AM62L: AM62L SD Card Boot Compatibility Issue
Part Number: AM62L
When booting from an SD card on the AM62L, compatibility issues have been observed across different brands. For example:
​​SanDisk SD cards​​: Some models fail to boot.
​​Kingston SD cards​​: Boot successfully.
​​Other brands​​: Mixed results—some cards work normally, while others fail to boot.
When SD card boot fail:
  • Yes, this is a known issue, errata is in the process of being updated.  Your observations align with ours, in that several different types of SanDisk cards fail, while cards from other manufacturers boot successfully.  For silicon revision 1.0, there is not a robust workaround, other than to continue using the working cards.  We have also seen that if you set both primary and backup to SD card boot, sometimes the backup boot will be successful on certain card that failed the primary boot
    James
