AM620-Q1: drivers/qspi.h not found in MCU +Sdk
Part Number: AM620-Q1
       We are trying to use SBL boot from MCU SDK to boot M4F application early. We have a qspi based Winbond Norflash. I found that there is no direct support in syscfg to change it from OSPI to QSPI. I tried to change it by changing in soc cfg to pick serial nor flash v1. But, I got a compile error that qspi.h is not found.
Is SBL flash with qspi support available in the sdk? If not, please direct me to correct source.
I am using MCU +SDK VERSION 10.00
  • Hi Vaibhav and Swargam,
               The issue is related to RAM configuration. With another device having a different RAM configuration, I could get past this situation to the point where the SBL2 loads the linux image.
    ERROR: Sciclient_service:251: ret status 0 msgtype 4368
    ERROR: Sciclient_service:258: ret status 0
    ERROR: Sciclient_service:251: ret status 0 msgtype 4613
    Before Drivers open
    ERROR: Flash_norOspiSetProtocol:734: Inside Ospi set protocol
    ERROR: Flash_norOspiSetProtocol:746: Ospi set protocol 3
    ERROR: Flash_setQeBit:365: Inside set qe bit 4
    ERROR: Flash_norOspiCmdRead:129: cmd 5 cmdaddr 4294967295 databuf @ datalen 1
    ERROR: Flash_norOspiCmdRead:129: cmd 53 cmdaddr 4294967295 databuf ▒@ datalen 1
    ERROR: Flash_setQeBit:381: Qe type 4 sr2 0xFF
    ERROR: Flash_norOspiSetAddressBytes:317: Setting address byte to 1 enable 4 byte 0
    ERROR: Flash_norOspiCmdRead:129: cmd 159 cmdaddr 4294967295 databuf :▒1 datalen 3
    ERROR: Flash_norOspiReadId:854: man id 3A devid C031
    ERROR: Flash_norOspiReadId:863: Failed to read device id
    ERROR: Flash_norOspiCmdRead:129: cmd 159 cmdaddr 4294967295 databuf ▒` datalen 3
    ERROR: Flash_norOspiReadId:854: man id 9D devid 6018
    ERROR: Sciclient_service:251: ret status 0 msgtype 2
    SYSFW Firmware Version 10.0.8--v10.00.08 (Fiery Fox)
    SYSFW Firmware revision 0xa
    SYSFW ABI revision 4.0
    Drivers open done
    ERROR: Bootloader_open:93: Bootloader open Flash open status 0
    Performing ram test
    Ram test done
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60100000 dest 0x43C2C858
    ERROR: Bootloader_verifyMulticoreImage:593: x509header 02-07 0▒S▒▒▒Cx▒C
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60100000 dest 0x84000000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60100000 84000000
    ERROR: OSPI_dmaCopy:111: value at source address 0x53068230
    ERROR: Sciclient_service:251: ret status 0 msgtype 49440
    ERROR: Bootloader_socAuthImage:1076: ret status 0
    ERROR: Bootloader_parseMultiCoreAppImage:749: verify multicore image 0!!
    ERROR: Bootloader_parseMultiCoreAppImage:780: Image read function magic string 0x5254534D 0!!
    Parse image status 0!!
    ERROR: Sciclient_service:251: ret status 0 msgtype 49152
    ERROR: Sciclient_service:251: ret status 0 msgtype 268
    ERROR: Sciclient_service:251: ret status 0 msgtype 512
    ERROR: Sciclient_service:251: ret status 0 msgtype 514
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60100677 dest 0x43C2C8E0
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6010068B dest 0x43C2C8CC
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6010069F dest 0x5000000
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x601007DF dest 0x43C2C8CC
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x601007F3 dest 0x5000200
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6010F583 dest 0x43C2C8CC
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6010F597 dest 0x504C800
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6011174F dest 0x43C2C8CC
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60111763 dest 0x9CC00000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60111780 9CC0001D
    ERROR: OSPI_dmaCopy:111: value at source address 0x0
    Reading mcu app image 0!!
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60080000 dest 0x43C2C858
    ERROR: Bootloader_verifyMulticoreImage:593: x509header 02-07 0▒S▒▒C▒▒C
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60080000 dest 0x84000000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60080000 84000000
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60080677 dest 0x43C2C8D8
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x6008068B dest 0x43C2C8C4
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x6008069F dest 0xA0340000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 600806A0 A0340001
    ERROR: OSPI_dmaCopy:111: value at source address 0x242C4000
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60081DD7 dest 0x43C2C8C4
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60081DEB dest 0xA0341740
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60081E00 A0341755
    ERROR: OSPI_dmaCopy:111: value at source address 0xD8250046
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x600A2F0B dest 0x43C2C8C4
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x600A2F1F dest 0xA0362880
    ERROR: OSPI_dmaCopy:110: Dma copy source address 600A2F20 A0362881
    ERROR: OSPI_dmaCopy:111: value at source address 0x7C1D301
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x600A371F dest 0x43C2C8C4
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x600A3733 dest 0xA036AE80
    ERROR: Sciclient_service:251: ret status 0 msgtype 270
    Reading sbl app image 0!!
    [BOOTLOADER_PROFILE] Boot Media : FLASH
    [BOOTLOADER_PROFILE] Boot Media Clock : 166.667 MHz
    [BOOTLOADER_PROFILE] Boot Image Size : 212 KB
    [BOOTLOADER_PROFILE] Cores present :
    m4f0-0
    r5f0-0
    [BOOTLOADER PROFILE] System_init : 35583us
    [BOOTLOADER PROFILE] Board_init : 0us
    [BOOTLOADER PROFILE] Drivers_open : 18717us
    [BOOTLOADER PROFILE] Board_driversOpen : 82395us
    [BOOTLOADER PROFILE] Sciclient Get Version : 19173us
    [BOOTLOADER PROFILE] App_waitForMcuPbist : 13466us
    [BOOTLOADER PROFILE] App_waitForMcuLbist : 7689us
    [BOOTLOADER PROFILE] App_loadImages : 354285us
    [BOOTLOADER PROFILE] App_loadSelfcoreImage : 229937us
    [BOOTLOADER_PROFILE] SBL Total Time Taken : 761249us
    m4f0-0
    r5f0-0
    Image loading done, switching to application ...
    Starting MCU-m4f and 2nd stage bootloader
    ERROR: Sciclient_service:251: ret status 0 msgtype 49153
    ERROR: Flash_setQeBit:365: Inside set qe bit 0
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C00000 dest 0xA0366DB0
    ERROR: Bootloader_verifyMulticoreImage:593: x509header 02-07 0▒SP▒5▒P▒5▒▒n6▒P▒5▒
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60C00000 dest 0x84000000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60C00000 84000000
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C0D5AF dest 0xA0366D98
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C0D5C3 dest 0xA0366D84
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60C0D5D7 dest 0x9E800000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60C0D5E0 9E800009
    ERROR: OSPI_dmaCopy:111: value at source address 0xF6AA0203
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C8233F dest 0xA0366D98
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C82353 dest 0xA0366D84
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60C82367 dest 0x80080000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60C82380 80080019
    ERROR: OSPI_dmaCopy:111: value at source address 0xC000
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C00687 dest 0xA0366E38
    ERROR: OSPI_readDirect:1214: DMA copy 0, phy enable 0 src 0x60C0069B dest 0xA0366E24
    ERROR: OSPI_readDirect:1214: DMA copy 1, phy enable 0 src 0x60C006AF dest 0x80000000
    ERROR: OSPI_dmaCopy:110: Dma copy source address 60C006C0 80000011
    ERROR: OSPI_dmaCopy:111: value at source address 0xA0D28106
    [BOOTLOADER_PROFILE] Boot Image Size : 929 KB
    a530-0
    [BOOTLOADER PROFILE] System_init : 3502us
    [BOOTLOADER PROFILE] Drivers_open : 37537us
    [BOOTLOADER PROFILE] Board_driversOpen : 61375us
    [BOOTLOADER PROFILE] Sciclient Get Version : 19239us
    [BOOTLOADER PROFILE] App_loadLinuxImages : 342730us
    [BOOTLOADER_PROFILE] SBL Total Time Taken : 464386us
    Starting linux and RTOS/Baremetal applications
    ERROR: Sciclient_service:251: ret status 0 msgtype 49408
    ERROR: ScicNOTICE: BlL31i: v2.10.0e(relneaset):v2.10.0-36_7-g00fs1ec6be87-drirtyv
    NOTICE: i BL31: Bcuilte : :16:09:205, 5Feb 1 9 :202 4
    ERROR: Timeout waiting for thread SP_RESPONSE to fill
    ERROR: Thread SP_RESPONSE verification failed (-60)
    ERROR: Message receive failed (-60)
    ERROR: Failed to get response (-60)
    ERROR: Transfer send failed (-60)
    ERROR: Unable to query firmware capabilities (-60)
    E/TC:0 0 k3_sec_proxy_verify_thread:108 Queue is busy
    E/TC:0 0 k3_sec_proxy_recv:196 Thread SEC_PROXY_RESPONSE_THREAD verification failed. ret = -65523
    E/TC:0 0 ti_sci_get_response:101 Message receive failed (-65523)
    E/TC:0 0 ti_sci_do_xfer:150 Failed to get response (-65523)
    E/TC:0 0 ti_sci_init:486 Unable to communicate with control firmware (-65523)
    E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x00070568 failed
    E/TC:0 0 tee_otp_get_hw_unique_key:97 Could not get HUK
    E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x00070590 failed
    E/TC:0 0 sa2ul_init:106 Could not change TRNG firewall owner
    E/TC:0 0 call_initcalls:43 Initcall __text_start + 0x00070598 failed
    E/TC:0 0
    E/TC:0 0 Core data-abort at address 0x14 (translation fault)
    E/TC:0 0 esr 0x96000005 ttbr0 0x9e8a1000 ttbr1 0x00000000 cidr 0x0
    E/TC:0 0 cpu #0 cpsr 0x600003c4
    E/TC:0 0 x0 000000009e874000 x1 0000000000000000
    E/TC:0 0 x2 0000000000000000 x3 0000000000000000
    E/TC:0 0 x4 0000000000000050 x5 000000009e891d70
    E/TC:0 0 x6 ffffffffffffffb0 x7 0000000000010cb0
    E/TC:0 0 x8 0000000000010cb0 x9 000000009e891f80
    E/TC:0 0 x10 000000009e881070 x11 0000000000000008
    E/TC:0 0 x12 0000000000000000 x13 000000009e8a2e60
    E/TC:0 0 x14 0000000000000000 x15 0000000000000000
    E/TC:0 0 x16 000000009e81c74c x17 0000000000000000
    E/TC:0 0 x18 0000000000000000 x19 000000009e8a31e0
    E/TC:0 0 x20 000000009e8a31e8 x21 000000009e874000
    E/TC:0 0 x22 000000009e874000 x23 000000009e874f00
    E/TC:0 0 x24 000000009e873dc0 x25 0000000000000000
    E/TC:0 0 x26 0000000000000000 x27 0000000000000000
    E/TC:0 0 x28 0000000000000000 x29 000000009e8a3170
    E/TC:0 0 x30 000000009e816f6c elr 000000009e816f7c
    E/TC:0 0 sp_el0 000000009e8a3170
    E/TC:0 0 TEE load address @ 0x9e800000
    E/TC:0 0 Call stack:
    E/TC:0 0 0x9e816f7c
    E/TC:0 0 0x9e807c64
    E/TC:0 0 0x9e8220ec
    E/TC:0 0 0x9e807de0
    E/TC:0 0 Panic 'unhandled pageable abort' at /usr/src/debug/optee-os/4.2.0+git/core/arch/arm/kernel/abort.c:582 <abort_handle>
    E/TC:0 0 0x9e808030
    E/TC:0 0 0x9e81ebb0
    E/TC:0 0 0x9e807884
    E/TC:0 0 0x9e804a68
    But I don't see any messages on MCU console and getting fault when the linux image starts to run. Do you have any clue where to look at?
  • Hi Vaibhav,
         I am able to boot MCU and A53 core successfully. This was done after adding r5f image. I thought that it is not needed. Ideally, what application should be loaded to r5f if we don't want to run any custom application in that core?
  • Ideally, what application should be loaded to r5f if we don't want to run any custom application in that core?
    You can go ahead and have an empty example loaded as follows: C:\ti\mcu_plus_sdk_am62x_11_00_00_16\examples\empty\am62x-sk-lp\r5fss0-0_freertos\ti-arm-clang
    Vaibhav
