TDA4VH-Q1: How to Interpret AWB Tuning Output Graphs
Part Number: TDA4VH-Q1
I am trying to understand the results of the output of AWB tuning done using the DCC tool and have 2 questions about the gray level graphs and the "Measured and interpolated reference for all gray levels". I am using VPAC3 for J784S4.
Questions 1: I posted the graphs for all 4 gray levels below. In each graph I see 4 distinct lines highlighted by the pink line. What exactly are these 4 distinct lines representing?
Question 2: The "Measured and interpolated reference for all gray levels" graph also has 4 distinct lines. What do each of those represent? What do the colors used (green, blue, red and pink) for each lines mean? Specifically is there a reason why green, blue, red and pink were chosen?
Thank you for your help.
  • Hi Vaibhav,
    Your calibration does not look good.
    Please follow the AWB plugin guide carefully.
    Most likely, you have not set the black level correctly.
    Those are for measured on 4 different gray patches of the color checker.
    The color has no specific meaning in terms of AWB calibration.
  • Hi Gang. Thank you for the clarification.
    So just to be clear the lines in the gray level graphs 1 - 4 are lines for each gray patch right? If that is the case should each gray graph have only 1 line? Why does Gray1_out_of_4 have 4 lines?
    For the Measured and interpolated graph I am assuming based on the description each line is supposed to represent one of the gray levels right? This graph simply is meant to combine all gray 1 - 4 graph data right?
  • Hi Vaibhav,
    I believe all of the 4 lines for main references are plotted together in these 4 graphs.
    Only additional references are plotted separately.
    Yes, it is for plotting all 4 lines together.
