if AT11 and AR9 can be used as DM8168 VGA H/V SYNC pins
team
I notice that DM8168 PG2.0 will support VGA H/V SYNC pins.Following is the mapping for HS and VS pins: HS -- AR5/AT9/AR8; VS -- AL5/AP9/AL9.
My questions are below items
 1. if it means that only AR5/AT9/AR8 can be used as VGA HS.  but AT11 and AR9 can not be used as VGA HS though AT11 and AR9 can pinmux as vout[0]_hsync?
2. if it has time delay between HS, VS pins and RGB signal. are their same module or different module?
