what to do after changing the video file in EZSDK decode and display gstream demo?
I changed the video file in EZSDK decode and display gstream demo.
my video file is MP with resolution of 352x288
It can not work and said that can not decode.
So, Does the EZSDK/DM8148 support video other than HP/HD?
if it does, when i change the video file with a different Profile and different resolution, how to change the parameter for OPENMAX example and Gstream example respectively?
futher more, Does Gstream support video capture in DM8148?
    Yes EZSDK/DM8148 supports H264 decode other than HP/HD. You can try out the gstreamer pipelines available at http://processors.wiki.ti.com/index.php/DM81xx_Gstreamer_Pipelines. Gstreamer video decode element currently instantiates video decoder for 4.2 level. You should be able to decode streams upto Level 4.2 and up to high profile.
    Current version of gstreamer in EZSDK 5.03.01.15 doesn't have gstreamer video capture element, but will be available from in next EZSDK version. If you need it earlier than that you might want to check development branch at gstreamer.ti.com, it would be available there in next couple of weeks.
    Satish
    Please mark this Forum post as answered via the Verify Answer button below if it helps answer your question.  Thanks!
