PROCESSOR-SDK-J722S: [J722S][EVM] name="UNKNOWN" in dfu-util -l when DFU mode
Part Number: PROCESSOR-SDK-J722S
Hi TI
I try to follow this
software-dl.ti.com/.../UG-DFU.html
3.1.1.2. USB Device Firmware Upgrade (DFU)
I set J722S EVM's boot mode to DFU mode
SW3[1:8] = 1100 1010
SW4[1:8] = 0000 0000
SW2[1:8] = 0011 1100
My SDK is J722S 10.01.00.04
After
dfu-util.exe -R -a bootloader -D  tiboot3.bin
I get this
Found DFU: [0451:6165] ver=0200, devnum=15, cfg=1, intf=0, path="3-1.1", alt=1, name="UNKNOWN", serial="UNKNOWN"
Found DFU: [0451:6165] ver=0200, devnum=15, cfg=1, intf=0, path="3-1.1", alt=0, name="UNKNOWN", serial="UNKNOWN"
Is anything wrong in my step ?
DFU LOG:
UART LOG:
https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j722s/latest/exports/docs/linux/Foundational_Components/U-Boot/UG-DFU.html
    Which SDK version are you using?
    Also is this a custom board or Ti EVM?
    Keerthy
  • Hi Keerthy
    > J722S  10.01.00.04
    > Ti EVM
    Best Regards
    Jiahao
  • Hi Jiahao,
    We do not support booting using DFU from Windows.Please use a linux host machine for DFU and do let us know if you face any issues.
    Gokul
  • Hi  Gokul
    This show J722S support on windows host
    Please help this, thanks
    3.1.1.2.1
    Best Regards
    Jiahao
  • HI Jiahao,
    Can you try following the below steps for flashing the following.
    • Run the setup.sh script present in the SDK directory as per the below link.
    • host# export CROSS_COMPILE_64="${SDK_INSTALL_DIR}/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-"
      host# export SYSROOT_64="${SDK_INSTALL_DIR}/linux-devkit/sysroots/aarch64-oe-linux"
      host# export CC_64="${CROSS_COMPILE_64}gcc --sysroot=${SYSROOT_64}"
      host# export CROSS_COMPILE_32="${SDK_INSTALL_DIR}/k3r5-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-oe-eabi/arm-oe-eabi-"
    • cd <path to u-boot dir>
    • export PREBUILT_IMAGES=${SDK_INSTALL_DIR}/board-support/prebuilt-images
    • make ARCH=arm O=./build/r5 j722s_evm_r5_defconfig j722s_evm_r5_usbdfu.config
    • make ARCH=arm O=./build/r5 CROSS_COMPILE="$CROSS_COMPILE_32" BINMAN_INDIRS=${PREBUILT_IMAGES}
    • make ARCH=arm O=<output directory>/a53 j722s_evm_a53_defconfig
    • make ARCH=arm O=<output directory>/a53 CROSS_COMPILE="$CROSS_COMPILE_64" CC="$CC_64" BL31=${PREBUILT_IMAGES}/bl31.bin TEE=${PREBUILT_IMAGES}/bl32.bin BINMAN_INDIRS=${PREBUILT_IMAGES}
    Once the above steps are done,flash the files from the below path:
    • {SDK_INSTALL_DIR}/board-support/<ti-u-boot dir>/build/r5/tiboot3-j722s-hs-fs-evm.bin
    • {SDK_INSTALL_DIR}/board-support/prebuilt-images/tispl.bin
    • {SDK_INSTALL_DIR}/board-support/prebuilt-images/u-boot.img
    Gokul
  • Hi Gokul
    After the above modifications, SPL-DFU can work normally
    1) switch to SPL-DFU mode
    2) dfu-util-static.exe -R -a bootloader -D tiboot3.bin
    3) dfu-util-static.exe -R -a tispl.bin -D tispl.bin
    4) dfu-util-static.exe -R -a u-boot.img -D u-boot.img
    CMDS_LOG:
    E:\platform-tools-r35.0.2>dfu-util-static.exe -l
    dfu-util 0.11
    Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
    Copyright 2010-2021 Tormod Volden and Stefan Schmidt
    This program is Free Software and has ABSOLUTELY NO WARRANTY
    Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
    Found DFU: [0451:6165] ver=0200, devnum=19, cfg=1, intf=0, path="3-1.2", alt=1, name="SocId", serial="01.00.00.00"
    Found DFU: [0451:6165] ver=0200, devnum=19, cfg=1, intf=0, path="3-1.2", alt=0, name="bootloader", serial="01.00.00.00"
    E:\platform-tools-r35.0.2>dfu-util-static.exe -R -a bootloader -D usbdfu\tiboot3.bin
    dfu-util 0.11
    Warning: Invalid DFU suffix signature
    A valid DFU suffix will be required in a future dfu-util release
    Opening DFU capable USB device...
    Device ID 0451:6165
    Device DFU version 0110
    Claiming USB DFU Interface...
    Setting Alternate Interface #0 ...
    Determining device status...
    DFU state(2) = dfuIDLE, status(0) = No error condition is present
    DFU mode device DFU version 0110
    Device returned transfer size 512
    Copying data from PC to DFU device
    Download        [=========================] 100%       350655 bytes
    Download done.
    DFU state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is present
    unable to read DFU status after completion (LIBUSB_ERROR_PIPE)
    dfu-util 0.11
    Found DFU: [0451:6165] ver=0223, devnum=21, cfg=1, intf=0, path="3-1.2", alt=1, name="u-boot.img", serial="UNKNOWN"
    Found DFU: [0451:6165] ver=0223, devnum=21, cfg=1, intf=0, path="3-1.2", alt=0, name="tispl.bin", serial="UNKNOWN"
    E:\platform-tools-r35.0.2>dfu-util-static.exe -R -a tispl.bin -D usbdfu\tispl.bin
    dfu-util 0.11
    Device ID 0451:6165
    Device returned transfer size 4096
    Download        [=========================] 100%      1030979 bytes
    Download done.
    DFU state(7) = dfuMANIFEST, status(0) = No error condition is present
    Done!
    Resetting USB to switch back to Run-Time mode
    E:\platform-tools-r35.0.2>dfu-util-static.exe -R -a u-boot.img -D usbdfu\u-boot.img
    dfu-util 0.11
    Device ID 0451:6165
    Setting Alternate Interface #1 ...
    Download        [=========================] 100%      1207947 bytes
    Download done.
    Done!
    UART_LOG:
    U-Boot SPL 2024.04-ti-gc7151985dcdc (May 21 2025 - 06:41:59 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.6--v10.01.06 (Fiery Fox)')
    SPL initial stack usage: 17048 bytes
    Trying to boot from DFU
    ###################################################DOWNLOAD ... OK
    Ctrl+C to exit ...
    Authentication passed
    init_env from device 10 not supported!
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty
    NOTICE:  BL31: Built : 04:20:32, Nov  1 2024
    Ctrl+C to exit ...
    U-Boot 2024.04-ti-gc7151985dcdc (May 21 2025 - 06:41:59 +0000)
    SoC:   J722S SR1.0 HS-FS
    Model: Texas Instruments J722S EVM
    DRAM:  2 GiB (effective 8 GiB)
    Core:  79 devices, 29 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    After the above modifications, device boot from sdcard fail
    UART_LOG:
    Trying to boot from MMC2
    spl: could not initialize mmc. error: -19
    SPL: failed to boot from all boot devices
    ### ERROR ### Please RESET the board ###
    Best Regards
    Jiahao
  • Hi Jiahao,
    Can you raise this as a separate E2E as this is an SD card question and DFU is now resolved.Also,it would be helpful if you can you mark this issue as resolved.
    Thanks in advance.
    Gokul
  • Hi Gokul
    Is this an official correct to fix SPL-DFU fail ?
    software-dl.ti.com/.../Run_Setup_Scripts.html
    Jiahao
  • Hi Jiahao,
    Yes Jiahao,
    Gokul
  • yocto-build/sources/meta-ti/meta-ti-bsp/conf/machine/j722s-evm-k3r5.conf
             UBOOT_MACHINE = "j722s_evm_r5_defconfig"
           +UBOOT_CONFIG_FRAGMENTS = "j722s_evm_r5_usbdfu.config"
