TDA4VM: TDA4VM
Part Number: TDA4VM
Hi team ,
Is it possible to access ISP (VISS) registers  or where to find the register lists of all the parameters of blocks in VISS to understand the mapping ?
Sushma Biradar
  • Hi Sushma,
    https://www.ti.com/lit/zip/spruil1
    TDA4 register manual is included in the TRM package.
  • Hi Gang,
    Thank you for the quick update ,
    Can you please guide me as where to find or understand ISP registers of a particular block mapping to the HW or how is it internally being accessed ?
    Sushma Biradar
  • Hi Sushma,
    Each register has its own physical address as you can see in the register manual and it can be accessed via CPU or DMA.
    I am not sure what this means as I am not familiar with low level details.
    Could you please explain?
  • Hello Gang,
    We were trying to access ISP registers (ex: NSF4 block and its parameters) map them externally and update the values via TCP if possible ,
    so we need information of how internally in SDK the registers are being mapped to their respective parameters
    Sushma Biradar
  • Hi Sushma,
    All ISP register information is available in the TRM package as we discussed above.
    Typically, controlling ISP registers directly and externally is not possible.
    While some cameras are running and using ISP, they will update the ISP registers frame by frame.
    Any other external control of ISP registers would be overridden by the running cameras.
    The way we did similar control in tuning tool is indirect.
    i.e., external control is applied on a camera's tuning data.
    While the camera updates ISP registers before each new image frame, it will use the updated dataset.
  • we need information of how internally in SDK the registers are being mapped to their respective parameters
    This mapping depends on the s/w stack you use, but you probably don't use the TI SDK stack.
    In TI SDK, ISP parameters are separately defined and they are passed to tiovx VPAC kernels to be mapped to PDK driver format before calling PDK driver.
