Part Number: TDA4VM
Hello, an error occurred when using ldc for distortion correction and downsampling, see the attached log.
There was no error before when using sdk10.0. After upgrading to sdk10.1, ldc stuck in vxProcessGraph function after running a few frames. What is the reason for this?
We tried to modify LDC_DS_FACTOR=4, and the ldc node could run, but the result was wrong. LDC_DS_FACTOR=0, the result was correct, but it would be stuck in vxProcessGraph function. How can we modify the configuration parameters to adapt to the new sdk?
