Part Number: AM62L-PROCESSOR-SDK
Other Parts Discussed in Thread: AM62L
Hi Team,
While testing the new SDK release, I noticed that Weston GUI support appears to be removed from the build. In the previous SDK, running the command systemctl restart weston would successfully bring up the Weston interface on the display. However, in the new SDK, the same command fails with an error indicating that the Weston service is not available. I also tried manually adding the Weston service and socket files, but the service continues to fail. I would like to know how to properly restore Weston GUI support in the new SDK—specifically, which Yocto packages or recipes need to be added and where they should be included (such as in local.conf or the image recipe) to enable Weston and ensure the service is installed and starts correctly.
Dheeraj K
