I use EVM to run the demo code and find the error message about video capture. It seems when I use capture, encode, and decode at the same time, the below message will appear and the DSP will crash. Do you have any idea ? Thanks.
[m3vpss ] 36033932: CAPTURE: Fields = 435707 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 37833943: CAPTURE: Fields = 435707 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 39633958: CAPTURE: Fields = 435708 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 41433959: CAPTURE: Fields = 435703 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 43233969: CAPTURE: Fields = 435711 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 45033973: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 46833974: CAPTURE: Fields = 435706 (fps = 242), Total Resets = 0 (Avg 0 ms per reset)
[m3vpss ] 48013798: CAPTURE: Overflow detected on VIP0, Total Resets = 1
[m3vpss ] 48013805: DEI : Loading Up-scaling Co-effs
[m3vpss ] 48013806: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] 48633987: CAPTURE: Fields = 435697 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 50433997: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 52234005: CAPTURE: Fields = 435710 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 54034011: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 55834012: CAPTURE: Fields = 435707 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 57634013: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 59434022: CAPTURE: Fields = 435710 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 61234023: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 63034027: CAPTURE: Fields = 435703 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 64834037: CAPTURE: Fields = 435708 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 66634040: CAPTURE: Fields = 435706 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 68434050: CAPTURE: Fields = 435708 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 70234058: CAPTURE: Fields = 435707 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 72034065: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 73834066: CAPTURE: Fields = 435707 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 75634067: CAPTURE: Fields = 435706 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 77434082: CAPTURE: Fields = 435708 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 79234088: CAPTURE: Fields = 435704 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
[m3vpss ] 81034104: CAPTURE: Fields = 435710 (fps = 242), Total Resets = 1 (Avg 7 ms per reset)
