SK-AM62P-LP: Unstable Wi-Fi Connection in Yocto with CC33xx Driver
Part Number: SK-AM62P-LP
Other Parts Discussed in Thread: M2-CC3351,
I am using the M2-CC3351 Wi-Fi module with the SK-AM62P-LP board. The image I'm using is the prebuilt Yocto release : tisdk-default-image-am62pxx-evm-11.00.09.04.rootfs.wic
Experiencing an unstable Wi-Fi connection on my Yocto-based system using the CC33xx Wi-Fi module.
To connect WiFi, navigate to /usr/share/CC33xx
./sta_start.sh
./sta_connect.sh -s WPA-PSK -n <SSID> -p <Password>
I receive a successful connection message:
wlan0: CTRL-EVENT-CONNECTED - Connection to ec:75:0c:25:3e:e8 completed [id=5 id_str=]
However, as soon as I try to ping google.com, the connection drops and starts attempting to reconnect. Below are the relevant logs:
wlan0: CTRL-EVENT-BEACON-LOSS
[ 866.917428] cc33xx: Connection loss work (role_id: 0).
[ 866.922624] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 867.453477] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms)
[ 867.969529] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms)
[ 868.489548] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms)
wlan0: CTRL-EVENT-DISCONNECTED bssid=ec:75:0c:25:3e:e8 reason=4 locally_generated=1
wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
wlan0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=US
Then, the module attempts to reconnect:
wlan0: SME: Trying to authenticate with ec:75:0c:25:3e:e8 (SSID='xxx' freq=5785 MHz)
[ 885.046419] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 885.054615] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 885.066845] wlan0: authenticated
[ 885.070881] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 885.103622] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 885.116106] cc33xx: HE Disabled
[ 885.120758] wlan0: associated
wlan0: Associated with ec:75:0c:25:3e:e8
wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
wlan0: WPA: Key negotiation completed with ec:75:0c:25:3e:e8 [PTK=CCMP GTK=CCMP]
This cycle continues indefinitely.
dmesg log
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.12.17-ti-00771-gc85877d40f8e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Mar 25 12:45:29 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM62P5 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: legacy bootconsole [ns16550a0] enabled
[    0.000000] Reserved memory: created CMA memory pool at 0x00000009dc000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000009dc000000..0x00000009ffffffff (589824 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b500000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node rtos-ipc-memory@9b500000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b500000..0x000000009b7fffff (3072 KiB) nomap non-reusable rtos-ipc-memory@9b500000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@9b800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@9b800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@9b900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@9b900000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9c900000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-memory@9c900000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000009ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b4fffff]
[    0.000000]   node   0: [mem 0x000000009b500000-0x000000009e6fffff]
[    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000ff6fffff]
[    0.000000]   node   0: [mem 0x00000000ff700000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000009ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] pcpu-alloc: s51672 r8192 d30248 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2097152
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000fb700000-0x00000000ff700000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880050000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008684] Console: colour dummy device 80x25
[    0.013283] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023948] pid_max: default: 32768 minimum: 301
[    0.028749] LSM: initializing lsm=capability,selinux
[    0.033877] SELinux:  Initializing.
[    0.037921] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.045679] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.069966] rcu: Hierarchical SRCU implementation.
[    0.074887] rcu: 	Max phase no-delay instances is 1000.
[    0.080428] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.089183] EFI services will not be available.
[    0.097855] smp: Bringing up secondary CPUs ...
[    0.110850] Detected VIPT I-cache on CPU1
[    0.110933] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.110950] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
[    0.110995] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.118849] Detected VIPT I-cache on CPU2
[    0.118917] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.118932] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
[    0.118967] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.126869] Detected VIPT I-cache on CPU3
[    0.126934] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.126949] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
[    0.126982] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.127111] smp: Brought up 1 node, 4 CPUs
[    0.206740] SMP: Total of 4 processors activated.
[    0.211545] CPU: All CPU(s) started at EL2
[    0.215740] CPU features: detected: 32-bit EL0 Support
[    0.220991] CPU features: detected: CRC32 instructions
[    0.226285] alternatives: applying system-wide alternatives
[    0.232600] Memory: 7455124K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 334608K reserved, 589824K cma-reserved)
[    0.248168] devtmpfs: initialized
[    0.262770] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.272767] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.295234] 27152 pages in range for non-PLT usage
[    0.295257] 518672 pages in range for PLT usage
[    0.300493] pinctrl core: initialized pinctrl subsystem
[    0.310957] DMI not present or invalid.
[    0.317121] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.324471] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.331923] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.340043] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.348696] audit: initializing netlink subsys (disabled)
[    0.354521] audit: type=2000 audit(0.240:1): state=initialized audit_enabled=0 res=1
[    0.354968] thermal_sys: Registered thermal governor 'step_wise'
[    0.362448] thermal_sys: Registered thermal governor 'power_allocator'
[    0.368630] cpuidle: using governor menu
[    0.379487] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.386511] ASID allocator initialised with 65536 entries
[    0.398599] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[    0.410097] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.422734] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.432756] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.445487] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.460839] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    0.473604] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.484632] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    0.499376] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.509321] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.520799] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.530036] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.539984] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.546959] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.553373] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.560307] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.566714] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.573649] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.580050] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.586984] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.595222] k3-chipinfo 43000014.chipid: Family:AM62PX rev:SR1.0 JTAGID[0x0bb9d02f] Detected
[    0.604657] iommu: Default domain type: Translated
[    0.609586] iommu: DMA domain TLB invalidation policy: strict mode
[    0.616289] SCSI subsystem initialized
[    0.620290] libata version 3.00 loaded.
[    0.620476] usbcore: registered new interface driver usbfs
[    0.626112] usbcore: registered new interface driver hub
[    0.631566] usbcore: registered new device driver usb
[    0.637240] pps_core: LinuxPPS API ver. 1 registered
[    0.642318] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.651659] PTP clock support registered
[    0.655699] EDAC MC: Ver: 3.0.0
[    0.659231] scmi_core: SCMI protocol bus registered
[    0.664520] FPGA manager framework
[    0.668074] Advanced Linux Sound Architecture Driver Initialized.
[    0.675288] vgaarb: loaded
[    0.678444] clocksource: Switched to clocksource arch_sys_counter
[    0.684983] VFS: Disk quotas dquot_6.6.0
[    0.689023] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.703531] NET: Registered PF_INET protocol family
[    0.708838] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.722014] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.730874] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.738813] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.747315] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.756639] TCP: Hash tables configured (established 65536 bind 65536)
[    0.763534] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.770643] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.778331] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.784642] RPC: Registered named UNIX socket transport module.
[    0.790716] RPC: Registered udp transport module.
[    0.795522] RPC: Registered tcp transport module.
[    0.800329] RPC: Registered tcp-with-tls transport module.
[    0.805937] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.812532] NET: Registered PF_XDP protocol family
[    0.817445] PCI: CLS 0 bytes, default 64
[    0.822863] Initialise system trusted keyrings
[    0.827660] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.834578] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.840829] NFS: Registering the id_resolver key type
[    0.846044] Key type id_resolver registered
[    0.850322] Key type id_legacy registered
[    0.854445] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.861298] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.924166] Key type asymmetric registered
[    0.928377] Asymmetric key parser 'x509' registered
[    0.933436] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.941173] io scheduler mq-deadline registered
[    0.945810] io scheduler kyber registered
[    0.949937] io scheduler bfq registered
[    0.957405] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.963969] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.971852] ledtrig-cpu: registered to indicate activity on CPUs
[    0.984307] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.999878] loop: module loaded
[    1.004249] megasas: 07.727.03.00-rc1
[    1.012050] tun: Universal TUN/TAP device driver, 1.6
[    1.018302] VFIO - User Level meta-driver version: 0.3
[    1.024849] usbcore: registered new interface driver usb-storage
[    1.031604] i2c_dev: i2c /dev entries driver
[    1.037685] sdhci: Secure Digital Host Controller Interface driver
[    1.044058] sdhci: Copyright(c) Pierre Ossman
[    1.048753] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.055239] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.062548] usbcore: registered new interface driver usbhid
[    1.068254] usbhid: USB HID core driver
[    1.073479] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    1.083738] optee: probing for conduit method.
[    1.088319] optee: revision 4.5 (ef1ebdc23034a804)
[    1.088688] optee: dynamic shared memory is enabled
[    1.099311] optee: initialized driver
[    1.099425] random: crng init done
[    1.104917] Initializing XFRM netlink socket
[    1.110991] NET: Registered PF_PACKET protocol family
[    1.116231] Key type dns_resolver registered
[    1.129324] registered taskstats version 1
[    1.133817] Loading compiled-in X.509 certificates
[    1.151695] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
[    1.210117] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    1.222908] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.230474] pca953x 1-0023: supply vcc not found, using dummy regulator
[    1.237360] pca953x 1-0023: using AI
[    1.256641] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.265891] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.275824] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    1.285042] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    1.295133] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.302063] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.308029] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.317278] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.326276] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created
[    1.336437] simple-framebuffer ff700000.framebuffer: framebuffer at 0xff700000, 0x8ca000 bytes
[    1.345291] simple-framebuffer ff700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
[    1.366138] Console: switching to colour frame buffer device 240x75
[    1.382822] simple-framebuffer ff700000.framebuffer: fb0: simplefb registered!
[    1.390601] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.399371] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.410542] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.421666] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.431294] ti-udma 4e230000.dma-controller: Number of rings: 6
[    1.437949] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
[    1.447468] printk: legacy console [ttyS2] disabled
[    1.452813] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 250, base_baud = 3000000) is a 8250
[    1.461796] printk: legacy console [ttyS2] enabled
[    1.471491] printk: legacy bootconsole [ns16550a0] disabled
[    1.489962] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.496995] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.502395] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.509173] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.515667] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.522255] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.528601] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.535527] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.542070] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.714458] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000
[    1.728936] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.737039] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.745160] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006
[    1.758110] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.765244] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
[    1.773003] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0
[    1.793275] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.804329] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/usb@f900000/usb@31000000
[    1.816847] /bus@f0000/usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
[    1.833357] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.838914] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.846689] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    1.852695] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
[    1.862127] xhci-hcd xhci-hcd.0.auto: irq 265, io mem 0x31100000
[    1.868920] hub 1-0:1.0: USB hub found
[    1.872712] hub 1-0:1.0: 1 port detected
[    1.878471] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
[    1.890965] mmc0: CQHCI version 5.10
[    1.897039] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.903869] pca953x 1-0022: using AI
[    1.914266] clk: Disabling unused clocks
[    1.923507] PM: genpd: Disabling unused power domains
[    1.928865] ALSA device list:
[    1.928882] mmc2: CQHCI version 5.10
[    1.928982] mmc1: CQHCI version 5.10
[    1.931871]   No soundcards found.
[    1.941150] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.970469] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    1.978779] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    1.986786] Waiting for root device PARTUUID=076c4a2a-02...
[    1.995571] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[    2.016083] mmc2: new high speed SDIO card at address 0001
[    2.030750] mmc0: Command Queue Engine enabled
[    2.035225] mmc0: new HS200 MMC card at address 0001
[    2.038143] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
[    2.040889] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.047638] mmcblk1: mmc1:aaaa SN64G 59.5 GiB
[    2.054352]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20
[    2.057694]  mmcblk1: p1 p2
[    2.066302] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.072809] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.078701] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    2.264249] EXT4-fs (mmcblk1p2): mounted filesystem e2641b9b-60b5-4246-bcb4-4f1e1879c28e r/w with ordered data mode. Quota mode: none.
[    2.276512] VFS: Mounted root (ext4 filesystem) on device 179:34.
[    2.283305] devtmpfs: mounted
[    2.287031] Freeing unused kernel memory: 2752K
[    2.291649] Run /sbin/init as init process
[    2.295741]   with arguments:
[    2.295745]     /sbin/init
[    2.295748]   with environment:
[    2.295751]     HOME=/
[    2.295755]     TERM=linux
[    2.354492] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.475056] systemd[1]: System time before build time, advancing clock.
[    2.517300] NET: Registered PF_INET6 protocol family
[    2.523358] Segment Routing with IPv6
[    2.527083] In-situ OAM (IOAM) with IPv6
[    2.536523] hub 1-1:1.0: USB hub found
[    2.540420] hub 1-1:1.0: 4 ports detected
[    2.558762] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.590671] systemd[1]: Detected architecture arm64.
[    2.612657] systemd[1]: Hostname set to <am62pxx-evm>.
[    2.622869] systemd[1]: Initializing machine ID from random generator.
[    2.822493] usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
[    2.856743] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.902004] systemd[1]: Configuration file /usr/lib/systemd/system/seva-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.952489] hub 1-1.1:1.0: USB hub found
[    2.956567] hub 1-1.1:1.0: 4 ports detected
[    2.987452] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    3.154822] systemd[1]: Queued start job for default target Graphical Interface.
[    3.208306] systemd[1]: Created slice Slice /system/getty.
[    3.228915] systemd[1]: Created slice Slice /system/modprobe.
[    3.238485] usb 1-1.1.1: new full-speed USB device number 4 using xhci-hcd
[    3.256870] systemd[1]: Created slice Slice /system/serial-getty.
[    3.276308] systemd[1]: Created slice User and Session Slice.
[    3.294918] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.314806] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.334657] systemd[1]: Expecting device /dev/ttyS2...
[    3.338772] usb 1-1.1.1: not running at top speed; connect to a high speed hub
[    3.354765] systemd[1]: Reached target Path Units.
[    3.370648] systemd[1]: Reached target Remote File Systems.
[    3.386585] systemd[1]: Reached target Slice Units.
[    3.398595] systemd[1]: Reached target Swaps.
[    3.401728] input: Generic AB13X USB Audio as /devices/platform/bus@f0000/f910000.usb/31100000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.3/0003:001F:0B21.0001/input/input0
[    3.476016] hid-generic 0003:001F:0B21.0001: input: USB HID v2.01 Device [Generic AB13X USB Audio] on usb-xhci-hcd.0.auto-1.1.1/input3
[    3.479693] systemd[1]: Listening on RPCbind Server Activation Socket.
[    3.506778] systemd[1]: Reached target RPC Port Mapper.
[    3.529653] systemd[1]: Listening on Process Core Dump Socket.
[    3.547066] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.567780] systemd[1]: Listening on Journal Audit Socket.
[    3.591300] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.602470] usb 1-1.2: new full-speed USB device number 5 using xhci-hcd
[    3.615361] systemd[1]: Listening on Journal Socket.
[    3.631477] systemd[1]: Listening on Network Service Netlink Socket.
[    3.654423] systemd[1]: Listening on udev Control Socket.
[    3.671173] systemd[1]: Listening on udev Kernel Socket.
[    3.687268] systemd[1]: Listening on User Database Manager Socket.
[    3.738828] systemd[1]: Mounting Huge Pages File System...
[    3.754802] systemd[1]: Mounting POSIX Message Queue File System...
[    3.778877] systemd[1]: Mounting Kernel Debug File System...
[    3.791365] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    3.792060] input: WaveShare WS170120 Touchscreen as /devices/platform/bus@f0000/f910000.usb/31100000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:0005.0002/input/input1
[    3.820329] hid-generic 0003:0EEF:0005.0002: input: USB HID v1.11 Device [WaveShare WS170120] on usb-xhci-hcd.0.auto-1.2/input0
[    3.824257] systemd[1]: Mounting Temporary Directory /tmp...
[    3.856193] systemd[1]: Starting Create List of Static Device Nodes...
[    3.879441] systemd[1]: Starting Load Kernel Module configfs...
[    3.903266] systemd[1]: Starting Load Kernel Module drm...
[    3.919568] systemd[1]: Starting Load Kernel Module fuse...
[    3.950336] systemd[1]: Starting Start psplash boot splash screen...
[    3.957240] fuse: init (API version 7.41)
[    3.980343] systemd[1]: Starting RPC Bind...
[    3.991153] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    4.000528] systemd[1]: Starting Journal Service...
[    4.030046] systemd[1]: Starting Load Kernel Modules...
[    4.053322] systemd[1]: Starting Generate network units from Kernel command line...
[    4.079041] cryptodev: loading out-of-tree module taints kernel.
[    4.093424] sysctl table check failed: ioctl/(null) procname is null
[    4.094868] systemd-journald[133]: Collecting audit messages is enabled.
[    4.099829] sysctl table check failed: ioctl/(null) No proc_handler
[    4.107252] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.113114] cryptodev: driver 1.14 loaded.
[    4.142152] systemd[1]: Starting Coldplug All udev Devices...
[    4.166957] EXT4-fs (mmcblk1p2): re-mounted e2641b9b-60b5-4246-bcb4-4f1e1879c28e r/w. Quota mode: none.
[    4.173797] systemd[1]: Started Start psplash boot splash screen.
[    4.201359] systemd[1]: Started RPC Bind.
[    4.215192] systemd[1]: Started Journal Service.
[    4.509374] systemd-journald[133]: Received client request to flush runtime journal.
[    4.706050] audit: type=1334 audit(1736360579.224:2): prog-id=6 op=LOAD
[    4.712790] audit: type=1334 audit(1736360579.236:3): prog-id=7 op=LOAD
[    4.719550] audit: type=1334 audit(1736360579.244:4): prog-id=8 op=LOAD
[    5.009616] audit: type=1334 audit(1736360579.528:5): prog-id=9 op=LOAD
[    5.016331] audit: type=1334 audit(1736360579.536:6): prog-id=10 op=LOAD
[    5.263178] audit: type=1334 audit(1736360579.784:7): prog-id=11 op=LOAD
[    5.286959] audit: type=1334 audit(1736360579.808:8): prog-id=12 op=LOAD
[    5.531177] input: WaveShare WS170120 as /devices/platform/bus@f0000/f910000.usb/31100000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:0EEF:0005.0002/input/input3
[    5.589086] hid-multitouch 0003:0EEF:0005.0002: input: USB HID v1.11 Device [WaveShare WS170120] on usb-xhci-hcd.0.auto-1.2/input0
[    6.842226] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[    6.916014] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
[    6.924218] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
[    6.924337] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
[    6.932000] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
[    6.939964] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
[    6.952515] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
[    6.960165] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
[    6.982729] mc: Linux media interface: v0.10
[    7.013039] videodev: Linux video capture interface: v2.00
[    7.198047] platform 79000000.r5f: configured R5F for remoteproc mode
[    7.207850] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
[    7.232365] remoteproc remoteproc0: 79000000.r5f is available
[    7.270115] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
[    7.274754] remoteproc remoteproc0: powering up 79000000.r5f
[    7.285909] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    7.286348] remoteproc remoteproc0: Booting fw image am62p-mcu-r5f0_0-fw, size 58312
[    7.298010] platform 78000000.r5f: configured R5F for IPC-only mode
[    7.315452] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
[    7.324859] vdec 30210000.video-codec: Product Code:      0x521c
[    7.331896] vdec 30210000.video-codec: Firmware Revision: 344874
[    7.348949] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node mcu-r5fss-dma-memory-region@9b800000
[    7.349512] remoteproc remoteproc1: 78000000.r5f is available
[    7.360211] virtio_rpmsg_bus virtio0: rpmsg host is online
[    7.365089] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    7.395826] remoteproc remoteproc1: attaching to 78000000.r5f
[    7.399802] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    7.410519] remoteproc remoteproc0: remote processor 79000000.r5f is now up
[    7.438785] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    7.439102] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node r5f-dma-memory@9c800000
[    7.464411] virtio_rpmsg_bus virtio1: rpmsg host is online
[    7.464612] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    7.481291] rproc-virtio rproc-virtio.2.auto: registered virtio1 (type 7)
[    7.488378] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    7.590563] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    7.651344] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    7.799383] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    7.813420] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    7.829776] i2c i2c-1: Added multiplexed i2c bus 3
[    7.876475] PVR_K:  216: Device: fd80000.gpu
[    7.882283] usb 1-1.1.1: Warning! Unlikely big volume range (=11520), cval->res is probably wrong.
[    7.891471] usb 1-1.1.1: [2] FU [PCM Playback Volume] ch = 1, val = -11520/0/1
[    7.902587] usb 1-1.1.1: Warning! Unlikely big volume range (=8191), cval->res is probably wrong.
[    7.911797] usb 1-1.1.1: [5] FU [Mic Capture Volume] ch = 1, val = 0/8191/1
[    7.936419] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
[    7.940305] PVR_K:  216: Read BVNC 36.53.104.796 from HW device registers
[    7.950063] PVR_K:  216: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[    7.965589] usbcore: registered new interface driver snd-usb-audio
[    7.986557] tidss 30200000.dss: [drm] fb1: tidssdrmfb frame buffer device
[    8.020512] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 1
[    8.371215] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.395156] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.403114] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    8.514044] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
[    8.629373] audit: type=1334 audit(1736360583.148:9): prog-id=13 op=LOAD
[    9.230563] audit: type=1334 audit(1736360583.748:10): prog-id=14 op=LOAD
[    9.242551] audit: type=1334 audit(1736360583.760:11): prog-id=15 op=LOAD
[    9.253995] audit: type=1334 audit(1736360583.760:12): prog-id=16 op=LOAD
[    9.495137] audit: type=1334 audit(1736360584.016:13): prog-id=17 op=LOAD
[    9.587306] Bluetooth: Core ver 2.22
[    9.591877] NET: Registered PF_BLUETOOTH protocol family
[    9.597339] Bluetooth: HCI device and connection manager initialized
[    9.597368] Bluetooth: HCI socket layer initialized
[    9.597377] Bluetooth: L2CAP socket layer initialized
[    9.597406] Bluetooth: SCO socket layer initialized
[    9.721044] EXT4-fs (mmcblk0p19): mounted filesystem d07a9cda-4c00-4590-acde-fb8bb0dab821 r/w with ordered data mode. Quota mode: none.
[   10.154709] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[   10.164193] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[   10.195801] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[   10.205251] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[   11.063656] EXT4-fs (mmcblk1p2): resizing filesystem from 3077569 to 15558912 blocks
[   13.504727] EXT4-fs (mmcblk1p2): resized filesystem to 15558912
[   16.381408] audit: type=1006 audit(1736360590.900:14): pid=1464 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   16.395269] audit: type=1300 audit(1736360590.900:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffff4f47c98 a2=4 a3=1 items=0 ppid=1 pid=1464 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
[   16.423180] audit: type=1327 audit(1736360590.900:14): proctitle="(systemd)"
[   18.466694] PVR_K:  1473: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
[   18.479243] PVR_K:  1473: Shader binary image 'rgx.sh.36.53.104.796' loaded
[   25.187975] audit: type=1006 audit(1736360599.708:15): pid=1508 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
[   25.201590] audit: type=1300 audit(1736360599.708:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffff0838e68 a2=1 a3=1 items=0 ppid=1 pid=1508 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
[   25.229242] audit: type=1327 audit(1736360599.708:15): proctitle="(systemd)"
[   25.251389] audit: type=1334 audit(1736360599.772:16): prog-id=18 op=LOAD
[   25.258229] audit: type=1300 audit(1736360599.772:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffce3b41d8 a2=90 a3=0 items=0 ppid=1 pid=1508 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
[   25.285099] audit: type=1327 audit(1736360599.772:16): proctitle="(systemd)"
[   25.292193] audit: type=1334 audit(1736360599.772:17): prog-id=18 op=UNLOAD
[   25.299189] audit: type=1300 audit(1736360599.772:17): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffff84ac8c60 items=0 ppid=1 pid=1508 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
[   25.325874] audit: type=1327 audit(1736360599.772:17): proctitle="(systemd)"
[   25.332981] audit: type=1334 audit(1736360599.772:18): prog-id=19 op=LOAD
[   62.201909] wlan0: regulatory prevented using AP config, downgraded
[   62.249149] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[   62.257302] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[   62.269540] wlan0: authenticated
[   62.274546] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[   62.306342] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[   62.318762] cc33xx: HE Disabled
[   62.323533] wlan0: associated
[   62.492657] cc33xx: Association complete.
[   63.968766] kauditd_printk_skb: 5 callbacks suppressed
[   63.968782] audit: type=1334 audit(1749031460.620:20): prog-id=20 op=LOAD
[   64.154777] audit: type=1334 audit(1749031460.808:21): prog-id=20 op=UNLOAD
[  166.798270] cc33xx: Connection loss work (role_id: 0).
[  166.803473] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  167.310751] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  167.835329] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  170.949268] wlan0: regulatory prevented using AP config, downgraded
[  170.996518] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  171.004676] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  171.011184] wlan0: authenticated
[  171.018375] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  171.048265] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  171.060786] cc33xx: HE Disabled
[  171.065427] wlan0: associated
[  171.225132] cc33xx: Association complete.
[  204.453811] cc33xx: Connection loss work (role_id: 0).
[  204.459022] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  204.985989] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  205.502212] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  206.030468] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  209.123116] wlan0: regulatory prevented using AP config, downgraded
[  209.170876] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  209.179081] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  209.189683] wlan0: authenticated
[  209.195785] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  209.229247] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  209.241619] cc33xx: HE Disabled
[  209.246234] wlan0: associated
[  209.381547] cc33xx: Association complete.
[  226.478546] cc33xx: Connection loss work (role_id: 0).
[  226.483797] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  227.030714] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  227.542839] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  228.059044] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  231.188345] wlan0: regulatory prevented using AP config, downgraded
[  231.235319] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  231.243478] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  231.255379] wlan0: authenticated
[  231.260264] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  231.296965] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  231.309752] cc33xx: HE Disabled
[  231.314398] wlan0: associated
[  241.323697] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  244.532035] wlan0: regulatory prevented using AP config, downgraded
[  244.579385] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  244.587537] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  244.601096] wlan0: authenticated
[  244.605193] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  244.641015] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  244.653497] cc33xx: HE Disabled
[  244.658268] wlan0: associated
[  244.819121] cc33xx: Association complete.
[  260.081813] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  263.419725] wlan0: regulatory prevented using AP config, downgraded
[  263.467147] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  263.475309] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  263.495102] wlan0: authenticated
[  263.500043] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  263.533409] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  263.545755] cc33xx: HE Disabled
[  263.550450] wlan0: associated
[  263.693784] cc33xx: Association complete.
[  301.940311] cc33xx: Connection loss work (role_id: 0).
[  301.945545] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  302.475506] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  302.998849] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  306.158396] wlan0: regulatory prevented using AP config, downgraded
[  306.205635] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  306.213796] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  306.220360] wlan0: authenticated
[  306.228509] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  306.337996] wlan0: associate with ec:75:0c:25:3e:e8 (try 2/3)
[  306.445876] wlan0: associate with ec:75:0c:25:3e:e8 (try 3/3)
[  306.557820] wlan0: association with ec:75:0c:25:3e:e8 timed out
[  310.264104] wlan0: regulatory prevented using AP config, downgraded
[  310.311358] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  310.319528] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  310.332907] wlan0: authenticated
[  310.340690] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  310.371709] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  310.384278] cc33xx: HE Disabled
[  310.389104] wlan0: associated
[  310.566325] cc33xx: Association complete.
[  327.524506] cc33xx: Connection loss work (role_id: 0).
[  327.529706] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  328.076550] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  328.600567] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  329.120605] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  332.400460] wlan0: regulatory prevented using AP config, downgraded
[  332.447766] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  332.455980] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  332.463993] wlan0: authenticated
[  332.468875] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  332.501282] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  332.513706] cc33xx: HE Disabled
[  332.518317] wlan0: associated
[  332.671382] cc33xx: Association complete.
[  357.729385] cc33xx: Connection loss work (role_id: 0).
[  357.734595] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  358.269347] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  358.781237] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  359.293192] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  362.539933] wlan0: regulatory prevented using AP config, downgraded
[  362.587140] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  362.596089] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  362.604521] wlan0: authenticated
[  362.608745] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  362.641445] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  362.653896] cc33xx: HE Disabled
[  362.658552] wlan0: associated
[  362.810597] cc33xx: Association complete.
[  379.998374] cc33xx: Connection loss work (role_id: 0).
[  380.003556] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  380.542314] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  381.058272] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  381.570119] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  384.686127] wlan0: regulatory prevented using AP config, downgraded
[  384.736581] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  384.744727] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  384.754321] wlan0: authenticated
[  384.761726] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  384.796011] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  384.808701] cc33xx: HE Disabled
[  384.813372] wlan0: associated
[  394.818760] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  398.135892] wlan0: regulatory prevented using AP config, downgraded
[  398.183270] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  398.191461] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  398.212150] wlan0: authenticated
[  398.220022] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  398.251315] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  398.263732] cc33xx: HE Disabled
[  398.268639] wlan0: associated
[  398.429819] cc33xx: Association complete.
[  465.748069] cc33xx: Connection loss work (role_id: 0).
[  465.753284] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  466.276008] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  466.791983] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  467.351885] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  470.547079] wlan0: regulatory prevented using AP config, downgraded
[  470.596177] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  470.604351] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  470.613732] wlan0: authenticated
[  470.619560] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  470.651612] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  470.664558] cc33xx: HE Disabled
[  470.669327] wlan0: associated
[  470.805425] cc33xx: Association complete.
[  489.004578] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  489.549615] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  490.069553] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  490.637514] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  493.967911] wlan0: regulatory prevented using AP config, downgraded
[  494.015198] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  494.028351] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  494.045517] wlan0: authenticated
[  494.057228] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  494.087650] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  494.105566] cc33xx: HE Disabled
[  494.110614] wlan0: associated
[  494.255714] cc33xx: Association complete.
[  522.453828] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  525.892673] wlan0: regulatory prevented using AP config, downgraded
[  525.935627] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  525.943779] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  525.956042] wlan0: authenticated
[  525.962177] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  525.994270] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  526.006710] cc33xx: HE Disabled
[  526.011323] wlan0: associated
[  526.163994] cc33xx: Association complete.
[  543.308722] cc33xx: Connection loss work (role_id: 0).
[  543.313954] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  543.844641] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  544.356518] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  547.647966] wlan0: regulatory prevented using AP config, downgraded
[  547.695372] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  547.703611] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  547.713206] wlan0: authenticated
[  547.720285] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  547.753835] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  547.766157] cc33xx: HE Disabled
[  547.771110] wlan0: associated
[  547.930066] cc33xx: Association complete.
[  566.346700] cc33xx: Connection loss work (role_id: 0).
[  566.351916] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  566.898657] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  567.410624] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  570.578860] wlan0: regulatory prevented using AP config, downgraded
[  570.626378] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  570.634544] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  570.640960] wlan0: authenticated
[  570.646412] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  570.678281] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  570.690664] cc33xx: HE Disabled
[  570.695430] wlan0: associated
[  570.844785] cc33xx: Association complete.
[  589.640971] cc33xx: Connection loss work (role_id: 0).
[  589.646173] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  590.156905] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  590.668817] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  591.180805] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  594.300050] wlan0: regulatory prevented using AP config, downgraded
[  594.347458] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  594.355671] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  594.362181] wlan0: authenticated
[  594.368565] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  594.399937] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  594.412235] cc33xx: HE Disabled
[  594.416902] wlan0: associated
[  604.422956] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  607.667955] wlan0: regulatory prevented using AP config, downgraded
[  607.715052] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  607.723265] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  607.735861] wlan0: authenticated
[  607.743599] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  607.772847] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  607.785386] cc33xx: HE Disabled
[  607.790304] wlan0: associated
[  607.970387] cc33xx: Association complete.
[  729.907512] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  733.090780] wlan0: regulatory prevented using AP config, downgraded
[  733.138098] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  733.146272] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  733.158675] wlan0: authenticated
[  733.164324] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  733.195841] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  733.208360] cc33xx: HE Disabled
[  733.212993] wlan0: associated
[  733.370277] cc33xx: Association complete.
[  750.427229] cc33xx: Connection loss work (role_id: 0).
[  750.432413] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  750.967298] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  751.483398] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  762.868610] wlan0: regulatory prevented using AP config, downgraded
[  762.918072] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  762.926226] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  762.936700] wlan0: authenticated
[  762.941346] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  762.973773] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  762.986393] cc33xx: HE Disabled
[  762.991126] wlan0: associated
[  763.131348] cc33xx: Association complete.
[  782.172496] cc33xx: Connection loss work (role_id: 0).
[  782.177689] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  782.704592] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  783.216658] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  786.425442] wlan0: regulatory prevented using AP config, downgraded
[  786.472617] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  786.480820] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  786.490269] wlan0: authenticated
[  786.497255] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  786.528637] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  786.541036] cc33xx: HE Disabled
[  786.545924] wlan0: associated
[  787.703251] cc33xx: Association complete.
[  802.655766] cc33xx: Connection loss work (role_id: 0).
[  802.660947] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[  803.175846] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  803.687959] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  804.199977] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[  807.413047] wlan0: regulatory prevented using AP config, downgraded
[  807.457479] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  807.465634] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  807.472785] wlan0: authenticated
[  807.480553] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  807.512597] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  807.525057] cc33xx: HE Disabled
[  807.529847] wlan0: associated
[  807.666545] cc33xx: Association complete.
[  871.697593] wlan0: regulatory prevented using AP config, downgraded
[  871.744876] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[  871.753032] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[  871.759712] wlan0: authenticated
[  871.765834] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[  871.798747] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[  871.811192] cc33xx: HE Disabled
[  871.815793] wlan0: associated
[  881.823923] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[  884.999140] wlan0: regulatory prevented using AP config, downgraded
[  885.269264] cc33xx: Association complete.
[ 1243.523752] cc33xx: Connection loss work (role_id: 0).
[ 1243.528957] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 1244.055824] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1244.575809] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1247.863706] wlan0: regulatory prevented using AP config, downgraded
[ 1247.911038] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1247.919233] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1247.927204] wlan0: authenticated
[ 1247.932027] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1247.966159] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 1247.978687] cc33xx: HE Disabled
[ 1247.983517] wlan0: associated
[ 1248.141858] cc33xx: Association complete.
[ 1338.498454] cc33xx: Connection loss work (role_id: 0).
[ 1338.503633] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 1339.018377] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1339.534358] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1340.050337] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1343.265518] wlan0: regulatory prevented using AP config, downgraded
[ 1343.312811] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1343.320991] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1343.328055] wlan0: authenticated
[ 1343.334202] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1343.364991] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 1343.377740] cc33xx: HE Disabled
[ 1343.382421] wlan0: associated
[ 1343.527942] cc33xx: Association complete.
[ 1360.769118] cc33xx: Connection loss work (role_id: 0).
[ 1360.774304] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 1361.297133] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1361.813133] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1362.329027] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1365.532932] wlan0: regulatory prevented using AP config, downgraded
[ 1365.580191] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1365.588383] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1365.611674] wlan0: authenticated
[ 1365.616865] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1365.670792] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 1365.683407] cc33xx: HE Disabled
[ 1365.688044] wlan0: associated
[ 1375.694399] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1378.887954] wlan0: regulatory prevented using AP config, downgraded
[ 1378.930141] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1378.938416] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1378.950784] wlan0: authenticated
[ 1378.960148] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1378.989363] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 1379.001811] cc33xx: HE Disabled
[ 1379.006736] wlan0: associated
[ 1379.169958] cc33xx: Association complete.
[ 1546.880730] cc33xx: Connection loss work (role_id: 0).
[ 1546.885986] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 1547.424808] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1547.940799] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1548.456826] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 1551.549712] wlan0: regulatory prevented using AP config, downgraded
[ 1551.591868] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1551.600085] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1551.607975] wlan0: authenticated
[ 1551.612853] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1551.724837] wlan0: associate with ec:75:0c:25:3e:e8 (try 2/3)
[ 1551.832886] wlan0: associate with ec:75:0c:25:3e:e8 (try 3/3)
[ 1551.940844] wlan0: association with ec:75:0c:25:3e:e8 timed out
[ 1555.473375] wlan0: regulatory prevented using AP config, downgraded
[ 1555.521016] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 1555.529168] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 1555.544739] wlan0: authenticated
[ 1555.548944] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 1555.582593] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 1555.595320] cc33xx: HE Disabled
[ 1555.600024] wlan0: associated
[ 1555.766924] cc33xx: Association complete.
[ 2347.389010] cc33xx: Connection loss work (role_id: 0).
[ 2347.394184] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 2347.940997] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 2348.461003] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 2351.657630] wlan0: regulatory prevented using AP config, downgraded
[ 2351.699624] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 2351.707812] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 2351.714284] wlan0: authenticated
[ 2351.721095] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 2351.751149] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 2351.763531] cc33xx: HE Disabled
[ 2351.768180] wlan0: associated
[ 2351.922943] cc33xx: Association complete.
[ 3533.201741] cc33xx: Connection loss work (role_id: 0).
[ 3533.207104] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 3533.717775] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 3534.229847] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 3537.471500] wlan0: regulatory prevented using AP config, downgraded
[ 3537.518965] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 3537.527119] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 3537.533979] wlan0: authenticated
[ 3537.541928] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 3537.572013] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=6)
[ 3537.584565] cc33xx: HE Disabled
[ 3537.589404] wlan0: associated
[ 3537.727793] cc33xx: Association complete.
[ 7157.777342] cc33xx: Connection loss work (role_id: 0).
[ 7157.782539] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 7158.309383] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7158.825380] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7159.349375] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7162.603369] wlan0: regulatory prevented using AP config, downgraded
[ 7162.650581] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7162.658832] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7162.665425] wlan0: authenticated
[ 7162.673041] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7162.781467] wlan0: associate with ec:75:0c:25:3e:e8 (try 2/3)
[ 7162.889526] wlan0: associate with ec:75:0c:25:3e:e8 (try 3/3)
[ 7162.997480] wlan0: association with ec:75:0c:25:3e:e8 timed out
[ 7166.547143] wlan0: regulatory prevented using AP config, downgraded
[ 7166.589246] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7166.597418] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7166.609665] wlan0: authenticated
[ 7166.613674] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7166.646432] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 7166.658728] cc33xx: HE Disabled
[ 7166.663599] wlan0: associated
[ 7166.831758] cc33xx: Association complete.
[ 7377.684873] cc33xx: Connection loss work (role_id: 0).
[ 7377.690073] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 7378.227720] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7378.742736] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7381.941114] wlan0: regulatory prevented using AP config, downgraded
[ 7381.988340] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7381.996569] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7382.003122] wlan0: authenticated
[ 7382.008906] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7382.120699] wlan0: associate with ec:75:0c:25:3e:e8 (try 2/3)
[ 7382.228580] wlan0: associate with ec:75:0c:25:3e:e8 (try 3/3)
[ 7382.336364] wlan0: association with ec:75:0c:25:3e:e8 timed out
[ 7385.863260] wlan0: regulatory prevented using AP config, downgraded
[ 7385.910484] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7385.918635] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7385.931157] wlan0: authenticated
[ 7385.938972] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7385.967920] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 7385.980432] cc33xx: HE Disabled
[ 7385.985073] wlan0: associated
[ 7386.140655] cc33xx: Association complete.
[ 7661.396715] cc33xx: Connection loss work (role_id: 0).
[ 7661.401971] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 7661.908875] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7662.421001] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7662.933065] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 7666.098853] wlan0: regulatory prevented using AP config, downgraded
[ 7666.146169] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7666.154323] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7666.160849] wlan0: authenticated
[ 7666.169463] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7666.277960] wlan0: associate with ec:75:0c:25:3e:e8 (try 2/3)
[ 7666.385988] wlan0: associate with ec:75:0c:25:3e:e8 (try 3/3)
[ 7666.493984] wlan0: association with ec:75:0c:25:3e:e8 timed out
[ 7670.035321] wlan0: regulatory prevented using AP config, downgraded
[ 7670.082686] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 7670.090861] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 7670.105139] wlan0: authenticated
[ 7670.111039] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 7670.142147] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 7670.154668] cc33xx: HE Disabled
[ 7670.159520] wlan0: associated
[ 7670.337102] cc33xx: Association complete.
[ 8223.325116] cc33xx: Connection loss work (role_id: 0).
[ 8223.330318] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 8223.863101] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8224.393259] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8227.432421] wlan0: regulatory prevented using AP config, downgraded
[ 8227.480476] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 8227.488641] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 8227.495058] wlan0: authenticated
[ 8227.500392] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 8227.532375] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 8227.544813] cc33xx: HE Disabled
[ 8227.549585] wlan0: associated
[ 8237.540231] wlan0: deauthenticating from ec:75:0c:25:3e:e8 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 8240.798412] wlan0: regulatory prevented using AP config, downgraded
[ 8240.845612] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 8240.853779] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 8240.866092] wlan0: authenticated
[ 8240.873859] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 8240.904538] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 8240.917522] cc33xx: HE Disabled
[ 8240.922219] wlan0: associated
[ 8241.091606] cc33xx: Association complete.
[ 8802.291529] cc33xx: Connection loss work (role_id: 0).
[ 8802.296703] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 8802.805218] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8803.318906] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8806.443016] wlan0: regulatory prevented using AP config, downgraded
[ 8806.490046] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 8806.498221] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 8806.504684] wlan0: authenticated
[ 8806.511099] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 8806.541375] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 8806.553785] cc33xx: HE Disabled
[ 8806.558472] wlan0: associated
[ 8806.701344] cc33xx: Association complete.
[ 8851.746161] cc33xx: Connection loss work (role_id: 0).
[ 8851.751344] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 8852.282437] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8852.794731] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8853.310981] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 8856.524782] wlan0: regulatory prevented using AP config, downgraded
[ 8856.572014] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 8856.580167] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 8856.586675] wlan0: authenticated
[ 8856.592612] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 8856.623486] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 8856.636237] cc33xx: HE Disabled
[ 8856.641074] wlan0: associated
[ 8856.786901] cc33xx: Association complete.
[ 9880.625734] cc33xx: Connection loss work (role_id: 0).
[ 9880.631050] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[ 9881.185688] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 9881.701684] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 9882.221555] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[ 9885.428987] wlan0: regulatory prevented using AP config, downgraded
[ 9885.476479] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[ 9885.484642] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[ 9885.491423] wlan0: authenticated
[ 9885.497177] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[ 9885.528363] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[ 9885.540953] cc33xx: HE Disabled
[ 9885.545812] wlan0: associated
[ 9885.707001] cc33xx: Association complete.
[11081.015357] cc33xx: Connection loss work (role_id: 0).
[11081.020553] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[11081.555184] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[11082.067086] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[11085.234765] wlan0: regulatory prevented using AP config, downgraded
[11085.276832] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[11085.284982] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[11085.292508] wlan0: authenticated
[11085.302158] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[11085.331657] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[11085.344114] cc33xx: HE Disabled
[11085.348748] wlan0: associated
[11085.492107] cc33xx: Association complete.
[11912.534673] cc33xx: Connection loss work (role_id: 0).
[11912.539912] wlan0: Connection to AP ec:75:0c:25:3e:e8 lost
[11913.078642] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[11913.590622] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[11914.106626] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
[11917.234187] wlan0: regulatory prevented using AP config, downgraded
[11917.281655] wlan0: authenticate with ec:75:0c:25:3e:e8 (local address=f8:fb:90:13:6c:4a)
[11917.289810] wlan0: send auth to ec:75:0c:25:3e:e8 (try 1/3)
[11917.296903] wlan0: authenticated
[11917.302576] wlan0: associate with ec:75:0c:25:3e:e8 (try 1/3)
[11917.333629] wlan0: RX AssocResp from ec:75:0c:25:3e:e8 (capab=0x11 status=0 aid=5)
[11917.346344] cc33xx: HE Disabled
[11917.351008] wlan0: associated
[11917.493381] cc33xx: Association complete.
