SK-AM62A-LP: Switch between IR and RGB when using a Omnivision Ox05B1S sensor
Part Number: SK-AM62A-LP
Tool/software: GStreamer / C++
How to have a GStreamer pipeline programatically switch between IR and RGB sensor several times (without crashing due to memory leaks) when using a Omnivision Ox05B1S?
  • Hi Felix,
    I had verified the below code on AM62A with 0x05B connected. Disclaimer: Its just a reference code for running a pipeline to toggle between IR and RGB.
    Hope this helps.
    Suren
    #include <gst/gst.h>
    #include <iostream>
    #include <string>
    #include <glib.h>  // For g_usleep
     * @brief Enum for color schemes used in the video stream.
    enum GSM_ColorScheme_t
        GSM_ColorScheme_NV12, /**< NV12 color scheme (YUV 4:2:0). */
        GSM_ColorScheme_GRAY8 /**< GRAY8 color scheme (grayscale). */
    // Global GStreamer elements and variables
    static GstElement *pipeline = nullptr;
    static GstElement *text_overlay = nullptr;
    static GstElement *video_converter = nullptr;
    static GstElement *video_encoder = nullptr;
    static GstElement *isp = nullptr;
    static GMainContext *context = nullptr;
    static std::string Color = "";  // Current stream color (RGB or IR)
    static int RTPStreamWidth = 1920;
    static int RTPStreamHeight = 1080;
    static bool isHighResolution = true;  // Toggle between high and low resolution
    static GSM_ColorScheme_t ColorMode = GSM_ColorScheme_NV12;  // Default color scheme
    static int switch_count = 0;  // Counter for how many times the resolution has been switched
    static int iteration_count = 0;  // Counter for main loop iterations
     * @brief Sets up the GStreamer pipeline for video processing.
     * This function constructs the GStreamer pipeline according to the specified
     * width, height, and color scheme (RGB or IR).
     * @param width The width of the video stream.
     * @param height The height of the video stream.
     * @param RTPStreamColorScheme The color scheme for the RTP stream (e.g., NV12 or GRAY8).
    static void GSM_CreatePipeline(int width, int height, GSM_ColorScheme_t RTPStreamColorScheme)
        GError *error = nullptr;
        std::string pipeline_desc;
        std::cout << "Creating the pipeline with video resolution " << width << "x" << height << "..." << std::endl;
        // Choose the pipeline description based on the color scheme.
        switch (RTPStreamColorScheme)
            case GSM_ColorScheme_GRAY8:
                // IR grayscale processing.
                pipeline_desc =
                    "v4l2src device=/dev/video3 io-mode=dmabuf-import ! "
                    "video/x-bayer, width=2592, height=1944, framerate=30/1, format=bggi10 ! "
                    "queue ! tiovxisp name=isp sink_0::pool-size=2 sensor-name=SENSOR_OX05B1S "
                    "dcc-isp-file=/opt/imaging/ox05b1s/linear/dcc_viss.bin sink_0::dcc-2a-file=/opt/imaging/ox05b1s/linear/dcc_2a.bin format-msb=9 ! "
                    "video/x-raw, format=GRAY8, width=2592, height=1944 ! tee name=t "
                    "t. ! queue ! tiovxmultiscaler src_0::pool-size=2 target=1 ! video/x-raw, format=GRAY8, width=" + std::to_string(width) + ", height=" + std::to_string(height) + " ! "
                    "queue ! textoverlay name=overlay ! videoconvert name=videoconverter ! v4l2h264enc name=videoencoder ! rtph264pay ! udpsink host=192.168.1.10 port=5000";
                break;
            case GSM_ColorScheme_NV12:
            default:
                // Default NV12 (YUV) color processing.
                pipeline_desc =
                    "v4l2src device=/dev/video4 io-mode=dmabuf-import ! "
                    "queue ! tiovxisp name=isp sink_0::pool-size=2 sink_0::device=/dev/v4l-subdev2 sensor-name=SENSOR_OX05B1S "
                    "queue ! tiovxldc dcc-file=/opt/imaging/ox05b1s/linear/dcc_ldc.bin sensor-name=SENSOR_OX05B1S ! "
                    "video/x-raw, format=NV12, width=2592, height=1944 ! queue ! tiovxmultiscaler src_0::pool-size=4 target=1 ! video/x-raw, format=NV12, width=" + std::to_string(width) + ", height=" + std::to_string(height) + " ! "
                break;
        // Parse and create the pipeline from the description.
        pipeline = gst_parse_launch(pipeline_desc.c_str(), &error);
        if (error != nullptr)
            std::cerr << "Error creating pipeline: " << error->message << std::endl;
            g_clear_error(&error);
            return;
        // Retrieve key elements from the pipeline.
        text_overlay = gst_bin_get_by_name(GST_BIN(pipeline), "overlay");
        video_converter = gst_bin_get_by_name(GST_BIN(pipeline), "videoconverter");
        video_encoder = gst_bin_get_by_name(GST_BIN(pipeline), "videoencoder");
        isp = gst_bin_get_by_name(GST_BIN(pipeline), "isp");
        std::cout << "Pipeline created." << std::endl;
     * @brief Sets the text overlay with the specified string.
     * @param TextOverlay The text to be displayed on the overlay.
    int GSM_SetTextOverlay(const std::string& TextOverlay) {
        if (text_overlay != nullptr) {
            g_object_set(text_overlay, "text", TextOverlay.c_str(), nullptr);
        } else {
            std::cerr << "text_overlay element is nullptr" << std::endl;
        return 0;
     * @brief Stops and deallocates the GStreamer pipeline.
     * This function ensures all pipeline elements are properly cleaned up and the pipeline
     * is set to the NULL state.
    void GSM_StopPipeline()
        if (pipeline)
            // Set the pipeline to NULL state to ensure it stops.
            gst_element_set_state(pipeline, GST_STATE_NULL);
            // Safely unref all individual elements.
            if (isp) {
                gst_bin_remove(GST_BIN(pipeline), isp);
                gst_object_unref(isp);
                isp = nullptr;
            if (text_overlay) {
                gst_bin_remove(GST_BIN(pipeline), text_overlay);
                gst_object_unref(text_overlay);
            if (video_converter) {
                gst_bin_remove(GST_BIN(pipeline), video_converter);
                gst_object_unref(video_converter);
            if (video_encoder) {
                gst_bin_remove(GST_BIN(pipeline), video_encoder);
                gst_object_unref(video_encoder);
            // Finally, unref the entire pipeline.
            gst_object_unref(pipeline);
            pipeline = nullptr;
        std::cout << "Pipeline and elements stopped and unrefed." << std::endl;
     * @brief Toggles the video resolution between 1920x1080 and 800x600.
    void GSM_ToggleResolution()
        // Stop the current pipeline.
        GSM_StopPipeline();
        // Toggle the resolution between high and low.
        if (isHighResolution)
            RTPStreamWidth = 800;
            RTPStreamHeight = 600;
        else
        isHighResolution = !isHighResolution;
        switch_count++;  // Increment the switch counter.
        // Create and start the pipeline with the new resolution.
        GSM_CreatePipeline(RTPStreamWidth, RTPStreamHeight, GSM_ColorScheme_NV12);
        if (pipeline)
            gst_element_set_state(pipeline, GST_STATE_PLAYING);
            // Update the text overlay with the current resolution, switch count, and color mode.
            std::string overlay_text = "Resolution: " + std::to_string(RTPStreamWidth) + "x" + std::to_string(RTPStreamHeight) +
                                       " | Switch count: " + std::to_string(switch_count) +
                                       " | Color: " + Color;
            GSM_SetTextOverlay(overlay_text);
            std::cout << "Started " << Color << " Stream with resolution: " << RTPStreamWidth << "x" << RTPStreamHeight << " | Switch count: " << switch_count << std::endl;
     * @brief Toggles between color modes (RGB and IR).
    void GSM_ToggleColorMode()
        GSM_StopPipeline();
        // Toggle between NV12 (RGB) and GRAY8 (IR).
        if (ColorMode == GSM_ColorScheme_NV12)
            ColorMode = GSM_ColorScheme_GRAY8;
            Color = "IR";
        else
            Color = "RGB";
        // Create and start the pipeline with the new color mode.
        GSM_CreatePipeline(RTPStreamWidth, RTPStreamHeight, ColorMode);
        if (pipeline)
     * @brief Main function to initialize GStreamer and control the main loop.
    int main(int argc, char *argv[])
        std::cout << "Initializing GStreamer..." << std::endl;
        // Initialize GStreamer.
        gst_init(&argc, &argv);
        // Create a default GStreamer context.
        context = g_main_context_default();
        // Create and start the initial pipeline.
        int switch_after_iterations = 30;  // Change resolution/color every 30 iterations.
        // Main loop to handle GStreamer events and toggle modes.
        while (true) {
            // Process GStreamer events in the main loop.
            g_main_context_iteration(context, FALSE);
            // Increment the iteration counter.
            iteration_count++;
            // Toggle color mode or resolution after a set number of iterations (~ 3 seconds).
            if (iteration_count % switch_after_iterations == 0) {
                GSM_ToggleColorMode();
                //GSM_ToggleResolution();
            // Sleep for a short time between iterations (100 ms).
            g_usleep(100000);
        return 0;
