sdk version 10.0.1
We found that during the switching process, there would be frame loss in the dma output of our 4-channel video. It causes the data of our four channels to be out of sync。
The code for statistical frames:
// SPDX-License-Identifier: GPL-2.0-only /* * TI CSI2 RX driver. * * Copyright (C) 2021 Texas Instruments Incorporated - https://www.ti.com/ * * Author: Pratyush Yadav <p.yadav@ti.com> */ #include <linux/bitfield.h> #include <linux/dmaengine.h> #include <linux/list.h> #include <linux/module.h> #include <linux/of_platform.h> #include <linux/platform_device.h> #include <linux/pm_runtime.h> #include <linux/adaps_dtof_uapi.h> #include <media/mipi-csi2.h> #include <media/v4l2-device.h> #include <media/v4l2-ioctl.h> #include <media/v4l2-mc.h> //#include <media/videobuf2-dma-contig.h> #include <media/videobuf2-dma-sg.h> #define TI_CSI2RX_MODULE_NAME "j721e-csi2rx" #define SHIM_CNTL 0x10 #define SHIM_CNTL_PIX_RST BIT(0) #define SHIM_DMACNTX(i) (0x20 + ((i) * 0x20)) #define SHIM_DMACNTX_EN BIT(31) #define SHIM_DMACNTX_YUV422 GENMASK(27, 26) #define SHIM_DMACNTX_SIZE GENMASK(21, 20) #define SHIM_DMACNTX_VC GENMASK(9, 6) #define SHIM_DMACNTX_FMT GENMASK(5, 0) #define SHIM_DMACNTX_YUV422_MODE_11 3 #define SHIM_DMACNTX_SIZE_8 0 #define SHIM_DMACNTX_SIZE_16 1 #define SHIM_DMACNTX_SIZE_32 2 #define SHIM_PSI_CFG0(i) (0x24 + ((i) * 0x20)) #define SHIM_PSI_CFG0_SRC_TAG GENMASK(15, 0) #define SHIM_PSI_CFG0_DST_TAG GENMASK(31, 16) #define PSIL_WORD_SIZE_BYTES 16 #define TI_CSI2RX_MAX_CTX 32 /* * There are no hard limits on the width or height. The DMA engine can handle * all sizes. The max width and height are arbitrary numbers for this driver. * Use 16K * 16K as the arbitrary limit. It is large enough that it is unlikely * the limit will be hit in practice. */ #define MAX_WIDTH_BYTES SZ_16K #define MAX_HEIGHT_LINES SZ_16K #define TI_CSI2RX_PAD_SINK 0 #define TI_CSI2RX_PAD_FIRST_SOURCE 1 #define TI_CSI2RX_MAX_SOURCE_PADS TI_CSI2RX_MAX_CTX #define TI_CSI2RX_MAX_PADS (1 + TI_CSI2RX_MAX_SOURCE_PADS) #define DRAIN_TIMEOUT_MS 50 #define DRAIN_BUFFER_SIZE SZ_32K struct ti_csi2rx_fmt { u32 fourcc; /* Four character code. */ u32 code; /* Mbus code. */ u32 csi_dt; /* CSI Data type. */ u8 bpp; /* Bits per pixel. */ u8 size; /* Data size shift when unpacking. */ }; struct ti_csi2rx_buffer { /* Common v4l2 buffer. Must be first. */ struct vb2_v4l2_buffer vb; struct list_head list; struct ti_csi2rx_ctx *ctx; }; enum ti_csi2rx_dma_state { TI_CSI2RX_DMA_STOPPED, /* Streaming not started yet. */ TI_CSI2RX_DMA_IDLE, /* Streaming but no pending DMA operation. */ TI_CSI2RX_DMA_ACTIVE, /* Streaming and pending DMA operation. */ }; struct ti_csi2rx_dma { /* Protects all fields in this struct. */ spinlock_t lock; struct dma_chan *chan; /* Buffers queued to the driver, waiting to be processed by DMA. */ struct list_head queue; enum ti_csi2rx_dma_state state; /* * Queue of buffers submitted to DMA engine. */ struct list_head submitted; }; struct ti_csi2rx_dev; struct ti_csi2rx_ctx { struct ti_csi2rx_dev *csi; struct video_device vdev; struct vb2_queue vidq; struct mutex mutex; /* To serialize ioctls. */ struct v4l2_format v_fmt; struct ti_csi2rx_dma dma; struct media_pad pad; u32 sequence; u32 idx; u32 vc; u32 stream; u32 ok_frame_cnt; u32 ng_frame_cnt; ktime_t rx_start; }; struct ti_csi2rx_dev { struct device *dev; void __iomem *shim; /* To serialize core subdev ioctls. */ struct mutex mutex; unsigned int enable_count; bool enable_multi_stream; unsigned int num_ctx; struct v4l2_async_notifier notifier; struct media_device mdev; struct media_pipeline pipe; struct media_pad pads[TI_CSI2RX_MAX_PADS]; struct v4l2_device v4l2_dev; struct v4l2_subdev *source; struct v4l2_subdev subdev; struct ti_csi2rx_ctx ctx[TI_CSI2RX_MAX_CTX]; u64 enabled_streams_mask; /* Buffer to drain stale data from PSI-L endpoint */ struct { void *vaddr; dma_addr_t paddr; size_t len; } drain; }; static const struct ti_csi2rx_fmt ti_csi2rx_formats[] = { { .fourcc = V4L2_PIX_FMT_SBGGR8, .code = MEDIA_BUS_FMT_SBGGR8_1X8, .csi_dt = MIPI_CSI2_DT_USER_DEFINED(0), .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_YUYV, .code = MEDIA_BUS_FMT_YUYV8_1X16, .csi_dt = MIPI_CSI2_DT_YUV422_8B, .bpp = 16, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_UYVY, .code = MEDIA_BUS_FMT_UYVY8_1X16, .csi_dt = MIPI_CSI2_DT_YUV422_8B, .bpp = 16, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_YVYU, .code = MEDIA_BUS_FMT_YVYU8_1X16, .csi_dt = MIPI_CSI2_DT_YUV422_8B, .bpp = 16, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_VYUY, .code = MEDIA_BUS_FMT_VYUY8_1X16, .csi_dt = MIPI_CSI2_DT_YUV422_8B, .bpp = 16, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_SBGGR8, .code = MEDIA_BUS_FMT_SBGGR8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_SGBRG8, .code = MEDIA_BUS_FMT_SGBRG8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_SGRBG8, .code = MEDIA_BUS_FMT_SGRBG8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_SRGGB8, .code = MEDIA_BUS_FMT_SRGGB8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { }, { .fourcc = V4L2_PIX_FMT_GREY, .code = MEDIA_BUS_FMT_Y8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { }, { .fourcc = V4L2_PIX_FMT_GREY, .code = MEDIA_BUS_FMT_Y8_1X8, .csi_dt = MIPI_CSI2_DT_RAW8, .bpp = 8, .size = SHIM_DMACNTX_SIZE_8, }, { .fourcc = V4L2_PIX_FMT_SBGGR10, .code = MEDIA_BUS_FMT_SBGGR10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGBRG10, .code = MEDIA_BUS_FMT_SGBRG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGRBG10, .code = MEDIA_BUS_FMT_SGRBG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SRGGB10, .code = MEDIA_BUS_FMT_SRGGB10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SBGGR12, .code = MEDIA_BUS_FMT_SBGGR12_1X12, .csi_dt = MIPI_CSI2_DT_RAW12, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGBRG12, .code = MEDIA_BUS_FMT_SGBRG12_1X12, .csi_dt = MIPI_CSI2_DT_RAW12, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGRBG12, .code = MEDIA_BUS_FMT_SGRBG12_1X12, .csi_dt = MIPI_CSI2_DT_RAW12, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SRGGB12, .code = MEDIA_BUS_FMT_SRGGB12_1X12, .csi_dt = MIPI_CSI2_DT_RAW12, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SRGGI10, .code = MEDIA_BUS_FMT_SRGGI10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGRIG10, .code = MEDIA_BUS_FMT_SGRIG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SBGGI10, .code = MEDIA_BUS_FMT_SBGGI10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGBIG10, .code = MEDIA_BUS_FMT_SGBIG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGIRG10, .code = MEDIA_BUS_FMT_SGIRG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SIGGR10, .code = MEDIA_BUS_FMT_SIGGR10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SGIBG10, .code = MEDIA_BUS_FMT_SGIBG10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, { .fourcc = V4L2_PIX_FMT_SIGGB10, .code = MEDIA_BUS_FMT_SIGGB10_1X10, .csi_dt = MIPI_CSI2_DT_RAW10, .bpp = 16, .size = SHIM_DMACNTX_SIZE_16, }, /* More formats can be supported but they are not listed for now. */ }; /* Forward declaration needed by ti_csi2rx_dma_callback. */ static int ti_csi2rx_start_dma(struct ti_csi2rx_ctx *ctx, struct ti_csi2rx_buffer *buf); static const struct ti_csi2rx_fmt *find_format_by_fourcc(u32 pixelformat) { unsigned int i; for (i = 0; i < ARRAY_SIZE(ti_csi2rx_formats); i++) { if (ti_csi2rx_formats[i].fourcc == pixelformat) return &ti_csi2rx_formats[i]; } return NULL; } static const struct ti_csi2rx_fmt *find_format_by_code(u32 code) { unsigned int i; for (i = 0; i < ARRAY_SIZE(ti_csi2rx_formats); i++) { if (ti_csi2rx_formats[i].code == code) return &ti_csi2rx_formats[i]; } return NULL; } static void ti_csi2rx_fill_fmt(const struct ti_csi2rx_fmt *csi_fmt, struct v4l2_format *v4l2_fmt) { struct v4l2_pix_format *pix = &v4l2_fmt->fmt.pix; unsigned int pixels_in_word; u8 bpp = csi_fmt->bpp; u32 bpl; pixels_in_word = PSIL_WORD_SIZE_BYTES * 8 / bpp; pix->width = clamp_t(unsigned int, pix->width, pixels_in_word, MAX_WIDTH_BYTES * 8 / bpp); // HACK: Allow non-16-aligned width /*pix->width = rounddown(pix->width, pixels_in_word);*/ pix->height = clamp_t(unsigned int, pix->height, 1, MAX_HEIGHT_LINES); v4l2_fmt->type = V4L2_BUF_TYPE_VIDEO_CAPTURE; pix->pixelformat = csi_fmt->fourcc; pix->colorspace = V4L2_COLORSPACE_SRGB; pix->sizeimage = pix->height * pix->width * (bpp / 8); bpl = (pix->width * ALIGN(bpp, 8)) >> 3; // HACK: Allow non-16-aligned width //pix->bytesperline = ALIGN(bpl, 16); } static int ti_csi2rx_querycap(struct file *file, void *priv, struct v4l2_capability *cap) { strscpy(cap->driver, TI_CSI2RX_MODULE_NAME, sizeof(cap->driver)); strscpy(cap->card, TI_CSI2RX_MODULE_NAME, sizeof(cap->card)); return 0; } static int ti_csi2rx_enum_fmt_vid_cap(struct file *file, void *priv, struct v4l2_fmtdesc *f) { const struct ti_csi2rx_fmt *fmt = NULL; if (f->mbus_code) { /* 1-to-1 mapping between bus formats and pixel formats */ if (f->index > 0) return -EINVAL; fmt = find_format_by_code(f->mbus_code); } else { if (f->index >= ARRAY_SIZE(ti_csi2rx_formats)) return -EINVAL; fmt = &ti_csi2rx_formats[f->index]; } if (!fmt) return -EINVAL; f->pixelformat = fmt->fourcc; memset(f->reserved, 0, sizeof(f->reserved)); f->type = V4L2_BUF_TYPE_VIDEO_CAPTURE; return 0; } static int ti_csi2rx_g_fmt_vid_cap(struct file *file, void *prov, struct v4l2_format *f) { struct ti_csi2rx_ctx *csi = video_drvdata(file); *f = csi->v_fmt; return 0; } static int ti_csi2rx_try_fmt_vid_cap(struct file *file, void *priv, struct v4l2_format *f) { const struct ti_csi2rx_fmt *fmt; /* * Default to the first format if the requested pixel format code isn't * supported. */ fmt = find_format_by_fourcc(f->fmt.pix.pixelformat); if (!fmt) fmt = &ti_csi2rx_formats[0]; /* Interlaced formats are not supported. */ f->fmt.pix.field = V4L2_FIELD_NONE; ti_csi2rx_fill_fmt(fmt, f); return 0; } static int ti_csi2rx_s_fmt_vid_cap(struct file *file, void *priv, struct v4l2_format *f) { struct ti_csi2rx_ctx *csi = video_drvdata(file); struct vb2_queue *q = &csi->vidq; int ret; if (vb2_is_busy(q)) return -EBUSY; ret = ti_csi2rx_try_fmt_vid_cap(file, priv, f); if (ret < 0) return ret; csi->v_fmt = *f; return 0; } static int ti_csi2rx_enum_framesizes(struct file *file, void *fh, struct v4l2_frmsizeenum *fsize) { const struct ti_csi2rx_fmt *fmt; unsigned int pixels_in_word; u8 bpp; fmt = find_format_by_fourcc(fsize->pixel_format); if (!fmt || fsize->index != 0) return -EINVAL; bpp = ALIGN(fmt->bpp, 8); /* * Number of pixels in one PSI-L word. The transfer happens in multiples * of PSI-L word sizes. */ pixels_in_word = PSIL_WORD_SIZE_BYTES * 8 / bpp; fsize->type = V4L2_FRMSIZE_TYPE_STEPWISE; fsize->stepwise.min_width = pixels_in_word; fsize->stepwise.max_width = rounddown(MAX_WIDTH_BYTES * 8 / bpp, pixels_in_word); // HACK: Set step width to 1 to allow non-16 aligned transfers fsize->stepwise.step_width = 1; fsize->stepwise.min_height = 1; fsize->stepwise.max_height = MAX_HEIGHT_LINES; fsize->stepwise.step_height = 1; return 0; } static const struct v4l2_ioctl_ops csi_ioctl_ops = { .vidioc_querycap = ti_csi2rx_querycap, .vidioc_enum_fmt_vid_cap = ti_csi2rx_enum_fmt_vid_cap, .vidioc_try_fmt_vid_cap = ti_csi2rx_try_fmt_vid_cap, .vidioc_g_fmt_vid_cap = ti_csi2rx_g_fmt_vid_cap, .vidioc_s_fmt_vid_cap = ti_csi2rx_s_fmt_vid_cap, .vidioc_enum_framesizes = ti_csi2rx_enum_framesizes, .vidioc_reqbufs = vb2_ioctl_reqbufs, .vidioc_create_bufs = vb2_ioctl_create_bufs, .vidioc_prepare_buf = vb2_ioctl_prepare_buf, .vidioc_querybuf = vb2_ioctl_querybuf, .vidioc_qbuf = vb2_ioctl_qbuf, .vidioc_dqbuf = vb2_ioctl_dqbuf, .vidioc_expbuf = vb2_ioctl_expbuf, .vidioc_streamon = vb2_ioctl_streamon, .vidioc_streamoff = vb2_ioctl_streamoff, }; static const struct v4l2_file_operations csi_fops = { .owner = THIS_MODULE, .open = v4l2_fh_open, .release = vb2_fop_release, .read = vb2_fop_read, .poll = vb2_fop_poll, .unlocked_ioctl = video_ioctl2, .mmap = vb2_fop_mmap, }; static int csi_async_notifier_bound(struct v4l2_async_notifier *notifier, struct v4l2_subdev *subdev, struct v4l2_async_connection *asc) { struct ti_csi2rx_dev *csi = dev_get_drvdata(notifier->v4l2_dev->dev); csi->source = subdev; return 0; } static int csi_async_notifier_complete(struct v4l2_async_notifier *notifier) { struct ti_csi2rx_dev *csi = dev_get_drvdata(notifier->v4l2_dev->dev); int ret, i; /* Create link from source to subdev */ ret = v4l2_create_fwnode_links_to_pad(csi->source, &csi->pads[TI_CSI2RX_PAD_SINK], MEDIA_LNK_FL_IMMUTABLE | MEDIA_LNK_FL_ENABLED); if (ret) return ret; /* Create and link video nodes for all DMA contexts */ for (i = 0; i < csi->num_ctx; i++) { struct ti_csi2rx_ctx *ctx = &csi->ctx[i]; struct video_device *vdev = &ctx->vdev; ret = video_register_device(vdev, VFL_TYPE_VIDEO, -1); if (ret) goto unregister_dev; ret = media_create_pad_link(&csi->subdev.entity, TI_CSI2RX_PAD_FIRST_SOURCE + ctx->idx, &vdev->entity, 0, MEDIA_LNK_FL_IMMUTABLE | MEDIA_LNK_FL_ENABLED); if (ret) { video_unregister_device(vdev); goto unregister_dev; } } ret = v4l2_device_register_subdev_nodes(&csi->v4l2_dev); if (ret) goto unregister_dev; return 0; unregister_dev: i--; for (; i >= 0; i--) video_unregister_device(&csi->ctx[i].vdev); return ret; } static const struct v4l2_async_notifier_operations csi_async_notifier_ops = { .bound = csi_async_notifier_bound, .complete = csi_async_notifier_complete, }; static int ti_csi2rx_notifier_register(struct ti_csi2rx_dev *csi) { struct fwnode_handle *fwnode; struct v4l2_async_connection *asc; struct device_node *node; int ret; node = of_get_child_by_name(csi->dev->of_node, "csi-bridge"); if (!node) return -EINVAL; fwnode = of_fwnode_handle(node); if (!fwnode) { of_node_put(node); return -EINVAL; } v4l2_async_nf_init(&csi->notifier, &csi->v4l2_dev); csi->notifier.ops = &csi_async_notifier_ops; asc = v4l2_async_nf_add_fwnode(&csi->notifier, fwnode, struct v4l2_async_connection); of_node_put(node); if (IS_ERR(asc)) { v4l2_async_nf_cleanup(&csi->notifier); return PTR_ERR(asc); } ret = v4l2_async_nf_register(&csi->notifier); if (ret) { v4l2_async_nf_cleanup(&csi->notifier); return ret; } return 0; } static void ti_csi2rx_setup_shim(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dev *csi = ctx->csi; const struct ti_csi2rx_fmt *fmt; unsigned int reg; fmt = find_format_by_fourcc(ctx->v_fmt.fmt.pix.pixelformat); /* De-assert the pixel interface reset. */ if (!csi->enable_count) { reg = SHIM_CNTL_PIX_RST; writel(reg, csi->shim + SHIM_CNTL); } reg = SHIM_DMACNTX_EN; reg |= FIELD_PREP(SHIM_DMACNTX_FMT, fmt->csi_dt); /* * The hardware assumes incoming YUV422 8-bit data on MIPI CSI2 bus * follows the spec and is packed in the order U0 -> Y0 -> V0 -> Y1 -> * ... * * There is an option to swap the bytes around before storing in * memory, to achieve different pixel formats: * * Byte3 <----------- Byte0 * [ Y1 ][ V0 ][ Y0 ][ U0 ] MODE 11 * [ Y1 ][ U0 ][ Y0 ][ V0 ] MODE 10 * [ V0 ][ Y1 ][ U0 ][ Y0 ] MODE 01 * [ U0 ][ Y1 ][ V0 ][ Y0 ] MODE 00 * * We don't have any requirement to change pixelformat from what is * coming from the source, so we keep it in MODE 11, which does not * swap any bytes when storing in memory. */ switch (fmt->fourcc) { case V4L2_PIX_FMT_UYVY: case V4L2_PIX_FMT_VYUY: case V4L2_PIX_FMT_YUYV: case V4L2_PIX_FMT_YVYU: reg |= FIELD_PREP(SHIM_DMACNTX_YUV422, SHIM_DMACNTX_YUV422_MODE_11); break; default: /* Ignore if not YUV 4:2:2 */ break; } reg |= FIELD_PREP(SHIM_DMACNTX_SIZE, fmt->size); reg |= FIELD_PREP(SHIM_DMACNTX_VC, ctx->vc); writel(reg, csi->shim + SHIM_DMACNTX(ctx->idx)); reg = FIELD_PREP(SHIM_PSI_CFG0_SRC_TAG, 0) | FIELD_PREP(SHIM_PSI_CFG0_DST_TAG, 0); writel(reg, csi->shim + SHIM_PSI_CFG0(ctx->idx)); } static void ti_csi2rx_drain_callback(void *param) { struct completion *drain_complete = param; complete(drain_complete); } /* * Drain the stale data left at the PSI-L endpoint. * * This might happen if no buffers are queued in time but source is still * streaming. In multi-stream scenarios this can happen when one stream is * stopped but other is still streaming, and thus module-level pixel reset is * not asserted. * * To prevent that stale data corrupting the subsequent transactions, it is * required to issue DMA requests to drain it out. */ static int ti_csi2rx_drain_dma(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dev *csi = ctx->csi; struct dma_async_tx_descriptor *desc; struct completion drain_complete; dma_cookie_t cookie; int ret; init_completion(&drain_complete); desc = dmaengine_prep_slave_single(ctx->dma.chan, csi->drain.paddr, csi->drain.len, DMA_DEV_TO_MEM, DMA_PREP_INTERRUPT | DMA_CTRL_ACK); if (!desc) { ret = -EIO; goto out; } desc->callback = ti_csi2rx_drain_callback; desc->callback_param = &drain_complete; cookie = dmaengine_submit(desc); ret = dma_submit_error(cookie); if (ret) goto out; dma_async_issue_pending(ctx->dma.chan); if (!wait_for_completion_timeout(&drain_complete, msecs_to_jiffies(DRAIN_TIMEOUT_MS))) { dmaengine_terminate_sync(ctx->dma.chan); dev_dbg(csi->dev, "DMA transfer timed out for drain buffer\n"); ret = -ETIMEDOUT; goto out; } out: return ret; } static int ti_csi2rx_dma_submit_pending(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dma *dma = &ctx->dma; struct ti_csi2rx_buffer *buf; int ret = 0; /* If there are more buffers to process then start their transfer. */ while (!list_empty(&dma->queue)) { buf = list_entry(dma->queue.next, struct ti_csi2rx_buffer, list); ret = ti_csi2rx_start_dma(ctx, buf); if (ret) { dev_err(ctx->csi->dev, "Failed to queue the next buffer for DMA\n"); vb2_buffer_done(&buf->vb.vb2_buf, VB2_BUF_STATE_ERROR); break; } list_move_tail(&buf->list, &dma->submitted); } return ret; } static void ti_csi2rx_dma_callback(void *param, const struct dmaengine_result *result) { struct ti_csi2rx_buffer *buf = param; struct ti_csi2rx_ctx *ctx = buf->ctx; struct ti_csi2rx_dma *dma = &ctx->dma; unsigned long flags = 0; /* * TODO: Derive the sequence number from the CSI2RX frame number * hardware monitor registers. */ buf->vb.vb2_buf.timestamp = ktime_get_ns(); buf->vb.sequence = ctx->sequence++; spin_lock_irqsave(&dma->lock, flags); WARN_ON(!list_is_first(&buf->list, &dma->submitted)); if (0 == (ctx->ok_frame_cnt + ctx->ng_frame_cnt)) { ctx->rx_start = ktime_get(); } if (result && (result->result != 5) & (result->result != DMA_TRANS_NOERROR || result->residue != 0)) { #if 0 // The log may bring something can't restored unless reboot the system, according to Qingfeng's test. dev_err(ctx->csi->dev, "Failed DMA transfer for frame#%u of (stream: %d idx: %d, vc: %d),timestamp: %lld result=%d, residue=%u\n", buf->vb.sequence, ctx->stream, ctx->idx, ctx->vc, buf->vb.vb2_buf.timestamp, result->result, result->residue ); #endif ctx->ng_frame_cnt++; vb2_buffer_done(&buf->vb.vb2_buf, VB2_BUF_STATE_ERROR); } else { ctx->ok_frame_cnt++; vb2_buffer_done(&buf->vb.vb2_buf, VB2_BUF_STATE_DONE); } list_del(&buf->list); ti_csi2rx_dma_submit_pending(ctx); if (list_empty(&dma->submitted)) dma->state = TI_CSI2RX_DMA_IDLE; spin_unlock_irqrestore(&dma->lock, flags); } static int ti_csi2rx_start_dma(struct ti_csi2rx_ctx *ctx, struct ti_csi2rx_buffer *buf) { unsigned long addr; struct dma_async_tx_descriptor *desc; size_t len = ctx->v_fmt.fmt.pix.sizeimage; dma_cookie_t cookie; int ret = 0; struct sg_table *sg; // addr = vb2_dma_contig_plane_dma_addr(&buf->vb.vb2_buf, 0); // desc = dmaengine_prep_slave_single(ctx->dma.chan, addr, len, // DMA_DEV_TO_MEM, // DMA_PREP_INTERRUPT | DMA_CTRL_ACK); sg = vb2_dma_sg_plane_desc(&buf->vb.vb2_buf, 0); /*dev_err(ctx->csi->dev, "%s: Got scatter gather list with nents %d", __func__, sg->nents);*/ desc = dmaengine_prep_slave_sg(ctx->dma.chan, sg->sgl, sg->nents, DMA_DEV_TO_MEM, DMA_PREP_INTERRUPT | DMA_CTRL_ACK); if (!desc) return -EIO; desc->callback_result = ti_csi2rx_dma_callback; desc->callback_param = buf; cookie = dmaengine_submit(desc); ret = dma_submit_error(cookie); if (ret) return ret; dma_async_issue_pending(ctx->dma.chan); return 0; } static void ti_csi2rx_stop_dma(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dma *dma = &ctx->dma; enum ti_csi2rx_dma_state state; unsigned long flags; int ret; spin_lock_irqsave(&dma->lock, flags); state = ctx->dma.state; dma->state = TI_CSI2RX_DMA_STOPPED; spin_unlock_irqrestore(&dma->lock, flags); if (state != TI_CSI2RX_DMA_STOPPED) { /* * Normal DMA termination does not clean up pending data on * the endpoint if multiple streams are running and only one * is stopped, as the module-level pixel reset cannot be * enforced before terminating DMA. */ ret = ti_csi2rx_drain_dma(ctx); if (ret && ret != -ETIMEDOUT) dev_warn(ctx->csi->dev, "Failed to drain DMA. Next frame might be bogus\n"); } ret = dmaengine_terminate_sync(ctx->dma.chan); if (ret) dev_err(ctx->csi->dev, "Failed to stop DMA: %d\n", ret); } static void ti_csi2rx_cleanup_buffers(struct ti_csi2rx_ctx *ctx, enum vb2_buffer_state state) { struct ti_csi2rx_dma *dma = &ctx->dma; struct ti_csi2rx_buffer *buf, *tmp; unsigned long flags; spin_lock_irqsave(&dma->lock, flags); list_for_each_entry_safe(buf, tmp, &ctx->dma.queue, list) { list_del(&buf->list); vb2_buffer_done(&buf->vb.vb2_buf, state); } list_for_each_entry_safe(buf, tmp, &ctx->dma.submitted, list) { list_del(&buf->list); vb2_buffer_done(&buf->vb.vb2_buf, state); } spin_unlock_irqrestore(&dma->lock, flags); } static int ti_csi2rx_queue_setup(struct vb2_queue *q, unsigned int *nbuffers, unsigned int *nplanes, unsigned int sizes[], struct device *alloc_devs[]) { struct ti_csi2rx_ctx *ctx = vb2_get_drv_priv(q); unsigned int size = ctx->v_fmt.fmt.pix.sizeimage; if (*nplanes) { if (sizes[0] < size) return -EINVAL; size = sizes[0]; } *nplanes = 1; sizes[0] = size; return 0; } static int ti_csi2rx_buffer_prepare(struct vb2_buffer *vb) { struct ti_csi2rx_ctx *ctx = vb2_get_drv_priv(vb->vb2_queue); unsigned long size = ctx->v_fmt.fmt.pix.sizeimage; if (vb2_plane_size(vb, 0) < size) { dev_err(ctx->csi->dev, "Data will not fit into plane\n"); return -EINVAL; } vb2_set_plane_payload(vb, 0, size); return 0; } static void ti_csi2rx_buffer_queue(struct vb2_buffer *vb) { struct ti_csi2rx_ctx *ctx = vb2_get_drv_priv(vb->vb2_queue); struct ti_csi2rx_buffer *buf; struct ti_csi2rx_dma *dma = &ctx->dma; bool restart_dma = false; unsigned long flags = 0; int ret; buf = container_of(vb, struct ti_csi2rx_buffer, vb.vb2_buf); buf->ctx = ctx; spin_lock_irqsave(&dma->lock, flags); /* * Usually the DMA callback takes care of queueing the pending buffers. * But if DMA has stalled due to lack of buffers, restart it now. */ if (dma->state == TI_CSI2RX_DMA_IDLE) { /* * Do not restart DMA with the lock held because * ti_csi2rx_drain_dma() might block for completion. * There won't be a race on queueing DMA anyway since the * callback is not being fired. */ restart_dma = true; dma->state = TI_CSI2RX_DMA_ACTIVE; } else { list_add_tail(&buf->list, &dma->queue); } spin_unlock_irqrestore(&dma->lock, flags); if (restart_dma) { /* * Once frames start dropping, some data gets stuck in the DMA * pipeline somewhere. So the first DMA transfer after frame * drops gives a partial frame. This is obviously not useful to * the application and will only confuse it. Issue a DMA * transaction to drain that up. */ ret = ti_csi2rx_drain_dma(ctx); if (ret && ret != -ETIMEDOUT) dev_warn(ctx->csi->dev, "Failed to drain DMA. Next frame might be bogus\n"); spin_lock_irqsave(&dma->lock, flags); ret = ti_csi2rx_start_dma(ctx, buf); if (ret) { vb2_buffer_done(&buf->vb.vb2_buf, VB2_BUF_STATE_ERROR); dma->state = TI_CSI2RX_DMA_IDLE; spin_unlock_irqrestore(&dma->lock, flags); dev_err(ctx->csi->dev, "Failed to start DMA: %d\n", ret); } else { list_add_tail(&buf->list, &dma->submitted); spin_unlock_irqrestore(&dma->lock, flags); } } } static int ti_csi2rx_get_vc(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dev *csi = ctx->csi; struct v4l2_mbus_frame_desc fd; struct media_pad *pad; int ret, i; pad = media_entity_remote_pad_unique(&csi->subdev.entity, MEDIA_PAD_FL_SOURCE); if (!pad) return -ENODEV; ret = v4l2_subdev_call(csi->source, pad, get_frame_desc, pad->index, &fd); if (ret) return ret; if (fd.type != V4L2_MBUS_FRAME_DESC_TYPE_CSI2) return -EINVAL; for (i = 0; i < fd.num_entries; i++) { if (ctx->stream == fd.entry[i].stream) return fd.entry[i].bus.csi2.vc; } return -ENODEV; } static int ti_csi2rx_start_streaming(struct vb2_queue *vq, unsigned int count) { struct ti_csi2rx_ctx *ctx = vb2_get_drv_priv(vq); struct ti_csi2rx_dev *csi = ctx->csi; struct ti_csi2rx_dma *dma = &ctx->dma; struct v4l2_subdev_krouting *routing; struct v4l2_subdev_route *route = NULL; struct media_pad *remote_pad; unsigned long flags; int ret = 0, i; struct v4l2_subdev_state *state; ret = pm_runtime_resume_and_get(csi->dev); if (ret) return ret; spin_lock_irqsave(&dma->lock, flags); if (list_empty(&dma->queue)) ret = -EIO; spin_unlock_irqrestore(&dma->lock, flags); if (ret) return ret; ret = video_device_pipeline_start(&ctx->vdev, &csi->pipe); if (ret) goto err; remote_pad = media_entity_remote_source_pad_unique(ctx->pad.entity); if (!remote_pad) { ret = -ENODEV; goto err; } state = v4l2_subdev_lock_and_get_active_state(&csi->subdev); routing = &state->routing; /* Find the stream to process. */ for (i = 0; i < routing->num_routes; i++) { struct v4l2_subdev_route *r = &routing->routes[i]; if (!(r->flags & V4L2_SUBDEV_ROUTE_FL_ACTIVE)) continue; if (r->source_pad != remote_pad->index) continue; route = r; break; } if (!route) { ret = -ENODEV; v4l2_subdev_unlock_state(state); goto err; } ctx->stream = route->sink_stream; v4l2_subdev_unlock_state(state); ret = ti_csi2rx_get_vc(ctx); if (ret == -ENOIOCTLCMD) ctx->vc = 0; else if (ret < 0) goto err; else ctx->vc = ret; ti_csi2rx_setup_shim(ctx); ctx->sequence = 0; spin_lock_irqsave(&dma->lock, flags); ret = ti_csi2rx_dma_submit_pending(ctx); if (ret) { spin_unlock_irqrestore(&dma->lock, flags); goto err_dma; } dma->state = TI_CSI2RX_DMA_ACTIVE; spin_unlock_irqrestore(&dma->lock, flags); ret = v4l2_subdev_enable_streams(&csi->subdev, TI_CSI2RX_PAD_FIRST_SOURCE + ctx->idx, BIT(0)); if (ret) goto err_dma; return 0; err_dma: ti_csi2rx_stop_dma(ctx); video_device_pipeline_stop(&ctx->vdev); writel(0, csi->shim + SHIM_CNTL); writel(0, csi->shim + SHIM_DMACNTX(ctx->idx)); err: ti_csi2rx_cleanup_buffers(ctx, VB2_BUF_STATE_QUEUED); pm_runtime_put(csi->dev); return ret; } static void ti_csi2rx_stop_streaming(struct vb2_queue *vq) { struct ti_csi2rx_ctx *ctx = vb2_get_drv_priv(vq); struct ti_csi2rx_dev *csi = ctx->csi; int ret; /* assert pixel reset to prevent stale data on stopping last stream */ if (csi->enable_count == 1) writel(0, csi->shim + SHIM_CNTL); video_device_pipeline_stop(&ctx->vdev); writel(0, csi->shim + SHIM_DMACNTX(ctx->idx)); ret = v4l2_subdev_disable_streams(&csi->subdev, TI_CSI2RX_PAD_FIRST_SOURCE + ctx->idx, BIT(0)); if (ret) dev_err(csi->dev, "Failed to stop subdev stream\n"); ti_csi2rx_stop_dma(ctx); ti_csi2rx_cleanup_buffers(ctx, VB2_BUF_STATE_ERROR); pm_runtime_put(csi->dev); } static const struct vb2_ops csi_vb2_qops = { .queue_setup = ti_csi2rx_queue_setup, .buf_prepare = ti_csi2rx_buffer_prepare, .buf_queue = ti_csi2rx_buffer_queue, .start_streaming = ti_csi2rx_start_streaming, .stop_streaming = ti_csi2rx_stop_streaming, .wait_prepare = vb2_ops_wait_prepare, .wait_finish = vb2_ops_wait_finish, }; static inline struct ti_csi2rx_dev *to_csi2rx_dev(struct v4l2_subdev *sd) { return container_of(sd, struct ti_csi2rx_dev, subdev); } static int ti_csi2rx_sd_set_fmt(struct v4l2_subdev *sd, struct v4l2_subdev_state *state, struct v4l2_subdev_format *format) { struct v4l2_mbus_framefmt *fmt; int ret = 0; /* No transcoding, don't allow setting source fmt */ if (format->pad >= TI_CSI2RX_PAD_FIRST_SOURCE) return v4l2_subdev_get_fmt(sd, state, format); if (!find_format_by_code(format->format.code)) format->format.code = ti_csi2rx_formats[0].code; format->format.field = V4L2_FIELD_NONE; fmt = v4l2_subdev_state_get_stream_format(state, format->pad, format->stream); if (!fmt) { ret = -EINVAL; goto out; } *fmt = format->format; fmt = v4l2_subdev_state_get_opposite_stream_format(state, format->pad, format->stream); if (!fmt) { ret = -EINVAL; goto out; } *fmt = format->format; out: return ret; } static int _ti_csi2rx_sd_set_routing(struct v4l2_subdev *sd, struct v4l2_subdev_state *state, struct v4l2_subdev_krouting *routing) { int ret; const struct v4l2_mbus_framefmt format = { .width = 640, .height = 480, .code = MEDIA_BUS_FMT_UYVY8_1X16, .field = V4L2_FIELD_NONE, .colorspace = V4L2_COLORSPACE_SRGB, .ycbcr_enc = V4L2_YCBCR_ENC_601, .quantization = V4L2_QUANTIZATION_LIM_RANGE, .xfer_func = V4L2_XFER_FUNC_SRGB, }; ret = v4l2_subdev_routing_validate(sd, routing, V4L2_SUBDEV_ROUTING_ONLY_1_TO_1 | V4L2_SUBDEV_ROUTING_NO_SOURCE_MULTIPLEXING); if (ret) return ret; ret = v4l2_subdev_set_routing_with_fmt(sd, state, routing, &format); return ret; } static int ti_csi2rx_sd_set_routing(struct v4l2_subdev *sd, struct v4l2_subdev_state *state, enum v4l2_subdev_format_whence which, struct v4l2_subdev_krouting *routing) { return _ti_csi2rx_sd_set_routing(sd, state, routing); } static int ti_csi2rx_sd_init_cfg(struct v4l2_subdev *sd, struct v4l2_subdev_state *state) { struct v4l2_subdev_route routes[] = { { .sink_pad = 0, .sink_stream = 0, .source_pad = TI_CSI2RX_PAD_FIRST_SOURCE, .source_stream = 0, .flags = V4L2_SUBDEV_ROUTE_FL_ACTIVE, } }; struct v4l2_subdev_krouting routing = { .num_routes = 1, .routes = routes, }; /* Initialize routing to single route to the fist source pad */ return _ti_csi2rx_sd_set_routing(sd, state, &routing); } static int ti_csi2rx_sd_all_sink_streams(struct v4l2_subdev_state *state) { struct v4l2_subdev_krouting *routing = &state->routing; u64 sink_streams = 0; int i; for (i = 0; i < routing->num_routes; i++) { struct v4l2_subdev_route *r = &routing->routes[i]; if (r->sink_pad == TI_CSI2RX_PAD_SINK) sink_streams |= BIT(r->sink_stream); } return sink_streams; } static int ti_csi2rx_sd_enable_streams(struct v4l2_subdev *sd, struct v4l2_subdev_state *state, u32 pad, u64 streams_mask) { struct ti_csi2rx_dev *csi = to_csi2rx_dev(sd); struct media_pad *remote_pad; int ret = 0; remote_pad = media_entity_remote_source_pad_unique(&csi->subdev.entity); if (!remote_pad) return -ENODEV; mutex_lock(&csi->mutex); if (csi->enable_multi_stream) { dev_dbg(csi->dev, "Enabling pad: %d, streams_mask: %lld.\n", pad, streams_mask); ret = v4l2_subdev_enable_streams(csi->source, remote_pad->index, BIT(csi->enable_count)); if (ret) goto out; csi->enabled_streams_mask |= BIT(csi->enable_count); } else { if (!csi->enable_count) { u64 sink_streams; sink_streams = ti_csi2rx_sd_all_sink_streams(state); dev_dbg(csi->dev, "Enabling all streams (%llx) on sink.\n", sink_streams); ret = v4l2_subdev_enable_streams(csi->source, remote_pad->index, sink_streams); if (ret) goto out; csi->enabled_streams_mask = sink_streams; } } csi->enable_count++; out: mutex_unlock(&csi->mutex); return ret; } static int ti_csi2rx_sd_disable_streams(struct v4l2_subdev *sd, struct v4l2_subdev_state *state, u32 pad, u64 streams_mask) { struct ti_csi2rx_dev *csi = to_csi2rx_dev(sd); struct media_pad *remote_pad; int ret = 0; remote_pad = media_entity_remote_source_pad_unique(&csi->subdev.entity); if (!remote_pad) return -ENODEV; mutex_lock(&csi->mutex); if (csi->enable_count == 0) { ret = -EINVAL; goto out; } if (csi->enable_multi_stream) { ret = v4l2_subdev_disable_streams(csi->source, remote_pad->index, BIT(csi->enable_count - 1)); if (ret) goto out; csi->enabled_streams_mask &= ~(BIT(csi->enable_count - 1)); if (csi->enable_count == 1) { csi->enable_multi_stream = false; } } else { if (csi->enable_count == 1) { u64 sink_streams; sink_streams = ti_csi2rx_sd_all_sink_streams(state); dev_dbg(csi->dev, "Disabling all streams (%llx) on sink.\n", sink_streams); ret = v4l2_subdev_disable_streams(csi->source, remote_pad->index, sink_streams); if (ret) goto out; csi->enabled_streams_mask = 0; } } --csi->enable_count; out: mutex_unlock(&csi->mutex); return ret; } static long ti_csi2rx_sd_ioctl(struct v4l2_subdev *sd, unsigned int cmd, void *arg) { struct ti_csi2rx_dev *csi = to_csi2rx_dev(sd); int ret = 0; switch (cmd) { case ADTOF_ENABLE_STREAM_NUM: mutex_lock(&csi->mutex); if (*((u32 *)arg) > 0) csi->enable_multi_stream = true; dev_err(csi->dev, "enable multi stream: %u from %d.\n", csi->enable_multi_stream, *((u32 *)arg)); mutex_unlock(&csi->mutex); break; default: return -ENOIOCTLCMD; } return ret; } static const struct v4l2_subdev_core_ops ti_csi2rx_subdev_core_ops = { .ioctl = ti_csi2rx_sd_ioctl, }; static const struct v4l2_subdev_pad_ops ti_csi2rx_subdev_pad_ops = { .init_cfg = ti_csi2rx_sd_init_cfg, .set_routing = ti_csi2rx_sd_set_routing, .get_fmt = v4l2_subdev_get_fmt, .set_fmt = ti_csi2rx_sd_set_fmt, .enable_streams = ti_csi2rx_sd_enable_streams, .disable_streams = ti_csi2rx_sd_disable_streams, }; static const struct v4l2_subdev_ops ti_csi2rx_subdev_ops = { .core = &ti_csi2rx_subdev_core_ops, .pad = &ti_csi2rx_subdev_pad_ops, }; static void ti_csi2rx_cleanup_dma(struct ti_csi2rx_ctx *ctx) { dma_release_channel(ctx->dma.chan); } static void ti_csi2rx_cleanup_v4l2(struct ti_csi2rx_dev *csi) { v4l2_subdev_cleanup(&csi->subdev); media_device_unregister(&csi->mdev); v4l2_device_unregister(&csi->v4l2_dev); media_device_cleanup(&csi->mdev); } static void ti_csi2rx_cleanup_notifier(struct ti_csi2rx_dev *csi) { v4l2_async_nf_unregister(&csi->notifier); v4l2_async_nf_cleanup(&csi->notifier); } static void ti_csi2rx_cleanup_vb2q(struct ti_csi2rx_ctx *ctx) { vb2_queue_release(&ctx->vidq); } static void ti_csi2rx_cleanup_ctx(struct ti_csi2rx_ctx *ctx) { if (!pm_runtime_status_suspended(ctx->csi->dev)) ti_csi2rx_cleanup_dma(ctx); ti_csi2rx_cleanup_vb2q(ctx); video_unregister_device(&ctx->vdev); mutex_destroy(&ctx->mutex); } static int ti_csi2rx_init_vb2q(struct ti_csi2rx_ctx *ctx) { struct vb2_queue *q = &ctx->vidq; int ret; q->type = V4L2_BUF_TYPE_VIDEO_CAPTURE; //q->io_modes = VB2_MMAP | VB2_DMABUF; q->io_modes = VB2_MMAP | VB2_DMABUF | VB2_USERPTR; q->drv_priv = ctx; q->buf_struct_size = sizeof(struct ti_csi2rx_buffer); q->ops = &csi_vb2_qops; //q->mem_ops = &vb2_dma_contig_memops; q->mem_ops = &vb2_dma_sg_memops; q->timestamp_flags = V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC; q->dev = dmaengine_get_dma_device(ctx->dma.chan); q->lock = &ctx->mutex; q->min_buffers_needed = 1; q->allow_cache_hints = 1; ret = vb2_queue_init(q); if (ret) return ret; ctx->vdev.queue = q; return 0; } static int ti_csi2rx_link_validate_get_fmt(struct media_pad *pad, struct v4l2_subdev_format *fmt) { if (is_media_entity_v4l2_subdev(pad->entity)) { struct v4l2_subdev *sd = media_entity_to_v4l2_subdev(pad->entity); fmt->which = V4L2_SUBDEV_FORMAT_ACTIVE; fmt->pad = pad->index; return v4l2_subdev_call(sd, pad, get_fmt, NULL, fmt); } WARN(pad->entity->function != MEDIA_ENT_F_IO_V4L, "Driver bug! Wrong media entity type 0x%08x, entity %s\n", pad->entity->function, pad->entity->name); return -EINVAL; } static int ti_csi2rx_link_validate(struct media_link *link) { struct media_entity *entity = link->sink->entity; struct video_device *vdev = media_entity_to_video_device(entity); struct ti_csi2rx_ctx *ctx = container_of(vdev, struct ti_csi2rx_ctx, vdev); struct ti_csi2rx_dev *csi = ctx->csi; struct v4l2_pix_format *csi_fmt = &ctx->v_fmt.fmt.pix; struct v4l2_subdev_format source_fmt; const struct ti_csi2rx_fmt *ti_fmt; int ret; ret = ti_csi2rx_link_validate_get_fmt(link->source, &source_fmt); if (ret) return ret; if (source_fmt.format.width != csi_fmt->width) { dev_err(csi->dev, "Width does not match (source %u, sink %u)\n", source_fmt.format.width, csi_fmt->width); return -EPIPE; } if (source_fmt.format.height != csi_fmt->height) { dev_err(csi->dev, "Height does not match (source %u, sink %u)\n", source_fmt.format.height, csi_fmt->height); return -EPIPE; } if (source_fmt.format.field != csi_fmt->field && csi_fmt->field != V4L2_FIELD_NONE) { dev_err(csi->dev, "Field does not match (source %u, sink %u)\n", source_fmt.format.field, csi_fmt->field); return -EPIPE; } ti_fmt = find_format_by_code(source_fmt.format.code); if (!ti_fmt) { dev_err(csi->dev, "Media bus format 0x%x not supported\n", source_fmt.format.code); return -EPIPE; } if (ctx->v_fmt.fmt.pix.pixelformat != ti_fmt->fourcc) { dev_err(csi->dev, "Cannot transform source fmt 0x%x to sink fmt 0x%x\n", ctx->v_fmt.fmt.pix.pixelformat, ti_fmt->fourcc); return -EPIPE; } return 0; } static const struct media_entity_operations ti_csi2rx_video_entity_ops = { .link_validate = ti_csi2rx_link_validate, }; static int ti_csi2rx_init_dma(struct ti_csi2rx_ctx *ctx) { struct dma_slave_config cfg = { .src_addr_width = DMA_SLAVE_BUSWIDTH_16_BYTES, }; char name[32]; int ret; snprintf(name, sizeof(name), "rx%u", ctx->idx); ctx->dma.chan = dma_request_chan(ctx->csi->dev, name); if (IS_ERR(ctx->dma.chan)) return PTR_ERR(ctx->dma.chan); ret = dmaengine_slave_config(ctx->dma.chan, &cfg); if (ret) { dma_release_channel(ctx->dma.chan); return ret; } return 0; } static int ti_csi2rx_v4l2_init(struct ti_csi2rx_dev *csi) { struct media_device *mdev = &csi->mdev; struct v4l2_subdev *sd = &csi->subdev; int ret, i; mdev->dev = csi->dev; mdev->hw_revision = 1; strscpy(mdev->model, "TI-CSI2RX", sizeof(mdev->model)); media_device_init(mdev); csi->v4l2_dev.mdev = mdev; ret = v4l2_device_register(csi->dev, &csi->v4l2_dev); if (ret) goto cleanup_media; ret = media_device_register(mdev); if (ret) goto unregister_v4l2; v4l2_subdev_init(sd, &ti_csi2rx_subdev_ops); sd->entity.function = MEDIA_ENT_F_VID_IF_BRIDGE; sd->flags = V4L2_SUBDEV_FL_HAS_DEVNODE | V4L2_SUBDEV_FL_STREAMS; strscpy(sd->name, dev_name(csi->dev), sizeof(sd->name)); sd->dev = csi->dev; csi->pads[TI_CSI2RX_PAD_SINK].flags = MEDIA_PAD_FL_SINK; for (i = TI_CSI2RX_PAD_FIRST_SOURCE; i < TI_CSI2RX_PAD_FIRST_SOURCE + csi->num_ctx; i++) csi->pads[i].flags = MEDIA_PAD_FL_SOURCE; ret = media_entity_pads_init(&sd->entity, TI_CSI2RX_PAD_FIRST_SOURCE + csi->num_ctx, csi->pads); if (ret) goto unregister_media; ret = v4l2_subdev_init_finalize(sd); if (ret) goto unregister_media; ret = v4l2_device_register_subdev(&csi->v4l2_dev, sd); if (ret) goto cleanup_subdev; return 0; cleanup_subdev: v4l2_subdev_cleanup(sd); unregister_media: media_device_unregister(mdev); unregister_v4l2: v4l2_device_unregister(&csi->v4l2_dev); cleanup_media: media_device_cleanup(mdev); return ret; } static int ti_csi2rx_init_ctx(struct ti_csi2rx_ctx *ctx) { struct ti_csi2rx_dev *csi = ctx->csi; struct video_device *vdev = &ctx->vdev; const struct ti_csi2rx_fmt *fmt; struct v4l2_pix_format *pix_fmt = &ctx->v_fmt.fmt.pix; int ret; mutex_init(&ctx->mutex); fmt = find_format_by_fourcc(V4L2_PIX_FMT_UYVY); if (!fmt) return -EINVAL; pix_fmt->width = 640; pix_fmt->height = 480; pix_fmt->field = V4L2_FIELD_NONE; pix_fmt->colorspace = V4L2_COLORSPACE_SRGB; pix_fmt->ycbcr_enc = V4L2_YCBCR_ENC_601, pix_fmt->quantization = V4L2_QUANTIZATION_LIM_RANGE, pix_fmt->xfer_func = V4L2_XFER_FUNC_SRGB, ti_csi2rx_fill_fmt(fmt, &ctx->v_fmt); ctx->pad.flags = MEDIA_PAD_FL_SINK; ret = media_entity_pads_init(&ctx->vdev.entity, 1, &ctx->pad); if (ret) return ret; snprintf(vdev->name, sizeof(vdev->name), "%s context %u", dev_name(csi->dev), ctx->idx); vdev->v4l2_dev = &csi->v4l2_dev; vdev->vfl_dir = VFL_DIR_RX; vdev->fops = &csi_fops; vdev->ioctl_ops = &csi_ioctl_ops; vdev->release = video_device_release_empty; vdev->device_caps = V4L2_CAP_VIDEO_CAPTURE | V4L2_CAP_STREAMING | V4L2_CAP_IO_MC; vdev->lock = &ctx->mutex; video_set_drvdata(vdev, ctx); INIT_LIST_HEAD(&ctx->dma.queue); INIT_LIST_HEAD(&ctx->dma.submitted); spin_lock_init(&ctx->dma.lock); ctx->dma.state = TI_CSI2RX_DMA_STOPPED; ret = ti_csi2rx_init_dma(ctx); if (ret) return ret; ret = ti_csi2rx_init_vb2q(ctx); if (ret) goto cleanup_dma; return 0; cleanup_dma: ti_csi2rx_cleanup_dma(ctx); return ret; } #ifdef CONFIG_PM static int ti_csi2rx_suspend(struct device *dev) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); enum ti_csi2rx_dma_state state; struct ti_csi2rx_ctx *ctx; struct ti_csi2rx_dma *dma; unsigned long flags = 0; int i, ret = 0; /* If device was not in use we can simply suspend */ if (pm_runtime_status_suspended(dev)) return 0; /* * If device is running, assert the pixel reset to cleanly stop any * on-going streams before we suspend. */ writel(0, csi->shim + SHIM_CNTL); for (i = 0; i < csi->num_ctx; i++) { ctx = &csi->ctx[i]; dma = &ctx->dma; spin_lock_irqsave(&dma->lock, flags); state = dma->state; spin_unlock_irqrestore(&dma->lock, flags); if (state != TI_CSI2RX_DMA_STOPPED) { /* Disable source */ ret = v4l2_subdev_disable_streams(&csi->subdev, TI_CSI2RX_PAD_FIRST_SOURCE + ctx->idx, BIT(0)); if (ret) dev_err(csi->dev, "Failed to stop subdev stream\n"); } /* Stop any on-going streams */ writel(0, csi->shim + SHIM_DMACNTX(ctx->idx)); /* Drain DMA */ ti_csi2rx_drain_dma(ctx); /* Terminate DMA */ ret = dmaengine_terminate_sync(ctx->dma.chan); if (ret) dev_err(csi->dev, "Failed to stop DMA\n"); } return ret; } static int ti_csi2rx_resume(struct device *dev) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); struct ti_csi2rx_ctx *ctx; struct ti_csi2rx_dma *dma; struct ti_csi2rx_buffer *buf; unsigned long flags = 0; unsigned int reg; int i, ret = 0; /* If device was not in use, we can simply wakeup */ if (pm_runtime_status_suspended(dev)) return 0; /* If device was in use before, restore all the running streams */ reg = SHIM_CNTL_PIX_RST; writel(reg, csi->shim + SHIM_CNTL); for (i = 0; i < csi->num_ctx; i++) { ctx = &csi->ctx[i]; dma = &ctx->dma; spin_lock_irqsave(&dma->lock, flags); if (dma->state != TI_CSI2RX_DMA_STOPPED) { /* Re-submit all previously submitted buffers to DMA */ list_for_each_entry(buf, &ctx->dma.submitted, list) { ti_csi2rx_start_dma(ctx, buf); } spin_unlock_irqrestore(&dma->lock, flags); /* Restore stream config */ ti_csi2rx_setup_shim(ctx); ret = v4l2_subdev_enable_streams(&csi->subdev, TI_CSI2RX_PAD_FIRST_SOURCE + ctx->idx, BIT(0)); if (ret) dev_err(ctx->csi->dev, "Failed to start subdev\n"); } else { spin_unlock_irqrestore(&dma->lock, flags); } } return ret; } static int ti_csi2rx_runtime_suspend(struct device *dev) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); int i; if (csi->enable_count != 0) return -EBUSY; for (i = 0; i < csi->num_ctx; i++) ti_csi2rx_cleanup_dma(&csi->ctx[i]); return 0; } static int ti_csi2rx_runtime_resume(struct device *dev) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); int ret, i; for (i = 0; i < csi->num_ctx; i++) { ret = ti_csi2rx_init_dma(&csi->ctx[i]); if (ret) return ret; } return 0; } static const struct dev_pm_ops ti_csi2rx_pm_ops = { SET_SYSTEM_SLEEP_PM_OPS(ti_csi2rx_suspend, ti_csi2rx_resume) SET_RUNTIME_PM_OPS(ti_csi2rx_runtime_suspend, ti_csi2rx_runtime_resume, NULL) }; #endif /* CONFIG_PM */ static ssize_t csi_rx_status_show(struct device *dev, struct device_attribute *attr, char *buf) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); int tmp_len = 0; char tmp[512] = {0}; char *p_tmp; int i; s64 us_delta; int total_fps = 0; int ok_fps = 0; p_tmp = tmp; for (i = 0; i < csi->num_ctx; i++) { us_delta = ktime_us_delta(ktime_get(), csi->ctx[i].rx_start); total_fps = (csi->ctx[i].ok_frame_cnt + csi->ctx[i].ng_frame_cnt) / (us_delta / 1000000); ok_fps = (csi->ctx[i].ok_frame_cnt) / (us_delta / 1000000); tmp_len = sprintf(p_tmp, "stream[%d] ok: %d, ng: %d, total_fps: %d, ok_fps: %d\n", i, csi->ctx[i].ok_frame_cnt, csi->ctx[i].ng_frame_cnt, total_fps, ok_fps); p_tmp += tmp_len; } return scnprintf(buf, PAGE_SIZE, "%s\n", tmp); } static ssize_t csi_rx_status_store(struct device *dev, struct device_attribute *attr, const char *buf, size_t count) { struct ti_csi2rx_dev *csi = dev_get_drvdata(dev); int i; int ret = 0; char cmd[20]; ret = sscanf(buf, "%s", cmd); if (ret == 1 && 6 == count) { ret = memcmp(cmd,"Clear",5); if (0 == ret) { for (i = 0; i < csi->num_ctx; i++) { csi->ctx[i].ok_frame_cnt = 0; csi->ctx[i].ng_frame_cnt = 0; } ret = 0; // avoid "write error: Operation not permitted" } else { return -EINVAL; } } else { return -EINVAL; } return ret ? -1 : count; } static DEVICE_ATTR_RW(csi_rx_status); static struct attribute *ti_csi2rx_dev_attrs[] = { &dev_attr_csi_rx_status.attr, NULL, }; static const struct attribute_group ti_csi2rx_dev_attrs_group = { .attrs = ti_csi2rx_dev_attrs, }; static int ti_csi2rx_register_attrib_group(struct device *dev) { return sysfs_create_group(&dev->kobj, &ti_csi2rx_dev_attrs_group); } static int ti_csi2rx_probe(struct platform_device *pdev) { struct device_node *np = pdev->dev.of_node; struct ti_csi2rx_dev *csi; int ret, i, count; csi = devm_kzalloc(&pdev->dev, sizeof(*csi), GFP_KERNEL); if (!csi) return -ENOMEM; csi->dev = &pdev->dev; platform_set_drvdata(pdev, csi); csi->shim = devm_platform_ioremap_resource(pdev, 0); if (IS_ERR(csi->shim)) { ret = PTR_ERR(csi->shim); return ret; } csi->drain.len = DRAIN_BUFFER_SIZE; csi->drain.vaddr = dma_alloc_coherent(csi->dev, csi->drain.len, &csi->drain.paddr, GFP_KERNEL); if (!csi->drain.vaddr) return -ENOMEM; /* Only use as many contexts as the number of DMA channels allocated. */ count = of_property_count_strings(np, "dma-names"); if (count < 0) { dev_err(csi->dev, "Failed to get DMA channel count: %d\n", count); return count; } csi->enable_multi_stream = false; csi->num_ctx = count; if (csi->num_ctx > TI_CSI2RX_MAX_CTX) { dev_warn(csi->dev, "%u DMA channels passed. Maximum is %u. Ignoring the rest.\n", csi->num_ctx, TI_CSI2RX_MAX_CTX); csi->num_ctx = TI_CSI2RX_MAX_CTX; } mutex_init(&csi->mutex); ret = ti_csi2rx_v4l2_init(csi); if (ret) goto err_v4l2; for (i = 0; i < csi->num_ctx; i++) { csi->ctx[i].idx = i; csi->ctx[i].csi = csi; ret = ti_csi2rx_init_ctx(&csi->ctx[i]); if (ret) goto err_ctx; } ret = ti_csi2rx_notifier_register(csi); if (ret) goto err_ctx; ret = of_platform_populate(csi->dev->of_node, NULL, NULL, csi->dev); if (ret) { dev_err(csi->dev, "Failed to create children: %d\n", ret); goto err_notifier; } ret = ti_csi2rx_register_attrib_group(csi->dev); if (ret) { dev_err(&pdev->dev, "Error creating sysfs attribute group for j721e-csi2rx driver\n"); } pm_runtime_set_active(csi->dev); pm_runtime_enable(csi->dev); pm_request_idle(csi->dev); return 0; err_notifier: ti_csi2rx_cleanup_notifier(csi); err_ctx: i--; for (; i >= 0; i--) ti_csi2rx_cleanup_ctx(&csi->ctx[i]); ti_csi2rx_cleanup_v4l2(csi); err_v4l2: mutex_destroy(&csi->mutex); dma_free_coherent(csi->dev, csi->drain.len, csi->drain.vaddr, csi->drain.paddr); return ret; } static int ti_csi2rx_remove(struct platform_device *pdev) { struct ti_csi2rx_dev *csi = platform_get_drvdata(pdev); int i; for (i = 0; i < csi->num_ctx; i++) { if (vb2_is_busy(&csi->ctx[i].vidq)) dev_err(csi->dev, "Failed to remove as queue busy for ctx %u\n", i); } for (i = 0; i < csi->num_ctx; i++) ti_csi2rx_cleanup_ctx(&csi->ctx[i]); ti_csi2rx_cleanup_notifier(csi); ti_csi2rx_cleanup_v4l2(csi); mutex_destroy(&csi->mutex); dma_free_coherent(csi->dev, csi->drain.len, csi->drain.vaddr, csi->drain.paddr); pm_runtime_disable(&pdev->dev); pm_runtime_set_suspended(&pdev->dev); return 0; } static const struct of_device_id ti_csi2rx_of_match[] = { { .compatible = "ti,j721e-csi2rx-shim", }, { }, }; MODULE_DEVICE_TABLE(of, ti_csi2rx_of_match); static struct platform_driver ti_csi2rx_pdrv = { .probe = ti_csi2rx_probe, .remove = ti_csi2rx_remove, .driver = { .name = TI_CSI2RX_MODULE_NAME, .of_match_table = ti_csi2rx_of_match, #ifdef CONFIG_PM .pm = &ti_csi2rx_pm_ops, #endif }, }; module_platform_driver(ti_csi2rx_pdrv); MODULE_DESCRIPTION("TI J721E CSI2 RX Driver"); MODULE_AUTHOR("Pratyush Yadav <p.yadav@ti.com>"); MODULE_LICENSE("GPL");
Each time there is a problem with the switching flow, there is an ng error frame
The first problematic switching curre: root@am62pxx-evm:~# cat /sys/devices/platform/bus@f0000/30102000.ticsi2rx/csi_rx_status stream[0] ok: 62311, ng: 0, total_fps: 537, ok_fps: 537 stream[1] ok: 62310, ng: 1, total_fps: 537, ok_fps: 537 stream[2] ok: 62310, ng: 0, total_fps: 537, ok_fps: 537 stream[3] ok: 62310, ng: 0, total_fps: 537, ok_fps: 537 stream[4] ok: 0, ng: 0, total_fps: 0, ok_fps: 0 stream[5] ok: 0, ng: 0, total_fps: 0, ok_fps: 0 two open: root@am62pxx-evm:~# cat /sys/devices/platform/bus@f0000/30102000.ticsi2rx/csi_rx_status stream[0] ok: 672411, ng: 0, total_fps: 622, ok_fps: 622 stream[1] ok: 672410, ng: 2, total_fps: 622, ok_fps: 622 stream[2] ok: 672410, ng: 0, total_fps: 622, ok_fps: 622 stream[3] ok: 672410, ng: 0, total_fps: 622, ok_fps: 622 stream[4] ok: 0, ng: 0, total_fps: 0, ok_fps: 0 stream[5] ok: 0, ng: 0, total_fps: 0, ok_fps: 0 three open: root@am62pxx-evm:~# cat /sys/devices/platform/bus@f0000/30102000.ticsi2rx/csi_rx_status stream[0] ok: 673719, ng: 0, total_fps: 620, ok_fps: 620 stream[1] ok: 673716, ng: 3, total_fps: 620, ok_fps: 620 stream[2] ok: 673717, ng: 0, total_fps: 620, ok_fps: 620 stream[3] ok: 673717, ng: 0, total_fps: 620, ok_fps: 620 stream[4] ok: 0, ng: 0, total_fps: 0, ok_fps: 0 stream[5] ok: 0, ng: 0, total_fps: 0, ok_fps: 0
Link:
media-ctl -p Media controller API version 6.6.32 Media device information ------------------------ driver j721e-csi2rx model TI-CSI2RX serial bus info platform:30102000.ticsi2rx hw revision 0x1 driver version 6.6.32 Device topology - entity 1: 30102000.ticsi2rx (7 pads, 7 links, 4 routes) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 routes: 0/0 -> 1/0 [ACTIVE] 0/1 -> 2/0 [ACTIVE] 0/2 -> 3/0 [ACTIVE] 0/3 -> 4/0 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:1 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:2 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:3 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "cdns_csi2rx.30101000.csi-bridge":1 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 0":0 [ENABLED,IMMUTABLE] pad2: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 1":0 [ENABLED,IMMUTABLE] pad3: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 2":0 [ENABLED,IMMUTABLE] pad4: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx context 3":0 [ENABLED,IMMUTABLE] pad5: Source -> "30102000.ticsi2rx context 4":0 [ENABLED,IMMUTABLE] pad6: Source -> "30102000.ticsi2rx context 5":0 [ENABLED,IMMUTABLE] - entity 9: cdns_csi2rx.30101000.csi-bridge (5 pads, 2 links, 4 routes) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 routes: 0/0 -> 1/0 [ACTIVE] 0/1 -> 1/1 [ACTIVE] 0/2 -> 1/2 [ACTIVE] 0/3 -> 1/3 [ACTIVE] pad0: Sink [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:1 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:2 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:3 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] <- "m00_dToF_ads6311 spi1.0":0 [ENABLED,IMMUTABLE] pad1: Source [stream:0 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:1 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:2 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] [stream:3 fmt:UYVY8_1X16/640x480 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range] -> "30102000.ticsi2rx":0 [ENABLED,IMMUTABLE] pad2: Source pad3: Source pad4: Source - entity 15: m00_dToF_ads6311 spi1.0 (1 pad, 1 link, 4 routes) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev2 routes: 0/0 -> 0/0 [ACTIVE] 0/0 -> 0/1 [ACTIVE] 0/0 -> 0/2 [ACTIVE] 0/0 -> 0/3 [ACTIVE] pad0: Source -> "cdns_csi2rx.30101000.csi-bridge":0 [ENABLED,IMMUTABLE] - entity 21: 30102000.ticsi2rx context 0 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video0 pad0: Sink <- "30102000.ticsi2rx":1 [ENABLED,IMMUTABLE] - entity 27: 30102000.ticsi2rx context 1 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video1 pad0: Sink <- "30102000.ticsi2rx":2 [ENABLED,IMMUTABLE] - entity 33: 30102000.ticsi2rx context 2 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Sink <- "30102000.ticsi2rx":3 [ENABLED,IMMUTABLE] - entity 39: 30102000.ticsi2rx context 3 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "30102000.ticsi2rx":4 [ENABLED,IMMUTABLE] - entity 45: 30102000.ticsi2rx context 4 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "30102000.ticsi2rx":5 [ENABLED,IMMUTABLE] - entity 51: 30102000.ticsi2rx context 5 (1 pad, 1 link) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "30102000.ticsi2rx":6 [ENABLED,IMMUTABLE]
dmesg
--on:1, dbg_ctrl:0x0, load_script: 0, ROI_data_src: 2 (from builtin_dot_h_file), lens_type: 0 (WIDEANGLE), workMode:6 (PCM), linkFreq:500000000, hawk_eco_version:ECO2, is_early_chip: 0, prbs_seed:0x34, mcu_chipid:0, mcu_fw_type: 0x0, drv_version: 3.2.0_LM20240904a--- [ 1120.812876] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_on> Line:4063--power_on:0, callline: 3537, sensor->power_on_times: 5--- [ 1120.937606] rpmsg wait for completion time-out for 100 ms. [ 1120.937628] rpmsg_tx: 00000000: 00 09 00 8a 00 06 8a ....... [ 1120.937635] rpmsg Write mcu reg:0x008a failed, ret:-110, rpmsg_from_user: 0 [ 1120.937641] Fail to set rx work mode: 6. [ 1120.940616] Success for sensor reset cost 1863 us, sensor chip id: 0x3400 [ 1120.940762] ------TRACE_PM_RUNTIME--End of <__sensor_power_on> Line:4228--power_on:1, load_script: 0, ret: 0, sensorId: 0x3400--- [ 1120.941160] client: fdls192_lidar_p (1215:1215) is running on CPU 3, ctrl->id: 0x9f0901, ctrl->val: 1, V4L2_CID_EXPOSURE: 0x980911 [ 1120.941168] sensor_set_ctrl Unhandled id:0x9f0901, val:0x1 [ 1120.941174] client: fdls192_lidar_p (1215:1215) is running on CPU 3, ctrl->id: 0x980911, ctrl->val: 100, V4L2_CID_EXPOSURE: 0x980911 [ 1120.941180] use roi sram from camxhawk-roi-mem.h, workMode: PCM, roi_data: 0000000050c4c83f, roi sram length: 6976 [ 1120.946999] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_on> Line:4063--power_on:1, callline: 3706, sensor->power_on_times: 6--- [ 1120.947009] It is power on already. [ 1126.178728] --on:0, dbg_ctrl:0x0, load_script: 0, ROI_data_src: 2 (from builtin_dot_h_file), lens_type: 0 (WIDEANGLE), workMode:6 (PCM), linkFreq:500000000, hawk_eco_version:ECO2, is_early_chip: 0, prbs_seed:0x2a, mcu_chipid:0, mcu_fw_type: 0x0, drv_version: 3.2.0_LM20240904a--- [ 1126.178764] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_off> Line:4239--power_on:1, callline: 3830--- [ 1126.182623] ------TRACE_PM_RUNTIME--End of <__sensor_power_off> Line:4280--power_on:0--- [ 1133.097582] client: fdls192_lidar_p (1215:1215) is running on CPU 3, pad: 0, name:m00_dToF_ads6311 spi1.0, fd: 000000004fc3710c [ 1133.097655] num_routes: 4, source_pad: 0, source_stream: 0 [ 1133.097662] num_entries: 0, w*h: 32 * 192, code: 0x3008, bpp: 16 [ 1133.097668] num_routes: 4, source_pad: 0, source_stream: 1 [ 1133.097673] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 1133.097678] num_routes: 4, source_pad: 0, source_stream: 2 [ 1133.097682] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.097687] num_routes: 4, source_pad: 0, source_stream: 3 [ 1133.097691] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.097850] j721e-csi2rx 30102000.ticsi2rx: enable multi stream: 1 from 4. [ 1133.097878] client: fdls192_lidar_p (1215:1215) is running on CPU 3 [ 1133.097888] ---- S_OPEN from fdls192_lidar_p (1215:1215) on CPU 3 [ 1133.097900] client: fdls192_lidar_p (1215:1215) subframe_count: 32, load_script: 0, streaming: 0, pad: 0, stream: 0, code: 0x0, state: 00000000361cf332, which:0x1, width:32, height:192 [ 1133.097921] fmt->which: 1, pad: 0, stream: 0, code: 0x3008, w*h: 32*192. [ 1133.097931] ---- S_CLOSE from fdls192_lidar_p (1215:1215) on CPU 3 [ 1133.097951] client: fdls192_lidar_p (1215:1215) is running on CPU 3 [ 1133.097958] ---- S_OPEN from fdls192_lidar_p (1215:1215) on CPU 3 [ 1133.097966] client: fdls192_lidar_p (1215:1215) subframe_count: 32, load_script: 0, streaming: 0, pad: 0, stream: 0, code: 0x0, state: 00000000361cf332, which:0x1, width:32, height:192 [ 1133.097978] fmt->which: 1, pad: 0, stream: 0, code: 0x3008, w*h: 32*192. [ 1133.097987] ---- S_CLOSE from fdls192_lidar_p (1215:1215) on CPU 3 [ 1133.112073] client: fdls192_lidar_p (1215:1215) is running on CPU 3, pad: 0, name:m00_dToF_ads6311 spi1.0, fd: 00000000f9118d29 [ 1133.112098] num_routes: 4, source_pad: 0, source_stream: 0 [ 1133.112103] num_entries: 0, w*h: 32 * 192, code: 0x3008, bpp: 16 [ 1133.112109] num_routes: 4, source_pad: 0, source_stream: 1 [ 1133.112113] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 1133.112118] num_routes: 4, source_pad: 0, source_stream: 2 [ 1133.112123] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112128] num_routes: 4, source_pad: 0, source_stream: 3 [ 1133.112132] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112562] client: fdls192_lidar_p (1215:1215) is running on CPU 3, pad: 0, name:m00_dToF_ads6311 spi1.0, fd: 00000000f9118d29 [ 1133.112574] num_routes: 4, source_pad: 0, source_stream: 0 [ 1133.112579] num_entries: 0, w*h: 32 * 192, code: 0x3008, bpp: 16 [ 1133.112584] num_routes: 4, source_pad: 0, source_stream: 1 [ 1133.112588] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 1133.112593] num_routes: 4, source_pad: 0, source_stream: 2 [ 1133.112597] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112602] num_routes: 4, source_pad: 0, source_stream: 3 [ 1133.112606] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112639] client: fdls192_lidar_p (1215:1215) is running on CPU 3, pad: 0, name:m00_dToF_ads6311 spi1.0, fd: 00000000f9118d29 [ 1133.112647] num_routes: 4, source_pad: 0, source_stream: 0 [ 1133.112651] num_entries: 0, w*h: 32 * 192, code: 0x3008, bpp: 16 [ 1133.112656] num_routes: 4, source_pad: 0, source_stream: 1 [ 1133.112659] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 1133.112665] num_routes: 4, source_pad: 0, source_stream: 2 [ 1133.112668] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112673] num_routes: 4, source_pad: 0, source_stream: 3 [ 1133.112677] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112708] client: fdls192_lidar_p (1215:1215) is running on CPU 3, pad: 0, name:m00_dToF_ads6311 spi1.0, fd: 00000000f9118d29 [ 1133.112716] num_routes: 4, source_pad: 0, source_stream: 0 [ 1133.112720] num_entries: 0, w*h: 32 * 192, code: 0x3008, bpp: 16 [ 1133.112725] num_routes: 4, source_pad: 0, source_stream: 1 [ 1133.112729] num_entries: 1, w*h: 480 * 128, code: 0x3008, bpp: 16 [ 1133.112734] num_routes: 4, source_pad: 0, source_stream: 2 [ 1133.112738] num_entries: 2, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112742] num_routes: 4, source_pad: 0, source_stream: 3 [ 1133.112746] num_entries: 3, w*h: 40 * 1, code: 0x3001, bpp: 8 [ 1133.112769] Function csi2rx_enable_streams at line 494 [ 1133.112777] --on:1, dbg_ctrl:0x0, load_script: 0, ROI_data_src: 2 (from builtin_dot_h_file), lens_type: 0 (WIDEANGLE), workMode:6 (PCM), linkFreq:500000000, hawk_eco_version:ECO2, is_early_chip: 0, prbs_seed:0x2a, mcu_chipid:0, mcu_fw_type: 0x0, drv_version: 3.2.0_LM20240904a--- [ 1133.112790] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_on> Line:4063--power_on:0, callline: 3537, sensor->power_on_times: 6--- [ 1133.237607] rpmsg wait for completion time-out for 100 ms. [ 1133.237629] rpmsg_tx: 00000000: 00 0a 00 8a 00 06 89 ....... [ 1133.237636] rpmsg Write mcu reg:0x008a failed, ret:-110, rpmsg_from_user: 0 [ 1133.237642] Fail to set rx work mode: 6. [ 1133.240531] Success for sensor reset cost 1776 us, sensor chip id: 0x3400 [ 1133.240677] ------TRACE_PM_RUNTIME--End of <__sensor_power_on> Line:4228--power_on:1, load_script: 0, ret: 0, sensorId: 0x3400--- [ 1133.241075] client: fdls192_lidar_p (1215:1215) is running on CPU 3, ctrl->id: 0x9f0901, ctrl->val: 1, V4L2_CID_EXPOSURE: 0x980911 [ 1133.241083] sensor_set_ctrl Unhandled id:0x9f0901, val:0x1 [ 1133.241090] client: fdls192_lidar_p (1215:1215) is running on CPU 3, ctrl->id: 0x980911, ctrl->val: 100, V4L2_CID_EXPOSURE: 0x980911 [ 1133.241096] use roi sram from camxhawk-roi-mem.h, workMode: PCM, roi_data: 0000000050c4c83f, roi sram length: 6976 [ 1133.246917] ------TRACE_PM_RUNTIME--Begin of <__sensor_power_on> Line:4063--power_on:1, callline: 3706, sensor->power_on_times: 7--- [ 1133.246929] It is power on already. [ 1713.600714] client: media-ctl (4363:4363) is running on CPU 0 [ 1713.600753] ---- S_OPEN from media-ctl (4363:4363) on CPU 0 [ 1713.601176] ---- S_CLOSE from media-ctl (4363:4363) on CPU 0 [ 1738.238009] client: media-ctl (4408:4408) is running on CPU 1 [ 1738.238056] ---- S_OPEN from media-ctl (4408:4408) on CPU 1
thank!
