TDA4VL-Q1: mixedPrecisionFactor got an error during convert our model to TI bin files
Part Number: TDA4VL-Q1
hi expert:
 i have already submit this kind of problem before, but did not get the response from your side.
this is my tidl tools version for model convert.
this is my config file for model convert:
problem is:
if  i convert the model with parameter mixedPrecisionFactor = xx
then it would get the assert error
we found the src code for "PC_dsp_test_dl_algo.out"
you can see from our config file ,we did not set the "inElementType" so by your files said:
the default value should be 0
may be i think that because we set "mixedPrecisionFactor" so this  "inElementType" would be changed to other value
but we don't know how to avoid this error.
we need use "mixedPrecisionFactor" parameter for more efficiency inference frame rate  and higher accuracy inference result.
so please check this bug and fix your code ASAP. and help us to handle this problem. thanks!
    Can you send the import config file?  And the model if possible.  Looks like you are using a yolo7 model, I cold find a similar one.  It looks like your input file is a txt file.  These means it is a list of paths to compressed image files (jpg/png).  If so then set inFileFormat to 2.
    Chris
  • hi, I have already send a email to your colleague(Zhang), maybe he can synchronize information with you
  • Dear Chris.
    upload the onnx file from customer, Linfeng fu.
    https://tidrive.ext.ti.com/a/bcDJ4QXAyTl_wMno/72061ab3-cf6d-4d46-9e34-25d8ad61488e?l
    it is private data, so provide above link as internal sharing.
    Please let me know if you can download that.
    And customer will use SDK9.2 for production, but the TIDL has been upgraded to 10.0 to solve some bug in 9.2. Please noted.
    thanks a lot!
    yong
  • Hi
    Can you try with sdk 11.0? we have a sub version of tidl in 11.0 that is compatible with 9.2.
    Adam
  • Hi
    I have test this with tidl 11.0.8 and here is part of the import log (whole log is too long):
    Core 0 End of Layer # -   52 with outPtrs[0] = 0x7267f8eb5280
    Core 0 Alg Process for Layer # -   53, layer type 1
    Processing Layer # -   53
    Core 0 End of Layer # -   53 with outPtrs[0] = 0x7267f9221880
    Core 0 Alg Process for Layer # -   54, layer type 1
    Processing Layer # -   54
    Core 0 End of Layer # -   54 with outPtrs[0] = 0x7267f9230e80
    Core 0 Alg Process for Layer # -   55, layer type 1
    Processing Layer # -   55
    Core 0 End of Layer # -   55 with outPtrs[0] = 0x7267f9212680
    Core 0 Alg Process for Layer # -   56, layer type 1
    Processing Layer # -   56
    Core 0 End of Layer # -   56 with outPtrs[0] = 0x7267f91f9500
    Core 0 Alg Process for Layer # -   57, layer type 12
    Processing Layer # -   57
    Core 0 End of Layer # -   57 with outPtrs[0] = 0x7267f8eb5280
    Core 0 Alg Process for Layer # -   58, layer type 1
    Processing Layer # -   58
    Core 0 End of Layer # -   58 with outPtrs[0] = 0x7267f9174100
    Core 0 Alg Process for Layer # -   59, layer type 1
    Processing Layer # -   59
    Core 0 End of Layer # -   59 with outPtrs[0] = 0x7267f9221880
    Core 0 Alg Process for Layer # -   60, layer type 21
    Processing Layer # -   60
    Core 0 End of Layer # -   60 with outPtrs[0] = 0x7267f8eb5280
    Core 0 Alg Process for Layer # -   61, layer type 12
    Processing Layer # -   61
    Core 0 End of Layer # -   61 with outPtrs[0] = 0x7267f8fe3c80
    Core 0 Alg Process for Layer # -   62, layer type 1
    Processing Layer # -   62
    Core 0 End of Layer # -   62 with outPtrs[0] = 0x7267f8b90080
    Core 0 Alg Process for Layer # -   63, layer type 1
    Processing Layer # -   63
    Core 0 End of Layer # -   63 with outPtrs[0] = 0x7267f8f7fc00
    Core 0 Alg Process for Layer # -   64, layer type 1
    Processing Layer # -   64
    Core 0 End of Layer # -   64 with outPtrs[0] = 0x7267f9257000
    Core 0 Alg Process for Layer # -   65, layer type 1
    Processing Layer # -   65
    Core 0 End of Layer # -   65 with outPtrs[0] = 0x7267f8eb5280
    Core 0 Alg Process for Layer # -   66, layer type 12
    Processing Layer # -   66
    Core 0 End of Layer # -   66 with outPtrs[0] = 0x7267f8fe3c80
    Core 0 Alg Process for Layer # -   67, layer type 1
    Processing Layer # -   67
    Core 0 End of Layer # -   67 with outPtrs[0] = 0x7267f8f19300
    Core 0 Alg Process for Layer # -   68, layer type 1
    Processing Layer # -   68
    Core 0 End of Layer # -   68 with outPtrs[0] = 0x7267f8f7fc00
    Core 0 Alg Process for Layer # -   69, layer type 12
    Processing Layer # -   69
    Core 0 End of Layer # -   69 with outPtrs[0] = 0x7267f8fe3c80
    Core 0 Alg Process for Layer # -   70, layer type 1
    Processing Layer # -   70
    Core 0 End of Layer # -   70 with outPtrs[0] = 0x7267f8f19300
    Core 0 Alg Process for Layer # -   71, layer type 1
    Processing Layer # -   71
    Core 0 End of Layer # -   71 with outPtrs[0] = 0x7267f91f9500
    Core 0 Alg Process for Layer # -   72, layer type 1
    Processing Layer # -   72
    Core 0 End of Layer # -   72 with outPtrs[0] = 0x7267f8b90080
    Core 0 Alg Process for Layer # -   73, layer type 1
    Processing Layer # -   73
    Core 0 End of Layer # -   73 with outPtrs[0] = 0x7267f8f7fc00
    Core 0 Alg Process for Layer # -   74, layer type 12
    Processing Layer # -   74
    Core 0 End of Layer # -   74 with outPtrs[0] = 0x7267f8fe3c80
    Core 0 Alg Process for Layer # -   75, layer type 1
    Processing Layer # -   75
    Core 0 End of Layer # -   75 with outPtrs[0] = 0x7267f91a6300
    Core 0 Alg Process for Layer # -   76, layer type 1
    Processing Layer # -   76
    Core 0 End of Layer # -   76 with outPtrs[0] = 0x7267f9230e80
    Core 0 Alg Process for Layer # -   77, layer type 12
    Processing Layer # -   77
    Core 0 End of Layer # -   77 with outPtrs[0] = 0x7267f9174100
    Core 0 Alg Process for Layer # -   78, layer type 1
    Processing Layer # -   78
    Core 0 End of Layer # -   78 with outPtrs[0] = 0x7267f9221880
    Core 0 Alg Process for Layer # -   79, layer type 1
    Processing Layer # -   79
    Core 0 End of Layer # -   79 with outPtrs[0] = 0x7267f923d780
    Core 0 Alg Process for Layer # -   80, layer type 1
    Processing Layer # -   80
    Core 0 End of Layer # -   80 with outPtrs[0] = 0x7267f9212680
    Core 0 Alg Process for Layer # -   81, layer type 1
    Processing Layer # -   81
    Core 0 End of Layer # -   81 with outPtrs[0] = 0x7267f9230e80
    Core 0 Alg Process for Layer # -   82, layer type 12
    Processing Layer # -   82
    Core 0 End of Layer # -   82 with outPtrs[0] = 0x7267f9174100
    Core 0 Alg Process for Layer # -   83, layer type 1
    Processing Layer # -   83
    Core 0 End of Layer # -   83 with outPtrs[0] = 0x7267f9257000
    Core 0 Alg Process for Layer # -   84, layer type 1
    Processing Layer # -   84
    Core 0 End of Layer # -   84 with outPtrs[0] = 0x7267f9174100
    Core 0 Alg Process for Layer # -   85, layer type 1
    Processing Layer # -   85
    Core 0 End of Layer # -   85 with outPtrs[0] = 0x7267f923d780
    Core 0 Alg Process for Layer # -   86, layer type 8
    Processing Layer # -   86
    Core 0 End of Layer # -   86 with outPtrs[0] = 0x60108e80feb0
    Core 0 Alg Process for Layer # -   87, layer type 0
    TIDL_process is completed with handle : 0x60108e7da480
    Skipping static gen-set function
    TIDL_deactivate is called with handle : 0x60108e7da480 - Copying handle of size 19736 from 0x60108e7e4780 to 0x60108e7da480
    cd /home/ht/edgeai/edgeai-tidl-tools/tools/AM68A/tidl_tools && ./ti_cnnperfsim.out /home/ht/customers/longhorn/yolov7/output/yolov7_net.bin_autoMixedPrecArtifacts/import.txt_MP_layer_86.perf_sim_config.txt /tmp 83887681 0 2
    ========================== [Memory Planning Started] ==========================
    ------------------------- Network Compiler Traces ------------------------------
    Successful Memory Allocation
    Successful Workload Creation
    ========================= [Memory Planning Completed] =========================
    Network buffer segments:
    buf(0), offset(       0), size(  162816)
    buf(1), offset(  980160), size( 1756912)
    buf(2), offset(  162816), size(  817344)
    buf(3), offset( 2737088), size(  676488)
    Removing mixed precision artifacts
    Empty prototxt path, running calibration
    Num of Layer Detected :  88
      Num|TIDL Layer Name               |Out Data Name                                     |Group |#Ins  |#Outs |Inbuf Ids                       |Outbuf Id |In NCHW                             |Out NCHW                            |MACS       |
        0|TIDL_DataLayer                |images                                            |     0|    -1|     1|  x   x   x   x   x   x   x   x |  0       |       0        0        0        0        0        0 |       1        1        1        3      640      640 |         0 |
        1|TIDL_ConvolutionLayer         |onnx::Conv_112                                    |     0|     1|     1|  0   x   x   x   x   x   x   x |  1       |       1        1        1        3      640      640 |       1        1        1       16      320      320 |  44236800 |
        2|TIDL_ConvolutionLayer         |onnx::Conv_114                                    |     0|     1|     1|  1   x   x   x   x   x   x   x |  2       |       1        1        1       16      320      320 |       1        1        1       32      160      160 | 117964800 |
        3|TIDL_ConvolutionLayer         |onnx::Conv_118                                    |     0|     1|     1|  2   x   x   x   x   x   x   x |  3       |       1        1        1       32      160      160 |       1        1        1       16      160      160 |  13107200 |
        4|TIDL_ConvolutionLayer         |onnx::Concat_116                                  |     0|     1|     1|  2   x   x   x   x   x   x   x |  4       |       1        1        1       32      160      160 |       1        1        1       16      160      160 |  13107200 |
        5|TIDL_ConvolutionLayer         |onnx::Conv_120                                    |     0|     1|     1|  3   x   x   x   x   x   x   x |  5       |       1        1        1       16      160      160 |       1        1        1       16      160      160 |  58982400 |
        6|TIDL_ConvolutionLayer         |onnx::Concat_122                                  |     0|     1|     1|  5   x   x   x   x   x   x   x |  6       |       1        1        1       16      160      160 |       1        1        1       16      160      160 |  58982400 |
        7|TIDL_ConcatLayer              |input.24                                          |     0|     4|     1|  6   5   3   4   x   x   x   x |  7       |       1        1        1       16      160      160 |       1        1        1       64      160      160 |   1638400 |
        8|TIDL_ConvolutionLayer         |onnx::MaxPool_125                                 |     0|     1|     1|  7   x   x   x   x   x   x   x |  8       |       1        1        1       64      160      160 |       1        1        1       32      160      160 |  52428800 |
        9|TIDL_PoolingLayer             |input.32                                          |     0|     1|     1|  8   x   x   x   x   x   x   x |  9       |       1        1        1       32      160      160 |       1        1        1       32       80       80 |    819200 |
       10|TIDL_ConvolutionLayer         |onnx::Conv_130                                    |     0|     1|     1|  9   x   x   x   x   x   x   x | 10       |       1        1        1       32       80       80 |       1        1        1       32       80       80 |   6553600 |
       11|TIDL_ConvolutionLayer         |onnx::Concat_128                                  |     0|     1|     1|  9   x   x   x   x   x   x   x | 11       |       1        1        1       32       80       80 |       1        1        1       32       80       80 |   6553600 |
       12|TIDL_ConvolutionLayer         |onnx::Conv_132                                    |     0|     1|     1| 10   x   x   x   x   x   x   x | 12       |       1        1        1       32       80       80 |       1        1        1       32       80       80 |  58982400 |
       13|TIDL_ConvolutionLayer         |onnx::Concat_134                                  |     0|     1|     1| 12   x   x   x   x   x   x   x | 13       |       1        1        1       32       80       80 |       1        1        1       32       80       80 |  58982400 |
       14|TIDL_ConcatLayer              |input.52                                          |     0|     4|     1| 13  12  10  11   x   x   x   x | 14       |       1        1        1       32       80       80 |       1        1        1      128       80       80 |    819200 |
       15|TIDL_ConvolutionLayer         |onnx::MaxPool_137                                 |     0|     1|     1| 14   x   x   x   x   x   x   x | 15       |       1        1        1      128       80       80 |       1        1        1       64       80       80 |  52428800 |
       16|TIDL_PoolingLayer             |input.60                                          |     0|     1|     1| 15   x   x   x   x   x   x   x | 16       |       1        1        1       64       80       80 |       1        1        1       64       40       40 |    409600 |
       17|TIDL_ConvolutionLayer         |onnx::Concat_213                                  |     0|     1|     1| 15   x   x   x   x   x   x   x | 17       |       1        1        1       64       80       80 |       1        1        1       32       80       80 |  13107200 |
       18|TIDL_ConvolutionLayer         |onnx::Conv_142                                    |     0|     1|     1| 16   x   x   x   x   x   x   x | 18       |       1        1        1       64       40       40 |       1        1        1       64       40       40 |   6553600 |
       19|TIDL_ConvolutionLayer         |onnx::Concat_140                                  |     0|     1|     1| 16   x   x   x   x   x   x   x | 19       |       1        1        1       64       40       40 |       1        1        1       64       40       40 |   6553600 |
       20|TIDL_ConvolutionLayer         |onnx::Conv_144                                    |     0|     1|     1| 18   x   x   x   x   x   x   x | 20       |       1        1        1       64       40       40 |       1        1        1       64       40       40 |  58982400 |
       21|TIDL_ConvolutionLayer         |onnx::Concat_146                                  |     0|     1|     1| 20   x   x   x   x   x   x   x | 21       |       1        1        1       64       40       40 |       1        1        1       64       40       40 |  58982400 |
       22|TIDL_ConcatLayer              |input.80                                          |     0|     4|     1| 21  20  18  19   x   x   x   x | 22       |       1        1        1       64       40       40 |       1        1        1      256       40       40 |    409600 |
       23|TIDL_ConvolutionLayer         |onnx::MaxPool_149                                 |     0|     1|     1| 22   x   x   x   x   x   x   x | 23       |       1        1        1      256       40       40 |       1        1        1      128       40       40 |  52428800 |
       24|TIDL_PoolingLayer             |input.88                                          |     0|     1|     1| 23   x   x   x   x   x   x   x | 24       |       1        1        1      128       40       40 |       1        1        1      128       20       20 |    204800 |
       25|TIDL_ConvolutionLayer         |onnx::Concat_192                                  |     0|     1|     1| 23   x   x   x   x   x   x   x | 25       |       1        1        1      128       40       40 |       1        1        1       64       40       40 |  13107200 |
       26|TIDL_ConvolutionLayer         |onnx::Conv_154                                    |     0|     1|     1| 24   x   x   x   x   x   x   x | 26       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |   6553600 |
       27|TIDL_ConvolutionLayer         |onnx::Concat_152                                  |     0|     1|     1| 24   x   x   x   x   x   x   x | 27       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |   6553600 |
       28|TIDL_ConvolutionLayer         |onnx::Conv_156                                    |     0|     1|     1| 26   x   x   x   x   x   x   x | 28       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |  58982400 |
       29|TIDL_ConvolutionLayer         |onnx::Concat_158                                  |     0|     1|     1| 28   x   x   x   x   x   x   x | 29       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |  58982400 |
       30|TIDL_ConcatLayer              |input.108                                         |     0|     4|     1| 29  28  26  27   x   x   x   x | 30       |       1        1        1      128       20       20 |       1        1        1      512       20       20 |    204800 |
       31|TIDL_ConvolutionLayer         |onnx::Conv_161                                    |     0|     1|     1| 30   x   x   x   x   x   x   x | 31       |       1        1        1      512       20       20 |       1        1        1      256       20       20 |  52428800 |
       32|TIDL_ConvolutionLayer         |onnx::Concat_163                                  |     0|     1|     1| 31   x   x   x   x   x   x   x | 32       |       1        1        1      256       20       20 |       1        1        1      128       20       20 |  13107200 |
       33|TIDL_ConvolutionLayer         |onnx::MaxPool_165                                 |     0|     1|     1| 31   x   x   x   x   x   x   x | 33       |       1        1        1      256       20       20 |       1        1        1      128       20       20 |  13107200 |
       34|TIDL_PoolingLayer             |onnx::MaxPool_166                                 |     0|     1|     1| 33   x   x   x   x   x   x   x | 34       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       35|TIDL_PoolingLayer             |onnx::MaxPool_168                                 |     0|     1|     1| 33   x   x   x   x   x   x   x | 35       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       36|TIDL_PoolingLayer             |onnx::MaxPool_172                                 |     0|     1|     1| 33   x   x   x   x   x   x   x | 36       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       37|TIDL_PoolingLayer             |onnx::Concat_167                                  |     0|     1|     1| 34   x   x   x   x   x   x   x | 37       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       38|TIDL_PoolingLayer             |onnx::MaxPool_169                                 |     0|     1|     1| 35   x   x   x   x   x   x   x | 38       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       39|TIDL_PoolingLayer             |onnx::MaxPool_173                                 |     0|     1|     1| 36   x   x   x   x   x   x   x | 39       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       40|TIDL_PoolingLayer             |onnx::MaxPool_170                                 |     0|     1|     1| 38   x   x   x   x   x   x   x | 40       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       41|TIDL_PoolingLayer             |onnx::MaxPool_174                                 |     0|     1|     1| 39   x   x   x   x   x   x   x | 41       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       42|TIDL_PoolingLayer             |onnx::Concat_171                                  |     0|     1|     1| 40   x   x   x   x   x   x   x | 42       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       43|TIDL_PoolingLayer             |onnx::MaxPool_175                                 |     0|     1|     1| 41   x   x   x   x   x   x   x | 43       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       44|TIDL_PoolingLayer             |onnx::MaxPool_176                                 |     0|     1|     1| 43   x   x   x   x   x   x   x | 44       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       45|TIDL_PoolingLayer             |onnx::Concat_177                                  |     0|     1|     1| 44   x   x   x   x   x   x   x | 45       |       1        1        1      128       20       20 |       1        1        1      128       20       20 |    460800 |
       46|TIDL_ConcatLayer              |input.124                                         |     0|     4|     1| 45  42  37  33   x   x   x   x | 46       |       1        1        1      128       20       20 |       1        1        1      512       20       20 |    204800 |
       47|TIDL_ConvolutionLayer         |onnx::Concat_180                                  |     0|     1|     1| 46   x   x   x   x   x   x   x | 47       |       1        1        1      512       20       20 |       1        1        1      128       20       20 |  26214400 |
       48|TIDL_ConcatLayer              |input.132                                         |     0|     2|     1| 47  32   x   x   x   x   x   x | 48       |       1        1        1      128       20       20 |       1        1        1      256       20       20 |    102400 |
       49|TIDL_ConvolutionLayer         |onnx::Conv_183                                    |     0|     1|     1| 48   x   x   x   x   x   x   x | 49       |       1        1        1      256       20       20 |       1        1        1      128       20       20 |  13107200 |
       50|TIDL_ConvolutionLayer         |onnx::Resize_185                                  |     0|     1|     1| 49   x   x   x   x   x   x   x | 50       |       1        1        1      128       20       20 |       1        1        1       64       20       20 |   3276800 |
       51|TIDL_ResizeLayer              |onnx::Concat_190                                  |     0|     1|     1| 50   x   x   x   x   x   x   x | 51       |       1        1        1       64       20       20 |       1        1        1       64       40       40 |    409600 |
       52|TIDL_ConcatLayer              |input.148                                         |     0|     2|     1| 25  51   x   x   x   x   x   x | 52       |       1        1        1       64       40       40 |       1        1        1      128       40       40 |    204800 |
       53|TIDL_ConvolutionLayer         |onnx::Conv_197                                    |     0|     1|     1| 52   x   x   x   x   x   x   x | 53       |       1        1        1      128       40       40 |       1        1        1       32       40       40 |   6553600 |
       54|TIDL_ConvolutionLayer         |onnx::Concat_195                                  |     0|     1|     1| 52   x   x   x   x   x   x   x | 54       |       1        1        1      128       40       40 |       1        1        1       32       40       40 |   6553600 |
       55|TIDL_ConvolutionLayer         |onnx::Conv_199                                    |     0|     1|     1| 53   x   x   x   x   x   x   x | 55       |       1        1        1       32       40       40 |       1        1        1       32       40       40 |  14745600 |
       56|TIDL_ConvolutionLayer         |onnx::Concat_201                                  |     0|     1|     1| 55   x   x   x   x   x   x   x | 56       |       1        1        1       32       40       40 |       1        1        1       32       40       40 |  14745600 |
       57|TIDL_ConcatLayer              |input.168                                         |     0|     4|     1| 56  55  53  54   x   x   x   x | 57       |       1        1        1       32       40       40 |       1        1        1      128       40       40 |    204800 |
       58|TIDL_ConvolutionLayer         |onnx::Conv_204                                    |     0|     1|     1| 57   x   x   x   x   x   x   x | 58       |       1        1        1      128       40       40 |       1        1        1       64       40       40 |  13107200 |
       59|TIDL_ConvolutionLayer         |onnx::Resize_206                                  |     0|     1|     1| 58   x   x   x   x   x   x   x | 59       |       1        1        1       64       40       40 |       1        1        1       32       40       40 |   3276800 |
       60|TIDL_ResizeLayer              |onnx::Concat_211                                  |     0|     1|     1| 59   x   x   x   x   x   x   x | 60       |       1        1        1       32       40       40 |       1        1        1       32       80       80 |    819200 |
       61|TIDL_ConcatLayer              |input.184                                         |     0|     2|     1| 17  60   x   x   x   x   x   x | 61       |       1        1        1       32       80       80 |       1        1        1       64       80       80 |    409600 |
       62|TIDL_ConvolutionLayer         |onnx::Conv_218                                    |     0|     1|     1| 61   x   x   x   x   x   x   x | 62       |       1        1        1       64       80       80 |       1        1        1       16       80       80 |   6553600 |
       63|TIDL_ConvolutionLayer         |onnx::Concat_216                                  |     0|     1|     1| 61   x   x   x   x   x   x   x | 63       |       1        1        1       64       80       80 |       1        1        1       16       80       80 |   6553600 |
       64|TIDL_ConvolutionLayer         |onnx::Conv_220                                    |     0|     1|     1| 62   x   x   x   x   x   x   x | 64       |       1        1        1       16       80       80 |       1        1        1       16       80       80 |  14745600 |
       65|TIDL_ConvolutionLayer         |onnx::Concat_222                                  |     0|     1|     1| 64   x   x   x   x   x   x   x | 65       |       1        1        1       16       80       80 |       1        1        1       16       80       80 |  14745600 |
       66|TIDL_ConcatLayer              |input.204                                         |     0|     4|     1| 65  64  62  63   x   x   x   x | 66       |       1        1        1       16       80       80 |       1        1        1       64       80       80 |    409600 |
       67|TIDL_ConvolutionLayer         |onnx::Conv_225                                    |     0|     1|     1| 66   x   x   x   x   x   x   x | 67       |       1        1        1       64       80       80 |       1        1        1       32       80       80 |  13107200 |
       68|TIDL_ConvolutionLayer         |onnx::Concat_227                                  |     0|     1|     1| 67   x   x   x   x   x   x   x | 68       |       1        1        1       32       80       80 |       1        1        1       64       40       40 |  29491200 |
       69|TIDL_ConcatLayer              |input.216                                         |     0|     2|     1| 68  58   x   x   x   x   x   x | 69       |       1        1        1       64       40       40 |       1        1        1      128       40       40 |    204800 |
       70|TIDL_ConvolutionLayer         |onnx::Conv_232                                    |     0|     1|     1| 69   x   x   x   x   x   x   x | 70       |       1        1        1      128       40       40 |       1        1        1       32       40       40 |   6553600 |
       71|TIDL_ConvolutionLayer         |onnx::Concat_230                                  |     0|     1|     1| 69   x   x   x   x   x   x   x | 71       |       1        1        1      128       40       40 |       1        1        1       32       40       40 |   6553600 |
       72|TIDL_ConvolutionLayer         |onnx::Conv_234                                    |     0|     1|     1| 70   x   x   x   x   x   x   x | 72       |       1        1        1       32       40       40 |       1        1        1       32       40       40 |  14745600 |
       73|TIDL_ConvolutionLayer         |onnx::Concat_236                                  |     0|     1|     1| 72   x   x   x   x   x   x   x | 73       |       1        1        1       32       40       40 |       1        1        1       32       40       40 |  14745600 |
       74|TIDL_ConcatLayer              |input.236                                         |     0|     4|     1| 73  72  70  71   x   x   x   x | 74       |       1        1        1       32       40       40 |       1        1        1      128       40       40 |    204800 |
       75|TIDL_ConvolutionLayer         |onnx::Conv_239                                    |     0|     1|     1| 74   x   x   x   x   x   x   x | 75       |       1        1        1      128       40       40 |       1        1        1       64       40       40 |  13107200 |
       76|TIDL_ConvolutionLayer         |onnx::Concat_241                                  |     0|     1|     1| 75   x   x   x   x   x   x   x | 76       |       1        1        1       64       40       40 |       1        1        1      128       20       20 |  29491200 |
       77|TIDL_ConcatLayer              |input.248                                         |     0|     2|     1| 76  49   x   x   x   x   x   x | 77       |       1        1        1      128       20       20 |       1        1        1      256       20       20 |    102400 |
       78|TIDL_ConvolutionLayer         |onnx::Conv_246                                    |     0|     1|     1| 77   x   x   x   x   x   x   x | 78       |       1        1        1      256       20       20 |       1        1        1       64       20       20 |   6553600 |
       79|TIDL_ConvolutionLayer         |onnx::Concat_244                                  |     0|     1|     1| 77   x   x   x   x   x   x   x | 79       |       1        1        1      256       20       20 |       1        1        1       64       20       20 |   6553600 |
       80|TIDL_ConvolutionLayer         |onnx::Conv_248                                    |     0|     1|     1| 78   x   x   x   x   x   x   x | 80       |       1        1        1       64       20       20 |       1        1        1       64       20       20 |  14745600 |
       81|TIDL_ConvolutionLayer         |onnx::Concat_250                                  |     0|     1|     1| 80   x   x   x   x   x   x   x | 81       |       1        1        1       64       20       20 |       1        1        1       64       20       20 |  14745600 |
       82|TIDL_ConcatLayer              |input.268                                         |     0|     4|     1| 81  80  78  79   x   x   x   x | 82       |       1        1        1       64       20       20 |       1        1        1      256       20       20 |    102400 |
       83|TIDL_ConvolutionLayer         |onnx::Conv_253                                    |     0|     1|     1| 82   x   x   x   x   x   x   x | 83       |       1        1        1      256       20       20 |       1        1        1      128       20       20 |  13107200 |
       84|TIDL_ConvolutionLayer         |onnx::Conv_255                                    |     0|     1|     1| 83   x   x   x   x   x   x   x | 84       |       1        1        1      128       20       20 |       1        1        1      256       20       20 | 117964800 |
       85|TIDL_ConvolutionLayer         |onnx::Sigmoid_256                                 |     0|     1|     1| 84   x   x   x   x   x   x   x | 85       |       1        1        1      256       20       20 |       1        1        1       24       20       20 |   2457600 |
       86|TIDL_BatchNormLayer           |output1                                           |     0|     1|     1| 85   x   x   x   x   x   x   x | 86       |       1        1        1       24       20       20 |       1        1        1       24       20       20 |      9600 |
       87|TIDL_DataLayer                |output1                                           |     0|     1|    -1| 86   x   x   x   x   x   x   x |  0       |       1        1        1       24       20       20 |       0        0        0        0        0        0 |         0 |
    Total Giga Macs : 1.4233
    -------- Running Calibration in Float Mode to Collect Tensor Statistics --------
    cd /home/ht/edgeai/edgeai-tidl-tools/tools/AM68A/tidl_tools && ./PC_dsp_test_dl_algo.out s:/home/ht/customers/longhorn/yolov7/output/import.txt.qunat_stats_config.txt
    Input : dataId=0, name=images, elementType 6, scale=1.000000, zero point=0, layout=0
    Ouput : dataId=86, name=output1, elementType 6, scale=1.000000, zero point=0, layout=0
         42227128,     40.271 0x7dfe142bd010
    worstCaseDelay for Pre-emption is 0.0000000
    Network File Read done
    Calling algAlloc
    TIDL Memory size requiement (record wise):
    MemRecNum   , Space               , Attribute   , Alignment   , Size(KBytes), BasePtr
    0           , DDR Cacheable       , Persistent  ,  128, 19.27   , 0x00000000
    1           , DDR Cacheable       , Persistent  ,  128, 0.66    , 0x00000000
    2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x00000000
    3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x00000000
    4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x00000000
    5           , DDR Cacheable       , Persistent  ,  128, 312.59  , 0x00000000
    6           , DDR Cacheable       , Scratch     ,  128, 23969.06, 0x00000000
    7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x00000000
    8           , DDR Cacheable       , Scratch     ,  128, 25600.12, 0x00000000
    9           , DDR Cacheable       , Scratch     ,  128, 12963.38, 0x00000000
    10          , DDR Cacheable       , Persistent  ,  128, 1060.44 , 0x00000000
    11          , DDR Cacheable       , Scratch     ,  128, 4096.25 , 0x00000000
    12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x00000000
    13          , DDR Cacheable       , Persistent  ,  128, 41237.55, 0x00000000
    14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x00000000
    15          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x00000000
    Total memory size requirement (space wise):
    Mem Space , Size(KBytes)
    DDR Cacheable, 109335.70
    NOTE: Memory requirement in host emulation can be different from the same on EVM
          To get the actual TIDL memory requirement make sure to run on EVM with
          debugTraceLevel = 2
    Num,    Space,     SizeinBytes,   SineInMB
       0,    17,        19736,      0.019 0x60f573c62d00
       1,    17,          672,      0.001 0x60f573c67a80
       2,    17,        16384,      0.016 0x60f573c67e00
       3,    17,         4096,      0.004 0x60f573c6be80
       4,    17,        57344,      0.055 0x60f573c6cf80
       5,    17,       320096,      0.305 0x7dfeaacc3080
       6,    17,     24544320,     23.407 0x7dfe12b54080
       7,    17,          128,      0.000 0x60f573c61b00
       8,    17,     26214528,     25.000 0x7dfe11253080
       9,    17,     13274496,     12.660 0x7dfe105aa080
      10,    17,      1085888,      1.036 0x7dfe104a0080
      11,    17,      4194560,      4.000 0x7dfe1009f080
      12,    17,          128,      0.000 0x60f573c61c00
      13,    17,     42227256,     40.271 0x7dfe0d859080
      14,    17,            1,      0.000 0x60f573c7b000
      15,    17,          128,      0.000 0x60f573c7b100
    Total External Memory (DDR) Size =    111959761,    106.773
    TIDL init call from ivision API
    0           , DDR Cacheable       , Persistent  ,  128, 19.27   , 0x73c62d00
    1           , DDR Cacheable       , Persistent  ,  128, 0.66    , 0x73c67a80
    2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x73c67e00
    3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x73c6be80
    4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x73c6cf80
    5           , DDR Cacheable       , Persistent  ,  128, 312.59  , 0xaacc3080
    6           , DDR Cacheable       , Scratch     ,  128, 23969.06, 0x12b54080
    7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x73c61b00
    8           , DDR Cacheable       , Scratch     ,  128, 25600.12, 0x11253080
    9           , DDR Cacheable       , Scratch     ,  128, 12963.38, 0x105aa080
    10          , DDR Cacheable       , Persistent  ,  128, 1060.44 , 0x104a0080
    11          , DDR Cacheable       , Scratch     ,  128, 4096.25 , 0x1009f080
    12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x73c61c00
    13          , DDR Cacheable       , Persistent  ,  128, 41237.55, 0x0d859080
    14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x73c7b000
    15          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x73c7b100
          debugTraceLevel = 2
    Alg Init for Layer # -    1
    Alg Init for Layer # -    2
    Alg Init for Layer # -    3
    Alg Init for Layer # -    4
    Alg Init for Layer # -    5
    Alg Init for Layer # -    6
    Alg Init for Layer # -    7
    Alg Init for Layer # -    8
    Alg Init for Layer # -    9
    Alg Init for Layer # -   10
    Alg Init for Layer # -   11
    Alg Init for Layer # -   12
    Alg Init for Layer # -   13
    Alg Init for Layer # -   14
    Alg Init for Layer # -   15
    Alg Init for Layer # -   16
    Alg Init for Layer # -   17
    Alg Init for Layer # -   18
    Alg Init for Layer # -   19
    Alg Init for Layer # -   20
    Alg Init for Layer # -   21
    Alg Init for Layer # -   22
    Alg Init for Layer # -   23
    Alg Init for Layer # -   24
    Alg Init for Layer # -   25
    Alg Init for Layer # -   26
    Alg Init for Layer # -   27
    Alg Init for Layer # -   28
    Alg Init for Layer # -   29
    Alg Init for Layer # -   30
    Alg Init for Layer # -   31
    Alg Init for Layer # -   32
    Alg Init for Layer # -   33
    Alg Init for Layer # -   34
    Alg Init for Layer # -   35
    Alg Init for Layer # -   36
    Alg Init for Layer # -   37
    Alg Init for Layer # -   38
    Alg Init for Layer # -   39
    Alg Init for Layer # -   40
    Alg Init for Layer # -   41
    Alg Init for Layer # -   42
    Alg Init for Layer # -   43
    Alg Init for Layer # -   44
    Alg Init for Layer # -   45
    Alg Init for Layer # -   46
    Alg Init for Layer # -   47
    Alg Init for Layer # -   48
    Alg Init for Layer # -   49
    Alg Init for Layer # -   50
    Alg Init for Layer # -   51
    Alg Init for Layer # -   52
    Alg Init for Layer # -   53
    Alg Init for Layer # -   54
    Alg Init for Layer # -   55
    Alg Init for Layer # -   56
    Alg Init for Layer # -   57
    Alg Init for Layer # -   58
    Alg Init for Layer # -   59
    Alg Init for Layer # -   60
    Alg Init for Layer # -   61
    Alg Init for Layer # -   62
    Alg Init for Layer # -   63
    Alg Init for Layer # -   64
    Alg Init for Layer # -   65
    Alg Init for Layer # -   66
    Alg Init for Layer # -   67
    Alg Init for Layer # -   68
    Alg Init for Layer # -   69
    Alg Init for Layer # -   70
    Alg Init for Layer # -   71
    Alg Init for Layer # -   72
    Alg Init for Layer # -   73
    Alg Init for Layer # -   74
    Alg Init for Layer # -   75
    Alg Init for Layer # -   76
    Alg Init for Layer # -   77
    Alg Init for Layer # -   78
    Alg Init for Layer # -   79
    Alg Init for Layer # -   80
    Alg Init for Layer # -   81
    Alg Init for Layer # -   82
    Alg Init for Layer # -   83
    Alg Init for Layer # -   84
    Alg Init for Layer # -   85
    Alg Init for Layer # -   86
     Freeing memory for user provided Net
     Instance created for  /home/ht/customers/longhorn/yolov7/output/import.txt.qunat_stats_config.txt
    Processing Cnt :    0, InstCnt :    0 /home/ht/customers/longhorn/yolov7/output/yolov7_net.bin!
    TIDL_RT: Set default TIDLRT tensor done
        13189216,     12.578 0x7dfe15823010
          160000,      0.153 0x60f573c9d230
    TIDL_process is started with handle : 0x60f573c62d00 =========================] 100 %
    TIDL_activate is called with handle : 0x60f573c62d00 - Copying handle of size 19736 from 0x60f573c62d00 to 0x60f573c6d000
    Core 0 Alg Process for Layer # -    0, layer type 0
    Core 0 Alg Process for Layer # -    1, layer type 1
    Processing Layer # -    1
    Core 0 End of Layer # -    1 with outPtrs[0] = 0x7dfe12b54080
    Core 0 Alg Process for Layer # -    2, layer type 1
    Processing Layer # -    2
    Core 0 End of Layer # -    2 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -    3, layer type 1
    Processing Layer # -    3
    Core 0 End of Layer # -    3 with outPtrs[0] = 0x7dfe12b54080
    Core 0 Alg Process for Layer # -    4, layer type 1
    Processing Layer # -    4
    Core 0 End of Layer # -    4 with outPtrs[0] = 0x7dfe134c8300
    Core 0 Alg Process for Layer # -    5, layer type 1
    Core 0 End of Layer # -    5 with outPtrs[0] = 0x7dfe13658380
    Core 0 Alg Process for Layer # -    6, layer type 1
    Core 0 End of Layer # -    6 with outPtrs[0] = 0x7dfe137f2500
    Core 0 Alg Process for Layer # -    7, layer type 12
    Core 0 End of Layer # -    7 with outPtrs[0] = 0x7dfe13982580
    Core 0 Alg Process for Layer # -    8, layer type 1
    Core 0 End of Layer # -    8 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -    9, layer type 2
    Processing Layer # -    9
    Core 0 End of Layer # -    9 with outPtrs[0] = 0x7dfe134c8300
    Core 0 Alg Process for Layer # -   10, layer type 1
    Processing Layer # -   10
    Core 0 End of Layer # -   10 with outPtrs[0] = 0x7dfe13658380
    Core 0 Alg Process for Layer # -   11, layer type 1
    Processing Layer # -   11
    Core 0 End of Layer # -   11 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   12, layer type 1
    Processing Layer # -   12
    Core 0 End of Layer # -   12 with outPtrs[0] = 0x7dfe12b54080
    Core 0 Alg Process for Layer # -   13, layer type 1
    Processing Layer # -   13
    Core 0 End of Layer # -   13 with outPtrs[0] = 0x7dfe134c8300
    Core 0 Alg Process for Layer # -   14, layer type 12
    Processing Layer # -   14
    Core 0 End of Layer # -   14 with outPtrs[0] = 0x7dfe13982580
    Core 0 Alg Process for Layer # -   15, layer type 1
    Processing Layer # -   15
    Core 0 End of Layer # -   15 with outPtrs[0] = 0x7dfe137f2500
    Core 0 Alg Process for Layer # -   16, layer type 2
    Processing Layer # -   16
    Core 0 End of Layer # -   16 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   17, layer type 1
    Processing Layer # -   17
    Core 0 End of Layer # -   17 with outPtrs[0] = 0x7dfe134c8300
    Core 0 Alg Process for Layer # -   18, layer type 1
    Processing Layer # -   18
    Core 0 End of Layer # -   18 with outPtrs[0] = 0x7dfe12b54080
    Core 0 Alg Process for Layer # -   19, layer type 1
    Processing Layer # -   19
    Core 0 End of Layer # -   19 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 Alg Process for Layer # -   20, layer type 1
    Processing Layer # -   20
    Core 0 End of Layer # -   20 with outPtrs[0] = 0x7dfe14026c00
    Core 0 Alg Process for Layer # -   21, layer type 1
    Processing Layer # -   21
    Core 0 End of Layer # -   21 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   22, layer type 12
    Processing Layer # -   22
    Core 0 End of Layer # -   22 with outPtrs[0] = 0x7dfe13982580
    Core 0 Alg Process for Layer # -   23, layer type 1
    Processing Layer # -   23
    Core 0 End of Layer # -   23 with outPtrs[0] = 0x7dfe137f2500
    Core 0 Alg Process for Layer # -   24, layer type 2
    Processing Layer # -   24
    Core 0 End of Layer # -   24 with outPtrs[0] = 0x7dfe14095100
    Core 0 Alg Process for Layer # -   25, layer type 1
    Processing Layer # -   25
    Core 0 End of Layer # -   25 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 Alg Process for Layer # -   26, layer type 1
    Processing Layer # -   26
    Core 0 End of Layer # -   26 with outPtrs[0] = 0x7dfe140c7200
    Core 0 Alg Process for Layer # -   27, layer type 1
    Processing Layer # -   27
    Core 0 End of Layer # -   27 with outPtrs[0] = 0x7dfe14103880
    Core 0 Alg Process for Layer # -   28, layer type 1
    Processing Layer # -   28
    Core 0 End of Layer # -   28 with outPtrs[0] = 0x7dfe14135900
    Core 0 Alg Process for Layer # -   29, layer type 1
    Processing Layer # -   29
    Core 0 End of Layer # -   29 with outPtrs[0] = 0x7dfe14095100
    Core 0 Alg Process for Layer # -   30, layer type 12
    Processing Layer # -   30
    Core 0 End of Layer # -   30 with outPtrs[0] = 0x7dfe137f2500
    Core 0 Alg Process for Layer # -   31, layer type 1
    Processing Layer # -   31
    Core 0 End of Layer # -   31 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   32, layer type 1
    Processing Layer # -   32
    Core 0 End of Layer # -   32 with outPtrs[0] = 0x7dfe14103880
    Core 0 Alg Process for Layer # -   33, layer type 1
    Processing Layer # -   33
    Core 0 End of Layer # -   33 with outPtrs[0] = 0x7dfe14135900
    Core 0 Alg Process for Layer # -   34, layer type 2
    Processing Layer # -   34
    Core 0 End of Layer # -   34 with outPtrs[0] = 0x7dfe140c7200
    Core 0 Alg Process for Layer # -   35, layer type 2
    Processing Layer # -   35
    Core 0 End of Layer # -   35 with outPtrs[0] = 0x7dfe14172280
    Core 0 Alg Process for Layer # -   36, layer type 2
    Processing Layer # -   36
    Core 0 End of Layer # -   36 with outPtrs[0] = 0x7dfe141ae900
    Core 0 Alg Process for Layer # -   37, layer type 2
    Processing Layer # -   37
    Core 0 End of Layer # -   37 with outPtrs[0] = 0x7dfe14095100
    Core 0 Alg Process for Layer # -   38, layer type 2
    Processing Layer # -   38
    Core 0 End of Layer # -   38 with outPtrs[0] = 0x7dfe140c7200
    Core 0 Alg Process for Layer # -   39, layer type 2
    Processing Layer # -   39
    Core 0 End of Layer # -   39 with outPtrs[0] = 0x7dfe14172280
    Core 0 Alg Process for Layer # -   40, layer type 2
    Processing Layer # -   40
    Core 0 End of Layer # -   40 with outPtrs[0] = 0x7dfe141ae900
    Core 0 Alg Process for Layer # -   41, layer type 2
    Processing Layer # -   41
    Core 0 End of Layer # -   41 with outPtrs[0] = 0x7dfe140c7200
    Core 0 Alg Process for Layer # -   42, layer type 2
    Processing Layer # -   42
    Core 0 End of Layer # -   42 with outPtrs[0] = 0x7dfe141eb200
    Core 0 Alg Process for Layer # -   43, layer type 2
    Processing Layer # -   43
    Core 0 End of Layer # -   43 with outPtrs[0] = 0x7dfe141ae900
    Core 0 Alg Process for Layer # -   44, layer type 2
    Processing Layer # -   44
    Core 0 End of Layer # -   44 with outPtrs[0] = 0x7dfe14172280
    Core 0 Alg Process for Layer # -   45, layer type 2
    Processing Layer # -   45
    Core 0 End of Layer # -   45 with outPtrs[0] = 0x7dfe1421d380
    Core 0 Alg Process for Layer # -   46, layer type 12
    Processing Layer # -   46
    Core 0 End of Layer # -   46 with outPtrs[0] = 0x7dfe137f2500
    Core 0 Alg Process for Layer # -   47, layer type 1
    Processing Layer # -   47
    Core 0 End of Layer # -   47 with outPtrs[0] = 0x7dfe1421d380
    Core 0 Alg Process for Layer # -   48, layer type 12
    Processing Layer # -   48
    Core 0 End of Layer # -   48 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   49, layer type 1
    Processing Layer # -   49
    Core 0 End of Layer # -   49 with outPtrs[0] = 0x7dfe1421d380
    Core 0 Alg Process for Layer # -   50, layer type 1
    Processing Layer # -   50
    Core 0 End of Layer # -   50 with outPtrs[0] = 0x7dfe14135900
    Core 0 Alg Process for Layer # -   51, layer type 21
    Processing Layer # -   51
    Core 0 End of Layer # -   51 with outPtrs[0] = 0x7dfe131a8200
    Core 0 Alg Process for Layer # -   52, layer type 12
    Processing Layer # -   52
    Core 0 End of Layer # -   52 with outPtrs[0] = 0x7dfe137f2500
    Core 0 End of Layer # -   53 with outPtrs[0] = 0x7dfe141ae900
    Core 0 End of Layer # -   54 with outPtrs[0] = 0x7dfe141eb200
    Core 0 End of Layer # -   55 with outPtrs[0] = 0x7dfe14172280
    Core 0 End of Layer # -   56 with outPtrs[0] = 0x7dfe14103880
    Core 0 End of Layer # -   57 with outPtrs[0] = 0x7dfe137f2500
    Core 0 End of Layer # -   58 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 End of Layer # -   59 with outPtrs[0] = 0x7dfe141ae900
    Core 0 End of Layer # -   60 with outPtrs[0] = 0x7dfe137f2500
    Core 0 End of Layer # -   61 with outPtrs[0] = 0x7dfe13982580
    Core 0 End of Layer # -   62 with outPtrs[0] = 0x7dfe12b54080
    Core 0 End of Layer # -   63 with outPtrs[0] = 0x7dfe137f2500
    Core 0 End of Layer # -   64 with outPtrs[0] = 0x7dfe1424fd00
    Core 0 End of Layer # -   65 with outPtrs[0] = 0x7dfe134c8300
    Core 0 End of Layer # -   66 with outPtrs[0] = 0x7dfe13982580
    Core 0 End of Layer # -   67 with outPtrs[0] = 0x7dfe13658380
    Core 0 End of Layer # -   68 with outPtrs[0] = 0x7dfe137f2500
    Core 0 End of Layer # -   69 with outPtrs[0] = 0x7dfe13982580
    Core 0 End of Layer # -   70 with outPtrs[0] = 0x7dfe141ae900
    Core 0 End of Layer # -   71 with outPtrs[0] = 0x7dfe141eb200
    Core 0 End of Layer # -   72 with outPtrs[0] = 0x7dfe14172280
    Core 0 End of Layer # -   73 with outPtrs[0] = 0x7dfe14103880
    Core 0 End of Layer # -   74 with outPtrs[0] = 0x7dfe13982580
    Core 0 End of Layer # -   75 with outPtrs[0] = 0x7dfe14026c00
    Core 0 End of Layer # -   76 with outPtrs[0] = 0x7dfe141eb200
    Core 0 End of Layer # -   77 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 End of Layer # -   78 with outPtrs[0] = 0x7dfe141ae900
    Core 0 End of Layer # -   79 with outPtrs[0] = 0x7dfe1421d380
    Core 0 End of Layer # -   80 with outPtrs[0] = 0x7dfe14172280
    Core 0 End of Layer # -   81 with outPtrs[0] = 0x7dfe141eb200
    Core 0 End of Layer # -   82 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 End of Layer # -   83 with outPtrs[0] = 0x7dfe1424fd00
    Core 0 End of Layer # -   84 with outPtrs[0] = 0x7dfe13fc2b80
    Core 0 End of Layer # -   85 with outPtrs[0] = 0x7dfe1421d380
    Core 0 End of Layer # -   86 with outPtrs[0] = 0x60f573c9d230
    TIDL_process is completed with handle : 0x60f573c62d00
    TIDL_deactivate is called with handle : 0x60f573c62d00 - Copying handle of size 19736 from 0x60f573c6d000 to 0x60f573c62d00
    ------------------ Fixed-point Calibration Iteration [1 / 1]: ------------------
    Input : dataId=0, name=images, elementType 0, scale=1.000000, zero point=0, layout=0
    Ouput : dataId=86, name=output1, elementType 2, scale=56258.375000, zero point=0, layout=0
         38324152,     36.549 0x7fa493e76010
    Calling algAlloc
    5           , DDR Cacheable       , Persistent  ,  128, 317.64  , 0x00000000
    6           , DDR Cacheable       , Scratch     ,  128, 7358.58 , 0x00000000
    8           , DDR Cacheable       , Scratch     ,  128, 9720.50 , 0x00000000
    9           , DDR Cacheable       , Scratch     ,  128, 3243.09 , 0x00000000
    13          , DDR Cacheable       , Persistent  ,  128, 37426.05, 0x00000000
    DDR Cacheable, 63318.86
          debugTraceLevel = 2
       0,    17,        19736,      0.019 0x639e69529880
       1,    17,          672,      0.001 0x639e6952e680
       2,    17,        16384,      0.016 0x639e6952ea00
       3,    17,         4096,      0.004 0x639e69532a80
       4,    17,        57344,      0.055 0x639e69533b80
       5,    17,       325264,      0.310 0x7fa52a435080
       6,    17,      7535184,      7.186 0x7fa493746080
       7,    17,          128,      0.000 0x639e69528700
       8,    17,      9953792,      9.493 0x7fa492dc7080
       9,    17,      3320928,      3.167 0x7fa492a9c080
      10,    17,      1085888,      1.036 0x7fa492992080
      11,    17,      4194560,      4.000 0x7fa492591080
      12,    17,          128,      0.000 0x639e69528880
      13,    17,     38324280,     36.549 0x7fa490104080
      14,    17,            1,      0.000 0x639e69541c00
      15,    17,          128,      0.000 0x639e69541d00
    Total External Memory (DDR) Size =     64838513,     61.835
    0           , DDR Cacheable       , Persistent  ,  128, 19.27   , 0x69529880
    1           , DDR Cacheable       , Persistent  ,  128, 0.66    , 0x6952e680
    2           , DDR Cacheable       , Scratch     ,  128, 16.00   , 0x6952ea00
    3           , DDR Cacheable       , Scratch     ,  128, 4.00    , 0x69532a80
    4           , DDR Cacheable       , Scratch     ,  128, 56.00   , 0x69533b80
    5           , DDR Cacheable       , Persistent  ,  128, 317.64  , 0x2a435080
    6           , DDR Cacheable       , Scratch     ,  128, 7358.58 , 0x93746080
    7           , DDR Cacheable       , Scratch     ,  128, 0.12    , 0x69528700
    8           , DDR Cacheable       , Scratch     ,  128, 9720.50 , 0x92dc7080
    9           , DDR Cacheable       , Scratch     ,  128, 3243.09 , 0x92a9c080
    10          , DDR Cacheable       , Persistent  ,  128, 1060.44 , 0x92992080
    11          , DDR Cacheable       , Scratch     ,  128, 4096.25 , 0x92591080
    12          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x69528880
    13          , DDR Cacheable       , Persistent  ,  128, 37426.05, 0x90104080
    14          , DDR Cacheable       , Persistent  ,  128, 0.00    , 0x69541c00
    15          , DDR Cacheable       , Persistent  ,  128, 0.12    , 0x69541d00
          debugTraceLevel = 2
         3297304,      3.145 0x7fa495e4a010
           40000,      0.038 0x639e6955f320
    TIDL_process is started with handle : 0x639e69529880 =========================] 100 %
    TIDL_activate is called with handle : 0x639e69529880 - Copying handle of size 19736 from 0x639e69529880 to 0x639e69533c00
    Core 0 End of Layer # -    1 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -    2 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -    3 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -    4 with outPtrs[0] = 0x7fa4939a3280
    Core 0 End of Layer # -    5 with outPtrs[0] = 0x7fa493a07300
    Core 0 End of Layer # -    6 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -    7 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -    8 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -    9 with outPtrs[0] = 0x7fa4939a3280
    Core 0 End of Layer # -   10 with outPtrs[0] = 0x7fa493a07300
    Core 0 End of Layer # -   11 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   12 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -   13 with outPtrs[0] = 0x7fa4939a3280
    Core 0 End of Layer # -   14 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   15 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   16 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   17 with outPtrs[0] = 0x7fa4939a3280
    Core 0 End of Layer # -   18 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -   19 with outPtrs[0] = 0x7fa493d8e280
    Core 0 End of Layer # -   20 with outPtrs[0] = 0x7fa493da7300
    Core 0 End of Layer # -   21 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   22 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   23 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   24 with outPtrs[0] = 0x7fa493dc2e00
    Core 0 End of Layer # -   25 with outPtrs[0] = 0x7fa493d8e280
    Core 0 End of Layer # -   26 with outPtrs[0] = 0x7fa493dcf700
    Core 0 End of Layer # -   27 with outPtrs[0] = 0x7fa493dde900
    Core 0 End of Layer # -   28 with outPtrs[0] = 0x7fa493deb180
    Core 0 End of Layer # -   29 with outPtrs[0] = 0x7fa493dc2e00
    Core 0 End of Layer # -   30 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   31 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   32 with outPtrs[0] = 0x7fa493dfa500
    Core 0 End of Layer # -   33 with outPtrs[0] = 0x7fa493deb180
    Core 0 End of Layer # -   34 with outPtrs[0] = 0x7fa493dcf700
    Core 0 End of Layer # -   35 with outPtrs[0] = 0x7fa493e13680
    Core 0 End of Layer # -   36 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   37 with outPtrs[0] = 0x7fa493dde900
    Core 0 End of Layer # -   38 with outPtrs[0] = 0x7fa493dcf700
    Core 0 End of Layer # -   39 with outPtrs[0] = 0x7fa493e13680
    Core 0 End of Layer # -   40 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   41 with outPtrs[0] = 0x7fa493dcf700
    Core 0 End of Layer # -   42 with outPtrs[0] = 0x7fa493dc2e00
    Core 0 End of Layer # -   43 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   44 with outPtrs[0] = 0x7fa493e13680
    Core 0 End of Layer # -   45 with outPtrs[0] = 0x7fa493e31e80
    Core 0 End of Layer # -   46 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   47 with outPtrs[0] = 0x7fa493e3e780
    Core 0 End of Layer # -   48 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   49 with outPtrs[0] = 0x7fa493e3e780
    Core 0 End of Layer # -   50 with outPtrs[0] = 0x7fa493deb180
    Core 0 End of Layer # -   51 with outPtrs[0] = 0x7fa4938db180
    Core 0 End of Layer # -   52 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   53 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   54 with outPtrs[0] = 0x7fa493e31e80
    Core 0 End of Layer # -   55 with outPtrs[0] = 0x7fa493e13680
    Core 0 End of Layer # -   56 with outPtrs[0] = 0x7fa493dfa500
    Core 0 End of Layer # -   57 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   58 with outPtrs[0] = 0x7fa493d8e280
    Core 0 End of Layer # -   59 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   60 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   61 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   62 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -   63 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   64 with outPtrs[0] = 0x7fa493e58000
    Core 0 End of Layer # -   65 with outPtrs[0] = 0x7fa4939a3280
    Core 0 End of Layer # -   66 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   67 with outPtrs[0] = 0x7fa493a07300
    Core 0 End of Layer # -   68 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   69 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   70 with outPtrs[0] = 0x7fa493a07300
    Core 0 End of Layer # -   71 with outPtrs[0] = 0x7fa493dfa500
    Core 0 End of Layer # -   72 with outPtrs[0] = 0x7fa493746080
    Core 0 End of Layer # -   73 with outPtrs[0] = 0x7fa493a6dc80
    Core 0 End of Layer # -   74 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   75 with outPtrs[0] = 0x7fa493da7300
    Core 0 End of Layer # -   76 with outPtrs[0] = 0x7fa493e31e80
    Core 0 End of Layer # -   77 with outPtrs[0] = 0x7fa493d8e280
    Core 0 End of Layer # -   78 with outPtrs[0] = 0x7fa493e22880
    Core 0 End of Layer # -   79 with outPtrs[0] = 0x7fa493e3e780
    Core 0 End of Layer # -   80 with outPtrs[0] = 0x7fa493e13680
    Core 0 End of Layer # -   81 with outPtrs[0] = 0x7fa493e31e80
    Core 0 End of Layer # -   82 with outPtrs[0] = 0x7fa493bfdd00
    Core 0 End of Layer # -   83 with outPtrs[0] = 0x7fa493e58000
    Core 0 End of Layer # -   84 with outPtrs[0] = 0x7fa493d8e280
    Core 0 End of Layer # -   85 with outPtrs[0] = 0x7fa493e3e780
    Core 0 End of Layer # -   86 with outPtrs[0] = 0x639e6955f320
    TIDL_process is completed with handle : 0x639e69529880
    TIDL_deactivate is called with handle : 0x639e69529880 - Copying handle of size 19736 from 0x639e69533c00 to 0x639e69529880
    ==================== [Quantization & Calibration Completed] ====================
    cd /home/ht/edgeai/edgeai-tidl-tools/tools/AM68A/tidl_tools && ./ti_cnnperfsim.out /home/ht/customers/longhorn/yolov7/output/import.txt.perf_sim_config.txt /tmp 83887681 0 2
    buf(1), offset(  980160), size( 1751280)
    buf(3), offset( 2731456), size(  677936)
    Rerunning network compiler...
    /home/ht/edgeai/edgeai-tidl-tools/tools/AM68A/tidl_tools/tidl_graphVisualiser.out output/yolov7_net.bin
    **               TIDL Model Checker               **
    ======================== Subgraph Compiled Successfully ========================
    I successfully convert the model without errors. Could you try the same on your side? You can download the latest tool from https://github.com/TexasInstruments/edgeai-tidl-tools/tree/11_00_08_00 by running the setup.sh in this repo.
    Here is the generated artifacts:
    4466.artifacts.tar.gz
    Adam
  • yes,i have already tried the version tidl_tools 11000800, and it indeed can convert the model and without erros.
    so i tried to convert another model for segment task. but it  gets a core dump with this version. I think it's because your tidl_tools.tar.gz did not contain the "tidl_dump.out "file so, my file is used version 10.00.02.00 and lead this problem
    but i have convert 3 other models without this "tidl_dump.out" cmd
    so i not sure why this segment model would triggle this part of cmd?
    the io file and net file have been generate. can this two file be use or not?
  • Hi
    tidl_dump.out is not necessary as it only decodes the generated bin files to a txt file for easy reading. Your issue comes from using different c7 firmware version and tidl tool version. For a quick test, I suggest you use tidl tools 11_00_06_00 and sdk version 11.0. If that works, we can help with tidl backporting.
    I think these two files can be used if your evm is with correct c7xmma firmware.
    Adam
  • ok, thank you for your suggestion and we will tried to update our tidl version to 11
