J784S4XEVM: Integrate tiovxisp in tisdk-base-image.
Part Number: J784S4XEVM
We are working with a J784S4 EVM board and are currently trying to integrate the tiovxisp modules into the tisdk-base-image. However, we're encountering an error when running the command gst-inspect-1.0 tiovxisp. We would appreciate any guidance on the correct steps or layers that need to be added or appended to the image to ensure proper integration of the module. Thank you in advance for your support!
  • Hi Carlos,
    Can you send the error message and what you've done to add the tiovxisp plugins to the image?
    Jared
  • This is the error:
    root@j784s4-evm:~# gst-inspect-1.0 tiovxisp
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio1.rpmsg_chrdev.-1.13
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.r[   41.821442] audit: type=1701 audit(1746025659.204:26): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=832 comm="gst-inspect-1.0" exe="/usr/bin/gst-inspect-1.0" sig=11 res=1
    pmsg_chrdev.-1.13
    _rpmsg_char_find_ctrldev: could not find t[   41.837551] audit: type=1334 audit(1746025659.220:27): prog-id=23 op=LOAD
    [   41.849810] audit: type=1334 audit(1746025659.232:28): prog-id=24 op=LOAD
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctr[   41.862119] audit: type=1334 audit(1746025659.244:29): prog-id=25 op=LOAD
    l device for virtio4.rpmsg_chrdev.-1.13
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio5.rpmsg_chrdev.-1.13
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio6.rpmsg_chrdev.-1.13
    _rpmsg_char_find_rproc: 64800000.dsp does not have any virtio devices!
    _rpmsg_char_find_rproc: 65800000.dsp does not have any virtio devices!
    _rpmsg_char_find_rproc: 66800000.dsp does not have any virtio devices!
    _rpmsg_char_find_rproc: 67800000.dsp is either not probed or not a remoteproc!
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio1.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio2.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio3.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio4.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio5.rpmsg_chrdev.-1.21
    _rpmsg_char_find_ctrldev: could not find the matching rpmsg_ctrl device for virtio6.rpmsg_chrdev.-1.21
    APP: Init ... !!!
       638.493935 s: MEM: Init ... !!!
       638.493958 s: MEM: Initialized DMA HEAP (fd=6) !!!
       638.494058 s: MEM: Init ... Done !!!
       638.494063 s: IPC: Init ... !!!
       638.519992 s: IPC: ERROR: Unable to create TX channels for CPU [mcu2_0] !!!
       638.519996 s: IPC: ERROR: Unable to create TX channels for CPU [mcu2_1] !!!
       638.519999 s: IPC: ERROR: Unable to create TX channels for CPU [mcu3_0] !!!
       638.520001 s: IPC: ERROR: Unable to create TX channels for CPU [mcu3_1] !!!
       638.520003 s: IPC: ERROR: Unable to create TX channels for CPU [mcu4_0] !!!
       638.520005 s: IPC: ERROR: Unable to create TX channels for CPU [mcu4_1] !!!
       638.520008 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_1] !!!
       638.520010 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_2] !!!
       638.520012 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_3] !!!
       638.520014 s: IPC: ERROR: Unable to create TX channels for CPU [c7x_4] !!!
       638.520016 s: IPC: Init ... Done !!!
    APP: ERROR: IPC init failed !!!
    REMOTE_SERVICE: Init ... !!!
    REMOTE_SERVICE: Init ... Done !!!
       638.521620 s: GTC Frequency = 200 MHz
    APP: Init ... Done !!!
       638.521664 s:  VX_ZONE_INIT:Enabled
       638.521667 s:  VX_ZONE_ERROR:Enabled
       638.521670 s:  VX_ZONE_WARNING:Enabled
       638.522118 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0
       638.522224 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1
       638.522295 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2
       638.522365 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3
       638.522370 s:  VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
       638.522716 s:  VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!!
    Factory Details:
      Rank                     none (0)
      Long-name                TIOVX ISP
      Klass                    Filter
    :Segmentation fault (core dumped)
    root@j784s4-evm:~# [   42.618884] audit: type=1334 audit(1746025660.004:30): prog-id=25 op=UNLOAD
    [   42.625856] audit: type=1334 audit(1746025660.004:31): prog-id=24 op=UNLOAD
    [   42.632810] audit: type=1334 audit(1746025660.004:32): prog-id=23 op=UNLOAD
      Description              Image Signal Processing using the TIOVX Modules API
    and in the local.conf I have these append:
    IMAGE_INSTALL:append = " edgeai-gst-plugins edgeai-tiovx-modules edgeai-tiovx-kernels edgeai-tiovx-apps ti-vision-apps"
    IMAGE_INSTALL:append = " gstreamer1.0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good"
  • Hi Carlos,
    Do you have the edgai dtbo (device-tree overlay) applied in the uEnv.txt?
    Jared
  • Hi Jared,
    I applied the Device Tree Overlay ti/k3-j784s4-edgeai-apps.dtbo in the uEnv.txt  file.
  • Hi Carlos,
    What is the output of:
    $ ls -l /lib/firmware/
    Jared
  • The ouput is:
    root@j784s4-evm:~# ls -l /lib/firmware/
    -rw-r--r-- 1 root root 482664 Mar 9 2018 bl32.bin
    -rw-r--r-- 1 root root 4432904 Mar 9 2018 bl32.elf
    drwxr-xr-x 2 root root 4096 Mar 9 2018 cadence
    drwxr-xr-x 2 root root 4096 Mar 9 2018 cnm
    lrwxrwxrwx 1 root root 70 Mar 9 2018 j784s4-main-r5f0_0-fw -> /usr/lib/firmware/ti-eth/j784s4/app_remoteswitchcfg_server_strip.xer5f
    lrwxrwxrwx 1 root root 77 Mar 9 2018 j784s4-main-r5f0_0-fw-sec -> /usr/lib/firmware/ti-eth/j784s4/app_remoteswitchcfg_server_strip.xer5f.signed
    -rw-r--r-- 1 root root 143360 Mar 9 2018 rgx.fw.36.53.104.796
    -rw-r--r-- 1 root root 383128 Mar 9 2018 rgx.sh.36.53.104.796
    -rw-r--r-- 1 root root 28 Mar 9 2018 tee-header_v2.bin
    -rw-r--r-- 1 root root 0 Mar 9 2018 tee-pageable_v2.bin
    -rw-r--r-- 1 root root 482664 Mar 9 2018 tee-pager_v2.bin
    -rw-r--r-- 1 root root 482664 Mar 9 2018 tee-raw.bin
    -rw-r--r-- 1 root root 482692 Mar 9 2018 tee.bin
    -rw-r--r-- 1 root root 4432904 Mar 9 2018 tee.elf
    drwxr-xr-x 3 root root 4096 Mar 9 2018 ti-eth
    lrwxrwxrwx 1 root root 46 Mar 9 2018 wave521c_k3_codec_fw.bin -> /usr/lib/firmware/cnm/wave521c_k3_codec_fw.bin
  • Hi Carlos,
    You appear to be missing the ipc_echo_test firmware. That should be built using the ti-edgeai-firmware.bb recipe. Can you add that recipe to your build?
    Jared
  • I add that recipe and it's works, thank you!!.
    Hi Carlos,
    Jared
  • I can successfully build the base image, but when I try to add the following recipes: edgeai-gst-plugins, edgeai-tiovx-modules, edgeai-tiovx-kernels, edgeai-tiovx-apps, and ti-vision-apps using IMAGE_INSTALL:append in local.conf
    the build fails and throws an error.
    NOTE: Executing Tasks
    WARNING: ti-vision-apps-10.0.0-r0_edgeai_7 do_fetch: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.00.00.04;manifest=vision_apps_yocto.xml, attempting MIRRORS if available
    ERROR: ti-vision-apps-10.0.0-r0_edgeai_7 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export REMOTE_CONTAINERS_IPC="/tmp/vscode-remote-containers-ipc-db5669c8-ab8f-4682-9438-c29d21e1e17a.sock"; export SSH_AUTH_SOCK="/tmp/vscode-ssh-auth-db5669c8-ab8f-4682-9438-c29d21e1e17a.sock"; export PATH="/home/tisdk/tisdk/sources/oe-core/scripts:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot/usr/bin/crossscripts:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/sbin:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/usr/bin:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/sbin:/home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/recipe-sysroot-native/bin:/home/tisdk/tisdk/sources/bitbake/bin:/home/tisdk/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/tisdk"; /usr/bin/env repo sync failed with exit code 1, output:
    fatal: unable to connect to git.ti.com:
    git.ti.com[0: 198.47.28.207]: errno=Connection refused
    processor-sdk/app_utils:
    processor-sdk/app_utils: sleeping 4.0 seconds before retrying
    processor-sdk/sdk_builder:
    processor-sdk/sdk_builder: sleeping 4.0 seconds before retrying
    processor-sdk/tiovx:
    processor-sdk/tiovx: sleeping 4.0 seconds before retrying
    processor-sdk/imaging:
    processor-sdk/imaging: sleeping 4.0 seconds before retrying
    processor-sdk/ti-perception-toolkit:
    processor-sdk/ti-perception-toolkit: sleeping 4.0 seconds before retrying
    processor-sdk/concerto:
    processor-sdk/concerto: sleeping 4.0 seconds before retrying
    git.ti.com[0: 198.47.28.208]: errno=Connection refused
    processor-sdk/psdk_include:
    processor-sdk/psdk_include: sleeping 4.0 seconds before retrying
    processor-sdk/video_io:
    processor-sdk/video_io: sleeping 4.0 seconds before retrying
    processor-sdk/vision_apps:
    processor-sdk/vision_apps: sleeping 4.0 seconds before retrying
    processor-sdk-vision/arm-tidl:
    processor-sdk-vision/arm-tidl: sleeping 4.0 seconds before retrying
    warning: repo is not tracking a remote branch, so it will not receive updates; run `repo init --repo-rev=stable` to fix.
    error: Cannot fetch processor-sdk/app_utils from git://git.ti.com/processor-sdk/app_utils
    error: Cannot fetch processor-sdk/sdk_builder from git://git.ti.com/processor-sdk/sdk_builder
    error: Cannot fetch processor-sdk/tiovx from git://git.ti.com/processor-sdk/tiovx
    error: Cannot fetch processor-sdk/imaging from git://git.ti.com/processor-sdk/imaging
    error: Cannot fetch processor-sdk/ti-perception-toolkit from git://git.ti.com/processor-sdk/ti-perception-toolkit
    error: Cannot fetch processor-sdk/concerto from git://git.ti.com/processor-sdk/concerto
    error: Cannot fetch processor-sdk/psdk_include from git://git.ti.com/processor-sdk/psdk_include
    error: Cannot fetch processor-sdk/video_io from git://git.ti.com/processor-sdk/video_io
    error: Cannot fetch processor-sdk/vision_apps from git://git.ti.com/processor-sdk/vision_apps
    error: Cannot fetch processor-sdk-vision/arm-tidl from git://git.ti.com/processor-sdk-vision/arm-tidl
    error: Cannot checkout processor-sdk/app_utils: ManifestInvalidRevisionError: revision refs/tags/REL.PSDK.ANALYTICS.10.00.00.04 in processor-sdk/app_utils not found
    error: in `sync`: revision refs/tags/REL.PSDK.ANALYTICS.10.00.00.04 in processor-sdk/app_utils not found
    ERROR: ti-vision-apps-10.0.0-r0_edgeai_7 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.00.00.04;manifest=vision_apps_yocto.xml')
    ERROR: Logfile of failure stored in: /home/tisdk/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.0.0/temp/log.do_fetch.4043672
    ERROR: Task (/home/tisdk/tisdk/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1'
    NOTE: Tasks Summary: Attempted 8838 tasks of which 8836 didn't need to be rerun and 1 failed.
    NOTE: Writing buildhistory
    NOTE: Writing buildhistory took: 4 seconds
    Summary: 1 task failed:
    Summary: There was 1 WARNING message.
    Summary: There were 2 ERROR messages, returning a non-zero exit code.
    I tried this:
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1512129/am62a7-failed-when-build-image-with-yocto/5822686#5822686
    but I don't works for me.
