Part Number: AM5708
Looking at the AM571x IDK, a pull-up or pull-down resistor is connected to determine the SYSBOOT logic.
Would it be okay to use a combination of a dip switch and a pull-up resistor to determine the logic?
Connect a pull-up resistor to one side of the dip switch and connect the other to ground.
The dip switch is ON: low, OFF: high.
This is because it is necessary to change the BOOT source, and changing the resistor is not recommended.
Hiroshi Yamada
