Part Number: AM62A7
Other Parts Discussed in Thread: SK-AM62A-LP
Hello TI Dev,
I had a similar problem last time regarding compilation tflite model with TIDL. Due to the different version between TIDL and TI-processor-sdk, it caused an error. This time, I have a similar error when I inference on a project setup board for evaluation. I attached the log file below for error information. I tested on SK-AM62A-LP and it produced a result without an error. However, once I moved the artifacts and model from tested EVM board to project board, which has an identical setup, It showed an error as in log file below. Could you please elaborate on this issue?
Number of subgraphs:1 , 12 nodes delegated out of 12 nodes APP: Init ... !!! 15020.398211 s: MEM: Init ... !!! 15020.398270 s: MEM: Initialized DMA HEAP (fd=6) !!! 15020.398431 s: MEM: Init ... Done !!! 15020.398458 s: IPC: Init ... !!! 15020.413787 s: IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 15020.417439 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 15020.417595 s: VX_ZONE_INIT:Enabled 15020.417623 s: VX_ZONE_ERROR:Enabled 15020.417631 s: VX_ZONE_WARNING:Enabled 15020.418562 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-0 15020.418824 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-1 15020.419019 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-2 15020.419507 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:124] Added target MPU-3 15020.419609 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!! 15020.420235 s: VX_ZONE_INIT:[tivxHostInitLocal:106] Initialization Done for HOST !!! 15020.428205 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.428248 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.428263 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.428277 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.428291 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.428324 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.428334 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!! TIDL_RT_OVX: ERROR: Verify OpenVX graph failed 15020.435134 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.435177 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.435196 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.435214 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.435229 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.435246 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.435256 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.435363 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.435375 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.435385 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0030s 15020.438867 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.438910 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.438921 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.438933 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.438948 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.438964 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.438974 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.439077 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.439089 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.439099 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.442346 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.442388 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.442402 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.442413 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.442427 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.442444 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.442455 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.442560 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.442572 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.442583 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.446016 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.446057 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.446069 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.446080 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.446095 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.446111 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.446122 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.446226 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.446238 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.446248 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.449526 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.449568 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.449580 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.449591 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.449606 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.449622 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.449632 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.449736 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.449748 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.449758 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.453016 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.453057 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.453069 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.453080 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.453094 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.453110 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.453121 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.453226 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.453238 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.453247 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0018s 15020.456471 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.456511 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.456524 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.456534 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.456549 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.456565 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.456576 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.456683 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.456696 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.456705 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.459944 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.459987 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.459998 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.460009 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.460024 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.460042 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.460052 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.460158 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.460170 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.460180 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.463414 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.463453 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.463465 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.463476 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.463491 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.463507 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.463517 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.463621 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.463633 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.463643 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.466923 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.466967 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.466982 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.466993 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.467008 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.467024 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.467034 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.467139 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.467152 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.467161 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.470468 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.470509 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.470521 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.470533 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.470547 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.470564 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.470574 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.470680 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.470692 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.470702 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.473958 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.474000 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.474014 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.474025 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.474040 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.474057 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.474067 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.474172 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.474184 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.474194 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.477431 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.477471 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.477484 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.477495 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.477509 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.477525 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.477536 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.477640 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.477652 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.477662 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.480917 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.480958 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.480970 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.480982 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.480997 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.481014 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.481024 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.481129 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.481142 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.481152 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.484391 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.484430 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.484443 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.484454 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.484468 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.484486 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.484496 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.484603 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.484614 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.484624 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.487789 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.487830 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.487841 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.487851 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.487867 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.487883 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.487893 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.488034 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.488049 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.488059 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.491281 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.491322 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.491334 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.491345 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.491360 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.491375 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.491386 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.491489 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.491501 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.491510 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.494740 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.494781 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.494792 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.494803 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.494817 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.494833 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.494844 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.494950 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.494963 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.494972 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.498259 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.498300 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.498313 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.498324 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.498339 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.498354 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.498365 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.498469 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.498481 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.498491 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s 15020.501739 s: VX_ZONE_ERROR:[ownContextSendCmd:885] Command ack message returned failure cmd_status: -1 15020.501780 s: VX_ZONE_ERROR:[ownNodeKernelInit:592] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 15020.501791 s: VX_ZONE_ERROR:[ownNodeKernelInit:593] Please be sure the target callbacks have been registered for this core 15020.501802 s: VX_ZONE_ERROR:[ownNodeKernelInit:594] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 15020.501817 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:620] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 15020.501832 s: VX_ZONE_ERROR:[vxVerifyGraph:2254] Node kernel init failed 15020.501843 s: VX_ZONE_ERROR:[vxVerifyGraph:2311] Graph verify failed 15020.501947 s: VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:919] graph is not in a state required to be scheduled 15020.501959 s: VX_ZONE_ERROR:[vxProcessGraph:844] schedule graph failed 15020.501969 s: VX_ZONE_ERROR:[vxProcessGraph:849] wait graph failed ERROR: Running TIDL graph ... Failed !!! time invoked: 0.0017s Output: 0 True: 0 15020.545807 s: VX_ZONE_INIT:[tivxHostDeInitLocal:120] De-Initialization Done for HOST !!! 15020.550382 s: VX_ZONE_INIT:[tivxDeInitLocal:206] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! 15020.550846 s: IPC: Deinit ... !!! 15020.551321 s: IPC: DeInit ... Done !!! 15020.551368 s: MEM: Deinit ... !!! 15020.551383 s: DDR_SHARED_MEM: Alloc's: 8 alloc's of 4833756 bytes 15020.551392 s: DDR_SHARED_MEM: Free's : 8 free's of 4833756 bytes 15020.551400 s: DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes 15020.551414 s: MEM: Deinit ... Done !!! APP: Deinit ... Done !!!
Key
