Part Number: SK-AM62P-LP
HI TI :
I use the board customized by the company . start kernel fail, I don't know what causes that
Hit any key to stop autoboot: 0
=> sf probe; sf read ${loadaddr} 0x600000 0x140e200; sf read ${fdtaddr} 0x500000 0x1004f
SF: Detected s28hs512t with page size 256 Bytes, erase size 256 KiB, total 64 MiB
device 0 offset 0x600000, size 0x140e200
SF: 21029376 bytes @ 0x600000 Read: OK
device 0 offset 0x500000, size 0x1004f
SF: 65615 bytes @ 0x500000 Read: OK
=> sf read ${rdaddr} 0x1c00000 0x106aa00
device 0 offset 0x1c00000, size 0x106aa00
SF: 17213952 bytes @ 0x1c00000 Read: OK
=> setenv args_initramfs 'setenv bootargs console=${console} ${optargs}'
=> run args_all args_initramfs
=> booti ${loadaddr} ${rdaddr}:0x${filesize} ${fdtaddr}
Working FDT set to 88000000
Loading Ramdisk to 90000000, end 90000000 ... OK
Loading Device Tree to 000000008ffec000, end 000000008ffff019 ... OK
Working FDT set to 8ffec000
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.58 (zdc@zdc-virtual-machine) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #24 SMP PREEMPT Thu May 8 14:43:51 CST 2025
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Texas Instruments AM62P5 SK
[ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[ 0.000000] printk: bootconsole [ns16550a0] enabled
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
[ 0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[ 0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
[ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff]
[ 0.000000] node 0: [mem 0x0000000080080000-0x000000009b4fffff]
[ 0.000000] node 0: [mem 0x000000009b500000-0x000000009e6fffff]
[ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2064384
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Memory: 7474748K/8388608K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 324036K reserved, 589824K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 256 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x0000000880040000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880050000
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.008547] Console: colour dummy device 80x25
[ 0.013140] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[ 0.023814] pid_max: default: 32768 minimum: 301
[ 0.028613] LSM: initializing lsm=capability,selinux,integrity
[ 0.034596] SELinux: Initializing.
[ 0.038287] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.046048] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.055959] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.063262] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.071176] rcu: Hierarchical SRCU implementation.
[ 0.076077] rcu: Max phase no-delay instances is 1000.
[ 0.081671] Platform MSI: msi-controller@1820000 domain created
[ 0.087939] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.097379] EFI services will not be available.
[ 0.102258] smp: Bringing up secondary CPUs ...
[ 0.107493] Detected VIPT I-cache on CPU1
[ 0.107565] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[ 0.107582] GICv3: CPU1: using allocated LPI pending table @0x0000000880060000
[ 0.107626] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.108303] Detected VIPT I-cache on CPU2
[ 0.108363] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[ 0.108377] GICv3: CPU2: using allocated LPI pending table @0x0000000880070000
[ 0.108409] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.109006] Detected VIPT I-cache on CPU3
[ 0.109056] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[ 0.109068] GICv3: CPU3: using allocated LPI pending table @0x0000000880080000
[ 0.109098] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.109167] smp: Brought up 1 node, 4 CPUs
[ 0.188819] SMP: Total of 4 processors activated.
[ 0.193628] CPU features: detected: 32-bit EL0 Support
[ 0.198894] CPU features: detected: CRC32 instructions
[ 0.204202] CPU: All CPU(s) started at EL2
[ 0.208396] alternatives: applying system-wide alternatives
[ 0.215729] devtmpfs: initialized
[ 0.230360] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.240357] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.262032] pinctrl core: initialized pinctrl subsystem
[ 0.267874] DMI not present or invalid.
[ 0.272407] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.279344] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.286784] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.294897] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.303140] audit: initializing netlink subsys (disabled)
[ 0.308847] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1
[ 0.309301] thermal_sys: Registered thermal governor 'step_wise'
[ 0.316771] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.322951] cpuidle: using governor menu
[ 0.333769] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.340786] ASID allocator initialised with 65536 entries
[ 0.351697] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[ 0.363180] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[ 0.375825] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.385737] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[ 0.398447] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.413874] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[ 0.426651] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.437393] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[ 0.452042] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 0.461985] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.473314] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[ 0.482551] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 0.492099] Modules: 27488 pages in range for non-PLT usage
[ 0.492105] Modules: 519008 pages in range for PLT usage
[ 0.498513] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.510902] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.517306] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.524238] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.530639] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.537572] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.543973] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.550904] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.558663] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
[ 0.568015] iommu: Default domain type: Translated
[ 0.572933] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.579532] SCSI subsystem initialized
[ 0.583670] usbcore: registered new interface driver usbfs
[ 0.589308] usbcore: registered new interface driver hub
[ 0.594762] usbcore: registered new device driver usb
[ 0.600405] pps_core: LinuxPPS API ver. 1 registered
[ 0.605481] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.614821] PTP clock support registered
[ 0.619024] EDAC MC: Ver: 3.0.0
[ 0.622712] scmi_core: SCMI protocol bus registered
[ 0.627986] FPGA manager framework
[ 0.631548] Advanced Linux Sound Architecture Driver Initialized.
[ 0.638711] vgaarb: loaded
[ 0.641807] clocksource: Switched to clocksource arch_sys_counter
[ 0.648256] VFS: Disk quotas dquot_6.6.0
[ 0.652311] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.666208] NET: Registered PF_INET protocol family
[ 0.671489] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.684613] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.693454] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.701392] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.709900] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.719217] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.726083] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.733188] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.740876] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.747128] RPC: Registered named UNIX socket transport module.
[ 0.753204] RPC: Registered udp transport module.
[ 0.758010] RPC: Registered tcp transport module.
[ 0.762815] RPC: Registered tcp-with-tls transport module.
[ 0.768419] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.775004] NET: Registered PF_XDP protocol family
[ 0.779916] PCI: CLS 0 bytes, default 64
[ 0.785329] Initialise system trusted keyrings
[ 0.790099] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.797010] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.803243] NFS: Registering the id_resolver key type
[ 0.808440] Key type id_resolver registered
[ 0.812713] Key type id_legacy registered
[ 0.816825] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.823675] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.865283] Key type asymmetric registered
[ 0.869483] Asymmetric key parser 'x509' registered
[ 0.874515] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.882220] io scheduler mq-deadline registered
[ 0.886857] io scheduler kyber registered
[ 0.890981] io scheduler bfq registered
[ 0.898256] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[ 0.904848] pinctrl-single f4000.pinctrl: 171 pins, size 684
[ 0.917713] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[ 0.935413] loop: module loaded
[ 0.939694] megasas: 07.725.01.00-rc1
[ 0.947179] tun: Universal TUN/TAP device driver, 1.6
[ 0.953379] VFIO - User Level meta-driver version: 0.3
[ 0.959774] usbcore: registered new interface driver usb-storage
[ 0.966555] i2c_dev: i2c /dev entries driver
[ 0.972443] sdhci: Secure Digital Host Controller Interface driver
[ 0.978778] sdhci: Copyright(c) Pierre Ossman
[ 0.983460] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.990004] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.996444] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.003734] usbcore: registered new interface driver usbhid
[ 1.009434] usbhid: USB HID core driver
[ 1.014649] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.023654] optee: probing for conduit method.
[ 1.028235] optee: revision 4.4 (8f645256efc0dc66)
[ 1.028553] optee: dynamic shared memory is enabled
[ 1.038667] optee: initialized driver
[ 1.043930] Initializing XFRM netlink socket
[ 1.048367] NET: Registered PF_PACKET protocol family
[ 1.053631] Key type dns_resolver registered
[ 1.066421] registered taskstats version 1
[ 1.070778] Loading compiled-in X.509 certificates
[ 1.089520] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)')
[ 1.143210] /bus@f0000/bus@b00000/i2c@2b200000/pmic@48: Fixed dependency cycle(s) with /bus@f0000/bus@b00000/i2c@2b200000/pmic@48/regulators/buck3
[ 1.156876] omap_i2c 2b200000.i2c: bus 0 rev0.12 at 400 kHz
[ 1.164045] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[ 1.176820] omap_i2c 20000000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.183941] pca953x 2-0023: supply vcc not found, using dummy regulator
[ 1.190841] pca953x 2-0023: using AI
[ 1.217922] pca953x 2-0023: failed writing register
[ 1.223079] pca953x: probe of 2-0023 failed with error -121
[ 1.228966] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.238186] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[ 1.248109] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[ 1.257318] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[ 1.267366] omap_i2c 20010000.i2c: bus 2 rev0.12 at 100 kHz
[ 1.274228] omap_i2c 20020000.i2c: bus 3 rev0.12 at 400 kHz
[ 1.280166] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[ 1.288482] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[ 1.297718] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[ 1.306695] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[ 1.316247] ti-udma 485c0100.dma-controller: Number of rings: 82
[ 1.325022] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[ 1.336208] ti-udma 485c0000.dma-controller: Number of rings: 150
[ 1.347347] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[ 1.356935] ti-udma 4e230000.dma-controller: Number of rings: 6
[ 1.363560] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[ 1.373028] printk: console [ttyS2] disabled
[ 1.377737] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 251, base_baud = 3000000) is a 8250
[ 1.386636] printk: console [ttyS2] enabled
[ 1.395107] printk: bootconsole [ns16550a0] disabled
[ 1.408937] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[ 1.414012] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[ 1.420974] Creating 7 MTD partitions on "fc40000.spi.0":
[ 1.426368] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[ 1.433203] 0x000000080000-0x000000280000 : "ospi.tispl"
[ 1.439795] 0x000000280000-0x000000680000 : "ospi.u-boot"
[ 1.446434] 0x000000680000-0x0000006c0000 : "ospi.env"
[ 1.452741] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[ 1.459678] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[ 1.466311] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[ 1.473297] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration.
[ 1.521795] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[ 1.531636] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[ 1.539480] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[ 1.547356] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[ 1.560215] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[ 1.567344] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[ 1.573971] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[ 1.587705] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[ 22.601777] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 22.607876] rcu: 0-...0: (0 ticks this GP) idle=20dc/1/0x4000000000000000 softirq=284/284 fqs=2626
[ 22.616908] rcu: (detected by 3, t=5254 jiffies, g=-1031, q=38 ncpus=4)
[ 22.623593] Task dump for CPU 0:
[ 22.626810] task:kworker/u8:2 state:R running task stack:0 pid:46 ppid:2 flags:0x0000000a
[ 22.636711] Workqueue: events_unbound deferred_probe_work_func
[ 22.642543] Call trace:
[ 22.644979] __switch_to+0xcc/0x12c
[ 22.648465] 0xffff000801799280
[ 85.649775] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 85.655855] rcu: 0-...0: (0 ticks this GP) idle=20dc/1/0x4000000000000000 softirq=284/284 fqs=10504
[ 85.664973] rcu: (detected by 3, t=21016 jiffies, g=-1031, q=38 ncpus=4)
[ 85.671745] Task dump for CPU 0:
[ 85.674960] task:kworker/u8:2 state:R running task stack:0 pid:46 ppid:2 flags:0x0000000a
[ 85.684858] Workqueue: events_unbound deferred_probe_work_func
[ 85.690683] Call trace:
[ 85.693119] __switch_to+0xcc/0x12c
[ 85.696603] 0xffff000801799280
[ 148.697775] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 148.703854] rcu: 0-...0: (0 ticks this GP) idle=20dc/1/0x4000000000000000 softirq=284/284 fqs=18382
[ 148.712970] rcu: (detected by 3, t=36778 jiffies, g=-1031, q=38 ncpus=4)
[ 148.719742] Task dump for CPU 0:
[ 148.722958] task:kworker/u8:2 state:R running task stack:0 pid:46 ppid:2 flags:0x0000000a
[ 148.732855] Workqueue: events_unbound deferred_probe_work_func
[ 148.738681] Call trace:
[ 148.741116] __switch_to+0xcc/0x12c
[ 148.744598] 0xffff000801799280
[ 211.745775] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 211.751853] rcu: 0-...0: (0 ticks this GP) idle=20dc/1/0x4000000000000000 softirq=284/284 fqs=26260
[ 211.760971] rcu: (detected by 3, t=52540 jiffies, g=-1031, q=38 ncpus=4)
[ 211.767744] Task dump for CPU 0:
[ 211.770958] task:kworker/u8:2 state:R running task stack:0 pid:46 ppid:2 flags:0x0000000a
[ 211.780855] Workqueue: events_unbound deferred_probe_work_func
[ 211.786680] Call trace:
[ 211.789115] __switch_to+0xcc/0x12c
[ 211.792597] 0xffff000801799280
[ 274.793775] rcu: INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 274.799853] rcu: 0-...0: (0 ticks this GP) idle=20dc/1/0x4000000000000000 softirq=284/284 fqs=34138
[ 274.808971] rcu: (detected by 3, t=68302 jiffies, g=-1031, q=38 ncpus=4)
[ 274.815743] Task dump for CPU 0:
[ 274.818957] task:kworker/u8:2 state:R running task stack:0 pid:46 ppid:2 flags:0x0000000a
[ 274.828856] Workqueue: events_unbound deferred_probe_work_func
[ 274.834679] Call trace:
[ 274.837114] __switch_to+0xcc/0x12c
[ 274.840595] 0xffff000801799280
