Other Parts Discussed in Thread: TEST2, AM62L, AM62P
sdk version: ti-processor-sdk-linux-adas-j722s-evm-11_00_00_08
The j722s has 4 csi2rx interfaces: ti_csi2rx0、ti_csi2rx1、ti_csi2rx2、ti_csi2rx3
>>Test1:ti_csi2rx0
&csi0_port0 { status = "okay"; csi2rx0_in_sensor: endpoint { remote-endpoint = <&csi2_cam0>; bus-type = <4>; /* CSI2 DPHY */ clock-lanes = <0>; data-lanes = <1 2 3 4>; }; }; &ti_csi2rx0 { status = "okay"; /* MIPI-CSI Connector */ }; &dphy0 { status = "okay"; };
video node can be generated:
>>Test2:ti_csi2rx1
&csi1_port0 { status = "okay"; csi2rx0_in_sensor: endpoint { remote-endpoint = <&csi2_cam0>; bus-type = <4>; clock-lanes = <0>; data-lanes = <1 2 3 4>; }; }; &ti_csi2rx1 { status = "okay"; /* MIPI-CSI Connector */ }; &dphy1 { status = "okay"; };
But no video node was generated:
the error log:
[ 8.718925] genirq: Flags mismatch irq 24. 00000004 (30121000.csi-bridge) vs. 00006004 (20000000.i2c)
[ 8.718954] cdns-csi2rx 30121000.csi-bridge: Unable to request interrupt: -16
[ 8.718967] cdns-csi2rx 30121000.csi-bridge: probe with driver cdns-csi2rx failed with error -16
U-Boot SPL 2025.01-ti (Jul 01 2025 - 15:30:38 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') SPL initial stack usage: 17048 bytes Trying to boot from MMC1 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.12.0(release):11.00.09-dirty NOTICE: BL31: Built : 12:35:58, Mar 24 2025 U-Boot SPL 2025.01-ti (Jul 01 2025 - 15:30:34 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') Trying to boot from MMC1 Authentication passed Authentication passed U-Boot 2025.01-ti (Jul 01 2025 - 15:30:34 +0800) SoC: J722S SR1.0 HS-FS Model: Texas Instruments J722S EVM DRAM: 2 GiB (total 8 GiB) Core: 103 devices, 29 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device ________________________________SD/MMC found on device 1 1128 bytes read in 2 ms (550.8 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... Failed to load '/lib/firmware/j722s-mcu-r5f0_0-fw' 625536 bytes read in 34 ms (17.5 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 2 with data@addr=0x82000000 625536 bytes: Success! 11804840 bytes read in 152 ms (74.1 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 3 with data@addr=0x82000000 11804840 bytes: Success! 11804840 bytes read in 152 ms (74.1 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 4 with data@addr=0x82000000 11804840 bytes: Success! 22256128 bytes read in 237 ms (89.6 MiB/s) 79497 bytes read in 4 ms (19 MiB/s) Working FDT set to 88000000 2919 bytes read in 4 ms (711.9 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK Working FDT set to 8fee9000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.12.17-ti (cesar@xiamenvt-RH2288-V3) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #3 SMP PREEMPT Tue Jul 1 15:31:40 CST 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments J722S EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: legacy bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000009c8000000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000009c8000000..0x00000009ffffffff (917504 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@a1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@a1000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@a1100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@a1100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node main-r5fss-dma-memory-region@a2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable main-r5fss-dma-memory-region@a2000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node main-r5fss-memory-region@a2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable main-r5fss-memory-region@a2100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable c7x-dma-memory@a3000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@a3100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable c7x-memory@a3100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable c7x-dma-memory@a4000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@a4100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable c7x-memory@a4100000 [ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a6bfffff (28672 KiB) nomap non-reusable ipc-memories@a5000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a6bfffff] [ 0.000000] node 0: [mem 0x00000000a6c00000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=d73bf4db-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2097152 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880050000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008677] Console: colour dummy device 80x25 [ 0.013269] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023935] pid_max: default: 32768 minimum: 301 [ 0.028730] LSM: initializing lsm=capability,selinux [ 0.033851] SELinux: Initializing. [ 0.037864] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.045624] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.069898] rcu: Hierarchical SRCU implementation. [ 0.074819] rcu: Max phase no-delay instances is 1000. [ 0.080328] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.089105] EFI services will not be available. [ 0.097780] smp: Bringing up secondary CPUs ... [ 0.110747] Detected VIPT I-cache on CPU1 [ 0.110822] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.110838] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000 [ 0.110883] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.118744] Detected VIPT I-cache on CPU2 [ 0.118806] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.118819] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000 [ 0.118849] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.122733] Detected VIPT I-cache on CPU3 [ 0.122788] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.122802] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000 [ 0.122832] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.122941] smp: Brought up 1 node, 4 CPUs [ 0.202586] SMP: Total of 4 processors activated. [ 0.207395] CPU: All CPU(s) started at EL2 [ 0.211591] CPU features: detected: 32-bit EL0 Support [ 0.216843] CPU features: detected: CRC32 instructions [ 0.222137] alternatives: applying system-wide alternatives [ 0.228412] Memory: 7077292K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 384760K reserved, 917504K cma-reserved) [ 0.243967] devtmpfs: initialized [ 0.258315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.268321] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.297232] 27152 pages in range for non-PLT usage [ 0.297256] 518672 pages in range for PLT usage [ 0.302470] pinctrl core: initialized pinctrl subsystem [ 0.312867] DMI not present or invalid. [ 0.318757] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.325955] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.333383] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.341491] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.350114] audit: initializing netlink subsys (disabled) [ 0.355922] audit: type=2000 audit(0.244:1): state=initialized audit_enabled=0 res=1 [ 0.356326] thermal_sys: Registered thermal governor 'step_wise' [ 0.363847] thermal_sys: Registered thermal governor 'power_allocator' [ 0.370034] cpuidle: using governor menu [ 0.380861] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.387880] ASID allocator initialised with 65536 entries [ 0.400174] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000 [ 0.411671] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000 [ 0.423342] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.433351] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.443280] /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 0.460460] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000 [ 0.472249] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.484617] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.494574] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.505013] /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 0.518801] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 0.528043] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.537966] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.544931] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.551336] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.558270] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.564672] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.571606] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.578014] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.584950] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.593004] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected [ 0.602549] iommu: Default domain type: Translated [ 0.607476] iommu: DMA domain TLB invalidation policy: strict mode [ 0.614152] SCSI subsystem initialized [ 0.618340] usbcore: registered new interface driver usbfs [ 0.623970] usbcore: registered new interface driver hub [ 0.629426] usbcore: registered new device driver usb [ 0.635128] pps_core: LinuxPPS API ver. 1 registered [ 0.640207] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.649546] PTP clock support registered [ 0.653587] EDAC MC: Ver: 3.0.0 [ 0.657089] scmi_core: SCMI protocol bus registered [ 0.662350] FPGA manager framework [ 0.665898] Advanced Linux Sound Architecture Driver Initialized. [ 0.673015] vgaarb: loaded [ 0.676123] clocksource: Switched to clocksource arch_sys_counter [ 0.682645] VFS: Disk quotas dquot_6.6.0 [ 0.686671] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.700086] NET: Registered PF_INET protocol family [ 0.705371] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.717822] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.726668] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.734612] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.743068] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.752361] TCP: Hash tables configured (established 65536 bind 65536) [ 0.759223] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.766305] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.773966] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.780258] RPC: Registered named UNIX socket transport module. [ 0.786316] RPC: Registered udp transport module. [ 0.791121] RPC: Registered tcp transport module. [ 0.795928] RPC: Registered tcp-with-tls transport module. [ 0.801536] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.808119] NET: Registered PF_XDP protocol family [ 0.813034] PCI: CLS 0 bytes, default 64 [ 0.818254] Initialise system trusted keyrings [ 0.823036] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.829908] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.836139] NFS: Registering the id_resolver key type [ 0.841352] Key type id_resolver registered [ 0.845627] Key type id_legacy registered [ 0.849739] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.856586] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.911521] Key type asymmetric registered [ 0.915722] Asymmetric key parser 'x509' registered [ 0.920759] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.928510] io scheduler mq-deadline registered [ 0.933147] io scheduler kyber registered [ 0.937270] io scheduler bfq registered [ 0.944402] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.951163] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.958553] ledtrig-cpu: registered to indicate activity on CPUs [ 0.970383] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.984995] loop: module loaded [ 0.989283] megasas: 07.727.03.00-rc1 [ 0.996680] tun: Universal TUN/TAP device driver, 1.6 [ 1.002870] VFIO - User Level meta-driver version: 0.3 [ 1.009286] usbcore: registered new interface driver usb-storage [ 1.015987] i2c_dev: i2c /dev entries driver [ 1.021407] sdhci: Secure Digital Host Controller Interface driver [ 1.027739] sdhci: Copyright(c) Pierre Ossman [ 1.032416] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.038843] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.046029] usbcore: registered new interface driver usbhid [ 1.051732] usbhid: USB HID core driver [ 1.056823] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available [ 1.067083] optee: probing for conduit method. [ 1.071666] optee: revision 4.5 (ef1ebdc23034a804) [ 1.072022] optee: dynamic shared memory is enabled [ 1.082540] optee: initialized driver [ 1.082637] random: crng init done [ 1.088352] Initializing XFRM netlink socket [ 1.094157] NET: Registered PF_PACKET protocol family [ 1.099395] Key type dns_resolver registered [ 1.111437] registered taskstats version 1 [ 1.115878] Loading compiled-in X.509 certificates [ 1.131505] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') [ 1.193786] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz [ 1.200861] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz [ 1.207733] /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 1.219457] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30122000/csi-bridge@30121000 [ 1.231549] pca953x 2-0023: supply vcc not found, using dummy regulator [ 1.238448] pca953x 2-0023: using AI [ 1.258245] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.265303] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.274544] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.284466] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 1.293669] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 1.303731] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz [ 1.310768] pca954x 4-0070: supply vdd not found, using dummy regulator [ 1.332400] i2c i2c-4: Added multiplexed i2c bus 5 [ 1.337488] i2c i2c-4: Added multiplexed i2c bus 6 [ 1.342399] pca954x 4-0070: registered 2 multiplexed busses for I2C switch pca9543 [ 1.350336] pca954x 4-0071: supply vdd not found, using dummy regulator [ 1.357471] i2c i2c-4: Added multiplexed i2c bus 7 [ 1.362528] i2c i2c-4: Added multiplexed i2c bus 8 [ 1.367433] pca954x 4-0071: registered 2 multiplexed busses for I2C switch pca9543 [ 1.375220] omap_i2c 20020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.381129] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.389451] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.398653] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.407629] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.422008] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.430295] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16) [ 1.440986] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.451478] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.460925] ti-udma 4e230000.dma-controller: Number of rings: 40 [ 1.469556] ti-udma 4e230000.dma-controller: Channels: 40 (bchan: 0, tchan: 8, rchan: 32) [ 1.480596] printk: legacy console [ttyS2] disabled [ 1.485968] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 311, base_baud = 3000000) is a 8250 [ 1.494846] printk: legacy console [ttyS2] enabled [ 1.494846] printk: legacy console [ttyS2] enabled [ 1.504588] printk: legacy bootconsole [ns16550a0] disabled [ 1.504588] printk: legacy bootconsole [ns16550a0] disabled [ 1.531433] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.538421] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.543825] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.550507] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.556872] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.563271] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.569471] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.576319] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.582776] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.760134] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000 [ 1.771266] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.779396] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006 [ 1.792464] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.799606] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32 [ 1.807340] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0 [ 1.825212] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.839287] mmc0: CQHCI version 5.10 [ 1.880718] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.909922] pca953x 3-0020: supply vcc not found, using dummy regulator [ 1.916695] pca953x 3-0020: using no AI [ 1.944744] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges: [ 1.952205] j721e-pcie f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000 [ 1.960306] j721e-pcie f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000 [ 1.968403] j721e-pcie f102000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.977098] mmc0: Command Queue Engine enabled [ 1.981575] mmc0: new HS200 MMC card at address 0001 [ 1.987506] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.994391] mmcblk0: p1 p2 p3 p4 < p5 p6 > [ 1.999491] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 2.005295] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 2.011181] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0) [ 3.084936] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00 [ 3.091300] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.096788] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff]) [ 3.106256] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff] [ 3.113150] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400 PCIe Root Port [ 3.120474] pci 0000:00:00.0: PCI bridge to [bus 00] [ 3.125435] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff] [ 3.131522] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff] [ 3.138306] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref] [ 3.146098] pci 0000:00:00.0: supports D1 [ 3.150104] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 3.158173] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.166432] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.173067] pci 0000:00:00.0: PCI bridge to [bus 01] [ 3.178036] pci_bus 0000:00: resource 4 [io 0x0000-0xffff] [ 3.183603] pci_bus 0000:00: resource 5 [mem 0x68011000-0x6fffffff] [ 3.190033] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 3.196970] pcieport 0000:00:00.0: PME: Signaling with IRQ 567 [ 3.203093] pcieport 0000:00:00.0: AER: enabled with IRQ 567 [ 3.210526] mmc1: CQHCI version 5.10 [ 3.210563] clk: Disabling unused clocks [ 3.224370] PM: genpd: Disabling unused power domains [ 3.229527] ALSA device list: [ 3.232569] No soundcards found. [ 3.256704] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.264400] Waiting for root device PARTUUID=d73bf4db-02... [ 3.328723] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 3.335950] mmcblk1: mmc1:aaaa SD32G 29.7 GiB [ 3.342039] mmcblk1: p1 p2 [ 3.469902] EXT4-fs (mmcblk1p2): recovery complete [ 3.475616] EXT4-fs (mmcblk1p2): mounted filesystem b9bbcee6-884f-423b-894a-2960cb8eaf33 r/w with ordered data mode. Quota mode: none. [ 3.487784] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.498908] devtmpfs: mounted [ 3.502596] Freeing unused kernel memory: 2752K [ 3.507209] Run /sbin/init as init process [ 3.725423] systemd[1]: System time before build time, advancing clock. [ 3.767949] NET: Registered PF_INET6 protocol family [ 3.773889] Segment Routing with IPv6 [ 3.777612] In-situ OAM (IOAM) with IPv6 [ 3.815041] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 3.846959] systemd[1]: Detected architecture arm64. Welcome to Arago 2025.01! [ 3.866609] systemd[1]: Hostname set to <j722s-evm>. [ 3.989626] systemd-sysv-generator[113]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file, automatically generating a unit file for compatibility. [ 4.005460] systemd-sysv-generator[113]: Please update package to include a native systemd unit file. [ 4.014807] systemd-sysv-generator[113]: ! This compatibility logic is deprecated, expect removal soon. ! [ 4.203620] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.374441] systemd[1]: Queued start job for default target Graphical Interface. [ 4.417866] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 4.438544] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 4.458515] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 4.477988] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.496582] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 4.516483] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 4.536326] systemd[1]: Expecting device /dev/ttyS2... Expecting device /dev/ttyS2... [ 4.552366] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 4.564269] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.580265] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.592267] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.657248] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.676433] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.699138] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.716659] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.737440] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.756981] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.777007] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.789131] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.810073] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.828862] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.844883] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.888593] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.898622] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.924711] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.936899] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.955329] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 4.977980] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 5.001070] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 5.024954] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 5.041258] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 5.070914] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen.[ 5.079827] fuse: init (API version 7.41) .. [ 5.116910] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 5.128652] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 5.149560] systemd[1]: Starting Journal Service... Starting Journal Service... [ 5.167454] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.185679] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network units from Kernel command line... [ 5.208730] cryptodev: loading out-of-tree module taints kernel. [ 5.209915] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems sysctl table check failed: ioctl/(null) procname is null [0m... [ 5.234086] sysctl table check failed: ioctl/(null) No proc_handler [ 5.241061] cryptodev: driver 1.14 loaded. [ 5.248076] systemd-journald[131]: Collecting audit messages is enabled. [ 5.250741] systemd[1]: Starting Coldplug All udev Devices... Starting Coldplug All udev Devices... [ 5.285533] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 5.296842] EXT4-fs (mmcblk1p2): re-mounted b9bbcee6-884f-423b-894a-2960cb8eaf33 r/w. Quota mode: none. [ 5.309214] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted Huge Pages File System. [ 5.333033] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Start psplas…temd progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev gr[ 5.664977] systemd-journald[131]: Received client request to flush runtime journal. acefully... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev gracefully. Starting Create Static Device Nodes in /dev... [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /var/volatile... [ 5.914938] audit: type=1334 audit(1741187611.184:2): prog-id=6 op=LOAD [ 5.921741] audit: type=1334 audit(1741187611.192:3): prog-id=7 op=LOAD Starting Rule-based Manager for Device Events and Files... [ OK ] Mounted /var/volatile. Starting Load/Save OS Random Seed... [ OK ] Reached target Local File Systems. Starting Create System Files and Directories... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Load/Save OS Random Seed. [ OK ] Finished Create System Files and Directories. [ 6.122910] audit: type=1334 audit(1741187611.392:4): prog-id=8 op=LOAD Starting Network Name Resolution... [ 6.164385] audit: type=1334 audit(1741187611.436:5): prog-id=9 op=LOAD Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ 6.211008] audit: type=1334 audit(1741187611.480:6): prog-id=10 op=LOAD [ 6.217907] audit: type=1334 audit(1741187611.488:7): prog-id=11 op=LOAD [ 6.224695] audit: type=1334 audit(1741187611.496:8): prog-id=12 op=LOAD Starting User Database Manager... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started User Database Manager. [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Found device /dev/ttyS2. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. [ 6.886896] audit: type=1334 audit(1751621470.746:9): prog-id=13 op=LOAD Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Socket Units. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. [ OK ] Started Multiple Spanning Tree Protocol Daemon. Starting Telephony service... Starting PulseAudio Sound System... Starting Expand the rootfs partiti…to full size of the boot device.... [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 7.481151] audit: type=1334 audit(1751621471.342:10): prog-id=14 op=LOAD [ 7.490898] audit: type=1334 audit(1751621471.350:11): prog-id=15 op=LOAD Starting User Login Management... Starting Telnet Server... [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished Telnet Server. [ OK ] Reached target Preparation for Network. Starting Network Configuration... [ OK ] Started Telephony service. [ OK ] Started Avahi mDNS/DNS-SD Stack. [ 7.850342] CAN device driver interface [ 8.013700] mc: Linux media interface: v0.10 [ 8.022802] Bluetooth: Core ver 2.22 [ 8.028704] NET: Registered PF_BLUETOOTH protocol family [ 8.035416] Bluetooth: HCI device and connection manager initialized [ 8.042558] Bluetooth: HCI socket layer initialized [ 8.047581] Bluetooth: L2CAP socket layer initialized [ 8.052739] Bluetooth: SCO socket layer initialized [ 8.067042] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 8.079717] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 8.090403] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100 [ 8.103662] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100 [ 8.134227] videodev: Linux video capture interface: v2.00 [ OK ] Started PulseAudio Sound System. [ OK ] Finished Expand the rootfs partition to full size of the boot device.. [ 8.303209] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@a3000000 [ 8.312152] platform 79000000.r5f: configured R5F for remoteproc mode [ 8.313749] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode [ 8.321035] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@a1000000 [ 8.326352] remoteproc remoteproc0: 7e000000.dsp is available [ 8.344974] remoteproc remoteproc0: attaching to 7e000000.dsp [ 8.345629] remoteproc remoteproc1: 79000000.r5f is available [ 8.351103] remoteproc remoteproc0: carveout rsc has non zero reserved bytes [ 8.364078] remoteproc remoteproc0: Failed to process resources: -22 [ 8.385328] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 8.396213] remoteproc remoteproc1: powering up 79000000.r5f [ 8.404436] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 8.417145] k3-dsp-rproc 7e000000.dsp: error -EINVAL: failed to add register device with remoteproc core [ 8.426822] remoteproc remoteproc1: request_firmware failed: -2 [ 8.443081] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 8.452169] k3-dsp-rproc 7e000000.dsp: probe with driver k3-dsp-rproc failed with error -22 [ 8.464815] remoteproc remoteproc0: releasing 7e000000.dsp [ 8.471478] platform 78000000.r5f: configured R5F for IPC-only mode [ 8.478094] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 8.487312] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node c7x-dma-memory@a4000000 [ 8.491272] remoteproc remoteproc2: 78000000.r5f is available [ 8.501935] remoteproc remoteproc2: attaching to 78000000.r5f [ 8.508049] k3-dsp-rproc 7e200000.dsp: configured DSP for IPC-only mode [ 8.509336] rproc-virtio rproc-virtio.4.auto: assigned reserved memory node r5f-dma-memory@a0000000 [ 8.527565] remoteproc remoteproc0: 7e200000.dsp is available [ 8.534077] remoteproc remoteproc0: attaching to 7e200000.dsp [ 8.536185] virtio_rpmsg_bus virtio0: rpmsg host is online [ 8.540001] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 8.553186] remoteproc remoteproc0: unsupported vendor resource 512 [ 8.555287] rproc-virtio rproc-virtio.4.auto: registered virtio0 (type 7) [ 8.555628] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE' [ 8.555637] vdec 30210000.video-codec: Product Code: 0x521c [ 8.555642] vdec 30210000.video-codec: Firmware Revision: 344874 [ 8.559856] remoteproc remoteproc0: unsupported vendor resource 512 [ 8.567514] remoteproc remoteproc2: remote processor 78000000.r5f is now attached [ 8.574439] remoteproc remoteproc0: rsc table is truncated [ 8.605975] remoteproc remoteproc0: Failed to process resources: -22 [ 8.609035] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ 8.614655] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.619584] platform 78400000.r5f: configured R5F for IPC-only mode [ 8.619810] platform 78400000.r5f: assigned reserved memory node main-r5fss-dma-memory-region@a2000000 [ 8.641037] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.641798] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 8.691341] k3-dsp-rproc 7e200000.dsp: error -EINVAL: failed to add register device with remoteproc core [ 8.691365] k3-dsp-rproc 7e200000.dsp: probe with driver k3-dsp-rproc failed with error -22 [ 8.718925] genirq: Flags mismatch irq 24. 00000004 (30121000.csi-bridge) vs. 00006004 (20000000.i2c) [ 8.718954] cdns-csi2rx 30121000.csi-bridge: Unable to request interrupt: -16 [ 8.718967] cdns-csi2rx 30121000.csi-bridge: probe with driver cdns-csi2rx failed with error -16 [ 8.724534] remoteproc remoteproc0: releasing 7e200000.dsp [ 8.738050] remoteproc remoteproc3: 78400000.r5f is available [ 8.738144] remoteproc remoteproc3: attaching to 78400000.r5f [ 8.738648] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node main-r5fss-dma-memory-region@a2000000 [ 8.831144] virtio_rpmsg_bus virtio1: rpmsg host is online [ 8.836434] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 8.847790] rproc-virtio rproc-virtio.5.auto: registered virtio1 (type 7) [ OK ] Started Network Configuration. [ 8.896631] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 8.896656] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 8.896918] remoteproc remoteproc3: remote processor 78400000.r5f is now attached [ 8.914121] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ OK ] Reached target Network. Starting Enable and configure wl18xx bluetooth stack... [ 9.068024] m_can_platform 4e08000.can: m_can device registered (irq=585, version=32) Starting containerd container runtime... [ 9.088526] m_can_platform 4e18000.can: m_can device registered (irq=586, version=32) Starting LLDP daemon... [ OK ] Started Netperf Benchmark Server. [ 9.184604] PVR_K: 210: Device: fd80000.gpu [ 9.217425] m_can_platform 20701000.can: m_can device registered (irq=587, version=32) [ 9.226055] PVR_K: 210: Read BVNC 36.53.104.796 from HW device registers [ 9.244868] sii902x 3-003b: supply iovcc not found, using dummy regulator [ 9.256508] sii902x 3-003b: supply cvcc12 not found, using dummy regulator [ 9.261339] PVR_K: 210: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 9.272767] i2c i2c-3: Added multiplexed i2c bus 9 Starting Simple Network Management Protocol (SNMP) Daemon.... [ 9.331703] [drm] Initialized tidss 1.0.0 for 30220000.dss on minor 1 [ 9.340855] tidss 30220000.dss: [drm] Cannot find any crtc or sizes [ 9.349035] tidss 30220000.dss: [drm] Cannot find any crtc or sizes Starting Permit User Sessions... [ OK ] Started User Login Management. [ OK ] Started LLDP daemon. [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ 9.412695] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 0 [ OK ] Reached target Hardware activated USB gadget. [ OK ] Finished Permit User Sessions. [ OK ] Started emptty display manager. Starting EdgeAI OOB demos... [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Reached target Login Prompts. [ OK ] Created slice Slice /system/tee-supplicant. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Started TEE Supplicant on teepriv0. Stopping emptty display manager... Starting Virtual Console Setup... [ 9.825956] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 9.832848] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 1 [ OK ] Stopped emptty display manager.[ 9.844421] xhci-hcd xhci-hcd.8.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010 [ 9.862959] xhci-hcd xhci-hcd.8.auto: irq 590, io mem 0x31210000 [ 9.869323] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 9.875056] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 2 [ 9.882822] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed [ 9.894375] hub 1-0:1.0: USB hub found [ 9.943278] hub 1-0:1.0: 1 port detected [ 9.961331] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 9.982837] hub 2-0:1.0: USB hub found [ 9.987747] hub 2-0:1.0: 1 port detected [ 10.034092] m_can_platform 20701000.can main_mcan0: renamed from can2 [ 10.068021] m_can_platform 4e18000.can mcu_mcan1: renamed from can1 [ 10.136989] m_can_platform 4e08000.can mcu_mcan0: renamed from can0 [ OK ] Finished Virtual Console Setup. [ 10.208357] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 10.350358] hub 1-1:1.0: USB hub found [ 10.355312] hub 1-1:1.0: 4 ports detected [ 10.468287] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 10.489976] hub 2-1:1.0: USB hub found [ 10.496404] hub 2-1:1.0: 4 ports detected [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Created slice Slice /system/systemd-fsck. Expecting device /dev/mmcblk0p1... Expecting device /dev/mmcblk0p2... Expecting device /dev/mmcblk0p3... Expecting device /dev/mmcblk0p5... Starting Save/Restore Sound Card State... [ OK ] Finished Save/Restore Sound Card State. [ OK ] Reached target Sound Card. [ OK ] Found device /dev/mmcblk0p2. Starting File System Check on /dev/mmcblk0p2... [ OK ] Found device /dev/mmcblk0p1. [ 10.937544] usbcore: registered new device driver onboard-usb-dev Starting File System Check on /dev/mmcblk0p1... [ OK ] Found device /dev/mmcblk0p3. [ OK ] Found device /dev/mmcblk0p5. [ OK ] Started EdgeAI OOB demos. [ OK ] Finished File System Check on /dev/mmcblk0p2. [ OK ] Finished File System Check on /dev/mmcblk0p1. Expecting device /dev/mmcblk1p1... Mounting /run/media/mmcblk0p1... Mounting /run/media/rootfs-mmcblk0p2... Starting File System Check on /dev/mmcblk0p3... Starting File System Check on /dev/mmcblk0p5... [ 11.224794] EXT4-fs (mmcblk0p2): mounted filesystem 6df47fd6-3f21-4e28-b9fc-82759baff4c3 r/w with ordered data mode. Quota mode: none. [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Mounted /run/media/rootfs-mmcblk0p2. [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ OK ] Finished File System Check on /dev/mmcblk0p3. Mounting /run/media/backup-mmcblk0p3... [ OK ] Finished File System Check on /dev/mmcblk0p5. Mounting /run/media/user-mmcblk0p5... [ 11.483816] EXT4-fs (mmcblk0p3): mounted filesystem 177ee670-bb9c-42d0-96be-b7d6b7c859e6 r/w with ordered data mode. Quota mode: none. [ 11.505276] EXT4-fs (mmcblk0p5): mounted filesystem 11eb0200-dc98-41aa-9974-f9da9797dfcd r/w with ordered data mode. Quota mode: none. [ OK ] Mounted /run/media/backup-mmcblk0p3. [ OK ] Mounted /run/media/user-mmcblk0p5. [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/BOOT-mmcblk1p1... [ OK ] Mounted /run/media/BOOT-mmcblk1p1. [ OK ] Started containerd container runtime. [ 12.979501] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 13.294782] kauditd_printk_skb: 2 callbacks suppressed [ 13.294799] audit: type=1701 audit(1751621477.154:14): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=990 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1 [ OK ] Created slice Slice /system/systemd[ 13.350279] audit: type=1334 audit(1751621477.210:15): prog-id=18 op=LOAD -coredump. [ 13.360939] audit: type=1334 audit(1751621477.222:16): prog-id=19 op=LOAD [ 13.368854] audit: type=1334 audit(1751621477.222:17): prog-id=20 op=LOAD [ OK ] Started Process Core Dump (PID 1158/UID 0). *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils-dev elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip hidapi kbd-dev kbd-keymaps-pine less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libgnutls-dev libgnutls-openssl27 libgomp1 libidn2-0 libidn2-dev libmpc3 libmpfr6 libopcodes libqt6core5compat-plugins libqt6core5compat-qmlplugins libqt6core5compat6 libqt6shadertools-dev libqt6shadertools-plugins libqt6shadertools-qmlplugins libqt6shadertools6 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libtasn1-dev libunistring-dev libunistring5 m4 make nettle-dev nettle parted piglit qtbase-dev qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase-staticdev qtbase qtdeclarative-dev qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-staticdev qtdeclarative-tools qtdeclarative qtlanguageserver-dev qtlanguageserver-plugins qtlanguageserver-qmlplugins qtlanguageserver-staticdev qtlanguageserver qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquicktimeline-plugins qtquicktimeline-qmlplugins qtquicktimeline qtsvg-dev qtsvg-plugins qtsvg-qmlplugins qtsvg qtwayland-dev qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ 14.664453] audit: type=1334 audit(1751621478.526:18): prog-id=20 op=UNLOAD [ 14.671792] audit: type=1334 audit(1751621478.526:19): prog-id=19 op=UNLOAD [ 14.680070] audit: type=1334 audit(1751621478.526:20): prog-id=18 op=UNLOAD _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j722s-evm ttyS2 Arago 2025.01 j722s-evm ttyS2 j722s-evm login:
>>Test3:ti_csi2rx2
&csi2_port0 { status = "okay"; csi2rx0_in_sensor: endpoint { remote-endpoint = <&csi2_cam0>; bus-type = <4>; clock-lanes = <0>; data-lanes = <1 2 3 4>; }; }; &ti_csi2rx2 { status = "okay"; /* MIPI-CSI Connector */ }; &dphy2 { status = "okay"; };
the log:
U-Boot SPL 2025.01-ti (Jul 01 2025 - 15:30:38 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') SPL initial stack usage: 17048 bytes Trying to boot from MMC1 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.12.0(release):11.00.09-dirty NOTICE: BL31: Built : 12:35:58, Mar 24 2025 U-Boot SPL 2025.01-ti (Jul 01 2025 - 15:30:34 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') Trying to boot from MMC1 Authentication passed Authentication passed U-Boot 2025.01-ti (Jul 01 2025 - 15:30:34 +0800) SoC: J722S SR1.0 HS-FS Model: Texas Instruments J722S EVM DRAM: 2 GiB (total 8 GiB) Core: 103 devices, 29 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 Net: eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device 1128 bytes read in 3 ms (367.2 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... Failed to load '/lib/firmware/j722s-mcu-r5f0_0-fw' 625536 bytes read in 34 ms (17.5 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 2 with data@addr=0x82000000 625536 bytes: Success! 11804840 bytes read in 151 ms (74.6 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 3 with data@addr=0x82000000 11804840 bytes: Success! 11804840 bytes read in 153 ms (73.6 MiB/s) Warning: Did not detect image signing certificate. Skipping authentication to prevent boot failure. This will fail on Security Enforcing(HS-SE) devices Load Remote Processor 4 with data@addr=0x82000000 11804840 bytes: Success! 22256128 bytes read in 237 ms (89.6 MiB/s) 79497 bytes read in 6 ms (12.6 MiB/s) Working FDT set to 88000000 2919 bytes read in 4 ms (711.9 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008fee9000, end 000000008fffffff ... OK Working FDT set to 8fee9000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.12.17-ti (cesar@xiamenvt-RH2288-V3) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #3 SMP PREEMPT Tue Jul 1 15:31:40 CST 2025 [ 0.000000] KASLR disabled due to lack of seed [ 0.000000] Machine model: Texas Instruments J722S EVM [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: legacy bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000009c8000000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000009c8000000..0x00000009ffffffff (917504 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-dma-memory-region@a1000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable mcu-r5fss-dma-memory-region@a1000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node mcu-r5fss-memory-region@a1100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable mcu-r5fss-memory-region@a1100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node main-r5fss-dma-memory-region@a2000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable main-r5fss-dma-memory-region@a2000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node main-r5fss-memory-region@a2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable main-r5fss-memory-region@a2100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable c7x-dma-memory@a3000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@a3100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable c7x-memory@a3100000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c7x-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable c7x-dma-memory@a4000000 [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c7x-memory@a4100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable c7x-memory@a4100000 [ 0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a6bfffff (28672 KiB) nomap non-reusable ipc-memories@a5000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000009ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000a6bfffff] [ 0.000000] node 0: [mem 0x00000000a6c00000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000009ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000009ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=PARTUUID=d73bf4db-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear) [ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2097152 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000880050000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008684] Console: colour dummy device 80x25 [ 0.013281] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023962] pid_max: default: 32768 minimum: 301 [ 0.028763] LSM: initializing lsm=capability,selinux [ 0.033888] SELinux: Initializing. [ 0.037906] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.045669] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 0.073961] rcu: Hierarchical SRCU implementation. [ 0.078882] rcu: Max phase no-delay instances is 1000. [ 0.084395] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.093181] EFI services will not be available. [ 0.101853] smp: Bringing up secondary CPUs ... [ 0.110826] Detected VIPT I-cache on CPU1 [ 0.110901] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.110917] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000 [ 0.110963] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.118803] Detected VIPT I-cache on CPU2 [ 0.118862] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.118876] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000 [ 0.118908] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.126815] Detected VIPT I-cache on CPU3 [ 0.126875] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.126890] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000 [ 0.126920] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.127040] smp: Brought up 1 node, 4 CPUs [ 0.206682] SMP: Total of 4 processors activated. [ 0.211491] CPU: All CPU(s) started at EL2 [ 0.215687] CPU features: detected: 32-bit EL0 Support [ 0.220939] CPU features: detected: CRC32 instructions [ 0.226232] alternatives: applying system-wide alternatives [ 0.232490] Memory: 7077292K/8388608K available (12928K kernel code, 1254K rwdata, 4644K rodata, 2752K init, 639K bss, 384760K reserved, 917504K cma-reserved) [ 0.248069] devtmpfs: initialized [ 0.262442] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.272442] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.302572] 27152 pages in range for non-PLT usage [ 0.302596] 518672 pages in range for PLT usage [ 0.307812] pinctrl core: initialized pinctrl subsystem [ 0.318200] DMI not present or invalid. [ 0.324092] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.331294] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations [ 0.338728] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.346833] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.355429] audit: initializing netlink subsys (disabled) [ 0.361219] audit: type=2000 audit(0.248:1): state=initialized audit_enabled=0 res=1 [ 0.361620] thermal_sys: Registered thermal governor 'step_wise' [ 0.369140] thermal_sys: Registered thermal governor 'power_allocator' [ 0.375329] cpuidle: using governor menu [ 0.386151] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.393175] ASID allocator initialised with 65536 entries [ 0.405610] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000 [ 0.417109] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000 [ 0.428787] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.438808] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.448745] /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 0.465940] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000 [ 0.477741] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.490097] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 0.500049] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.510578] /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 0.524361] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 0.533605] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 0.543542] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.550508] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.556913] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.563850] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.570254] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.577190] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.583600] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.590533] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 0.598580] k3-chipinfo 43000014.chipid: Family:J722S rev:SR1.0 JTAGID[0x0bba002f] Detected [ 0.608158] iommu: Default domain type: Translated [ 0.613082] iommu: DMA domain TLB invalidation policy: strict mode [ 0.619760] SCSI subsystem initialized [ 0.623954] usbcore: registered new interface driver usbfs [ 0.629586] usbcore: registered new interface driver hub [ 0.635037] usbcore: registered new device driver usb [ 0.640764] pps_core: LinuxPPS API ver. 1 registered [ 0.645843] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.655183] PTP clock support registered [ 0.659219] EDAC MC: Ver: 3.0.0 [ 0.662725] scmi_core: SCMI protocol bus registered [ 0.667987] FPGA manager framework [ 0.671542] Advanced Linux Sound Architecture Driver Initialized. [ 0.678663] vgaarb: loaded [ 0.681767] clocksource: Switched to clocksource arch_sys_counter [ 0.688296] VFS: Disk quotas dquot_6.6.0 [ 0.692323] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.705836] NET: Registered PF_INET protocol family [ 0.711093] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.723536] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear) [ 0.732367] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 0.740307] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.748767] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear) [ 0.758060] TCP: Hash tables configured (established 65536 bind 65536) [ 0.764927] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.772011] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear) [ 0.779670] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 0.785945] RPC: Registered named UNIX socket transport module. [ 0.792013] RPC: Registered udp transport module. [ 0.796819] RPC: Registered tcp transport module. [ 0.801623] RPC: Registered tcp-with-tls transport module. [ 0.807228] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.813814] NET: Registered PF_XDP protocol family [ 0.818727] PCI: CLS 0 bytes, default 64 [ 0.823954] Initialise system trusted keyrings [ 0.828748] workingset: timestamp_bits=46 max_order=21 bucket_order=0 [ 0.835621] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.841861] NFS: Registering the id_resolver key type [ 0.847060] Key type id_resolver registered [ 0.851337] Key type id_legacy registered [ 0.855447] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.862294] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.917322] Key type asymmetric registered [ 0.921526] Asymmetric key parser 'x509' registered [ 0.926566] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 0.934320] io scheduler mq-deadline registered [ 0.938960] io scheduler kyber registered [ 0.943082] io scheduler bfq registered [ 0.950325] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 0.957077] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 0.964486] ledtrig-cpu: registered to indicate activity on CPUs [ 0.976358] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.990954] loop: module loaded [ 0.995269] megasas: 07.727.03.00-rc1 [ 1.002649] tun: Universal TUN/TAP device driver, 1.6 [ 1.008877] VFIO - User Level meta-driver version: 0.3 [ 1.015315] usbcore: registered new interface driver usb-storage [ 1.022066] i2c_dev: i2c /dev entries driver [ 1.027548] sdhci: Secure Digital Host Controller Interface driver [ 1.033880] sdhci: Copyright(c) Pierre Ossman [ 1.038568] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.044998] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.052174] usbcore: registered new interface driver usbhid [ 1.057881] usbhid: USB HID core driver [ 1.062955] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available [ 1.073212] optee: probing for conduit method. [ 1.077808] optee: revision 4.5 (ef1ebdc23034a804) [ 1.078142] optee: dynamic shared memory is enabled [ 1.088683] optee: initialized driver [ 1.088781] random: crng init done [ 1.094484] Initializing XFRM netlink socket [ 1.100327] NET: Registered PF_PACKET protocol family [ 1.105564] Key type dns_resolver registered [ 1.117583] registered taskstats version 1 [ 1.122041] Loading compiled-in X.509 certificates [ 1.138513] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.0.9--v11.00.09+ (Fancy Rat)') [ 1.201202] omap_i2c 4900000.i2c: bus 0 rev0.12 at 400 kHz [ 1.208274] omap_i2c 2b200000.i2c: bus 1 rev0.12 at 400 kHz [ 1.215220] /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/camera@29 [ 1.226988] /bus@f0000/i2c@20000000/camera@29: Fixed dependency cycle(s) with /bus@f0000/ticsi2rx@30142000/csi-bridge@30141000 [ 1.239052] pca953x 2-0023: supply vcc not found, using dummy regulator [ 1.245943] pca953x 2-0023: using AI [ 1.263868] omap_i2c 20000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.270932] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.280172] /bus@f0000/dss@30220000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b [ 1.290101] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi [ 1.299313] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30220000 [ 1.309377] omap_i2c 20010000.i2c: bus 3 rev0.12 at 100 kHz [ 1.316411] pca954x 4-0070: supply vdd not found, using dummy regulator [ 1.338038] i2c i2c-4: Added multiplexed i2c bus 5 [ 1.343125] i2c i2c-4: Added multiplexed i2c bus 6 [ 1.348030] pca954x 4-0070: registered 2 multiplexed busses for I2C switch pca9543 [ 1.355962] pca954x 4-0071: supply vdd not found, using dummy regulator [ 1.363105] i2c i2c-4: Added multiplexed i2c bus 7 [ 1.368156] i2c i2c-4: Added multiplexed i2c bus 8 [ 1.373069] pca954x 4-0071: registered 2 multiplexed busses for I2C switch pca9543 [ 1.380852] omap_i2c 20020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.386770] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created [ 1.395088] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.404289] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.413255] ti-sci-inta 4e400000.interrupt-controller: Interrupt Aggregator domain 200 created [ 1.427655] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.435929] ti-udma 485c0100.dma-controller: Channels: 44 (bchan: 16, tchan: 12, rchan: 16) [ 1.446622] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.457152] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.466592] ti-udma 4e230000.dma-controller: Number of rings: 40 [ 1.475190] ti-udma 4e230000.dma-controller: Channels: 40 (bchan: 0, tchan: 8, rchan: 32) [ 1.486206] printk: legacy console [ttyS2] disabled [ 1.491510] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 311, base_baud = 3000000) is a 8250 [ 1.500471] printk: legacy console [ttyS2] enabled [ 1.500471] printk: legacy console [ttyS2] enabled [ 1.510187] printk: legacy bootconsole [ns16550a0] disabled [ 1.510187] printk: legacy bootconsole [ns16550a0] disabled [ 1.529137] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.536123] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.541519] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.548233] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.554587] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.561006] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.567167] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.574017] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.580464] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.757777] davinci_mdio 8000f00.mdio: davinci mdio revision 17.7, bus freq 1000000 [ 1.768915] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867 [ 1.777043] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01903, cpsw version 0x6BA81903 Ports: 3 quirks:00000006 [ 1.790112] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.797250] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32 [ 1.805015] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010d, freq:500000000, add_val:1 pps:0 [ 1.824516] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.839011] mmc0: CQHCI version 5.10 [ 1.878351] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit [ 1.911627] pca953x 3-0020: supply vcc not found, using dummy regulator [ 1.918421] pca953x 3-0020: using no AI [ 1.946409] j721e-pcie f102000.pcie: host bridge /bus@f0000/pcie@f102000 ranges: [ 1.953874] j721e-pcie f102000.pcie: IO 0x0068001000..0x0068010fff -> 0x0068001000 [ 1.961980] j721e-pcie f102000.pcie: MEM 0x0068011000..0x006fffffff -> 0x0068011000 [ 1.970098] j721e-pcie f102000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.978634] mmc0: Command Queue Engine enabled [ 1.983100] mmc0: new HS200 MMC card at address 0001 [ 1.989004] mmcblk0: mmc0:0001 G1M15L 29.6 GiB [ 1.995883] mmcblk0: p1 p2 p3 p4 < p5 p6 > [ 2.000916] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB [ 2.006685] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB [ 2.012394] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0) [ 3.086579] j721e-pcie f102000.pcie: PCI host bridge to bus 0000:00 [ 3.092938] pci_bus 0000:00: root bus resource [bus 00-ff] [ 3.098425] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x68001000-0x68010fff]) [ 3.107893] pci_bus 0000:00: root bus resource [mem 0x68011000-0x6fffffff] [ 3.114788] pci 0000:00:00.0: [104c:b010] type 01 class 0x060400 PCIe Root Port [ 3.122107] pci 0000:00:00.0: PCI bridge to [bus 00] [ 3.127072] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff] [ 3.133160] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff] [ 3.139946] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref] [ 3.147741] pci 0000:00:00.0: supports D1 [ 3.151747] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 3.159852] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.168015] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.174653] pci 0000:00:00.0: PCI bridge to [bus 01] [ 3.179622] pci_bus 0000:00: resource 4 [io 0x0000-0xffff] [ 3.185188] pci_bus 0000:00: resource 5 [mem 0x68011000-0x6fffffff] [ 3.191571] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22 [ 3.198506] pcieport 0000:00:00.0: PME: Signaling with IRQ 567 [ 3.204682] pcieport 0000:00:00.0: AER: enabled with IRQ 567 [ 3.212133] mmc1: CQHCI version 5.10 [ 3.212194] clk: Disabling unused clocks [ 3.226007] PM: genpd: Disabling unused power domains [ 3.231165] ALSA device list: [ 3.234204] No soundcards found. [ 3.260352] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 3.268066] Waiting for root device PARTUUID=d73bf4db-02... [ 3.326735] mmc1: new ultra high speed SDR104 SDHC card at address aaaa [ 3.333938] mmcblk1: mmc1:aaaa SD32G 29.7 GiB [ 3.340012] mmcblk1: p1 p2 [ 3.458124] EXT4-fs (mmcblk1p2): recovery complete [ 3.463843] EXT4-fs (mmcblk1p2): mounted filesystem b9bbcee6-884f-423b-894a-2960cb8eaf33 r/w with ordered data mode. Quota mode: none. [ 3.476003] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.487433] devtmpfs: mounted [ 3.491122] Freeing unused kernel memory: 2752K [ 3.495746] Run /sbin/init as init process [ 3.715081] systemd[1]: System time before build time, advancing clock. [ 3.757879] NET: Registered PF_INET6 protocol family [ 3.763812] Segment Routing with IPv6 [ 3.767533] In-situ OAM (IOAM) with IPv6 [ 3.805358] systemd[1]: systemd 255.18^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 3.837258] systemd[1]: Detected architecture arm64. Welcome to Arago 2025.01! [ 3.856231] systemd[1]: Hostname set to <j722s-evm>. [ 3.961036] systemd-sysv-generator[112]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file, automatically generating a unit file for compatibility. [ 3.976910] systemd-sysv-generator[112]: Please update package to include a native systemd unit file. [ 3.986187] systemd-sysv-generator[112]: ! This compatibility logic is deprecated, expect removal soon. ! [ 4.175381] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether. [ 4.346136] systemd[1]: Queued start job for default target Graphical Interface. [ 4.379506] systemd[1]: Created slice Slice /system/getty. [ OK ] Created slice Slice /system/getty. [ 4.400227] systemd[1]: Created slice Slice /system/modprobe. [ OK ] Created slice Slice /system/modprobe. [ 4.420208] systemd[1]: Created slice Slice /system/serial-getty. [ OK ] Created slice Slice /system/serial-getty. [ 4.439606] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 4.458226] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ 4.478133] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 4.497957] systemd[1]: Expecting device /dev/ttyS2... Expecting device /dev/ttyS2... [ 4.514026] systemd[1]: Reached target Path Units. [ OK ] Reached target Path Units. [ 4.525909] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 4.541901] systemd[1]: Reached target Slice Units. [ OK ] Reached target Slice Units. [ 4.553916] systemd[1]: Reached target Swaps. [ OK ] Reached target Swaps. [ 4.618948] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 4.638058] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 4.664806] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 4.682358] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 4.703103] systemd[1]: Listening on Journal Audit Socket. [ OK ] Listening on Journal Audit Socket. [ 4.722678] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 4.746918] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.766948] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.787609] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 4.806540] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 4.822565] systemd[1]: Listening on User Database Manager Socket. [ OK ] Listening on User Database Manager Socket. [ 4.882150] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 4.898159] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 4.922320] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 4.934519] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing). [ 4.952938] systemd[1]: Mounting Temporary Directory /tmp... Mounting Temporary Directory /tmp... [ 4.971674] systemd[1]: Starting Create List of Static Device Nodes... Starting Create List of Static Device Nodes... [ 4.994656] systemd[1]: Starting Load Kernel Module configfs... Starting Load Kernel Module configfs... [ 5.018550] systemd[1]: Starting Load Kernel Module drm... Starting Load Kernel Module drm... [ 5.034869] systemd[1]: Starting Load Kernel Module fuse... Starting Load Kernel Module fuse... [ 5.061969] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen.[ 5.073373] fuse: init (API version 7.41) .. [ 5.091856] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 5.102400] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/). [ 5.150027] systemd[1]: Starting Journal Service... Starting Journal Service... [ 5.169456] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 5.187470] systemd[1]: Starting Generate network units from Kernel command line... Starting Generate network units from Kernel command line... [ 5.211529] systemd[1]: Starting Remount Root and Kernel File Systems... [ 5.211581] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems sysctl table check failed: ioctl/(null) procname is null [0m... [ 5.236888] sysctl table check failed: ioctl/(null) No proc_handler [ 5.243897] cryptodev: driver 1.14 loaded. [ 5.250858] systemd[1]: Starting Coldplug All udev Devices... [ 5.255994] systemd-journald[131]: Collecting audit messages is enabled. Starting Coldplug All udev Devices... [ 5.272311] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 5.283149] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted Huge Pages File System. [ 5.304316] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File Sy[ 5.314402] EXT4-fs (mmcblk1p2): re-mounted b9bbcee6-884f-423b-894a-2960cb8eaf33 r/w. Quota mode: none. stem. [ 5.340351] systemd[1]: Mounted Kernel Debug File System. [ OK ] Mounted Kernel Debug File System. [ 5.362473] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Temporary Directory /tmp. [ OK ] Finished Create List of Static Device Nodes. [ OK ] Finished Load Kernel Module configfs. [ OK ] Finished Load Kernel Module drm. [ OK ] Finished Load Kernel Module fuse. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Start psplas…temd progress communication helper. [ OK ] Finished Load Kernel Modules. [ OK ] Finished Generate network units from Kernel command line. [ OK ] Finished Remount Root and Kernel File Systems. Mounting FUSE Control File System... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables... Starting Create Static Device Nodes in /dev gr[ 5.682999] systemd-journald[131]: Received client request to flush runtime journal. acefully... [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. [ OK ] Finished Flush Journal to Persistent Storage. [ OK ] Finished Apply Kernel Variables. [ OK ] Finished Create Static Device Nodes in /dev gracefully. Starting Create Static Device Nodes in /dev... [ OK ] Finished Create Static Device Nodes in /dev. [ OK ] Reached target Preparation for Local File Systems. Mounting /var/volatile... [ 5.940596] audit: type=1334 audit(1741187611.220:2): prog-id=6 op=LOAD [ 5.947767] audit: type=1334 audit(1741187611.228:3): prog-id=7 op=LOAD Starting Rule-based Manager for Device Events and Files... [ OK ] Mounted /var/volatile. Starting Load/Save OS Random Seed... [ OK ] Reached target Local File Systems. Starting Create System Files and Directories... [ OK ] Finished Coldplug All udev Devices. [ OK ] Finished Load/Save OS Random Seed. [ OK ] Finished Create System Files and Directories. [ 6.120024] audit: type=1334 audit(1741187611.400:4): prog-id=8 op=LOAD Starting Network Name Resolution... [ 6.158278] audit: type=1334 audit(1741187611.440:5): prog-id=9 op=LOAD Starting Network Time Synchronization... Starting Record System Boot/Shutdown in UTMP... [ 6.228663] audit: type=1334 audit(1741187611.508:6): prog-id=10 op=LOAD [ 6.235522] audit: type=1334 audit(1741187611.516:7): prog-id=11 op=LOAD [ 6.242337] audit: type=1334 audit(1741187611.524:8): prog-id=12 op=LOAD Starting User Database Manager... [ OK ] Finished Record System Boot/Shutdown in UTMP. [ OK ] Started User Database Manager. [ OK ] Started Rule-based Manager for Device Events and Files. [ OK ] Found device /dev/ttyS2. [ OK ] Started Network Time Synchronization. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target System Time Set. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timer Units. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API... [ OK ] Listening on dropbear.socket. [ OK ] Listening on PC/SC Smart Card Daemon Activation Socket. [ 6.928325] audit: type=1334 audit(1751621126.704:9): prog-id=13 op=LOAD Starting D-Bus System Message Bus... Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Finished Reboot and dump vmcore via kexec. [ OK ] Started D-Bus System Message Bus. [ OK ] Reached target Socket Units. [ OK ] Reached target Basic System. [ OK ] Started Job spooling tools. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. [ OK ] Started Multiple Spanning Tree Protocol Daemon. Starting Telephony service... Starting PulseAudio Sound System... Starting Expand the rootfs partiti…to full size of the boot device.... [ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [ 7.560964] audit: type=1334 audit(1751621127.336:10): prog-id=14 op=LOAD [ 7.569884] audit: type=1334 audit(1751621127.344:11): prog-id=15 op=LOAD Starting User Login Management... Starting Telnet Server... [ OK ] Finished IPv4 Packet Filtering Framework. [ OK ] Finished IPv6 Packet Filtering Framework. [ OK ] Reached target Preparation for Network. Starting Network Configuration... [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Finished Telnet Server. [ OK ] Started Telephony service. [ 7.921559] Bluetooth: Core ver 2.22 [ 7.925429] NET: Registered PF_BLUETOOTH protocol family [ 7.931440] Bluetooth: HCI device and connection manager initialized [ 7.938498] Bluetooth: HCI socket layer initialized [ 7.943942] Bluetooth: L2CAP socket layer initialized [ 7.949452] Bluetooth: SCO socket layer initialized [ OK ] Finished Expand the rootfs partition to full size of the boot device.. [ 8.246960] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 8.263701] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 8.264434] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ OK ] Started PulseAudio Sound System. [ 8.305008] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100 [ 8.305430] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100 [ 8.309881] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100 [ 8.313421] CAN device driver interface [ 8.338490] omap-mailbox 29030000.mailbox: omap mailbox rev 0x66fca100 [ 8.359609] mc: Linux media interface: v0.10 [ 8.402794] videodev: Linux video capture interface: v2.00 [ OK ] Started User Login Management. [ 8.503249] rtc-ti-k3 2b1f0000.rtc: registered as rtc0 [ 8.512285] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@a3000000 [ 8.522524] k3-dsp-rproc 7e000000.dsp: configured DSP for IPC-only mode [ 8.554685] remoteproc remoteproc0: 7e000000.dsp is available [ 8.561138] remoteproc remoteproc0: attaching to 7e000000.dsp [ 8.567044] remoteproc remoteproc0: unsupported vendor resource 512 [ 8.573465] remoteproc remoteproc0: rsc table is truncated [ 8.573479] remoteproc remoteproc0: Failed to process resources: -22 [ OK ] Started Network Configuration. [ OK ] Reached target Network. [ 8.651985] k3-dsp-rproc 7e000000.dsp: error -EINVAL: failed to add register device with remoteproc core [ 8.661674] k3-dsp-rproc 7e000000.dsp: probe with driver k3-dsp-rproc failed with error -22 Starting Enable and configure wl18xx bluetooth[ 8.676448] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL) stack... [ 8.687088] remoteproc remoteproc0: releasing 7e000000.dsp [ 8.693324] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ 8.704359] platform 79000000.r5f: configured R5F for remoteproc mode [ 8.715812] platform 79000000.r5f: assigned reserved memory node mcu-r5fss-dma-memory-region@a1000000 [ 8.718313] k3-dsp-rproc 7e200000.dsp: assigned reserved memory node c7x-dma-memory@a4000000 [ 8.735994] remoteproc remoteproc1: 79000000.r5f is available [ 8.747288] k3-dsp-rproc 7e200000.dsp: configured DSP for IPC-only mode [ 8.754282] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 8.764721] remoteproc remoteproc0: 7e200000.dsp is available [ 8.765471] remoteproc remoteproc1: powering up 79000000.r5f [ 8.774011] remoteproc remoteproc0: attaching to 7e200000.dsp [ 8.780144] remoteproc remoteproc1: Direct firmware load for j722s-mcu-r5f0_0-fw failed with error -2 [ 8.782511] remoteproc remoteproc0: unsupported vendor resource 512 [ 8.791447] remoteproc remoteproc1: request_firmware failed: -2 [ 8.804068] remoteproc remoteproc0: unsupported vendor resource 512 [ 8.810754] remoteproc remoteproc0: rsc table is truncated [ 8.816604] remoteproc remoteproc0: Failed to process resources: -22 [ 8.823429] k3-dsp-rproc 7e200000.dsp: error -EINVAL: failed to add register device with remoteproc core [ 8.833573] k3-dsp-rproc 7e200000.dsp: probe with driver k3-dsp-rproc failed with error -22 [ 8.846350] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ OK ] Started Netperf Benchmark Server 8.863482] platform 78000000.r5f: configured R5F for IPC-only mode m. [ 8.872185] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 8.886722] remoteproc remoteproc0: releasing 7e200000.dsp [ 8.892343] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE' [ 8.898278] remoteproc remoteproc2: 78000000.r5f is available [ 8.907878] vdec 30210000.video-codec: Product Code: 0x521c [ 8.910036] remoteproc remoteproc2: attaching to 78000000.r5f [ 8.914584] vdec 30210000.video-codec: Firmware Revision: 344874 Starting Simple Network Management Protocol (SNMP) Daemon.... [ 8.950547] rproc-virtio rproc-virtio.5.auto: assigned reserved memory node r5f-dma-memory@a0000000 [ 8.993856] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 9.034013] virtio_rpmsg_bus virtio0: rpmsg host is online [ 9.034141] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd [ 9.040679] rproc-virtio rproc-virtio.5.auto: registered virtio0 (type 7) [ 9.054218] remoteproc remoteproc2: remote processor 78000000.r5f is now attached Starting Permit User Sessions... [ 9.100261] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe [ OK ] Finished Enable and configure wl18xx bluetooth stack. [ OK ] Finished Permit User Sessions. [ OK ] Reached target Hardware activated U[ 9.173045] ____________________csi2rx_async_bound___________name:cdns_csi2rx.30141000.csi-bridge____________ SB gadget. [ 9.187545] platform 78400000.r5f: configured R5F for IPC-only mode [ 9.196069] platform 78400000.r5f: assigned reserved memory node main-r5fss-dma-memory-region@a2000000 [ 9.197367] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 9.243626] remoteproc remoteproc0: 78400000.r5f is available [ 9.251083] remoteproc remoteproc0: attaching to 78400000.r5f [ 9.274334] rproc-virtio rproc-virtio.6.auto: assigned reserved memory node main-r5fss-dma-memory-region@a2000000 [ 9.287575] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 9.288416] virtio_rpmsg_bus virtio1: rpmsg host is online [ 9.289214] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 9.298566] sii902x 3-003b: supply iovcc not found, using dummy regulator [ 9.315109] rproc-virtio rproc-virtio.6.auto: registered virtio1 (type 7) [ 9.322494] remoteproc remoteproc0: remote processor 78400000.r5f is now attached [ 9.324200] sii902x 3-003b: supply cvcc12 not found, using dummy regulator [ 9.369707] cdns-csi2rx 30141000.csi-bridge: Probed CSI2RX with 4/4 lanes, 4 streams, external D-PHY [ 9.404853] i2c i2c-3: Added multiplexed i2c bus 9 [ OK ] Started emptty display manager. [ 9.446154] m_can_platform 4e08000.can: m_can device registered (irq=584, version=32) Starting EdgeAI OOB demos... [ 9.473366] m_can_platform 4e18000.can: m_can device registered (irq=585, version=32) [ OK ] Started Getty on tty1. [ 9.529394] PVR_K: 226: Device: fd80000.gpu [ 9.558794] m_can_platform 20701000.can: m_can device registered (irq=588, version=32) [ 9.612466] PVR_K: 226: Read BVNC 36.53.104.796 from HW device registers [ 9.619466] PVR_K: 226: RGX Device registered BVNC 36.53.104.796 with 1 core in the system [ 9.637962] [drm] Initialized pvr 24.2.6643903 for fd80000.gpu on minor 0 [ OK ] Reached target Login Prompts.[ 9.649650] [drm] Initialized tidss 1.0.0 for 30220000.dss on minor 1 [ 9.660817] tidss 30220000.dss: [drm] Cannot find any crtc or sizes [ OK ] Started LLDP daemon. [ 9.677063] tidss 30220000.dss: [drm] Cannot find any crtc or sizes [ 9.694889] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY Stopping emptty display manager... [ OK ] Stopped emptty display manager. [ OK ] Created slice Slice /system/tee-supplicant. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. Starting Virtual Console Setup... [ OK ] Started TEE Supplicant on teepriv0. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Finished Virtual Console Setup. [ OK ] Created slice Slice /system/systemd-fsck. Expecting device /dev/mmcblk0p1... Expecting device /dev/mmcblk0p3... [ 10.309639] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 10.381312] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 1 [ 10.405339] xhci-hcd xhci-hcd.8.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000008010 [ 10.420931] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 10.430758] xhci-hcd xhci-hcd.8.auto: irq 591, io mem 0x31210000 [ 10.437566] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller [ 10.443300] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 2 [ 10.451162] xhci-hcd xhci-hcd.8.auto: Host supports USB 3.0 SuperSpeed [ 10.460935] hub 1-0:1.0: USB hub found [ 10.464907] hub 1-0:1.0: 1 port detected [ 10.469722] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. Expecting device /dev/mmcblk0p2... [ 10.492316] hub 2-0:1.0: USB hub found [ 10.500737] hub 2-0:1.0: 1 port detected [ 10.507792] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 10.515487] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 10.549647] m_can_platform 20701000.can main_mcan0: renamed from can2 Expecting device /dev/mmcblk0p5... [ 10.660000] m_can_platform 4e08000.can mcu_mcan0: renamed from can0 [ 10.691743] m_can_platform 4e18000.can mcu_mcan1: renamed from can1 [ 10.714065] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ OK ] Found device /dev/mmcblk0p1. [ 10.793503] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ 10.856095] hub 1-1:1.0: USB hub found [ 10.864260] hub 1-1:1.0: 4 ports detected Starting File System Check on /dev/mmcblk0p1... [ 10.884564] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY [ OK ] Found device /dev/mmcblk0p2. [ 10.973917] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ OK ] Found device /dev/mmcblk0p3. [ 11.072224] hub 2-1:1.0: USB hub found [ 11.077960] hub 2-1:1.0: 4 ports detected Starting Save/Restore Sound Card State... Starting File System Check on /dev/mmcblk0p2 11.100861] cdns-csi2rx 30121000.csi-bridge: Couldn't get external D-PHY 0m... Starting File System Check on /dev/mmcblk0p3... [ OK ] Found device /dev/mmcblk0p5. [ OK ] Finished File System Check on /dev/mmcblk0p1. [ OK ] Finished Save/Restore Sound Card State. Expecting device /dev/mmcblk1p1... [ OK ] Reached target Sound Card. Mounting /run/media/mmcblk0p1... Starting File System Check on /dev/mmcblk0p5... [ OK ] Mounted /run/media/mmcblk0p1. [ OK ] Started EdgeAI OOB demos. [ OK ] Finished File System Check on /dev/mmcblk0p2. Mounting /run/media/rootfs-mmcblk0p2... [ OK ] Finished File System Check on /dev/mmcblk0p3. [ OK ] Finished File System Check on /dev/mmcblk0p5. [ 11.486263] usbcore: registered new device driver onboard-usb-dev Mounting /run/media/backup-mmcblk0p3... Mounting /run/media/user-mmcblk0p5... [ 11.570202] EXT4-fs (mmcblk0p3): mounted filesystem 177ee670-bb9c-42d0-96be-b7d6b7c859e6 r/w with ordered data mode. Quota mode: none. [ 11.579135] EXT4-fs (mmcblk0p2): mounted filesystem 6df47fd6-3f21-4e28-b9fc-82759baff4c3 r/w with ordered data mode. Quota mode: none. [ OK ] Mounted /run/media/backup-mmcblk0p3. [ OK ] Mounted /run/media/rootfs-mmcblk0p2. [ 11.638530] EXT4-fs (mmcblk0p5): mounted filesystem 11eb0200-dc98-41aa-9974-f9da9797dfcd r/w with ordered data mode. Quota mode: none. [ OK ] Found device /dev/mmcblk1p1. [ OK ] Mounted /run/media/user-mmcblk0p5. Starting File System Check on /dev/mmcblk1p1... [ OK ] Finished File System Check on /dev/mmcblk1p1. Mounting /run/media/BOOT-mmcblk1p1... [ OK ] Mounted /run/media/BOOT-mmcblk1p1. [ OK ] Started containerd container runtime. [ 12.793077] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx [ 13.679421] kauditd_printk_skb: 2 callbacks suppressed [ 13.679438] audit: type=1701 audit(1751621133.456:14): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=992 comm="edgeai-gui-app" exe="/usr/bin/edgeai-gui-app" sig=6 res=1 [ OK ] Created slice Slice /system/systemd[ 13.735509] audit: type=1334 audit(1751621133.512:15): prog-id=18 op=LOAD -coredump. [ 13.746301] audit: type=1334 audit(1751621133.524:16): prog-id=19 op=LOAD [ 13.754525] audit: type=1334 audit(1751621133.532:17): prog-id=20 op=LOAD [ OK ] Started Process Core Dump (PID 1164/UID 0). *************************************************************** *************************************************************** NOTICE: This file system contains the following GPL-3.0 packages: adwaita-icon-theme-symbolic autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils-dev elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gnu-config grub-common grub-editenv grub-efi gzip hidapi kbd-dev kbd-keymaps-pine less libasm1 libatomic-dev libatomic1 libbfd libdebuginfod1 libdw1 libelf1 libgcc-s-dev libgcc1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libgnutls-dev libgnutls-openssl27 libgomp1 libidn2-0 libidn2-dev libmpc3 libmpfr6 libopcodes libqt6core5compat-plugins libqt6core5compat-qmlplugins libqt6core5compat6 libqt6shadertools-dev libqt6shadertools-plugins libqt6shadertools-qmlplugins libqt6shadertools6 libreadline-dev libreadline8 libstdc++-dev libstdc++6 libtasn1-dev libunistring-dev libunistring5 m4 make nettle-dev nettle parted piglit qtbase-dev qtbase-examples qtbase-plugins qtbase-qmlplugins qtbase-staticdev qtbase qtdeclarative-dev qtdeclarative-plugins qtdeclarative-qmlplugins qtdeclarative-staticdev qtdeclarative-tools qtdeclarative qtlanguageserver-dev qtlanguageserver-plugins qtlanguageserver-qmlplugins qtlanguageserver-staticdev qtlanguageserver qtmultimedia-plugins qtmultimedia-qmlplugins qtmultimedia qtquick3d-plugins qtquick3d-qmlplugins qtquick3d qtquicktimeline-plugins qtquicktimeline-qmlplugins qtquicktimeline qtsvg-dev qtsvg-plugins qtsvg-qmlplugins qtsvg qtwayland-dev qtwayland-plugins qtwayland-qmlplugins qtwayland tar which If you do not wish to distribute GPL-3.0 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ 15.062249] audit: type=1334 audit(1751621134.840:18): prog-id=20 op=UNLOAD [ 15.069361] audit: type=1334 audit(1751621134.840:19): prog-id=19 op=UNLOAD [ 15.076540] audit: type=1334 audit(1751621134.840:20): prog-id=18 op=UNLOAD _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j722s-evm ttyS2 Arago 2025.01 j722s-evm ttyS2 j722s-evm login: [
Summarize: Why can't the csirx1 node be generated.
Cesar
