Part Number: SK-TDA4VM
I am writing a custom gstreamer plugin to use the VPAC and VISS modules for processing the frames, I get the below errors when I try to run the plugin:
root@tda4vm-sk:/usr/custom_plugins# GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video-imx219-cam0 io-mode=dmabuf-import ! video/x-bayer,width=1920,height=1080,framerate=30/1,format=bggr ! visscon
vert sensor-name=IMX219 sensor-dcc-id=219 dcc-isp-config-file=/usr/custom_plugins/dcc_viss_1920x1080.bin ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! autovideosink
0:00:00.084992507 3964 0x165b9830 WARN default gstvissconvert.c:162:gst_viss_convert_init:<GstVissConvert@0x165dc6d0> GstTIOVXAllocator not available, falling back to default allocator
Setting pipeline to PAUSED ...
0:00:00.128656669 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128707067 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128729773 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128770975 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128791310 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128809421 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128828347 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128846428 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128864024 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128882194 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128899845 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128917466 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128934977 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128952488 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128969908 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.128987394 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129005095 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129022576 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129040487 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129058122 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129075683 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129093344 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129110690 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129128135 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129145976 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129163042 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129180278 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129197683 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129215304 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129233055 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129250691 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129268002 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129285702 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129302908 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129320239 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129337325 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129355110 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129373116 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129390697 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129408113 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129425914 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129443284 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129460875 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129478776 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129496132 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129513383 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129530628 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.129548299 3964 0x1657b6a0 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl0> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146314968 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146358480 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146379676 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146399492 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146419193 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146438399 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146457109 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146475460 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146493446 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146511462 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146529173 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146547303 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146565079 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146583675 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146601521 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146619057 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146637272 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146654393 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146672284 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146689365 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146707860 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146726026 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146743667 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146761623 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146780559 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146798125 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146815935 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146833206 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146851132 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146865798 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146883148 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146901159 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146919095 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146936746 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146954526 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146971812 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.146989373 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147007554 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147025285 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147042535 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147060376 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147077657 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147095178 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147113238 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147131184 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147181672 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147200002 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0:00:00.147218528 3964 0x165a2a40 WARN glcontext gstglcontext_egl.c:552:gst_gl_context_egl_dump_config:<glcontextegl1> unknown EGL_COLOR_BUFFER_TYPE value 3300
0.000000 s: VX_ZONE_INIT:Enabled
0.000000 s: VX_ZONE_ERROR:Enabled
0.000000 s: VX_ZONE_WARNING:Enabled
0.000000 s: VX_ZONE_ERROR:[ownPlatformInit:85] insufficient shared memory size
0.000000 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-0
0.000000 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-1
0.000000 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-2
0.000000 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:116] Added target MPU-3
0.000000 s: VX_ZONE_INIT:[tivxInitLocal:136] Initialization Done !!!
0.000000 s: VX_ZONE_INIT:[tivxHostInitLocal:101] Initialization Done for HOST !!!
0:00:00.155812775 3964 0x165b9830 ERROR default gstvissconvert.c:377:gst_viss_convert_init_module:<vissconvert0> Insufficient CMA memory: 33940 kB, need at least 200MB
0:00:00.155879067 3964 0x165b9830 ERROR default gstvissconvert.c:821:gst_viss_convert_change_state:<vissconvert0> Failed to initialize TIOVX module
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
