Part Number: AM62A7
Hi TI Experts,
It seem some file download error ,
But I can download other file successfully, why?
How to I solve this problem?
Meng
Sstate summary: Wanted 179 Local 107 Mirrors 0 Missed 72 Current 6610 (59% match, 98% complete)############################################################################# | ETA: 0:00:00
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:04
NOTE: Executing Tasks
WARNING: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.01.00.04;manifest=vision_apps_yocto.xml, attempting MIRRORS if available
ERROR: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export GIT_PROXY_COMMAND="oe-git-proxy"; export all_proxy="socks://127.0.0.1:7890/"; export ALL_PROXY="socks://127.0.0.1:7890/"; export no_proxy="127.0.0.1"; export NO_PROXY="127.0.0.1"; export ftp_proxy="">http://127.0.0.1:7890/"; export https_proxy="">http://127.0.0.1:7890"; export http_proxy="">http://127.0.0.1:7890/"; export PATH="/home/user/tisdk/sources/oe-core/scripts:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot/usr/bin/crossscripts:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/sbin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/bin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/sbin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/bin:/home/user/tisdk/sources/bitbake/bin:/home/user/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/user"; /usr/bin/env repo sync failed with exit code 1, output:
error: command 'sync' requires repo to be installed first.
Use "repo init" to install it here.
ERROR: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.01.00.04;manifest=vision_apps_yocto.xml')
ERROR: Logfile of failure stored in: /home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/temp/log.do_fetch.2253028
ERROR: Task (/home/user/tisdk/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 14478 tasks of which 14471 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 2 seconds
Summary: 1 task failed:
Summary: There was 1 WARNING message.
Summary: There were 2 ERROR messages, returning a non-zero exit code.
