build Gingerbread with dsp error!
Hi,all.
I get Gingerbread with repo from rowboat ,and when I want compie it ,i input
make TARGET_PRODUCT=beagerboard OMAPES=5.x,
after a while, it complained an error:
target Dex:AccountAndSyncSettings
target Dex:ApplicationsProvider
packages/apps/Calculator/src/com/android/calculator2/HistoryAdapter.java:65: cannot access org.xmlpull.v1.XmlPullParser   bad class file: org/xmlpull/v1/XmlPullParser.class(org/xmlpull/v1:XmlPullParser.class)   unable to access file: corrupted zip file   Please remove or make sure it appears in the correct subdirectory of the classpath.               view = mInflater.inflate(R.layout.history_item, parent, false);                               ^   1 error   make: *** [out/target/common/obj/APPS/DeskClock_intermediates/classes-full-debug.jar] Error 41
 It seemed something is wrong when the build system want to find xmlpull, but I can find the source code of xmlpull.
thank you !
