AM62A7-Q1: AM62AX SDK Yocto build issue
Part Number: AM62A7-Q1
Hi Ti Expert,
I am trying to build a processor SDK for AM62AX version is 10_01_00. I have flowed the steps mentioned in the SDK build document but i am facing build issue.
The below link of the build document: -
https://software-dl.ti.com/processor-sdk-linux/esd/AM62AX/10_01_00/exports/docs/linux/Overview_Building_the_SDK.html
Below error i am facing: -
Sstate summary: Wanted 6073 Local 181 Mirrors 0 Missed 5892 Current 716 (2% match, 13% complete)######################## | ETA: 0:00:01
Initialising tasks: 100% |#########################################################################################################| Time: 0:00:17
NOTE: Executing Tasks
WARNING: boost-1.84.0-r0 do_fetch: Checksum failure encountered with download of boostorg.jfrog.io/.../boost_1_84_0.tar.bz2 - will attempt other sources if available
WARNING: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Failed to fetch URL repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.01.00.04;manifest=vision_apps_yocto.xml, attempting MIRRORS if available
ERROR: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1001/bus"; export SSH_AUTH_SOCK="/tmp/ssh-XXXXjvBXvm/agent.13109"; export PATH="/home/user/tisdk/sources/oe-core/scripts:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot/usr/bin/crossscripts:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/sbin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/usr/bin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/sbin:/home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/recipe-sysroot-native/bin:/home/user/tisdk/sources/bitbake/bin:/home/user/tisdk/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/user"; /usr/bin/env repo sync failed with exit code 1, output:
manifests:
fatal: unable to access 'git.ti.com/.../': gnutls_handshake() failed: Error in the pull function.
manifests: sleeping 4.0 seconds before retrying
fatal: unable to connect to git.ti.com:
git.ti.com[0: 198.47.28.207]: errno=Connection refused
processor-sdk/app_utils:
processor-sdk/app_utils: sleeping 4.0 seconds before retrying
processor-sdk/imaging:
processor-sdk/imaging: sleeping 4.0 seconds before retrying
processor-sdk/psdk_include:
processor-sdk/psdk_include: sleeping 4.0 seconds before retrying
processor-sdk-vision/arm-tidl:
processor-sdk-vision/arm-tidl: sleeping 4.0 seconds before retrying
processor-sdk/sdk_builder:
processor-sdk/sdk_builder: sleeping 4.0 seconds before retrying
git.ti.com[0: 198.47.28.208]: errno=Connection refused
processor-sdk/concerto:
processor-sdk/concerto: sleeping 4.0 seconds before retrying
processor-sdk/ti-perception-toolkit:
processor-sdk/ti-perception-toolkit: sleeping 4.0 seconds before retrying
processor-sdk/tiovx:
processor-sdk/tiovx: sleeping 4.0 seconds before retrying
processor-sdk/video_io:
processor-sdk/video_io: sleeping 4.0 seconds before retrying
processor-sdk/vision_apps:
processor-sdk/vision_apps: sleeping 4.0 seconds before retrying
warning: repo is not tracking a remote branch, so it will not receive updates; run `repo init --repo-rev=stable` to fix.
error: Cannot fetch processor-sdk/app_utils from git://git.ti.com/processor-sdk/app_utils
error: Cannot fetch processor-sdk/imaging from git://git.ti.com/processor-sdk/imaging
error: Cannot fetch processor-sdk/psdk_include from git://git.ti.com/processor-sdk/psdk_include
error: Cannot fetch processor-sdk-vision/arm-tidl from git://git.ti.com/processor-sdk-vision/arm-tidl
error: Cannot fetch processor-sdk/sdk_builder from git://git.ti.com/processor-sdk/sdk_builder
error: Cannot fetch processor-sdk/concerto from git://git.ti.com/processor-sdk/concerto
error: Cannot fetch processor-sdk/ti-perception-toolkit from git://git.ti.com/processor-sdk/ti-perception-toolkit
error: Cannot fetch processor-sdk/tiovx from git://git.ti.com/processor-sdk/tiovx
error: Cannot fetch processor-sdk/video_io from git://git.ti.com/processor-sdk/video_io
error: Cannot fetch processor-sdk/vision_apps from git://git.ti.com/processor-sdk/vision_apps
error: Cannot checkout processor-sdk/app_utils: ManifestInvalidRevisionError: revision refs/tags/REL.PSDK.ANALYTICS.10.01.00.04 in processor-sdk/app_utils not found
error: in `sync`: revision refs/tags/REL.PSDK.ANALYTICS.10.01.00.04 in processor-sdk/app_utils not found
ERROR: ti-vision-apps-10.1.0-r0_edgeai_10 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.10.01.00.04;manifest=vision_apps_yocto.xml')
ERROR: Logfile of failure stored in: /home/user/tisdk/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/10.1.0/temp/log.do_fetch.1155193
ERROR: Task (/home/user/tisdk/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1'
is there any way to solve this problem.
Satyajeet Singh
