Part Number: PROCESSOR-SDK-AM69A
Other Parts Discussed in Thread: AM69A
i have compile and run inference time IResNet101 Model with TIDL but look like issue inference time , pls help me check it.
Hi Le,
Did you try running the inference step on osrt_python/ort ? Please let me know if you see the same issue there. Also could you share your artifacts that you created as well. I will try to run it on my end as well on PC. The high inference time is due to the model completely on ARM.
Warm regards,
Christina
Hi Christina,
i send you file log in folder /opt/edge-tidl-tool/model-artifact .
Please help me check it. Thank you
drive.google.com/.../view
Hi Le
What is the inference time that you get when you run this on PC inference? Is it similar?
Warm regards,
Christina
it's log when i run IResnet check inference time when docker .
Pls help me check it. Thank you
Hi Le Tung,
I double checked and the time that you have on the inference is microseconds [μs], not milliseconds [ms] (as I wrongly informed you in a past E2e) Apologies for that oversight, as I was remembering model run time units for benchmark testing, not for this case.
Everything looks fine for me. What is your target run time? There are some warnings that your model gets when running into TIDL that you can optimize to better run on TIDL.
Warm regards,
Christina
Hi Christina Kuruvilla ,
when running our self-trained resnet101 model, the inference time result is 538 microseconds. but when running our facenet model, the inference time result is too optimal compared to other models.
can you give me a link to the document about this inference time unit?
Hi Le,
There is no documentation that states the unit for the inference time, however, I was able to check this based on looking at the onnxrt_ep.py. Around line 405, it has
total_proc_time = total_proc_time / 1000000 sub_graphs_time = sub_graphs_time / 1000000
which is what I used to confirm.
Hope this helps.
Warm regards,
Christina
Hello Christina Kuruvilla ,
I was previously running the model on the ARM cores due to an incorrect path to the model artifacts. After updating the artifact path, I now encounter the following error during execution:
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
Could you please re-run the model on your end and share the complete inference log with me? Having your log output will help us diagnose the issue more effectively.
Thank you in advance for your assistance.
An Dao
Hi An,
I ran these under advanced_examples in OSRT on PC. Advanced_examples creates a random data to test the model. I have added both the compilation and inference for your reference. It will look different on the device a bit but please send over your input and the way you are running it on the device if possible.
Warm regards,
Christina
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider'] Running 1 Models - ['arrow'] [35;1m========================= [Model Compilation Started] ========================= [0mModel compilation will perform the following stages: 1. Parsing 2. Graph Optimization 3. Quantization & Calibration 4. Memory Planning [35;1m============================== [Version Summary] ============================== [0m------------------------------------------------------------------------------- | TIDL Tools Version | [32;1m10_01_04_00[0m | ------------------------------------------------------------------------------- | C7x Firmware Version | [32;1m10_01_00_01[0m | ------------------------------------------------------------------------------- | Runtime Version | [32;1m1.15.0[0m | ------------------------------------------------------------------------------- | Model Opset Version | [32;1m11[0m | ------------------------------------------------------------------------------- [35;1m============================== [Parsing Started] ============================== [0m[33m[TIDL Import] [PARSER] WARNING: Network not identified as Object Detection network : (1) Ignore if network is not Object Detection network (2) If network is Object Detection network, please specify "model_type":"OD" as part of OSRT compilation options[0m ------------------------- Subgraph Information Summary ------------------------- ------------------------------------------------------------------------------- | Core | No. of Nodes | Number of Subgraphs | ------------------------------------------------------------------------------- | C7x | 255 | 1 | | CPU | 0 | x | ------------------------------------------------------------------------------- [35;1m============================= [Parsing Completed] ============================= [0m[35;1m==================== [Optimization for subgraph_0 Started] ==================== [0m[33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_1's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_4's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_10's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_15's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_20's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_26's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_31's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_36's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_41's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_46's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_51's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_56's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_61's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_66's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_71's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_76's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_81's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_86's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_92's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_97's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_102's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_107's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_112's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_117's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_122's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_127's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_132's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_137's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_142's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_147's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_152's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_157's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_162's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_167's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_172's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_177's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_182's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_187's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_192's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_197's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_202's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_207's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_212's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_217's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_222's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_227's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_232's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_237's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_243's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: PReLU Layer PRelu_248's bias cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random[0m [33m[TIDL Import] [PARSER] WARNING: Batch Norm Layer BatchNormalization_254's coeff cannot be found(or not match) in coeff file, Random bias will be generated only for evaluation usage. Results are all random [0m ----------------------------- Optimization Summary ----------------------------- -------------------------------------------------------------------------------- Running_Model : arrow [WARNING] The run might fail for transformer/convnext networks, user will have to modify the strict to set graph_optimization_level to DISABLE_ALL in session. Running shape inference on model ../../../../../models/arrow/resnet101.onnx Completed model - resnet101.onnx Name : arrow , Total time : 17644.79, Offload Time : 13276.17 , DDR RW MBs : 0
Available execution providers : ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider'] Running 1 Models - ['arrow'] Running_Model : arrow [WARNING] The run might fail for transformer/convnext networks, user will have to modify the strict to set graph_optimization_level to DISABLE_ALL in session. EP Error /root/onnxruntime/onnxruntime/core/providers/tidl/tidl_execution_provider.cc:94 onnxruntime::TidlExecutionProvider::TidlExecutionProvider(const onnxruntime::TidlExecutionProviderInfo&) status == true was false. when using ['TIDLExecutionProvider', 'CPUExecutionProvider'] Falling back to ['CPUExecutionProvider'] and retrying. Completed model - resnet101.onnx Name : arrow , Total time : 277.51, Offload Time : 0.00 , DDR RW MBs : 0
Hi Christina,
Thank you for sharing the advanced_examples for OSRT on PC—I really appreciate having both the compilation and inference logs for reference.
My colleague Mr. Tung and I are working on the AM69A evaluation kit. When I execute the same workflow as Mr. Tung, the log confirms that the model is running entirely on the ARM core, just as shown in the screenshot above.
To adapt the example to our setup, I only modified the onnxrt_ep.py file, updating:
so that the runtime can locate the allowedNode.txt file. However, once the TIDL provider is invoked, the run fails with:
Could you please try running the advanced_examples on an AM69A device and share your logs or any insights? Your help would be invaluable in diagnosing this TIDL verification failure.
Hi An and Le,
Did you set the model details under common_utils found in /edgeai-tidl-tools/examples/osrt_python/advanced_examples/unit_tests_validation/ ?
Also, do you have an input file for your model that you are using? If you have an input file, I recommend using /edgeai-tidl-tools/examples/osrt_python/ort
for the best data since advanced_examples is just for testing compatibility purposes and not accuracy. If you can send the input file, I can test it on the AM69a device to check where you may be having the issue.
Warm regards,
Christina
Hi Christina
https://drive.google.com/file/d/1iBooIewlHdXRZr-0d6C2vM0slaY9TnYE/view?usp=sharing
this link bellow the input file.
thanks,
Thanks Le,
Please give me some time to set this up and run on my end.
Warm regards,
Christina
Hi Le,
No support from your end currently needed. I am setting up the device but due to bandwidth, it may take me some time to get back to you. Please expect a response by latest next Wednesday on my progress.
I appreciate your patience.
Warm regards,
Christina
Hi Le,
I think I came across the artifacts_folder issue that you mentioned. Here is the output I received
libtidl_onnxrt_EP loaded 0xad959a0 EP Error /root/onnxruntime/onnxruntime/core/providers/tidl/tidl_execution_provider.cc:94 onnxruntime::TidlExecutionProvider::TidlExecutionProvider(const onnxruntime::TidlExecutionProviderInfo&) status == true was false. when using ['TIDLExecutionProvider', 'CPUExecutionProvider']Falling back to ['CPUExecutionProvider'] and retrying.Completed model - resnet101.onnx
Name : arrow , Total time : 538.19, Offload Time : 0.00 , DDR RW MBs : 0
ERROR : artifacts_folder not a directoryroot
When trying to run your model under examples, it takes a long time to compile. I am still working through trying to determine the case of this, as well as the artifacts_folder issue. I may try to run your model directly under tidl_tools through TIDLRT since this will then use the TIDLExecution instead of CPU. If you would like to work on it in parallel, the documentation for it can be followed through with jupyter notebooks:
I will continue to update you on the progress.
Warm regards,
Christina
Could you try the following changes on your board?
under /run/media/BOOT-mmcblk1p1/uEnv.tx
if the name_overlays line is set to
name_overlays=ti/k3-j784s4-edgeai-apps.dtbo
please change it to
name_overlays=ti/k3-j784s4-edgeai-apps.dtbo ti/k3-am68-sk-v3link-fusion.dtbo ti/k3-v3link-imx219-0-0.dtbo
If you are continuing to have trouble running under OSRT, TIDLRT is a second option to run these under.
Let me know what happens with the error when this occurs.
Warm regards,
Christina
Hi Christina ,
After fixing according to your instructions, there is still no change in the error. I tried the TIDLRT part but it is having an error. It seems that the documentation on the github page has not been updated. Can you send me the detailed results of the part where you tested my resnet101.onnx self-train model on the tidlrt tool?
Thanks and bét regard.
Hi all,
I have attached the import and inference files needed for successful import and inference of the resnet101 model that I presented in the debug session. This assumes you have edgeai-tidl-tools set up and have run 'source setup'.sh successfully.
First step is to make an arrow/E2E-1491952/ under edgeai-tidl-tools/ and copy resnete101.onnx model to arrow/E2E-1491952/. Then cd into edgeai-tidl-tools/tidl_tools, copy import_resnet101_host to tidl_tools, run mkdir out/, and run "./tidl_model_import.out import_resnet101". This will compile the model and place the artifacts in out/.
Once you have the artifacts, you can then run:
tidl_tools# ./PC_dsp_test_dl_algo.out s:inference_resnet101_host
This will execute the model in emulation mode on the PC.
On the device, make an /opt/arrow directory.
From tidl_tools/, copy the out folder to /opt/arrow/ by scp -r out root@<your_device_ip_address>/opt/arrow
Then copy jet.bmp and inference_resnet101 to /opt/arrow/ by scp inference_resnet101 root@<your_device_ip_address>/opt/arrow and cp jet.bmp root@<your_device_ip_address>/opt/arrow
Finally, SSH to the device and cd to /opt/arrow. Then on the device, run:
root@am69-sk:/opt/arrow# ../tidl_test/TI_DEVICE_armv8_test_dl_algo_host_rt.out s:inference_resnet101
The .zip file has the generated binaries I used in the debug session. It is not needed except as a reference.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/inference_5F00_resnet101_5F00_hosthttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/import_5F00_resnet101https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/inference_5F00_resnet101
device.zip
regards,
Chris
Hi Christina ,
i have follow step by step for you but have issue the same when you before reboot
it's log when i follow guide for you , i try reboot devices but not update env , pls help me check it.
I suspect there is something wrong with the SD card image. This will work with the .wic file for 10.01 from https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM69A/10.01.00.05. Is that the .wic file used to create the SD card? One other thing to try is to initialize the OpenVX environment by:
root@ j7-evm:~# cd /opt/vision_apps
root@ j7-evm:~# source ./vision_apps_init.sh
root@ j7-evm:/opt/tidl_test# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib
Before running inference.
regards,
ChrisHi Christina,
I followed the same procedure as in the resnet101.onnx example to import our custom-trained yolov8s.onnx model. However, I encountered the following error logs during the import process using tidl_model_import.out:
This is the link to the YOLOv8s model that runs successfully on the kit, but it currently runs 100% on the CPU.
Could you help us understand the cause of these errors and how to resolve them?
2. Requirement to build from source code for evaluation:
I noticed that your guides often focus on using pre-built executables along with input files for inference. However, our goal is to build the toolchain from source so that we can integrate additional evaluations beyond inference time, such as accuracy and custom metrics.
Could you please guide us on how to properly build the necessary components from source to support these needs?
Hi Le,
Please add a new E2E for a new question. We keep all E2E's on a single topic for search purposes. It sounds like you are able to import the resnet101 model and are going to a new model. This is good, and please close this thread and start a new one on the new model.
I am also not able to open your log file.
Chris
Hi Christina ,
I sincerely appreciate your support in helping me successfully run the resnet101.onnx model on the AM69A board.
I have created a new case regarding the YOLOv8s model , pls help me check it.
e2e.ti.com/.../processor-sdk-am69a-processor-sdk-am69a-issue-deploying-custom-yolov8s-model-self-trained-on-am69a-with-tidl
thanks and best regart ,
