PROCESSOR-SDK-AM57X: SDK 9.03: Default image dmesg output errors
Part Number: PROCESSOR-SDK-AM57X
Other Parts Discussed in Thread: BEAGLEBOARD-X15
Hello all,
I just booted the latest SDK release (SDK 9.03) for the AM57xx EVM. In the log attached below, I noticed some concerning error messages in the dmesg output. To make them easier to locate, I ran dmesg -l 3 at the end of the log. I assume your team is already aware of these messages and that they’re likely not an issue, but I wanted to check—should I be concerned about them?
U-Boot 2023.04-ti-g2bedcd265ca6 (Dec 07 2024 - 07:04:35 +0000)
CPU  : DRA752-GP ES2.0
Model: TI AM5728 BeagleBoard-X15 rev C
Board: BeagleBoard X15 REV C.00
DRAM:  2 GiB
ti_emmc_boardid_get failed -5
Core:  70 devices, 24 uclasses, devicetree: separate
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... *** Error - No Valid Environment Area found
*** Warning - bad env area, using default environment
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Net:   eth2: ethernet@48484000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
This will not be a case any time
7930368 bytes read in 370 ms (20.4 MiB/s)
216847 bytes read in 37 ms (5.6 MiB/s)
Working FDT set to 88000000
Kernel image @ 0x82000000 [ 0x000000 - 0x790200 ]
   Loading Device Tree to 8fec8000, end 8fffffff ... OK
Working FDT set to 8fec8000
ft_fixup_clocks failed for DSP voltage domain: <valid offset/length>
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.1.119-ti-ge4e8b16e66f5 (oe-user@oe-host) (arm-oe-linux-gnueabi-gcc (GCC) 11.5.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Sat Dec  7 07:14:10 UTC 2024
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: TI AM5728 BeagleBoard-X15 rev C
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000095800000, size 56 MiB
[    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009f000000, size 8 MiB
[    0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 64 MiB at 0x00000000fb800000
[    0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000afcfffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x00000000afd00000-0x00000000ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000956fffff]
[    0.000000]   node   0: [mem 0x0000000095700000-0x00000000957fffff]
[    0.000000]   node   0: [mem 0x0000000095800000-0x000000009cffffff]
[    0.000000]   node   0: [mem 0x000000009d000000-0x000000009effffff]
[    0.000000]   node   0: [mem 0x000000009f000000-0x00000000afcfffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] On node 0, zone HighMem: 768 pages in unavailable ranges
[    0.000000] DRA752 ES2.0
[    0.000000] clockdomain: ipu1_clkdm: powerdomain ipu_pwrdm does not exist
[    0.000000] clockdomain: ipu_clkdm: powerdomain ipu_pwrdm does not exist
[    0.000000] percpu: Embedded 16 pages/cpu s34324 r8192 d23020 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 521990
[    0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=49dc51d7-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000aab58000-0x00000000aeb58000] (64MB)
[    0.000000] Memory: 1759108K/2094080K available (12288K kernel code, 1466K rwdata, 3260K rodata, 2048K init, 305K bss, 138364K reserved, 196608K cma-reserved, 1245184K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000000] sched_clock: 32 bits at 33kHz, resolution 30517ns, wraps every 65535999984741ns
[    0.001434] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000
[    0.003143] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2c000
[    0.003326] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2e000
[    0.004455] Console: colour dummy device 80x30
[    0.004486] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[    0.062072] CPU: Testing write buffer coherency: ok
[    0.062103] CPU0: Spectre v2: using ICIALLU workaround
[    0.062103] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.062103] pid_max: default: 32768 minimum: 301
[    0.062255] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062255] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062896] /cpus/cpu@0 missing clock-frequency property
[    0.062927] /cpus/cpu@1 missing clock-frequency property
[    0.062927] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.063568] cblist_init_generic: Setting adjustable number of callback queues.
[    0.063598] cblist_init_generic: Setting shift to 1 and lim to 1.
[    0.063690] Setting up static identity map for 0x80200000 - 0x80200138
[    0.063781] rcu: Hierarchical SRCU implementation.
[    0.063781] rcu:     Max phase no-delay instances is 1000.
[    0.066101] EFI services will not be available.
[    0.066650] smp: Bringing up secondary CPUs ...
[    0.126861] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.126892] CPU1: Spectre v2: using ICIALLU workaround
[    0.126983] smp: Brought up 1 node, 2 CPUs
[    0.126983] SMP: Total of 2 processors activated (3994.41 BogoMIPS).
[    0.127014] CPU: All CPU(s) started in HYP mode.
[    0.127014] CPU: Virtualization extensions available.
[    0.127441] devtmpfs: initialized
[    0.152862] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.153045] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.153045] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.157531] pinctrl core: initialized pinctrl subsystem
[    0.158172] DMI not present or invalid.
[    0.158599] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.160308] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.161224] thermal_sys: Registered thermal governor 'step_wise'
[    0.161285] cpuidle: using governor menu
[    0.188232] platform ocp: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@e00/clock@20
[    0.188293] platform ocp: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@700/clock@20
[    0.191833] platform connector: Fixed dependency cycle(s) with /encoder
[    0.191925] platform encoder: Fixed dependency cycle(s) with /connector
[    0.191986] platform encoder: Fixed dependency cycle(s) with /ocp/target-module@58000000/dss@0/target-module@40000/encoder@0
[    0.192352] No ATAGs?
[    0.192413] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.192413] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.209594] iommu: Default domain type: Translated
[    0.209594] iommu: DMA domain TLB invalidation policy: strict mode
[    0.210937] SCSI subsystem initialized
[    0.211273] usbcore: registered new interface driver usbfs
[    0.211303] usbcore: registered new interface driver hub
[    0.211334] usbcore: registered new device driver usb
[    0.211730] pps_core: LinuxPPS API ver. 1 registered
[    0.211730] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.211761] PTP clock support registered
[    0.211883] EDAC MC: Ver: 3.0.0
[    0.213684] clocksource: Switched to clocksource 32k_counter
[    0.221496] NET: Registered PF_INET protocol family
[    0.221679] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.224273] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.224304] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.224304] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.224365] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.224609] TCP: Hash tables configured (established 8192 bind 8192)
[    0.224670] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.224700] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.224822] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.225219] RPC: Registered named UNIX socket transport module.
[    0.225219] RPC: Registered udp transport module.
[    0.225250] RPC: Registered tcp transport module.
[    0.225250] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.225250] PCI: CLS 0 bytes, default 64
[    0.225616] armv7-pmu pmu: hw perfevents: no interrupt-affinity property, guessing.
[    0.225769] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.226623] Initialise system trusted keyrings
[    0.226959] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[    0.232177] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.232757] NFS: Registering the id_resolver key type
[    0.232788] Key type id_resolver registered
[    0.232818] Key type id_legacy registered
[    0.232879] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.232910] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.232940] ntfs: driver 2.1.32 [Flags: R/O].
[    0.233398] Key type asymmetric registered
[    0.233398] Asymmetric key parser 'x509' registered
[    0.233520] bounce: pool size: 64 pages
[    0.233612] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.233642] io scheduler mq-deadline registered
[    0.233642] io scheduler kyber registered
[    0.236724] omap_prm: probe of 4ae06500.prm failed with error -22
[    0.282867] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[    0.284851] STMicroelectronics ASC driver initialized
[    0.293579] brd: module loaded
[    0.298217] loop: module loaded
[    0.302612] CAN device driver interface
[    0.302978] e1000e: Intel(R) PRO/1000 Network Driver
[    0.303009] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.303039] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.303039] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.303924] pegasus: Pegasus/Pegasus II USB Ethernet driver
[    0.303955] usbcore: registered new interface driver pegasus
[    0.303985] usbcore: registered new interface driver asix
[    0.304016] usbcore: registered new interface driver ax88179_178a
[    0.304046] usbcore: registered new interface driver cdc_ether
[    0.304077] usbcore: registered new interface driver smsc75xx
[    0.304138] usbcore: registered new interface driver smsc95xx
[    0.304138] usbcore: registered new interface driver net1080
[    0.304168] usbcore: registered new interface driver cdc_subset
[    0.304199] usbcore: registered new interface driver zaurus
[    0.304260] usbcore: registered new interface driver cdc_ncm
[    0.304962] usbcore: registered new interface driver usb-storage
[    0.305664] i2c_dev: i2c /dev entries driver
[    0.308044] sdhci: Secure Digital Host Controller Interface driver
[    0.308044] sdhci: Copyright(c) Pierre Ossman
[    0.308227] Synopsys Designware Multimedia Card Interface Driver
[    0.308441] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.309082] ledtrig-cpu: registered to indicate activity on CPUs
[    0.309387] usbcore: registered new interface driver usbhid
[    0.309387] usbhid: USB HID core driver
[    0.311950] NET: Registered PF_INET6 protocol family
[    0.312835] Segment Routing with IPv6
[    0.312896] In-situ OAM (IOAM) with IPv6
[    0.312957] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.313446] NET: Registered PF_PACKET protocol family
[    0.313446] can: controller area network core
[    0.313507] NET: Registered PF_CAN protocol family
[    0.313507] can: raw protocol
[    0.313507] can: broadcast manager protocol
[    0.313507] can: netlink gateway - max_hops=1
[    0.313659] Key type dns_resolver registered
[    0.313751] ThumbEE CPU extension supported.
[    0.313751] Registering SWP/SWPB emulation handler
[    0.314208] omap_voltage_late_init: Voltage driver support not added
[    0.314208] Power Management for TI OMAP4+ devices.
[    0.314971] Loading compiled-in X.509 certificates
[    0.348297] platform 4a000000.interconnect: Fixed dependency cycle(s) with /ocp/interconnect@4a000000/segment@0/target-module@8000/cm_core@0/clock@d00/clock@20
[    0.354339] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[    0.376434] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.392395] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it!
[    0.392700] OMAP GPIO hardware version 0.1
[    0.394958] ti-sysc: probe of 4ae18000.target-module failed with error -16
[    0.401824] printk: console [ttyS2] disabled
[    0.401885] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 100, base_baud = 3000000) is a 8250
[    1.637939] printk: console [ttyS2] enabled
[    1.649871] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it!
[    1.659881] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it!
[    1.669677] gpio gpiochip3: (gpio-96-127): not an immutable chip, please consider fixing it!
[    1.679473] gpio gpiochip4: (gpio-128-159): not an immutable chip, please consider fixing it!
[    1.689331] gpio gpiochip5: (gpio-160-191): not an immutable chip, please consider fixing it!
[    1.699188] gpio gpiochip6: (gpio-192-223): not an immutable chip, please consider fixing it!
[    1.709075] gpio gpiochip7: (gpio-224-255): not an immutable chip, please consider fixing it!
[    1.719757] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    1.731506] palmas 0-0058: Irq flag is 0x00000008
[    1.765624] palmas 0-0058: Muxing GPIO 2f, PWM 0, LED 0
[    1.798400] at24 0-0050: supply vcc not found, using dummy regulator
[    1.805267] at24 0-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
[    1.812072] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    1.824768] omap_rng 48090000.rng: Random Number Generator ver. 20
[    1.831634] random: crng init done
[    1.913757] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.926086] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver Micrel KSZ9031 Gigabit PHY
[    1.935821] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver Micrel KSZ9031 Gigabit PHY
[    1.946136] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4
[    1.952941] cpsw-switch 48484000.switch: ALE Table size 1024
[    1.958709] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies)
[    1.966369] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec
[    1.977508] cpsw-switch 48484000.switch: Detected MACID = 28:ec:9a:de:c0:14
[    1.984588] cpsw-switch 48484000.switch: Detected MACID = 28:ec:9a:de:c0:15
[    1.993286] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0)
[    2.015838] ti-sysc: probe of 4882c000.target-module failed with error -16
[    2.023498] ti-sysc: probe of 4882e000.target-module failed with error -16
[    2.034332] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    2.041564] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    2.060882] dra7-pcie 51000000.pcie: host bridge /ocp/target-module@51000000/pcie@51000000 ranges:
[    2.069946] dra7-pcie 51000000.pcie:       IO 0x0020003000..0x0020012fff -> 0x0000000000
[    2.078124] dra7-pcie 51000000.pcie:      MEM 0x0020013000..0x002fffffff -> 0x0020013000
[    2.086486] dra7-pcie 51000000.pcie: iATU unroll: disabled
[    2.092010] dra7-pcie 51000000.pcie: iATU regions: 16 ob, 4 ib, align 4K, limit 4G
[    3.100555] dra7-pcie 51000000.pcie: Phy link never came up
[    3.106292] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    3.112579] pci_bus 0000:00: root bus resource [bus 00-ff]
[    3.118133] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    3.124359] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    3.131286] pci 0000:00:00.0: [104c:8888] type 01 class 0x060400
[    3.137390] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[    3.143676] pci 0000:00:00.0: reg 0x14: [mem 0x00000000-0x0000ffff]
[    3.150054] pci 0000:00:00.0: supports D1
[    3.154113] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    3.167419] PCI: bus0: Fast back to back transfers disabled
[    3.173370] PCI: bus1: Fast back to back transfers enabled
[    3.178924] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    3.185760] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    3.192596] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    3.198211] pcieport 0000:00:00.0: PME: Signaling with IRQ 133
[    3.210083] edma 43300000.dma: memcpy is disabled
[    3.218170] edma 43300000.dma: TI EDMA DMA engine driver
[    3.229827] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    3.237579] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    3.244232] platform 40800000.dsp: Adding to iommu group 0
[    3.251220] platform 58820000.ipu: Adding to iommu group 1
[    3.256896] omap-iommu 58882000.mmu: 58882000.mmu registered
[    3.264770] platform 55020000.ipu: Adding to iommu group 2
[    3.270294] omap-iommu 55082000.mmu: 55082000.mmu registered
[    3.291290] omap-iommu 41501000.mmu: 41501000.mmu registered
[    3.298583] omap-iommu 41502000.mmu: 41502000.mmu registered
[    3.305419] platform 41000000.dsp: Adding to iommu group 3
[    3.313415] ti-sysc 4ae06000.target-module: Failed to create device link (0x180) with ocp
[    3.355316] rtc-ds1307 2-006f: registered as rtc0
[    3.360351] rtc-ds1307 2-006f: hctosys: unable to read the hardware clock
[    3.370422] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: registered as rtc1
[    3.380798] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[    3.381103] sdhci-omap 480b4000.mmc: supply pbias not found, using dummy regulator
[    3.389678] sdhci-omap 4809c000.mmc: Got CD GPIO
[    3.403778] clk: Disabling unused clocks
[    3.412872] l3init-clkctrl:0030:0: failed to disable
[    3.418121] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[    3.437316] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    3.457336] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    3.464660] Waiting for root device PARTUUID=49dc51d7-02...
[    3.492156] mmc1: new DDR MMC card at address 0001
[    3.497406] mmcblk1: mmc1:0001 M62704 3.56 GiB
[    3.503448]  mmcblk1: p1
[    3.506164] mmc0: new high speed SDHC card at address 0001
[    3.512359] mmcblk1boot0: mmc1:0001 M62704 2.00 MiB
[    3.517608] mmcblk0: mmc0:0001 GB1QT 29.8 GiB
[    3.522949] mmcblk1boot1: mmc1:0001 M62704 2.00 MiB
[    3.529296] mmcblk1rpmb: mmc1:0001 M62704 512 KiB, chardev (243:0)
[    3.535583]  mmcblk0: p1 p2
[    3.590332] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: disabled.
[    3.599334] VFS: Mounted root (ext4 filesystem) on device 179:18.
[    3.606292] devtmpfs: mounted
[    3.610534] Freeing unused kernel image (initmem) memory: 2048K
[    3.616607] Run /sbin/init as init process
[    3.946716] systemd[1]: System time before build time, advancing clock.
[    3.978790] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    4.010772] systemd[1]: Detected architecture arm.
Welcome to Arago 2023.10!
[    4.054687] systemd[1]: Hostname set to <am57xx-evm>.
[    4.068389] systemd[1]: Initializing machine ID from random generator.
[    4.205688] systemd-sysv-generator[114]: SysV service '/etc/init.d/thermal-zone-init' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    4.234802] systemd-sysv-generator[114]: SysV service '/etc/init.d/gdbserverproxy' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
[    4.559906] systemd[1]: /lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.633392] systemd[1]: /etc/systemd/system/sys-clock-drift.service:10: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.655334] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.745269] systemd[1]: Queued start job for default target Graphical Interface.
[    4.754638] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    4.794860] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    4.835144] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    4.874237] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.914062] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    4.954223] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    4.994171] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    5.023925] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.063873] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    5.093902] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    5.132507] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    5.174041] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    5.222137] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    5.264068] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    5.337890] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[    5.349334] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.384796] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.424346] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    5.464416] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.504699] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.544158] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    5.584350] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    5.644134] systemd[1]: Mounting POSIX Message Queue File System...
[    5.686126] systemd[1]: Mounting Kernel Debug File System...
[    5.784118] systemd[1]: Mounting Kernel Trace File System...
[    5.828247] systemd[1]: Mounting Temporary Directory /tmp...
[    5.867858] systemd[1]: Starting Create List of Static Device Nodes...
[    5.907714] systemd[1]: Starting Load Kernel Module configfs...
[    5.947723] systemd[1]: Starting Load Kernel Module drm...
[    5.987487] systemd[1]: Starting Load Kernel Module fuse...
[    6.037139] systemd[1]: Starting Start psplash boot splash screen...
[    6.077545] systemd[1]: Starting RPC Bind...
[    6.104156] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    6.117462] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    6.130401] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    6.140594] systemd[1]: Starting Journal Service...
[    6.224182] systemd[1]: Starting Load Kernel Modules...
[    6.245422] cryptodev: loading out-of-tree module taints kernel.
[    6.252655] cryptodev: driver 1.12 loaded.
[    6.259216] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network …ts from Kernel command line...
[    6.307647] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.328857] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: disabled.
[    6.394409] systemd[1]: Starting Coldplug All udev Devices...
[    6.431793] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    6.474182] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Trace File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    7.044036] systemd-journald[126]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create System Users...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /media/ram.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Mounted /var/volatile.
         Starting Wait for udev To …plete Device Initialization...
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Rebuild Dynamic Linker Cache...
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Finished Create Volatile Files and [    8.070007] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
Directories.
[    8.083251] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    8.102996] omap-sham 4b101000.sham: will run requests pump with realtime priority
[    8.117584] remoteproc remoteproc0: 58820000.ipu is available
[    8.131927] omap-sham 42701000.sham: hw accel on OMAP rev 4.3
         Starting Rebuild Journal Catalog...
[    8.162445] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[    8.170715] omap-sham 42701000.sham: will run requests pump with realtime priority
         Starting Network Time Synchronization...
[    8.211639] remoteproc remoteproc1: 55020000.ipu is available
         Starting Record System Boot/Shutdown in UTMP...
[    8.277221] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[  OK  ] Found device /dev/ttyS2.
[    8.324218] remoteproc remoteproc2: 40800000.dsp is available
[    8.381530] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[    8.435882] remoteproc remoteproc3: 41000000.dsp is available
[    8.522979] remoteproc remoteproc0: powering up 58820000.ipu
[    8.528869] remoteproc remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 4855436
[    8.580261] omap-iommu 58882000.mmu: no fck found
[    8.585052] omap-iommu 58882000.mmu: pwrdm_constraint failed to be set, status = -19
[    8.592834] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[    8.600372] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node ipu1-memory@9d000000
[    8.624786] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.626525] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x32
[    8.635192] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    8.647460] virtio_rpmsg_bus virtio0: creating channel rpmsg-client-sample addr 0x33
[    8.653381] remoteproc remoteproc0: remote processor 58820000.ipu is now up
[    8.656555] virtio_rpmsg_bus virtio0: creating channel rpmsg-omx addr 0x3c
[    8.676605] virtio_rpmsg_bus virtio0: creating channel rpmsg-rpc addr 0x65
[    8.960418] remoteproc remoteproc1: powering up 55020000.ipu
[    8.966156] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3747228
[    8.974273] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    9.025482] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node ipu2-memory@95800000
[    9.035980] virtio_rpmsg_bus virtio1: rpmsg host is online
[    9.041534] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[    9.048400] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[    9.055847] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x65
[    9.063079] virtio_rpmsg_bus virtio1: creating channel rpmsg-rpc addr 0x66
[    9.074096] omap_rtc 48838000.rtc: registered as rtc2
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[    9.234191] remoteproc remoteproc2: powering up 40800000.dsp
[    9.239898] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5535952
[    9.248962] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[    9.254882] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[    9.271667] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node dsp1-memory@99000000
[    9.282287] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    9.282531] virtio_rpmsg_bus virtio2: rpmsg host is online
[    9.288177] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x32
[    9.294799] rproc-virtio rproc-virtio.3.auto: registered virtio2 (type 7)
[    9.309661] virtio_rpmsg_bus virtio2: creating channel rpmsg-client-sample addr 0x33
[    9.318878] omap-des 480a5000.des: will run requests pump with realtime priority
[    9.319702] virtio_rpmsg_bus virtio2: creating channel rpmsg-omx addr 0x3c
[    9.326751] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[    9.334320] virtio_rpmsg_bus virtio2: creating channel rpmsg-rpc addr 0x65
[    9.370178] remoteproc remoteproc3: powering up 41000000.dsp
[    9.376800] ahci-dwc 4a140000.sata: supply ahci not found, using dummy regulator
[    9.390167] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    9.400329] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5536080
[    9.411773] ahci-dwc 4a140000.sata: supply phy not found, using dummy regulator
[    9.422576] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[    9.428527] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[    9.434600] ahci-dwc 4a140000.sata: supply target not found, using dummy regulator
[    9.436309] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    9.452270] ahci-dwc 4a140000.sata: forcing port_map 0x0 -> 0x1
[    9.458587] mc: Linux media interface: v0.10
[    9.471618] ahci-dwc 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    9.495452] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node dsp2-memory@9f000000
[    9.496459] omap-aes 4b500000.aes: will run requests pump with realtime priority
[    9.508239] ahci-dwc 4a140000.sata: flags: 64bit ncq sntf pm led clo only pmp pio slum part ccc apst
[    9.531005] videodev: Linux video capture interface: v2.00
[    9.542480] virtio_rpmsg_bus virtio3: rpmsg host is online
[    9.548065] virtio_rpmsg_bus virtio3: creating channel rpmsg-client-sample addr 0x32
[    9.550628] rproc-virtio rproc-virtio.4.auto: registered virtio3 (type 7)
[    9.557891] virtio_rpmsg_bus virtio3: creating channel rpmsg-client-sample addr 0x33
[    9.563049] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[    9.571289] virtio_rpmsg_bus virtio3: creating channel rpmsg-omx addr 0x3c
[  OK  ] Finished Rebuild Journal Catalog    9.586059] virtio_rpmsg_bus virtio3: creating channel rpmsg-rpc addr 0x65
m.
[    9.598541] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    9.606567] omap-aes 4b700000.aes: will run requests pump with realtime priority
[    9.608428] scsi host0: ahci-dwc
[    9.686828] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 157
[    9.733093] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 0
[    9.747985] DSS: OMAP DSS rev 6.1
[    9.782562] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops [omapdrm])
[    9.839233] omapdss_dss 58000000.dss: bound 58040000.encoder (ops hdmi5_component_ops [omapdrm])
[    9.897796] dmm 4e000000.dmm: workaround for errata i878 in use
[    9.934631] dmm 4e000000.dmm: initialized all PAT entries
[    9.972412] omapdrm omapdrm.0: [drm] Cannot find any crtc or sizes
[    9.992156] ------------[ cut here ]------------
[    9.996887] WARNING: CPU: 1 PID: 147 at drivers/gpu/drm/drm_bridge.c:1416 drm_bridge_hpd_enable+0x7c/0x80
[   10.006561] Hot plug detection already enabled
[   10.011047] Modules linked in: snd_soc_simple_card_utils omapdrm(+) v4l2_fwnode videobuf2_dma_contig v4l2_async videobuf2_memops videobuf2_v4l2 snd_soc_davinci_mcasp cec pvrsrvkm(O) videobuf2_common snd_soc_ti_udma snd_soc_tlv320aic3x_i2c snd_soc_ti_edma snd_soc_tlv320aic3x snd_soc_ti_sdma videodev snd_soc_core mc omap_aes_driver snd_pcm_dmaengine ac97_bus pruss omap_wdt snd_pcm libaes ahci_dwc omap_hwspinlock snd_timer omap_des dwc3_omap snd rtc_omap omap_crypto libdes soundcore extcon_palmas omap_sham omap_remoteproc crypto_engine virtio_rpmsg_bus rpmsg_ns rpmsg_core ti_tpd12s015 display_connector gdbserverproxy(O) cryptodev(O)
[   10.026458] ata1: SATA link down (SStatus 0 SControl 300)
[   10.067291] CPU: 1 PID: 147 Comm: systemd-udevd Tainted: G           O       6.1.119-ti-ge4e8b16e66f5 #1
[   10.067291] Hardware name: Generic DRA74X (Flattened Device Tree)
[   10.067291]  unwind_backtrace from show_stack+0x10/0x14
[   10.067321]  show_stack from dump_stack_lvl+0x40/0x4c
[   10.098693]  dump_stack_lvl from __warn+0x7c/0x158
[   10.103515]  __warn from warn_slowpath_fmt+0x124/0x1c0
[   10.108673]  warn_slowpath_fmt from drm_bridge_hpd_enable+0x7c/0x80
[   10.114990]  drm_bridge_hpd_enable from pdev_probe+0x5e8/0x788 [omapdrm]
[   10.121856]  pdev_probe [omapdrm] from platform_probe+0x5c/0xbc
[   10.127899]  platform_probe from really_probe+0xc8/0x2ec
[   10.133239]  really_probe from __driver_probe_device+0x88/0x1a0
[   10.139160]  __driver_probe_device from driver_probe_device+0x30/0x104
[   10.145721]  driver_probe_device from __driver_attach+0x90/0x174
[   10.151763]  __driver_attach from bus_for_each_dev+0x74/0xc0
[   10.157470]  bus_for_each_dev from bus_add_driver+0x164/0x1f0
[   10.163238]  bus_add_driver from driver_register+0x88/0x11c
[   10.168853]  driver_register from __platform_register_drivers+0x38/0x88
[   10.175506]  __platform_register_drivers from omap_drm_init+0x3c/0x50 [omapdrm]
[   10.182922]  omap_drm_init [omapdrm] from do_one_initcall+0x48/0x254
[   10.189392]  do_one_initcall from do_init_module+0x44/0x1d4
[   10.195007]  do_init_module from sys_finit_module+0xc0/0x110
[   10.200714]  sys_finit_module from __sys_trace_return+0x0/0x10
[   10.206573] Exception stack(0xf00f5fa8 to 0xf00f5ff0)
[   10.211639] 5fa0:                   00000000 00000000 0000000e b6d6a8a0 00000000 00020000
[   10.219848] 5fc0: 00000000 00000000 00000000 0000017b 00000000 000972a8 00000007 00000000
[   10.228057] 5fe0: becac710 becac700 b6d65d4f b6c9b052
[   10.233154] ---[ end trace 0000000000000000 ]---
[   10.364074] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[   10.393951] vpe 489d0000.vpe: Device registered as /dev/video0
[   11.456878] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   11.476287] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 1
[   11.497589] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000008002010010
[   11.510253] xhci-hcd xhci-hcd.6.auto: irq 165, io mem 0x48890000
[   11.516876] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1
[   11.518859] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller
[   11.530456] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 2
[   11.539733] xhci-hcd xhci-hcd.6.auto: Host supports USB 3.0 SuperSpeed
[   11.561889] hub 1-0:1.0: USB hub found
[   11.566589] hub 1-0:1.0: 1 port detected
[   11.575164] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   11.586791] hub 2-0:1.0: USB hub found
[   11.593811] hub 2-0:1.0: 1 port detected
[*     ] (1 of 2) A start job is running for…namic Linker Cache (6s / no limit)
[   11.689727] remoteproc remoteproc4: 4b234000.pru is available
[   11.705871] remoteproc remoteproc5: 4b238000.pru is available
[   11.780181] remoteproc remoteproc6: 4b2b4000.pru is available
[   11.833801] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[   11.863159] remoteproc remoteproc7: 4b2b8000.pru is available
[**    ] (1 of 2) A start job is running for…namic Linker Cache (7s / no limit)
[   12.104339] hub 1-1:1.0: USB hub found
[   12.108337] hub 1-1:1.0: 4 ports detected
[   12.213806] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[   12.264404] hub 2-1:1.0: USB hub found
[***   ] (1 of 2) A start job is running for…namic Linker Cache (7s / no limit)
[ ***  ] (2 of 2) A start job is running for…vice Initialization (7s / 3min 3s)
[   12.680725] hub 1-1:1.0: USB hub found
[   12.684631] hub 1-1:1.0: 4 ports detected
[   12.841094] hub 1-1:1.0: USB hub found
[   12.848297] hub 1-1:1.0: 4 ports detected
[   12.936798] hub 2-1:1.0: USB hub found
[   12.940673] hub 2-1:1.0: 4 ports detected
[   12.984832] hub 2-1:1.0: USB hub found
[  OK  ] Created slice Slice /system/systemd-fsck.
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting File System Check on /dev/mmcblk0p1...
         Starting File System Check on /dev/mmcblk1p1...
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Finished Rebuild Dynamic Linker Cache.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting Update is Completed...
[  OK  ] Finished Update is Completed.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
         Starting Weston socket...
         Starting D-Bus System Message Bus...
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Listening on Weston socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Finished File System Check on /dev/mmcblk0p1.
         Mounting /run/media/boot-mmcblk0p1...
[  OK  ] Finished Reboot and dump vmcore via kexec.
[  OK  ] Mounted /run/media/boot-mmcblk0p1.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Basic System.
         Starting Save/Restore Sound Card State...
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
         Starting DEMO...
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Telephony service...
         Starting Expand the rootfs…ll size of the boot device....
[  OK  ] Started strongSwan IPsec I…IKEv2 daemon using ipsec.conf.
         Starting User Login Management...
         Starting Telnet Server...
         Starting TI IPC Daemon...
[  OK  ] Finished File System Check on /dev/mmcblk1p1.
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Telnet Server.
[  OK  ] Reached target Preparation for Network.
[  OK  ] Reached target Sound Card.
         Mounting /run/media/rootfs-mmcblk1p1...
         Starting Network Configuration...
[  OK  ] Started TI IPC Daemon.
[  OK  ] Started Telephony service.
[   13.893859] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Quota mode: disabled.
[  OK  ] Mounted /run/media/rootfs-mmcblk1p1.
[  OK  ] Started DEMO.
[  OK  ] Started User Login Management.
[   14.413482] Bluetooth: Core ver 2.22
[   14.431579] NET: Registered PF_BLUETOOTH protocol family
[   14.437225] Bluetooth: HCI device and connection manager initialized
[   14.443634] Bluetooth: HCI socket layer initialized
[   14.463745] Bluetooth: L2CAP socket layer initialized
[   14.468872] Bluetooth: SCO socket layer initialized
[   14.527587] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.813903] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.824890] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[  OK  ] Started Network Configuration.
[   15.000366] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
         Starting Network Name Resolution...
[   15.133728] Micrel KSZ9031 Gigabit PHY 48485000.mdio:02: attached PHY driver (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
[   15.179718] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[   15.325134] Micrel KSZ9031 Gigabit PHY 48485000.mdio:01: attached PHY driver (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
[   15.412231] Initializing XFRM netlink socket
[   15.557220] EXT4-fs (mmcblk0p2): resizing filesystem from 1962710 to 7782144 blocks
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
         Starting containerd container runtime...
[  OK  ] Started Netperf Benchmark Server.
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Finished Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting Weston, a Wayland…ositor, as a system service...
[  OK  ] Finished Synchronize System and HW clocks.
[  OK  ] Started system clock drift service.
         Starting User Database Manager...
[  OK  ] Started User Database Manager.
[   19.501556] systemd-journald[126]: Time jumped backwards, rotating.
[  OK  ] Created slice User Slice of UID 1000.
         Starting User Runtime Directory /run/user/1000...
[  OK  ] Finished User Runtime Directory /run/user/1000.
         Starting User Manager for UID 1000...
[  OK  ] Started containerd container runtime.
[   20.157348] EXT4-fs (mmcblk0p2): resized filesystem to 7782144
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am57xx-evm -
Arago 2023.10 am57xx-evm -
am57xx-evm login: root
NOTICE: This file system contains the following GPL-3.0 packages:
        adwaita-icon-theme-symbolic
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbc6x
        gdbserver
        gettext
        glmark2
        gnu-config
        gzip
        hidapi
        less
        libasm1
        libatomic-dev
        libatomic1
        libbfd
        libdebuginfod1
        libdw1
        libelf1
        libgcc-s-dev
        libgcc1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libgomp1
        libidn2-0
        libmpc3
        libmpfr6
        libopcodes
        libqt5charts-examples
        libqt5charts-plugins
        libqt5charts-qmlplugins
        libqt5charts5
        libqt5sensors-plugins
        libqt5sensors-qmlplugins
        libqt5sensors5
        libqt5serialport-examples
        libqt5serialport-plugins
        libqt5serialport-qmlplugins
        libqt5serialport5
        libqt5svg-examples
        libqt5svg-plugins
        libqt5svg-qmlplugins
        libqt5svg5
        libqt5virtualkeyboard-plugins
        libqt5virtualkeyboard-qmlplugins
        libqt5virtualkeyboard5
        libqt5webchannel-plugins
        libqt5webchannel-qmlplugins
        libqt5webchannel5
        libreadline-dev
        libreadline8
        libstdc++-dev
        libstdc++6
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        pdm-anomaly-detection
        piglit
        qt3d-plugins
        qt3d-qmlplugins
        qt3d
        qtbase-examples
        qtbase-plugins
        qtbase-qmlplugins
        qtbase
        qtconnectivity-plugins
        qtconnectivity-qmlplugins
        qtconnectivity
        qtdeclarative-plugins
        qtdeclarative-qmlplugins
        qtdeclarative-tools
        qtdeclarative
        qtgraphicaleffects-qmlplugins
        qtlocation-examples
        qtlocation-plugins
        qtlocation-qmlplugins
        qtlocation
        qtmultimedia-examples
        qtmultimedia-plugins
        qtmultimedia-qmlplugins
        qtmultimedia
        qtquics-qmlplugins.control
        qtquics2-plugins.control
        qtquics2-qmlplugins.control
        qtquics2.control
        qtscript-examples
        qtscript-plugins
        qtscript-qmlplugins
        qtscript
        qtwayland-examples
        qtwayland-plugins
        qtwayland-qmlplugins
        qtwayland
        tar
        which
If you do not wish to distribute GPL-3.0 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
root@am57xx-evm:~# dmesg -l 3
-Job
