Part Number: PROCESSOR-SDK-AM62X
Other Parts Discussed in Thread: AM6252, AM62P
DearTI,
we have an issue with the AM6252 board (own product, not Dev Kit).
According to the datasheet we should set the following HSYNC/VSYNC control DSS0 pins:
In TI code this seems to be the case the applicable register is configured correctly:
We performed the following 2 tests:
1. Using default code (as above):
Registers seem to be set ok.
Oscilloscope is showing VSYNCH signal transition on falling edge:
2. Modified code to set the RF to NEGATIVE edge:
The register seems to be set correctly.
When measuring the VSYNCH signal we see the VSYNCH STILL being driven on the falling edge though:
It currently seems changing the RF in VP2_FREQ register setting has no effect!
Are we missing something?
We're looking forward to your feedback.
Thank you in advance!
M.Kubica
