J784S4XEVM: Kernel Panic on Image Generated with Yocto (processor-sdk-scarthgap-11.00.09.04-config.txt)
Part Number: J784S4XEVM
Information:
Platform: J784S4XG01EVM
Boot Mode: TFTP/NFS
Image: Yocto build with processor-sdk-scarthgap-11.00.09.04-config.txt file
Host: Ubuntu 22.04.5
Docker Image: ghcr.io/texasinstruments/ubuntu-distro:latest (commit hash: 7047cf3)
Problem:
After migrating from Yocto config file "processor-sdk-scarthgap-10.01.10.04-config.txt" to "processor-sdk-scarthgap-11.00.09.04-config.txt", we sometimes encounter a Kernel Panic on boot phase. It's hard to catch, happens at %5-10 rate. We NEVER encounter this on previous config file. All the other variants are same (our layer, board, docker image, boot mode, etc). I attached the kernel log for you to review.
U-Boot SPL 2025.01-00406-gcd91d7360181-dirty (Mar 25 2025 - 16:14:37 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
Initialized 4 DRAM controllers
SPL initial stack usage: 13456 bytes
Trying to boot from MMC1
mmc_load_image_raw_sector: mmc block read error
Skipping authentication on GP device
Loading Environment from nowhere... OK
init_env from device 17 not supported!
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.12.0(release):11.00.09-dirty
NOTICE:  BL31: Built : 12:35:58, Mar 24 2025
I/TC:
I/TC: OP-TEE version: 4.5.0-73-gef1ebdc23-dev (gcc version 13.3.0 (GCC)) #1 Tue Feb  4 11:33:18 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: GIC redistributor base address not provided
I/TC: Assuming default GIC group status and modifier
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: HUK Initialized
I/TC: Primary CPU switching to normal world boot
U-Boot 2025.01-00406-gcd91d7360181-dirty (Mar 25 2025 - 16:14:37 +0000)
SoC:   J784S4 SR1.0 GP
Model: Texas Instruments J784S4 EVM
DRAM:  2 GiB (total 32 GiB)
mmio-mux mux-controller@4080: unable to set idle state
Core:  143 devices, 36 uclasses, devicetree: separate
Flash: spi_nand nand@0: Winbond SPI NAND was found.
spi_nand nand@0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
k3-navss-ringacc ringacc@2b800000: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
k3-navss-ringacc ringacc@2b800000: dma-ring-reset-quirk: disabled
cadence_spi spi@47040000: Pattern not found. Skipping calibration
0 Bytes
MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
In:    serial@2880000
Out:   serial@2880000
Err:   serial@2880000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
Net:   eth0: ethernet@46000000port@1
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0(part 0) is current device
SD/MMC found on device 0
322 bytes read in 1 ms (314.5 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
am65_cpsw_nuss_port ethernet@46000000port@1: K3 CPSW: rflow_id_base: 3
ethernet@46000000port@1 Waiting for PHY auto negotiation to complete.. done
link up on port 1, speed 1000, full duplex
Using ethernet@46000000port@1 device
TFTP from server 192.168.1.20; our IP address is 192.168.1.10
Filename 'Image'.
Load address: 0x82000000
Loading: ##################################################  21.2 MiB
	 3 MiB/s
done
Bytes transferred = 22256128 (1539a00 hex)
Filename 'k3-j784s4-evm.dtb'.
Load address: 0x88000000
Loading: ##################################################  127.6 KiB
	 7.8 MiB/s
done
Bytes transferred = 130685 (1fe7d hex)
Working FDT set to 88000000
   Loading Device Tree to 000000008ffdd000, end 000000008ffffe7c ... OK
Working FDT set to 8ffdd000
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 6.12.17-ti-00771-gc85877d40f8e (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Mar 25 12:45:29 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments J784S4 EVM
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000f90000000, size 1792 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000f90000000..0x0000000fffffffff (1835008 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a4000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable r5f-memory@a4100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a5000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable r5f-memory@a5100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a6000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable r5f-memory@a6100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a7000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable r5f-memory@a7100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable c71-dma-memory@a8000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable c71-memory@a8100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a9000000..0x00000000a90fffff (1024 KiB) nomap non-reusable c71-dma-memory@a9000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a9100000..0x00000000a9ffffff (15360 KiB) nomap non-reusable c71-memory@a9100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000aa0fffff (1024 KiB) nomap non-reusable c71-dma-memory@aa000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000aa100000..0x00000000aaffffff (15360 KiB) nomap non-reusable c71-memory@aa100000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ab000000..0x00000000ab0fffff (1024 KiB) nomap non-reusable c71-dma-memory@ab000000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000ab100000..0x00000000abffffff (15360 KiB) nomap non-reusable c71-memory@ab100000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x0000000fffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Spectre-v3a
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM erratum 1742098
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200 root=/dev/nfs rw nfsroot=192.168.1.20:/srv/nfs/rootfs,v3,tcp ip=192.168.1.10:::255.255.255.0::eth0:dhcp
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8388608
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 8.
[    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000880070000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880080000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.000327] Console: colour dummy device 80x25
[    0.000368] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.000373] pid_max: default: 32768 minimum: 301
[    0.000422] LSM: initializing lsm=capability,selinux
[    0.000465] SELinux:  Initializing.
[    0.000852] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000912] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002394] rcu: Hierarchical SRCU implementation.
[    0.002397] rcu: 	Max phase no-delay instances is 1000.
[    0.002519] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.002850] EFI services will not be available.
[    0.003085] smp: Bringing up secondary CPUs ...
[    0.011571] Detected PIPT I-cache on CPU1
[    0.011618] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.011633] GICv3: CPU1: using allocated LPI pending table @0x0000000880090000
[    0.011667] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.020197] Detected PIPT I-cache on CPU2
[    0.020227] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[    0.020239] GICv3: CPU2: using allocated LPI pending table @0x00000008800a0000
[    0.020263] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[    0.028740] Detected PIPT I-cache on CPU3
[    0.028772] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[    0.028785] GICv3: CPU3: using allocated LPI pending table @0x00000008800b0000
[    0.028809] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[    0.040388] Detected PIPT I-cache on CPU4
[    0.040450] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[    0.040463] GICv3: CPU4: using allocated LPI pending table @0x00000008800c0000
[    0.040497] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[    0.049035] Detected PIPT I-cache on CPU5
[    0.049073] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[    0.049086] GICv3: CPU5: using allocated LPI pending table @0x00000008800d0000
[    0.049111] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[    0.060295] Detected PIPT I-cache on CPU6
[    0.060334] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[    0.060347] GICv3: CPU6: using allocated LPI pending table @0x00000008800e0000
[    0.060371] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[    0.068869] Detected PIPT I-cache on CPU7
[    0.068910] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[    0.068923] GICv3: CPU7: using allocated LPI pending table @0x00000008800f0000
[    0.068947] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[    0.069031] smp: Brought up 1 node, 8 CPUs
[    0.069035] SMP: Total of 8 processors activated.
[    0.069037] CPU: All CPU(s) started at EL2
[    0.069040] CPU features: detected: 32-bit EL0 Support
[    0.069042] CPU features: detected: CRC32 instructions
[    0.069077] alternatives: applying system-wide alternatives
[    0.069446] Memory: 30757804K/33554432K available (12928K kernel code, 1254K rwdata, 4648K rodata, 2752K init, 639K bss, 950064K reserved, 1835008K cma-reserved)
[    0.070006] devtmpfs: initialized
[    0.081780] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.081792] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.104642] 27152 pages in range for non-PLT usage
[    0.104650] 518672 pages in range for PLT usage
[    0.104867] pinctrl core: initialized pinctrl subsystem
[    0.105134] DMI not present or invalid.
[    0.106753] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.108030] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.108752] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.109451] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.109594] audit: initializing netlink subsys (disabled)
[    0.109742] audit: type=2000 audit(0.108:1): state=initialized audit_enabled=0 res=1
[    0.109952] thermal_sys: Registered thermal governor 'step_wise'
[    0.109955] thermal_sys: Registered thermal governor 'power_allocator'
[    0.109979] cpuidle: using governor menu
[    0.110048] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.110159] ASID allocator initialised with 65536 entries
[    0.115561] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
[    0.115666] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.115688] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.115712] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.115940] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.115948] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.115972] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.115994] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.116004] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.120102] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.120133] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.120181] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.123362] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.123402] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.123419] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.123572] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.123798] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.123835] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.123874] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.123907] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.124773] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /connector-dp0
[    0.124824] /connector-dp0: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.125999] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.126003] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.126006] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.126007] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.126010] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.126011] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.126013] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.126015] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.126977] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[    0.127465] iommu: Default domain type: Translated
[    0.127468] iommu: DMA domain TLB invalidation policy: strict mode
[    0.127921] SCSI subsystem initialized
[    0.128111] usbcore: registered new interface driver usbfs
[    0.128125] usbcore: registered new interface driver hub
[    0.128139] usbcore: registered new device driver usb
[    0.128428] pps_core: LinuxPPS API ver. 1 registered
[    0.128431] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.128438] PTP clock support registered
[    0.128458] EDAC MC: Ver: 3.0.0
[    0.128611] scmi_core: SCMI protocol bus registered
[    0.128769] FPGA manager framework
[    0.128812] Advanced Linux Sound Architecture Driver Initialized.
[    0.129286] vgaarb: loaded
[    0.129460] clocksource: Switched to clocksource arch_sys_counter
[    0.129598] VFS: Disk quotas dquot_6.6.0
[    0.129612] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.133284] NET: Registered PF_INET protocol family
[    0.133595] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.138779] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.138924] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.138943] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.139751] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.140605] TCP: Hash tables configured (established 262144 bind 65536)
[    0.140702] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.141013] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.141442] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.141829] RPC: Registered named UNIX socket transport module.
[    0.141832] RPC: Registered udp transport module.
[    0.141834] RPC: Registered tcp transport module.
[    0.141836] RPC: Registered tcp-with-tls transport module.
[    0.141837] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.141842] NET: Registered PF_XDP protocol family
[    0.141856] PCI: CLS 0 bytes, default 64
[    0.142830] Initialise system trusted keyrings
[    0.142943] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.143103] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.143244] NFS: Registering the id_resolver key type
[    0.143259] Key type id_resolver registered
[    0.143261] Key type id_legacy registered
[    0.143271] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.143273] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.164895] Key type asymmetric registered
[    0.164899] Asymmetric key parser 'x509' registered
[    0.164935] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.165061] io scheduler mq-deadline registered
[    0.165064] io scheduler kyber registered
[    0.165078] io scheduler bfq registered
[    0.167716] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.167815] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[    0.167987] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[    0.168292] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[    0.168424] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[    0.168811] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.168881] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.169628] ledtrig-cpu: registered to indicate activity on CPUs
[    0.173443] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.179004] loop: module loaded
[    0.179656] megasas: 07.727.03.00-rc1
[    0.181735] tun: Universal TUN/TAP device driver, 1.6
[    0.182328] VFIO - User Level meta-driver version: 0.3
[    0.183096] usbcore: registered new interface driver usb-storage
[    0.183493] i2c_dev: i2c /dev entries driver
[    0.184230] sdhci: Secure Digital Host Controller Interface driver
[    0.184232] sdhci: Copyright(c) Pierre Ossman
[    0.184378] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.184832] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.185255] usbcore: registered new interface driver usbhid
[    0.185257] usbhid: USB HID core driver
[    0.186034] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
[    0.186545] optee: probing for conduit method.
[    0.186564] optee: revision 4.5 (ef1ebdc23034a804)
[    0.203032] optee: dynamic shared memory is enabled
[    0.203443] optee: initialized driver
[    0.203556] random: crng init done
[    0.203688] mux muxchip0: unable to set idle state
[    0.203692] mmio-mux 104080.mux-controller: probe with driver mmio-mux failed with error -5
[    0.204819] Initializing XFRM netlink socket
[    0.204838] NET: Registered PF_PACKET protocol family
[    0.204881] Key type dns_resolver registered
[    0.208759] registered taskstats version 1
[    0.209024] Loading compiled-in X.509 certificates
[    0.216094] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
[    0.290410] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    0.291141] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.291200] pca953x 3-0020: using no AI
[    0.310496] pca953x 3-0022: supply vcc not found, using dummy regulator
[    0.310559] pca953x 3-0022: using AI
[    0.311726] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.312204] pca953x 4-0020: supply vcc not found, using dummy regulator
[    0.312247] pca953x 4-0020: using no AI
[    0.325947] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
[    0.326576] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.326621] pca953x 5-0020: using no AI
[    0.341824] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.341856] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.341879] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.341991] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.342057] omap_i2c 2040000.i2c: bus 5 rev0.12 at 400 kHz
[    0.342626] pca953x 6-0020: supply vcc not found, using dummy regulator
[    0.342680] pca953x 6-0020: using no AI
[    0.357800] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[    0.357915] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[    0.358004] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[    0.358100] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[    0.358337] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[    0.364275] ti-udma 311a0000.dma-controller: Number of rings: 48
[    0.365811] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
[    0.367295] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[    0.367300] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.367303] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    0.369303] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[    0.369308] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    0.369310] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    0.370003] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 275, base_baud = 6000000) is a 8250
[    0.370605] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 276, base_baud = 3000000) is a 8250
[    0.370653] printk: legacy console [ttyS2] enabled
[    2.873463] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.884362] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.892633] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.905507] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.912718] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    2.920089] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.969460] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.980149] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    2.988242] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    3.001026] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    3.007326] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    3.014452] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
[    3.021654] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[    3.032000] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[    3.041169] mmc0: CQHCI version 5.10
[    3.081473] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    3.173459] mmc0: Command Queue Engine enabled
[    3.177911] mmc0: new HS400 MMC card at address 0001
[    3.183392] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    3.189020]  mmcblk0: p1 p2
[    3.192174] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    3.197870] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    3.203530] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    3.355620] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    3.364027] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.371520] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.379610] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.387697] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.497855] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[    4.504126] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.509603] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    4.519065] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    4.525951] pci 0000:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
[    4.533247] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    4.542900] pci 0000:00:00.0: PCI bridge to [bus 00]
[    4.547857] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    4.553941] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    4.560722] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    4.568536] pci 0000:00:00.0: supports D1
[    4.572536] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    4.580177] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.588288] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    4.594904] pci 0000:00:00.0: PCI bridge to [bus 01]
[    4.599867] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    4.605427] pci_bus 0000:00: resource 5 [mem 0x10011000-0x17ffffff]
[    4.611741] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    4.618534] pcieport 0000:00:00.0: PME: Signaling with IRQ 538
[    4.624504] pcieport 0000:00:00.0: AER: enabled with IRQ 538
[    4.630409] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.637899] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.645987] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.654072] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.757534] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[    5.763793] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.769269] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    5.778903] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[    5.785782] pci 0001:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
[    5.793077] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    5.802728] pci 0001:00:00.0: PCI bridge to [bus 00]
[    5.807686] pci 0001:00:00.0:   bridge window [io  0x0000-0x0fff]
[    5.813767] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    5.820549] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    5.828399] pci 0001:00:00.0: supports D1
[    5.832399] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    5.838158] pci 0001:00:00.0: VF BAR 0 [mem 0x00000000-0x003fffff 64bit]
[    5.844846] pci 0001:00:00.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]: contains BAR 0 for 4 VFs
[    5.855731] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.863836] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    5.870452] pci 0001:00:00.0: VF BAR 0 [mem 0x18400000-0x193fffff 64bit]: assigned
[    5.878012] pci 0001:00:00.0: PCI bridge to [bus 01]
[    5.882973] pci_bus 0001:00: resource 4 [io  0x10000-0x1ffff]
[    5.888708] pci_bus 0001:00: resource 5 [mem 0x18011000-0x1fffffff]
[    5.895002] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[    5.901781] pcieport 0001:00:00.0: PME: Signaling with IRQ 540
[    5.907740] pcieport 0001:00:00.0: AER: enabled with IRQ 540
[    5.914192] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[    5.924525] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[    5.936444] spi-nand spi0.0: Winbond SPI NAND was found.
[    5.941763] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[    5.950237] 7 fixed-partitions partitions found on MTD device spi0.0
[    5.956587] Creating 7 MTD partitions on "spi0.0":
[    5.961387] 0x000000000000-0x000000100000 : "ospi_nand.tiboot3"
[    5.968332] 0x000000100000-0x000000300000 : "ospi_nand.tispl"
[    5.975115] 0x000000300000-0x000000700000 : "ospi_nand.u-boot"
[    5.982403] 0x000000700000-0x000000740000 : "ospi_nand.env"
[    5.988610] 0x000000740000-0x000000780000 : "ospi_nand.env.backup"
[    5.995432] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[    6.023251] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[    6.030121] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
[    6.039678] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[    6.046728] Creating 7 MTD partitions on "47050000.spi.0":
[    6.052203] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[    6.058271] 0x000000080000-0x000000280000 : "qspi.tispl"
[    6.064147] 0x000000280000-0x000000680000 : "qspi.u-boot"
[    6.070102] 0x000000680000-0x0000006c0000 : "qspi.env"
[    6.075805] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[    6.082095] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    6.088079] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[    6.129464] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.140275] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    6.148542] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    6.161398] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    6.168608] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    6.175965] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    6.192390] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    6.237462] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.248266] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    6.256361] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    6.269147] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    6.275456] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    6.282579] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
[    6.289929] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    6.306788] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[    6.317217] mmc1: CQHCI version 5.10
[    6.358018] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    6.379536] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    6.389026] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    6.543253] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    6.550339] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[    6.559418]  mmcblk1: p1 p2
[   10.496626] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   10.517468] IP-Config: Complete:
[   10.520684]      device=eth0, hwaddr=04:25:e8:b6:b0:26, ipaddr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255
[   10.531102]      host=192.168.1.10, domain=, nis-domain=(none)
[   10.536922]      bootserver=255.255.255.255, rootserver=192.168.1.20, rootpath=
[   10.537026] clk: Disabling unused clocks
[   10.559914] PM: genpd: Disabling unused power domains
[   10.565067] ALSA device list:
[   10.568102]   No soundcards found.
[   10.579865] VFS: Mounted root (nfs filesystem) on device 0:23.
[   10.585970] devtmpfs: mounted
[   10.589968] Freeing unused kernel memory: 2752K
[   10.594573] Run /sbin/init as init process
[   10.751967] systemd[1]: System time before build time, advancing clock.
[   10.788407] NET: Registered PF_INET6 protocol family
[   10.794949] Segment Routing with IPv6
[   10.798639] In-situ OAM (IOAM) with IPv6
[   10.831442] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   10.863369] systemd[1]: Detected architecture arm64.
Welcome to Arago 2025.01!
[   10.879492] systemd[1]: Hostname set to <j784s4-evm-custom>.
[   11.131640] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   11.237272] systemd[1]: Queued start job for default target Graphical Interface.
[   11.296440] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[   11.318505] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[   11.338392] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[   11.358239] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   11.377633] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[   11.397594] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[   11.417530] systemd[1]: Expecting device /dev/ttyS2...
[   11.429578] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[   11.441519] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[   11.457525] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[   11.469518] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[   11.535599] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[   11.557598] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[   11.582009] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[   11.605682] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   11.626373] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[   11.650111] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[   11.673803] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[   11.690147] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[   11.711063] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[   11.729705] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[   11.746150] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[   11.805686] systemd[1]: Mounting Huge Pages File System...
[   11.819986] systemd[1]: Mounting POSIX Message Queue File System...
[   11.840318] systemd[1]: Mounting Kernel Debug File System...
[   11.853768] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[   11.869737] systemd[1]: Mounting Temporary Directory /tmp...
[   11.885160] systemd[1]: Starting Create List of Static Device Nodes...
[   11.908422] systemd[1]: Starting Load Kernel Module configfs...
[   11.924302] systemd[1]: Starting Load Kernel Module drm...
[   11.940112] systemd[1]: Starting Load Kernel Module fuse...
[   11.961493] systemd[1]: Starting Start psplash boot splash screen...
         Starting Start psplash boot splash screen.[   11.972539] fuse: init (API version 7.41)
[   11.990441] systemd[1]: Starting RPC Bind...
[   12.006039] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   12.023402] systemd[1]: Starting Journal Service...
[   12.045255] systemd[1]: Starting Load Kernel Modules...
[   12.060699] systemd[1]: Starting Generate network units from Kernel command line...
[   12.079043] cryptodev: loading out-of-tree module taints kernel.
[   12.086193] sysctl table check failed: ioctl/(null) procname is null
[   12.088553] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.089129] systemd-journald[176]: Collecting audit messages is enabled.
[   12.092675] sysctl table check failed: ioctl/(null) No proc_handler
[   12.112526] cryptodev: driver 1.14 loaded.
         Starting Remount Root and Kernel File Systems systemd[1]: Starting Coldplug All udev Devices...
[0m...
[   12.141783] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[   12.158017] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Start psplas…temd progress communication helper.
[  OK  ] Finished Load Kernel Modules.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
[   12.481757] systemd-journald[176]: Received client request to flush runtime journal.
         Starting Create Static Device Nodes in /dev gracefully...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Apply Kernel Variables.
[  OK  ] Finished Create Static Device Nodes in /dev gracefully.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[   12.723106] audit: type=1334 audit(1736360578.968:2): prog-id=6 op=LOAD
[   12.729741] audit: type=1334 audit(1736360578.976:3): prog-id=7 op=LOAD
         Starting Rule-based Manager for Device Events and Files...
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save OS Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create System Files and Directories...
[  OK  ] Finished Load/Save OS Random Seed.
[   12.866290] audit: type=1334 audit(1736360579.112:4): prog-id=8 op=LOAD
[   12.872935] audit: type=1334 audit(1736360579.116:5): prog-id=9 op=LOAD
[   12.879580] audit: type=1334 audit(1736360579.124:6): prog-id=10 op=LOAD
         Starting User Database Manager...
[  OK  ] Finished Create System Files and Directories.
[   12.936873] audit: type=1334 audit(1736360579.180:7): prog-id=11 op=LOAD
         Starting Network Name Resolution...
[   12.952101] audit: type=1334 audit(1736360579.196:8): prog-id=12 op=LOAD
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Started User Database Manager.
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Found device /dev/ttyS2.
[   13.116928] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[   13.116964] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[   13.116988] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[   13.117686] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[   13.117959] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[   13.119436] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[   13.121507] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timer Units.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API...
[  OK  ] Listening on dropbear.socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
[   13.411896] CAN device driver interface
[   13.423804] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   13.431614] audit: type=1334 audit(1749547958.414:9): prog-id=13 op=LOAD
[   13.432912] mc: Linux media interface: v0.10
[   13.456088] videodev: Linux video capture interface: v2.00
         Starting D-Bus System Message Bus...
[   13.475266] PVR_K:  241: Device: 4e20000000.gpu
[   13.487462] cdns-mhdp8546 a000000.bridge: error -EINVAL: invalid resource (null)
[   13.495453] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
[   13.502007] PVR_K:  241: Read BVNC 36.53.104.796 from HW device registers
         Starting Reboot and dump vmcore via kexec.[   13.512043] PVR_K:  241: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
[  OK  ] Listening on Docker Socket for the API.
[   13.544572] [drm] Initialized pvr 24.2.6643903 for 4e20000000.gpu on minor 0
[   13.576996] at24 0-0050: supply vcc not found, using dummy regulator
[   13.592007] SError Interrupt on CPU0, code 0x00000000bf000002 -- SError
[   13.592030] CPU: 0 UID: 0 PID: 253 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
[   13.592037] Tainted: [O]=OOT_MODULE
[   13.592039] Hardware name: Texas Instruments J784S4 EVM (DT)
[   13.592042] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   13.592047] pc : _raw_spin_unlock_irqrestore+0x1c/0x44
[   13.592064] lr : __irq_put_desc_unlock+0x20/0x4c
[   13.592073] sp : ffff800080003cb0
[   13.592075] x29: ffff800080003cb0 x28: ffff00080196c880 x27: 0000000000000100
[   13.592082] x26: ffff0008016c1000 x25: fffffdffe00e1b00 x24: 0000000000000000
[   13.592087] x23: ffff000802f35608 x22: ffff000802f35630 x21: 0000000000000002
[   13.592092] x20: 0000000000000001 x19: ffff000801697400 x18: 0000000000000000
[   13.592097] x17: ffff800e8acef000 x16: ffff800080000000 x15: 01ab7ca5435f1726
[   13.592102] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000014
[   13.592106] x11: 0000000000000108 x10: ffff800080e35428 x9 : 1fffe001002a3fe1
[   13.592112] x8 : 0000000000000001 x7 : ffff00080151ff00 x6 : ffffffffffffffe0
[   13.592117] x5 : ffff00080150fa80 x4 : 0000000000000000 x3 : ffffffffffffffe0
[   13.592121] x2 : 0000000000000001 x1 : ffff000803478000 x0 : 0000000100000103
[   13.592128] Kernel panic - not syncing: Asynchronous SError Interrupt
[   13.592130] CPU: 0 UID: 0 PID: 253 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
[   13.592135] Tainted: [O]=OOT_MODULE
[   13.592137] Hardware name: Texas Instruments J784S4 EVM (DT)
[   13.592142] Call trace:
[   13.592144]  dump_backtrace+0x90/0xe8
[   13.592152]  show_stack+0x18/0x24
[   13.592156]  dump_stack_lvl+0x34/0x8c
[   13.592164]  dump_stack+0x18/0x24
[   13.592168]  panic+0x390/0x3a4
[   13.592175]  nmi_panic+0x40/0x8c
[   13.592180]  arm64_serror_panic+0x64/0x70
[   13.592185]  do_serror+0x3c/0x70
[   13.592189]  el1h_64_error_handler+0x30/0x48
[   13.592199]  el1h_64_error+0x64/0x68
[   13.592202]  _raw_spin_unlock_irqrestore+0x1c/0x44
[   13.592206]  enable_irq+0x60/0xa8
[   13.592211]  am65_cpsw_nuss_rx_poll+0x36c/0x994
[   13.592218]  __napi_poll+0x38/0x17c
[   13.592223]  net_rx_action+0x15c/0x2b8
[   13.592226]  handle_softirqs+0x104/0x248
[   13.592230]  __do_softirq+0x14/0x20
[   13.592232]  ____do_softirq+0x10/0x1c
[   13.592236]  call_on_irq_stack+0x24/0x4c
[   13.592239]  do_softirq_own_stack+0x1c/0x28
[   13.592243]  irq_exit_rcu+0x8c/0xc4
[   13.592246]  el1_interrupt+0x38/0x68
[   13.592250]  el1h_64_irq_handler+0x18/0x24
[   13.592254]  el1h_64_irq+0x64/0x68
[   13.592257]  _raw_spin_unlock_irqrestore+0x8/0x44
[   13.592261]  wake_up_q+0x60/0xc4
[   13.592266]  rwsem_wake.isra.0+0x7c/0xb0
[   13.592271]  up_write+0x7c/0x80
[   13.592274]  kernfs_add_one+0xec/0x148
[   13.592281]  __kernfs_create_file+0x90/0xf4
[   13.592286]  sysfs_add_bin_file_mode_ns+0x58/0xec
[   13.592292]  sysfs_create_bin_file+0x78/0xac
[   13.592296]  device_create_bin_file+0x14/0x28
[   13.592305]  nvmem_register+0x594/0x704
[   13.592311]  devm_nvmem_register+0x1c/0x70
[   13.592315]  at24_probe+0x4cc/0x738 [at24]
[   13.592337]  i2c_device_probe+0x148/0x290
[   13.592344]  really_probe+0xbc/0x29c
[   13.592350]  __driver_probe_device+0x78/0x12c
[   13.592354]  driver_probe_device+0xd8/0x15c
[   13.592358]  __driver_attach+0x90/0x19c
[   13.592362]  bus_for_each_dev+0x7c/0xdc
[   13.592365]  driver_attach+0x24/0x30
[   13.592369]  bus_add_driver+0xe4/0x208
[   13.592373]  driver_register+0x5c/0x124
[   13.592378]  i2c_register_driver+0x48/0xcc
[   13.592383]  at24_init+0x40/0x1000 [at24]
[   13.592390]  do_one_initcall+0x80/0x1c8
[   13.592393]  do_init_module+0x58/0x1fc
[   13.592399]  load_module+0x1bcc/0x1d8c
[   13.592403]  init_module_from_file+0x88/0xcc
[   13.592407]  __arm64_sys_finit_module+0x148/0x324
[   13.592411]  invoke_syscall+0x48/0x10c
[   13.592418]  el0_svc_common.constprop.0+0xc0/0xe0
[   13.592423]  do_el0_svc+0x1c/0x28
[   13.592427]  el0_svc+0x28/0x98
[   13.592431]  el0t_64_sync_handler+0x120/0x12c
[   13.592436]  el0t_64_sync+0x190/0x194
[   13.592440] SMP: stopping secondary CPUs
[   13.592454] Kernel Offset: disabled
[   13.592456] CPU features: 0x08,00002002,80200000,4200420b
[   13.592459] Memory Limit: none
[   13.976559] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
I/TC:
0 Bytes
In:    serial@2880000
Out:   serial@2880000
Err:   serial@2880000
Running uenvcmd ...
Filename 'Image'.
	 3.1 MiB/s
done
	 8.3 MiB/s
done
Starting kernel ...
[    0.000336] Console: colour dummy device 80x25
[    0.000375] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.000382] pid_max: default: 32768 minimum: 301
[    0.000428] LSM: initializing lsm=capability,selinux
[    0.000469] SELinux:  Initializing.
[    0.000879] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000942] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.002459] rcu: Hierarchical SRCU implementation.
[    0.002462] rcu: 	Max phase no-delay instances is 1000.
[    0.002584] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.004234] EFI services will not be available.
[    0.007955] smp: Bringing up secondary CPUs ...
[    0.024220] Detected PIPT I-cache on CPU1
[    0.024271] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.024285] GICv3: CPU1: using allocated LPI pending table @0x0000000880090000
[    0.024321] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.032843] Detected PIPT I-cache on CPU2
[    0.032872] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
[    0.032884] GICv3: CPU2: using allocated LPI pending table @0x00000008800a0000
[    0.032908] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
[    0.041383] Detected PIPT I-cache on CPU3
[    0.041415] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
[    0.041428] GICv3: CPU3: using allocated LPI pending table @0x00000008800b0000
[    0.041451] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
[    0.052365] Detected PIPT I-cache on CPU4
[    0.052426] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
[    0.052439] GICv3: CPU4: using allocated LPI pending table @0x00000008800c0000
[    0.052473] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
[    0.061009] Detected PIPT I-cache on CPU5
[    0.061046] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
[    0.061059] GICv3: CPU5: using allocated LPI pending table @0x00000008800d0000
[    0.061083] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
[    0.072341] Detected PIPT I-cache on CPU6
[    0.072381] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
[    0.072393] GICv3: CPU6: using allocated LPI pending table @0x00000008800e0000
[    0.072417] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
[    0.080910] Detected PIPT I-cache on CPU7
[    0.080952] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
[    0.080965] GICv3: CPU7: using allocated LPI pending table @0x00000008800f0000
[    0.080989] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
[    0.081074] smp: Brought up 1 node, 8 CPUs
[    0.081079] SMP: Total of 8 processors activated.
[    0.081081] CPU: All CPU(s) started at EL2
[    0.081083] CPU features: detected: 32-bit EL0 Support
[    0.081085] CPU features: detected: CRC32 instructions
[    0.081120] alternatives: applying system-wide alternatives
[    0.081478] Memory: 30757804K/33554432K available (12928K kernel code, 1254K rwdata, 4648K rodata, 2752K init, 639K bss, 950064K reserved, 1835008K cma-reserved)
[    0.082103] devtmpfs: initialized
[    0.093905] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.093918] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.115735] 27152 pages in range for non-PLT usage
[    0.115743] 518672 pages in range for PLT usage
[    0.115968] pinctrl core: initialized pinctrl subsystem
[    0.116283] DMI not present or invalid.
[    0.117986] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.119271] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.119975] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.120689] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.120721] audit: initializing netlink subsys (disabled)
[    0.120862] audit: type=2000 audit(0.120:1): state=initialized audit_enabled=0 res=1
[    0.121080] thermal_sys: Registered thermal governor 'step_wise'
[    0.121083] thermal_sys: Registered thermal governor 'power_allocator'
[    0.121109] cpuidle: using governor menu
[    0.121184] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.121292] ASID allocator initialised with 65536 entries
[    0.126814] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
[    0.126916] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.126939] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.126963] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.127190] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.127199] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.127223] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.127245] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.127255] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.131333] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.131362] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.131400] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.134586] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.134624] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.134641] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.134790] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.135020] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.135055] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
[    0.135097] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.135129] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.135967] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /connector-dp0
[    0.136019] /connector-dp0: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
[    0.137235] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.137238] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.137241] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.137243] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.137245] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.137246] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.137249] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.137250] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.138185] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
[    0.138726] iommu: Default domain type: Translated
[    0.138729] iommu: DMA domain TLB invalidation policy: strict mode
[    0.139101] SCSI subsystem initialized
[    0.139269] usbcore: registered new interface driver usbfs
[    0.139281] usbcore: registered new interface driver hub
[    0.139301] usbcore: registered new device driver usb
[    0.139570] pps_core: LinuxPPS API ver. 1 registered
[    0.139573] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.139579] PTP clock support registered
[    0.139598] EDAC MC: Ver: 3.0.0
[    0.139738] scmi_core: SCMI protocol bus registered
[    0.139888] FPGA manager framework
[    0.139931] Advanced Linux Sound Architecture Driver Initialized.
[    0.140391] vgaarb: loaded
[    0.140575] clocksource: Switched to clocksource arch_sys_counter
[    0.140709] VFS: Disk quotas dquot_6.6.0
[    0.140721] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.144493] NET: Registered PF_INET protocol family
[    0.144800] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.150003] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.150146] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.150165] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.150973] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.151851] TCP: Hash tables configured (established 262144 bind 65536)
[    0.151948] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.152260] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.152702] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.153031] RPC: Registered named UNIX socket transport module.
[    0.153035] RPC: Registered udp transport module.
[    0.153037] RPC: Registered tcp transport module.
[    0.153038] RPC: Registered tcp-with-tls transport module.
[    0.153040] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.153046] NET: Registered PF_XDP protocol family
[    0.153059] PCI: CLS 0 bytes, default 64
[    0.154089] Initialise system trusted keyrings
[    0.154194] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    0.154367] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.154497] NFS: Registering the id_resolver key type
[    0.154511] Key type id_resolver registered
[    0.154513] Key type id_legacy registered
[    0.154525] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.154528] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.176020] Key type asymmetric registered
[    0.176025] Asymmetric key parser 'x509' registered
[    0.176058] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.176152] io scheduler mq-deadline registered
[    0.176155] io scheduler kyber registered
[    0.176170] io scheduler bfq registered
[    0.178790] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
[    0.178892] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
[    0.179057] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
[    0.179365] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
[    0.179495] pinctrl-single 11c000.pinctrl: 72 pins, size 288
[    0.179880] pinctrl-single 104200.pinctrl: 20 pins, size 80
[    0.179954] pinctrl-single 104280.pinctrl: 8 pins, size 32
[    0.180667] ledtrig-cpu: registered to indicate activity on CPUs
[    0.184434] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.189920] loop: module loaded
[    0.190565] megasas: 07.727.03.00-rc1
[    0.192528] tun: Universal TUN/TAP device driver, 1.6
[    0.193114] VFIO - User Level meta-driver version: 0.3
[    0.193840] usbcore: registered new interface driver usb-storage
[    0.194234] i2c_dev: i2c /dev entries driver
[    0.194955] sdhci: Secure Digital Host Controller Interface driver
[    0.194958] sdhci: Copyright(c) Pierre Ossman
[    0.195098] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.195532] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.195934] usbcore: registered new interface driver usbhid
[    0.195936] usbhid: USB HID core driver
[    0.196702] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
[    0.197036] optee: probing for conduit method.
[    0.197054] optee: revision 4.5 (ef1ebdc23034a804)
[    0.213500] optee: dynamic shared memory is enabled
[    0.213894] optee: initialized driver
[    0.213987] random: crng init done
[    0.214118] mux muxchip0: unable to set idle state
[    0.214122] mmio-mux 104080.mux-controller: probe with driver mmio-mux failed with error -5
[    0.215224] Initializing XFRM netlink socket
[    0.215241] NET: Registered PF_PACKET protocol family
[    0.215285] Key type dns_resolver registered
[    0.219179] registered taskstats version 1
[    0.219450] Loading compiled-in X.509 certificates
[    0.226658] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)')
[    0.305489] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
[    0.306242] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.306300] pca953x 3-0020: using no AI
[    0.321644] pca953x 3-0022: supply vcc not found, using dummy regulator
[    0.321691] pca953x 3-0022: using AI
[    0.322904] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.323342] pca953x 4-0020: supply vcc not found, using dummy regulator
[    0.323384] pca953x 4-0020: using no AI
[    0.337072] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
[    0.337687] pca953x 5-0020: supply vcc not found, using dummy regulator
[    0.337745] pca953x 5-0020: using no AI
[    0.352939] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.352973] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel
[    0.352996] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
[    0.353104] /bus@100000/i2c@2040000/dsi-edp-bridge@2c/aux-bus/panel: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
[    0.353174] omap_i2c 2040000.i2c: bus 5 rev0.12 at 400 kHz
[    0.353768] pca953x 6-0020: supply vcc not found, using dummy regulator
[    0.353816] pca953x 6-0020: using no AI
[    0.368913] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[    0.369027] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
[    0.369117] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
[    0.369216] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
[    0.369445] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
[    0.375379] ti-udma 311a0000.dma-controller: Number of rings: 48
[    0.376899] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
[    0.378377] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
[    0.378382] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    0.378385] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    0.380403] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
[    0.380409] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    0.380412] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[    0.381102] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 275, base_baud = 6000000) is a 8250
[    0.381706] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 276, base_baud = 3000000) is a 8250
[    0.381756] printk: legacy console [ttyS2] enabled
[    2.888576] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.899494] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    2.907766] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    2.920646] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    2.927858] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    2.935256] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    2.984580] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    2.995200] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    3.003294] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    3.016067] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    3.022364] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    3.029490] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
[    3.036691] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
[    3.046982] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
[    3.055900] mmc0: CQHCI version 5.10
[    3.100744] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    3.192690] mmc0: Command Queue Engine enabled
[    3.197136] mmc0: new HS400 MMC card at address 0001
[    3.202610] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    3.208142]  mmcblk0: p1 p2
[    3.211264] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    3.216805] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    3.222311] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    3.330339] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
[    3.338924] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.346429] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.354520] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.362606] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    4.477174] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
[    4.483447] pci_bus 0000:00: root bus resource [bus 00-ff]
[    4.488924] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x10001000-0x10010fff])
[    4.498385] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff]
[    4.505272] pci 0000:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
[    4.512570] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    4.522222] pci 0000:00:00.0: PCI bridge to [bus 00]
[    4.527178] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    4.533259] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    4.540040] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    4.547854] pci 0000:00:00.0: supports D1
[    4.551854] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    4.559516] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    4.567621] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    4.574242] pci 0000:00:00.0: PCI bridge to [bus 01]
[    4.579206] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    4.584768] pci_bus 0000:00: resource 5 [mem 0x10011000-0x17ffffff]
[    4.591079] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
[    4.597875] pcieport 0000:00:00.0: PME: Signaling with IRQ 538
[    4.603887] pcieport 0000:00:00.0: AER: enabled with IRQ 538
[    4.609795] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    4.617282] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    4.625368] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    4.633452] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    5.744688] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
[    5.750953] pci_bus 0001:00: root bus resource [bus 00-ff]
[    5.756429] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x18001000-0x18010fff])
[    5.766064] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff]
[    5.772941] pci 0001:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
[    5.780237] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[    5.789901] pci 0001:00:00.0: PCI bridge to [bus 00]
[    5.794858] pci 0001:00:00.0:   bridge window [io  0x0000-0x0fff]
[    5.800939] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    5.807719] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
[    5.815558] pci 0001:00:00.0: supports D1
[    5.819559] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
[    5.825318] pci 0001:00:00.0: VF BAR 0 [mem 0x00000000-0x003fffff 64bit]
[    5.832004] pci 0001:00:00.0: VF BAR 0 [mem 0x00000000-0x00ffffff 64bit]: contains BAR 0 for 4 VFs
[    5.842877] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    5.850980] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    5.857598] pci 0001:00:00.0: VF BAR 0 [mem 0x18400000-0x193fffff 64bit]: assigned
[    5.865157] pci 0001:00:00.0: PCI bridge to [bus 01]
[    5.870118] pci_bus 0001:00: resource 4 [io  0x10000-0x1ffff]
[    5.875851] pci_bus 0001:00: resource 5 [mem 0x18011000-0x1fffffff]
[    5.882143] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
[    5.888918] pcieport 0001:00:00.0: PME: Signaling with IRQ 540
[    5.894876] pcieport 0001:00:00.0: AER: enabled with IRQ 540
[    5.901344] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
[    5.911672] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
[    5.923627] spi-nand spi0.0: Winbond SPI NAND was found.
[    5.928946] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
[    5.937447] 7 fixed-partitions partitions found on MTD device spi0.0
[    5.943797] Creating 7 MTD partitions on "spi0.0":
[    5.948584] 0x000000000000-0x000000100000 : "ospi_nand.tiboot3"
[    5.955649] 0x000000100000-0x000000300000 : "ospi_nand.tispl"
[    5.962422] 0x000000300000-0x000000700000 : "ospi_nand.u-boot"
[    5.969840] 0x000000700000-0x000000740000 : "ospi_nand.env"
[    5.976072] 0x000000740000-0x000000780000 : "ospi_nand.env.backup"
[    5.982902] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
[    6.010616] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
[    6.017474] cadence-qspi 47040000.spi: Pattern not found. Skipping calibration.
[    6.027033] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
[    6.034077] Creating 7 MTD partitions on "47050000.spi.0":
[    6.039557] 0x000000000000-0x000000080000 : "qspi.tiboot3"
[    6.045634] 0x000000080000-0x000000280000 : "qspi.tispl"
[    6.051521] 0x000000280000-0x000000680000 : "qspi.u-boot"
[    6.057488] 0x000000680000-0x0000006c0000 : "qspi.env"
[    6.063187] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
[    6.069471] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
[    6.075483] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
[    6.116576] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.127377] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    6.135646] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    6.148524] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    6.155734] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
[    6.163090] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
[    6.179920] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    6.228579] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    6.239289] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
[    6.247391] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[    6.260244] am65-cpsw-nuss c200000.ethernet: Use random MAC address
[    6.266585] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
[    6.273714] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
[    6.281192] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[    6.298254] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
[    6.308581] mmc1: CQHCI version 5.10
[    6.349176] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    6.370655] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    6.380145] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    6.537509] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    6.544581] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
[    6.553769]  mmcblk1: p1 p2
[   10.495737] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   10.516584] IP-Config: Complete:
[   10.519802]      device=eth0, hwaddr=04:25:e8:b6:b0:26, ipaddr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255
[   10.530223]      host=192.168.1.10, domain=, nis-domain=(none)
[   10.536043]      bootserver=255.255.255.255, rootserver=192.168.1.20, rootpath=
[   10.536142] clk: Disabling unused clocks
[   10.559113] PM: genpd: Disabling unused power domains
[   10.564267] ALSA device list:
[   10.567300]   No soundcards found.
[   10.576572] VFS: Mounted root (nfs filesystem) on device 0:23.
[   10.582544] devtmpfs: mounted
[   10.586489] Freeing unused kernel memory: 2752K
[   10.591097] Run /sbin/init as init process
[   10.744561] systemd[1]: System time before build time, advancing clock.
[   10.780352] NET: Registered PF_INET6 protocol family
[   10.786889] Segment Routing with IPv6
[   10.790563] In-situ OAM (IOAM) with IPv6
[   10.822048] systemd[1]: systemd 255.17^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[   10.853927] systemd[1]: Detected architecture arm64.
[   10.874713] systemd[1]: Hostname set to <j784s4-evm-custom>.
[   11.121894] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   11.228994] systemd[1]: Queued start job for default target Graphical Interface.
[   11.291666] systemd[1]: Created slice Slice /system/getty.
[   11.313641] systemd[1]: Created slice Slice /system/modprobe.
[   11.333552] systemd[1]: Created slice Slice /system/serial-getty.
[   11.353376] systemd[1]: Created slice User and Session Slice.
[   11.372750] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   11.392707] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.412651] systemd[1]: Expecting device /dev/ttyS2...
[   11.424678] systemd[1]: Reached target Path Units.
[   11.436635] systemd[1]: Reached target Remote File Systems.
[   11.452629] systemd[1]: Reached target Slice Units.
[   11.464637] systemd[1]: Reached target Swaps.
[   11.514820] systemd[1]: Listening on RPCbind Server Activation Socket.
[   11.536697] systemd[1]: Reached target RPC Port Mapper.
[   11.560985] systemd[1]: Listening on Process Core Dump Socket.
[   11.580789] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.605499] systemd[1]: Listening on Journal Audit Socket.
[   11.629269] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.648902] systemd[1]: Listening on Journal Socket.
[   11.661301] systemd[1]: Listening on Network Service Netlink Socket.
[   11.681917] systemd[1]: Listening on udev Control Socket.
[   11.700817] systemd[1]: Listening on udev Kernel Socket.
[   11.717190] systemd[1]: Listening on User Database Manager Socket.
[   11.760800] systemd[1]: Mounting Huge Pages File System...
[   11.779102] systemd[1]: Mounting POSIX Message Queue File System...
[   11.798947] systemd[1]: Mounting Kernel Debug File System...
[   11.816872] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[   11.832599] systemd[1]: Mounting Temporary Directory /tmp...
[   11.851751] systemd[1]: Starting Create List of Static Device Nodes...
[   11.871188] systemd[1]: Starting Load Kernel Module configfs...
[   11.887564] systemd[1]: Starting Load Kernel Module drm...
[   11.903465] systemd[1]: Starting Load Kernel Module fuse...
[   11.924985] systemd[1]: Starting Start psplash boot splash screen...
         Starting Start psplash boot splash screen.[   11.935682] fuse: init (API version 7.41)
[   11.957837] systemd[1]: Starting RPC Bind...
[   11.969132] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   11.986713] systemd[1]: Starting Journal Service...
[   12.004413] systemd[1]: Starting Load Kernel Modules...
[   12.020096] systemd[1]: Starting Generate network units from Kernel command line...
[   12.038087] cryptodev: loading out-of-tree module taints kernel.
[   12.044988] sysctl table check failed: ioctl/(null) procname is null
[   12.045773] systemd-journald[174]: Collecting audit messages is enabled.
[   12.047658] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.051396] sysctl table check failed: ioctl/(null) No proc_handler
[   12.071021] cryptodev: driver 1.14 loaded.
[0m...
[   12.096992] systemd[1]: Started RPC Bind.
[   12.117807] systemd[1]: Started Journal Service.
         Starting Create Static Device Nodes in /dev gr[   12.428337] systemd-journald[174]: Received client request to flush runtime journal.
acefully...
[   12.638932] audit: type=1334 audit(1736360578.892:2): prog-id=6 op=LOAD
[   12.645596] audit: type=1334 audit(1736360578.900:3): prog-id=7 op=LOAD
[   12.785473] audit: type=1334 audit(1736360579.040:4): prog-id=8 op=LOAD
[   12.792123] audit: type=1334 audit(1736360579.044:5): prog-id=9 op=LOAD
[   12.798773] audit: type=1334 audit(1736360579.052:6): prog-id=10 op=LOAD
[   12.884812] audit: type=1334 audit(1736360579.140:7): prog-id=11 op=LOAD
[   12.930705] audit: type=1334 audit(1736360579.184:8): prog-id=12 op=LOAD
[   13.080498] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
[   13.081759] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
[   13.081969] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
[   13.083541] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
[   13.087752] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
[   13.101210] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
[   13.375614] CAN device driver interface
[  OK  ] Listening on PC/SC Smart Card Daemo[   13.410066] SError Interrupt on CPU0, code 0x00000000bf000002 -- SError
[   13.410085] CPU: 0 UID: 0 PID: 235 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
[   13.410092] Tainted: [O]=OOT_MODULE
[   13.410094] Hardware name: Texas Instruments J784S4 EVM (DT)
[   13.410097] pstate: 400000c5 (nZcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[   13.410102] pc : _raw_spin_unlock+0x18/0x40
[   13.410119] lr : handle_irq_event+0x44/0xa8
[   13.410130] sp : ffff800080003a00
[   13.410132] x29: ffff800080003a00 x28: ffff000804f2a100 x27: 0000000000000100
[   13.410140] x26: ffff000803642000 x25: ffff000804cf5800 x24: 0000000000000001
[   13.410145] x23: ffff000805374a30 x22: ffff0008041714ac x21: ffff000804171430
[   13.410150] x20: ffff000804171430 x19: ffff000804171400 x18: 0000000000000000
[   13.410155] x17: ffff800e8acef000 x16: ffff800080000000 x15: ffff000f0bf03240
[   13.410159] x14: 0000000000000000 x13: 0000000000000000 x12: 0000000000000014
[   13.410164] x11: 0000000000000040 x10: ffff000803adf8b0 x9 : ffff000803adf8a8
[   13.410169] x8 : ffff000803160dd8 x7 : 0000000000000000 x6 : 0000000000000000
[   13.410174] x5 : ffff800e8acef000 x4 : ffff800080003a30 x3 : ffff800e8acef000
[   13.410179] x2 : ffff000804171400 x1 : ffff000804f2a100 x0 : 0000000100010101
[   13.410186] Kernel panic - not syncing: Asynchronous SError Interrupt
[   13.410188] CPU: 0 UID: 0 PID: 235 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
[   13.410193] Tainted: [O]=OOT_MODULE
[   13.410195] Hardware name: Texas Instruments J784S4 EVM (DT)
[   13.410198] Call trace:
[   13.410201]  dump_backtrace+0x90/0xe8
[   13.410211]  show_stack+0x18/0x24
[   13.410215]  dump_stack_lvl+0x34/0x8c
[   13.410222]  dump_stack+0x18/0x24
[   13.410226]  panic+0x390/0x3a4
[   13.410233]  nmi_panic+0x40/0x8c
[   13.410237]  arm64_serror_panic+0x64/0x70
[   13.410243]  do_serror+0x3c/0x70
[   13.410248]  el1h_64_error_handler+0x30/0x48
[   13.410254]  el1h_64_error+0x64/0x68
[   13.410257]  _raw_spin_unlock+0x18/0x40
[   13.410261]  handle_level_irq+0xc0/0x1a8
[   13.410265]  handle_irq_desc+0x40/0x58
[   13.410269]  generic_handle_domain_irq+0x1c/0x28
[   13.410274]  ti_sci_inta_irq_handler+0x7c/0x128
[   13.410282]  handle_irq_desc+0x40/0x58
[   13.410287]  generic_handle_domain_irq+0x1c/0x28
[   13.410292]  gic_handle_irq+0x54/0xd0
[   13.410295]  do_interrupt_handler+0x50/0x8c
[   13.410298]  el1_interrupt+0x34/0x68
[   13.410302]  el1h_64_irq_handler+0x18/0x24
[   13.410307]  el1h_64_irq+0x64/0x68
[   13.410310]  _raw_spin_unlock_irqrestore+0x1c/0x44
[   13.410314]  enable_irq+0x60/0xa8
[   13.410320]  am65_cpsw_nuss_rx_poll+0x36c/0x994
[   13.410328]  __napi_poll+0x38/0x17c
[   13.410334]  net_rx_action+0x15c/0x2b8
[   13.410338]  handle_softirqs+0x104/0x248
[   13.410342]  __do_softirq+0x14/0x20
[   13.410345]  ____do_softirq+0x10/0x1c
[   13.410348]  call_on_irq_stack+0x24/0x4c
[   13.410352]  do_softirq_own_stack+0x1c/0x28
[   13.410356]  irq_exit_rcu+0x8c/0xc4
[   13.410359]  el1_interrupt+0x38/0x68
[   13.410363]  el1h_64_irq_handler+0x18/0x24
[   13.410368]  el1h_64_irq+0x64/0x68
[   13.410371]  _raw_spin_unlock_irqrestore+0x8/0x44
[   13.410376]  mbox_send_message+0xb4/0x130
[   13.410384]  ti_sci_manage_irq.constprop.0+0xd4/0x260
[   13.410392]  ti_sci_cmd_set_event_map+0x40/0x50
[   13.410396]  ti_sci_inta_request_resources+0x150/0x4e4
[   13.410402]  irq_chip_request_resources_parent+0x20/0x34
[   13.410408]  __setup_irq+0x2ac/0x6d0
[   13.410413]  request_threaded_irq+0xc8/0x1ac
[   13.410417]  udma_alloc_chan_resources+0x450/0x8f4
[   13.410424]  dma_chan_get+0x7c/0x1e4
[   13.410428]  find_candidate+0x138/0x1e0
[   13.410432]  __dma_request_channel+0x80/0xfc
[   13.410436]  udma_of_xlate+0x84/0x114
[   13.410439]  of_dma_request_slave_channel+0x174/0x274
[   13.410444]  dma_request_chan+0x40/0x28c
[   13.410447]  sa_ul_probe+0x19c/0x524 [sa2ul]
[   13.410469]  platform_probe+0x68/0xc4
[   13.410479]  really_probe+0xbc/0x29c
[   13.410483]  __driver_probe_device+0x78/0x12c
[   13.410487]  driver_probe_device+0xd8/0x15c
[   13.410492]  __driver_attach+0x90/0x19c
[   13.410496]  bus_for_each_dev+0x7c/0xdc
[   13.410500]  driver_attach+0x24/0x30
[   13.410504]  bus_add_driver+0xe4/0x208
[   13.410508]  driver_register+0x5c/0x124
[   13.410513]  __platform_driver_register+0x24/0x30
[   13.410518]  sa_ul_driver_init+0x20/0x1000 [sa2ul]
[   13.410524]  do_one_initcall+0x80/0x1c8
[   13.410528]  do_init_module+0x58/0x1fc
[   13.410535]  load_module+0x1bcc/0x1d8c
[   13.410539]  init_module_from_file+0x88/0xcc
[   13.410543]  __arm64_sys_finit_module+0x148/0x324
[   13.410547]  invoke_syscall+0x48/0x10c
[   13.410552]  el0_svc_common.constprop.0+0xc0/0xe0
[   13.410556]  do_el0_svc+0x1c/0x28
[   13.410560]  el0_svc+0x28/0x98
[   13.410565]  el0t_64_sync_handler+0x120/0x12c
[   13.410569]  el0t_64_sync+0x190/0x194
[   13.410572] SMP: stopping secondary CPUs
[   13.410586] Kernel Offset: disabled
[   13.410588] CPU features: 0x08,00002002,80200000,4200420b
[   13.410592] Memory Limit: none
[   13.863737] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
  • Hi Gokhan,
    Does the kernel panic occur in the same spot every time, or does it vary?
    Does this occur with warm resets or only cold resets?
    Jared
  • Hi Jared,
    It seems to occur with nearly same timestamp values (~13 sec).
    Two example log files above are taken from two different sessions and the kernel panic time is nearly same.
    I am sure i witnessed this with warm resets but not sure with cold resets.
  • Hi Gokhan,
    Which image are you building?
    I will see if I can replicate your issue on my end.
    Jared
  • Hi Jared,
    The information about Yocto image build process is inside the question description. (Information section)
  • Hi Gokhan,
    I see which config you are using, but I don't see which image you built.
    Jared
  • Hi Jared,
    I am building "tisdk-default-image".
  • Hi Gokhan,
    I will see if I can replicate the issue on my end, but in the interim, can you try using a processor-sdk-linux config?
    Jared
  • Hi Jared,
    I looked for a config file that best match with the "ti-processor-sdk-linux-adas-j784s4-evm-11_00_00_08" version. Since "processor-sdk-scarthgap-11.00.09.04-config.txt" is the only one that has version 11, I used that one. As far as i see, the latest configuration inside processor-sdk-linux is "processor-sdk-linux-10_01_08_01.txt". Can you confirm? If you direct me to an 11 version processor-sdk-linux file, i could use that one.
  • Hi Gokhan,
    I apologize, I see that there isn't a config for 11.0 currently; I assumed there would be. I asked, because this is where the J7 release configs are stored. The Sitara release configs are stored in the processor-sdk directory.
    I am currently constantly rebooting a board with a tisdk-default-image generated using the processor-sdk config, and will report if I see your kernel panic issue.
    Jared
  • Hi Gokhan,
    I was unable to recreate your issue with an SD card. I am now attempting it using NFS for the rootfs.
    Jared
  • Hi Gokhan
    I was able to see a kernel panic after 89 reboots. It appears to be a different issue than yours, however.
    [    8.747506] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
    [    8.754320] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [    8.766233] remoteproc remoteproc4: 5900000.r5f is available
    [    8.767470] remoteproc remoteproc5: 65800000.dsp is available
    [    8.772614] remoteproc remoteproc4: attaching to 5900000.r5f
    [    8.781066] remoteproc remoteproc5: attaching to 65800000.dsp
    [    8.784179] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    8.784188] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    8.784192] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    8.784195] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    8.789407] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node r5f-dma-memory@a6000000
    [    8.795930] remoteproc remoteproc5: unsupported resource 65538
    [    8.800266] SError Interrupt on CPU0, code 0x00000000bf000002 -- SError
    [    8.800280] CPU: 0 UID: 0 PID: 270 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
    [    8.800286] Tainted: [O]=OOT_MODULE
    [    8.800288] Hardware name: Texas Instruments J784S4 EVM (DT)
    [    8.800291] pstate: 800000c5 (Nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [    8.800295] pc : _raw_spin_unlock+0x18/0x40
    [    8.800311] lr : handle_level_irq+0xe0/0x1a8
    [    8.800317] sp : ffff800080003f20
    [    8.800319] x29: ffff800080003f20 x28: ffff00080657e300 x27: 0000000000000000
    [    8.800326] x26: ffff000f0bf04300 x25: ffff000802f82400 x24: 0000000000000001
    [    8.800331] x23: ffff000802f8f030 x22: ffff00080354f800 x21: ffff0008035934ac
    [    8.800336] x20: ffff000803593430 x19: ffff000803593400 x18: 0000000000000000
    [    8.800341] x17: ffff800e8acef000 x16: ffff800080000000 x15: 00625a979c4a22e0
    [    8.800345] x14: 000089ac96b76c64 x13: 000000000000007c x12: 000000000000007c
    [    8.800350] x11: 0000000000000040 x10: ffff00080354f8b0 x9 : ffff00080354f8a8
    [    8.800355] x8 : ffff000f0bf00f58 x7 : a35bcd24d4973214 x6 : ffffffffffffffe0
    [    8.800359] x5 : ffff00080150a480 x4 : 0000000000000000 x3 : ffffffffffffffe0
    [    8.800364] x2 : ffff800083a00000 x1 : ffff00080657e300 x0 : 0000000000010001
    [    8.800370] Kernel panic - not syncing: Asynchronous SError Interrupt
    [    8.800372] CPU: 0 UID: 0 PID: 270 Comm: (udev-worker) Tainted: G           O       6.12.17-ti-00771-gc85877d40f8e #1
    [    8.800377] Tainted: [O]=OOT_MODULE
    [    8.800378] Hardware name: Texas Instruments J784S4 EVM (DT)
    [    8.800381] Call trace:
    [    8.800382]  dump_backtrace+0x90/0xe8
    [    8.800392]  show_stack+0x18/0x24
    [    8.800396]  dump_stack_lvl+0x34/0x8c
    [    8.800402]  dump_stack+0x18/0x24
    [    8.800405]  panic+0x390/0x3a4
    [    8.800412]  nmi_panic+0x40/0x8c
    [    8.800416]  arm64_serror_panic+0x64/0x70
    [    8.800421]  do_serror+0x3c/0x70
    [    8.800426]  el1h_64_error_handler+0x30/0x48
    [    8.800432]  el1h_64_error+0x64/0x68
    [    8.800434]  _raw_spin_unlock+0x18/0x40
    [    8.800438]  handle_irq_desc+0x40/0x58
    [    8.800443]  generic_handle_domain_irq+0x1c/0x28
    [    8.800447]  ti_sci_inta_irq_handler+0x7c/0x128
    [    8.800455]  handle_irq_desc+0x40/0x58
    [    8.800459]  generic_handle_domain_irq+0x1c/0x28
    [    8.800462]  gic_handle_irq+0x54/0xd0
    [    8.800465]  call_on_irq_stack+0x24/0x4c
    [    8.800469]  do_interrupt_handler+0x80/0x8c
    [    8.800473]  el1_interrupt+0x34/0x68
    [    8.800477]  el1h_64_irq_handler+0x18/0x24
    [    8.800481]  el1h_64_irq+0x64/0x68
    [    8.800483]  smp_call_function_many_cond+0x150/0x3c0
    [    8.800488]  kick_all_cpus_sync+0x44/0x70
    [    8.800491]  load_module+0x1750/0x1d8c
    [    8.800499]  init_module_from_file+0x88/0xcc
    [    8.800503]  __arm64_sys_finit_module+0x148/0x324
    [    8.800507]  invoke_syscall+0x48/0x10c
    [    8.800512]  el0_svc_common.constprop.0+0xc0/0xe0
    [    8.800516]  do_el0_svc+0x1c/0x28
    [    8.800520]  el0_svc+0x28/0x98
    [    8.800524]  el0t_64_sync_handler+0x120/0x12c
    [    8.800527]  el0t_64_sync+0x190/0x194
    [    8.800532] SMP: stopping secondary CPUs
    [    9.855535] SMP: failed to stop secondary CPUs 4
    [    9.855542] Kernel Offset: disabled
    [    9.855544] CPU features: 0x08,00002002,80200000,4200420b
    [    9.855547] Memory Limit: none
    [   10.220942] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
    Jared
  • Hi Jared,
    I will switch to version 11 config inside processor-sdk-linux directory when it is available. I will periodically check the repository in future. For the kernel panic case on my side, i will also try to narrow down the error, maybe enable some kernel debug config to be able to get more information and share them with you. I will also check if I get this error when i use the prebuilt image that is created with create-sdcard.sh script provided with ti-processor-sdk-linux-adas-j784s4-evm-11_00_00_08 package. Thanks for your patience and effort for trying 89 reboots :)
  • Hi Gokhan,
    Let me know what your results are. Running another test, it's made it to 208 reboots (so far), so I don't think I am able to recreate your issue.
    Could your issue be due to a drop in connectivity between the nfs server and client?
    New note: board rebooted 482 times before I stopped the test.
    Jared
  • Hi Jared,
    With the prebuilt image created with processor-sdk-linux-adas-j784s4-evm-11_00_00_08 (boot mode: sdcard), i also can not recreate the issue.
    There are 2 possible suspects; yocto image or nfs boot mode like you suggested.
    Now, I will try with the yocto image without nfs (boot from sdcard) in order to isolate the problem. I will keep you posted.
  • Hi Gokhan,
    You can also test processor-sdk-linux-adas-j784s4-evm-11_00_00_08 with NFS. Let me know the results of your experiment.
    Jared
  • Hi Jared,
    I tested below configurations.
    Yocto + without NFS = 181 reboots successful.
    Yocto + NFS = 32 reboots until kernel panic occured.
    Processor SDK Linux + NFS = 76 reboots until kernel panic occured.
    Also you and i have checked "Processor SDK Linux + without NFS" configuration before and did not see a kernel panic.
    In summary, this could be a NFS issue "due to a drop in connectivity between the nfs server and client" as you have pointed out.
    I will not debug this issue further since it is hard to detect if it's our company network responsible or some issue in kernel network drivers/init scripts, etc. Since we use NFS workflow in our development phase, i can live with this issue.
    Thanks for pointing me to the right direction and for your time.
    Gokhan
