Other Parts Discussed in Thread: TLV320AIC33
I am working on DM355-leopard board .I loaded uimage and ramdisk to
RAM after that i gave bootm 0x80700000 command then i got as follows
DM355 LEOPARD# bootm 0x80700000
## Booting image at 80700000 ...
Image Name: Linux-2.6.10_mvl401
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1578988 Bytes = 1.5 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
OK
Starting kernel ...
Linux version 2.6.10_mvl401 (a0868396@gtcmbuild3.gt.design.ti.com) (gcc version8
CPU: ARM926EJ-Sid(wb) [41069265] revision 5 (ARMv5TEJ)
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
Machine: DaVinci DM355 EVM
Memory policy: ECC disabled, Data cache writeback
DM0350
Built 1 zonelists
Kernel command line: ip=dhcp mem=80M console=ttyS0,115200n8 root=/dev/ram0 rw i=
PID hash table entries: 512 (order: 9, 8192 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 80MB = 80MB total
Memory: 69376KB available (2748K code, 570K data, 180K init)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
spawn_desched_task(00000000)
desched cpu_callback 3/00000000
ksoftirqd started up.
desched cpu_callback 2/00000000
checking if image is initramfs...it isn't (bad gzip magic numbers); looks like d
desched thread 0 started up.
Freeing initrd memory: 8192K
NET: Registered protocol family 16
DaVinci: 104 gpio irqs
Registering platform device 'serial8250.0'. Parent at platform
Registering platform device 'musb_hdrc'. Parent at platform
Registering platform device 'nand_davinci.0'. Parent at platform
Registering platform device 'dm9000.0'. Parent at platform
Registering platform device 'mmc.0'. Parent at platform
Registering platform device 'mmc.1'. Parent at platform
DaVinci I2C DEBUG: 23:57:20 Feb 2 2008
Registering platform device 'i2c'. Parent at platform
ch0 default output "COMPOSITE", mode "NTSC"
VPBE Encoder Initialized
LogicPD encoder initialized
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
musb_hdrc: version 2.2a/db-0.4.8 [cppi-dma] [host] [debug=0]
musb_hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
musb_hdrc: MHDRC RTL version 1.300
musb_hdrc: USB Host mode controller at c5802000 using DMA, IRQ 12
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
DaVinci I2C WARNING: i2c: NACK detected
Registering platform device 'dm_spi.0'. Parent at platform
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
yaffs Feb 2 2008 23:56:53 Installing.
Initializing Cryptographic API
Registering platform device 'davincifb.0'. Parent at platform
davincifb davincifb.0: dm_osd0_fb: 720x480x16@0,0 with framebuffer size 1350KB
davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 675KB
davincifb davincifb.0: dm_osd1_fb: 720x480x4@0,0 with framebuffer size 1350KB
davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 675KB
watchdog: TI DaVinci Watchdog Timer: timer margin 64 sec
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Registering platform device 'serial8250'. Parent at platform
ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
ttyS1 at MMIO 0x1c20400 (irq = 41) is a 16550A
ttyS2 at MMIO 0x1e06000 (irq = 14) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
loop: loaded (max 8 devices)
dm9000 Ethernet Driver
dm9000: read wrong id 0x2b2a2928
dm9000: wrong id: 0x2b2a2928
dm9000: not found (-19).
i2c /dev entries driver
Linux video capture interface: v1.00
MUX: initialized VIN_CINL_EN
Registering platform device 'vpfe.1'. Parent at platform
Registering platform device 'DavinciDisplay.1'. Parent at platform
Trying to register davinci display video device.
layer=c25edc00,layer->video_dev=c25edd64
layer=c25eda00,layer->video_dev=c25edb64
davinci_init
aVinci V4L2 Display Driver V1.0 loaded
ipipe major#: 254, minor# 0
Registering platform device 'dm355_ipipe.2'. Parent at platform
ipipe driver registered
af major#: 253, minor# 0
Registering platform device 'dm355_af.2'. Parent at platform
aew major#: 252, minor# 0
Registering platform device 'dm355_aew.2'. Parent at platform
elevator: using anticipatory as default io scheduler
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bi)
2 NAND chips detected
Creating 5 MTD partitions on "nand_davinci.0":
0x00000000-0x003c0000 : "bootloader"
0x003c0000-0x00400000 : "params"
0x00400000-0x00800000 : "kernel"
0x00800000-0x20800000 : "filesystem1"
mtd: partition "filesystem1" extends beyond the end of device "nand_davinci.0" 0
0x20800000-0x20000000 : "filesystem2"
mtd: partition "filesystem2" is out of reach -- disabled
nand_davinci nand_davinci.0: hardware revision: 2.3
dm_spi.0: davinci SPI Controller driver at 0xc5862000 (irq = 42) use_dma=0
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
mice: PS/2 mouse device common for all mice
mmc mmc.0: Supporting 4-bit mode
mmc mmc.0: Using DMA mode
mmc mmc.1: Supporting 4-bit mode
mmc mmc.1: Using DMA mode
Registering platform device 'davinci-audio.0'. Parent at platform
i2c write: error = -121
tlv320aic33_write_value: aic33 write failed
aic33 write failed for reg = 0
aic33 write failed for reg = 42
aic33 write failed for reg = 51
aic33 write failed for reg = 65
aic33 write failed for reg = 86
aic33 write failed for reg = 93
aic33 write failed for reg = 37
aic33 write failed for reg = 15
aic33 write failed for reg = 16
aic33 write failed for reg = 47
aic33 write failed for reg = 64
aic33 write failed for reg = 82
aic33 write failed for reg = 92
aic33 write failed for reg = 19
aic33 write failed for reg = 22
aic33 write failed for reg = 17
aic33 write failed for reg = 18
aic33 write failed for reg = 26
aic33 write failed for reg = 27
aic33 write failed for reg = 28
aic33 write failed for reg = 29
aic33 write failed for reg = 30
aic33 write failed for reg = 31
aic33 write failed for reg = 43
aic33 write failed for reg = 44
aic33 write failed for reg = 25
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 8192 bind 16384)
Initializing XFRM netlink socket
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
IP-Config: No network devices available.
RAMDISK: ext2 filesystem found at block 0
RAMDISK: Loading 24576KiB [1 disk] into ram disk... done.
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 180K
Warning: Cannot create /dev/console: -20Warning: unable to open an initial cons.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
Can anyone tell me why this error is happenning??How will i solve this??
Shinu
