Part Number: TDA4VM
hi
We encountered some issues while debugging A2B, as there was no sound playing when playing a WAV file with aplay.
We connected the four cables of I2S to the Raspberry Pi board, providing A2B with I2S data cables FSYNC and BCLK that can play sound.
Therefore, we suspect that there is a problem with the configuration of I2S here, but we have not found the problem.
Could you please help analyze where the problem lies. Below are the DTS files and hardware schematics。
br
zhangbo
// SPDX-License-Identifier: GPL-2.0
* Copyright (C) 2019 Texas Instruments Incorporated - https://www.ti.com/
* Product Link: https://www.ti.com/tool/J721EXCPXEVM
/dts-v1/;
#include "k3-j721e-som-p0.dtsi"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/input/input.h>
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/phy/phy-cadence.h>
compatible = "ti,j721e-evm", "ti,j721e";
model = "Texas Instruments J721e EVM";
aliases {
serial0 = &wkup_uart0;
serial1 = &mcu_uart0;
serial2 = &main_uart0;
serial7 = &main_uart5;
spi3 = &main_spi3;
spi5 = &main_spi5;
ethernet0 = &cpsw_port1;
mmc0 = &main_sdhci0;
mmc1 = &main_sdhci1;
chosen {
stdout-path = "serial2:115200n8";
bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait";
evm_12v0: fixedregulator-evm12v0 {
/* main supply */
compatible = "regulator-fixed";
regulator-name = "evm_12v0";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-always-on;
regulator-boot-on;
vsys_3v3: fixedregulator-vsys3v3 {
/* Output of LMS140 */
regulator-name = "vsys_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&evm_12v0>;
regulator-boot-on;
vsys_5v0: fixedregulator-vsys5v0 {
/* Output of LM5140 */
regulator-name = "vsys_5v0";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
vdd_mmc1: fixedregulator-sd {
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
vin-supply = <&vsys_3v3>;
//gpio = <&exp2 2 GPIO_ACTIVE_HIGH>;
vdd_sd_dv_alt: gpio-regulator-tps659411 {
compatible = "regulator-gpio";
pinctrl-names = "default";
pinctrl-0 = <&vdd_sd_dv_alt_pins_default>;
regulator-name = "vdd_sd_dv";
regulator-min-microvolt = <1800000>;
regulator-boot-on;
gpios = <&main_gpio0 111 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
dp_pwr_3v3: regulator-dp-pwr {
regulator-name = "dp-pwr";
//gpio = <&exp4 0 GPIO_ACTIVE_HIGH>; /* P0 - DP0_PWR_SW_EN */
enable-active-high;
dp0: connector {
compatible = "dp-connector";
label = "DP0";
type = "full-size";
dp-pwr-supply = <&dp_pwr_3v3>;
port {
dp_connector_in: endpoint {
remote-endpoint = <&dp0_out>;
pps_gpio {
status = "okay";
compatible = "pps-gpio";
gpios = <&main_gpio1 13 GPIO_ACTIVE_HIGH>;
codec_test: codec_test {
compatible = "linux,snd-soc-dummy";
#sound-dai-cells = <0>;
status="okay";
codec_audio0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "FXN_A2B";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&sound_master0>;
simple-audio-card,frame-master = <&sound_master0>;
sound_master0: simple-audio-card,cpu {
sound-dai = <&mcasp1>;
system-clock-direction-out;
simple-audio-card,codec {
sound-dai = <&codec_test>;
&main_pmx0 {
main_uart0_pins_default: main-uart0-default-pins {
pinctrl-single,pins = <
J721E_IOPAD(0x1f0, PIN_INPUT, 0) /* (AC2) UART0_CTSn */
J721E_IOPAD(0x1f4, PIN_OUTPUT, 0) /* (AB1) UART0_RTSn */
J721E_IOPAD(0x1e8, PIN_INPUT, 0) /* (AB2) UART0_RXD */
J721E_IOPAD(0x1ec, PIN_OUTPUT, 0) /* (AB3) UART0_TXD */
main_mmc1_pins_default: main-mmc1-default-pins {
J721E_IOPAD(0x254, PIN_INPUT, 0) /* (R29) MMC1_CMD */
J721E_IOPAD(0x250, PIN_INPUT, 0) /* (P25) MMC1_CLK */
J721E_IOPAD(0x2ac, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */
J721E_IOPAD(0x24c, PIN_INPUT, 0) /* (R24) MMC1_DAT0 */
J721E_IOPAD(0x248, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */
J721E_IOPAD(0x244, PIN_INPUT, 0) /* (R25) MMC1_DAT2 */
J721E_IOPAD(0x240, PIN_INPUT, 0) /* (R26) MMC1_DAT3 */
J721E_IOPAD(0x258, PIN_INPUT, 0) /* (P23) MMC1_SDCD */
J721E_IOPAD(0x25c, PIN_INPUT, 0) /* (R28) MMC1_SDWP */
vdd_sd_dv_alt_pins_default: vdd-sd-dv-alt-default-pins {
J721E_IOPAD(0x1c0, PIN_OUTPUT, 7) /* (AA2) SPI0_CS0.GPIO0_111 */
dp0_pins_default: dp0-default-pins {
J721E_IOPAD(0x1c4, PIN_INPUT, 5) /* SPI0_CS1.DP0_HPD */
mcasp10_pins_default: mcasp10-default-pins {
//J721E_IOPAD(0x158, PIN_OUTPUT_PULLDOWN, 12) /* (U23) RGMII5_TX_CTL.MCASP10_ACLKX */ /*pin FOR I2C2 del 2025/02/25 */
//J721E_IOPAD(0x15c, PIN_OUTPUT_PULLDOWN, 12) /* (U26) RGMII5_RX_CTL.MCASP10_AFSX */ /*pin FOR I2C2 del 2025/02/25 */
//J721E_IOPAD(0x160, PIN_OUTPUT_PULLDOWN, 12) /* (V28) RGMII5_TD3.MCASP10_AXR0 */ /*pin FOR UART3 del 2025/02/25 */
//J721E_IOPAD(0x164, PIN_OUTPUT_PULLDOWN, 12) /* (V29) RGMII5_TD2.MCASP10_AXR1 */ /*pin FOR UART3 del 2025/02/25 */
//J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 12) /* (U29) RGMII5_TXC.MCASP10_AXR2 */
//J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 12) /* (U25) RGMII5_RXC.MCASP10_AXR3 */
// J721E_IOPAD(0x198, PIN_INPUT_PULLDOWN, 12) /* (V25) RGMII6_TD1.MCASP10_AXR4 */ /* pin FOR SPI5 del 2025/02/27 */
// J721E_IOPAD(0x19c, PIN_INPUT_PULLDOWN, 12) /* (W27) RGMII6_TD0.MCASP10_AXR5 */
// J721E_IOPAD(0x1a0, PIN_INPUT_PULLDOWN, 12) /* (W29) RGMII6_TXC.MCASP10_AXR6 */ /* pin FOR SPI5 del 2025/02/27 */
/* conflict gpio delete for /dev/gpiochip0 */
// audi_ext_refclk2_pins_default: audi-ext-refclk2-default-pins {
// pinctrl-single,pins = <
// J721E_IOPAD(0x1a4, PIN_OUTPUT, 3) /* (W26) RGMII6_RXC.AUDIO_EXT_REFCLK2 */
// main域gpio0的设备树具体内容需要各位老师确认,有需要则打开注释,最后仍保留注释部分将从设备树中删除
// add
main_gpio0_pins_default: main-gpio0-default-pins {
// J721E_IOPAD(0x4, PIN_OUTPUT, 7) /* (AC23) PRG1_PRU0_GPO0.GPIO0_1 */
// J721E_IOPAD(0x8, PIN_INPUT, 7) /* (AG22) PRG1_PRU0_GPO1.GPIO0_2 */
// J721E_IOPAD(0xc, PIN_OUTPUT, 7) /* (AF22) PRG1_PRU0_GPO2.GPIO0_3 */
//J721E_IOPAD(0x10, PIN_OUTPUT_PULLDOWN, 7) /* (AJ23) PRG1_PRU0_GPO3.GPIO0_4 */
// J721E_IOPAD(0x14, PIN_OUTPUT, 7) /* (AH23) PRG1_PRU0_GPO4.GPIO0_5 */
// J721E_IOPAD(0x1c, PIN_OUTPUT, 7) /* (AD22) PRG1_PRU0_GPO6.GPIO0_7 */
J721E_IOPAD(0x28, PIN_INPUT, 7) /* (AG20) PRG1_PRU0_GPO9.GPIO0_10 */
J721E_IOPAD(0x2c, PIN_OUTPUT_PULLUP, 7) /* (AD21) PRG1_PRU0_GPO10.GPIO0_11 */
// J721E_IOPAD(0x30, PIN_OUTPUT, 7) /* (AF24) PRG1_PRU0_GPO11.GPIO0_12 */
// J721E_IOPAD(0x34, PIN_OUTPUT, 7) /* (AJ24) PRG1_PRU0_GPO12.GPIO0_13 */
// J721E_IOPAD(0x38, PIN_INPUT, 7) /* (AG24) PRG1_PRU0_GPO13.GPIO0_14 */
// J721E_IOPAD(0x3c, PIN_OUTPUT, 7) /* (AD24) PRG1_PRU0_GPO14.GPIO0_15 */
// J721E_IOPAD(0x40, PIN_INPUT, 7) /* (AC24) PRG1_PRU0_GPO15.GPIO0_16 */
// J721E_IOPAD(0x44, PIN_INPUT, 7) /* (AE24) PRG1_PRU0_GPO16.GPIO0_17 */
// J721E_IOPAD(0x4c, PIN_INPUT, 7) /* (AJ21) PRG1_PRU0_GPO17.GPIO0_18 */
// J721E_IOPAD(0x50, PIN_INPUT, 7) /* (AE21) PRG1_PRU0_GPO18.GPIO0_19 */
// J721E_IOPAD(0x54, PIN_INPUT, 7) /* (AH21) PRG1_PRU0_GPO19.GPIO0_20 */
// J721E_IOPAD(0x58, PIN_INPUT, 7) /* (AE22) PRG1_PRU1_GPO0.GPIO0_21 */
// J721E_IOPAD(0x5c, PIN_INPUT, 7) /* (AG23) PRG1_PRU1_GPO1.GPIO0_22 */
// J721E_IOPAD(0x60, PIN_INPUT, 7) /* (AF23) PRG1_PRU1_GPO2.GPIO0_23 */
// J721E_IOPAD(0x64, PIN_INPUT, 7) /* (AD23) PRG1_PRU1_GPO3.GPIO0_24 */
// J721E_IOPAD(0x68, PIN_INPUT, 7) /* (AH24) PRG1_PRU1_GPO4.GPIO0_25 */
// J721E_IOPAD(0x6c, PIN_INPUT, 7) /* (AG21) PRG1_PRU1_GPO5.GPIO0_26 */
// J721E_IOPAD(0x70, PIN_INPUT, 7) /* (AE23) PRG1_PRU1_GPO6.GPIO0_27 */
// J721E_IOPAD(0x74, PIN_INPUT, 7) /* (AC21) PRG1_PRU1_GPO7.GPIO0_28 */
// J721E_IOPAD(0x78, PIN_INPUT, 7) /* (Y23) PRG1_PRU1_GPO8.GPIO0_29 */
// J721E_IOPAD(0x7c, PIN_OUTPUT, 7) /* (AF21) PRG1_PRU1_GPO9.GPIO0_30 */
// J721E_IOPAD(0x80, PIN_OUTPUT, 7) /* (AB23) PRG1_PRU1_GPO10.GPIO0_31 */
// J721E_IOPAD(0x90, PIN_OUTPUT_PULLDOWN, 7) /* (AH26) PRG1_PRU1_GPO14.GPIO0_35 */
J721E_IOPAD(0x94, PIN_INPUT, 7) /* (AJ27) PRG1_PRU1_GPO15.GPIO0_36 */
J721E_IOPAD(0xa4, PIN_INPUT, 7) /* (AH22) PRG1_PRU1_GPO19.GPIO0_40 add for S32K SPI */
// J721E_IOPAD(0xa8, PIN_OUTPUT, 7) /* (AD19) PRG1_MDIO0_MDIO.GPIO0_41 */
// J721E_IOPAD(0xac, PIN_OUTPUT, 7) /* (AD18) PRG1_MDIO0_MDC.GPIO0_42 */
// J721E_IOPAD(0xb0, PIN_OUTPUT, 7) /* (AF28) PRG0_PRU0_GPO0.GPIO0_43 */
// J721E_IOPAD(0xb4, PIN_INPUT, 7) /* (AE28) PRG0_PRU0_GPO1.GPIO0_44 */
// J721E_IOPAD(0xb8, PIN_OUTPUT, 7) /* (AE27) PRG0_PRU0_GPO2.GPIO0_45 */
// J721E_IOPAD(0xbc, PIN_OUTPUT, 7) /* (AD26) PRG0_PRU0_GPO3.GPIO0_46 */
// J721E_IOPAD(0xc0, PIN_INPUT, 7) /* (AD25) PRG0_PRU0_GPO4.GPIO0_47 */
// J721E_IOPAD(0xc8, PIN_OUTPUT, 7) /* (AE26) PRG0_PRU0_GPO6.GPIO0_49 */
// J721E_IOPAD(0xcc, PIN_OUTPUT, 7) /* (AC28) PRG0_PRU0_GPO7.GPIO0_50 */
// J721E_IOPAD(0xd0, PIN_INPUT, 7) /* (AC27) PRG0_PRU0_GPO8.GPIO0_51 */
// J721E_IOPAD(0xdc, PIN_OUTPUT, 7) /* (AJ28) PRG0_PRU0_GPO11.GPIO0_54 */
// J721E_IOPAD(0xe0, PIN_OUTPUT, 7) /* (AH27) PRG0_PRU0_GPO12.GPIO0_55 */
// J721E_IOPAD(0xe4, PIN_INPUT, 7) /* (AH29) PRG0_PRU0_GPO13.GPIO0_56 */
// J721E_IOPAD(0xe8, PIN_INPUT, 7) /* (AG28) PRG0_PRU0_GPO14.GPIO0_57 */
// J721E_IOPAD(0xec, PIN_INPUT, 7) /* (AG27) PRG0_PRU0_GPO15.GPIO0_58 */
// J721E_IOPAD(0xf0, PIN_OUTPUT, 7) /* (AH28) PRG0_PRU0_GPO16.GPIO0_59 */
// J721E_IOPAD(0xf8, PIN_OUTPUT, 7) /* (AB29) PRG0_PRU0_GPO18.GPIO0_61 */
// J721E_IOPAD(0xfc, PIN_INPUT, 7) /* (AB28) PRG0_PRU0_GPO19.GPIO0_62 */
// J721E_IOPAD(0x100, PIN_INPUT, 7) /* (AE29) PRG0_PRU1_GPO0.GPIO0_63 */
// J721E_IOPAD(0x104, PIN_INPUT, 7) /* (AD28) PRG0_PRU1_GPO1.GPIO0_64 */
J721E_IOPAD(0x130, PIN_INPUT, 7) /* (AF27) PRG0_PRU1_GPO12.GPIO0_75 */
J721E_IOPAD(0x134, PIN_OUTPUT_PULLUP, 7) /* (AF26) PRG0_PRU1_GPO13.GPIO0_76 */
// J721E_IOPAD(0x138, PIN_OUTPUT_PULLUP, 7) /* (AE25) PRG0_PRU1_GPO14.GPIO0_77 */
// J721E_IOPAD(0x13c, PIN_OUTPUT, 7) /* (AF29) PRG0_PRU1_GPO15.GPIO0_78 */
// J721E_IOPAD(0x140, PIN_INPUT, 7) /* (AG29) PRG0_PRU1_GPO16.GPIO0_79 */
// J721E_IOPAD(0x154, PIN_OUTPUT_PULLDOWN, 7) /* (AA27) PRG0_MDIO0_MDC.GPIO0_84 */
// J721E_IOPAD(0x168, PIN_OUTPUT, 7) /* (V27) RGMII5_TD1.GPIO0_89 */
J721E_IOPAD(0x16c, PIN_INPUT, 7) /* (U28) RGMII5_TD0.GPIO0_90 OPEN for SPI3_CS2 IRQ */
// J721E_IOPAD(0x170, PIN_OUTPUT_PULLDOWN, 7) /* (U29) RGMII5_TXC.GPIO0_91 */
// J721E_IOPAD(0x174, PIN_OUTPUT_PULLDOWN, 7) /* (U25) RGMII5_RXC.GPIO0_92 */
// J721E_IOPAD(0x178, PIN_OUTPUT, 7) /* (U27) RGMII5_RD3.GPIO0_93 */
// J721E_IOPAD(0x17c, PIN_OUTPUT, 7) /* (U24) RGMII5_RD2.GPIO0_94 */
// J721E_IOPAD(0x180, PIN_OUTPUT_PULLDOWN, 7) /* (R23) RGMII5_RD1.GPIO0_95 */
// J721E_IOPAD(0x184, PIN_OUTPUT_PULLDOWN, 7) /* (T23) RGMII5_RD0.GPIO0_96 */
// J721E_IOPAD(0x188, PIN_OUTPUT, 7) /* (Y28) RGMII6_TX_CTL.GPIO0_97 */
J721E_IOPAD(0x18c, PIN_INPUT, 7) /* (V23) RGMII6_RX_CTL.GPIO0_98 */
J721E_IOPAD(0x190, PIN_INPUT, 7) /* (W23) RGMII6_TD3.GPIO0_99 */
// J721E_IOPAD(0x194, PIN_OUTPUT, 7) /* (W28) RGMII6_TD2.GPIO0_100 */
// J721E_IOPAD(0x198, PIN_OUTPUT, 7) /* (V25) RGMII6_TD1.GPIO0_101 */
// J721E_IOPAD(0x19c, PIN_OUTPUT, 7) /* (W27) RGMII6_TD0.GPIO0_102 */
// J721E_IOPAD(0x1a0, PIN_INPUT, 7) /* (W29) RGMII6_TXC.GPIO0_103 */
J721E_IOPAD(0x1a4, PIN_INPUT, 7) /* (W26) RGMII6_RXC.GPIO0_104 */
// J721E_IOPAD(0x1c0, PIN_OUTPUT, 7) /* (AA2) SPI0_CS0.GPIO0_111 */
// J721E_IOPAD(0x1c4, PIN_OUTPUT, 7) /* (Y4) SPI0_CS1.GPIO0_112 */
// J721E_IOPAD(0x1c8, PIN_OUTPUT, 7) /* (AA1) SPI0_CLK.GPIO0_113 */
// J721E_IOPAD(0x1cc, PIN_OUTPUT, 7) /* (AB5) SPI0_D0.GPIO0_114 */
// J721E_IOPAD(0x1d0, PIN_OUTPUT, 7) /* (AA3) SPI0_D1.GPIO0_115 */
// J721E_IOPAD(0x1dc, PIN_INPUT, 7) /* (Y1) SPI1_CLK.GPIO0_118 */
// J721E_IOPAD(0x1e0, PIN_INPUT, 7) /* (Y5) SPI1_D0.GPIO0_119 */
J721E_IOPAD(0x1e4, PIN_INPUT, 7) /* (Y2) SPI1_D1.GPIO0_120 */
// main域gpio1的设备树具体内容需要各位老师确认,有需要则打开注释,最后仍保留注释部分将从设备树中删除
// add
main_gpio1_pins_default: main-gpio1-default-pins {
// J721E_IOPAD(0x218, PIN_OUTPUT, 7) /* (W2) I3C0_SCL.GPIO1_5 */
// J721E_IOPAD(0x21c, PIN_INPUT, 7) /* (W1) I3C0_SDA.GPIO1_6 */
// J721E_IOPAD(0x230, PIN_INPUT, 7) /* (U2) ECAP0_IN_APWM_OUT.GPIO1_11 */
// J721E_IOPAD(0x234, PIN_INPUT, 7) /* (U3) EXT_REFCLK1.GPIO1_12 */
J721E_IOPAD(0x238, PIN_INPUT, 7) /* (V6) TIMER_IO0.GPIO1_13 ADD for PPS */
J721E_IOPAD(0x260, PIN_OUTPUT_PULLDOWN, 7) /* (T28) MMC2_DAT3.GPIO1_23 */
// J721E_IOPAD(0x264, PIN_INPUT, 7) /* (T29) MMC2_DAT2.GPIO1_24 */
//J721E_IOPAD(0x268, PIN_OUTPUT_PULLUP, 7) /* (T27) MMC2_DAT1.GPIO1_25 */ /*pin FOR TDA4_LG69T_RST del 2025/02/25 */
// J721E_IOPAD(0x26c, PIN_OUTPUT, 7) /* (T24) MMC2_DAT0.GPIO1_26 */
// J721E_IOPAD(0x270, PIN_INPUT, 7) /* (T26) MMC2_CLK.GPIO1_27 */
// J721E_IOPAD(0x274, PIN_INPUT, 7) /* (T25) MMC2_CMD.GPIO1_28 */
// J721E_IOPAD(0x290, PIN_OUTPUT, 7) /* (U6) USB0_DRVVBUS.GPIO1_29 */
// J721E_IOPAD(0x294, PIN_INPUT, 7) /* (AD1) MLB0_MLBSP.GPIO1_30 */
// J721E_IOPAD(0x298, PIN_INPUT, 7) /* (AC1) MLB0_MLBSN.GPIO1_31 */
// J721E_IOPAD(0x29c, PIN_INPUT, 7) /* (AC3) MLB0_MLBDP.GPIO1_32 */
// J721E_IOPAD(0x2a0, PIN_INPUT, 7) /* (AD3) MLB0_MLBDN.GPIO1_33 */
// J721E_IOPAD(0x2a4, PIN_INPUT, 7) /* (AD2) MLB0_MLBCP.GPIO1_34 */
// J721E_IOPAD(0x2a8, PIN_INPUT, 7) /* (AE2) MLB0_MLBCN.GPIO1_35 */
// add
main_mcasp1_pins_default: main-mcasp1-default-pins {
J721E_IOPAD(0x114, PIN_OUTPUT, 12) /* (AB27) PRG0_PRU1_GPO5.MCASP1_ACLKX */
J721E_IOPAD(0x120, PIN_OUTPUT, 12) /* (AA28) PRG0_PRU1_GPO8.MCASP1_AFSX */
J721E_IOPAD(0x110, PIN_INPUT, 12) /* (AD29) PRG0_PRU1_GPO4.MCASP1_AXR2 */
J721E_IOPAD(0x118, PIN_INPUT, 12) /* (AC26) PRG0_PRU1_GPO6.MCASP1_AXR3 */
J721E_IOPAD(0x128, PIN_OUTPUT, 12) /* (AA25) PRG0_PRU1_GPO10.MCASP1_AXR6 */
J721E_IOPAD(0x12c, PIN_OUTPUT, 12) /* (AG26) PRG0_PRU1_GPO11.MCASP1_AXR7 */
// add
main_mmcsd1_pins_default: main-mmcsd1-default-pins {
// add
main_pcie3_pins_default: main-pcie3-default-pins {
J721E_IOPAD(0x25c, PIN_INPUT, 6) /* (R28) MMC1_SDWP.PCIE3_CLKREQn */
// main_i2c1_exp4_pins_default: main-i2c1-exp4-default-pins {
main_i2c1_pins_default: main-i2c1-default-pins {
J721E_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (Y6) I2C1_SCL */
J721E_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (AA6) I2C1_SDA */
/* AG190W SPI <---> TDA4 SPI3 */
main_spi3_pins_default: main-spi3-default-pins {
J721E_IOPAD(0x144, PIN_INPUT, 4) /* (Y25) PRG0_PRU1_GPO17.SPI3_CLK */
J721E_IOPAD(0x11c, PIN_INPUT, 4) /* (AA24) PRG0_PRU1_GPO7.SPI3_CS0 */
J721E_IOPAD(0xd4, PIN_INPUT, 4) /* (AB26) PRG0_PRU0_GPO9.SPI3_CS1 */
J721E_IOPAD(0xd8, PIN_INPUT, 4) /* (AB25) PRG0_PRU0_GPO10.SPI3_CS2 */
J721E_IOPAD(0x124, PIN_INPUT, 4) /* (Y24) PRG0_PRU1_GPO9.SPI3_CS3 */
J721E_IOPAD(0x148, PIN_INPUT, 4) /* (AA26) PRG0_PRU1_GPO18.SPI3_D0 */
J721E_IOPAD(0x14c, PIN_INPUT, 4) /* (AA29) PRG0_PRU1_GPO19.SPI3_D1 */
/* Add for A2 Sample AG568N <---> TDA4 SPI5 */
main_spi5_pins_default: main_spi5-default-pins {
J721E_IOPAD(0x1a0, PIN_INPUT, 3) /* (W29) RGMII6_TXC.SPI5_CLK */
J721E_IOPAD(0x1b4, PIN_INPUT, 3) /* (W25) RGMII6_RD0.SPI5_CS1 */
J721E_IOPAD(0x198, PIN_INPUT, 3) /* (V25) RGMII6_TD1.SPI5_D0 */
J721E_IOPAD(0x1b0, PIN_INPUT, 3) /* (W24) RGMII6_RD1.SPI5_D1 */
// add
main_system0_pins_default: main-system0-default-pins {
J721E_IOPAD(0x278, PIN_OUTPUT, 0) /* (T6) RESETSTATz */
J721E_IOPAD(0x280, PIN_INPUT, 0) /* (U4) SOC_SAFETY_ERRORn */
/* AG190W Uart3 <----> TDA4 Uart5 */
main_uart5_pins_default: main-uart5-default-pins {
J721E_IOPAD(0x1d4, PIN_INPUT, 3) /* (Y3) SPI1_CS0.UART5_RXD */
J721E_IOPAD(0x1d8, PIN_OUTPUT, 3) /* (W4) SPI1_CS1.UART5_TXD */
&wkup_pmx0 {
/delete-node/ pmic-irq-default-pins;
mcu_fss0_ospi0_pins_default: mcu_fss0_ospi0-default-pins {
J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 0) /* (E20) MCU_OSPI0_CLK */
J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 0) /* (F19) MCU_OSPI0_CSn0 */
J721E_WKUP_IOPAD(0xc, PIN_INPUT, 0) /* (D20) MCU_OSPI0_D0 */
J721E_WKUP_IOPAD(0x10, PIN_INPUT, 0) /* (G19) MCU_OSPI0_D1 */
J721E_WKUP_IOPAD(0x14, PIN_INPUT, 0) /* (G20) MCU_OSPI0_D2 */
J721E_WKUP_IOPAD(0x18, PIN_INPUT, 0) /* (F20) MCU_OSPI0_D3 */
J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 0) /* (F21) MCU_OSPI0_D4 */
J721E_WKUP_IOPAD(0x20, PIN_INPUT, 0) /* (E21) MCU_OSPI0_D5 */
J721E_WKUP_IOPAD(0x24, PIN_INPUT, 0) /* (B22) MCU_OSPI0_D6 */
J721E_WKUP_IOPAD(0x28, PIN_INPUT, 0) /* (G21) MCU_OSPI0_D7 */
J721E_WKUP_IOPAD(0x8, PIN_INPUT, 0) /* (D21) MCU_OSPI0_DQS */
J721E_WKUP_IOPAD(0x3c, PIN_INPUT_PULLUP, 6) /* (B23) MCU_OSPI1_DQS.MCU_OSPI0_ECC_FAIL */
J721E_WKUP_IOPAD(0x38, PIN_OUTPUT_PULLUP, 6) /* (A23) MCU_OSPI1_LBCLKO.MCU_OSPI0_RESET_OUT0 */
mcu_cpsw_pins_default: mcu-cpsw-default-pins {
J721E_WKUP_IOPAD(0x0058, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */
J721E_WKUP_IOPAD(0x005c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */
J721E_WKUP_IOPAD(0x0060, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */
J721E_WKUP_IOPAD(0x0064, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */
J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */
J721E_WKUP_IOPAD(0x006c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */
J721E_WKUP_IOPAD(0x0078, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */
J721E_WKUP_IOPAD(0x007c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */
J721E_WKUP_IOPAD(0x0080, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */
J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */
J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */
J721E_WKUP_IOPAD(0x0074, PIN_INPUT, 0) /* MCU_RGMII1_RXC */
// modify
// mcu_mdio_pins_default: mcu-mdio1-default-pins {
// J721E_WKUP_IOPAD(0x008c, PIN_OUTPUT, 0) /* MCU_MDIO0_MDC */
// J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_MDIO0_MDIO */
J721E_WKUP_IOPAD(0x8c, PIN_OUTPUT, 0) /* (F23) MCU_MDIO0_MDC */
J721E_WKUP_IOPAD(0x88, PIN_INPUT, 0) /* (E23) MCU_MDIO0_MDIO */
// wkup域gpio0的设备树具体内容需要各位老师确认,有需要则打开注释,最后仍保留注释部分将从设备树中删除
wkup_gpio_pins_default: wkup-gpio-default-pins {
// J721E_WKUP_IOPAD(0xbc, PIN_OUTPUT_PULLDOWN, 7) /* (F27) WKUP_GPIO0_3 */ /*pin Board_ID_EEPROM_WP del 2025/02/25 */
J721E_WKUP_IOPAD(0xc8, PIN_INPUT, 7) /* (F29) WKUP_GPIO0_6 */
// J721E_WKUP_IOPAD(0xcc, PIN_OUTPUT, 7) /* (G28) WKUP_GPIO0_7 */
// J721E_WKUP_IOPAD(0xd0, PIN_INPUT, 7) /* (G27) WKUP_GPIO0_8 */
// J721E_WKUP_IOPAD(0xd4, PIN_INPUT, 7) /* (G26) WKUP_GPIO0_9 */
// J721E_WKUP_IOPAD(0xd8, PIN_INPUT, 7) /* (H26) WKUP_GPIO0_10 */
// J721E_WKUP_IOPAD(0xdc, PIN_OUTPUT, 7) /* (H27) WKUP_GPIO0_11 */
// J721E_WKUP_IOPAD(0x4, PIN_INPUT_PULLUP, 7) /* (C21) MCU_OSPI0_LBCLKO.WKUP_GPIO0_17 */
J721E_WKUP_IOPAD(0x34, PIN_INPUT, 7) /* (F22) MCU_OSPI1_CLK.WKUP_GPIO0_29 */
// J721E_WKUP_IOPAD(0x44, PIN_OUTPUT, 7) /* (G22) MCU_OSPI1_D1.WKUP_GPIO0_33 */
// J721E_WKUP_IOPAD(0x48, PIN_INPUT, 7) /* (D23) MCU_OSPI1_D2.WKUP_GPIO0_34 */
// J721E_WKUP_IOPAD(0x4c, PIN_INPUT, 7) /* (C23) MCU_OSPI1_D3.WKUP_GPIO0_35 */
// J721E_WKUP_IOPAD(0x50, PIN_OUTPUT_PULLUP, 7) /* (C22) MCU_OSPI1_CSn0.WKUP_GPIO0_36 */
// J721E_WKUP_IOPAD(0x9c, PIN_INPUT, 7) /* (E25) MCU_SPI0_CS0.WKUP_GPIO0_55 */
// J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 7) /* (D26) MCU_I3C0_SCL.WKUP_GPIO0_60 */
// J721E_WKUP_IOPAD(0xf4, PIN_OUTPUT, 7) /* (D25) MCU_I3C0_SDA.WKUP_GPIO0_61 */
// J721E_WKUP_IOPAD(0x108, PIN_OUTPUT_PULLDOWN, 7) /* (E26) PMIC_POWER_EN0.WKUP_GPIO0_66 */ /*pin BOOT_EEPROM_WP del 2025/02/25 */
// add
mcu_rgmii1_pins_default: mcu-rgmii1-default-pins {
J721E_WKUP_IOPAD(0x84, PIN_INPUT, 0) /* (B24) MCU_RGMII1_RD0 */
J721E_WKUP_IOPAD(0x80, PIN_INPUT, 0) /* (A24) MCU_RGMII1_RD1 */
J721E_WKUP_IOPAD(0x7c, PIN_INPUT, 0) /* (D24) MCU_RGMII1_RD2 */
J721E_WKUP_IOPAD(0x78, PIN_INPUT, 0) /* (A25) MCU_RGMII1_RD3 */
J721E_WKUP_IOPAD(0x74, PIN_INPUT, 0) /* (C24) MCU_RGMII1_RXC */
J721E_WKUP_IOPAD(0x5c, PIN_INPUT, 0) /* (C25) MCU_RGMII1_RX_CTL */
J721E_WKUP_IOPAD(0x6c, PIN_OUTPUT, 0) /* (B25) MCU_RGMII1_TD0 */
J721E_WKUP_IOPAD(0x68, PIN_OUTPUT, 0) /* (A26) MCU_RGMII1_TD1 */
J721E_WKUP_IOPAD(0x64, PIN_OUTPUT, 0) /* (A27) MCU_RGMII1_TD2 */
J721E_WKUP_IOPAD(0x60, PIN_OUTPUT, 0) /* (A28) MCU_RGMII1_TD3 */
J721E_WKUP_IOPAD(0x70, PIN_OUTPUT, 0) /* (B26) MCU_RGMII1_TXC */
J721E_WKUP_IOPAD(0x58, PIN_OUTPUT, 0) /* (B27) MCU_RGMII1_TX_CTL */
&main_spi3 {
status = "okay";
pinctrl-0 = <&main_spi3_pins_default>;
spidev@0 {
compatible = "ti,spi-evm";
spi-max-frequency = <3125000>;
reg = <0>;
spi-cpol = <1>; // CPOL = 1
spi-cpha = <1>; // CPHA = 1
spidev@1 {
reg = <1>;
spi-cpol = <0>; // CPOL = 0
spidev@2 {
reg = <2>;
spi-cpha = <0>; // CPHA = 0
// interrupts = <GIC_SPI 90 IRQ_TYPE_EDGE_RISING>;
spidev@3 {
reg = <3>;
&main_spi5 {
status = "okay";
pinctrl-0 = <&main_spi5_pins_default>;
spidev@0 {
reg = <1>;
&wkup_uart0 {
/* Wakeup UART is used by System firmware */
status = "reserved";
&mcu_uart0 {
&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
clock-frequency = <400000>;
a2b24xx: a2b24xx@0x68 {
compatible = "adi,a2b24xx";
reg = <0x68>;
&main_uart0 {
status = "okay";
pinctrl-0 = <&main_uart0_pins_default>;
/* Shared with ATF on this platform */
power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>;
&main_uart1 {
status = "disabled";
&main_uart2 {
&main_uart4 {
/* Add For AG190W Uart */
&main_uart5 {
status = "okay";
pinctrl-0 = <&main_uart5_pins_default>;
&wkup_gpio0 {
status = "okay";
pinctrl-0 = <&wkup_gpio_pins_default>;
&main_gpio0 {
status = "okay";
pinctrl-0 = <&main_gpio0_pins_default>;
&main_gpio1 {
status = "okay";
pinctrl-0 = <&main_gpio1_pins_default>;
&main_sdhci0 {
/* eMMC */
status = "okay";
non-removable;
ti,driver-strength-ohm = <50>;
disable-wp;
&main_sdhci1 {
/* SD/MMC */
status = "okay";
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
no-1-8-v;
sdhci-caps-mask = <0x8000000F 0x0>;
&ufs_wrapper {
status = "okay";
ufs@4e84000 {
/* ufs */
status = "okay";
freq-table-hz = <26000000 26000000>, // 高速频率
<19200000 19200000>, // 低速频率1
<19200000 19200000>; // 低速频率2
&serdes_ln_ctrl { /*disable serdes for cpsw9g*/
idle-states = <J721E_SERDES2_LANE0_PCIE2_LANE0>, <J721E_SERDES2_LANE1_PCIE2_LANE1>,
<J721E_SERDES3_LANE0_USB3_0_SWAP>, <J721E_SERDES3_LANE1_USB3_0>,
<J721E_SERDES4_LANE0_EDP_LANE0>, <J721E_SERDES4_LANE1_EDP_LANE1>,
<J721E_SERDES4_LANE2_EDP_LANE2>, <J721E_SERDES4_LANE3_EDP_LANE3>;
&serdes_wiz3 {
typec-dir-gpios = <&main_gpio1 3 GPIO_ACTIVE_HIGH>;
typec-dir-debounce-ms = <700>; /* TUSB321, tCCB_DEFAULT 133 ms */
&serdes3 {
serdes3_usb_link: phy@0 {
reg = <0>;
cdns,num-lanes = <2>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_USB3>;
resets = <&serdes_wiz3 1>, <&serdes_wiz3 2>;
status = "disabled"; /*disable serdes for cpsw9g*/
&ospi0 {
status = "okay";
flash@0 {
cdns,read-delay = <4>;
&ospi1 {
&tscadc0 {
status = "okay";
adc {
ti,adc-channels = <0 1 2 3 4 5 6 7>;
&tscadc1 {
status = "okay";
adc {
// &k3_clks {
// /* Confiure AUDIO_EXT_REFCLK2 pin as output */
// pinctrl-names = "default";
// pinctrl-0 = <&audi_ext_refclk2_pins_default>;
&mcu_cpsw {
pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>;
cpts@3d000 {
/* Map HW4_TS_PUSH to GENF1 */
ti,pps = <3 1>;
&davinci_mdio {
phy2: ethernet-phy@2 {
reg = <2>;
mv88q2220-reset-gpios = <&main_gpio0 76 GPIO_ACTIVE_HIGH>;
reset-assert-us = <10000>; // 10ms
reset-deassert-us = <10000>; // 10ms
&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&phy2>;
&dss {
* These clock assignments are chosen to enable the following outputs:
* VP0 - DisplayPort SST
* VP1 - DPI0
* VP2 - DSI
* VP3 - DPI1
assigned-clocks = <&k3_clks 152 1>,
<&k3_clks 152 4>,
<&k3_clks 152 9>,
<&k3_clks 152 13>;
assigned-clock-parents = <&k3_clks 152 2>, /* PLL16_HSDIV0 */
<&k3_clks 152 6>, /* PLL19_HSDIV0 */
<&k3_clks 152 11>, /* PLL18_HSDIV0 */
<&k3_clks 152 18>; /* PLL23_HSDIV0 */
&dss_ports {
port {
dpi0_out: endpoint {
remote-endpoint = <&dp0_in>;
&dp0_ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
dp0_in: endpoint {
remote-endpoint = <&dpi0_out>;
port@4 {
reg = <4>;
dp0_out: endpoint {
remote-endpoint = <&dp_connector_in>;
&mcasp1 {
status = "okay";
pinctrl-0 = <&main_mcasp1_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
auxclk-fs-ratio = <256>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 2 2
0 0 1 1
0 0 0 0
tx-num-evt = <0>;
rx-num-evt = <0>;
&cmn_refclk1 {
clock-frequency = <100000000>;
&wiz0_pll1_refclk {
assigned-clocks = <&wiz0_pll1_refclk>;
assigned-clock-parents = <&cmn_refclk1>;
status = "disabled";/*disable serdes for cpsw9g*/
&wiz0_refclk_dig {
assigned-clocks = <&wiz0_refclk_dig>;
&wiz1_pll1_refclk {
assigned-clocks = <&wiz1_pll1_refclk>;
&wiz1_refclk_dig {
assigned-clocks = <&wiz1_refclk_dig>;
&wiz2_pll1_refclk {
assigned-clocks = <&wiz2_pll1_refclk>;
&wiz2_refclk_dig {
assigned-clocks = <&wiz2_refclk_dig>;
&serdes0 {
assigned-clocks = <&serdes0 CDNS_SIERRA_PLL_CMNLC>;
assigned-clock-parents = <&wiz0_pll1_refclk>;
serdes0_pcie_link: phy@0 {
reg = <0>;
cdns,num-lanes = <1>;
#phy-cells = <0>;
cdns,phy-type = <PHY_TYPE_PCIE>;
resets = <&serdes_wiz0 1>;
&serdes1 {
assigned-clocks = <&serdes1 CDNS_SIERRA_PLL_CMNLC>;
assigned-clock-parents = <&wiz1_pll1_refclk>;
serdes1_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>;
&serdes_wiz0 {
&serdes_wiz1 {
&serdes_wiz2 {
&serdes_wiz3 {
&serdes2 {
assigned-clocks = <&serdes2 CDNS_SIERRA_PLL_CMNLC>;
assigned-clock-parents = <&wiz2_pll1_refclk>;
serdes2_pcie_link: phy@0 {
reg = <0>;
#phy-cells = <0>;
resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&serdes4 {
torrent_phy_dp: phy@0 {
reg = <0>;
resets = <&serdes_wiz4 1>;
cdns,phy-type = <PHY_TYPE_DP>;
cdns,num-lanes = <4>;
cdns,max-bit-rate = <2700>;
#phy-cells = <0>;
&mhdp {
phys = <&torrent_phy_dp>;
phy-names = "dpphy";
pinctrl-0 = <&dp0_pins_default>;
&pcie0_rc {
status = "okay";
//reset-gpios = <&exp1 6 GPIO_ACTIVE_HIGH>;
phys = <&serdes0_pcie_link>;
phy-names = "pcie-phy";
num-lanes = <1>;
&pcie1_rc {
status = "okay";
//reset-gpios = <&exp1 2 GPIO_ACTIVE_HIGH>;
phys = <&serdes1_pcie_link>;
num-lanes = <2>;
&pcie2_rc {
status = "okay";
//reset-gpios = <&exp2 20 GPIO_ACTIVE_HIGH>;
phys = <&serdes2_pcie_link>;
num-lanes = <2>;
#define K3_TS_OFFSET(pa, val) (0x4+(pa)*4) (0x10000 | val)
×ync_router {
status = "okay";
pinctrl-0 = <&mcu_cpsw_cpts>;
/* Use Time Sync Router to map GENF1 input to HW4_TS_PUSH output */
mcu_cpsw_cpts: mcu-cpsw-cpts {
/* pps [mcu cpsw cpts genf1] in17 -> out25 [mcu cpsw cpts hw4_push] */
K3_TS_OFFSET(25, 17)
&wkup_i2c0 {
/delete-node/ eeprom@50;
/delete-node/ pmic@48;
/delete-node/ pmic@4c;
/*status = "reserved";*/
&cbass_main {
phy@4580000 {
status = "disable";
phy@4590000 {
status = "disable";
dp-bridge@a000000 {
status = "disable";
