SoC: K3-AM62P5
Platform: SK-AM62P-LP
SDK: v10.1
Dear Supporter,
We could not boot rootfs from eMMC. Re-ran "make -j4 all" several times and had same problem.
List related information below for troubleshooting ...
CONFIG_CMDLINE="console=ttyS2,115200n8 quiet earlycon=ns16550a,mmio32,0x2800000 root=/dev/mmcblk0p2 rw rootfstype=ext4"
Console log:
[BOOTLOADER_PROFILE] Boot Media : eMMC [BOOTLOADER_PROFILE] Boot Media Clock : 200.000 MHz [BOOTLOADER_PROFILE] Boot Image Size : 914 KB [BOOTLOADER_PROFILE] Cores present : hsm-m4f0-0 mcu-r5f0-0 a530-0 [BOOTLOADER PROFILE] SBL Drivers_open : 26640us [BOOTLOADER PROFILE] HSM Image Load : 5845us [BOOTLOADER PROFILE] MCU R5 Image Load : 7310us [BOOTLOADER PROFILE] A53 Image Load : 20114us [BOOTLOADER_PROFILE] SBL Total Time Taken : 59910us Image loading done, switching to application ... Starting linux and RTOS/Baremetal applications NOTICE: BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty NOTICE: BL31: Built : 04:20:32, Nov 1 2024 U-Boot SPL 2024.04-ti-g29d0c23d67ee (Nov 29 2024 - 11:41:54 +0000) SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') SPL initial stack usage: 1904 bytes Trying to boot from MMC1 Authentication passed Authentication passed U-Boot 2024.04 (Apr 11 2025 - 13:32:04 +0800) SoC: AM62PX SR1.0 HS-FS Model: Texas Instruments AM62P5 SK DRAM: 2 GiB (effective 8 GiB) Core: 85 devices, 31 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial Out: serial Err: serial Net: eth0: ethernet@8000000port@1 Warning: ethernet@8000000port@2 (eth1) using random MAC address - 32:e6:7c:1f:fa:7e , eth1: ethernet@8000000port@2 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 585 bytes read in 9 ms (63.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... 21029376 bytes read in 102 ms (196.6 MiB/s) 68365 bytes read in 8 ms (8.1 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feec000, end 000000008fffffff ... OK Working FDT set to 8feec000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.58-ti-01497-ga7758da17c28-dirty (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Wed Nov 27 13:23:15 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM62P5 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node AVM_shared-memories@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a1ffffff (32768 KiB) nomap non-reusable AVM_shared-memories@a0000000 [ 0.000000] OF: reserved mem: initialized node yuv_image00_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a21fffff (2048 KiB) map non-reusable yuv_image00_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image10_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2200000..0x00000000a23fffff (2048 KiB) map non-reusable yuv_image10_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image20_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2400000..0x00000000a25fffff (2048 KiB) map non-reusable yuv_image20_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image30_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2600000..0x00000000a27fffff (2048 KiB) map non-reusable yuv_image30_shared-memories [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009b4fffff] [ 0.000000] node 0: [mem 0x000000009b500000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a1ffffff] [ 0.000000] node 0: [mem 0x00000000a2000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=43398273-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 7433836K/8388608K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 364948K reserved, 589824K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008509] Console: colour dummy device 80x25 [ 0.013097] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023772] pid_max: default: 32768 minimum: 301 [ 0.028560] LSM: initializing lsm=capability,selinux,integrity [ 0.034538] SELinux: Initializing. [ 0.038215] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.045972] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.055701] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.062995] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.070883] rcu: Hierarchical SRCU implementation. [ 0.075779] rcu: Max phase no-delay instances is 1000. [ 0.081344] Platform MSI: msi-controller@1820000 domain created [ 0.087606] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.097008] EFI services will not be available. [ 0.101868] smp: Bringing up secondary CPUs ... [ 0.107042] Detected VIPT I-cache on CPU1 [ 0.107110] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.107125] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.107168] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.107775] Detected VIPT I-cache on CPU2 [ 0.107822] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.107834] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.107862] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.108396] Detected VIPT I-cache on CPU3 [ 0.108438] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.108450] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.108477] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.108537] smp: Brought up 1 node, 4 CPUs [ 0.188194] SMP: Total of 4 processors activated. [ 0.193002] CPU features: detected: 32-bit EL0 Support [ 0.198268] CPU features: detected: CRC32 instructions [ 0.203568] CPU: All CPU(s) started at EL2 [ 0.207759] alternatives: applying system-wide alternatives [ 0.214950] devtmpfs: initialized [ 0.228362] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.238355] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.258447] pinctrl core: initialized pinctrl subsystem [ 0.264242] DMI not present or invalid. [ 0.268705] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.275555] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.282980] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.291080] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.299318] audit: initializing netlink subsys (disabled) [ 0.305006] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1 [ 0.305413] thermal_sys: Registered thermal governor 'step_wise' [ 0.312923] thermal_sys: Registered thermal governor 'power_allocator' [ 0.319098] cpuidle: using governor menu [ 0.329921] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.336926] ASID allocator initialised with 65536 entries [ 0.347413] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000 [ 0.358888] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 0.371532] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.381432] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 0.394124] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.403995] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0 [ 0.414042] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1 [ 0.424098] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.434150] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /display [ 0.442958] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.453018] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /display [ 0.466531] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 0.479285] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.489820] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 0.504224] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.514156] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.524031] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0 [ 0.534079] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1 [ 0.544145] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.554213] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /display [ 0.562981] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.573057] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /display [ 0.583051] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 0.592293] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.601827] Modules: 27488 pages in range for non-PLT usage [ 0.601833] Modules: 519008 pages in range for PLT usage [ 0.608165] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.620540] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.626939] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.633871] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.640271] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.647206] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.653608] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.660543] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.668157] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected [ 0.677391] iommu: Default domain type: Translated [ 0.682304] iommu: DMA domain TLB invalidation policy: strict mode [ 0.688872] SCSI subsystem initialized [ 0.692976] usbcore: registered new interface driver usbfs [ 0.698610] usbcore: registered new interface driver hub [ 0.704063] usbcore: registered new device driver usb [ 0.709638] pps_core: LinuxPPS API ver. 1 registered [ 0.714711] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.724053] PTP clock support registered [ 0.728232] EDAC MC: Ver: 3.0.0 [ 0.731857] scmi_core: SCMI protocol bus registered [ 0.737097] FPGA manager framework [ 0.740645] Advanced Linux Sound Architecture Driver Initialized. [ 0.747708] vgaarb: loaded [ 0.750778] clocksource: Switched to clocksource arch_sys_counter [ 0.757257] VFS: Disk quotas dquot_6.6.0 [ 0.761300] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.774325] Carveout Heap: Exported 2 MiB at 0x00000000a2000000 [ 0.780501] Carveout Heap: Exported 2 MiB at 0x00000000a2200000 [ 0.786653] Carveout Heap: Exported 2 MiB at 0x00000000a2400000 [ 0.792792] Carveout Heap: Exported 2 MiB at 0x00000000a2600000 [ 0.798931] NET: Registered PF_INET protocol family [ 0.804149] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.816536] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.825362] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.833295] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.841746] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.850874] TCP: Hash tables configured (established 65536 bind 65536) [ 0.857700] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.864793] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.872443] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.878624] RPC: Registered named UNIX socket transport module. [ 0.884694] RPC: Registered udp transport module. [ 0.889497] RPC: Registered tcp transport module. [ 0.894300] RPC: Registered tcp-with-tls transport module. [ 0.899903] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.906485] NET: Registered PF_XDP protocol family [ 0.911391] PCI: CLS 0 bytes, default 64 [ 0.916636] Initialise system trusted keyrings [ 0.921388] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.928273] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.934476] NFS: Registering the id_resolver key type [ 0.939663] Key type id_resolver registered [ 0.943939] Key type id_legacy registered [ 0.948047] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.954896] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.991657] Key type asymmetric registered [ 0.995851] Asymmetric key parser 'x509' registered [ 1.000881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 1.008579] io scheduler mq-deadline registered [ 1.013213] io scheduler kyber registered [ 1.017334] io scheduler bfq registered [ 1.024195] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 1.030709] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 1.042594] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 1.058994] loop: module loaded [ 1.063103] megasas: 07.725.01.00-rc1 [ 1.069987] tun: Universal TUN/TAP device driver, 1.6 [ 1.076083] VFIO - User Level meta-driver version: 0.3 [ 1.082304] usbcore: registered new interface driver usb-storage [ 1.088991] i2c_dev: i2c /dev entries driver [ 1.094720] sdhci: Secure Digital Host Controller Interface driver [ 1.101056] sdhci: Copyright(c) Pierre Ossman [ 1.105692] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.112105] ledtrig-cpu: registered to indicate activity on CPUs [ 1.118497] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.125677] usbcore: registered new interface driver usbhid [ 1.131377] usbhid: USB HID core driver [ 1.136416] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 1.145294] optee: probing for conduit method. [ 1.149869] optee: revision 4.4 (8f645256efc0dc66) [ 1.150139] optee: dynamic shared memory is enabled [ 1.160224] optee: initialized driver [ 1.165357] Initializing XFRM netlink socket [ 1.169778] NET: Registered PF_PACKET protocol family [ 1.175088] Key type dns_resolver registered [ 1.186805] registered taskstats version 1 [ 1.191113] Loading compiled-in X.509 certificates [ 1.207363] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') [ 1.255722] /bus@f0000/bus@b00000/i2c@2b200000/pmic@48: Fixed dependency cycle(s) with /bus@f0000/bus@b00000/i2c@2b200000/pmic@48/regulators/buck3 [ 1.269368] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz [ 1.276298] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 1.289022] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz [ 1.296090] pca953x 2-0023: supply vcc not found, using dummy regulator [ 1.303009] pca953x 2-0023: using AI [ 1.328872] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.338097] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.348015] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 1.357219] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 1.367258] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz [ 1.374010] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz [ 1.380199] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.388512] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.397720] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.406667] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.416049] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.424504] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.435354] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.445875] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.455237] ti-udma 4e230000.dma-controller: Number of rings: 6 [ 1.461791] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6) [ 1.471141] printk: console [ttyS2] disabled [ 1.475864] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 251, base_baud = 3000000) is a 8250 [ 1.484742] printk: console [ttyS2] enabled [ 1.484742] printk: console [ttyS2] enabled [ 1.493209] printk: bootconsole [ns16550a0] disabled [ 1.493209] printk: bootconsole [ns16550a0] disabled [ 1.509711] spi-nor spi0.0: s28hs512t (65536 Kbytes) [ 1.514818] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.521773] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.527163] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.533797] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.540248] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.546752] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.552956] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.559743] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.566173] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.742785] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000 [ 1.757547] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.765653] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867 [ 1.773770] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006 [ 1.786607] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.793736] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.800282] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0 [ 1.813547] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.823464] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 1.835947] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 1.852413] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.857965] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.865708] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.871711] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010 [ 1.881132] xhci-hcd xhci-hcd.0.auto: irq 266, io mem 0x31100000 [ 1.887948] hub 1-0:1.0: USB hub found [ 1.891739] hub 1-0:1.0: 1 port detected [ 1.975940] pca953x 2-0022: supply vcc not found, using dummy regulator [ 1.982704] pca953x 2-0022: using AI [ 1.993601] mmc1: CQHCI version 5.10 [ 1.994503] clk: Disabling unused clocks [ 2.005641] ALSA device list: [ 2.008681] No soundcards found. [ 2.041390] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 2.049174] Waiting for root device PARTUUID=43398273-02... [ 2.098037] mmc1: new ultra high speed SDR104 SDHC card at address 0001 [ 2.105257] mmcblk1: mmc1:0001 ASTC 29.1 GiB [ 2.111437] mmcblk1: p1 p2 [ 12.083297] platform 2b300050.target-module: deferred probe pending
eMMC settings in Kconfig
user@am62p:~/projects/am62p/linux-10.01.10.04/board-support/ti-linux-kernel-6.6.58+git-ti$ ./scripts/extract-ikconfig ../prebuilt-images/am62pxx-evm-display-cluster/Image | grep "^CONFIG_MMC" CONFIG_MMC=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=32 CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_IO_ACCESSORS=y CONFIG_MMC_SDHCI_PLTFM=y CONFIG_MMC_SDHCI_OF_ARASAN=y CONFIG_MMC_CQHCI=y CONFIG_MMC_SDHCI_AM654=y user@am62p:~/projects/am62p/linux-10.01.10.04/board-support/ti-linux-kernel-6.6.58+git-ti$ ll ../prebuilt-images/am62pxx-evm-display-cluster/Image -rw-rw-r-- 1 user user 15813120 Apr 25 16:43 ../prebuilt-images/am62pxx-evm-display-cluster/Image
we post device tree here as well.
// SPDX-License-Identifier: GPL-2.0-only OR MIT
* Device Tree file for the AM62P5-SK
* Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/
* Schematics: https://www.ti.com/lit/zip/sprr487
/dts-v1/;
#include <dt-bindings/leds/common.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/net/ti-dp83867.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include "k3-am62p5.dtsi"
compatible = "ti,am62p5-sk", "ti,am62p5";
model = "Texas Instruments AM62P5 SK";
aliases {
serial0 = &wkup_uart0;
serial2 = &main_uart0;
serial3 = &main_uart1;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
spi0 = &ospi0;
ethernet0 = &cpsw_port1;
ethernet1 = &cpsw_port2;
usb0 = &usb0;
usb1 = &usb1;
chosen {
#address-cells = <2>;
#size-cells = <2>;
ranges;
bootargs = "console=ttyS2,115200n8 quiet earlycon=ns16550a,mmio32,0x2800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait";
stdout-path = &main_uart0;
framebuffer0: framebuffer@0 {
compatible = "simple-framebuffer";
power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>,
<&k3_pds 243 TI_SCI_PD_EXCLUSIVE>, /* OLDI0 */
<&k3_pds 244 TI_SCI_PD_EXCLUSIVE>; /* OLDI1 */
clocks = <&k3_clks 186 6>,
<&dss0_vp1_clk>,
<&k3_clks 186 2>;
display = <&dss0>;
status = "disabled";
memory@80000000 {
/* 8G RAM */
reg = <0x00000000 0x80000000 0x00000000 0x80000000>,
<0x00000008 0x80000000 0x00000001 0x80000000>;
device_type = "memory";
bootph-pre-ram;
reserved_memory: reserved-memory {
#size-cells = <2>;
ranges;
linux,cma {
compatible = "shared-dma-pool";
reusable;
size = <0x00 0x24000000>;
linux,cma-default;
rtos_ipc_memory_region: rtos-ipc-memory@9b500000 {
reg = <0x00 0x9b500000 0x00 0x00300000>;
no-map;
mcu_r5fss0_core0_dma_memory_region: mcu-r5fss-dma-memory-region@9b800000 {
reg = <0x00 0x9b800000 0x00 0x00100000>;
no-map;
mcu_r5fss0_core0_memory_region: mcu-r5fss-memory-region@9b900000 {
reg = <0x00 0x9b900000 0x00 0x00f00000>;
no-map;
wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9c800000 {
reg = <0x00 0x9c800000 0x00 0x00100000>;
no-map;
wkup_r5fss0_core0_memory_region: r5f-memory@9c900000 {
reg = <0x00 0x9c900000 0x00 0x01e00000>;
no-map;
secure_tfa_ddr: tfa@9e780000 {
reg = <0x00 0x9e780000 0x00 0x80000>;
no-map;
secure_ddr: optee@9e800000 {
reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */
no-map;
AVM_shared: AVM_shared-memories@a0000000 {
reg = <0x00 0xa0000000 0x00 0x02000000>;
no-map;
yuv_image00_shared: yuv_image00_shared-memories {
compatible = "dma-heap-carveout";
reg = <0x00 0xa2000000 0x00 0x200000>;
yuv_image10_shared: yuv_image10_shared-memories {
reg = <0x00 0xa2200000 0x00 0x200000>;
yuv_image20_shared: yuv_image20_shared-memories {
reg = <0x00 0xa2400000 0x00 0x200000>;
yuv_image30_shared: yuv_image30_shared-memories {
reg = <0x00 0xa2600000 0x00 0x200000>;
vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
compatible = "regulator-fixed";
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
bootph-all;
vcc_5v0: regulator-1 {
/* Output of TPS630702RNMR */
regulator-name = "vcc_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
bootph-all;
vdd_mmc1: regulator-2 {
/* TPS22918DBVR */
regulator-name = "vdd_mmc1";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
enable-active-high;
gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
bootph-all;
vddshv_sdio: regulator-3 {
compatible = "regulator-gpio";
regulator-name = "vddshv_sdio";
pinctrl-names = "default";
pinctrl-0 = <&vddshv_sdio_pins_default>;
regulator-min-microvolt = <1800000>;
regulator-boot-on;
gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
bootph-all;
vcc_3v3_main: regulator-4 {
regulator-name = "vcc_3v3_main";
regulator-boot-on;
leds {
compatible = "gpio-leds";
pinctrl-0 = <&usr_led_pins_default>;
led-0 {
label = "am62-sk:green:heartbeat";
gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
function = LED_FUNCTION_HEARTBEAT;
default-state = "off";
opp-table {
/* Add 1.4GHz OPP for am62p5-sk board. Requires VDD_CORE at 0v85 */
opp-1400000000 {
opp-hz = /bits/ 64 <1400000000>;
opp-supported-hw = <0x01 0x0004>;
clock-latency-ns = <6000000>;
tlv320_mclk: clk-0 {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <12288000>;
codec_audio: sound {
compatible = "simple-audio-card";
simple-audio-card,name = "AM62x-SKEVM";
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Line", "Line In",
"Microphone", "Microphone Jack";
simple-audio-card,routing =
"Headphone Jack", "HPLOUT",
"Headphone Jack", "HPROUT",
"LINE1L", "Line In",
"LINE1R", "Line In",
"MIC3R", "Microphone Jack",
"Microphone Jack", "Mic Bias";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp1>;
sound_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&tlv320_mclk>;
hdmi0: connector-hdmi {
compatible = "hdmi-connector";
label = "hdmi";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&sii9022_out>;
&main_gpio0 {
bootph-all;
status = "okay";
pinctrl-0 = <&test_gpio_default>;
&main_gpio1 {
bootph-all;
&main_pmx0 {
bootph-all;
main_i2c0_pins_default: main-i2c0-default-pins {
pinctrl-single,pins = <
AM62PX_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B25) I2C0_SCL */
AM62PX_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A24) I2C0_SDA */
main_i2c1_pins_default: main-i2c1-default-pins {
AM62PX_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (C24) I2C1_SCL */
AM62PX_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (B24) I2C1_SDA */
bootph-all;
main_i2c2_pins_default: main-i2c2-default-pins {
AM62PX_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (T22) GPMC0_CSn2.I2C2_SCL */
AM62PX_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (U25) GPMC0_CSn3.I2C2_SDA */
main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins {
AM62PX_IOPAD(0x01d4, PIN_INPUT, 7) /* (C22) UART0_RTSn.GPIO1_23 */
main_mcasp1_pins_default: main-mcasp1-default-pins {
AM62PX_IOPAD(0x0090, PIN_INPUT, 2) /* (U24) GPMC0_BE0n_CLE.MCASP1_ACLKX */
AM62PX_IOPAD(0x0098, PIN_INPUT, 2) /* (AA24) GPMC0_WAIT0.MCASP1_AFSX */
AM62PX_IOPAD(0x008c, PIN_OUTPUT, 2) /* (T25) GPMC0_WEn.MCASP1_AXR0 */
AM62PX_IOPAD(0x0084, PIN_INPUT, 2) /* (R25) GPMC0_ADVn_ALE.MCASP1_AXR2 */
main_mdio1_pins_default: main-mdio1-default-pins {
AM62PX_IOPAD(0x0160, PIN_OUTPUT, 0) /* (F17) MDIO0_MDC */
AM62PX_IOPAD(0x015c, PIN_INPUT, 0) /* (F16) MDIO0_MDIO */
main_mmc1_pins_default: main-mmc1-default-pins {
AM62PX_IOPAD(0x023c, PIN_INPUT, 0) /* (H20) MMC1_CMD */
AM62PX_IOPAD(0x0234, PIN_OUTPUT, 0) /* (J24) MMC1_CLK */
AM62PX_IOPAD(0x0230, PIN_INPUT, 0) /* (H21) MMC1_DAT0 */
AM62PX_IOPAD(0x022c, PIN_INPUT_PULLUP, 0) /* (H23) MMC1_DAT1 */
AM62PX_IOPAD(0x0228, PIN_INPUT_PULLUP, 0) /* (H22) MMC1_DAT2 */
AM62PX_IOPAD(0x0224, PIN_INPUT_PULLUP, 0) /* (H25) MMC1_DAT3 */
AM62PX_IOPAD(0x0240, PIN_INPUT, 0) /* (D23) MMC1_SDCD */
bootph-all;
main_mmc2_pins_default: main-mmc2-default-pins {
AM62PX_IOPAD(0x0120, PIN_INPUT, 0) /* (K24) MMC2_CMD */
AM62PX_IOPAD(0x0118, PIN_OUTPUT, 0) /* (K21) MMC2_CLK */
AM62PX_IOPAD(0x011C, PIN_INPUT, 0) /* () MMC2_CLKLB */
AM62PX_IOPAD(0x0114, PIN_INPUT, 0) /* (K23) MMC2_DAT0 */
AM62PX_IOPAD(0x0110, PIN_INPUT_PULLUP, 0) /* (K22) MMC2_DAT1 */
AM62PX_IOPAD(0x010c, PIN_INPUT_PULLUP, 0) /* (L20) MMC2_DAT2 */
AM62PX_IOPAD(0x0108, PIN_INPUT_PULLUP, 0) /* (L21) MMC2_DAT3 */
bootph-all;
main_rgmii1_pins_default: main-rgmii1-default-pins {
AM62PX_IOPAD(0x014c, PIN_INPUT, 0) /* (B15) RGMII1_RD0 */
AM62PX_IOPAD(0x0150, PIN_INPUT, 0) /* (B16) RGMII1_RD1 */
AM62PX_IOPAD(0x0154, PIN_INPUT, 0) /* (A14) RGMII1_RD2 */
AM62PX_IOPAD(0x0158, PIN_INPUT, 0) /* (B14) RGMII1_RD3 */
AM62PX_IOPAD(0x0148, PIN_INPUT, 0) /* (A16) RGMII1_RXC */
AM62PX_IOPAD(0x0144, PIN_INPUT, 0) /* (A15) RGMII1_RX_CTL */
AM62PX_IOPAD(0x0134, PIN_INPUT, 0) /* (A18) RGMII1_TD0 */
AM62PX_IOPAD(0x0138, PIN_INPUT, 0) /* (C17) RGMII1_TD1 */
AM62PX_IOPAD(0x013c, PIN_INPUT, 0) /* (A17) RGMII1_TD2 */
AM62PX_IOPAD(0x0140, PIN_INPUT, 0) /* (C16) RGMII1_TD3 */
AM62PX_IOPAD(0x0130, PIN_INPUT, 0) /* (B17) RGMII1_TXC */
AM62PX_IOPAD(0x012c, PIN_INPUT, 0) /* (B18) RGMII1_TX_CTL */
bootph-all;
main_rgmii2_pins_default: main-rgmii2-default-pins {
AM62PX_IOPAD(0x0184, PIN_INPUT, 0) /* (E19) RGMII2_RD0 */
AM62PX_IOPAD(0x0188, PIN_INPUT, 0) /* (E16) RGMII2_RD1 */
AM62PX_IOPAD(0x018c, PIN_INPUT, 0) /* (E17) RGMII2_RD2 */
AM62PX_IOPAD(0x0190, PIN_INPUT, 0) /* (C19) RGMII2_RD3 */
AM62PX_IOPAD(0x0180, PIN_INPUT, 0) /* (D19) RGMII2_RXC */
AM62PX_IOPAD(0x017c, PIN_INPUT, 0) /* (F19) RGMII2_RX_CTL */
AM62PX_IOPAD(0x016c, PIN_INPUT, 0) /* (B19) RGMII2_TD0 */
AM62PX_IOPAD(0x0170, PIN_INPUT, 0) /* (A21) RGMII2_TD1 */
AM62PX_IOPAD(0x0174, PIN_INPUT, 0) /* (D17) RGMII2_TD2 */
AM62PX_IOPAD(0x0178, PIN_INPUT, 0) /* (A19) RGMII2_TD3 */
AM62PX_IOPAD(0x0168, PIN_INPUT, 0) /* (D16) RGMII2_TXC */
AM62PX_IOPAD(0x0164, PIN_INPUT, 0) /* (A20) RGMII2_TX_CTL */
bootph-all;
main_uart0_pins_default: main-uart0-default-pins {
AM62PX_IOPAD(0x1c8, PIN_INPUT, 0) /* (A22) UART0_RXD */
AM62PX_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (B22) UART0_TXD */
bootph-all;
main_uart1_pins_default: main-uart1-default-pins {
AM62PX_IOPAD(0x0194, PIN_INPUT, 2) /* (D25) MCASP0_AXR3.UART1_CTSn */
AM62PX_IOPAD(0x0198, PIN_OUTPUT, 2) /* (E25) MCASP0_AXR2.UART1_RTSn */
AM62PX_IOPAD(0x01ac, PIN_INPUT, 2) /* (G23) MCASP0_AFSR.UART1_RXD */
AM62PX_IOPAD(0x01b0, PIN_OUTPUT, 2) /* (G20) MCASP0_ACLKR.UART1_TXD */
bootph-all;
main_usb1_pins_default: main-usb1-default-pins {
AM62PX_IOPAD(0x0258, PIN_INPUT, 0) /* (G21) USB1_DRVVBUS */
main_wlirq_pins_default: main-wlirq-default-pins {
AM62PX_IOPAD(0x0128, PIN_INPUT, 7) /* (K25) MMC2_SDWP.GPIO0_72 */
ospi0_pins_default: ospi0-default-pins {
AM62PX_IOPAD(0x0000, PIN_OUTPUT, 0) /* (P23) OSPI0_CLK */
AM62PX_IOPAD(0x002c, PIN_OUTPUT, 0) /* (M25) OSPI0_CSn0 */
AM62PX_IOPAD(0x000c, PIN_INPUT, 0) /* (L25) OSPI0_D0 */
AM62PX_IOPAD(0x0010, PIN_INPUT, 0) /* (N24) OSPI0_D1 */
AM62PX_IOPAD(0x0014, PIN_INPUT, 0) /* (N25) OSPI0_D2 */
AM62PX_IOPAD(0x0018, PIN_INPUT, 0) /* (M24) OSPI0_D3 */
AM62PX_IOPAD(0x001c, PIN_INPUT, 0) /* (N21) OSPI0_D4 */
AM62PX_IOPAD(0x0020, PIN_INPUT, 0) /* (N22) OSPI0_D5 */
AM62PX_IOPAD(0x0024, PIN_INPUT, 0) /* (P21) OSPI0_D6 */
AM62PX_IOPAD(0x0028, PIN_INPUT, 0) /* (N20) OSPI0_D7 */
AM62PX_IOPAD(0x0008, PIN_INPUT, 0) /* (P22) OSPI0_DQS */
bootph-all;
usr_led_pins_default: usr-led-default-pins {
AM62PX_IOPAD(0x0244, PIN_INPUT, 7) /* (D24) MMC1_SDWP.GPIO1_49 */
vddshv_sdio_pins_default: vddshvr-sdio-default-pins {
AM62PX_IOPAD(0x007c, PIN_INPUT, 7) /* (Y25) GPMC0_CLK.GPIO0_31 */
bootph-all;
wlan_en_pins_default: wlan-en-default-pins {
AM62PX_IOPAD(0x0124, PIN_INPUT, 7) /* (J25) MMC2_SDCD.GPIO0_71 */
main_dpi_pins_default: main-dpi-default-pins {
AM62PX_IOPAD(0x0100, PIN_OUTPUT, 0) /* (W20) VOUT0_VSYNC */
AM62PX_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AC20) VOUT0_HSYNC */
AM62PX_IOPAD(0x0104, PIN_OUTPUT, 0) /* (Y21) VOUT0_PCLK */
AM62PX_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (W21) VOUT0_DE */
AM62PX_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (AE24) VOUT0_DATA0 */
AM62PX_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (W23) VOUT0_DATA1 */
AM62PX_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA2 */
AM62PX_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA3 */
AM62PX_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (AB23) VOUT0_DATA4 */
AM62PX_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (AD23) VOUT0_DATA5 */
AM62PX_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (AC23) VOUT0_DATA6 */
AM62PX_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AE23) VOUT0_DATA7 */
AM62PX_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (AE22) VOUT0_DATA8 */
AM62PX_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (AC22) VOUT0_DATA9 */
AM62PX_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA10 */
AM62PX_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AE21) VOUT0_DATA11 */
AM62PX_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AD21) VOUT0_DATA12 */
AM62PX_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AC21) VOUT0_DATA13 */
AM62PX_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (AA20) VOUT0_DATA14 */
AM62PX_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (Y20) VOUT0_DATA15 */
AM62PX_IOPAD(0x005c, PIN_OUTPUT, 1) /* (AC25) GPMC0_AD8.VOUT0_DATA16 */
AM62PX_IOPAD(0x0060, PIN_OUTPUT, 1) /* (AB25) GPMC0_AD9.VOUT0_DATA17 */
AM62PX_IOPAD(0x0064, PIN_OUTPUT, 1) /* (AA25) GPMC0_AD10.VOUT0_DATA18 */
AM62PX_IOPAD(0x0068, PIN_OUTPUT, 1) /* (W24) GPMC0_AD11.VOUT0_DATA19 */
AM62PX_IOPAD(0x006c, PIN_OUTPUT, 1) /* (Y24) GPMC0_AD12.VOUT0_DATA20 */
AM62PX_IOPAD(0x0070, PIN_OUTPUT, 1) /* (AD25) GPMC0_AD13.VOUT0_DATA21 */
AM62PX_IOPAD(0x0074, PIN_OUTPUT, 1) /* (AB24) GPMC0_AD14.VOUT0_DATA22 */
AM62PX_IOPAD(0x0078, PIN_OUTPUT, 1) /* (AC24) GPMC0_AD15.VOUT0_DATA23 */
AM62PX_IOPAD(0x009c, PIN_OUTPUT, 1) /* (AD24) GPMC0_WAIT1.VOUT0_EXTPCLKIN */
test_gpio_default: test-gpio {
AM62PX_IOPAD(0x00a0, PIN_INPUT, 7) /* (P24) GPMC0_WPn.GPIO0_39 */
&main_i2c0 {
status = "okay";
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
typec_pd0: usb-power-controller@3f {
compatible = "ti,tps6598x";
reg = <0x3f>;
connector {
compatible = "usb-c-connector";
label = "USB-C";
self-powered;
data-role = "dual";
power-role = "sink";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
usb_con_hs: endpoint {
remote-endpoint = <&usb0_hs_ep>;
&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
clock-frequency = <100000>;
bootph-all;
tlv320aic3106: audio-codec@1b {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x1b>;
ai3x-micbias-vg = <1>; /* 2.0V */
exp1: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "OLDI_INT#", "x8_NAND_DETECT",
"UART1_FET_SEL", "MMC1_SD_EN",
"VPP_EN", "EXP_PS_3V3_EN",
"UART1_FET_BUF_EN", "EXP_HAT_DETECT",
"DSI_GPIO0", "DSI_GPIO1",
"OLDI_EDID", "BT_UART_WAKE_SOC_3V3",
"USB_TYPEA_OC_INDICATION", "CSI_GPIO0",
"CSI_GPIO1", "WLAN_ALERTn",
"HDMI_INTn", "TEST_GPIO2",
"MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
"MCASP1_FET_SEL", "DSI_EDID",
"PD_I2C_IRQ", "IO_EXP_TEST_LED";
interrupt-parent = <&main_gpio1>;
interrupts = <23 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
bootph-all;
exp2: gpio@23 {
reg = <0x23>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "BT_EN_SOC", "EXP_PS_5V0_EN",
"WL_LT_EN", "",
"TP3", "TP6",
"TP4", "TP7",
"TP5", "TP8",
"SoC_I2C2_MCAN_SEL", "GPIO_HDMI_RSTn",
"GPIO_CPSW2_RST", "GPIO_CPSW1_RST",
"GPIO_OLDI_RSTn", "GPIO_AUD_RSTn",
"GPIO_eMMC_RSTn", "SoC_WLAN_SDIO_RST";
sii9022: bridge-hdmi@3b {
compatible = "sil,sii9022";
reg = <0x3b>;
interrupt-parent = <&exp1>;
interrupts = <16 IRQ_TYPE_EDGE_FALLING>;
sil,i2s-data-lanes = < 0 >;
hdmi_tx_ports: ports {
#size-cells = <0>;
* HDMI can be serviced with 3 potential VPs -
* (DSS0 VP1 / DSS1 VP0 / DSS1 VP1).
* For now, we will service it with DSS0 VP1.
port@0 {
reg = <0>;
sii9022_in: endpoint {
remote-endpoint = <&dss0_dpi1_out>;
port@1 {
reg = <1>;
sii9022_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
&main_i2c2 {
status = "okay";
pinctrl-0 = <&main_i2c2_pins_default>;
&sdhci0 {
status = "okay";
ti,driver-strength-ohm = <50>;
disable-wp;
bootph-all;
&sdhci1 {
/* SD/MMC */
status = "okay";
vmmc-supply = <&vdd_mmc1>;
vqmmc-supply = <&vddshv_sdio>;
pinctrl-0 = <&main_mmc1_pins_default>;
disable-wp;
bootph-all;
&cpsw3g {
pinctrl-0 = <&main_rgmii1_pins_default>,
<&main_rgmii2_pins_default>;
&cpsw_port1 {
phy-mode = "rgmii-rxid";
phy-handle = <&cpsw3g_phy0>;
&cpsw_port2 {
phy-handle = <&cpsw3g_phy1>;
&cpsw3g_mdio {
pinctrl-0 = <&main_mdio1_pins_default>;
status = "okay";
cpsw3g_phy0: ethernet-phy@0 {
reg = <0>;
ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>;
ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>;
ti,min-output-impedance;
cpsw3g_phy1: ethernet-phy@1 {
reg = <1>;
&usbss0 {
status = "okay";
ti,vbus-divider;
&usbss1 {
status = "okay";
ti,vbus-divider;
&usb0 {
usb-role-switch;
#size-cells = <0>;
port@0 {
reg = <0>;
usb0_hs_ep: endpoint {
remote-endpoint = <&usb_con_hs>;
&usb1 {
dr_mode = "host";
pinctrl-0 = <&main_usb1_pins_default>;
&mcasp1 {
status = "okay";
pinctrl-0 = <&main_mcasp1_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
1 0 2 0
0 0 0 0
0 0 0 0
0 0 0 0
tx-num-evt = <0>;
rx-num-evt = <0>;
&fss {
bootph-all;
&ospi0 {
status = "okay";
pinctrl-0 = <&ospi0_pins_default>;
bootph-all;
flash@0{
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-tx-bus-width = <8>;
spi-rx-bus-width = <8>;
spi-max-frequency = <25000000>;
cdns,tshsl-ns = <60>;
cdns,tsd2d-ns = <60>;
cdns,tchsh-ns = <60>;
cdns,tslch-ns = <60>;
cdns,read-delay = <4>;
bootph-all;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
bootph-all;
partition@0 {
label = "ospi.tiboot3";
reg = <0x00 0x80000>;
partition@80000 {
label = "ospi.tispl";
reg = <0x80000 0x200000>;
partition@280000 {
label = "ospi.u-boot";
reg = <0x280000 0x400000>;
partition@680000 {
label = "ospi.env";
reg = <0x680000 0x40000>;
partition@6c0000 {
label = "ospi.env.backup";
reg = <0x6c0000 0x40000>;
partition@800000 {
label = "ospi.rootfs";
reg = <0x800000 0x37c0000>;
partition@3fc0000 {
label = "ospi.phypattern";
reg = <0x3fc0000 0x40000>;
bootph-all;
&mailbox0_cluster0 {
mbox_r5_0: mbox-r5-0 {
ti,mbox-rx = <0 0 0>;
ti,mbox-tx = <1 0 0>;
&mailbox0_cluster1 {
mbox_mcu_r5_0: mbox-mcu-r5-0 {
&wkup_r5fss0 {
status = "okay";
&wkup_r5fss0_core0 {
mboxes = <&mailbox0_cluster0 &mbox_r5_0>;
memory-region = <&wkup_r5fss0_core0_dma_memory_region>,
<&wkup_r5fss0_core0_memory_region>;
&mcu_r5fss0 {
status = "okay";
&mcu_r5fss0_core0 {
mboxes = <&mailbox0_cluster1 &mbox_mcu_r5_0>;
memory-region = <&mcu_r5fss0_core0_dma_memory_region>,
<&mcu_r5fss0_core0_memory_region>;
&main_uart0 {
pinctrl-0 = <&main_uart0_pins_default>;
interrupts-extended = <&gic500 GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>,
<&main_pmx0 0x1c8>; /* (D14) UART0_RXD PADCONFIG114 */
interrupt-names = "irq", "wakeup";
test-gpios = <&main_gpio0 39 GPIO_ACTIVE_HIGH>;
status = "okay";
bootph-all;
&main_uart1 {
pinctrl-0 = <&main_uart1_pins_default>;
/* Main UART1 is used by TIFS firmware */
status = "reserved";
bootph-all;
&mcu_pmx0 {
bootph-all;
pmic_irq_pins_default: pmic-irq-default-pins {
AM62PX_MCU_IOPAD(0x000, PIN_INPUT, 7) /* (B10) MCU_GPIO0_0 */
wkup_uart0_pins_default: wkup-uart0-default-pins {
AM62PX_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (D8) WKUP_UART0_RXD */
AM62PX_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (D7) WKUP_UART0_TXD */
bootph-all;
wkup_i2c0_pins_default: wkup-i2c0-default-pins {
AM62PX_MCU_IOPAD(0x04c, PIN_INPUT, 0) /* (A13) WKUP_I2C0_SCL */
AM62PX_MCU_IOPAD(0x050, PIN_INPUT, 0) /* (C11) WKUP_I2C0_SDA */
&wkup_uart0 {
/* WKUP UART0 is used by DM firmware */
pinctrl-0 = <&wkup_uart0_pins_default>;
bootph-all;
&wkup_i2c0 {
status = "okay";
pinctrl-0 = <&wkup_i2c0_pins_default>;
tps65224: pmic@48 {
compatible = "ti,tps65224-q1";
reg = <0x48>;
pinctrl-0 = <&pmic_irq_pins_default>;
interrupt-parent = <&mcu_gpio0>;
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
ti,primary-pmic;
gpio-controller;
#gpio-cells = <2>;
buck12-supply = <&vcc_3v3_main>;
buck3-supply = <&vcc_3v3_main>;
buck4-supply = <&vcc_3v3_main>;
ldo1-supply = <&vcc_3v3_main>;
ldo2-supply = <&vcc_3v3_main>;
ldo3-supply = <&buck3>;
regulators {
buck12: buck12 {
regulator-name = "vcc_core_buck12";
regulator-min-microvolt = <715000>;
regulator-max-microvolt = <895000>;
regulator-boot-on;
buck3: buck3 {
regulator-name = "vcc1v8_sys_buck3";
regulator-max-microvolt = <1800000>;
regulator-boot-on;
buck4: buck4 {
regulator-name = "vcc1v1_buck4";
regulator-min-microvolt = <1100000>;
regulator-max-microvolt = <1100000>;
regulator-boot-on;
ldo1: ldo1 {
regulator-name = "vdda1v8_ldo1";
regulator-boot-on;
ldo2: ldo2 {
regulator-name = "dvdd3v3_ldo2";
regulator-boot-on;
ldo3: ldo3 {
regulator-name = "vcc_0v85_ldo3";
regulator-min-microvolt = <850000>;
regulator-max-microvolt = <850000>;
regulator-boot-on;
/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */
&mcu_gpio0 {
status = "okay";
&mcu_gpio_intr {
status = "okay";
&dss_oldi_io_ctrl {
bootph-all;
&dss0 {
bootph-all;
status = "okay";
pinctrl-0 = <&main_dpi_pins_default>;
&dss0_ports {
/* DSS0-VP2: DPI/HDMI Output */
hdmi0_dss: port@1 {
reg = <1>;
dss0_dpi1_out: endpoint {
remote-endpoint = <&sii9022_in>;
However, if boot from SD card, rootfs could be loaded successfully. It shows rootfs in eMMC is fine.
SYSFW Firmware Version 10.1.8--v10.01.08 (Fiery Fox) SYSFW Firmware revision 0xa SYSFW ABI revision 4.0 [BOOTLOADER_PROFILE] Boot Media : SD Card [BOOTLOADER_PROFILE] Boot Image Size : 263 KB [BOOTLOADER_PROFILE] Cores present : mcu-r5f0-0 wkup-r5f0-0 a530-0 [BOOTLOADER PROFILE] System_init : 38728us [BOOTLOADER PROFILE] Drivers_open : 2794us [BOOTLOADER PROFILE] Board_driversOpen : 0us [BOOTLOADER PROFILE] Sciclient Get Version : 10052us [BOOTLOADER PROFILE] MCU R5 Image Load : 261274us [BOOTLOADER PROFILE] WKUP R5 Image Load : 274166us [BOOTLOADER PROFILE] A53 Image Load : 2018549us [BOOTLOADER_PROFILE] SBL Total Time Taken : 2605566us Image loading done, switching to application ... Starting linux and RTOS/Baremetal applications NOTICE: BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty NOTICE: BL31: Built : 04:20:32, Nov 1 2024 [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.58 (user@am62p) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #11 SMP PREEMPT Tue Apr 22 14:01:02 CST 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM62P5 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader! [ 0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000 [ 0.000000] OF: reserved mem: 0x000000009e780000..0x000000009e7fffff (512 KiB) nomap non-reusable tfa@9e780000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node AVM_shared-memories@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a1ffffff (32768 KiB) nomap non-reusable AVM_shared-memories@a0000000 [ 0.000000] OF: reserved mem: initialized node yuv_image00_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a21fffff (2048 KiB) map non-reusable yuv_image00_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image10_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2200000..0x00000000a23fffff (2048 KiB) map non-reusable yuv_image10_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image20_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2400000..0x00000000a25fffff (2048 KiB) map non-reusable yuv_image20_shared-memories [ 0.000000] OF: reserved mem: initialized node yuv_image30_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a2600000..0x00000000a27fffff (2048 KiB) map non-reusable yuv_image30_shared-memories [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009b4fffff] [ 0.000000] node 0: [mem 0x000000009b500000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e77ffff] [ 0.000000] node 0: [mem 0x000000009e780000-0x00000000a1ffffff] [ 0.000000] node 0: [mem 0x00000000a2000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 20 pages/cpu s42216 r8192 d31512 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2800000 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 7455116K/8388608K available (9600K kernel code, 978K rwdata, 2976K rodata, 1728K init, 492K bss, 343668K reserved, 589824K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008503] Console: colour dummy device 80x25 [ 0.013084] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023753] pid_max: default: 32768 minimum: 301 [ 0.028535] LSM: initializing lsm=capability,selinux,integrity [ 0.034513] SELinux: Initializing. [ 0.038184] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.045937] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.055585] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.062866] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.070751] rcu: Hierarchical SRCU implementation. [ 0.075649] rcu: Max phase no-delay instances is 1000. [ 0.081202] Platform MSI: msi-controller@1820000 domain created [ 0.087597] EFI services will not be available. [ 0.092452] smp: Bringing up secondary CPUs ... [ 0.097626] Detected VIPT I-cache on CPU1 [ 0.097693] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.097707] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.097748] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.098331] Detected VIPT I-cache on CPU2 [ 0.098379] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.098391] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.098419] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.098916] Detected VIPT I-cache on CPU3 [ 0.098962] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.098973] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.098996] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.099052] smp: Brought up 1 node, 4 CPUs [ 0.178676] SMP: Total of 4 processors activated. [ 0.183482] CPU features: detected: 32-bit EL0 Support [ 0.188743] CPU features: detected: CRC32 instructions [ 0.194039] CPU: All CPU(s) started at EL2 [ 0.198228] alternatives: applying system-wide alternatives [ 0.205154] devtmpfs: initialized [ 0.215412] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.225403] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.245450] pinctrl core: initialized pinctrl subsystem [ 0.251060] DMI not present or invalid. [ 0.255498] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.262272] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.269677] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.277768] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.285952] audit: initializing netlink subsys (disabled) [ 0.291622] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1 [ 0.299553] cpuidle: using governor menu [ 0.303639] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.310635] ASID allocator initialised with 65536 entries [ 0.321149] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000 [ 0.332619] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 0.345267] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.355175] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 0.367872] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.377739] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0 [ 0.387784] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1 [ 0.397845] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.407895] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /display [ 0.416690] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.426741] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /display [ 0.439517] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 0.452254] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.462823] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector [ 0.476980] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.486908] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.496780] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@0 [ 0.506831] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/dss@30200000/oldi-txes/oldi@1 [ 0.516895] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.526972] /bus@f0000/dss@30200000/oldi-txes/oldi@0: Fixed dependency cycle(s) with /display [ 0.535741] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 0.545814] /bus@f0000/dss@30200000/oldi-txes/oldi@1: Fixed dependency cycle(s) with /display [ 0.555759] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 0.564980] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.574441] Modules: 28768 pages in range for non-PLT usage [ 0.574446] Modules: 520288 pages in range for PLT usage [ 0.580639] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.593015] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.599418] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.606355] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.612758] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.619693] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.626096] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.633027] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.640425] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected [ 0.649480] iommu: Default domain type: Translated [ 0.654388] iommu: DMA domain TLB invalidation policy: strict mode [ 0.661117] EDAC MC: Ver: 3.0.0 [ 0.664695] scmi_core: SCMI protocol bus registered [ 0.670716] clocksource: Switched to clocksource arch_sys_counter [ 0.682800] Carveout Heap: Exported 2 MiB at 0x00000000a2000000 [ 0.688954] Carveout Heap: Exported 2 MiB at 0x00000000a2200000 [ 0.695110] Carveout Heap: Exported 2 MiB at 0x00000000a2400000 [ 0.701242] Carveout Heap: Exported 2 MiB at 0x00000000a2600000 [ 0.707377] NET: Registered PF_INET protocol family [ 0.712587] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.724942] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.733766] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.741704] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.750148] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.759263] TCP: Hash tables configured (established 65536 bind 65536) [ 0.766096] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.773180] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.780827] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.787012] RPC: Registered named UNIX socket transport module. [ 0.793078] RPC: Registered udp transport module. [ 0.797886] RPC: Registered tcp transport module. [ 0.802688] RPC: Registered tcp-with-tls transport module. [ 0.808289] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.814871] NET: Registered PF_XDP protocol family [ 0.820892] Initialise system trusted keyrings [ 0.825591] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.832612] NFS: Registering the id_resolver key type [ 0.837816] Key type id_resolver registered [ 0.842089] Key type id_legacy registered [ 0.846197] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.853044] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.889685] Key type asymmetric registered [ 0.893880] Asymmetric key parser 'x509' registered [ 0.898903] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.906597] io scheduler mq-deadline registered [ 0.911226] io scheduler kyber registered [ 0.915347] io scheduler bfq registered [ 0.921294] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.927857] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.937825] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.948205] panel-simple display: supply power not found, using dummy regulator [ 0.961192] loop: module loaded [ 0.965847] i2c_dev: i2c /dev entries driver [ 0.970877] sdhci: Secure Digital Host Controller Interface driver [ 0.977199] sdhci: Copyright(c) Pierre Ossman [ 0.981807] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.987992] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.995738] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 1.004620] optee: probing for conduit method. [ 1.009184] optee: revision 4.4 (8f645256efc0dc66) [ 1.009437] optee: dynamic shared memory is enabled [ 1.019518] optee: initialized driver [ 1.023667] Initializing XFRM netlink socket [ 1.028051] NET: Registered PF_PACKET protocol family [ 1.033286] Key type dns_resolver registered [ 1.042114] Loading compiled-in X.509 certificates [ 1.055731] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') [ 1.094580] /bus@f0000/bus@b00000/i2c@2b200000/pmic@48: Fixed dependency cycle(s) with /bus@f0000/bus@b00000/i2c@2b200000/pmic@48/regulators/buck3 [ 1.108184] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz [ 1.114901] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000 [ 1.127591] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz [ 1.134498] pca953x 2-0023: supply vcc not found, using dummy regulator [ 1.141338] pca953x 2-0023: using AI [ 1.168791] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.178006] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.187920] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 1.197119] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000 [ 1.207127] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz [ 1.213757] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz [ 1.219832] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.228134] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.237330] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.246271] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.255562] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.263856] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.274449] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.284705] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.293884] ti-udma 4e230000.dma-controller: Number of rings: 6 [ 1.300413] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6) [ 1.312152] mmc0: CQHCI version 5.10 [ 1.353298] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.386608] pca953x 2-0022: supply vcc not found, using dummy regulator [ 1.393471] pca953x 2-0022: using AI [ 1.401118] printk: console [ttyS2] disabled [ 1.405765] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 475, base_baud = 3000000) is a 8250 [ 1.414629] printk: console [ttyS2] enabled [ 1.414629] printk: console [ttyS2] enabled [ 1.423090] printk: bootconsole [ns16550a0] disabled [ 1.423090] printk: bootconsole [ns16550a0] disabled [ 1.440813] mmc1: CQHCI version 5.10 [ 1.442280] clk: Disabling unused clocks [ 1.455181] mmc0: Command Queue Engine enabled [ 1.459652] mmc0: new HS400 MMC card at address 0001 [ 1.465115] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.470656] mmcblk0: p1 p2 [ 1.473960] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 1.479433] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 1.484810] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (248:0) [ 1.491265] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 1.552089] mmc1: new ultra high speed SDR104 SDHC card at address 0001 [ 1.559316] mmcblk1: mmc1:0001 ASTC 29.1 GiB [ 1.565140] mmcblk1: p1 p2 [ 1.587393] EXT4-fs (mmcblk0p2): recovery complete [ 1.592752] EXT4-fs (mmcblk0p2): mounted filesystem 79cda2bc-3b52-468c-86a0-547f85b513a5 r/w with ordered data mode. Quota mode: disabled. [ 1.605248] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.611540] devtmpfs: mounted [ 1.614960] Freeing unused kernel memory: 1728K [ 1.619549] Run /sbin/init as init process INIT: version 3.04 booting Starting udev [ 1.809610] udevd[112]: starting version 3.2.14 [ 2.894723] random: crng init done [ 2.910090] udevd[113]: starting eudev-3.2.14 [ 3.134838] EXT4-fs (mmcblk0p2): re-mounted 79cda2bc-3b52-468c-86a0-547f85b513a5 r/w. Quota mode: disabled. hwclock: can't open '/dev/misc/rtc': No such file or directory Fri Mar 9 12:34:56 UTC 2018 hwclock: can't open '/dev/misc/rtc': No such file or directory INIT: Entering runlevel: 5misc/rtc': No such file or directory Configuring network interfaces... ip: SIOCGIFFLAGS: No such device ip: SIOCGIFFLAGS: No such device Starting syslogd/klogd: done Poky (Yocto Project Reference Distro) 5.0.8 am62pxx-evm /dev/ttyS2 am62pxx-evm login:
Is there any possibility? Thanks.
Image and dts were uploaded for reference at https://tidrive.ext.ti.com/u/htRL7CZUS36U1Evk/bbafdc6a-fe2e-48b2-bd7d-688416fdfb58?l
access code: b2q$Pgi8
Wilson Hung
