Hello CCS expert,
1) Is it possible to build with your CCS compiler from the command line on Linux Containers?
Specifically, I assumed to run a build on a Linux container in Pipeline using Jenkins and acquire build results.
For reference, there are compilers made by IAR Systems that can be used on Linux containers.
The following URL describes how to build using IAR Systems compilers on Linux containers.
2) If above is possible, will the build results (FW binary files, map files, etc.) in Linux containers be exactly the same as if built in Windows version CCSTUDIO?
A.Fujinaka
