Hi expert,
I learned the way to update the MCU firmware in below link:
The question is after building Linux SDK with yocto, i cannt find the same directory.
I want to know if another method is needed to solve it.
Hi expert,
The firmware is pulled from the ti-linux-firmware repository. You can write a bbappend for the ti-dm-fw recipe and patch the ipc_echo_testb_mcu1_0_release_strip.xer5f with your own custom binary.
Jared
After searching, i found 2 recipes:
1.meta-tisdk/recipes-bsp/ti-dm-fw/ti-dm-fw.bbapend
2.meta-ti/meta-ti-bsp/recipes-bsp/ti-dm-fw/ti-dm-fw.bb
Is it enough to only modify the ti-dm-fw recipe?Specifically, is it the ti-dm-fw.bbapend above? or create a new one in other dir?
Yes, you could modify the ti-dm-fw.bbappend to add your custom firmware.
Jared
Thanks a lot.
I renamed my firmware to "ipc_echo_testb_mcu1_0_release_strip.xer5f", and then replaced the original one by modifying the ti-dm-fw.bbappend.
Is it necessary to use the same name---ipc_echo_testb_mcu1_0_release_strip? If I want to use my own firmware name, what needs to be modified?
You will have to change the definition of the DM_FIRMWARE variable through a bbappend:
$ grep -n ipc_echo_testb_mcu1_0_release_strip -r ./* ./meta-ti/meta-ti-bsp/recipes-bsp/ti-dm-fw/ti-dm-fw.bb:41:DM_FIRMWARE = "ipc_echo_testb_mcu1_0_release_strip.xer5f" ./meta-ti/meta-ti-bsp/recipes-bsp/u-boot/u-boot-ti.inc:43:DM_FIRMWARE = "ipc_echo_testb_mcu1_0_release_strip.xer5f"
Jared
