Part Number: J721EXCPXEVM
Hi team,
I just want to know how I can enable IPC notify through examples. Like the way I have build the ipc_freertos and other??
Hi team,
Hello Ankit,
what do you mean by build ipc notify ?
ipc echo test example which you have built freeRTOS is available example in SDK.
Tarun Mukesh
Suppose I want to enable ipc_notify between a72 cores and r5f cores. How can we do that?
If your A72 is running linux, then R5F runs ipc_echo_test then you can follow
Tarun Mukesh
