Part Number: TDA3XEVM
vout
if(displayType == CHAINS_DISPLAY_TYPE_LCD_7_INCH)
pPrm->deviceId = DISPLAYCTRL_LINK_USE_LCD;
pVInfo->vencId = SYSTEM_DCTRL_DSS_VENC_LCD1;
pVInfo->outputPort = SYSTEM_DCTRL_DSS_DPI1_OUTPUT;
if ((BSP_PLATFORM_SOC_ID_TDA2EX == Bsp_platformGetSocId()) &&
(BSP_PLATFORM_PACKAGE_TYPE_17x17 == Bsp_platformGetPackageType()))
/* In case of TDA2EX and Package is 17 X 17, LCD is on DPI 3 */
pVInfo->vencId = SYSTEM_DCTRL_DSS_VENC_LCD3;
pVInfo->outputPort = SYSTEM_DCTRL_DSS_DPI3_OUTPUT;
pVInfo->vencOutputInfo.vsPolarity = SYSTEM_DCTRL_POLARITY_ACT_LOW;
pVInfo->vencOutputInfo.hsPolarity = SYSTEM_DCTRL_POLARITY_ACT_LOW;
/* Below are of dont care for EVM LCD */
pVInfo->vencOutputInfo.fidPolarity = SYSTEM_DCTRL_POLARITY_ACT_LOW;
pVInfo->vencOutputInfo.actVidPolarity = SYSTEM_DCTRL_POLARITY_ACT_LOW;
pVInfo->mInfo.standard = SYSTEM_STD_CUSTOM;
pVInfo->mInfo.width = displayWidth;
pVInfo->mInfo.height = displayHeight;
pVInfo->mInfo.scanFormat = SYSTEM_SF_PROGRESSIVE;
pVInfo->mInfo.pixelClock = 29232u;
pVInfo->mInfo.fps = 60U;
pVInfo->mInfo.hFrontPorch = 40u;
pVInfo->mInfo.hBackPorch = 40u;
pVInfo->mInfo.hSyncLen = 48u;
pVInfo->mInfo.vFrontPorch = 13u;
pVInfo->mInfo.vBackPorch = 29u;
pVInfo->mInfo.vSyncLen = 3u;
pVInfo->vencDivisorInfo.divisorLCD = 1;
if(Bsp_platformIsTda3xxFamilyBuild())
pVInfo->vencDivisorInfo.divisorPCD = 1;
else
pVInfo->vencDivisorInfo.divisorPCD = 4;
pVInfo->vencOutputInfo.dataFormat = SYSTEM_DF_RGB24_888;
pVInfo->vencOutputInfo.dvoFormat =
SYSTEM_DCTRL_DVOFMT_GENERIC_DISCSYNC;
pVInfo->vencOutputInfo.videoIfWidth = SYSTEM_VIFW_24BIT;
pVInfo->vencOutputInfo.pixelClkPolarity = SYSTEM_DCTRL_POLARITY_ACT_HIGH;
pVInfo->vencOutputInfo.aFmt = SYSTEM_DCTRL_A_OUTPUT_MAX;
/* Configure overlay params */
ovlyPrms->vencId = SYSTEM_DCTRL_DSS_VENC_LCD1;
ovlyPrms->vencId = SYSTEM_DCTRL_DSS_VENC_LCD3;
I set the display type as above to set the vout pixelclock.
After the update, 149mhz is observed when measuring the vout clock.
It seems that the above setting is not reflected.
