PROCESSOR-SDK-AM69A: PROCESSOR-SDK-AM69A
Something change with the SDK.
I builld "my" version of "tisdk-edigeai-image" with the version 09_00_01_03, 09_01_00_06, 10_00_00_08 (All kirkstone layers) without problems in the past. When I tried to upgrade to version 11_00_00_08, the build failed giving me the following message:
ERROR: ti-vision-apps-1.0-r0_edgeai_0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"; export SSH_AGENT_PID="152755"; export SSH_AUTH_SOCK="/tmp/ssh-XXXXXXNzCn3T/agent.152753"; export PATH="/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/sources/oe-core/scripts:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot-native/usr/bin/aarch64-oe-linux:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot/usr/bin/crossscripts:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot-native/usr/sbin:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot-native/usr/bin:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot-native/sbin:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/recipe-sysroot-native/bin:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/sources/bitbake/bin:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/hosttools"; export HOME="/home/jean"; /usr/bin/env repo sync failed with exit code 1, output:
fatal: unable to connect to git.ti.com:
git.ti.com[0: 198.47.28.207]: errno=Connection refused
processor-sdk/app_utils:
processor-sdk/app_utils: sleeping 4.0 seconds before retrying
processor-sdk/imaging:
processor-sdk/imaging: sleeping 4.0 seconds before retrying
processor-sdk/psdk_include:
processor-sdk/psdk_include: sleeping 4.0 seconds before retrying
processor-sdk-vision/arm-tidl:
processor-sdk-vision/arm-tidl: sleeping 4.0 seconds before retrying
processor-sdk/sdk_builder:
processor-sdk/sdk_builder: sleeping 4.0 seconds before retrying
processor-sdk/concerto:
processor-sdk/concerto: sleeping 4.0 seconds before retrying
git.ti.com[0: 198.47.28.208]: errno=Connection refused
processor-sdk/ti-perception-toolkit:
processor-sdk/ti-perception-toolkit: sleeping 4.0 seconds before retrying
processor-sdk/tiovx:
processor-sdk/tiovx: sleeping 4.0 seconds before retrying
processor-sdk/video_io:
processor-sdk/video_io: sleeping 4.0 seconds before retrying
processor-sdk/vision_apps:
processor-sdk/vision_apps: sleeping 4.0 seconds before retrying
warning: repo is not tracking a remote branch, so it will not receive updates; run `repo init --repo-rev=stable` to fix.
error: Cannot fetch processor-sdk/app_utils from git://git.ti.com/processor-sdk/app_utils
error: Cannot fetch processor-sdk/imaging from git://git.ti.com/processor-sdk/imaging
error: Cannot fetch processor-sdk/psdk_include from git://git.ti.com/processor-sdk/psdk_include
error: Cannot fetch processor-sdk-vision/arm-tidl from git://git.ti.com/processor-sdk-vision/arm-tidl
error: Cannot fetch processor-sdk/sdk_builder from git://git.ti.com/processor-sdk/sdk_builder
error: Cannot fetch processor-sdk/concerto from git://git.ti.com/processor-sdk/concerto
error: Cannot fetch processor-sdk/ti-perception-toolkit from git://git.ti.com/processor-sdk/ti-perception-toolkit
error: Cannot fetch processor-sdk/tiovx from git://git.ti.com/processor-sdk/tiovx
error: Cannot fetch processor-sdk/video_io from git://git.ti.com/processor-sdk/video_io
error: Cannot fetch processor-sdk/vision_apps from git://git.ti.com/processor-sdk/vision_apps
error: Cannot checkout processor-sdk/app_utils: ManifestInvalidRevisionError: revision refs/tags/REL.PSDK.ANALYTICS.09.00.01.01 in processor-sdk/app_utils not found
error: in `sync`: revision refs/tags/REL.PSDK.ANALYTICS.09.00.01.01 in processor-sdk/app_utils not found
ERROR: ti-vision-apps-1.0-r0_edgeai_0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/git/processor-sdk/psdk_repo_manifests;protocol=https;branch=refs/tags/REL.PSDK.ANALYTICS.09.00.01.01;manifest=vision_apps_yocto.xml')
ERROR: Logfile of failure stored in: /home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/temp/log.do_fetch.2320820
ERROR: Task (/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 11440 tasks of which 11438 didn't need to be rerun and 2 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 3 seconds
Summary: 2 tasks failed:
  /home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-edgeai-firmware.bb:do_install
Summary: There was 1 WARNING message.
Summary: There were 3 ERROR messages, returning a non-zero exit code.
jean@jean-cclab9-ti-dev:~/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build$
after walking the e2e.ti, found a request for the same problem, try the "receipt",
- 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0 - 0
e2e.ti.com/.../ti-vision-apps-build-failed-on-the-sdk-ti-processor-sdk-linux-j784-9-0-1-3
TRIED IT... NOW I GET WHAT FOLLOW AND ON TOP OF IT NONE OF THE PAST VERSION OF THE SDK CAN NOW BUILD THE SYSTEM...
NOTE: Deferred task mc:k3r5:virtual:native:/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/sources/oe-core/meta/recipes-devtools/python/python3-zipp_3.7.0.bb:do_populate_sysroot now buildable
WARNING: ti-vision-apps-1.0-r0_edgeai_0 do_fetch: Failed to fetch URL repo://git.ti.com/processor-sdk/psdk_repo_manifests.git;protocol=git;branch=refs/tags/REL.PSDK.ANALYTICS.09.00.01.01;manifest=vision_apps_yocto.xml, attempting MIRRORS if available
fatal: error parsing manifest /home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/downloads/repo/git.ti.com.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo/.repo/manifest.xml: [Errno 2] No such file or directory: '/home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/downloads/repo/git.ti.com.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo/.repo/manifest.xml'
ERROR: ti-vision-apps-1.0-r0_edgeai_0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'repo://git.ti.com/processor-sdk/psdk_repo_manifests.git;protocol=git;branch=refs/tags/REL.PSDK.ANALYTICS.09.00.01.01;manifest=vision_apps_yocto.xml')
ERROR: Logfile of failure stored in: /home/jean/ti-processor-sdk-linux-edgeai-j784s4-evm-09_00_01_03/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/1.0-r0_edgeai_0/temp/log.do_fetch.2322339
WHAT IS THE PROBLEM?
- I AM USING UBUNTU 22.04 LTS AS RECOMMENDED,
- I INSTALLED ALL THE RECOMMANDED SOFTWARE
- I ADD THE: EDGEAI_BRAND = "edgeai" OR ARAGO_BRAND = "edgeai" AS NEEDED BY THE SYSTEM
WHAT IT'S UP?
found the following:
with this "ti-vision-apps.bb" I get this:
it seems the config from the ti-vision-apps.bb is not "pointing" to the new web ti git server to download the files require by this package...
