"Enter path where SD card tarballs were downloaded" Can't create SD CARD
Part Number: TDA4VH-Q1
   Partitioning is now done
   Continue to install filesystem or select 'n' to safe exit
   **Warning** Continuing will erase files any files in the partitions
Would you like to continue? [y/n] : y
Enter path where SD card tarballs were downloaded :
Directory exists
This directory contains:
add-to-group.sh  create-sdcard.sh  setup-host-check.sh  setup-package-install.sh  setup-tftp.sh
common.sh        README            setup-minicom.sh     setup-targetfs-nfs.sh     setup-uboot-env.sh
Is this correct? [y/n] : y
Could not find boot_partition.tar.xz as expected.  Please
point to the directory containing the boot_partition.tar.xz
Hi Team,
   I wonder where is the SD card tarballs ?  I' m  using 10.00 version of SDK.
Best regards
Kong Xiangxu
  • Hi Kong,
    Can you provide the steps you followed with the entire logs as well so that we can track it down.
    Gokul
    This script will create a bootable SD card from custom or pre-built binaries.
    The script must be run with root permissions and from the bin directory of
    the SDK
    Example:
     $ sudo ./create-sdcard.sh
    Formatting can be skipped if the SD card is already formatted and
    partitioned properly.
    Available Drives to write images to:
    #  major   minor    size   name
    1:   8       32   62367744 sdc
    Enter Device Number or n to exit: 1
    sdc was selected
                    **********WARNING**********
            Selected Device is greater then 16GB
            Continuing past this point will erase data from device
            Double check that this is the correct SD Card
    Would you like to continue [y/n] : y
    /dev/sdc is an sdx device
    Unmounting the sdc drives
     unmounted /dev/sdc1
    Current size of sdc1 131072 bytes
    Current size of sdc2 2621440 bytes
    Current size of sdc3 59614208 bytes
       Detected device has 3 partitions already
       Re-partitioning will allow the choice of 2 or 3 partitions
    Would you like to re-partition the drive anyways [y/n] : n
    Skipping partitioning
    Directory exists
    Enter path where SD card tarballs were downloaded : ^C
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-j784s4/10_00_00_08/exports/docs/linux/Overview/Processor_SDK_Linux_create_SD_card.html#processor-sdk-linux-create-sd-card
    #!/bin/bash
    # Authors:
    #    LT Thomas <ltjr@ti.com>
    #    Chase Maupin
    #    Franklin Cooper Jr.
    # create-sdcard.sh v0.3
    # This distribution contains contributions or derivatives under copyright
    # as follows:
    # Copyright (c) 2023, Texas Instruments Incorporated
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without
    # modification, are permitted provided that the following conditions
    # are met:
    # - Redistributions of source code must retain the above copyright notice,
    #   this list of conditions and the following disclaimer.
    # - Redistributions in binary form must reproduce the above copyright
    #   notice, this list of conditions and the following disclaimer in the
    #   documentation and/or other materials provided with the distribution.
    # - Neither the name of Texas Instruments nor the names of its
    #   contributors may be used to endorse or promote products derived
    #   from this software without specific prior written permission.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    # "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
    # TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    # PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
    # CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
    # EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
    # PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
    # PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
    # LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    # OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
    # ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    # Force locale language to be set to English. This avoids issues when doing
    # text and string processing.
    export LANG=C
    # Determine the absolute path to the executable
    # EXE will have the PWD removed so we can concatenate with the PWD safely
    PWD=`pwd`
    EXE=`echo $0 | sed s=$PWD==`
    EXEPATH="$PWD"/"$EXE"
    clear
    cat << EOM
    the SDK
    Example:
    EOM
    AMIROOT=`whoami | awk {'print $1'}`
    if [ "$AMIROOT" != "root" ] ; then
    	echo "	**** Error *** must run script with sudo"
    	echo ""
    	exit
    fi
    THEPWD=$EXEPATH
    PARSEPATH=`echo $THEPWD | grep -o '.*ti-processor-sdk-linux.*.[0-9]/'`
    if [ "$PARSEPATH" != "" ] ; then
    PATHVALID=1
    else
    PATHVALID=0
    fi
    . $PARSEPATH/bin/common.sh
    if [ ! -z "$1" ]; then
    	platform=$1
    fi
    #Precentage function
    untar_progress ()
        TARBALL=$1;
        DIRECTPATH=$2;
        if grep -q .tar.xz <<< "$TARBALL"; then
            BLOCKING_FACTOR=$(($(xz --robot --list ${TARBALL} | grep 'totals' | awk '{print $5}') / 51200 + 1));
            tar --blocking-factor=${BLOCKING_FACTOR} --checkpoint=1 --checkpoint-action='ttyout=Written %u%  \r' -Jxf ${TARBALL} -C ${DIRECTPATH}
        elif grep -q .tar.gz <<< "$TARBALL"; then
            tar --checkpoint=1 --checkpoint-action='ttyout=Written %u%  \r' -zxf ${TARBALL} -C ${DIRECTPATH}
        else
            echo "untar: Unrecognised tarball format $TARBALL"
        fi
    #copy/paste programs
    cp_progress ()
    	CURRENTSIZE=0
    	while [ $CURRENTSIZE -lt $TOTALSIZE ]
    	do
    		TOTALSIZE=$1;
    		TOHERE=$2;
    		CURRENTSIZE=`sudo du -c $TOHERE | grep total | awk {'print $1'}`
    		echo -e -n "$CURRENTSIZE /  $TOTALSIZE copied \r"
    		sleep 1
    	done
    check_for_sdcards()
            # find the avaible SD cards
            ROOTDRIVE=`mount | grep 'on / ' | awk {'print $1'} |  cut -c6-8`
            PARTITION_TEST=`cat /proc/partitions | grep -v $ROOTDRIVE | grep '\<sd.\>\|\<mmcblk.\>' | grep -n ''`
            if [ "$PARTITION_TEST" = "" ]; then
    	        echo -e "Please insert a SD card to continue\n"
    	        while [ "$PARTITION_TEST" = "" ]; do
    		        read -p "Type 'y' to re-detect the SD card or 'n' to exit the script: " REPLY
    		        if [ "$REPLY" = 'n' ]; then
    		            exit 1
    		        fi
    	        done
            fi
    find_boot_files()
    	[ ! -z "$SOC" ] && [ ! -z "$SOC_TYPE" ] && PLATFORM_SUFFIX="-${SOC}-${SOC_TYPE}-evm"
    	MLO=`ls $1 | grep MLO | awk {'print $1'}`
    	SPL_A72=`ls $1 | grep tispl.bin | awk {'print $1'}`
    	SPL_R5=`ls $1 | grep tiboot3${PLATFORM_SUFFIX}.bin | awk {'print $1'}`
    	SYSFW=`ls $1  | grep sysfw${PLATFORM_SUFFIX}.itb | awk {'print $1'}`
    	BOOTIMG=`ls $1 | grep u-boot.img | awk {'print $1'}`
    	BOOTBIN=`ls $1 | grep u-boot.bin | awk {'print $1'}`
    	BOOTUENV=`ls $1 | grep uEnv.txt | awk {'print $1'}`
    	WIFICFG=`ls $1 | grep wificfg | awk {'print $1'}`
    populate_3_partitions() {
        ENTERCORRECTLY="0"
    	while [ $ENTERCORRECTLY -ne 1 ]
    	do
    		read -e -p 'Enter path where SD card tarballs were downloaded : '  TARBALLPATH
    		echo ""
    		ENTERCORRECTLY=1
    		if [ -d $TARBALLPATH ]
    		then
    			echo "Directory exists"
    			echo ""
    			echo "This directory contains:"
    			ls $TARBALLPATH
    			echo ""
    			read -p 'Is this correct? [y/n] : ' ISRIGHTPATH
    				case $ISRIGHTPATH in
    				"y" | "Y") ;;
    				"n" | "N" ) ENTERCORRECTLY=0;continue;;
    				*)  echo "Please enter y or n";ENTERCORRECTLY=0;continue;;
    				esac
    		else
    			echo "Invalid path make sure to include complete path"
    			ENTERCORRECTLY=0
                continue
    		fi
            # Check that tarballs were found
            if [ ! -e "$TARBALLPATH""/boot_partition.tar.xz" ]
            then
                echo "Could not find boot_partition.tar.xz as expected.  Please"
                echo "point to the directory containing the boot_partition.tar.xz"
                ENTERCORRECTLY=0
                continue
            fi
            if [ ! -e "$TARBALLPATH""/rootfs_partition.tar.xz" ]
            then
                echo "Could not find rootfs_partition.tar.xz as expected.  Please"
                echo "point to the directory containing the rootfs_partition.tar.xz"
                ENTERCORRECTLY=0
                continue
            fi
            if [ ! -e "$TARBALLPATH""/start_here_partition.tar.xz" ]
            then
                echo "Could not find start_here_partition.tar.xz as expected.  Please"
                echo "point to the directory containing the start_here_partition.tar.xz"
                ENTERCORRECTLY=0
                continue
            fi
    	done
            # Make temporary directories and untar mount the partitions
            mkdir $PWD/boot
            mkdir $PWD/rootfs
            mkdir $PWD/start_here
            mkdir $PWD/tmp
            mount -t vfat ${DRIVE}${P}1 boot
            mount -t ext4 ${DRIVE}${P}2 rootfs
            mount -t ext4 ${DRIVE}${P}3 start_here
            # Remove any existing content in case the partitions were not
            # recreated
            sudo rm -rf boot/*
            sudo rm -rf rootfs/*
            sudo rm -rf start_here/*
            # Extract the tarball contents.
    cat << EOM
            Extracting boot partition tarball
    EOM
            untar_progress $TARBALLPATH/boot_partition.tar.xz tmp/
            if [ -e "./tmp/MLO" ]
            then
                cp ./tmp/MLO boot/
            fi
            cp -rf ./tmp/* boot/
    cat << EOM
            Extracting rootfs partition tarball
    EOM
            untar_progress $TARBALLPATH/rootfs_partition.tar.xz rootfs/
    cat << EOM
            Extracting start_here partition to temp directory
    EOM
            rm -rf tmp/*
            untar_progress $TARBALLPATH/start_here_partition.tar.xz tmp/
    cat << EOM
            Copying Contents to START_HERE
    EOM
            TOTALSIZE=`sudo du -c tmp/* | grep total | awk {'print $1'}`
            cp -rf tmp/* start_here/ &
            cp_progress $TOTALSIZE start_here/
            sync;sync
            # Fix up the START_HERE partitoin permissions
            chown nobody -R start_here
            chgrp nogroup -R start_here
            umount boot rootfs start_here
            sync;sync
            # Clean up the temp directories
            rm -rf boot rootfs start_here tmp
    ROOTDRIVE=`mount | grep 'on / ' | awk {'print $1'} |  cut -c6-9`
    if [ "$ROOTDRIVE" = "root" ]; then
        ROOTDRIVE=`readlink /dev/root | cut -c1-3`
    else
        ROOTDRIVE=`echo $ROOTDRIVE | cut -c1-3`
    fi
    # Check for available mounts
    check_for_sdcards
    echo -e "\nAvailable Drives to write images to: \n"
    echo "#  major   minor    size   name "
    echo " "
    DEVICEDRIVENUMBER=
    while true;
    do
    	read -p 'Enter Device Number or 'n' to exit: ' DEVICEDRIVENUMBER
    	echo " "
            if [ "$DEVICEDRIVENUMBER" = 'n' ]; then
                    exit 1
            fi
            if [ "$DEVICEDRIVENUMBER" = "" ]; then
                    # Check to see if there are any changes
                    check_for_sdcards
                    echo -e "These are the Drives available to write images to:"
                    echo " "
                   continue
            fi
    	DEVICEDRIVENAME=`cat /proc/partitions | grep -v $ROOTDRIVE | grep '\<sd.\>\|\<mmcblk.\>' | grep -n '' | grep "${DEVICEDRIVENUMBER}:" | awk '{print $5}'`
    	if [ -n "$DEVICEDRIVENAME" ]
    	then
    	        DRIVE=/dev/$DEVICEDRIVENAME
    	        DEVICESIZE=`cat /proc/partitions | grep -v $ROOTDRIVE | grep '\<sd.\>\|\<mmcblk.\>' | grep -n '' | grep "${DEVICEDRIVENUMBER}:" | awk '{print $4}'`
    		break
    	else
    		echo -e "Invalid selection!"
                    check_for_sdcards
                    echo -e "These are the only Drives available to write images to: \n"
                    echo " "
    	fi
    done
    echo "$DEVICEDRIVENAME was selected"
    #Check the size of disk to make sure its under 16GB
    if [ $DEVICESIZE -gt 17000000 ] ; then
    cat << EOM
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -p 'Would you like to continue [y/n] : ' SIZECHECK
    		echo ""
    		echo " "
    		ENTERCORRECTLY=1
    		case $SIZECHECK in
    		"y")  ;;
    		"n")  exit;;
    		*)  echo "Please enter y or n";ENTERCORRECTLY=0;;
    		esac
    		echo ""
    	done
    fi
    echo ""
    NUM_OF_DRIVES=`df | grep -c $DEVICEDRIVENAME`
    # This if statement will determine if we have a mounted sdX or mmcblkX device.
    # If it is mmcblkX, then we need to set an extra char in the partition names, 'p',
    # to account for /dev/mmcblkXpY labled partitions.
    if [[ ${DEVICEDRIVENAME} =~ ^sd. ]]; then
    	echo "$DRIVE is an sdx device"
    	P=''
    else
    	echo "$DRIVE is an mmcblkx device"
    	P='p'
    fi
    if [ "$NUM_OF_DRIVES" != "0" ]; then
            echo "Unmounting the $DEVICEDRIVENAME drives"
            for ((c=1; c<="$NUM_OF_DRIVES"; c++ ))
            do
                    unmounted=`df | grep '\<'$DEVICEDRIVENAME$P$c'\>' | awk '{print $1}'`
                    if [ -n "$unmounted" ]
                    then
                         echo " unmounted ${DRIVE}$P$c"
                         sudo umount -f ${DRIVE}$P$c
                    fi
            done
    fi
    # Refresh this variable as the device may not be mounted at script instantiation time
    # This will always return one more then needed
    NUM_OF_PARTS=`cat /proc/partitions | grep -v $ROOTDRIVE | grep -c $DEVICEDRIVENAME`
    for ((c=1; c<"$NUM_OF_PARTS"; c++ ))
    do
            SIZE=`cat /proc/partitions | grep -v $ROOTDRIVE | grep '\<'$DEVICEDRIVENAME$P$c'\>'  | awk '{print $3}'`
            echo "Current size of $DEVICEDRIVENAME$P$c $SIZE bytes"
    done
    # check to see if the device is already partitioned
    for ((  c=1; c<5; c++ ))
    do
    	eval "SIZE$c=`cat /proc/partitions | grep -v $ROOTDRIVE | grep '\<'$DEVICEDRIVENAME$P$c'\>'  | awk '{print $3}'`"
    done
    PARTITION="0"
    if [ -n "$SIZE1" -a -n "$SIZE2" ] ; then
    	if  [ "$SIZE1" -gt "128000" -a "$SIZE2" -gt "700000" ]
    	then
    		PARTITION=1
    		if [ -z "$SIZE3" -a -z "$SIZE4" ]
    		then
    			#Detected 2 partitions
    			PARTS=2
    		elif [ "$SIZE3" -gt "1000" -a -z "$SIZE4" ]
    		then
    			#Detected 3 partitions
    			PARTS=3
    		else
    			echo "SD Card is not correctly partitioned"
    			PARTITION=0
    		fi
    	fi
    else
    	PARTITION=0
    	PARTS=0
    fi
    #Partition is found
    if [ "$PARTITION" -eq "1" ]
    then
    cat << EOM
       Detected device has $PARTS partitions already
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -p 'Would you like to re-partition the drive anyways [y/n] : ' CASEPARTITION
    		echo ""
    		echo " "
    		ENTERCORRECTLY=1
    		case $CASEPARTITION in
    		"y")  echo "Now partitioning $DEVICEDRIVENAME ...";PARTITION=0;;
    		"n")  echo "Skipping partitioning";;
    		esac
    		echo ""
    	done
    fi
    #Partition is not found, choose to partition 2 or 3 segments
    if [ "$PARTITION" -eq "0" ]
    then
    cat << EOM
    	Select 2 partitions if only need boot and rootfs (most users).
    	Select 3 partitions if need SDK & other content on SD card.  This is
            usually used by device manufacturers with access to partition tarballs.
    	****WARNING**** continuing will erase all data on $DEVICEDRIVENAME
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -p 'Number of partitions needed [2/3] : ' CASEPARTITIONNUMBER
    		echo ""
    		echo " "
    		ENTERCORRECTLY=1
    		case $CASEPARTITIONNUMBER in
    		"2")  echo "Now partitioning $DEVICEDRIVENAME with 2 partitions...";PARTITION=2;;
    		"3")  echo "Now partitioning $DEVICEDRIVENAME with 3 partitions...";PARTITION=3;;
    		"n")  exit;;
    		*)  echo "Please enter 2 or 3";ENTERCORRECTLY=0;;
    		esac
    		echo " "
    	done
    fi
    #Section for partitioning the drive
    #create 3 partitions
    if [ "$PARTITION" -eq "3" ]
    then
    # set the PARTS value as well
    PARTS=3
    cat << EOM
    		Now making 3 partitions
    EOM
    dd if=/dev/zero of=$DRIVE bs=1024 count=1024
    SIZE=`fdisk -l $DRIVE | grep Disk | awk '{print $5}'`
    echo DISK SIZE - $SIZE bytes
    cat << END | fdisk $DRIVE
    n
    p
    1
    +128M
    n
    p
    2
    +2.4G
    n
    p
    3
    t
    1
    c
    a
    1
    w
    END
    cat << EOM
    		Partitioning Boot
    EOM
    	mkfs.vfat -F 32 -n "boot" ${DRIVE}${P}1
    cat << EOM
    		Partitioning Rootfs
    EOM
    	mkfs.ext4 -L "rootfs" ${DRIVE}${P}2
    cat << EOM
    		Partitioning START_HERE
    EOM
    	mkfs.ext4 -L "START_HERE" ${DRIVE}${P}3
    	sync
    	sync
    #create only 2 partitions
    elif [ "$PARTITION" -eq "2" ]
    then
    # Set the PARTS value as well
    PARTS=2
    cat << EOM
    		Now making 2 partitions
    EOM
    n
    p
    1
    +128M
    n
    p
    2
    t
    1
    c
    a
    1
    w
    END
    cat << EOM
    		Partitioning Boot
    EOM
    cat << EOM
    		Partitioning rootfs
    EOM
    	mkfs.ext4 -L "root" ${DRIVE}${P}2
    	sync
    	sync
    	INSTALLSTARTHERE=n
    fi
    #Break between partitioning and installing file system
    cat << EOM
    EOM
    ENTERCORRECTLY=0
    do
    	read -p 'Would you like to continue? [y/n] : ' EXITQ
    	echo ""
    	echo " "
    	ENTERCORRECTLY=1
    	case $EXITQ in
    	"y") ;;
    	"n") exit;;
    	esac
    done
    # If this is a three partition card then we will jump to a function to
    # populate the three partitions and then exit the script.  If not we
    # go on to prompt the user for input on the two partitions
    if [ "$PARTS" -eq "3" ]
    then
        exit 0
    fi
    #Add directories for images
    export START_DIR=$PWD
    mkdir -p $START_DIR/tmp
    export PATH_TO_SDBOOT=boot
    export PATH_TO_SDROOTFS=root
    export PATH_TO_TMP_DIR=$START_DIR/tmp
    echo " "
    echo "Mount the partitions "
    mkdir -p $PATH_TO_SDBOOT
    mkdir -p $PATH_TO_SDROOTFS
    sudo mount -t vfat ${DRIVE}${P}1 $PATH_TO_SDBOOT/
    sudo mount -t ext4 ${DRIVE}${P}2 $PATH_TO_SDROOTFS/
    echo " "
    echo "Emptying partitions "
    echo " "
    sudo rm -rf  $PATH_TO_SDBOOT/*
    sudo rm -rf  $PATH_TO_SDROOTFS/*
    echo ""
    echo "Syncing...."
    echo ""
    sync
    sync
    sync
    cat << EOM
    	Choose file path to install from
    	1 ) Install pre-built images from SDK
    	2 ) Enter in custom boot and rootfs file paths
    EOM
    ENTERCORRECTLY=0
    do
    	read -p 'Choose now [1/2] : ' FILEPATHOPTION
    	echo ""
    	echo " "
    	ENTERCORRECTLY=1
    	case $FILEPATHOPTION in
    	"1") echo "Will now install from SDK pre-built images";;
    	"2") echo "";;
    	*)  echo "Please enter 1 or 2";ENTERCORRECTLY=0;;
    	esac
    done
    # SDK DEFAULTS
    if [ $FILEPATHOPTION -eq 1 ] ; then
    	#check that in the right directory
    	THEEVMSDK=`echo $PARSEPATH | grep -o 'ti-processor-sdk-linux-.*[0-9]'`
    	if [ $PATHVALID -eq 1 ]; then
    	echo "now installing:  $THEEVMSDK"
    	else
    	echo "no SDK PATH found"
    	ENTERCORRECTLY=0
    		do
    			read -e -p 'Enter path to SDK : '  SDKFILEPATH
    			echo ""
    			ENTERCORRECTLY=1
    			if [ -d $SDKFILEPATH ]
    			then
    				echo ""
    				PARSEPATH=`echo $SDKFILEPATH`
    				#echo $PARSEPATH
    				PATHVALID=1
    				else
    				PATHVALID=0
    				fi
    				#echo $PATHVALID
    				if [ $PATHVALID -eq 1 ] ; then
    				THEEVMSDK=`echo $SDKFILEPATH`
    				echo "Is this the correct SDK: $THEEVMSDK"
    				echo ""
    					"y") ;;
    					"n") ENTERCORRECTLY=0;;
    					esac
    				else
    				echo "Invalid SDK path make sure to include ti-processor-sdk-linux-xxxx"
    				ENTERCORRECTLY=0
    				fi
    			else
    				ENTERCORRECTLY=0
    			fi
    		done
    	fi
    	#check that files are in SDK
    	BOOTFILEPATH="$PARSEPATH/board-support/prebuilt-images"
    	find_boot_files $BOOTFILEPATH
    	KERNELIMAGE=`ls $BOOTFILEPATH | grep [uz]Image | awk {'print $1'}`
    	#rootfs
    	ROOTFILEPARTH="$PARSEPATH/filesystem"
    	#Make sure there is only 1 tar
    	CHECKNUMOFTAR=`ls $ROOTFILEPARTH | grep "tisdk.*image" | grep 'tar.xz' | grep -n '' | grep '2:' | awk {'print $1'}`
    	if [ -n "$CHECKNUMOFTAR" ]
    	then
    cat << EOM
       Multiple rootfs Tarballs found
    EOM
    		COUNT=`ls $ROOTFILEPARTH | grep "tisdk.*image" | grep 'tar.xz' | grep -n '' | awk {'print $1'} | wc -l`
    		while :
    		do
    			ls --sort=size $ROOTFILEPARTH | grep "tisdk.*image" | grep 'tar.xz' | grep -n '' | awk {'print "	" , $1'}
    			read -p "Enter Number of rootfs Tarball: " TARNUMBER
    			echo
    			if [ -z "${TARNUMBER//[1-$COUNT]}" ] && [ -n "$TARNUMBER" ] ; then
    				break
    			else
    				echo "Invalid selection: '$TARNUMBER'. Please use values from 1 to $COUNT"
    			fi
    			echo
    		done
    		FOUNDTARFILENAME=`ls --sort=size $ROOTFILEPARTH | grep "image" | grep 'tar.xz' | grep -n '' | grep "${TARNUMBER}:" | cut -c3- | awk {'print$1'}`
    		ROOTFSTAR=$FOUNDTARFILENAME
    		TARDEVICENAME=`ls $ROOTFILEPARTH | grep "tisdk-default-image" | grep 'tar.xz' | awk -F - {'print $4'}`
    		TARIMAGETYPE=`ls $ROOTFILEPARTH | grep "tisdk-default-image" | grep 'tar.xz' | awk -F - {'print $2'}`
    	else
    		ROOTFSTAR=`ls  $ROOTFILEPARTH | grep "tisdk.*image" | grep 'tar.xz' | awk {'print $1'}`
    	fi
    	ROOTFSUSERFILEPATH=$ROOTFILEPARTH/$ROOTFSTAR
    	BOOTPATHOPTION=1
    	ROOTFSPATHOPTION=2
    elif [ $FILEPATHOPTION -eq 2  ] ; then
    cat << EOM
      For U-boot and MLO
      If files are located in Tarball write complete path including the file name.
          e.x. $:  /home/user/MyCustomTars/boot.tar.xz
      If files are located in a directory write the directory path
          e.x. $: /ti-processor-sdk-linux/board-support/prebuilt-images/
      NOTE: Not all platforms will have an MLO file and this file can
            be ignored for platforms that do not support an MLO.
      Update: The proper location for the kernel image and device tree
              files have moved from the boot partition to the root filesystem.
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -e -p 'Enter path for Boot Partition : '  BOOTUSERFILEPATH
    		echo ""
    		ENTERCORRECTLY=1
    		if [ -f $BOOTUSERFILEPATH ]
    		then
    			echo "File exists"
    			echo ""
    		elif [ -d $BOOTUSERFILEPATH ]
    		then
    			echo ""
    			ls $BOOTUSERFILEPATH
    			echo ""
    				"y") ;;
    				esac
    		else
    			ENTERCORRECTLY=0
    		fi
    	done
    cat << EOM
       For Kernel Image and Device Trees files
        What would you like to do?
         1) Reuse kernel image and device tree files found in the selected rootfs.
         2) Provide a directory that contains the kernel image and device tree files
            to be used.
    EOM
    ENTERCORRECTLY=0
    do
    	read -p 'Choose option 1 or 2 : ' CASEOPTION
    	echo ""
    	echo " "
    	ENTERCORRECTLY=1
    	case $CASEOPTION in
    		"1")  echo "Reusing kernel and dt files from the rootfs's boot directory";KERNELFILESOPTION=1;;
    		"2")  echo "Choosing a directory that contains the kernel files to be used";KERNELFILESOPTION=2;;
    		"n")  exit;;
    	esac
    	echo " "
    done
    if [ $KERNELFILESOPTION == 2 ]
    then
    cat << EOM
      The kernel image name should contain the image type uImage or zImage depending
      on which format is used.
      The device tree files must end with .dtb
          e.g    am335x-evm.dtb am43x-gp-evm.dtb
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -e -p 'Enter path for kernel image and device tree files : '  KERNELUSERFILEPATH
    		echo ""
    		ENTERCORRECTLY=1
    		if [ -d $KERNELUSERFILEPATH ]
    		then
    			echo ""
    			ls $KERNELUSERFILEPATH
    			echo ""
    				"y") ;;
    				esac
    		else
    			ENTERCORRECTLY=0
    		fi
    	done
    fi
    cat << EOM
       For Rootfs partition
          e.x. $:  /home/user/MyCustomTars/rootfs.tar.xz
          e.x. $: /ti-processor-sdk-linux/targetNFS/
    EOM
    	ENTERCORRECTLY=0
    	do
    		read -e -p 'Enter path for Rootfs Partition : ' ROOTFSUSERFILEPATH
    		echo ""
    		ENTERCORRECTLY=1
    		if [ -f $ROOTFSUSERFILEPATH ]
    		then
    			echo "File exists"
    			echo ""
    		elif [ -d $ROOTFSUSERFILEPATH ]
    		then
    			ls $ROOTFSUSERFILEPATH
    			echo ""
    				"y") ;;
    				esac
    		else
    			ENTERCORRECTLY=0
    		fi
    	done
    	echo ""
    	# Check if user entered a tar or not for Boot
    	ISBOOTTAR=`echo $BOOTUSERFILEPATH | grep -E "\.tar\.[xg]z" | awk {'print $1'}`
    	if [ -n "$ISBOOTTAR" ]
    	then
    		BOOTPATHOPTION=2
    	else
    		BOOTPATHOPTION=1
    		BOOTFILEPATH=$BOOTUSERFILEPATH
    	fi
    	if [ "$KERNELFILESOPTION" == "2" ]
    	then
    		KERNELIMAGE=`ls $KERNELUSERFILEPATH | grep [uz]Image | awk {'print $1'}`
    		DTFILES=`ls $KERNELUSERFILEPATH | grep .dtb$ | awk {'print $1'}`
    	fi
    	#Check if user entered a tar or not for Rootfs
    	ISROOTFSTAR=`ls $ROOTFSUSERFILEPATH | grep .tar.xz | awk {'print $1'}`
    	if [ -n "$ISROOTFSTAR" ]
    	then
    		ROOTFSPATHOPTION=2
    	else
    		ROOTFSPATHOPTION=1
    		ROOTFSFILEPATH=$ROOTFSUSERFILEPATH
    	fi
    fi
    cat << EOM
    	Copying files now... will take minutes
    Copying boot partition
    EOM
    if [ $BOOTPATHOPTION -eq 1 ] ; then
    	echo ""
    	#copy boot files out of board support
            if [ "$TARDEVICENAME" == "am65xx" ] || [ "$TARDEVICENAME" == "j7" ]; then
    		if [ "$MLO" == "" ] && ( [ "$SPL_R5" == "" ] || [ "$SPL_A72" == "" ] || [ "$SYSFW" == "" ] ); then
    			echo "Boot image not found"
    		fi
    	else
    		if [ "$MLO" == "" ] && ( [ "$SPL_R5" == "" ] || [ "$SPL_A72" == "" ] ) ; then
    		fi
            fi
    	echo ""
    	echo ""
    	if [ "$MLO" != "" ] ; then
    		cp $BOOTFILEPATH/$MLO $PATH_TO_SDBOOT/MLO
    		echo "MLO copied"
    		echo ""
    		echo ""
    	fi
    	if [ "$SPL_A72" != "" ] ; then
    		cp $BOOTFILEPATH/$SPL_A72 $PATH_TO_SDBOOT/tispl.bin
    		echo "tispl.bin copied"
    		echo ""
    		echo ""
    	fi
    	if [ "$SPL_R5" != "" ] ; then
    		cp $BOOTFILEPATH/$SPL_R5 $PATH_TO_SDBOOT/tiboot3.bin
    		echo "tiboot3.bin copied"
    		echo ""
    		echo ""
    	fi
    	if [ "$SYSFW" != "" ] ; then
    		cp $BOOTFILEPATH/$SYSFW $PATH_TO_SDBOOT/sysfw.itb
    		echo "sysfw.itb copied"
    		echo ""
    		echo ""
    	fi
    	if [ "$BOOTIMG" != "" ] ; then
    		cp $BOOTFILEPATH/$BOOTIMG $PATH_TO_SDBOOT/u-boot.img
    		echo "u-boot.img copied"
    	elif [ "$BOOTBIN" != "" ] ; then
    		cp $BOOTFILEPATH/$BOOTBIN $PATH_TO_SDBOOT/u-boot.bin
    		echo "u-boot.bin copied"
    	else
    		echo "No U-Boot file found"
    	fi
    	echo ""
    	if [ "$BOOTUENV" != "" ] ; then
    		cp $BOOTFILEPATH/$BOOTUENV $PATH_TO_SDBOOT/uEnv.txt
    		echo "uEnv.txt copied"
    	fi
    	echo ""
    	if [ "$TARIMAGETYPE" == "default" ] && ( [ "$TARDEVICENAME" == "am64xx" ] || [ "$TARDEVICENAME" == "am62xx" ] ); then
    	       	if [ "$WIFICFG" != "" ] ; then
    			cp $BOOTFILEPATH/$WIFICFG $PATH_TO_SDBOOT/wificfg
    	                echo "wificfg copied"
    		else
    	                echo "wificfg file not found"
    	        fi
    	fi
    elif [ $BOOTPATHOPTION -eq 2  ] ; then
    	untar_progress $BOOTUSERFILEPATH $PATH_TO_TMP_DIR
    	cp -rf $PATH_TO_TMP_DIR/* $PATH_TO_SDBOOT
    	echo ""
    fi
    echo ""
    sync
    echo "Copying rootfs System partition"
    if [ $ROOTFSPATHOPTION -eq 1 ] ; then
    	TOTALSIZE=`sudo du -c $ROOTFSUSERFILEPATH/* | grep total | awk {'print $1'}`
    	sudo cp -r $ROOTFSUSERFILEPATH/* $PATH_TO_SDROOTFS & cp_progress $TOTALSIZE $PATH_TO_SDROOTFS
    elif [ $ROOTFSPATHOPTION -eq 2  ] ; then
    	untar_progress $ROOTFSUSERFILEPATH $PATH_TO_SDROOTFS
    fi
    echo ""
    echo ""
    then
    	mkdir -p $PATH_TO_SDROOTFS/boot
    	if [ "$KERNELIMAGE" != "" ] ; then
    		CLEANKERNELNAME=`ls "$BOOTFILEPATH/$KERNELIMAGE" | grep -o [uz]Image`
    		cp -f $KERNELUSERFILEPATH/$KERNELIMAGE $PATH_TO_SDROOTFS/boot/$CLEANKERNELNAME
    		echo "Kernel image copied"
    	else
    		echo "$KERNELIMAGE file not found"
    	fi
    	COPYINGDTB="false"
    	for dtb in $DTFILES
    	do
    		if [ -f "$KERNELUSERFILEPATH/$dtb" ] ; then
    			cp -f $KERNELUSERFILEPATH/$dtb $PATH_TO_SDROOTFS/boot
    			echo "$dtb copied"
    			COPYINGDTB="true"
    		fi
    	done
    	if [ "$COPYINGDTB" == "false" ]
    	then
    		echo "No device tree files found"
    	fi
    fi
    # The following firmware are required for early boot, and therefore must be
    # copied to the boot partition.
    RPROC_EARLYBOOT_FIRMWARE=" \
        dra7-ipu1-fw.xem4 \
    for fw in $RPROC_EARLYBOOT_FIRMWARE
    do
    	fw_path="$PATH_TO_SDROOTFS/lib/firmware/$fw"
    	# Handle links specifally as they may be absolute paths with respect to the rootfs
    	if [ -L "$fw_path" ]
    	then
    		fw_link=$(readlink "$fw_path")
    		if [[ "$fw_link" == /* ]]
    		then
    			# Absolute path
    			fw_path="$(readlink "$fw_path" | sed -e "s|^/|$PATH_TO_SDROOTFS/|")"
    		else
    			# Relative path
    			fw_path="$(dirname "$fw_path")/$fw_link"
    		fi
    	fi
    	# this is a global list of firmwares, so do not fail
    	cp -L "$fw_path" "$PATH_TO_SDBOOT/$fw" 2> /dev/null || true
    done
    echo " "
    echo "Syncing..."
    sync
    sync
    sync
    sync
    sync
    sync
    sync
    sync
    echo " "
    echo "Un-mount the partitions "
    sudo umount -f $PATH_TO_SDBOOT
    sudo umount -f $PATH_TO_SDROOTFS
    echo " "
    echo "Remove created temp directories "
    sudo rm -rf $PATH_TO_TMP_DIR
    echo " "
    echo "Operation Finished"
    echo " "
    1.My output
    2.The doc I followed
    3. The script I runed
  • Hi Kong,
    Can you try the following steps instead of running the script:
    • Download the following files from the below link:
    • >cd <FAT32 partition of sd card>
      >tar -xvf <Path to File 1>
      >sync
      >cd < EXT4 partition of sd card>
      >tar -xvf <Path to File 2>
      >sync
    Gokul
  • I tried .It won't work.Could you give me the a method that can work on your computer?
  • Hi Kong,
    Can you point out what wasn't working on your side as I tried the same steps on my computer and it works.
    Gokul
  • I think no mater what "tar.xz" file do,will not affect that your official create SD card scripts has some issues.
    Instead of asking me to try more things, don't you think you should check the scripts in your official doc and sdk ?
    My hope is you can give me scripts that works.
  • Hi Kong,
    The script has no isssues.
    You will have to download the following files from the below link to a directory.
    Then provide the path to that directory containing the above 2 files when this prompt comes up on running the script.
    Gokul
