting /var/volatile...
[  OK  ] Unmounted Temporary Directory /tmp.
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Preparation for Local File Systems.
[  OK  ] Stopped target Swaps.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Stopped Create Static Device Nodes in /dev gracefully.
[  OK  ] Reached target System Shutdown.
[  OK  ] Reached target Late Shutdown Services.
[  OK  ] Finished System Reboot.
[  OK  ] Reached target System Reboot.
[   36.859990] audit: type=1334 audit(1709133260.672:24): prog-id=16 op=UNLOAD
[   36.867019] audit: type=1334 audit(1709133260.672:25): prog-id=15 op=UNLOAD
[   36.874057] audit: type=1334 audit(1709133260.680:26): prog-id=7 op=UNLOAD
[   36.881149] audit: type=1334 audit(1709133260.680:27): prog-id=6 op=UNLOAD
[   36.888055] audit: type=1334 audit(1709133260.688:28): prog-id=5 op=UNLOAD
[   36.913025] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[   36.919988] watchdog: watchdog0: watchdog did not stop!
[   36.939218] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0
[   36.949075] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout.
[   36.959053] systemd-shutdown[1]: Watchdog running with a timeout of 1min.
[   36.988214] systemd-shutdown[1]: Syncing filesystems and block devices.
[   37.000789] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[   37.028587] systemd-journald[112]: Received SIGTERM from PID 1 (systemd-shutdow).
[   37.041428] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[   37.060988] systemd-shutdown[1]: Unmounting file systems.
[   37.068993] (sd-remount)[562]: Remounting '/' read-only with options ''.
[   37.102412] EXT4-fs (mmcblk0p1): re-mounted aaa19cde-b65c-48b2-bb1c-448d172f6eab ro. Quota mode: none.
[   37.115084] systemd-shutdown[1]: All filesystems unmounted.
[   37.120725] systemd-shutdown[1]: Deactivating swaps.
[   37.125838] systemd-shutdown[1]: All swaps deactivated.
[   37.131072] systemd-shutdown[1]: Detaching loop devices.
[   37.141515] systemd-shutdown[1]: All loop devices detached.
[   37.147113] systemd-shutdown[1]: Stopping MD devices.
[   37.152454] systemd-shutdown[1]: All MD devices stopped.
[   37.157776] systemd-shutdown[1]: Detaching DM devices.
[   37.163124] systemd-shutdown[1]: All DM devices detached.
[   37.168537] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[   37.178195] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[   37.185080] systemd-shutdown[1]: Failed to disable hardware watchdog, ignoring: Device or resource busy
[   37.194482] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[   37.201349] watchdog: watchdog0: watchdog did not stop!
[   37.209863] systemd-shutdown[1]: Syncing filesystems and block devices.
[   37.217027] systemd-shutdown[1]: Rebooting.
[   37.234854] reboot: Restarting system
Reboot log from J7200 EVM:
U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
Trying to boot from MMC2
I/TC:
Detected: J7X-BASE-CPB rev A
Detected: J7X-VSC8514-ETH rev E2
U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
SoC:   J7200 SR2.0 GP
Model: Texas Instruments J7200 EVM
Board: J7200X-PM2-SOM rev E8
DRAM:  2 GiB (effective 4 GiB)
Core:  103 devices, 32 uclasses, devicetree: separate
Flash: 0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
Net:   eth0: ethernet@46000000port@1
mmc1 is current device
SD/MMC found on device 1
574 bytes read in 12 ms (45.9 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
gpio: pin gpio@22_17 (gpio 126) value is 1
gpio: pin gpio@22_16 (gpio 125) value is 0
880124 bytes read in 67 ms (12.5 MiB/s)
Load Remote Processor 2 with data@addr=0x82000000 880124 bytes: Success!
75416 bytes read in 59 ms (1.2 MiB/s)
20285952 bytes read in 217 ms (89.2 MiB/s)
79882 bytes read in 14 ms (5.4 MiB/s)
   Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK
Working FDT set to 8fee9000
Starting kernel ...
[    0.000000] Linux version 6.6.32-ti-01287-g6de6e418c80e-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024
[    0.000000] Machine model: Texas Instruments J7200 EVM
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Memory: 3896268K/4194304K available (11968K kernel code, 1250K rwdata, 4036K rodata, 2432K init, 502K bss, 265268K reserved, 32768K cma-reserved)
[    0.008376] Console: colour dummy device 80x25
[    0.012942] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023613] pid_max: default: 32768 minimum: 301
[    0.028370] LSM: initializing lsm=capability,integrity
[    0.033678] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.041255] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.050151] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.057420] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.065279] rcu: Hierarchical SRCU implementation.
[    0.070179] rcu:     Max phase no-delay instances is 1000.
[    0.075702] Platform MSI: msi-controller@1820000 domain created
[    0.081874] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.091261] EFI services will not be available.
[    0.096000] smp: Bringing up secondary CPUs ...
[    0.109182] Detected PIPT I-cache on CPU1
[    0.109228] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.109242] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.109275] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.109329] smp: Brought up 1 node, 2 CPUs
[    0.138677] SMP: Total of 2 processors activated.
[    0.143482] CPU features: detected: 32-bit EL0 Support
[    0.148736] CPU features: detected: CRC32 instructions
[    0.154016] CPU: All CPU(s) started at EL2
[    0.158198] alternatives: applying system-wide alternatives
[    0.164765] devtmpfs: initialized
[    0.173092] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.183069] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.190635] pinctrl core: initialized pinctrl subsystem
[    0.196230] DMI not present or invalid.
[    0.200704] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.207186] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.214499] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.222538] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.230660] audit: initializing netlink subsys (disabled)
[    0.236280] audit: type=2000 audit(0.152:1): state=initialized audit_enabled=0 res=1
[    0.236481] thermal_sys: Registered thermal governor 'step_wise'
[    0.244205] thermal_sys: Registered thermal governor 'power_allocator'
[    0.250362] cpuidle: using governor menu
[    0.261101] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.268062] ASID allocator initialised with 65536 entries
[    0.282106] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.293137] Modules: 27680 pages in range for non-PLT usage
[    0.293142] Modules: 519200 pages in range for PLT usage
[    0.299282] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.311657] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.318059] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.324993] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.331395] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.338329] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.344730] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.351664] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.358867] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
[    0.368197] iommu: Default domain type: Translated
[    0.373113] iommu: DMA domain TLB invalidation policy: strict mode
[    0.379554] SCSI subsystem initialized
[    0.383542] usbcore: registered new interface driver usbfs
[    0.389167] usbcore: registered new interface driver hub
[    0.394605] usbcore: registered new device driver usb
[    0.399998] pps_core: LinuxPPS API ver. 1 registered
[    0.405071] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.414409] PTP clock support registered
[    0.418510] EDAC MC: Ver: 3.0.0
[    0.421958] scmi_core: SCMI protocol bus registered
[    0.427101] FPGA manager framework
[    0.430614] Advanced Linux Sound Architecture Driver Initialized.
[    0.437278] vgaarb: loaded
[    0.440204] clocksource: Switched to clocksource arch_sys_counter
[    0.446581] VFS: Disk quotas dquot_6.6.0
[    0.450606] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.460876] NET: Registered PF_INET protocol family
[    0.466173] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.475214] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.483990] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.491919] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.500152] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.508918] TCP: Hash tables configured (established 32768 bind 32768)
[    0.515752] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.522686] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.530119] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.536245] RPC: Registered named UNIX socket transport module.
[    0.542301] RPC: Registered udp transport module.
[    0.547105] RPC: Registered tcp transport module.
[    0.551908] RPC: Registered tcp-with-tls transport module.
[    0.557517] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.564102] NET: Registered PF_XDP protocol family
[    0.569007] PCI: CLS 0 bytes, default 64
[    0.573681] Initialise system trusted keyrings
[    0.578346] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.585130] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.591264] NFS: Registering the id_resolver key type
[    0.596451] Key type id_resolver registered
[    0.600725] Key type id_legacy registered
[    0.604828] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.611677] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.632892] Key type asymmetric registered
[    0.637081] Asymmetric key parser 'x509' registered
[    0.642093] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.649654] io scheduler mq-deadline registered
[    0.654280] io scheduler kyber registered
[    0.658395] io scheduler bfq registered
[    0.664123] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.670137] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
[    0.675931] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
[    0.682141] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
[    0.688069] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.693827] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.699531] pinctrl-single 11c000.pinctrl: 67 pins, size 268
[    0.705563] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
[    0.711565] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.721052] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.732615] loop: module loaded
[    0.736405] megasas: 07.725.01.00-rc1
[    0.741947] tun: Universal TUN/TAP device driver, 1.6
[    0.747728] VFIO - User Level meta-driver version: 0.3
[    0.753630] usbcore: registered new interface driver usb-storage
[    0.760108] i2c_dev: i2c /dev entries driver
[    0.765107] sdhci: Secure Digital Host Controller Interface driver
[    0.771431] sdhci: Copyright(c) Pierre Ossman
[    0.776005] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.782123] ledtrig-cpu: registered to indicate activity on CPUs
[    0.788441] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.795436] usbcore: registered new interface driver usbhid
[    0.801136] usbhid: USB HID core driver
[    0.805873] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.814547] optee: probing for conduit method.
[    0.819102] optee: revision 4.2 (12d7c4ee)
[    0.835535] optee: dynamic shared memory is enabled
[    0.845136] random: crng init done
[    0.848674] optee: initialized driver
[    0.853633] NET: Registered PF_PACKET protocol family
[    0.858855] Key type dns_resolver registered
[    0.866675] registered taskstats version 1
[    0.870948] Loading compiled-in X.509 certificates
[    0.883541] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    0.957614] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    0.964095] pca953x 1-0021: supply vcc not found, using dummy regulator
[    0.970929] pca953x 1-0021: using no AI
[    0.996623] pca953x 1-0020: supply vcc not found, using dummy regulator
[    1.003442] pca953x 1-0020: using no AI
[    1.007993] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.014818] pca953x 1-0022: using AI
[    1.019096] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    1.025277] pca953x 2-0020: supply vcc not found, using dummy regulator
[    1.032101] pca953x 2-0020: using no AI
[    1.056517] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
[    1.062245] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    1.071039] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    1.080428] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    1.089060] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
[    1.099046] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[    1.108937] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.115698] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.126114] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
[    1.136284] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.143043] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.151204] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 268, base_baud = 6000000) is a 8250
[    1.160872] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 269, base_baud = 3000000) is a 8250
[    1.169799] printk: console [ttyS2] enabled
[    1.178254] printk: bootconsole [ns16550a0] disabled
[    1.192876] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 270, base_baud = 3000000) is a 8250
[    1.202062] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 271, base_baud = 3000000) is a 8250
[    1.211880] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.256208] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.266154] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.274433] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.287291] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.294501] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.300696] pps pps0: new PPS source ptp0
[    1.304856] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    1.315238] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    1.324062] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
[    1.330691] mmc0: CQHCI version 5.10
[    1.330956] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
[    1.372751] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.467201] mmc0: Command Queue Engine enabled
[    1.471648] mmc0: new HS400 MMC card at address 0001
[    1.476964] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.482490]  mmcblk0:
[    1.484974] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.490606] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.496321] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    1.621875] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    1.627839] tps6594-rtc tps6594-rtc.4.auto: hctosys: unable to read the hardware clock
[    1.664634] vdd_core_0v85: Bringing 800000uV into 850000-850000uV
[    1.777958] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.785463] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.793545] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.801625] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.820820] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    2.827099] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.832576] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    2.842035] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    2.848914] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
[    2.855006] pci 0000:00:00.0: supports D1
[    2.859007] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.864757] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    2.871618] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    2.882865] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.890977] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.897593] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[    2.904891] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.909910] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    2.916693] pcieport 0000:00:00.0: PME: Signaling with IRQ 617
[    2.922668] pcieport 0000:00:00.0: AER: enabled with IRQ 617
[    2.929172] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    2.939357] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
[    2.951890] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    2.956915] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
[    2.963998] Creating 7 MTD partitions on "47040000.spi.0":
[    2.969475] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[    2.975542] 0x000000100000-0x000000300000 : "ospi.tispl"
[    2.981313] 0x000000300000-0x000000700000 : "ospi.u-boot"
[    2.987167] 0x000000700000-0x000000740000 : "ospi.env"
[    2.992766] 0x000000740000-0x000000780000 : "ospi.env.backup"
[    2.998963] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    3.004845] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    3.015122] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    3.060207] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.070203] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    3.078479] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    3.091346] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.098558] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.104719] pps pps0: new PPS source ptp1
[    3.108884] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    3.125072] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.135778] debugfs: Directory 'pd:49' with parent 'pm_genpd' already present!
[    3.136100] mmc1: CQHCI version 5.10
[    3.144338] debugfs: Directory 'pd:35' with parent 'pm_genpd' already present!
[    3.154232] clk: Disabling unused clocks
[    3.170663] ALSA device list:
[    3.173632]   No soundcards found.
[    3.186794] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.194380] Waiting for root device PARTUUID=076c4a2a-02...
[    3.246552] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    3.253580] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    3.262345]  mmcblk1: p1 p2
[    3.596859] EXT4-fs (mmcblk1p2): recovery complete
[    3.602656] EXT4-fs (mmcblk1p2): mounted filesystem 722d204a-d2eb-4a9a-acd1-331dd3afee1c r/w with ordered data mode. Quota mode: none.
[    3.614775] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    3.623236] devtmpfs: mounted
[    3.627659] Freeing unused kernel memory: 2432K
[    3.632293] Run /sbin/init as init process
[    3.822317] systemd[1]: System time before build time, advancing clock.
[    3.863746] NET: Registered PF_INET6 protocol family
[    3.869304] Segment Routing with IPv6
[    3.872986] In-situ OAM (IOAM) with IPv6
[    3.904424] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.936318] systemd[1]: Detected architecture arm64.
[    3.958353] systemd[1]: Hostname set to <j7200-evm>.
[    4.161162] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.227050] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.278682] systemd[1]: Queued start job for default target Graphical Interface.
[    4.315202] systemd[1]: Created slice Slice /system/getty.
[    4.337451] systemd[1]: Created slice Slice /system/modprobe.
[    4.361336] systemd[1]: Created slice Slice /system/serial-getty.
[    4.385099] systemd[1]: Created slice User and Session Slice.
[    4.408432] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    4.432366] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.456289] systemd[1]: Expecting device /dev/ttyS2...
[    4.476314] systemd[1]: Reached target Path Units.
[    4.496278] systemd[1]: Reached target Remote File Systems.
[    4.516263] systemd[1]: Reached target Slice Units.
[    4.536266] systemd[1]: Reached target Swaps.
[    4.578980] systemd[1]: Listening on RPCbind Server Activation Socket.
[    4.600384] systemd[1]: Reached target RPC Port Mapper.
[    4.623729] systemd[1]: Listening on Process Core Dump Socket.
[    4.644503] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    4.668867] systemd[1]: Listening on Journal Audit Socket.
[    4.692608] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.712608] systemd[1]: Listening on Journal Socket.
[    4.728674] systemd[1]: Listening on Network Service Netlink Socket.
[    4.757277] systemd[1]: Listening on udev Control Socket.
[    4.780537] systemd[1]: Listening on udev Kernel Socket.
[    4.800545] systemd[1]: Listening on User Database Manager Socket.
[    4.852424] systemd[1]: Mounting Huge Pages File System...
[    4.870470] systemd[1]: Mounting POSIX Message Queue File System...
[    4.896589] systemd[1]: Mounting Kernel Debug File System...
[    4.920574] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.937951] systemd[1]: Mounting Temporary Directory /tmp...
[    4.956752] systemd[1]: Starting Create List of Static Device Nodes...
[    4.984870] systemd[1]: Starting Load Kernel Module configfs...
[    5.028780] systemd[1]: Starting Load Kernel Module drm...
[    5.052863] systemd[1]: Starting Load Kernel Module fuse...
[    5.088673] systemd[1]: Starting RPC Bind...
[    5.102762] fuse: init (API version 7.39)
[    5.108496] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    5.124968] systemd[1]: Starting Journal Service...
[    5.156720] systemd[1]: Starting Load Kernel Modules...
[    5.184748] systemd-journald[110]: Collecting audit messages is enabled.
[    5.201528] systemd[1]: Starting Generate network units from Kernel command line...
[    5.234438] cryptodev: loading out-of-tree module taints kernel.
[    5.242545] cryptodev: driver 1.13 loaded.
[    5.248686] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.281707] systemd[1]: Starting Coldplug All udev Devices...
[    5.287168] EXT4-fs (mmcblk1p2): re-mounted 722d204a-d2eb-4a9a-acd1-331dd3afee1c r/w. Quota mode: none.
[    5.302178] systemd[1]: Started RPC Bind.
[    5.328691] systemd[1]: Started Journal Service.
[    5.665287] systemd-journald[110]: Received client request to flush runtime journal.
[    5.925711] audit: type=1334 audit(1709054766.100:2): prog-id=6 op=LOAD
[    5.932761] audit: type=1334 audit(1709054766.108:3): prog-id=7 op=LOAD
[    6.191261] audit: type=1334 audit(1709054766.364:4): prog-id=8 op=LOAD
[    6.222479] audit: type=1334 audit(1709054766.396:5): prog-id=9 op=LOAD
[    6.365239] audit: type=1334 audit(1709054766.540:6): prog-id=10 op=LOAD
[    6.385917] audit: type=1334 audit(1709054766.548:7): prog-id=11 op=LOAD
[    6.408275] audit: type=1334 audit(1709054766.548:8): prog-id=12 op=LOAD
[  OK  ] Started Daily rotation of log files.
[    7.119615] CAN device driver interface
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
[    7.150099] ti-udma 285c0000.dma-controller: chan1: is running!
         Starting Weston socket...
[    7.182774] audit: type=1334 audit(1709137476.720:9): prog-id=13 op=LOAD
[    7.193143] at24 0-0050: supply vcc not found, using dummy regulator
[    7.211492] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Weston socket.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[    7.352696] dbus-broker-lau[372]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    7.401609] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[    7.513978] platform 41000000.r5f: configured R5F for IPC-only mode
[    7.528108] m_can_platform 2701000.can: m_can device registered (irq=709, version=32)
[    7.530060] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
         Starting Print notice about GPLv3 packages[    7.546857] remoteproc remoteproc0: 41000000.r5f is available
[    7.547301] m_can_platform 40528000.can: m_can device registered (irq=710, version=32)
[    7.564700] gpio-mux mux-controller-0: 2-way mux-controller registered
         Starting IPv6 Packet Filtering Framework..[    7.571862] remoteproc remoteproc0: attaching to 41000000.r5f
[    7.583479] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    7.583494] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node r5f-dma-memory@a0000000
[    7.583614] m_can_platform 40568000.can: m_can device registered (irq=711, version=32)
[    7.584150] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.613450] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.621085] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.630927] rproc-virtio rproc-virtio.11.auto: registered virtio0 (type 7)
[    7.637982] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
[    7.639422] gpio-mux mux-controller-1: 2-way mux-controller registered
[    7.649882] platform 5c00000.r5f: configured R5F for IPC-only mode
         Starting IPv4 Packet Filtering Framework..[    7.658978] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[    7.675814] remoteproc remoteproc1: 5c00000.r5f is available
[  OK  ] Started irqbalance daemon.
[    7.681829] remoteproc remoteproc1: attaching to 5c00000.r5f
[    7.693470] m_can_platform 2731000.can: m_can device registered (irq=712, version=32)
[    7.700693] platform 5c00000.r5f: R5F core initialized in IPC-only mode
         Starting Telephony service...
[  OK  ] Started     7.725013] audit: type=1334 audit(1709137477.264:10): prog-id=14 op=LOAD
;1;39mstrongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[    7.743591] audit: type=1334 audit(1709137477.280:11): prog-id=15 op=LOAD
         Starting User Login Management...
[  OK  ] Reached target Preparation for Network.
[    7.867050] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node r5f-dma-memory@a2000000
[    7.898177] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.ethdevice addr 0x65
[  OK  ] Started Avahi mDNS/DNS-SD Stack[    7.906668] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[  OK  ] Started Telephony service.
[    7.927079] virtio_rpmsg_bus virtio1: rpmsg host is online
[    7.955916] rproc-virtio rproc-virtio.12.auto: registered virtio1 (type 7)
[    7.964683] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
[    7.997930] platform 5d00000.r5f: configured R5F for IPC-only mode
[    8.027043] Bluetooth: Core ver 2.22
[    8.036308] NET: Registered PF_BLUETOOTH protocol family
[    8.046718] Bluetooth: HCI device and connection manager initialized
[    8.051101] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[    8.060230] Bluetooth: HCI socket layer initialized
[    8.068241] Bluetooth: L2CAP socket layer initialized
[    8.076340] Bluetooth: SCO socket layer initialized
[    8.121292] remoteproc remoteproc2: 5d00000.r5f is available
[    8.127035] remoteproc remoteproc2: attaching to 5d00000.r5f
[    8.150348] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    8.165725] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node r5f-dma-memory@a3000000
[    8.176085] virtio_rpmsg_bus virtio2: rpmsg host is online
[  OK  ] Finished Expand the rootfs partitio[    8.182467] rproc-virtio rproc-virtio.13.auto: registered virtio2 (type 7)
[    8.183800] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[    8.194316] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
[    8.205439] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
         Starting Virtual Console Setup...
[    8.289330] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.296563] m_can_platform 2701000.can main_mcan0: renamed from can0
[    8.311014] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.317712] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    8.417642] m_can_platform 40568000.can mcu_mcan1: renamed from can2
[    8.475419] m_can_platform 40528000.can mcu_mcan0: renamed from can1
[  OK  ] Finished Virtual Console Setup.
[    8.580156] m_can_platform 2731000.can main_mcan3: renamed from can3
[    8.633584] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
[    8.657405] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 0, Type: Switch Port, Iface: eth1, Num TX: 2, Num RX: 1, Token: 0
[    8.672849] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 4, Type: MAC Port, Iface: eth2, Num TX: 1, Num RX: 1, Token: 400
         Starting Enable and configure wl18xx bluetooth stack...
         Starting Simple Network Management Protocol (SNMP) Daemon....
[    8.787345] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    8.797114] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
         Starting Weston, a Wayland compositor, as a system service...
[    8.961165] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 4 on interface eth2
[    8.995467] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 0 on interface eth1
[    9.019481] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 01:80:c2:00:00:0e is reserved for EthFw
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Created slice Slice /system/systemd-fsck.
         Expecting device /dev/mmcblk1p1...
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
         Mounting /run/media/boot-mmcblk1p1...
[  OK  ] Started User Manager for UID 1000.
[  OK  ] Started Session c1 of User weston.
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Mounted /run/media/boot-mmcblk1p1.
[FAILED] Failed to start Weston, a Wayland compositor, as a system service.
See 'systemctl status weston.service' for details.
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        kbd-dev
        kbd-keymaps-pine
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring5
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
NOTE: If the package is a dependency of another package you
[  OK  ] Reached target Graphical Interface.
[  OK  ] Finished Record Runlevel Change in UTMP.
 _____                    _____           _         _
              |___|                    |___|
Arago Project j7200-evm ttyS2
Arago 2023.10 j7200-evm ttyS2
j7200-evm login: root
[   19.859117] kauditd_printk_skb: 8 callbacks suppressed
[   19.859124] audit: type=1006 audit(1709137489.396:16): pid=946 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[   19.876959] audit: type=1300 audit(1709137489.396:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd285bf68 a2=1 a3=1 items=0 ppid=1 pid=946 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[   19.903449] audit: type=1327 audit(1709137489.396:16): proctitle="(systemd)"
[   19.910522] audit: type=1334 audit(1709137489.416:17): prog-id=18 op=LOAD
[   19.917343] audit: type=1300 audit(1709137489.416:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffce751298 a2=90 a3=0 items=0 ppid=1 pid=946 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   19.943058] audit: type=1327 audit(1709137489.416:17): proctitle="(systemd)"
[   19.950140] audit: type=1334 audit(1709137489.440:18): prog-id=18 op=UNLOAD
[   19.957122] audit: type=1300 audit(1709137489.440:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffb335bc60 items=0 ppid=1 pid=946 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   19.982673] audit: type=1327 audit(1709137489.440:18): proctitle="(systemd)"
[   19.989729] audit: type=1334 audit(1709137489.444:19): prog-id=19 op=LOAD
root@j7200-evm:~#
root@j7200-evm:~#
root@j7200-evm:~#
root@j7200-evm:~# pip
-sh: pip: command not found
root@j7200-evm:~# uname -a
Linux j7200-evm 6.6.32-ti-01287-g6de6e418c80e-dirty #1 SMP PREEMPT Fri Jul 26 14:32:20 UTC 2024 aarch64 GNU/Linux
root@j7200-evm:~# shutdown -r now
root@j7200-evm:~#      [  OK  ] Removed slice Slice /system/modprobe.
[  OK  ] Stopped target Graphical Interface.
[  OK  ] Stopped Daily rotation of log files.
         Stopping Job spooling tools...
         Stopping Periodic Command Scheduler...
         Stopping irqbalance daemon...
         Stopping Reboot and dump vmcore via kexec...
         Stopping Telephony service...
         Stopping Simple Network Management Protocol (SNMP) Daemon....
[  OK  ] Stopped Job spooling tools.
[  OK  ] Stopped Periodic Command Scheduler.
[  OK  ] Stopped irqbalance daemon.
[  OK  ] Stopped Telephony service.
[  OK  ] Stopped Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Stopped Reboot and dump vmcore via kexec.
[  OK  ] Stopped Session c2 of User root.
[ 7752.725851] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 01:80:c2:00:00:0e is reserved for EthFw
[ 7752.799262] kauditd_printk_skb: 5 callbacks suppressed
[ 7752.799269] audit: type=1334 audit(1709145222.336:21): prog-id=14 op=UNLOAD
[  OK  ] Removed slice User Slice of UID 0 7752.811550] audit: type=1334 audit(1709145222.336:22): prog-id=17 op=UNLOAD
0m.
[  OK  ] Closed PC/SC Smart Card Daemon Activation Socket.
[  OK  ] Closed Weston socket.
[  OK  ] Closed D-Bus System Message Bus Soc[ 7753.184402] audit: type=1334 audit(1709145222.724:23): prog-id=13 op=UNLOAD
ket.
[ 7753.301770] audit: type=1334 audit(1709145222.840:24): prog-id=9 op=UNLOAD
[ 7753.308721] audit: type=1334 audit(1709145222.844:25): prog-id=8 op=UNLOAD
         Unmounting /run/media/boot-mmcblk1p1...
[  OK  ] Unmounted /run/media/boot-mmcblk1p1.
[  OK  ] Stopped File System Check on /dev/mmcblk1p1.
[  OK  ] Removed slice Slice /system/systemd-fsck.
[ 7753.724790] audit: type=1334 audit(1709145223.264:26): prog-id=12 op=UNLOAD
[ 7753.732353] audit: type=1334 audit(1709145223.264:27): prog-id=11 op=UNLOAD
[ 7753.739338] audit: type=1334 audit(1709145223.264:28): prog-id=10 op=UNLOAD
[ 7753.746313] audit: type=1334 audit(1709145223.264:29): prog-id=16 op=UNLOAD
[ 7753.753278] audit: type=1334 audit(1709145223.264:30): prog-id=15 op=UNLOAD
[ 7753.776832] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 7753.784414] watchdog: watchdog0: watchdog did not stop!
[ 7753.801795] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0
[ 7753.811768] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout.
[ 7753.821694] systemd-shutdown[1]: Watchdog running with a timeout of 1min.
[ 7753.857424] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 7753.895785] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 7753.911377] systemd-journald[110]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 7753.930864] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 7753.943876] systemd-shutdown[1]: Unmounting file systems.
[ 7753.951036] (sd-remount)[1098]: Remounting '/' read-only with options ''.
[ 7753.987461] EXT4-fs (mmcblk1p2): re-mounted 722d204a-d2eb-4a9a-acd1-331dd3afee1c ro. Quota mode: none.
[ 7754.000262] systemd-shutdown[1]: All filesystems unmounted.
[ 7754.006022] systemd-shutdown[1]: Deactivating swaps.
[ 7754.011120] systemd-shutdown[1]: All swaps deactivated.
[ 7754.016393] systemd-shutdown[1]: Detaching loop devices.
[ 7754.024665] systemd-shutdown[1]: All loop devices detached.
[ 7754.030268] systemd-shutdown[1]: Stopping MD devices.
[ 7754.035481] systemd-shutdown[1]: All MD devices stopped.
[ 7754.041041] systemd-shutdown[1]: Detaching DM devices.
[ 7754.046318] systemd-shutdown[1]: All DM devices detached.
[ 7754.051721] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[ 7754.061372] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 7754.068242] systemd-shutdown[1]: Failed to disable hardware watchdog, ignoring: Device or resource busy
[ 7754.077621] watchdog: watchdog0: nowayout prevents watchdog being stopped!
[ 7754.084482] watchdog: watchdog0: watchdog did not stop!
[ 7754.096444] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 7754.103177] systemd-shutdown[1]: Rebooting.
[ 7754.119143] reboot: Restarting system
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
Warning: Detected image signing certificate on GP device. Skipping certificate to prevent boot failure. This will fail if the image was also encrypted
Loading Environment from nowhere... OK
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
I/TC:
I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
SoC:   J7200 SR2.0 GP
Flash: 0 Bytes
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work
880124 bytes read in 66 ms (12.7 MiB/s)
75416 bytes read in 58 ms (1.2 MiB/s)
Load Remote Processor 3 with data@addr=0x82000000 75416 bytes: Success!
79882 bytes read in 15 ms (5.1 MiB/s)
Working FDT set to 88000000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a47fffff (8192 KiB) nomap non-reusable ipc-memories@a4000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
[    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000ffffffff]
[    0.000000] cma: Reserved 32 MiB at 0x00000000fe000000 on node -1
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 20 pages/cpu s42920 r8192 d30808 u81920
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000fa000000-0x00000000fe000000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880040000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008361] Console: colour dummy device 80x25
[    0.012926] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023598] pid_max: default: 32768 minimum: 301
[    0.028356] LSM: initializing lsm=capability,integrity
[    0.033664] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.041241] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.050138] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.057407] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.065272] rcu: Hierarchical SRCU implementation.
[    0.070172] rcu:     Max phase no-delay instances is 1000.
[    0.075698] Platform MSI: msi-controller@1820000 domain created
[    0.081866] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.091251] EFI services will not be available.
[    0.095995] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
[    0.109183] Detected PIPT I-cache on CPU1
[    0.109230] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.109245] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[    0.109279] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.109337] smp: Brought up 1 node, 2 CPUs
[    0.138688] SMP: Total of 2 processors activated.
[    0.143492] CPU features: detected: 32-bit EL0 Support
[    0.148746] CPU features: detected: CRC32 instructions
[    0.154028] CPU: All CPU(s) started at EL2
[    0.158210] alternatives: applying system-wide alternatives
[    0.164790] devtmpfs: initialized
[    0.173072] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.183051] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.190603] pinctrl core: initialized pinctrl subsystem
[    0.196200] DMI not present or invalid.
[    0.200650] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.207138] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.214454] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.222494] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.230618] audit: initializing netlink subsys (disabled)
[    0.236238] audit: type=2000 audit(0.152:1): state=initialized audit_enabled=0 res=1
[    0.236443] thermal_sys: Registered thermal governor 'step_wise'
[    0.244161] thermal_sys: Registered thermal governor 'power_allocator'
[    0.250318] cpuidle: using governor menu
[    0.261059] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.268021] ASID allocator initialised with 65536 entries
[    0.281790] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@100000/pinctrl@a40000/mcu-cpsw-cpts
[    0.292830] Modules: 27680 pages in range for non-PLT usage
[    0.292836] Modules: 519200 pages in range for PLT usage
[    0.298969] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.311344] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.317747] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.324681] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.331083] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.338017] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.344418] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.351352] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.358548] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR2.0 JTAGID[0x1bb6d02f] Detected
[    0.367882] iommu: Default domain type: Translated
[    0.372789] iommu: DMA domain TLB invalidation policy: strict mode
[    0.379240] SCSI subsystem initialized
[    0.383229] usbcore: registered new interface driver usbfs
[    0.388856] usbcore: registered new interface driver hub
[    0.394295] usbcore: registered new device driver usb
[    0.399690] pps_core: LinuxPPS API ver. 1 registered
[    0.404763] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.414101] PTP clock support registered
[    0.418200] EDAC MC: Ver: 3.0.0
[    0.421658] scmi_core: SCMI protocol bus registered
[    0.426797] FPGA manager framework
[    0.430309] Advanced Linux Sound Architecture Driver Initialized.
[    0.436967] vgaarb: loaded
[    0.439891] clocksource: Switched to clocksource arch_sys_counter
[    0.446261] VFS: Disk quotas dquot_6.6.0
[    0.450295] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.460567] NET: Registered PF_INET protocol family
[    0.465862] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.474851] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.483625] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.491554] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.499782] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.508539] TCP: Hash tables configured (established 32768 bind 32768)
[    0.515381] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.522327] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.529760] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.535921] RPC: Registered named UNIX socket transport module.
[    0.541974] RPC: Registered udp transport module.
[    0.546777] RPC: Registered tcp transport module.
[    0.551580] RPC: Registered tcp-with-tls transport module.
[    0.557183] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.563766] NET: Registered PF_XDP protocol family
[    0.568671] PCI: CLS 0 bytes, default 64
[    0.573367] Initialise system trusted keyrings
[    0.578031] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.584810] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.590939] NFS: Registering the id_resolver key type
[    0.596122] Key type id_resolver registered
[    0.600396] Key type id_legacy registered
[    0.604499] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.611348] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.632654] Key type asymmetric registered
[    0.636843] Asymmetric key parser 'x509' registered
[    0.641853] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.649413] io scheduler mq-deadline registered
[    0.654040] io scheduler kyber registered
[    0.658154] io scheduler bfq registered
[    0.663861] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.669878] pinctrl-single 4301c038.pinctrl: 2 pins, size 8
[    0.675671] pinctrl-single 4301c068.pinctrl: 59 pins, size 236
[    0.681883] pinctrl-single 4301c174.pinctrl: 8 pins, size 32
[    0.687816] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.693569] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.699277] pinctrl-single 11c000.pinctrl: 67 pins, size 268
[    0.705310] pinctrl-single 11c11c.pinctrl: 3 pins, size 12
[    0.711303] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.720735] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.732385] loop: module loaded
[    0.736195] megasas: 07.725.01.00-rc1
[    0.741749] tun: Universal TUN/TAP device driver, 1.6
[    0.747509] VFIO - User Level meta-driver version: 0.3
[    0.753378] usbcore: registered new interface driver usb-storage
[    0.759830] i2c_dev: i2c /dev entries driver
[    0.764833] sdhci: Secure Digital Host Controller Interface driver
[    0.771160] sdhci: Copyright(c) Pierre Ossman
[    0.775725] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.781822] ledtrig-cpu: registered to indicate activity on CPUs
[    0.788121] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.795108] usbcore: registered new interface driver usbhid
[    0.800806] usbhid: USB HID core driver
[    0.805527] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.814158] optee: probing for conduit method.
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.818715] optee: revision 4.2 (12d7c4ee)
[    0.835156] optee: dynamic shared memory is enabled
[    0.844763] random: crng init done
[    0.848303] optee: initialized driver
[    0.853254] NET: Registered PF_PACKET protocol family
[    0.858468] Key type dns_resolver registered
[    0.866297] registered taskstats version 1
[    0.870693] Loading compiled-in X.509 certificates
[    0.883027] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
[    0.958172] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    0.964671] pca953x 1-0021: supply vcc not found, using dummy regulator
[    0.971501] pca953x 1-0021: using no AI
[    0.988330] pca953x 1-0020: supply vcc not found, using dummy regulator
[    0.995173] pca953x 1-0020: using no AI
[    0.999749] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.006563] pca953x 1-0022: using AI
[    1.010832] omap_i2c 2000000.i2c: bus 1 rev0.12 at 400 kHz
[    1.017007] pca953x 2-0020: supply vcc not found, using dummy regulator
[    1.023833] pca953x 2-0020: using no AI
[    1.048206] omap_i2c 2010000.i2c: bus 2 rev0.12 at 400 kHz
[    1.054152] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 137 domain created
[    1.062706] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 131 domain created
[    1.072047] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 213 domain created
[    1.080644] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
[    1.090591] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[    1.100481] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.107243] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.117675] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
[    1.127833] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.134592] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    1.142738] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 268, base_baud = 6000000) is a 8250
[    1.152450] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 269, base_baud = 3000000) is a 8250
[    1.161368] printk: console [ttyS2] enabled
[    1.169824] printk: bootconsole [ns16550a0] disabled
[    1.192574] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 270, base_baud = 3000000) is a 8250
[    1.201786] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 271, base_baud = 3000000) is a 8250
[    1.211632] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    1.255895] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.265856] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.274135] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    1.286987] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.294196] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.300397] pps pps0: new PPS source ptp0
[    1.304557] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    1.314960] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    1.323777] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
[    1.330401] mmc0: CQHCI version 5.10
[    1.330670] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
[    1.372440] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.466112] mmc0: Command Queue Engine enabled
[    1.470565] mmc0: new HS400 MMC card at address 0001
[    1.475912] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    1.481437]  mmcblk0:
[    1.483938] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    1.489696] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    1.495341] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    1.559011] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    1.565669] tps6594-rtc tps6594-rtc.4.auto: setting system clock to 2024-02-28T18:33:52 UTC (1709145232)
[    1.710972] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.718476] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.726559] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.734643] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.752497] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    2.758783] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.764269] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    2.773729] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    2.780610] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
[    2.786705] pci 0000:00:00.0: supports D1
[    2.790707] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.796458] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[    2.803318] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[    2.814315] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.822405] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.829020] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[    2.836318] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.841337] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    2.848109] pcieport 0000:00:00.0: PME: Signaling with IRQ 617
[    2.854118] pcieport 0000:00:00.0: AER: enabled with IRQ 617
[    2.860645] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    2.870817] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
[    2.883378] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    2.888397] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
[    2.895478] Creating 7 MTD partitions on "47040000.spi.0":
[    2.900960] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[    2.907034] 0x000000100000-0x000000300000 : "ospi.tispl"
[    2.912827] 0x000000300000-0x000000700000 : "ospi.u-boot"
[    2.918703] 0x000000700000-0x000000740000 : "ospi.env"
[    2.924311] 0x000000740000-0x000000780000 : "ospi.env.backup"
[    2.930510] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    2.936369] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    2.946917] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[    2.991899] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    3.001891] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    3.010170] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    3.023037] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    3.030247] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    3.036404] pps pps0: new PPS source ptp1
[    3.040559] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    3.056738] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    3.067464] debugfs: Directory 'pd:49' with parent 'pm_genpd' already present!
[    3.067748] mmc1: CQHCI version 5.10
[    3.076011] debugfs: Directory 'pd:35' with parent 'pm_genpd' already present!
[    3.085914] clk: Disabling unused clocks
[    3.102379] ALSA device list:
[    3.105349]   No soundcards found.
[    3.118485] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.126079] Waiting for root device PARTUUID=076c4a2a-02...
[    3.178099] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    3.185131] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    3.193861]  mmcblk1: p1 p2
[    3.378307] EXT4-fs (mmcblk1p2): mounted filesystem 722d204a-d2eb-4a9a-acd1-331dd3afee1c r/w with ordered data mode. Quota mode: none.
[    3.390469] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    3.400021] devtmpfs: mounted
[    3.404470] Freeing unused kernel memory: 2432K
[    3.409085] Run /sbin/init as init process
[    3.637748] NET: Registered PF_INET6 protocol family
[    3.643296] Segment Routing with IPv6
[    3.646976] In-situ OAM (IOAM) with IPv6
[    3.678506] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    3.710317] systemd[1]: Detected architecture arm64.
Welcome to Arago 2023.10!
[    3.736077] systemd[1]: Hostname set to <j7200-evm>.
[    3.942180] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.008916] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.061124] systemd[1]: Queued start job for default target Graphical Interface.
[    4.110850] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    4.133169] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    4.157022] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    4.180803] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.204140] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    4.228056] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    4.251983] systemd[1]: Expecting device /dev/ttyS2...
[    4.267999] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    4.283957] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.303948] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    4.319952] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    4.362765] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    4.384067] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    4.409279] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    4.432158] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.456556] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    4.480316] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.504304] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.524345] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.553057] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.576237] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.596245] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    4.644117] systemd[1]: Mounting Huge Pages File System...
[    4.666165] systemd[1]: Mounting POSIX Message Queue File System...
[    4.692557] systemd[1]: Mounting Kernel Debug File System...
[    4.712260] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.729605] systemd[1]: Mounting Temporary Directory /tmp...
[    4.771737] systemd[1]: Starting Create List of Static Device Nodes...
         Starting Create List of Static Device Nodes    4.780922] systemd[1]: Starting Load Kernel Module configfs...
m...
[    4.820624] systemd[1]: Starting Load Kernel Module drm...
[    4.844594] systemd[1]: Starting Load Kernel Module fuse...
[    4.885254] systemd[1]: Starting RPC Bind...
[    4.895064] fuse: init (API version 7.39)
[    4.900237] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    4.916634] systemd[1]: Starting Journal Service...
[    4.960428] systemd[1]: Starting Load Kernel Modules...
[    4.992862] systemd-journald[110]: Collecting audit messages is enabled.
[    5.008369] systemd[1]: Starting Generate network units from Kernel command line...
[    5.032508] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
[0m...
[    5.052754] cryptodev: driver 1.13 loaded.
[    5.077202] systemd[1]: Starting Coldplug All udev Devices...
[    5.099260] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    5.116450] EXT4-fs (mmcblk1p2): re-mounted 722d204a-d2eb-4a9a-acd1-331dd3afee1c r/w. Quota mode: none.
[    5.127756] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    5.497184] systemd-journald[110]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev gracefully...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    5.741384] audit: type=1334 audit(1709145236.672:2): prog-id=6 op=LOAD
[    5.748351] audit: type=1334 audit(1709145236.680:3): prog-id=7 op=LOAD
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create Volatile Files and Directories.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[    5.966047] audit: type=1334 audit(1709145236.896:4): prog-id=8 op=LOAD
         Starting Network Name Resolution...
[    6.018276] audit: type=1334 audit(1709145236.948:5): prog-id=9 op=LOAD
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Found device /dev/ttyS2.
[    6.133318] audit: type=1334 audit(1709145237.060:6): prog-id=10 op=LOAD
[    6.152018] audit: type=1334 audit(1709145237.072:7): prog-id=11 op=LOAD
[    6.163947] audit: type=1334 audit(1709145237.072:8): prog-id=12 op=LOAD
         Starting User Database Manager...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started User Database Manager.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[    6.923363] audit: type=1334 audit(1709145237.852:9): prog-id=13 op=LOAD
         Starting D-Bus System Message Bus...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Socket Units.
[  OK  ] Started D-Bus System Message Bus.
[    7.048807] CAN device driver interface
[  OK  ] Reached target Basic System.
[    7.088582] dbus-broker-lau[380]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
         Starting Avahi mDNS/DNS-SD Stack...
[    7.201484] at24 0-0050: supply vcc not found, using dummy regulator
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework..[    7.254501] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    7.299871] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    7.300053] ti-udma 285c0000.dma-controller: chan1: is running!
         Starting Expand the rootfs partiti…to full size of the boot device....
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[    7.370163] audit: type=1334 audit(1709145238.300:10): prog-id=14 op=LOAD
[    7.395964] audit: type=1334 audit(1709145238.312:11): prog-id=15 op=LOAD
         Starting Telnet Server...
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[    7.543026] platform 41000000.r5f: configured R5F for IPC-only mode
         Starting Network Configuration...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[    7.617110] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[    7.626759] remoteproc remoteproc0: 41000000.r5f is available
[    7.632607] remoteproc remoteproc0: attaching to 41000000.r5f
[    7.639608] platform 41000000.r5f: R5F core initialized in IPC-only mode
[    7.646401] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node r5f-dma-memory@a0000000
[    7.668576] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.674154] rproc-virtio rproc-virtio.11.auto: registered virtio0 (type 7)
[    7.676987] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.681761] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
[    7.688617] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.730898] Bluetooth: Core ver 2.22
[    7.735248] NET: Registered PF_BLUETOOTH protocol family
[    7.741051] Bluetooth: HCI device and connection manager initialized
[    7.748375] Bluetooth: HCI socket layer initialized
[    7.754793] Bluetooth: L2CAP socket layer initialized
[    7.759976] Bluetooth: SCO socket layer initialized
[    7.798579] m_can_platform 40528000.can: m_can device registered (irq=709, version=32)
[    7.810979] platform 5c00000.r5f: configured R5F for IPC-only mode
[    7.817559] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[    7.827646] remoteproc remoteproc1: 5c00000.r5f is available
[    7.833955] remoteproc remoteproc1: attaching to 5c00000.r5f
[    7.843242] m_can_platform 40568000.can: m_can device registered (irq=710, version=32)
[    7.873704] platform 5c00000.r5f: R5F core initialized in IPC-only mode
[    7.881588] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node r5f-dma-memory@a2000000
[    7.898068] m_can_platform 2701000.can: m_can device registered (irq=711, version=32)
[    7.903085] virtio_rpmsg_bus virtio1: rpmsg host is online
[    7.912725] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.ethdevice addr 0x65
[    7.917842] rproc-virtio rproc-virtio.12.auto: registered virtio1 (type 7)
[    7.922488] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[    7.935656] remoteproc remoteproc1: remote processor 5c00000.r5f is now attached
[    7.948105] platform 5d00000.r5f: configured R5F for IPC-only mode
[    7.948836] gpio-mux mux-controller-0: 2-way mux-controller registered
[    7.995338] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[    8.000558] remoteproc remoteproc2: 5d00000.r5f is available
[    8.000620] remoteproc remoteproc2: attaching to 5d00000.r5f
[    8.010880] m_can_platform 2731000.can: m_can device registered (irq=712, version=32)
[    8.040645] platform 5d00000.r5f: R5F core initialized in IPC-only mode
[    8.040670] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node r5f-dma-memory@a3000000
[    8.041144] virtio_rpmsg_bus virtio2: rpmsg host is online
[    8.041162] rproc-virtio rproc-virtio.13.auto: registered virtio2 (type 7)
[    8.041167] remoteproc remoteproc2: remote processor 5d00000.r5f is now attached
[    8.047583] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[    8.054402] gpio-mux mux-controller-1: 2-way mux-controller registered
[    8.073957] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[  OK  ] Started User Login Management.
[    8.213261] m_can_platform 2701000.can main_mcan0: renamed from can2
[    8.220051] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.244431] m_can_platform 40568000.can mcu_mcan1: renamed from can1
[    8.253707] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.260304] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    8.348694] m_can_platform 40528000.can mcu_mcan0: renamed from can0
[    8.393276] m_can_platform 2731000.can main_mcan3: renamed from can3
[  OK  ] Started Network Configuration.
[  OK  ] Reached target Network.
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
         Starting Permit User Sessions...
[    8.590776] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    8.608925] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    8.631171] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
[  OK  ] Finished Enable and configure wl18x[    8.642423] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 0, Type: Switch Port, Iface: eth1, Num TX: 2, Num RX: 1, Token: 0
x bluetooth stack.
[    8.661302] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: Virt Port: 4, Type: MAC Port, Iface: eth2, Num TX: 1, Num RX: 1, Token: 400
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[    8.856934] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 4 on interface eth2
[    8.909066] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: started port 0 on interface eth1
[    8.934078] ti_cpsw_proxy_client virtio1.ti.ethfw.ethdevice.-1.101: 01:80:c2:00:00:0e is reserved for EthFw
[  OK  ] Started containerd container runtime.
NOTICE: This file system contains the following GPL-3.0 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        kbd-dev
        kbd-keymaps-pine
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts5
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring5
        m4
        make
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity
        qtdeclarative-tools
        qtdeclarative
        qtlocation-examples
        qtlocation-plugins
        qtlocation
        qtmultimedia
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Finished Print notice about GPLv3 packages.
[  OK  ] Reached target Multi-User System.
         Starting Record Runlevel Change in UTMP...
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
[  356.184757] kauditd_printk_skb: 8 callbacks suppressed
[  356.184763] audit: type=1006 audit(1709145587.116:16): pid=952 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1
[  356.202315] audit: type=1300 audit(1709145587.116:16): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffe1974488 a2=1 a3=1 items=0 ppid=1 pid=952 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null)
[  356.229109] audit: type=1327 audit(1709145587.116:16): proctitle="(systemd)"
[  356.236609] audit: type=1334 audit(1709145587.136:17): prog-id=18 op=LOAD
[  356.243797] audit: type=1300 audit(1709145587.136:17): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc882dfc8 a2=90 a3=0 items=0 ppid=1 pid=952 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[  356.269853] audit: type=1327 audit(1709145587.136:17): proctitle="(systemd)"
[  356.277264] audit: type=1334 audit(1709145587.160:18): prog-id=18 op=UNLOAD
[  356.284551] audit: type=1300 audit(1709145587.160:18): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffa711dc60 items=0 ppid=1 pid=952 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[  356.310385] audit: type=1327 audit(1709145587.160:18): proctitle="(systemd)"
[  356.317627] audit: type=1334 audit(1709145587.160:19): prog-id=19 op=LOAD
root@j7200-evm:~#
  • Hi Charles,
    The reboot command finally lands in ATF:
    File: plat/ti/k3/common/drivers/ti_sci/ti_sci.c
     * ti_sci_core_reboot() - Command to request system reset
     * Return: 0 if all goes well, else appropriate error message
    int ti_sci_core_reboot(void)
            struct ti_sci_msg_req_reboot req;
            struct ti_sci_msg_hdr resp;
            struct ti_sci_xfer xfer;
            int ret;
            ret = ti_sci_setup_one_xfer(TI_SCI_MSG_SYS_RESET, 0,
                                        &req, sizeof(req),
                                        &resp, sizeof(resp),
                                        &xfer);
            if (ret) {
                    ERROR("Message alloc failed (%d)\n", ret);
                    return ret;
            req.domain = TI_SCI_DOMAIN_FULL_SOC_RESET;
            ret = ti_sci_do_xfer(&xfer);
            if (ret) {
                    ERROR("Transfer send failed (%d)\n", ret);
                    return ret;
            return 0;
    Could you check if the control is coming till there on the custom board?
    - Keerthy
  • Hi Keerthy,
    Yes, I can confirm that the control has reached ti_sci_core_reboot(void) function based on the following log. I used ERROR macro at the beginning of the function and clearly the message has been printed out in the last line of the log. What's the next step for trouble-shooting? Thanks.
    Logs after issuing reboot command:
    root@edr:~#          Stopping Session c1 of User root...
    [  OK  ] Stopped target Multi-User System.
    [  OK  ] Stopped target Login Prompts.
    [  OK  ] Stopped target Host and Network Name Lookups.
    [  OK  ] Stopped target RPC Port Mapper.
    [  OK  ] Stopped target System Time Set.
    [  OK  ] Stopped target Timer Units.
    [  OK  ] Stopped Daily Cleanup of Temporary Directories.
    [  OK  ] Stopped target Hardware activated USB gadget.
    [  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Stopping Avahi mDNS/DNS-SD Stack...
             Stopping containerd container runtime...
             Stopping Getty on tty1...
             Stopping Netperf Benchmark Server...
    [  OK  ] Stopped Expand the rootfs partition to full size of the boot device..
             Stopping Serial Getty on ttyS2...
             Stopping Load/Save OS Random Seed...
             Stopping Telnet Server...
    [  OK  ] Stopped Avahi mDNS/DNS-SD Stack.
    [  OK  ] Stopped Netperf Benchmark Server.
    [  OK  ] Stopped containerd container runtime.
    [  OK  ] Stopped Getty on tty1.
    [  OK  ] Stopped Serial Getty on ttyS2.
    [  OK  ] Stopped Load/Save OS Random Seed.
    [  OK  ] Stopped Telnet Server.
    [  OK  ] Stopped Session c1 of User root.
    [  OK  ] Removed slice Slice /system/getty.
    [  OK  ] Removed slice Slice /system/serial-getty.
             Stopping User Login Management...
             Stopping Permit User Sessions...
             Stopping User Manager for UID 0...
    [  OK  ] Stopped User Login Management.
    [  OK  ] Stopped User Manager for UID 0.
    [  OK  ] Stopped Permit User Sessions.
    [   28.658748] kauditd_printk_skb: 5 callbacks suppressed
    [   28.658759] audit: type=1334 audit(1709054789.700:39): prog-id=24 op=UNLOAD
    [  OK  ] Stopped target Network.
    [  OK  ] Stopped target Remote File Systems.
             Stopping Network Configuration...
             Stopping User Runtime Directory /run/user/0...
    [  OK  ] Unmounted /run/user/0.
    [  OK  ] Stopped Network Configuration.
    [  OK  ] Stopped User Runtime Directory /run/user/0.
    [   28.824186] audit: type=1334 audit(1709054789.868:40): prog-id=27 op=UNLOAD
    [  OK  ] Removed slice User Slice of UID 0.
    [  OK  ] Stopped target Preparation for Network.
    [  OK  ] Stopped IPv6 Packet Filtering Framework.
    [  OK  ] Stopped IPv4 Packet Filtering Framework.
    [  OK  ] Stopped target Basic System.
    [  OK  ] Stopped target Path Units.
    [  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
    [  OK  ] Stopped target Slice Units.
    [  OK  ] Removed slice User and Session Slice.
    [  OK  ] Stopped target Socket Units.
    [  OK  ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Closed Docker Socket for the API.
    [  OK  ] Closed dropbear.socket.
    [  OK  ] Closed Network Service Netlink Socket.
             Stopping D-Bus System Message Bus...
    [  OK  ] Stopped Generate network units from Kernel command line.
    [  OK  ] Stopped D-Bus System Message Bus.
    [  OK  ] Closed D-Bus System Message Bus Soc[   29.131955] audit: type=1334 audit(1709054790.176:41): prog-id=23 op=UNLOAD
    ket.
    [  OK  ] Stopped target System Initialization.
             Stopping Network Name Resolution...
             Stopping Network Time Synchronization...
    [  OK  ] Stopped Update is Completed.
    [  OK  ] Stopped Rebuild Dynamic Linker Cache.
    [  OK  ] Stopped Rebuild Journal Catalog.
    [  OK  ] Stopped Network Name Resolution.
    [  OK  ] Stopped Network Time Synchronization.
    [   29.300980] audit: type=1334 audit(1709054790.344:42): prog-id=22 op=UNLOAD
    [  OK  ] Stopped Apply Kernel Variables.[   29.308390] audit: type=1334 audit(1709054790.344:43): prog-id=18 op=UNLOAD
    [  OK  ] Closed Process Core Dump Socket.
    [  OK  ] Stopped Load Kernel Modules.
    [  OK  ] Stopped Create Volatile Files and Directories.
    [  OK  ] Stopped target Local File Systems.
             Unmounting Temporary Directory /tmp...
             Unmounting /var/volatile...
    [  OK  ] Unmounted Temporary Directory /tmp.
    [  OK  ] Unmounted /var/volatile.
    [  OK  ] Stopped target Preparation for Local File Systems.
    [  OK  ] Stopped target Swaps.
    [  OK  ] Reached target Unmount All Filesystems.
    [  OK  ] Stopped Create Static Device Nodes in /dev.
    [  OK  ] Stopped Create System Users.
    [  OK  ] Stopped Remount Root and Kernel File Systems.
    [  OK  ] Stopped Create Static Device Nodes in /dev gracefully.
    [  OK  ] Reached target System Shutdown.
    [  OK  ] Reached target Late Shutdown Services.
    [  OK  ] Finished System Reboot.
    [  OK  ] Reached target System Reboot.
    [   29.689728] audit: type=1334 audit(1709054790.732:44): prog-id=26 op=UNLOAD
    [   29.697141] audit: type=1334 audit(1709054790.732:45): prog-id=25 op=UNLOAD
    [   29.704715] audit: type=1334 audit(1709054790.736:46): prog-id=14 op=UNLOAD
    [   29.712165] audit: type=1334 audit(1709054790.736:47): prog-id=13 op=UNLOAD
    [   29.719499] audit: type=1334 audit(1709054790.744:48): prog-id=17 op=UNLOAD
    [   29.740730] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   29.747644] watchdog: watchdog0: watchdog did not stop!
    [   29.766939] systemd-shutdown[1]: Using hardware watchdog 'K3 RTI Watchdog', version 0, device /dev/watchdog0
    [   29.776854] systemd-shutdown[1]: Modifying watchdog timeout is not supported, reusing the programmed timeout.
    [   29.786787] systemd-shutdown[1]: Watchdog running with a timeout of 1min.
    [   29.814987] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   29.824493] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
    [   29.852990] systemd-journald[112]: Received SIGTERM from PID 1 (systemd-shutdow).
    [   29.867816] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
    [   29.886541] systemd-shutdown[1]: Unmounting file systems.
    [   29.894525] (sd-remount)[598]: Remounting '/' read-only with options ''.
    [   29.927921] EXT4-fs (mmcblk0p1): re-mounted e11559d8-9a67-4434-94c8-8a7d20043716 ro. Quota mode: none.
    [   29.940522] systemd-shutdown[1]: All filesystems unmounted.
    [   29.946170] systemd-shutdown[1]: Deactivating swaps.
    [   29.951294] systemd-shutdown[1]: All swaps deactivated.
    [   29.956532] systemd-shutdown[1]: Detaching loop devices.
    [   29.966827] systemd-shutdown[1]: All loop devices detached.
    [   29.972450] systemd-shutdown[1]: Stopping MD devices.
    [   29.977780] systemd-shutdown[1]: All MD devices stopped.
    [   29.983101] systemd-shutdown[1]: Detaching DM devices.
    [   29.988446] systemd-shutdown[1]: All DM devices detached.
    [   29.993855] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
    [   30.003503] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   30.010385] systemd-shutdown[1]: Failed to disable hardware watchdog, ignoring: Device or resource busy
    [   30.019780] watchdog: watchdog0: nowayout prevents watchdog being stopped!
    [   30.026646] watchdog: watchdog0: watchdog did not stop!
    [   30.035193] systemd-shutdown[1]: Syncing filesystems and block devices.
    [   30.042053] systemd-shutdown[1]: Rebooting.
    [   30.063412] reboot: Restarting system
    ERROR:
    ------------ Reached ti_sci_core_reboot() function --------------
  • Thanks. I will check if this there is any board level dependency to trigger reset as the EVM works well and the custom board is not.
    I will get back early next week on this.
    - Keerthy
  • Is the customer system attempting to reboot but failing, or not attempting to reboot.
    My understanding is the function writes to the CTRLMMR_WKUP_MCU_WARM_RST_CTRL register, which generates a warm reset.  This should cause the pin MCU_RESETSTATz to be asserted.  Our EVM connects this to the various flash/boot memories.  Could this be the issue - attempted reboot does not have flash memory in correct state?
    There is also an MCU_SAFETY_ERRORn pin that connects with the PMIC - for when errors are identified the PMIC can reset the processor.  I don't think this is used for software issued resets, but not sure.
  • We checked both RESETSTATz and MCU_RESETSTATz and after we issued reboot command, we saw 200us falling pulse on both lines. We use MCU_RESETSTATz to reset eMMC which is our boot media.
  • Hello Charles,
    Post reboot when you do not see any traces. Can you attach a debugger and check if R5F is executing ROM code in the next boot?
    We need to attach the debugger to MCU R5F and check the PC register to see what the R5F is executing.
    - Keerthy
  • Here's the MCU_R5F_0's registers after issuing reboot command.
  • Charles,
    Thanks. So the MCU R5F is actually gone back to executing the ROM code. What's the boot media on your custom board? Is it emmc? Seems like the ROM code is unable to fetch the bootloader from the boot media and is stuck. That's my hypothesis.
    Keerthy
  • Hi Keerthy,
    Thanks for the reply. Yes, we are using eMMC as boot media. What else can I do to confirm your hypothesis?
    Since our custom board can cold boot (i.e., after recycle the power supply) from eMMC but not warm boot (i.e., after reboot command), what differences could cause this issue?
    Charles
  • Can you check the eMMCs' minimum reset pulse duration - is it being violated by the processor's warm reset?  Possibly the eMMC has not completed its reset sequence when processor attempt to boot.  Possibly disconnect warm reset output from eMMC to see if it resolves issue.
  • According to JESD84-B51A standard, the minimum width of reset input signal is 1us which is far shorted than 20us we saw, so it should have no issue. In addition, we use similar eMMC chip as J7200 EVM uses. We use MTFC32GBCAQTC-AAT while EVM uses MTFC16GAPALBH-AAT.
    We tried disconnecting warm reset from eMMC, but it didn't solve the problem. What else do you think we can check?
    Charles
  • Is there a way to check if eMMC is in the correct state? Anyway to see if its reset correctly.
    - Keerthy
  • Hi Charles
    Can you check one thing , can you confirm hardware reset bit (RST_n_ENABLE) is enabled in the excsd register of the emmc device.
    You can make use of mmc linux utility to read the excsd register.
    Diwakar
  • Hi Diwakar,
    Thanks for the help. I totally forgot to enable eMMC warm reset. After I typed command in u-boot prompt and problem is solved.
    mmc rst-function 0 1
