PROCESSOR-SDK-J721E: J721e SDK yocto build fails with fetch error from git.ti.com
Part Number: PROCESSOR-SDK-J721E
We usually use the following instructions to build j721e SDK using yocto, as explained similar in here: https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/10_01_00_04/exports/docs/linux/Overview_Building_the_SDK.html
But since last week we've been having this issue on clean builds. Which seem to be related to a fetch error in the ti-vision apps recipe:
ERROR: ti-vision-apps-10.0.0-r0_edgeai_7 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/sources/oe-core/scripts:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot/usr/bin/crossscripts:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/sbin:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/bin:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/sbin:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/bin:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/sources/bitbake/bin:/home/tisdk/gateway-tda4vm_linux_rtos/fxn_gateway_tda4_bsp_sdk_10.0/psdkla/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/tisdk"; /usr/bin/env repo sync failed with exit code 1, output:
fatal: unable to connect to git.ti.com:
git.ti.com[0: 198.47.28.208]: errno=Connection refused
processor-sdk/app_utils:
processor-sdk/app_utils: sleeping 4.0 seconds before retrying
processor-sdk/ti-perception-toolkit:
processor-sdk/ti-perception-toolkit: sleeping 4.0 seconds before retrying
git.ti.com[0: 198.47.28.207]: errno=Connection refused
processor-sdk/tiovx:
processor-sdk/tiovx: sleeping 4.0 seconds before retrying
processor-sdk/concerto:
processor-sdk/concerto: sleeping 4.0 seconds before retrying
This is the config file we used with ./oe-layertool-setup.sh:
$ cat processor-sdk-analytics-10_00-config.txt
# This file takes repo entries in the format
# repo name,repo uri,repo branch,repo commit[,layers=layer1:layer2...:layern]
bitbake,git.openembedded.org/bitbake,2.8,11d83170922a2c6b9db1f6e8c23e533526984b2c
meta-arago,git.yoctoproject.org/meta-arago,scarthgap,cbf054c7401af6e1e8bcc4eab07daa9a4996f7f3,layers=meta-arago-distro:meta-arago-extras:meta-arago-demos:meta-arago-test
meta-qt5,github.com/.../meta-qt5.git,scarthgap,eb828418264a49b8d00035cb3d7b12fcea3be801,layers=
meta-virtualization,git.yoctoproject.org/meta-virtualization,scarthgap,54b806b1985f3989722ee308e1073530fe3328c1,layers=
meta-openembedded,git.openembedded.org/meta-openembedded,scarthgap,80e01188fa822d87d301ee71973c462d7a865493,layers=meta-networking:meta-python:meta-oe:meta-gnome:meta-filesystems:meta-multimedia
meta-ti,git.yoctoproject.org/meta-ti,scarthgap,84328ead40d7e6fcce4d80ab7d07f4dcaf9d777e,layers=meta-ti-extras:meta-ti-bsp
meta-arm,git.yoctoproject.org/meta-arm,scarthgap,ecece16871afe6b674d2aafd27e0f18bbaef1966,layers=meta-arm:meta-arm-toolchain
oe-core,git.openembedded.org/openembedded-core,scarthgap,bf3fe8c01c5cc00ada22049f4f0abb485e2a626f,layers=meta
meta-tisdk,git.ti.com/.../meta-tisdk.git,scarthgap,af81e0d81c5efd005bfc0ef749f690f9748c70f6,layers=
meta-edgeai,git.ti.com/.../meta-edgeai.git,scarthgap,c9351accf9c3ec152ffde84507c674901b7f23f1,layers=
OECORELAYERCONF=./sample-files/bblayers.conf.sample
OECORELOCALCONF=./sample-files/local-arago64-v2.conf.sample
BITBAKE_INCLUSIVE_VARS=yes
