How to capture an image??
           We are working with DM355_IPNC camera  which using montavista linux 2.6.10,arm_v5t_le. Actually we want to create a C-program for capturing the picture.Can anyone tell me that how to do this??
We have tried with the following program but it was not working..plz can anyone help me??
code
include "ApproDrvMsg.h"
#include "Appro_interface.h"
#include "cmem.h"
#include "Msg_Def.h"
#include <stdio.h>
int i;
void Init_Interface(int Msg_id)
    int qid;
    if(ApproDrvInit(Msg_id))
    exit(1);
    if(func_get_mem(&qid))
    ApproDrvExit();
    exit(1);
int SaveAudioFile( char *pFileName )
        FILE *pfd = NULL;
        int error_code = 0;
        int     SerialBook = -1;
        int     SerialLock = -1;
        int     ret = 0;
        int     save_cnt = 1;
        AV_DATA av_data;
        pfd = fopen(pFileName,"wb");
        if( pfd == NULL )
               // ERR("open file error!!");
                error_code = -1;
                goto RECORD_QUIT;
        if( fseek( pfd, 0, SEEK_SET ) < 0)
               // ERR("seek file error!!");
                error_code = -1;
                goto RECORD_QUIT;
        do
                GetAVData(AV_OP_GET_MJPEG_SERIAL, -1, &av_data );
        } while (av_data.serial < 0);
        SerialBook = av_data.serial;
        while( save_cnt > 0)
                ret = GetAVData(AV_OP_LOCK_MJPEG, SerialBook, &av_data );
                if (ret == RET_SUCCESS)
                        if( fwrite( av_data.ptr,av_data.size,1, pfd )  <= 0)
                               // ERR("save file error!!");
                                error_code = -1;
                                goto RECORD_QUIT;
                        if (SerialLock >= 0)
                                GetAVData(AV_OP_UNLOCK_MJPEG, SerialLock, &av_data);
                        SerialLock = SerialBook;
                        save_cnt--;
                        SerialBook++;
                else
                        if( SerialBook > av_data.serial )
                                // delay for waiting next frame
                               // usleep(5);
                                 // sleep();
                for(i=0;i<1000;i++);
                        }else{
RECORD_QUIT:
        if( pfd )
                fclose(pfd);
        return error_code;
int main()
    int result = 0;
    char *pFileName = "snap_test.jpg";
    Init_Interface(0x01);
    result = SaveAudioFile(pFileName );
    return 0;
Makefile
# Makefile
# Set this to where Rules.make exists
ROOTDIR = ../../..
TARGET = take_snap
include $(ROOTDIR)/Rules.make
#CONFIG = codec/codecscfg
C_FLAGS += -Wall -g
#$(shell cat $(CONFIG)/compiler.opt)
CPP_FLAGS += -I$(DVEVM_INSTALL_DIR)/demos/utils/include \
                -I$(LINUXKERNEL_INSTALL_DIR)/include \
                -I./appro_3a \
        -D_GNU_SOURCE \
        -D_LARGEFILE64_SOURCE \
        -D_FILE_OFFSET_BITS=64 \
                $(XDC_FLAGS)
LD_FLAGS += -lfreetype -lpng -ljpeg -lpthread
all:
    $(MVTOOL_PREFIX)gcc $(LD_FLAGS) take_snap.o -o take_snap $(LIB_DIR)/cmem.a $(LIB_DIR)/Appro_interface.a
        #$(MVTOOL_PREFIX)gcc $(C_FLAGS) $(CPP_FLAGS) -c take_snap.c
    #$(MAKE) take_snap.c
#COMPILE.c = $(MVTOOL_PREFIX)gcc $(C_FLAGS) $(CPP_FLAGS) -c
#LINK.c = $(MVTOOL_PREFIX)gcc $(LD_FLAGS)
#RELTARGET = $(TARGET)
#RELCFLAGS = -O2 -fno-strict-aliasing
#SOURCES = $(wildcard *.c)
#HEADERS = $(wildcard *.h)
#RELOBJFILES = $(SOURCES:%.c=release/%.o)
#RELLDFLAGS =
#release:    codec_chk    $(RELTARGET)
#codec_chk:
#    $(MAKE)  -C take_snap
#.PHONY: clean release install
#all:    release
#install: release
#    install -d $(EXEC_DIR)
#    install $(RELTARGET) $(EXEC_DIR)
#codec_chk:
#    $(MAKE) -C codec/
#codec/dm355_mpeg4_enc.o:
#    $(MAKE) -C codec/
#$(RELTARGET):   $(RELOBJFILES) codec/dm355_enc.o appro_3a/Appro_3A.a
#    $(LINK.c) -o $@ $^ $(RELLDFLAGS)
## $(CONFIG)/linker.cmd
#$(RELOBJFILES): release/%.o: %.c $(HEADERS)
#    @mkdir -p release
#    $(COMPILE.c) $(RELCFLAGS) -o $@ $<
#clean::
#    -$(RM) -rf release  *.d
#    $(MAKE) -C codec/ clean
