We are running the TI ESC on the AM5718. We are trying to generate an alert signal when the sync0 interrupt is out of sync with the reference clock. We have a partially working solution based on the System Time Difference Register with window monitoring enabled on the master. The remaining problem is when data transmission stops or a cable is unplugged, the sync0 interrupt continues triggering, but is no longer actively synced to the reference clock. Is there a method to check if the sync0 signal is being actively locked to the reference?
