HWI Object's Operation
Hi.
I want to know about operation properties of a hwi object property. already i know how STS Module is working.
and operation properties of hwi has a combobox to select proper option like STS_add(*addr) or STS_add(-*addr)....
but i don't understand what the "addr" argument is..
would you give me a some advice about that?
Regards.
    The various forms of the STS_add() and STS_delta() arguments denote unary operations that can be performed on the data at the addr specified before it gets added into the STS object.
    1) (*addr) means to fetch the data at the address and use it AS IS in the STS operation.
    2) (-*addr) means to fetch the data at the address then negate it (ie two's complement) before using it in the STS operation.
    3) (|*addr|) means to fetch the data at the address and then take the absolute value of it before using it in the STS operation.
    Alan
  • Thank you, Alan!!
    Your explanation is easy to understand! Very Helpful.
    Zizek
