Other Parts Discussed in Thread: 4430
Is the source of Release L27.G.4 includes Virtual display support?. Is it possible to enable virtual display support using the release L27.G.4 for Blaze?
Kamal
Kamal
Kamal,
L27.G.4 should work with Virtual Display. You need to set CONFIG_VIRTUAL_DISPLAY_SUPPORT to '1' or 'y' in the .config. Its off by default.
After you run 'make ARCH=arm android_4430_defconfig', edit the .config file and change that value to enable it. Alternatively you can run 'make ARCH=arm menuconfig' and find the entry for Virtual Display in the menus and enable it.
