Other Parts Discussed in Thread: SK-AM62A-LP, , AM62P
We are encountering kernel panic issues during operation on some of our custom boards based on the TI AM62A7, and would appreciate any guidance or insights from TI experts.
We have attached both the kernel panic log and the boot log for your reference.
Experiment Setup:
- Custom board based on TI AM62A7
- Both A53 and C7x cores are used
- PROCESSOR-SDK-LINUX-AM62A 10.00.00.08
- Boot from eMMC
- eth0 and eth1 configured in multi-port switch mode and connected in a ring topology
- RSTP (Rapid Spanning Tree Protocol) enabled
- Custom application is Python-based and uses a multi-process architecture
- The application performs video processing and AI inference
- Inference results are sent to a PC server via MQTT in JSON format
Observed Behavior:
- On certain boards, a kernel panic occurs within 30 minutes to a few hours after boot
- When this happens, the board becomes completely unresponsive: no SSH access, no ping reply
- RSTP appears to stop functioning, followed by broadcast storm symptoms on the Ethernet
- The issue tends to reproduce more quickly when the board is enclosed in a case, and more slowly when it is open
- During normal operation, MPU internal temperature stays around 55–60°C
We would greatly appreciate any suggestions, debugging hints, or directions to further investigate and resolve this issue.
Thank you very much in advance.
root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# [ 722.327911] BUG: Bad rss-counter state mm:0000000097bc3f56 type:MM_FILEPAGES val:1 [ 722.335557] BUG: Bad rss-counter state mm:0000000097bc3f56 type:MM_ANONPAGES val:-1 [ 860.269450] audit: type=1701 audit(1709360784.484:71): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1595 comm="python3" exe="/usr/bin/python3.12" sig=11 res=1 [ 863.864476] audit: type=1701 audit(1709360788.080:72): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1549 comm="python3" exe="/usr/bin/python3.12" sig=11 res=1 [ 873.037854] audit: type=1701 audit(1709360797.244:73): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1674 comm="python3" exe="/usr/bin/python3.12" sig=11 res=1 [ 873.744261] audit: type=1701 audit(1709360797.956:74): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1543 comm="app_gst_to_shm" exe="/opt/s1hs-apps/app_gst_to_shm" sig=11 res=1 [ 1024.489374] Unable to handle kernel paging request at virtual address fffeffff80000000 [ 1024.497803] Mem abort info: [ 1024.504182] ESR = 0x0000000096000004 [ 1024.525685] EC = 0x25: DABT (current EL), IL = 32 bits [ 1024.532180] SET = 0, FnV = 0 [ 1024.536187] EA = 0, S1PTW = 0 [ 1024.539325] FSC = 0x04: level 0 translation fault [ 1024.544494] Data abort info: [ 1024.548037] ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000 [ 1024.554519] CM = 0, WnR = 0, TnD = 0, TagAccess = 0 [ 1024.564372] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 1024.570265] [fffeffff80000000] address between user and kernel address ranges [ 1024.577642] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP [ 1024.583899] Modules linked in: bridge stp llc overlay cfg80211 bluetooth ecdh_generic ecc rfkill rpmsg_ctrl rpmsg_char cdns_csi2rx st_lis2dw12_spi st_lis2dw12 kfifo_buf crct10dif_ce e5010_jpeg_enc v4l2_jpeg j721e_csi2rx wave5 videobuf2_dma_contig v4l2_mem2mem videobuf2_memops videobuf2_v4l2 emtcam v4l2_fwnode videobuf2_common rti_wdt v4l2_async rtc_ti_k3 k3_j72xx_bandgap spi_omap2_mcspi videodev ti_k3_r5_remoteproc mc ti_k3_dsp_remoteproc sa2ul mcrc64 cdns_dphy_rx lm75 cryptodev(O) fuse drm drm_panel_orientation_quirks backlight ipv6 [ 1024.631185] CPU: 0 PID: 42 Comm: khugepaged Tainted: G O 6.6.32-ti-01301-gdb8871293143-dirty #1 [ 1024.641255] Hardware name: Texas Instruments AM62A7 S1HS (DT) [ 1024.646987] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1024.653936] pc : copy_page+0x10/0xd0 [ 1024.657515] lr : copy_highpage+0x48/0x108 [ 1024.661516] sp : ffff800081863bc0 [ 1024.664819] x29: ffff800081863bc0 x28: ffff00080984e780 x27: ffff00087097b000 [ 1024.671944] x26: 0000ffff5912a000 x25: ffff0008022b1d20 x24: 0000ffbf58e00000 [ 1024.679068] x23: ffff800081863cc8 x22: ffff00000f92a000 x21: fffffbfffe000000 [ 1024.686192] x20: fffeffff80000000 x19: fffffc00003e4a80 x18: 08000008f097b003 [ 1024.693316] x17: 1616261512261112 x16: 2c11112904051a02 x15: 0318090c22151120 [ 1024.700441] x14: 18121c1812271a17 x13: 381916371a182e16 x12: 142218132d181732 [ 1024.707565] x11: 1c1b2f1b1a2b1919 x10: 371313301514291c x9 : 1b2d1e1f3816132f [ 1024.714689] x8 : 1c223c18193c0a08 x7 : 1c04030904030f00 x6 : 0000000080000000 [ 1024.721813] x5 : 0001080001080000 x4 : fffffc0000000000 x3 : ffff00080984e780 [ 1024.728935] x2 : 0000040000000000 x1 : fffeffff80000000 x0 : ffff00000f92a000 [ 1024.736062] Call trace: [ 1024.738500] copy_page+0x10/0xd0 [ 1024.741726] copy_user_highpage+0x18/0x34 [ 1024.745729] hpage_collapse_scan_pmd+0xa08/0x10a4 [ 1024.750431] khugepaged+0x2d8/0x7cc [ 1024.753914] kthread+0x110/0x114 [ 1024.757135] ret_from_fork+0x10/0x20 [ 1024.760707] Code: d503245f d503201f d503201f d503201f (a9400c22) [ 1024.766787] ---[ end trace 0000000000000000 ]--- [ 1053.288207] audit: type=1701 audit(1709360977.500:75): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1757 comm="python3" exe="/usr/bin/python3.12" sig=11 res=1 [ 1114.156861] audit: type=1701 audit(1709361038.360:76): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1629 comm="python3" exe="/usr/bin/python3.12" sig=11 res=1 [ 1727.854900] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008 [ 1727.854961] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008 [ 1727.855458] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000014 [ 1727.855464] Mem abort info: [ 1727.855466] ESR = 0x0000000096000046 [ 1727.855469] EC = 0x25: DABT (current EL), IL = 32 bits [ 1727.855473] SET = 0, FnV = 0 [ 1727.855476] EA = 0, S1PTW = 0 [ 1727.855478] FSC = 0x06: level 2 translation fault [ 1727.855481] Data abort info: [ 1727.855483] ISV = 0, ISS = 0x00000046, ISS2 = 0x00000000 [ 1727.855486] CM = 0, WnR = 1, TnD = 0, TagAccess = 0 [ 1727.855489] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 1727.855493] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008898a6000 [ 1727.855498] [0000000000000014] pgd=0800000897197003, p4d=0800000897197003, pud=0800000889df3003, pmd=0000000000000000 [ 1727.855512] Internal error: Oops: 0000000096000046 [#2] PREEMPT SMP [ 1727.855516] Modules linked in: bridge stp llc overlay cfg80211 bluetooth ecdh_generic ecc rfkill rpmsg_ctrl rpmsg_char cdns_csi2rx st_lis2dw12_spi st_lis2dw12 kfifo_buf crct10dif_ce e5010_jpeg_enc v4l2_jpeg j721e_csi2rx wave5 videobuf2_dma_contig v4l2_mem2mem videobuf2_memops videobuf2_v4l2 emtcam v4l2_fwnode videobuf2_common rti_wdt v4l2_async rtc_ti_k3 k3_j72xx_bandgap spi_omap2_mcspi videodev ti_k3_r5_remoteproc mc ti_k3_dsp_remoteproc sa2ul mcrc64 cdns_dphy_rx lm75 cryptodev(O) fuse drm drm_panel_orientation_quirks backlight ipv6 [ 1727.855623] CPU: 3 PID: 3459 Comm: systemd-coredum Tainted: G D O 6.6.32-ti-01301-gdb8871293143-dirty #1 [ 1727.855631] Hardware name: Texas Instruments AM62A7 S1HS (DT) [ 1727.855634] pstate: 200000c5 (nzCv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1727.855641] pc : update_irq_load_avg+0x258/0x33c [ 1727.855657] lr : irq_enter_rcu+0x40/0x68 [ 1727.855664] sp : ffff8000875eb970 [ 1727.855666] x29: ffff8000875eb970 x28: ffff000812fe0e40 x27: ffff8000875ebcc8 [ 1727.855675] x26: 0000000000000001 x25: ffff000805afe400 x24: 0000000000000000 [ 1727.855684] x23: 0000000020000005 x22: ffff8000801bbb58 x21: ffff8000875ebb00 [ 1727.855693] x20: ffff8000800100c8 x19: ffff8000875eb9b0 x18: 0000000000000000 [ 1727.855702] x17: ffff8007fe7ab000 x16: ffff800081450000 x15: 02ced253f3edb16c [ 1727.855711] x14: 0000b56a0d2db44e x13: 0000000000000119 x12: 0000000000000002 [ 1727.855719] x11: fffffffffbc9a800 x10: 0000000000000400 x9 : 000001c57c4b5ac1 [ 1727.855728] x8 : ffff8000875ebb78 x7 : ffff00080061a6c8 x6 : ffff8000875ebb00 [ 1727.855736] x5 : fffffc002011bd34 x4 : 0000000000000000 x3 : 000000000000000c [ 1727.855744] x2 : 0000000000400000 x1 : 0000000000010000 x0 : ffff000812fe0e40 [ 1727.855753] Call trace: [ 1727.855756] update_irq_load_avg+0x258/0x33c [ 1727.855765] el1_interrupt+0x28/0x68 [ 1727.855772] el1h_64_irq_handler+0x18/0x24 [ 1727.855778] el1h_64_irq+0x64/0x68 [ 1727.855783] filemap_get_entry+0x130/0x1a0 [ 1727.855790] __filemap_get_folio+0x4c/0x398 [ 1727.855796] filemap_fault+0x110/0xa24 [ 1727.855801] __do_fault+0x3c/0x230 [ 1727.855807] __handle_mm_fault+0x3e8/0xc8c [ 1727.855812] handle_mm_fault+0x68/0x280 [ 1727.855817] do_page_fault+0x1ac/0x490 [ 1727.855824] do_translation_fault+0x9c/0xa8 [ 1727.855829] do_mem_abort+0x44/0x94 [ 1727.855834] el0_da+0x30/0x88 [ 1727.855839] el0t_64_sync_handler+0xb4/0x12c [ 1727.855845] el0t_64_sync+0x190/0x194 [ 1727.855854] Code: 93c880e7 9bc67c08 93c18084 9b067c01 (a9009067) [ 1727.855859] ---[ end trace 0000000000000000 ]--- [ 1727.855863] Kernel panic - not syncing: Oops: Fatal exception in interrupt [ 1727.855866] SMP: stopping secondary CPUs [ 1727.855871] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000015 [ 1727.855875] Mem abort info: [ 1727.855877] ESR = 0x0000000096000046 [ 1727.855879] EC = 0x25: DABT (current EL), IL = 32 bits [ 1727.855882] SET = 0, FnV = 0 [ 1727.855884] EA = 0, S1PTW = 0 [ 1727.855886] FSC = 0x06: level 2 translation fault [ 1727.855889] Data abort info: [ 1727.855890] ISV = 0, ISS = 0x00000046, ISS2 = 0x00000000 [ 1727.855892] CM = 0, WnR = 1, TnD = 0, TagAccess = 0 [ 1727.855895] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 1727.855898] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008898c5000 [ 1727.855902] [0000000000000015] pgd=08000008b6b9a003, p4d=08000008b6b9a003, pud=08000008800b8003, pmd=0000000000000000 [ 1727.863685] Mem abort info: [ 1727.863687] ESR = 0x0000000096000046 [ 1727.863689] EC = 0x25: DABT (current EL), IL = 32 bits [ 1727.863692] SET = 0, FnV = 0 [ 1727.863694] EA = 0, S1PTW = 0 [ 1727.863696] FSC = 0x06: level 2 translation fault [ 1727.863699] Data abort info: [ 1727.863700] ISV = 0, ISS = 0x00000046, ISS2 = 0x00000000 [ 1727.863703] CM = 0, WnR = 1, TnD = 0, TagAccess = 0 [ 1727.863706] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0 [ 1727.863709] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008f0be5000 [ 1727.863712] [0000000000000008] pgd=08000008f1f20003, p4d=08000008f1f20003, pud=08000008f3410003, pmd=0000000000000000 [ 1728.923676] SMP: failed to stop secondary CPUs 0-3 [ 1729.374454] Kernel Offset: disabled [ 1729.377929] CPU features: 0x0,00000008,00020000,1000420b [ 1729.383226] Memory Limit: none [ 1729.386271] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# root@am62axx-s1hs:/opt/edgeai-gst-apps# dmesg [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.6.32-ti-01301-gdb8871293143-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240620) #1 SMP PREEMPT Thu Aug 1 19:10:56 UTC 2024 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments AM62A7 S1HS [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000e3ffffff (589824 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x0000000099900000..0x000000009b7fffff (31744 KiB) nomap non-reusable c7x-memory@99900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000 [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a0ffffff (16384 KiB) nomap non-reusable edgeai-rtos-ipc-memory-region [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB [ 0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a2ffffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a1000000 [ 0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout [ 0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000adffffff (180224 KiB) map non-reusable edgeai_shared-memories [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ae000000, size 288 MiB [ 0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@ae000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000ae000000..0x00000000bfffffff (294912 KiB) nomap non-reusable edgeai-core-heap-memory@ae000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x00000000997fffff] [ 0.000000] node 0: [mem 0x0000000099800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a2ffffff] [ 0.000000] node 0: [mem 0x00000000a3000000-0x00000000adffffff] [ 0.000000] node 0: [mem 0x00000000ae000000-0x00000000bfffffff] [ 0.000000] node 0: [mem 0x00000000c0000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] percpu: Embedded 20 pages/cpu s43112 r8192 d30616 u81920 [ 0.000000] pcpu-alloc: s43112 r8192 d30616 u81920 alloc=20*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=a90d02f3-01 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] Memory: 2807496K/4194304K available (12224K kernel code, 1268K rwdata, 4092K rodata, 2432K init, 508K bss, 796984K reserved, 589824K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880040000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008528] Console: colour dummy device 80x25 [ 0.013120] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023802] pid_max: default: 32768 minimum: 301 [ 0.028601] LSM: initializing lsm=capability,integrity [ 0.033950] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.041529] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.051134] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.058435] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1. [ 0.066345] rcu: Hierarchical SRCU implementation. [ 0.071250] rcu: Max phase no-delay instances is 1000. [ 0.076829] Platform MSI: msi-controller@1820000 domain created [ 0.083078] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.092490] EFI services will not be available. [ 0.097358] smp: Bringing up secondary CPUs ... [ 0.102574] Detected VIPT I-cache on CPU1 [ 0.102639] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.102655] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000 [ 0.102701] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.103349] Detected VIPT I-cache on CPU2 [ 0.103399] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.103412] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000 [ 0.103442] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.104025] Detected VIPT I-cache on CPU3 [ 0.104071] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.104085] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000 [ 0.104114] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.104188] smp: Brought up 1 node, 4 CPUs [ 0.183910] SMP: Total of 4 processors activated. [ 0.188723] CPU features: detected: 32-bit EL0 Support [ 0.193994] CPU features: detected: CRC32 instructions [ 0.199305] CPU: All CPU(s) started at EL2 [ 0.203504] alternatives: applying system-wide alternatives [ 0.210714] devtmpfs: initialized [ 0.222570] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.232566] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.253191] pinctrl core: initialized pinctrl subsystem [ 0.259006] DMI not present or invalid. [ 0.263512] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.270310] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.277652] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.285728] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.293883] audit: initializing netlink subsys (disabled) [ 0.299575] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1 [ 0.299975] thermal_sys: Registered thermal governor 'step_wise' [ 0.307504] thermal_sys: Registered thermal governor 'power_allocator' [ 0.313690] cpuidle: using governor menu [ 0.324528] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.331544] ASID allocator initialised with 65536 entries [ 0.349474] platform a40000.pinctrl: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts [ 0.362741] Modules: 27584 pages in range for non-PLT usage [ 0.362754] Modules: 519104 pages in range for PLT usage [ 0.369133] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.381530] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.387941] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.394881] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.401288] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.408228] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.414635] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.421574] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.429267] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected [ 0.438598] iommu: Default domain type: Translated [ 0.443528] iommu: DMA domain TLB invalidation policy: strict mode [ 0.450105] SCSI subsystem initialized [ 0.454060] libata version 3.00 loaded. [ 0.454219] usbcore: registered new interface driver usbfs [ 0.459860] usbcore: registered new interface driver hub [ 0.465323] usbcore: registered new device driver usb [ 0.470949] pps_core: LinuxPPS API ver. 1 registered [ 0.476029] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.485378] PTP clock support registered [ 0.489548] EDAC MC: Ver: 3.0.0 [ 0.493215] scmi_core: SCMI protocol bus registered [ 0.498474] FPGA manager framework [ 0.502031] Advanced Linux Sound Architecture Driver Initialized. [ 0.509132] vgaarb: loaded [ 0.512195] clocksource: Switched to clocksource arch_sys_counter [ 0.518652] VFS: Disk quotas dquot_6.6.0 [ 0.522700] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.535954] Carveout Heap: Exported 176 MiB at 0x00000000a3000000 [ 0.542294] NET: Registered PF_INET protocol family [ 0.547463] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.557890] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.566691] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.574627] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.582934] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear) [ 0.591302] TCP: Hash tables configured (established 32768 bind 32768) [ 0.598159] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.605112] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.612624] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.618828] RPC: Registered named UNIX socket transport module. [ 0.624903] RPC: Registered udp transport module. [ 0.629713] RPC: Registered tcp transport module. [ 0.634521] RPC: Registered tcp-with-tls transport module. [ 0.640129] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.646721] NET: Registered PF_XDP protocol family [ 0.651634] PCI: CLS 0 bytes, default 64 [ 0.656959] Initialise system trusted keyrings [ 0.661740] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.668633] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.674848] NFS: Registering the id_resolver key type [ 0.680048] Key type id_resolver registered [ 0.684328] Key type id_legacy registered [ 0.688443] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.695298] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.736537] Key type asymmetric registered [ 0.740729] Asymmetric key parser 'x509' registered [ 0.745758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.753451] io scheduler mq-deadline registered [ 0.758090] io scheduler kyber registered [ 0.762214] io scheduler bfq registered [ 0.769286] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.775838] pinctrl-single f4000.pinctrl: 151 pins, size 604 [ 0.783373] pinctrl-single a40000.pinctrl: 512 pins, size 2048 [ 0.795600] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled [ 0.812318] loop: module loaded [ 0.816541] megasas: 07.725.01.00-rc1 [ 0.823904] tun: Universal TUN/TAP device driver, 1.6 [ 0.829351] CAN device driver interface [ 0.834196] VFIO - User Level meta-driver version: 0.3 [ 0.840635] usbcore: registered new interface driver usb-storage [ 0.847343] i2c_dev: i2c /dev entries driver [ 0.853287] sdhci: Secure Digital Host Controller Interface driver [ 0.859626] sdhci: Copyright(c) Pierre Ossman [ 0.864329] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.870905] ledtrig-cpu: registered to indicate activity on CPUs [ 0.877363] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.884651] usbcore: registered new interface driver usbhid [ 0.890354] usbhid: USB HID core driver [ 0.894592] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 0.901419] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 0.908221] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100 [ 0.914964] omap-mailbox 29030000.mailbox: no available mbox devices found [ 0.923289] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.932356] optee: probing for conduit method. [ 0.936923] optee: revision 4.2 (12d7c4ee) [ 0.937205] optee: dynamic shared memory is enabled [ 0.947081] random: crng init done [ 0.950660] optee: initialized driver [ 0.955841] Initializing XFRM netlink socket [ 0.960255] NET: Registered PF_PACKET protocol family [ 0.965425] can: controller area network core [ 0.969920] NET: Registered PF_CAN protocol family [ 0.974824] can: raw protocol [ 0.977860] can: broadcast manager protocol [ 0.982139] can: netlink gateway - max_hops=1 [ 0.986675] Key type dns_resolver registered [ 0.998525] registered taskstats version 1 [ 1.002858] Loading compiled-in X.509 certificates [ 1.020385] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)') [ 1.071843] i2c 0-0048: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5 [ 1.081686] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.088590] i2c 1-005c: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30102000/csi-bridge@30101000 [ 1.098374] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.105162] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.111214] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.119543] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.128765] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.137747] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.147307] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.155904] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.166885] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.177772] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.187233] ti-udma 4e230000.dma-controller: Number of rings: 6 [ 1.193824] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6) [ 1.203219] printk: console [ttyS2] disabled [ 1.207910] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 253, base_baud = 3000000) is a 8250 [ 1.216789] printk: console [ttyS2] enabled [ 1.225279] printk: bootconsole [ns16550a0] disabled [ 1.237496] 2820000.serial: ttyS8 at MMIO 0x2820000 (irq = 255, base_baud = 3000000) is a 8250 [ 1.247281] 2840000.serial: ttyS4 at MMIO 0x2840000 (irq = 256, base_baud = 3000000) is a 8250 [ 1.257058] 2850000.serial: ttyS5 at MMIO 0x2850000 (irq = 257, base_baud = 3000000) is a 8250 [ 1.266798] 2860000.serial: ttyS6 at MMIO 0x2860000 (irq = 258, base_baud = 3000000) is a 8250 [ 1.316206] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.331238] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83826NC [ 1.339516] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83826NC [ 1.347810] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.360707] am65-cpsw-nuss 8000000.ethernet: Use random MAC address [ 1.366980] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.374108] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512 [ 1.380483] pps pps0: new PPS source ptp0 [ 1.384742] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.398435] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.412526] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.418046] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.425876] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.431878] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010 [ 1.441308] xhci-hcd xhci-hcd.0.auto: irq 272, io mem 0x31100000 [ 1.447974] hub 1-0:1.0: USB hub found [ 1.451756] hub 1-0:1.0: 1 port detected [ 1.457124] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz [ 1.469510] mmc0: CQHCI version 5.10 [ 1.512221] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.565303] mmc0: Command Queue Engine enabled [ 1.569773] mmc0: new HS200 MMC card at address 0001 [ 1.575239] mmcblk0: mmc0:0001 MMC32G 29.1 GiB [ 1.588308] mmcblk0: p1 [ 1.591267] mmcblk0boot0: mmc0:0001 MMC32G 4.00 MiB [ 1.596989] mmcblk0boot1: mmc0:0001 MMC32G 4.00 MiB [ 1.602605] mmcblk0rpmb: mmc0:0001 MMC32G 4.00 MiB, chardev (239:0) [ 1.751694] tps6594-rtc tps6594-rtc.5.auto: registered as rtc0 [ 1.757685] tps6594-rtc tps6594-rtc.5.auto: hctosys: unable to read the hardware clock [ 1.767324] m_can_platform 4e18000.can: m_can device registered (irq=0, version=32) [ 1.776110] m_can_platform 20701000.can: m_can device registered (irq=542, version=32) [ 1.786484] mmc1: CQHCI version 5.10 [ 3.307209] sdhci-am654 fa00000.mmc: Power on failed [ 3.342785] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.352133] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 3.359473] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present! [ 3.367817] clk: Disabling unused clocks [ 3.376802] ALSA device list: [ 3.379762] No soundcards found. [ 4.679819] EXT4-fs (mmcblk0p1): recovery complete [ 4.685800] EXT4-fs (mmcblk0p1): mounted filesystem 1e59ee0a-6a3b-45f9-9bad-00ec1aa74d08 r/w with ordered data mode. Quota mode: none. [ 4.697946] VFS: Mounted root (ext4 filesystem) on device 179:1. [ 4.705194] devtmpfs: mounted [ 4.708786] Freeing unused kernel memory: 2432K [ 4.713359] Run /sbin/init as init process [ 4.717450] with arguments: [ 4.717453] /sbin/init [ 4.717456] with environment: [ 4.717458] HOME=/ [ 4.717461] TERM=linux [ 4.824707] systemd[1]: System time before build time, advancing clock. [ 4.853076] NET: Registered PF_INET6 protocol family [ 4.858894] Segment Routing with IPv6 [ 4.862591] In-situ OAM (IOAM) with IPv6 [ 4.887350] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 4.919249] systemd[1]: Detected architecture arm64. [ 4.938271] systemd[1]: Hostname set to <am62axx-s1hs>. [ 5.027880] systemd-sysv-generator[105]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. ! [ 5.238643] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 5.360482] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 5.439140] systemd[1]: Queued start job for default target Graphical Interface. [ 5.473343] systemd[1]: Created slice Slice /system/getty. [ 5.498364] systemd[1]: Created slice Slice /system/modprobe. [ 5.522313] systemd[1]: Created slice Slice /system/serial-getty. [ 5.545782] systemd[1]: Created slice User and Session Slice. [ 5.568609] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 5.592515] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 5.616371] systemd[1]: Expecting device /dev/ttyS2... [ 5.632409] systemd[1]: Reached target Path Units. [ 5.648324] systemd[1]: Reached target Remote File Systems. [ 5.668309] systemd[1]: Reached target Slice Units. [ 5.684321] systemd[1]: Reached target Swaps. [ 5.735743] systemd[1]: Listening on RPCbind Server Activation Socket. [ 5.756509] systemd[1]: Reached target RPC Port Mapper. [ 5.787240] systemd[1]: Listening on Process Core Dump Socket. [ 5.808682] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 5.833294] systemd[1]: Listening on Journal Audit Socket. [ 5.856851] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.880902] systemd[1]: Listening on Journal Socket. [ 5.901060] systemd[1]: Listening on Network Service Netlink Socket. [ 5.925990] systemd[1]: Listening on udev Control Socket. [ 5.948814] systemd[1]: Listening on udev Kernel Socket. [ 5.968845] systemd[1]: Listening on User Database Manager Socket. [ 6.024488] systemd[1]: Mounting Huge Pages File System... [ 6.043953] systemd[1]: Mounting POSIX Message Queue File System... [ 6.068148] systemd[1]: Mounting Kernel Debug File System... [ 6.084750] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 6.102432] systemd[1]: Mounting Temporary Directory /tmp... [ 6.125431] systemd[1]: Starting Create List of Static Device Nodes... [ 6.152376] systemd[1]: Starting Load Kernel Module configfs... [ 6.172350] systemd[1]: Starting Load Kernel Module drm... [ 6.192454] systemd[1]: Starting Load Kernel Module fuse... [ 6.217462] systemd[1]: Starting Start psplash boot splash screen... [ 6.227546] fuse: init (API version 7.39) [ 6.283749] systemd[1]: Starting RPC Bind... [ 6.308644] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 6.328670] systemd[1]: Starting Journal Service... [ 6.354542] systemd[1]: Starting Load Kernel Modules... [ 6.385004] systemd[1]: Starting Generate network units from Kernel command line... [ 6.409835] cryptodev: loading out-of-tree module taints kernel. [ 6.414238] systemd-journald[122]: Collecting audit messages is enabled. [ 6.423325] systemd[1]: Starting Remount Root and Kernel File Systems... [ 6.427278] cryptodev: driver 1.13 loaded. [ 6.438981] systemd[1]: Starting Coldplug All udev Devices... [ 6.475635] systemd[1]: Started RPC Bind. [ 6.492127] systemd[1]: Started Journal Service. [ 6.500719] EXT4-fs (mmcblk0p1): re-mounted 1e59ee0a-6a3b-45f9-9bad-00ec1aa74d08 r/w. Quota mode: none. [ 6.914584] systemd-journald[122]: Received client request to flush runtime journal. [ 7.214645] audit: type=1334 audit(1709054766.384:2): prog-id=6 op=LOAD [ 7.221422] audit: type=1334 audit(1709054766.392:3): prog-id=7 op=LOAD [ 7.479830] audit: type=1334 audit(1709054766.648:4): prog-id=8 op=LOAD [ 7.545143] audit: type=1334 audit(1709054766.716:5): prog-id=9 op=LOAD [ 7.638177] m_can_platform 20701000.can main_mcan0: renamed from can1 [ 7.708372] m_can_platform 4e18000.can mcu_mcan1: renamed from can0 [ 7.741100] audit: type=1334 audit(1709054766.912:6): prog-id=10 op=LOAD [ 7.751008] audit: type=1334 audit(1709054766.916:7): prog-id=11 op=LOAD [ 7.761197] audit: type=1334 audit(1709054766.916:8): prog-id=12 op=LOAD [ 8.243840] mc: Linux media interface: v0.10 [ 8.259978] videodev: Linux video capture interface: v2.00 [ 8.275920] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000 [ 8.285300] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode [ 8.292316] k3-dsp-rproc 7e000000.dsp: local reset is deasserted for device [ 8.303074] remoteproc remoteproc0: 7e000000.dsp is available [ 8.361397] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found [ 8.373211] vdec 30210000.video-codec: failed to get irq resource, falling back to polling [ 8.381466] hwmon hwmon0: temp1_input not attached to any thermal zone [ 8.394392] lm75 2-0048: hwmon0: sensor 'tmp112' [ 8.401676] platform 79000000.r5f: configured R5F for remoteproc mode [ 8.404369] remoteproc remoteproc0: powering up 7e000000.dsp [ 8.421509] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 11604048 [ 8.421620] emtcam 1-005c: supply DOVDD not found, using dummy regulator [ 8.424259] rtc-ti-k3 2b1f0000.rtc: registered as rtc1 [ 8.435650] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE' [ 8.452586] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000 [ 8.459602] emtcam 1-005c: supply AVDD not found, using dummy regulator [ 8.461109] vdec 30210000.video-codec: Product Code: 0x521c [ 8.473297] remoteproc remoteproc1: 79000000.r5f is available [ 8.474053] k3-dsp-rproc 7e000000.dsp: booting DSP core using boot addr = 0x99a00000 [ 8.488890] vdec 30210000.video-codec: Firmware Revision: 320127 [ 8.498571] emtcam 1-005c: supply DVDD not found, using dummy regulator [ 8.499412] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node c7x-dma-memory@99800000 [ 8.516882] virtio_rpmsg_bus virtio0: rpmsg host is online [ 8.522571] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 8.522609] remoteproc remoteproc1: powering up 79000000.r5f [ 8.530132] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.535421] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 53172 [ 8.547264] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7) [ 8.561839] remoteproc remoteproc0: remote processor 7e000000.dsp is now up [ 8.575846] platform 78000000.r5f: configured R5F for IPC-only mode [ 8.585598] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000 [ 8.585616] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9b800000 [ 8.596092] remoteproc remoteproc2: 78000000.r5f is available [ 8.609518] remoteproc remoteproc2: attaching to 78000000.r5f [ 8.614319] e5010 fd20000.jpeg-encoder: Device registered as /dev/video2 [ 8.622289] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.622563] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd [ 8.627990] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7) [ 8.633188] platform 78000000.r5f: R5F core initialized in IPC-only mode [ 8.633217] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node r5f-dma-memory@9c800000 [ 8.633765] virtio_rpmsg_bus virtio2: rpmsg host is online [ 8.633802] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7) [ 8.633808] remoteproc remoteproc2: remote processor 78000000.r5f is now attached [ 8.641218] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe [ 8.647717] remoteproc remoteproc1: remote processor 79000000.r5f is now up [ 8.699989] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd [ 8.707273] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15 [ 8.718711] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 8.726559] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe [ 8.734267] virtio_rpmsg_bus virtio2: msg received with no recipient [ 8.779794] audit: type=1334 audit(1709369192.080:9): prog-id=13 op=LOAD [ 8.796091] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 8.803955] virtio_rpmsg_bus virtio0: msg received with no recipient [ 8.957291] cdns-csi2rx 30101000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 8.981201] dbus-broker-lau[349]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set [ 9.360289] audit: type=1334 audit(1709369192.660:10): prog-id=14 op=LOAD [ 9.367418] audit: type=1334 audit(1709369192.660:11): prog-id=15 op=LOAD [ 9.527253] Bluetooth: Core ver 2.22 [ 9.531741] NET: Registered PF_BLUETOOTH protocol family [ 9.537791] Bluetooth: HCI device and connection manager initialized [ 9.549821] Bluetooth: HCI socket layer initialized [ 9.557792] Bluetooth: L2CAP socket layer initialized [ 9.563014] Bluetooth: SCO socket layer initialized [ 9.807012] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 9.827919] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 9.834429] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 9.907859] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83826NC] (irq=POLL) [ 9.917510] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode [ 9.943931] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83826NC] (irq=POLL) [ 9.953839] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rmii link mode [ 12.029031] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off [ 12.527652] kauditd_printk_skb: 15 callbacks suppressed [ 12.527666] audit: type=1701 audit(1709369195.828:23): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=753 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1 [ 12.607137] audit: type=1334 audit(1709369195.908:24): prog-id=21 op=LOAD [ 12.614002] audit: type=1334 audit(1709369195.916:25): prog-id=22 op=LOAD [ 12.620835] audit: type=1334 audit(1709369195.924:26): prog-id=23 op=LOAD [ 12.988997] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 13.288411] audit: type=1334 audit(1709369196.592:27): prog-id=23 op=UNLOAD [ 13.295513] audit: type=1334 audit(1709369196.592:28): prog-id=22 op=UNLOAD [ 13.302558] audit: type=1334 audit(1709369196.592:29): prog-id=21 op=UNLOAD [ 13.440394] audit: type=1701 audit(1709369196.744:30): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=1157 comm="kmsprint" exe="/usr/bin/kmsprint" sig=6 res=1 [ 13.464517] audit: type=1334 audit(1709369196.768:31): prog-id=24 op=LOAD [ 13.471382] audit: type=1334 audit(1709369196.772:32): prog-id=25 op=LOAD [ 14.013026] am65-cpsw-nuss 8000000.ethernet eth0: Link is Down [ 15.601239] am65-cpsw-nuss 8000000.ethernet eth1: Link is Down [ 16.643981] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. [ 16.731378] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83826NC] (irq=POLL) [ 16.740946] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rmii link mode [ 16.764848] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83826NC] (irq=POLL) [ 16.774354] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rmii link mode [ 16.791561] br0: port 1(eth0) entered blocking state [ 16.796595] br0: port 1(eth0) entered disabled state [ 16.801620] am65-cpsw-nuss 8000000.ethernet eth0: entered allmulticast mode [ 16.810378] am65-cpsw-nuss 8000000.ethernet eth0: entered promiscuous mode [ 16.823369] br0: port 2(eth1) entered blocking state [ 16.828503] br0: port 2(eth1) entered disabled state [ 16.833566] am65-cpsw-nuss 8000000.ethernet eth1: entered allmulticast mode [ 16.842343] am65-cpsw-nuss 8000000.ethernet eth1: entered promiscuous mode [ 18.780900] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 18.789885] br0: port 1(eth0) entered blocking state [ 18.812934] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off [ 18.821764] br0: port 2(eth1) entered blocking state [ 19.114478] br0: port 1(eth0) entered learning state [ 19.119730] br0: port 1(eth0) entered forwarding state [ 19.986820] br0: port 1(eth0) entered blocking state [ 19.992957] br0: port 2(eth1) entered learning state [ 19.998234] br0: port 2(eth1) entered forwarding state [ 20.004872] br0: port 1(eth0) entered learning state [ 20.010128] br0: port 1(eth0) entered forwarding state [ 21.582314] kauditd_printk_skb: 10 callbacks suppressed [ 21.582326] audit: type=1334 audit(1709369204.884:39): prog-id=27 op=LOAD [ 21.594396] audit: type=1334 audit(1709369204.892:40): prog-id=28 op=LOAD [ 21.601272] audit: type=1334 audit(1709369204.896:41): prog-id=29 op=LOAD [ 34.267992] audit: type=1006 audit(1709369217.568:42): pid=1292 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=3 res=1 [ 34.280635] audit: type=1300 audit(1709369217.568:42): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffffb16cc08 a2=1 a3=1 items=0 ppid=1 pid=1292 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" key=(null) [ 34.307309] audit: type=1327 audit(1709369217.568:42): proctitle="(systemd)" [ 34.314446] audit: type=1334 audit(1709369217.612:43): prog-id=30 op=LOAD [ 34.321260] audit: type=1300 audit(1709369217.612:43): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffdc28beb8 a2=90 a3=0 items=0 ppid=1 pid=1292 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null) [ 34.347078] audit: type=1327 audit(1709369217.612:43): proctitle="(systemd)" [ 34.354169] audit: type=1334 audit(1709369217.616:44): prog-id=30 op=UNLOAD [ 34.361167] audit: type=1300 audit(1709369217.616:44): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff86724c60 items=0 ppid=1 pid=1292 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null) [ 34.386840] audit: type=1327 audit(1709369217.616:44): proctitle="(systemd)" [ 34.393916] audit: type=1334 audit(1709369217.616:45): prog-id=31 op=LOAD
