AM62P: CSI2RX: Digilent PCam5C fails streaming to display in SDK 11
Part Number: AM62P
I was running through the Capture to display instructions to test if my Digilent PCam5C could stream to the hdmi display when i ran into the following error:
U-Boot SPL 2025.01-00406-gcd91d7360181 (Mar 25 2025 - 16:14:37 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
SPL initial stack usage: 17056 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.12.0(release):11.00.08-1-gb11beb2b6-dirty
NOTICE:  BL31: Built : 12:35:58, Mar 24 2025
SPL initial stack usage: 1904 bytes
U-Boot 2025.01-00406-gcd91d7360181 (Mar 25 2025 - 16:14:37 +0000)
SoC:   AM62PX SR1.0 HS-FS
Model: Texas Instruments AM62P5 SK
DRAM:  2 GiB (total 8 GiB)
Core:  97 devices, 32 uclasses, devicetree: separate
MMC:   mmc@fa10000: 0, mmc@fa00000: 1
Loading Environment from nowhere... OK
In:    serial
Out:   serial
Err:   serial
Net:   eth0: ethernet@8000000port@1
Warning: ethernet@8000000port@2 (eth1) using random MAC address - fa:e2:37:d6:f6:b3
, eth1: ethernet@8000000port@2
Hit any key to stop autoboot:  0
=> setenv name_overlays ti/k3-am62x-sk-csi2-ov5640.dtbo
=> boot
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
574 bytes read in 1 ms (560.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
22256128 bytes read in 228 ms (93.1 MiB/s)
64479 bytes read in 3 ms (20.5 MiB/s)
Working FDT set to 88000000
2332 bytes read in 2 ms (1.1 MiB/s)
   Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
Working FDT set to 8feed000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.17-ti-00771-gc85877d40f8e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Mar 25 12:45:29 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM62P5 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
[    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008683] Console: colour dummy device 80x25
[    0.013279] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023949] pid_max: default: 32768 minimum: 301
[    0.028751] LSM: initializing lsm=capability,selinux
[    0.033877] SELinux:  Initializing.
[    0.037910] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.045670] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.069955] rcu: Hierarchical SRCU implementation.
[    0.074876] rcu:     Max phase no-delay instances is 1000.
[    0.080404] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.089149] EFI services will not be available.
[    0.097824] smp: Bringing up secondary CPUs ...
[    0.110813] Detected VIPT I-cache on CPU1
[    0.110896] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.110912] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[    0.110961] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.118808] Detected VIPT I-cache on CPU2
[    0.118873] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.118888] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[    0.118922] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.126825] Detected VIPT I-cache on CPU3
[    0.126887] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.126901] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[    0.126935] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.127062] smp: Brought up 1 node, 4 CPUs
[    0.206699] SMP: Total of 4 processors activated.
[    0.211506] CPU: All CPU(s) started at EL2
[    0.215705] CPU features: detected: 32-bit EL0 Support
[    0.220955] CPU features: detected: CRC32 instructions
[    0.226253] alternatives: applying system-wide alternatives
[    0.232560] Memory: 7455124K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 334608K reserved, 589824K cma-reserved)
[    0.248139] devtmpfs: initialized
[    0.262354] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.272357] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.294436] 27152 pages in range for non-PLT usage
[    0.294462] 518672 pages in range for PLT usage
[    0.299662] pinctrl core: initialized pinctrl subsystem
[    0.310147] DMI not present or invalid.
[    0.316234] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.323535] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.330985] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.339099] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.347724] audit: initializing netlink subsys (disabled)
[    0.353543] audit: type=2000 audit(0.240:1): state=initialized audit_enabled=0 res=1
[    0.353974] thermal_sys: Registered thermal governor 'step_wise'
[    0.361466] thermal_sys: Registered thermal governor 'power_allocator'
[    0.367659] cpuidle: using governor menu
[    0.378503] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.385531] ASID allocator initialised with 65536 entries
[    0.397155] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[    0.408654] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.421297] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.431187] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    0.444651] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.457381] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
[    0.470821] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.485984] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.498750] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.508742] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    0.522927] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.537487] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
[    0.551266] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.561199] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.572563] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.581794] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.591836] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.598777] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.605187] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.612120] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.618522] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.625454] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.631856] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.638788] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.646915] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
[    0.656221] iommu: Default domain type: Translated
[    0.661141] iommu: DMA domain TLB invalidation policy: strict mode
[    0.667871] SCSI subsystem initialized
[    0.672046] usbcore: registered new interface driver usbfs
[    0.677680] usbcore: registered new interface driver hub
[    0.683135] usbcore: registered new device driver usb
[    0.688793] pps_core: LinuxPPS API ver. 1 registered
[    0.693874] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.703217] PTP clock support registered
[    0.707256] EDAC MC: Ver: 3.0.0
[    0.710792] scmi_core: SCMI protocol bus registered
[    0.716065] FPGA manager framework
[    0.719619] Advanced Linux Sound Architecture Driver Initialized.
[    0.726795] vgaarb: loaded
[    0.729936] clocksource: Switched to clocksource arch_sys_counter
[    0.736427] VFS: Disk quotas dquot_6.6.0
[    0.740464] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.754738] NET: Registered PF_INET protocol family
[    0.760029] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.772997] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.781839] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.789781] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.798288] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.807569] TCP: Hash tables configured (established 65536 bind 65536)
[    0.814461] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.821559] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.829253] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.835537] RPC: Registered named UNIX socket transport module.
[    0.841616] RPC: Registered udp transport module.
[    0.846423] RPC: Registered tcp transport module.
[    0.851230] RPC: Registered tcp-with-tls transport module.
[    0.856833] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.863418] NET: Registered PF_XDP protocol family
[    0.868330] PCI: CLS 0 bytes, default 64
[    0.873655] Initialise system trusted keyrings
[    0.878442] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.885360] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.891609] NFS: Registering the id_resolver key type
[    0.896812] Key type id_resolver registered
[    0.901087] Key type id_legacy registered
[    0.905199] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.912049] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.972610] Key type asymmetric registered
[    0.976813] Asymmetric key parser 'x509' registered
[    0.981857] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.989606] io scheduler mq-deadline registered
[    0.994245] io scheduler kyber registered
[    0.998371] io scheduler bfq registered
[    1.005463] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    1.012024] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    1.019700] ledtrig-cpu: registered to indicate activity on CPUs
[    1.031970] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.047224] loop: module loaded
[    1.051558] megasas: 07.727.03.00-rc1
[    1.059182] tun: Universal TUN/TAP device driver, 1.6
[    1.065416] VFIO - User Level meta-driver version: 0.3
[    1.071925] usbcore: registered new interface driver usb-storage
[    1.078667] i2c_dev: i2c /dev entries driver
[    1.084693] sdhci: Secure Digital Host Controller Interface driver
[    1.091083] sdhci: Copyright(c) Pierre Ossman
[    1.095774] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.102262] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.109529] usbcore: registered new interface driver usbhid
[    1.115311] usbhid: USB HID core driver
[    1.120575] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    1.130874] optee: probing for conduit method.
[    1.135446] optee: revision 4.5 (ef1ebdc23034a804)
[    1.135824] optee: dynamic shared memory is enabled
[    1.146441] optee: initialized driver
[    1.146547] random: crng init done
[    1.151889] Initializing XFRM netlink socket
[    1.158076] NET: Registered PF_PACKET protocol family
[    1.163334] Key type dns_resolver registered
[    1.176101] registered taskstats version 1
[    1.180464] Loading compiled-in X.509 certificates
[    1.197915] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
[    1.254161] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    1.266932] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.274435] pca953x 1-0023: supply vcc not found, using dummy regulator
[    1.281334] pca953x 1-0023: using AI
[    1.300133] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.309374] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.319306] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    1.328524] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    1.338620] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.345566] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    1.359247] pca954x 2-0071: supply vdd not found, using dummy regulator
[    1.382240] i2c i2c-2: Added multiplexed i2c bus 3
[    1.387436] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
[    1.400930] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    1.414546] i2c i2c-2: Added multiplexed i2c bus 4
[    1.419453] pca954x 2-0071: registered 2 multiplexed busses for I2C switch pca9543
[    1.427343] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.433333] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.442583] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.451577] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[    1.461714] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
[    1.470567] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
[    1.491251] Console: switching to colour frame buffer device 240x75
[    1.507705] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
[    1.515462] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.524152] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.535238] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.546254] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.555762] ti-udma 4e230000.dma-controller: Number of rings: 6
[    1.562447] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    1.571946] printk: legacy console [ttyS2] disabled
[    1.577357] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
[    1.586238] printk: legacy console [ttyS2] enabled
[    1.595933] printk: legacy bootconsole [ns16550a0] disabled
[    1.613322] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.620345] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.625749] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.632487] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.638997] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.645542] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.651842] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.658805] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.665364] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.672366] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
[    1.713947] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[    1.728405] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.736512] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.744637] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[    1.757582] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.764727] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[    1.772475] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[    1.791782] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.802655] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    1.815149] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    1.832302] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.837834] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.845611] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    1.851615] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
[    1.861049] xhci-hcd xhci-hcd.0.auto: irq 265, io mem 0x31100000
[    1.868182] hub 1-0:1.0: USB hub found
[    1.871975] hub 1-0:1.0: 1 port detected
[    1.878959] mmc0: CQHCI version 5.10
[    1.884704] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.891485] pca953x 1-0022: using AI
[    1.900770] clk: Disabling unused clocks
[    1.909469] PM: genpd: Disabling unused power domains
[    1.914759] ALSA device list:
[    1.914897] mmc1: CQHCI version 5.10
[    1.917725]   No soundcards found.
[    1.917990] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.972942] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.980675] Waiting for root device PARTUUID=076c4a2a-02...
[    2.013816] mmc0: Command Queue Engine enabled
[    2.018297] mmc0: new HS200 MMC card at address 0001
[    2.024891] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.033691]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20
[    2.034434] mmc1: new ultra high speed SDR104 SDHC card at address 0001
[    2.044574] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.049319] mmcblk1: mmc1:0001 GB1QT 29.8 GiB
[    2.054694] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.059880]  mmcblk1: p1 p2
[    2.063937] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    2.234537] EXT4-fs (mmcblk1p2): mounted filesystem 73196f33-5653-4d14-9e7f-cce534928a30 r/w with ordered data mode. Quota mode: none.
[    2.246749] VFS: Mounted root (ext4 filesystem) on device 179:66.
[    2.253510] devtmpfs: mounted
[    2.257244] Freeing unused kernel memory: 2752K
[    2.261873] Run /sbin/init as init process
[    2.444820] systemd[1]: System time before build time, advancing clock.
[    2.488245] NET: Registered PF_INET6 protocol family
[    2.494318] Segment Routing with IPv6
[    2.498033] In-situ OAM (IOAM) with IPv6
[    2.529662] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.561575] systemd[1]: Detected architecture arm64.
Welcome to Arago 2025.01!
[    2.580146] systemd[1]: Hostname set to <am62pxx-evm>.
[    2.801247] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.916571] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.089429] systemd[1]: Queued start job for default target Graphical Interface.
[    3.151745] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    3.172390] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    3.192469] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    3.211856] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    3.230417] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    3.250310] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.270136] systemd[1]: Expecting device /dev/ttyS2...
[    3.282189] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    3.294097] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    3.310066] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    3.322086] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    3.391135] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    3.410255] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    3.432955] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    3.450517] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    3.471296] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    3.490730] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    3.510806] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    3.522967] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    3.545231] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.562646] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.578719] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    3.638327] systemd[1]: Mounting Huge Pages File System...
[    3.654359] systemd[1]: Mounting POSIX Message Queue File System...
[    3.678382] systemd[1]: Mounting Kernel Debug File System...
[    3.690691] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.708943] systemd[1]: Mounting Temporary Directory /tmp...
[    3.727843] systemd[1]: Starting Create List of Static Device Nodes...
[    3.750897] systemd[1]: Starting Load Kernel Module configfs...
[    3.774753] systemd[1]: Starting Load Kernel Module drm...
[    3.791021] systemd[1]: Starting Load Kernel Module fuse...
[    3.819668] systemd[1]: Starting Start psplash boot splash screen...
         Starting Start psplash boot splash screen.[    3.830157] fuse: init (API version 7.41)
[    3.851754] systemd[1]: Starting RPC Bind...
[    3.866565] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    3.887933] systemd[1]: Starting Journal Service...
[    3.906846] systemd[1]: Starting Load Kernel Modules...
[    3.931086] systemd[1]: Starting Generate network units from Kernel command line...
[    3.955595] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.960149] cryptodev: loading out-of-tree module taints kernel.
         Starting Remount Root and Kernel File Systems sysctl table check failed: ioctl/(null) procname is null
[0m...
[    3.980743] sysctl table check failed: ioctl/(null) No proc_handler
[    3.982790] systemd-journald[127]: Collecting audit messages is enabled.
[    3.987836] cryptodev: driver 1.14 loaded.
[    4.014710] systemd[1]: Starting Coldplug All udev Devices...
[    4.048840] systemd[1]: Started Start psplash boot splash screen.
[  OK  ] Started Start psplash boot splash screen.
[    4.066556] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    4.082417] EXT4-fs (mmcblk1p2): re-mounted 73196f33-5653-4d14-9e7f-cce534928a30 r/w. Quota mode: none.
[    4.082746] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
[  OK  ] Started Start psplash-systemd progress communication helper.
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev gr[    4.407187] systemd-journald[127]: Received client request to flush runtime journal.
acefully...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    4.688950] audit: type=1334 audit(1736360579.240:2): prog-id=6 op=LOAD
[    4.695641] audit: type=1334 audit(1736360579.248:3): prog-id=7 op=LOAD
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create System Files and Directories...
[  OK  ] Finished Load/Save OS Random Seed.
[  OK  ] Finished Create System Files and Directories.
[    4.900149] audit: type=1334 audit(1736360579.452:4): prog-id=8 op=LOAD
         Starting Network Name Resolution...
[    4.945981] audit: type=1334 audit(1736360579.496:5): prog-id=9 op=LOAD
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[    4.988649] audit: type=1334 audit(1736360579.540:6): prog-id=10 op=LOAD
[    4.995527] audit: type=1334 audit(1736360579.548:7): prog-id=11 op=LOAD
[    5.002373] audit: type=1334 audit(1736360579.556:8): prog-id=12 op=LOAD
         Starting User Database Manager...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started User Database Manager.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
[    5.629863] audit: type=1334 audit(1745855522.825:9): prog-id=13 op=LOAD
         Starting D-Bus System Message Bus...
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Found device /dev/ttyS2.
[  OK  ] Finished Reboot and dump vmcore via kexec.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started Periodic Command Scheduler.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[  OK  ] Started irqbalance daemon.
[  OK  ] Started Multiple Spanning Tree Protocol Daemon.
         Starting Telephony service...
         Starting PulseAudio Sound System...
         Starting Expand the rootfs partiti…to full size of the boot device....
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[    6.412375] audit: type=1334 audit(1745855523.609:10): prog-id=14 op=LOAD
[    6.427381] audit: type=1334 audit(1745855523.617:11): prog-id=15 op=LOAD
         Starting User Login Management...
[    6.442061] audit: type=1334 audit(1745855523.617:12): prog-id=16 op=LOAD
         Starting Telnet Server...
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Reached target Preparation for Network.
[    6.568306] audit: type=1334 audit(1745855523.765:13): prog-id=17 op=LOAD
         Starting Network Configuration...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Telephony service.
[    6.735940] Bluetooth: Core ver 2.22
[    6.742154] NET: Registered PF_BLUETOOTH protocol family
[    6.747541] Bluetooth: HCI device and connection manager initialized
[    6.755617] Bluetooth: HCI socket layer initialized
[    6.760852] Bluetooth: L2CAP socket layer initialized
[    6.766306] Bluetooth: SCO socket layer initialized
[  OK  ] Finished Expand the rootfs partition to full size of the boot device..
[  OK  ] Started User Login Management.
[  OK  ] Started PulseAudio Sound System.
[    7.218312] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    7.314898] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    7.330997] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Started Network Configuration.
[    7.517618] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    7.527043] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    7.557249] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[    7.566710] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[  OK  ] Reached target Network.
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
         Starting LLDP daemon...
[  OK  ] Started Netperf Benchmark Server.
[    7.776823] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
         Starting Simple Network Management Protocol (S[    7.788309] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
NMP) Daemon....
[    7.808655] mc: Linux media interface: v0.10
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[    7.907676] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[  OK  ] Finished Permit User Sessions.
[    7.958146] videodev: Linux video capture interface: v2.00
[  OK  ] Started emptty display manager.
[    7.981236] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
[    7.995247] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
[    8.004465] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
[  OK  ] Started Getty on tty1.
[    8.049038] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting ti-apps-launcher service...
[    8.086204] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
[    8.108194] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
[    8.126211] platform 79000000.r5f: configured R5F for remoteproc mode
[    8.133758] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
[    8.144067] remoteproc remoteproc0: 79000000.r5f is available
[    8.153138] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    8.165554] platform 78000000.r5f: configured R5F for IPC-only mode
[    8.172250] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
[  OK  ] Started LLDP daemon.
[    8.182193] remoteproc remoteproc0: powering up 79000000.r5f
[    8.191702] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 58312
[    8.192435] remoteproc remoteproc1: 78000000.r5f is available
[    8.205760] remoteproc remoteproc1: attaching to 78000000.r5f
[    8.213515] ov5640 4-003c: supply DOVDD not found, using dummy regulator
[    8.223522] ov5640 4-003c: supply AVDD not found, using dummy regulator
[    8.234320] ov5640 4-003c: supply DVDD not found, using dummy regulator
[    8.241154] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
[    8.268146] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9c800000
[    8.278097] virtio_rpmsg_bus virtio1: rpmsg host is online
[    8.279163] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    8.286082] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
[    8.295620] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.295791] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    8.298123] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    8.326153] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
[    8.326171] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    8.333064] remoteproc remoteproc0: remote processor 79000000.r5f is now up
[    8.376351] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[  OK  ] Reached target Hardware activated USB gadget.
[    8.474285] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[    8.482450] vdec 30210000.video-codec: Product Code:      0x521c
[    8.488661] vdec 30210000.video-codec: Firmware Revision: 344874
[    8.559061] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    8.568553] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    8.611459] PVR_K:  188: Device: fd80000.gpu
[    8.619740] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
[    8.713769] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
[    8.714081] i2c i2c-1: Added multiplexed i2c bus 5
[    8.760362] PVR_K:  188: Read BVNC 36.53.104.796 from HW device registers
[    8.767776] PVR_K:  188: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[  OK  ] Created slice Slice /system/tee-supplicant.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started TEE Supplicant on teepriv0.
[    8.923139] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 1
[    8.963939] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
[    8.964233] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 0
         Starting Virtual Console Setup...
[  OK  ] Stopped Virtual Console Setup.
[    9.098236] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[  OK  ] Finished Virtual Console Setup.
         Starting Save/Restore Sound Card State...
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Created slice Slice /system/systemd-fsck.
         Expecting device /dev/mmcblk0p1...
[  OK  ] Reached target Sound Card.
[  OK  ] Found device /dev/mmcblk0p1.
         Starting File System Check on /dev/mmcblk0p1...
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
         Mounting /run/media/bootloader-mmcblk0p1...
[  OK  ] Mounted /run/media/bootloader-mmcblk0p1.
         Expecting device /dev/mmcblk0p19...
[  OK  ] Found device /dev/mmcblk0p19.
         Starting File System Check on /dev/mmcblk0p19...
[  OK  ] Finished File System Check on /dev/mmcblk0p19.
         Mounting /run/media/mnt/vendor/pers-mmcblk0p19...
[   10.139889] EXT4-fs (mmcblk0p19): mounted filesystem d07a9cda-4c00-4590-acde-fb8bb0dab821 r/w with ordered data mode. Quota mode: none.
[  OK  ] Started containerd container runtime.
[  OK  ] Mounted /run/media/mnt/vendor/pers-mmcblk0p19.
         Expecting device /dev/mmcblk1p1...
[  OK  ] Found device /dev/mmcblk1p1.
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
         Mounting /run/media/boot-mmcblk1p1...
[  OK  ] Mounted /run/media/boot-mmcblk1p1.
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils-dev
        elfutils
        findutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gnu-config
        grub-common
        grub-editenv
        grub-efi
        gzip
        hidapi
        kbd-dev
        kbd-keymaps-pine
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libgnutls-dev
        libgnutls-openssl27
        libgomp1
        libidn2-0
        libidn2-dev
        libmpc3
        libmpfr6
        libopcodes
        libqt6core5compat-plugins
        libqt6core5compat-qmlplugins
        libqt6core5compat6
        libqt6shadertools-dev
        libqt6shadertools-plugins
        libqt6shadertools-qmlplugins
        libqt6shadertools6
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libtasn1-dev
        libunistring-dev
        libunistring5
        m4
        make
        nettle-dev
        nettle
        parted
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-dev
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase-staticdev
        qtbase
        qtdeclarative-dev
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-staticdev
        qtdeclarative-tools
        qtdeclarative
        qtlanguageserver-dev
        qtlanguageserver-plugins
        qtlanguageserver-qmlplugins
        qtlanguageserver-staticdev
        qtlanguageserver
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquick3d-plugins
        qtquick3d-qmlplugins
        qtquick3d
        qtquicktimeline-plugins
        qtquicktimeline-qmlplugins
        qtquicktimeline
        qtsvg-dev
        qtsvg-plugins
        qtsvg-qmlplugins
        qtsvg
        qttools-plugins
        qttools-qmlplugins
        qttools
        qtwayland-dev
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Finished Print notice about GPLv3 packages.
[   11.641239] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   13.816840] audit: type=1006 audit(1745855531.013:14): pid=1434 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   13.830817] audit: type=1300 audit(1745855531.013:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff8f79238 a2=4 a3=1 items=0 ppid=1 pid=1434 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
[   13.858916] audit: type=1327 audit(1745855531.013:14): proctitle="(systemd)"
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am62pxx-evm ttyS2
Arago 2025.01 am62pxx-evm ttyS2
am62pxx-evm login: [   15.920199] PVR_K:  1442: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[   15.932710] PVR_K:  1442: Shader binary image 'rgx.sh.36.53.104.796' loaded
root
[   21.067074] audit: type=1006 audit(1745855538.265:15): pid=1480 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
[   21.080726] audit: type=1300 audit(1745855538.265:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc397f788 a2=1 a3=1 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
[   21.108426] audit: type=1327 audit(1745855538.265:15): proctitle="(systemd)"
[   21.154749] audit: type=1334 audit(1745855538.353:16): prog-id=18 op=LOAD
[   21.161611] audit: type=1300 audit(1745855538.353:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd359e5c8 a2=90 a3=0 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
[   21.188502] audit: type=1327 audit(1745855538.353:16): proctitle="(systemd)"
[   21.195792] audit: type=1334 audit(1745855538.353:17): prog-id=18 op=UNLOAD
[   21.202833] audit: type=1300 audit(1745855538.353:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffa765cc60 items=0 ppid=1 pid=1480 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
[   21.229647] audit: type=1327 audit(1745855538.353:17): proctitle="(systemd)"
[   21.236847] audit: type=1334 audit(1745855538.353:18): prog-id=19 op=LOAD
root@am62pxx-evm:~# lsmod | grep ov5640
ov5640                 36864  0
v4l2_fwnode            20480  3 ov5640,cdns_csi2rx
v4l2_async             20480  4 v4l2_fwnode,j721e_csi2rx,ov5640,cdns_csi2rx
videodev              253952  8 v4l2_async,v4l2_fwnode,j721e_csi2rx,ov5640,videobuf2_v4l2,cdns_csi2rx,v4l2_mem2mem,wave5
mc                     57344  8 v4l2_async,videodev,j721e_csi2rx,ov5640,videobuf2_v4l2,cdns_csi2rx,videobuf2_common,v4l2_mem2mem
root@am62pxx-evm:~# gst-launch-1.0 v4l2src device="/dev/video2" ! video/x-raw, width=640, height=480, format=UYVY ! autovideosink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstKMSSink:autovideosink0-actual-sink-kms: GStreamer encountered a general resource error.
Additional debug info:
/usr/src/debug/gstreamer1.0-plugins-bad/1.22.12/sys/kms/gstkmssink.c(2032): gst_kms_sink_show_frame (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstKMSSink:autovideosink0-actual-sink-kms:
drmModeSetPlane failed: Permission denied (13)
Execution ended after 0:00:00.423682425
Setting pipeline to NULL ...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
/usr/src/debug/gstreamer1.0/1.22.12/libs/gst/base/gstbasesrc.c(3134): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
Freeing pipeline ...
root@am62pxx-evm:~#
I made sure to double check the sensors connection to the CSI port and I used the proper device tree overlay described in the instructions.
Along with this bug I noticed that in the Ti apps launcher the "Live Camera" app is no longer present.
Am I missing any steps for video streaming to hdmi or is this a bug?
- Job
  • Hello Job,
    I noticed the following error:
    Please try either kmssink or waylandsink:
    root@am62pxx-evm:~# gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=UYVY ! ticolorconvert ! video/x-raw,width=640,height=480,format=NV12 ! waylandsink
    root@am62pxx-evm:~# gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=UYVY ! kmssink driver-name=tidss force-modesetting=true
    Jianzhong
  • Hello Jianzhong,
    Thank you for the reply.
    I tried running the kmssink and waylandsink commands and experienced the following error:
    In:    serial
    Out:   serial
    Err:   serial
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - be:ef:ae:84:00:b3
    => boot
    22256128 bytes read in 232 ms (91.5 MiB/s)
    Starting kernel ...
    [    0.008706] Console: colour dummy device 80x25
    [    0.013303] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023975] pid_max: default: 32768 minimum: 301
    [    0.028783] LSM: initializing lsm=capability,selinux
    [    0.033910] SELinux:  Initializing.
    [    0.037964] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.045726] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.070020] rcu: Hierarchical SRCU implementation.
    [    0.074940] rcu:     Max phase no-delay instances is 1000.
    [    0.080479] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.089241] EFI services will not be available.
    [    0.097917] smp: Bringing up secondary CPUs ...
    [    0.110844] Detected VIPT I-cache on CPU1
    [    0.110930] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.110947] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.110995] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.118904] Detected VIPT I-cache on CPU2
    [    0.118969] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.118984] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.119019] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.126926] Detected VIPT I-cache on CPU3
    [    0.126994] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.127010] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.127043] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.127160] smp: Brought up 1 node, 4 CPUs
    [    0.206804] SMP: Total of 4 processors activated.
    [    0.211613] CPU: All CPU(s) started at EL2
    [    0.215812] CPU features: detected: 32-bit EL0 Support
    [    0.221064] CPU features: detected: CRC32 instructions
    [    0.226361] alternatives: applying system-wide alternatives
    [    0.232719] Memory: 7455124K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 334608K reserved, 589824K cma-reserved)
    [    0.248307] devtmpfs: initialized
    [    0.262918] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.272920] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.295309] 27152 pages in range for non-PLT usage
    [    0.295334] 518672 pages in range for PLT usage
    [    0.300535] pinctrl core: initialized pinctrl subsystem
    [    0.311032] DMI not present or invalid.
    [    0.317187] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.324524] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.331986] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.340102] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.348758] audit: initializing netlink subsys (disabled)
    [    0.354549] audit: type=2000 audit(0.240:1): state=initialized audit_enabled=0 res=1
    [    0.354993] thermal_sys: Registered thermal governor 'step_wise'
    [    0.362474] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.368667] cpuidle: using governor menu
    [    0.379519] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.386553] ASID allocator initialised with 65536 entries
    [    0.398407] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.409921] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.422566] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.432457] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    0.445924] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.458658] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    0.472102] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.487453] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.500229] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.510221] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    0.524433] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.539068] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    0.552862] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.562797] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.574219] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.583454] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.593404] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.600378] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.606793] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.613728] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.620138] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.627075] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.633480] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.640414] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.648627] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    0.657999] iommu: Default domain type: Translated
    [    0.662924] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.669646] SCSI subsystem initialized
    [    0.673845] usbcore: registered new interface driver usbfs
    [    0.679484] usbcore: registered new interface driver hub
    [    0.684942] usbcore: registered new device driver usb
    [    0.690603] pps_core: LinuxPPS API ver. 1 registered
    [    0.695679] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.705023] PTP clock support registered
    [    0.709062] EDAC MC: Ver: 3.0.0
    [    0.712593] scmi_core: SCMI protocol bus registered
    [    0.717890] FPGA manager framework
    [    0.721455] Advanced Linux Sound Architecture Driver Initialized.
    [    0.728654] vgaarb: loaded
    [    0.731803] clocksource: Switched to clocksource arch_sys_counter
    [    0.738358] VFS: Disk quotas dquot_6.6.0
    [    0.742394] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.756926] NET: Registered PF_INET protocol family
    [    0.762227] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.775408] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.784265] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.792202] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.800712] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.810031] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.816925] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.824035] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.831719] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.838023] RPC: Registered named UNIX socket transport module.
    [    0.844100] RPC: Registered udp transport module.
    [    0.848917] RPC: Registered tcp transport module.
    [    0.853726] RPC: Registered tcp-with-tls transport module.
    [    0.859331] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.865917] NET: Registered PF_XDP protocol family
    [    0.870829] PCI: CLS 0 bytes, default 64
    [    0.876361] Initialise system trusted keyrings
    [    0.881166] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.888077] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.894328] NFS: Registering the id_resolver key type
    [    0.899529] Key type id_resolver registered
    [    0.903807] Key type id_legacy registered
    [    0.907930] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.914781] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.977555] Key type asymmetric registered
    [    0.981766] Asymmetric key parser 'x509' registered
    [    0.986827] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.994570] io scheduler mq-deadline registered
    [    0.999210] io scheduler kyber registered
    [    1.003335] io scheduler bfq registered
    [    1.010543] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    1.017118] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    1.024886] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.037298] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.052873] loop: module loaded
    [    1.057227] megasas: 07.727.03.00-rc1
    [    1.064969] tun: Universal TUN/TAP device driver, 1.6
    [    1.071260] VFIO - User Level meta-driver version: 0.3
    [    1.077793] usbcore: registered new interface driver usb-storage
    [    1.084535] i2c_dev: i2c /dev entries driver
    [    1.090583] sdhci: Secure Digital Host Controller Interface driver
    [    1.096923] sdhci: Copyright(c) Pierre Ossman
    [    1.101624] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.108141] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.115434] usbcore: registered new interface driver usbhid
    [    1.121146] usbhid: USB HID core driver
    [    1.126300] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.136608] optee: probing for conduit method.
    [    1.141188] optee: revision 4.5 (ef1ebdc23034a804)
    [    1.141559] optee: dynamic shared memory is enabled
    [    1.152269] optee: initialized driver
    [    1.152370] random: crng init done
    [    1.157823] Initializing XFRM netlink socket
    [    1.163915] NET: Registered PF_PACKET protocol family
    [    1.169165] Key type dns_resolver registered
    [    1.182208] registered taskstats version 1
    [    1.186687] Loading compiled-in X.509 certificates
    [    1.204083] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
    [    1.261267] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.274088] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.281679] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.288626] pca953x 1-0023: using AI
    [    1.310014] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.319254] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.329193] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.338409] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.348627] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.355637] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    1.369341] pca954x 2-0071: supply vdd not found, using dummy regulator
    [    1.392108] i2c i2c-2: Added multiplexed i2c bus 3
    [    1.397302] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    1.410800] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    1.424415] i2c i2c-2: Added multiplexed i2c bus 4
    [    1.429322] pca954x 2-0071: registered 2 multiplexed busses for I2C switch pca9543
    [    1.437164] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.443218] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.452469] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.461486] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.471628] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.480484] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.501397] Console: switching to colour frame buffer device 240x75
    [    1.518044] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.525801] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.534550] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.545737] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.556868] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.566445] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.573115] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.582639] printk: legacy console [ttyS2] disabled
    [    1.588093] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
    [    1.596996] printk: legacy console [ttyS2] enabled
    [    1.606699] printk: legacy bootconsole [ns16550a0] disabled
    [    1.623386] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.630379] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.635773] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.642554] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.649048] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.655581] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.661909] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.668875] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.675425] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.682450] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.723818] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.738326] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.746434] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.754557] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.767524] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.774662] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.782409] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.802955] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.814107] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.826616] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.843861] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.849380] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.857150] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.863157] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.872590] xhci-hcd xhci-hcd.0.auto: irq 265, io mem 0x31100000
    [    1.879490] hub 1-0:1.0: USB hub found
    [    1.883285] hub 1-0:1.0: 1 port detected
    [    1.888865] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.901386] mmc0: CQHCI version 5.10
    [    1.910730] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.917497] pca953x 1-0022: using AI
    [    1.926706] clk: Disabling unused clocks
    [    1.935482] PM: genpd: Disabling unused power domains
    [    1.940730] ALSA device list:
    [    1.940878] mmc1: CQHCI version 5.10
    [    1.943696]   No soundcards found.
    [    1.947291] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.996359] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.004266] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.036626] mmc0: Command Queue Engine enabled
    [    2.041139] mmc0: new HS200 MMC card at address 0001
    [    2.047024] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.054731]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20
    [    2.058321] mmc1: new ultra high speed SDR104 SDHC card at address 0001
    [    2.065575] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.070481] mmcblk1: mmc1:0001 GB1QT 29.8 GiB
    [    2.075881] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.080801]  mmcblk1: p1 p2
    [    2.084952] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.306339] EXT4-fs (mmcblk1p2): recovery complete
    [    2.320784] EXT4-fs (mmcblk1p2): mounted filesystem 73196f33-5653-4d14-9e7f-cce534928a30 r/w with ordered data mode. Quota mode: none.
    [    2.332953] VFS: Mounted root (ext4 filesystem) on device 179:66.
    [    2.339660] devtmpfs: mounted
    [    2.343367] Freeing unused kernel memory: 2752K
    [    2.347989] Run /sbin/init as init process
    [    2.534088] systemd[1]: System time before build time, advancing clock.
    [    2.577936] NET: Registered PF_INET6 protocol family
    [    2.583989] Segment Routing with IPv6
    [    2.587677] In-situ OAM (IOAM) with IPv6
    [    2.619457] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.651377] systemd[1]: Detected architecture arm64.
    [    2.674055] systemd[1]: Hostname set to <am62pxx-evm>.
    [    2.888969] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    3.004427] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.177382] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.229798] systemd[1]: Created slice Slice /system/getty.
    [    3.250237] systemd[1]: Created slice Slice /system/modprobe.
    [    3.270177] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.289662] systemd[1]: Created slice User and Session Slice.
    [    3.308250] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.328163] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.348005] systemd[1]: Expecting device /dev/ttyS2...
    [    3.364080] systemd[1]: Reached target Path Units.
    [    3.379954] systemd[1]: Reached target Remote File Systems.
    [    3.395933] systemd[1]: Reached target Slice Units.
    [    3.407952] systemd[1]: Reached target Swaps.
    [    3.473014] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.492113] systemd[1]: Reached target RPC Port Mapper.
    [    3.514832] systemd[1]: Listening on Process Core Dump Socket.
    [    3.532391] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.553137] systemd[1]: Listening on Journal Audit Socket.
    [    3.572663] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.592694] systemd[1]: Listening on Journal Socket.
    [    3.608798] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.631242] systemd[1]: Listening on udev Control Socket.
    [    3.648518] systemd[1]: Listening on udev Kernel Socket.
    [    3.664606] systemd[1]: Listening on User Database Manager Socket.
    [    3.728212] systemd[1]: Mounting Huge Pages File System...
    [    3.744219] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.768367] systemd[1]: Mounting Kernel Debug File System...
    [    3.780552] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.798775] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.817667] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.840770] systemd[1]: Starting Load Kernel Module configfs...
    [    3.864504] systemd[1]: Starting Load Kernel Module drm...
    [    3.880823] systemd[1]: Starting Load Kernel Module fuse...
    [    3.909798] systemd[1]: Starting Start psplash boot splash screen...
             Starting Start psplash boot splash screen.[    3.920530] fuse: init (API version 7.41)
    [    3.937805] systemd[1]: Starting RPC Bind...
    [    3.948390] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    3.957994] systemd[1]: Starting Journal Service...
    [    3.986878] systemd[1]: Starting Load Kernel Modules...
    [    4.008888] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.033190] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.035411] cryptodev: loading out-of-tree module taints kernel.
    [    4.052315] sysctl table check failed: ioctl/(null) procname is null
    [    4.056419] systemd-journald[129]: Collecting audit messages is enabled.
    [    4.059231] sysctl table check failed: ioctl/(null) No proc_handler
    [    4.072106] cryptodev: driver 1.14 loaded.
    [    4.112823] systemd[1]: Starting Coldplug All udev Devices...
    [    4.144623] systemd[1]: Started Start psplash boot splash screen.
    [    4.166000] systemd[1]: Started RPC Bind.
    [    4.180719] systemd[1]: Started Journal Service.
    [    4.192475] EXT4-fs (mmcblk1p2): re-mounted 73196f33-5653-4d14-9e7f-cce534928a30 r/w. Quota mode: none.
             Starting Create Static Device Nodes in /dev gr[    4.524713] systemd-journald[129]: Received client request to flush runtime journal.
    acefully...
    [    4.746714] audit: type=1334 audit(1736360579.208:2): prog-id=6 op=LOAD
    [    4.753433] audit: type=1334 audit(1736360579.216:3): prog-id=7 op=LOAD
    [    4.918220] audit: type=1334 audit(1736360579.380:4): prog-id=8 op=LOAD
    [    4.924906] audit: type=1334 audit(1736360579.388:5): prog-id=9 op=LOAD
    [    4.931567] audit: type=1334 audit(1736360579.392:6): prog-id=10 op=LOAD
    [    5.413219] audit: type=1334 audit(1736360579.876:7): prog-id=11 op=LOAD
    [    5.460684] audit: type=1334 audit(1736360579.924:8): prog-id=12 op=LOAD
    [    6.086975] audit: type=1334 audit(1745869421.752:9): prog-id=13 op=LOAD
    [    6.598352] audit: type=1334 audit(1745869422.264:10): prog-id=14 op=LOAD
    [    6.609513] audit: type=1334 audit(1745869422.272:11): prog-id=15 op=LOAD
    [    6.620434] audit: type=1334 audit(1745869422.272:12): prog-id=16 op=LOAD
    [    6.951946] audit: type=1334 audit(1745869422.616:13): prog-id=17 op=LOAD
    [    7.317092] Bluetooth: Core ver 2.22
    [    7.322811] NET: Registered PF_BLUETOOTH protocol family
    [    7.330802] Bluetooth: HCI device and connection manager initialized
    [    7.337309] Bluetooth: HCI socket layer initialized
    [    7.343871] Bluetooth: L2CAP socket layer initialized
    [    7.349701] Bluetooth: SCO socket layer initialized
    [    7.548350] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.576753] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.583936] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    7.653656] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    7.668341] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    7.670955] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    7.675606] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    7.690438] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    7.690819] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    7.699745] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    7.744299] mc: Linux media interface: v0.10
    [    7.807433] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.816942] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    7.859732] videodev: Linux video capture interface: v2.00
    [    7.874784] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    7.922054] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    7.932114] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    7.963143] ov5640 4-003c: supply DOVDD not found, using dummy regulator
    [    7.974200] ov5640 4-003c: supply AVDD not found, using dummy regulator
    [    7.983157] ov5640 4-003c: supply DVDD not found, using dummy regulator
    [    7.984533] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    7.986193] platform 79000000.r5f: configured R5F for remoteproc mode
    [    8.003024] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    8.018262] remoteproc remoteproc0: 79000000.r5f is available
    [    8.028013] remoteproc remoteproc0: powering up 79000000.r5f
    [    8.033864] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 58312
    [    8.068115] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    8.076150] vdec 30210000.video-codec: Product Code:      0x521c
    [    8.082203] vdec 30210000.video-codec: Firmware Revision: 344874
             Starting Simple Network Management Protocol (SNMP) Daemon....
    [    8.116680] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    8.133098] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.145264] platform 78000000.r5f: configured R5F for IPC-only mode
    [    8.147163] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.151670] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.157233] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
    [    8.165028] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    8.171620] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    8.199748] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.208479] remoteproc remoteproc1: 78000000.r5f is available
    [    8.219416] remoteproc remoteproc1: attaching to 78000000.r5f
    [    8.239527] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    8.264650] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    8.268249] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.277123] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.280001] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    8.291766] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    8.297113] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    8.297191] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    8.332040] i2c i2c-1: Added multiplexed i2c bus 5
    [    8.376384] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    8.506506] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    8.522058] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    8.532028] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    [    8.541805] PVR_K:  199: Device: fd80000.gpu
    [  OK  ] Started emptty display manager.[    8.552106] PVR_K:  199: Read BVNC 36.53.104.796 from HW device registers
    [    8.562118] PVR_K:  199: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    8.563648] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
    [    8.583129] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
    [    9.999849] EXT4-fs (mmcblk0p19): mounted filesystem d07a9cda-4c00-4590-acde-fb8bb0dab821 r/w with ordered data mode. Quota mode: none.
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat6
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver
            qtmultimedia
            qtquick3d-plugins
            qtquick3d
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland
            tar
            which
    [   11.931056] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   14.357647] audit: type=1006 audit(1745869430.024:14): pid=1435 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   14.371559] audit: type=1300 audit(1745869430.024:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffff829468 a2=4 a3=1 items=0 ppid=1 pid=1435 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   14.399472] audit: type=1327 audit(1745869430.024:14): proctitle="(systemd)"
     _____                    _____           _         _
                  |___|                    |___|
    am62pxx-evm login: [   16.406265] PVR_K:  1443: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   16.418663] PVR_K:  1443: Shader binary image 'rgx.sh.36.53.104.796' loaded
    root
    [   29.335307] audit: type=1006 audit(1745869445.000:15): pid=1495 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   29.348937] audit: type=1300 audit(1745869445.000:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffdcacf508 a2=1 a3=1 items=0 ppid=1 pid=1495 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   29.376642] audit: type=1327 audit(1745869445.000:15): proctitle="(systemd)"
    [   29.408589] audit: type=1334 audit(1745869445.076:16): prog-id=18 op=LOAD
    [   29.415437] audit: type=1300 audit(1745869445.076:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd36c6eb8 a2=90 a3=0 items=0 ppid=1 pid=1495 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   29.442368] audit: type=1327 audit(1745869445.076:16): proctitle="(systemd)"
    [   29.449507] audit: type=1334 audit(1745869445.076:17): prog-id=18 op=UNLOAD
    [   29.456530] audit: type=1300 audit(1745869445.076:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffbd553c60 items=0 ppid=1 pid=1495 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   29.483260] audit: type=1327 audit(1745869445.076:17): proctitle="(systemd)"
    [   29.490376] audit: type=1334 audit(1745869445.076:18): prog-id=19 op=LOAD
    root@am62pxx-evm:~# [   53.582392] kauditd_printk_skb: 5 callbacks suppressed
    [   53.582407] audit: type=1334 audit(1746018052.124:20): prog-id=20 op=LOAD
    [   53.772076] audit: type=1334 audit(1746018052.316:21): prog-id=20 op=UNLOAD
    root
    -sh: root: command not found
    WARNING: erroneous pipeline: no element "ticolorconvert"
    /GstPipeline:pipeline0/GstKMSSink:kmssink0: display-width = 1920
    /GstPipeline:pipeline0/GstKMSSink:kmssink0: display-height = 1080
    /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
    ERROR: from element /GstPipeline:pipeline0/GstKMSSink:kmssink0: GStreamer error: negotiation problem.
    /usr/src/debug/gstreamer1.0-plugins-bad/1.22.12/sys/kms/gstkmssink.c(1502): gst_kms_sink_set_caps (): /GstPipeline:pipeline0/GstKMSSink:kmssink0:
    failed to configure video mode
    Execution ended after 0:00:00.005807573
    root@am62pxx-evm:~#
    - Job
  • Can you provide the "media-ctl -p" output?
    Can you try to use v4l2-ctl or yavta to capture the image?
  • Here are the outputs:
    CSI_Failure4.txt
    I was able to capture some raw data frames with yavta.
    - Job
  • Hi Job,
    You should use /dev/video2 in your v4l2-ctl capture:
    root@am62pxx-evm:~# v4l2-ctl -d /dev/video2 --set-fmt-video=width=640,height=480,pixelformat=UYVY --stream-mmap=6
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 67.50 fps
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<^C
    Jianzhong
  • Hi Jianzhong,
    Looks like v4l2-ctl works now and capturing raw frames doesn't seem to be an issue.
    U-Boot SPL 2025.01-00406-gcd91d7360181 (Mar 25 2025 - 16:14:37 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
    SPL initial stack usage: 17056 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.12.0(release):11.00.08-1-gb11beb2b6-dirty
    NOTICE:  BL31: Built : 12:35:58, Mar 24 2025
    SPL initial stack usage: 1904 bytes
    U-Boot 2025.01-00406-gcd91d7360181 (Mar 25 2025 - 16:14:37 +0000)
    SoC:   AM62PX SR1.0 HS-FS
    Model: Texas Instruments AM62P5 SK
    DRAM:  2 GiB (total 8 GiB)
    Core:  97 devices, 32 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial
    Out:   serial
    Err:   serial
    Net:   eth0: ethernet@8000000port@1
    Warning: ethernet@8000000port@2 (eth1) using random MAC address - 7a:60:16:59:e0:8c
    , eth1: ethernet@8000000port@2
    Hit any key to stop autoboot:  0
    =>  setenv name_overlays ti/k3-am62x-sk-csi2-ov5640.dtbo
    => boot
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 1 ms (560.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22256128 bytes read in 228 ms (93.1 MiB/s)
    64479 bytes read in 3 ms (20.5 MiB/s)
    Working FDT set to 88000000
    2332 bytes read in 3 ms (758.8 KiB/s)
       Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
    Working FDT set to 8feed000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.17-ti-00771-gc85877d40f8e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Mar 25 12:45:29 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM62P5 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
    [    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
    [    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
    [    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000002] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.013304] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023976] pid_max: default: 32768 minimum: 301
    [    0.028784] LSM: initializing lsm=capability,selinux
    [    0.033912] SELinux:  Initializing.
    [    0.037965] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.045725] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.070018] rcu: Hierarchical SRCU implementation.
    [    0.074939] rcu:     Max phase no-delay instances is 1000.
    [    0.080478] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.089242] EFI services will not be available.
    [    0.097916] smp: Bringing up secondary CPUs ...
    [    0.106917] Detected VIPT I-cache on CPU1
    [    0.107000] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.107019] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.107067] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.114893] Detected VIPT I-cache on CPU2
    [    0.114957] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.114973] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.115007] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.118910] Detected VIPT I-cache on CPU3
    [    0.118973] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.118988] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.119019] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.119146] smp: Brought up 1 node, 4 CPUs
    [    0.198791] SMP: Total of 4 processors activated.
    [    0.203600] CPU: All CPU(s) started at EL2
    [    0.207795] CPU features: detected: 32-bit EL0 Support
    [    0.213050] CPU features: detected: CRC32 instructions
    [    0.218348] alternatives: applying system-wide alternatives
    [    0.224665] Memory: 7455124K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 334608K reserved, 589824K cma-reserved)
    [    0.240248] devtmpfs: initialized
    [    0.254874] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.264883] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.287312] 27152 pages in range for non-PLT usage
    [    0.287337] 518672 pages in range for PLT usage
    [    0.292540] pinctrl core: initialized pinctrl subsystem
    [    0.303042] DMI not present or invalid.
    [    0.309203] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.316562] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
    [    0.324018] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.332137] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.340801] audit: initializing netlink subsys (disabled)
    [    0.346622] audit: type=2000 audit(0.232:1): state=initialized audit_enabled=0 res=1
    [    0.347067] thermal_sys: Registered thermal governor 'step_wise'
    [    0.354549] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.360745] cpuidle: using governor menu
    [    0.371596] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.378626] ASID allocator initialised with 65536 entries
    [    0.390474] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.401987] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.414630] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.424522] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    0.437989] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.450725] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    0.464164] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.479511] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    0.492279] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.502275] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    0.516489] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.531126] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    0.544920] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.554859] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.566291] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.575526] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.585488] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.592463] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.598882] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.605818] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.612227] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.619162] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.625565] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.632499] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.640718] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
    [    0.650106] iommu: Default domain type: Translated
    [    0.655031] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.661757] SCSI subsystem initialized
    [    0.665943] usbcore: registered new interface driver usbfs
    [    0.671583] usbcore: registered new interface driver hub
    [    0.677044] usbcore: registered new device driver usb
    [    0.682720] pps_core: LinuxPPS API ver. 1 registered
    [    0.687798] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.697141] PTP clock support registered
    [    0.701181] EDAC MC: Ver: 3.0.0
    [    0.704702] scmi_core: SCMI protocol bus registered
    [    0.709989] FPGA manager framework
    [    0.713553] Advanced Linux Sound Architecture Driver Initialized.
    [    0.720820] vgaarb: loaded
    [    0.723974] clocksource: Switched to clocksource arch_sys_counter
    [    0.730531] VFS: Disk quotas dquot_6.6.0
    [    0.734572] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.748994] NET: Registered PF_INET protocol family
    [    0.754291] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
    [    0.767475] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
    [    0.776326] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.784269] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.792778] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [    0.802113] TCP: Hash tables configured (established 65536 bind 65536)
    [    0.809013] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.816131] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.823815] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.830118] RPC: Registered named UNIX socket transport module.
    [    0.836200] RPC: Registered udp transport module.
    [    0.841006] RPC: Registered tcp transport module.
    [    0.845812] RPC: Registered tcp-with-tls transport module.
    [    0.851417] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.858004] NET: Registered PF_XDP protocol family
    [    0.862915] PCI: CLS 0 bytes, default 64
    [    0.868318] Initialise system trusted keyrings
    [    0.873117] workingset: timestamp_bits=46 max_order=21 bucket_order=0
    [    0.880044] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.886299] NFS: Registering the id_resolver key type
    [    0.891500] Key type id_resolver registered
    [    0.895778] Key type id_legacy registered
    [    0.899891] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.906742] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.969603] Key type asymmetric registered
    [    0.973816] Asymmetric key parser 'x509' registered
    [    0.978875] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.986616] io scheduler mq-deadline registered
    [    0.991256] io scheduler kyber registered
    [    0.995390] io scheduler bfq registered
    [    1.002642] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    1.009210] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    1.016980] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.029414] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.045011] loop: module loaded
    [    1.049348] megasas: 07.727.03.00-rc1
    [    1.057112] tun: Universal TUN/TAP device driver, 1.6
    [    1.063344] VFIO - User Level meta-driver version: 0.3
    [    1.069868] usbcore: registered new interface driver usb-storage
    [    1.076648] i2c_dev: i2c /dev entries driver
    [    1.082712] sdhci: Secure Digital Host Controller Interface driver
    [    1.089083] sdhci: Copyright(c) Pierre Ossman
    [    1.093785] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.100291] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.107581] usbcore: registered new interface driver usbhid
    [    1.113290] usbhid: USB HID core driver
    [    1.118457] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.128769] optee: probing for conduit method.
    [    1.133352] optee: revision 4.5 (ef1ebdc23034a804)
    [    1.133734] optee: dynamic shared memory is enabled
    [    1.144491] optee: initialized driver
    [    1.144588] random: crng init done
    [    1.150038] Initializing XFRM netlink socket
    [    1.156144] NET: Registered PF_PACKET protocol family
    [    1.161396] Key type dns_resolver registered
    [    1.174472] registered taskstats version 1
    [    1.178971] Loading compiled-in X.509 certificates
    [    1.196340] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
    [    1.253624] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.266417] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.273954] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.280864] pca953x 1-0023: using AI
    [    1.302146] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.311391] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.321327] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.330548] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.340643] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.347640] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    1.361327] pca954x 2-0071: supply vdd not found, using dummy regulator
    [    1.384289] i2c i2c-2: Added multiplexed i2c bus 3
    [    1.389508] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    1.403005] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    1.416623] i2c i2c-2: Added multiplexed i2c bus 4
    [    1.421527] pca954x 2-0071: registered 2 multiplexed busses for I2C switch pca9543
    [    1.429419] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.435412] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.444662] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.453664] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.463777] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
    [    1.472633] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.493531] Console: switching to colour frame buffer device 240x75
    [    1.510176] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
    [    1.517940] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.526674] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.537862] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.549007] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.558575] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.565246] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.574764] printk: legacy console [ttyS2] disabled
    [    1.580149] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
    [    1.589034] printk: legacy console [ttyS2] enabled
    [    1.598824] printk: legacy bootconsole [ns16550a0] disabled
    [    1.615538] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.622530] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.627925] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.634802] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.641348] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.647889] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.654193] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.661167] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.667725] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.674740] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
    [    1.715988] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
    [    1.730476] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.738579] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.746698] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
    [    1.759658] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.766795] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.774525] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
    [    1.793960] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.804936] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
    [    1.817428] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.834426] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.839992] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.847767] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.853774] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.863214] xhci-hcd xhci-hcd.0.auto: irq 265, io mem 0x31100000
    [    1.870049] hub 1-0:1.0: USB hub found
    [    1.873841] hub 1-0:1.0: 1 port detected
    [    1.879434] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.891895] mmc0: CQHCI version 5.10
    [    1.897635] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.904411] pca953x 1-0022: using AI
    [    1.913796] clk: Disabling unused clocks
    [    1.915688] mmc1: CQHCI version 5.10
    [    1.925819] PM: genpd: Disabling unused power domains
    [    1.931057] ALSA device list:
    [    1.934031]   No soundcards found.
    [    1.936006] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.959985] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.967824] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.021918] mmc1: new ultra high speed SDR104 SDHC card at address 0001
    [    2.028658] mmc0: Command Queue Engine enabled
    [    2.029552] mmcblk1: mmc1:0001 GB1QT 29.8 GiB
    [    2.033129] mmc0: new HS200 MMC card at address 0001
    [    2.039201]  mmcblk1: p1 p2
    [    2.043766] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.052756]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20
    [    2.063448] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.069351] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.075207] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.787686] EXT4-fs (mmcblk1p2): recovery complete
    [    2.795678] EXT4-fs (mmcblk1p2): mounted filesystem 73196f33-5653-4d14-9e7f-cce534928a30 r/w with ordered data mode. Quota mode: none.
    [    2.807869] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.814471] devtmpfs: mounted
    [    2.818189] Freeing unused kernel memory: 2752K
    [    2.822809] Run /sbin/init as init process
    [    3.001019] systemd[1]: System time before build time, advancing clock.
    [    3.043176] NET: Registered PF_INET6 protocol family
    [    3.049199] Segment Routing with IPv6
    [    3.052918] In-situ OAM (IOAM) with IPv6
    [    3.082933] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    3.114861] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    3.130230] systemd[1]: Hostname set to <am62pxx-evm>.
    [    3.343611] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    3.459152] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.632111] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.685774] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.706367] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.726345] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.745873] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.764430] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.784324] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.804188] systemd[1]: Expecting device /dev/ttyS2...
    [    3.816208] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.828126] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.844118] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.856118] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.921121] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.944276] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.967153] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.984529] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    4.005399] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    4.024832] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.044878] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.056957] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    4.079713] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.096699] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.112749] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    4.172364] systemd[1]: Mounting Huge Pages File System...
    [    4.192900] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.216488] systemd[1]: Mounting Kernel Debug File System...
    [    4.228710] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.247005] systemd[1]: Mounting Temporary Directory /tmp...
    [    4.265941] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.288927] systemd[1]: Starting Load Kernel Module configfs...
    [    4.312822] systemd[1]: Starting Load Kernel Module drm...
    [    4.329007] systemd[1]: Starting Load Kernel Module fuse...
    [    4.357852] systemd[1]: Starting Start psplash boot splash screen...
             Starting Start psplash boot splash screen.[    4.368433] fuse: init (API version 7.41)
    [    4.386030] systemd[1]: Starting RPC Bind...
    [    4.396649] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.406260] systemd[1]: Starting Journal Service...
    [    4.433426] systemd[1]: Starting Load Kernel Modules...
    [    4.451677] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.479069] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems cryptodev: loading out-of-tree module taints kernel.
    [0m...
    [    4.500754] sysctl table check failed: ioctl/(null) procname is null
    [    4.507272] sysctl table check failed: ioctl/(null) No proc_handler
    [    4.510957] systemd-journald[127]: Collecting audit messages is enabled.
    [    4.512324] systemd[1]: Starting Coldplug All udev Devices...
    [    4.513642] cryptodev: driver 1.14 loaded.
    [    4.537747] systemd[1]: Started Start psplash boot splash screen.
    [  OK  ] Started Start psplash boot splash s[    4.544992] systemd[1]: Started RPC Bind.
    creen.
    [  OK  ] Started RPC Bind.
    [    4.569286] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    4.594354] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File Sy[    4.604563] EXT4-fs (mmcblk1p2): re-mounted 73196f33-5653-4d14-9e7f-cce534928a30 r/w. Quota mode: none.
    stem.
    [    4.622383] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
    [  OK  ] Started Start psplash-systemd progress communication helper.
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gr[    4.922097] systemd-journald[127]: Received client request to flush runtime journal.
    acefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    5.134770] audit: type=1334 audit(1736360579.128:2): prog-id=6 op=LOAD
    [    5.141707] audit: type=1334 audit(1736360579.136:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create System Files and Directories.
    [    5.345936] audit: type=1334 audit(1736360579.340:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    5.380208] audit: type=1334 audit(1736360579.376:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    5.447021] audit: type=1334 audit(1736360579.440:6): prog-id=10 op=LOAD
    [    5.453788] audit: type=1334 audit(1736360579.448:7): prog-id=11 op=LOAD
    [    5.460541] audit: type=1334 audit(1736360579.456:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    6.149007] audit: type=1334 audit(1746124371.643:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [  OK  ] Started Job spooling tools.
             Starting Avahi mDNS/DNS-SD Stack...
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting PulseAudio Sound System...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [    6.785440] audit: type=1334 audit(1746124372.279:10): prog-id=14 op=LOAD
    [    6.795662] audit: type=1334 audit(1746124372.287:11): prog-id=15 op=LOAD
    [    6.802656] audit: type=1334 audit(1746124372.287:12): prog-id=16 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished Telnet Server.
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Started Telephony service.
    [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [    7.320682] Bluetooth: Core ver 2.22
    [    7.324923] NET: Registered PF_BLUETOOTH protocol family
    [    7.331603] Bluetooth: HCI device and connection manager initialized
    [    7.338115] Bluetooth: HCI socket layer initialized
    [    7.343188] Bluetooth: L2CAP socket layer initialized
    [    7.348736] Bluetooth: SCO socket layer initialized
    [  OK  ] Reached target Preparation for Network.
    [    7.362914] audit: type=1334 audit(1746124372.855:13): prog-id=17 op=LOAD
             Starting Network Configuration...
    [  OK  ] Started User Login Management.
    [  OK  ] Started PulseAudio Sound System.
    [    7.855367] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.887520] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.896810] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [  OK  ] Started Network Configuration.
    [  OK  ] Reached target Network.
    [    8.013892] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    8.024995] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
             Starting Enable and configure wl18xx bluetooth stack...
    [    8.060257] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    8.072059] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
             Starting containerd container runtime...
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Permit User Sessions...
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [    8.372560] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    8.380364] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
    [    8.392549] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [    8.399907] mc: Linux media interface: v0.10
    [    8.410367] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
    [    8.417955] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
    [    8.425407] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
    [    8.438757] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
    [    8.455335] videodev: Linux video capture interface: v2.00
    [  OK  ] Started Getty on tty1.
    [    8.540436] ov5640 4-003c: supply DOVDD not found, using dummy regulator
    [    8.555250] ov5640 4-003c: supply AVDD not found, using dummy regulator
    [    8.578983] ov5640 4-003c: supply DVDD not found, using dummy regulator
    [    8.596131] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [  OK  ] Reached target Login Prompts.
             Starting ti-apps-launcher service...
    [  OK  ] Started LLDP daemon.
    [    8.702319] platform 79000000.r5f: configured R5F for remoteproc mode
    [    8.710350] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    8.729158] remoteproc remoteproc0: 79000000.r5f is available
    [    8.755040] remoteproc remoteproc0: powering up 79000000.r5f
    [    8.760783] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 58312
    [    8.806783] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.824359] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
    [    8.824400] platform 78000000.r5f: configured R5F for IPC-only mode
    [    8.835263] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.841168] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.843753] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    8.846708] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    8.848106] remoteproc remoteproc1: 78000000.r5f is available
    [    8.848219] remoteproc remoteproc1: attaching to 78000000.r5f
    [    8.848636] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    8.849063] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.849090] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
    [    8.849097] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    8.854441] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.862418] remoteproc remoteproc0: remote processor 79000000.r5f is now up
    [    8.869700] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.932170] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    8.946357] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    8.950757] /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000
    [    8.968363] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    8.968565] /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000: Fixed dependency cycle(s) with /bus@f0000/i2c@20020000/i2c-switch@71/i2c@1/camera@3c
    [    8.970610] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    8.970628] vdec 30210000.video-codec: Product Code:      0x521c
    [    8.970635] vdec 30210000.video-codec: Firmware Revision: 344874
    [  OK  ] Reached target Hardware activated U[    9.010913] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
    SB gadget.
    [    9.012442] i2c i2c-1: Added multiplexed i2c bus 5
    [    9.039792] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    9.043161] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    9.153527] PVR_K:  189: Device: fd80000.gpu
    [    9.162370] PVR_K:  189: Read BVNC 36.53.104.796 from HW device registers
    [    9.169390] PVR_K:  189: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    9.177792] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
    [  OK  ] Started Simple Network Management P[    9.205001] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
    [  OK  ] Created slice Slice /system/tee-supplicant.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [  OK  ] Started TEE Supplicant on teepriv0.
             Starting Virtual Console Setup...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Starting Save/Restore Sound Card State...
             Starting File System Check on /dev/mmcblk0p19...
    [  OK  ] Finished Save/Restore Sound Card State.
             Expecting device /dev/mmcblk0p1...
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Reached target Sound Card.
    [  OK  ] Found device /dev/mmcblk1p1.
    [  OK  ] Finished File System Check on /dev/mmcblk0p19.
             Mounting /run/media/mnt/vendor/pers-mmcblk0p19...
             Starting File System Check on /dev/mmcblk1p1...
    [   10.414997] EXT4-fs (mmcblk0p19): mounted filesystem d07a9cda-4c00-4590-acde-fb8bb0dab821 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Found device /dev/mmcblk0p1.
    [  OK  ] Mounted /run/media/mnt/vendor/pers-mmcblk0p19.
             Starting File System Check on /dev/mmcblk0p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/boot-mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/bootloader-mmcblk0p1...
    [  OK  ] Mounted /run/media/bootloader-mmcblk0p1.
    [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat-plugins
            libqt6core5compat-qmlplugins
            libqt6core5compat6
            libqt6shadertools-dev
            libqt6shadertools-plugins
            libqt6shadertools-qmlplugins
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qt3d-plugins
            qt3d-qmlplugins
            qt3d
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-staticdev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver-dev
            qtlanguageserver-plugins
            qtlanguageserver-qmlplugins
            qtlanguageserver-staticdev
            qtlanguageserver
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquicktimeline-plugins
            qtquicktimeline-qmlplugins
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qttools-plugins
            qttools-qmlplugins
            qttools
            qtwayland-dev
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
    [   12.123210] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [   14.130592] audit: type=1006 audit(1746124379.623:14): pid=1440 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   14.144519] audit: type=1300 audit(1746124379.623:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffffb383aa8 a2=4 a3=1 items=0 ppid=1 pid=1440 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   14.172482] audit: type=1327 audit(1746124379.623:14): proctitle="(systemd)"
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62pxx-evm ttyS2
    Arago 2025.01 am62pxx-evm ttyS2
    am62pxx-evm login: [   16.187171] PVR_K:  1448: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [   16.199723] PVR_K:  1448: Shader binary image 'rgx.sh.36.53.104.796' loaded
    root
    [   18.878149] audit: type=1006 audit(1746124384.371:15): pid=1474 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   18.891786] audit: type=1300 audit(1746124384.371:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffef73d098 a2=1 a3=1 items=0 ppid=1 pid=1474 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   18.919493] audit: type=1327 audit(1746124384.371:15): proctitle="(systemd)"
    [   18.961299] audit: type=1334 audit(1746124384.455:16): prog-id=18 op=LOAD
    [   18.968976] audit: type=1300 audit(1746124384.455:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe26d9a98 a2=90 a3=0 items=0 ppid=1 pid=1474 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   18.996457] audit: type=1327 audit(1746124384.455:16): proctitle="(systemd)"
    [   19.004305] audit: type=1334 audit(1746124384.455:17): prog-id=18 op=UNLOAD
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 60.00 fps
    Unfortunately the instructions for live streaming to an hdmi display listed in the release notes still are not functional. Are you able to reproduce the same errors I had in my initial post?
    - Job
  • Can you try to stop weston before running gstreamer?
    systemctl stop emptty
  • I no longer see the error when I stop weston before running gstreamer, however the stream is a dark grey screen.
    root@am62pxx-evm:~# systemctl stop emptty
    root@am62pxx-evm:~# gst-launch-1.0 v4l2src device="/dev/video2" ! video/x-raw, width=640, height=480, format=UYVY ! autovideosink
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Pipeline is PREROLLED ...
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    Redistribute latency...
    ^Chandling interrupt.
    Interrupt: Stopping pipeline ...
    Execution ended after 0:00:25.589269313
    Setting pipeline to NULL ...
    Freeing pipeline ...
    Execution ended after 0:00:25.124182631
    root@am62pxx-evm:~#
  • It's working fine on my setup. Please see logs below:
    root@am62pxx-evm:~# uname -a
    Linux am62pxx-evm 6.12.17-ti-00771-gc85877d40f8e #1 SMP PREEMPT Tue Mar 25 12:45:29 UTC 2025 aarch64 GNU/Linux
    root@am62pxx-evm:~# v4l2-ctl --list-devices
    j721e-csi2rx (platform:30102000.ticsi2rx):
            /dev/video2
            /dev/video3
            /dev/video4
            /dev/video5
            /dev/video6
            /dev/video7
            /dev/media0
    wave5-dec (platform:30210000.video-codec):
            /dev/video0
            /dev/video1
    Execution ended after 0:00:07.393451540
    root@am62pxx-evm:~# gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=UYVY ! kmssink driver-name=tidss force-modesetting=true
    /GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt601
    Execution ended after 0:01:57.184529860
    root@am62pxx-evm:~# media-ctl -V '"ov5640 4-003c":0 [fmt:UYVY8_1X16/1920x1080@1/30 field:none]'
    root@am62pxx-evm:~# media-ctl -V '"cdns_csi2rx.30101000.csi-bridge":0 [fmt:UYVY8_1X16/1920x1080 field:none]'
    root@am62pxx-evm:~# media-ctl -V '"30102000.ticsi2rx":0 [fmt:UYVY8_1X16/1920x1080 field:none]'
    root@am62pxx-evm:~# gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,width=1920,height=1080,format=UYVY ! kmssink driver-name=tidss force-mo
    desetting=true
    /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
    /GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)1920, height=(int)1080, format=(string)UYVY, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)bt709
    Execution ended after 0:00:19.120135135
    root@am62pxx-evm:~# v4l2-ctl -d /dev/video2 --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-mmap=6
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 33.76 fps
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 33.75 fps
    root@am62pxx-evm:~# media-ctl -V '"ov5640 4-003c":0 [fmt:UYVY8_1X16/640x480@1/30 field:none]'
    root@am62pxx-evm:~# media-ctl -V '"cdns_csi2rx.30101000.csi-bridge":0 [fmt:UYVY8_1X16/640x480 field:none]'
    root@am62pxx-evm:~# media-ctl -V '"30102000.ticsi2rx":0 [fmt:UYVY8_1X16/640x480 field:none]'
    <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 33.75 fps
    Execution ended after 0:00:03.919460530
    Does kmssink work for you?
    Can you also try saving the capture to a file instead of streaming to a display?
    gst-launch-1.0 v4l2src device="/dev/video2" ! video/x-raw, width=640, height=480, format=UYVY ! filesink location=ov5640.yuv
    Then use VLC player to play the recorded file.
    Jianzhong
  • Looks like the commands you ran solved my issue. Thank you for the assistance.
    - Job
